Please add NVIDIA Quadro P620
fsblank
Post by fsblank »
Name: Nvidia Quadro P620
Device ID: 10DE 1CB6 - 10DE 1264
*********************** Log Started 2018-10-17T07:04:29Z ***********************
07:04:29:************************* Folding@home Client *************************
07:04:29:        Website: https://foldingathome.org/
07:04:29:      Copyright: (c) 2009-2018 foldingathome.org
07:04:29:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:04:29:           Args:
07:04:29:         Config: C:\Users\...\AppData\Roaming\FAHClient\config.xml
07:04:29:******************************** Build ********************************
07:04:29:        Version: 7.5.1
07:04:29:           Date: May 11 2018
07:04:29:           Time: 13:06:32
07:04:29:     Repository: Git
07:04:29:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
07:04:29:         Branch: master
07:04:29:       Compiler: Visual C++ 2008
07:04:29:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:04:29:       Platform: win32 10
07:04:29:           Bits: 32
07:04:29:           Mode: Release
07:04:29:******************************* System ********************************
07:04:29:            CPU: Intel(R) Core(TM) i7-7820X CPU @ 3.60GHz
07:04:29:         CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
07:04:29:           CPUs: 16
07:04:29:         Memory: 31.71GiB
07:04:29:    Free Memory: 29.64GiB
07:04:29:        Threads: WINDOWS_THREADS
07:04:29:     OS Version: 6.2
07:04:29:    Has Battery: false
07:04:29:     On Battery: false
07:04:29:     UTC Offset: 11
07:04:29:            PID: 9404
07:04:29:            CWD: C:\Users\...\AppData\Roaming\FAHClient
07:04:29:             OS: Windows 10 Enterprise
07:04:29:        OS Arch: AMD64
07:04:29:           GPUs: 0
07:04:29:  CUDA Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:6.1 Driver:9.1
07:04:29:OpenCL Device 0: Platform:0 Device:0 Bus:101 Slot:0 Compute:1.2 Driver:391.74
07:04:29:  Win32 Service: false
07:04:29:***********************************************************************
Note: I removed personal details form the the path directories
Re: NVIDIA Quadro P620
This may be slow, about the same as a GTX 1050
here is the latest driver
https://www.nvidia.com/Download/driverR ... 7939/en-us
Good luck!
fsblank
Re: Please add NVIDIA Quadro P620
Post by fsblank »
Probably will be quite slow - it's primary function is to act as a display card for a workstation PC, otherwise it be all but unused.
I just added this GPU.
fsblank wrote:Probably will be quite slow - it's primary function is to act as a display card for a workstation PC, otherwise it be all but unused.
Every contribution to FAH that meets the deadline helps the research. Several of my clients are quite slow.
doctorlexus
Post by doctorlexus »
Does anyone have a ppd estimate for the P620? I saw in another thread someone said the P600 was doing about 65k ppd.
The GPU in P620 is something between a 1030 and a 1050 ... I don't know the PPD of those, but you'll probably find some performance data more easily ...
ProDigit
Post by ProDigit »
P620 is about 3x slower than a GTX970 in benchmarks.
Deducting from those gaming benchmarks, I guess you'd average at around 25k PPD.
A GTX 970 costs $80, and runs close to 75k PPD.
What did you smoke ? As far as I remember, a 970 got 300-350k PPD (since a 1060 which replaced it after its failure gets 350-400k PPD).
ProDigit
Post by ProDigit »
Last results I read were the 1050 got 100k PPD. But if they get more than 300k PPD, I'd be delighted!
Either way, he'll be at 1/3rd of that, closest estimation.
Post by foldy »
ProDigit you mixed up your own numbers ;-)
GTX 970 330k PPD (1664 shaders)
GTX 1050 100k PPD (640 shaders)
Quadro P620 85k PPD (512 shaders)
Quadro P600 65k PPD (384 shaders)
GT 1030 65k PPD (384 shaders)
Answer: Quadro P620 85k PPD
You can calculate the PPD if you compare the shader count.
ProDigit
Post by ProDigit »
Yeah, my mistake;
The GTX970 doesn't cost $80, the GTX960 does.
Probably mistyped in Google, didn't notice, and just copy pasted the results.
