WU getting expired
sago
WU getting expired
Post by sago »
Hi, i've been folding with GPU for a while now and noticed that for my account (^sago^) i've been getting A LOT of expired WU. With my OLD key, i got like 1000 expired WU - which i think it is not possible as i only have my GPU client running now.
To remedy this, i created a NEW key today with the same account (^sago^), and I noticed that now i now got 3 expired WU out of 8. When i check my logs, i clearly see that the WU completed and uploaded successfully.
I can also post my logs as needed. Btw, i'm currently using a 1080 Ti at 50% TDP which i'm pretty sure will complete the WU in time. Thanks for all the help.
Note: QRB is disabled now since i'm getting expired WU. thanks again.
Re: WU getting expired
Uninstall the client completely (inclulding data) and start with a fresh installation. That will probably fix the problem.
You can use the new passkey so the history of expired WUs doesn't follow you, but since we don't really know what will fix your problem, I'd stay with the old one until we can confirm that the expiration problem has been solved.
If that DOEN'T fix the problem, please pick a WU that was reported expired and one that was properly credited. For each of them, locate the segment of the log showing the WU being downloaded and a segment of the completed WU being uploaded. We'll need the date and time of all 4 segments along with the PRCG numbers for the WU. If you happen to find another of each, as second sample will probably be helpful.
Finding those segments may be a challenge. The client maintains a history of 16 previous logs plus the current log. They're all in the FAH data directory or in the "logs" sub-directory. (See the information referenced below for you OS.)
Of course, since you deleted the data when you reinstalled, you'll have to run for a while to create enough log data to achieve this
sago
Post by sago »
Thanks Bruce, will do a clean reinstall after i finish folding the one in my queue now. will keep you guys posted. thanks again.
sago
Post by sago »
Hi Bruce, before doing a clean reinstall here is the log using the NEW key.
Note: from the logs all the 6 WU got completed, but based on the bonus status site (https://apps.foldingathome.org/bonus) - i got 3 WU that expired. Hence I'm not sure where i got the 3 expired WU. thanks again.
00:09:23:WU00:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
00:10:31:WU00:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
00:10:32:WU01:FS01:Connecting to 65.254.110.245:8080
00:10:33:WU01:FS01:Assigned to work server 140.163.4.231
00:10:33:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.231
00:10:33:WU01:FS01:Connecting to 140.163.4.231:8080
00:10:43:WU01:FS01:Downloading 11.29MiB
00:10:43:WU01:FS01:Download complete
00:10:43:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11720 run:0 clone:548 gen:212 core:0x21 unit:0x000000f98ca304e75b89a0b2dd82ffbf
00:11:39:WU00:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
00:11:41:WU00:FS01:0x21:Saving result file logfile_01.txt
00:11:41:WU00:FS01:0x21:Saving result file checkpointState.xml
00:11:41:WU00:FS01:0x21:Saving result file checkpt.crc
00:11:41:WU00:FS01:0x21:Saving result file log.txt
00:11:41:WU00:FS01:0x21:Saving result file positions.xtc
00:11:41:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
00:11:41:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:11:42:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11728 run:0 clone:645 gen:80 core:0x21 unit:0x000000668ca304e75b9980775268bd57
00:11:42:WU00:FS01:Uploading 9.39MiB to 140.163.4.231
00:11:42:WU01:FS01:Starting
00:11:42:WU00:FS01:Connecting to 140.163.4.231:8080
00:11:42:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\_FAH_\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 4184 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
00:11:42:WU01:FS01:Started FahCore on PID 16244
00:11:42:WU01:FS01:Core PID:12948
00:11:42:WU01:FS01:FahCore 0x21 started
00:11:42:WU01:FS01:0x21:*********************** Log Started 2018-10-17T00:11:42Z ***********************
00:11:42:WU01:FS01:0x21:Project: 11720 (Run 0, Clone 548, Gen 212)
00:11:42:WU01:FS01:0x21:Unit: 0x000000f98ca304e75b89a0b2dd82ffbf
00:11:42:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:11:42:WU01:FS01:0x21:Machine: 1
00:11:42:WU01:FS01:0x21:Reading tar file core.xml
00:11:42:WU01:FS01:0x21:Reading tar file integrator.xml
00:11:42:WU01:FS01:0x21:Reading tar file state.xml
00:11:42:WU01:FS01:0x21:Reading tar file system.xml
00:11:42:WU01:FS01:0x21:Digital signatures verified
00:11:42:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:11:42:WU01:FS01:0x21:Version 0.0.18
00:11:46:WU00:FS01:Upload complete
00:11:46:WU00:FS01:Server responded WORK_ACK (400)
00:11:46:WU00:FS01:Final credit estimate, 45958.00 points
00:11:46:WU00:FS01:Cleaning up
00:11:46:WU01:FS01:0x21:Completed 0 out of 5000000 steps (0%)
00:11:46:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:12:40:WU01:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
00:13:34:WU01:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
01:39:58:WU01:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
01:40:52:WU01:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
01:40:52:WU00:FS01:Connecting to 65.254.110.245:8080
01:40:53:WU00:FS01:Assigned to work server 140.163.4.231
01:40:53:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.231
01:40:53:WU00:FS01:Connecting to 140.163.4.231:8080
01:41:03:WU00:FS01:Downloading 19.84MiB
01:41:09:WU00:FS01:Download 84.12%
01:41:46:WU01:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
01:41:47:WU01:FS01:0x21:Saving result file logfile_01.txt
01:41:47:WU01:FS01:0x21:Saving result file checkpointState.xml
01:41:47:WU01:FS01:0x21:Saving result file checkpt.crc
01:41:47:WU01:FS01:0x21:Saving result file log.txt
01:41:47:WU01:FS01:0x21:Saving result file positions.xtc
01:41:47:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
01:41:47:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:41:47:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11720 run:0 clone:548 gen:212 core:0x21 unit:0x000000f98ca304e75b89a0b2dd82ffbf
01:41:48:WU01:FS01:Uploading 7.02MiB to 140.163.4.231
01:41:48:WU01:FS01:Connecting to 140.163.4.231:8080
01:41:52:WU01:FS01:Upload complete
01:41:52:WU01:FS01:Server responded WORK_ACK (400)
01:41:52:WU01:FS01:Final credit estimate, 53064.00 points
01:41:52:WU01:FS01:Cleaning up
01:53:07:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.231
01:53:07:WU00:FS01:Connecting to 140.163.4.231:8080
01:53:20:WU00:FS01:Downloading 19.84MiB
01:53:26:WU00:FS01:Download 81.28%
01:53:29:WU00:FS01:Download complete
01:53:29:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11726 run:0 clone:370 gen:144 core:0x21 unit:0x000000b48ca304e75b8d8f168b33d1f3
01:53:29:WU00:FS01:Starting
01:53:29:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\_FAH_\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
01:53:29:WU00:FS01:Started FahCore on PID 10380
01:53:29:WU00:FS01:Core PID:10464
01:53:29:WU00:FS01:FahCore 0x21 started
01:53:30:WU00:FS01:0x21:*********************** Log Started 2018-10-17T01:53:29Z ***********************
01:53:30:WU00:FS01:0x21:Project: 11726 (Run 0, Clone 370, Gen 144)
01:53:30:WU00:FS01:0x21:Unit: 0x000000b48ca304e75b8d8f168b33d1f3
01:53:30:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
01:53:30:WU00:FS01:0x21:Machine: 1
01:53:30:WU00:FS01:0x21:Reading tar file core.xml
01:53:30:WU00:FS01:0x21:Reading tar file integrator.xml
01:53:30:WU00:FS01:0x21:Reading tar file state.xml
01:53:30:WU00:FS01:0x21:Reading tar file system.xml
01:53:30:WU00:FS01:0x21:Digital signatures verified
01:53:30:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
01:53:30:WU00:FS01:0x21:Version 0.0.18
01:53:38:WU00:FS01:0x21:Completed 0 out of 5000000 steps (0%)
01:53:38:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:55:04:WU00:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
01:56:30:WU00:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
01:57:58:WU00:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
04:17:03:WU00:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
04:18:30:WU00:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
04:18:31:WU01:FS01:Connecting to 65.254.110.245:8080
04:18:32:WU01:FS01:Assigned to work server 140.163.4.231
04:18:32:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.231
04:18:32:WU01:FS01:Connecting to 140.163.4.231:8080
04:18:42:WU01:FS01:Downloading 14.57MiB
04:18:46:WU01:FS01:Download complete
04:18:46:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11728 run:0 clone:907 gen:190 core:0x21 unit:0x000000d38ca304e75b998085057407bf
04:19:57:WU00:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
04:20:00:WU00:FS01:0x21:Saving result file logfile_01.txt
04:20:00:WU00:FS01:0x21:Saving result file checkpointState.xml
04:20:00:WU00:FS01:0x21:Saving result file checkpt.crc
04:20:00:WU00:FS01:0x21:Saving result file log.txt
04:20:00:WU00:FS01:0x21:Saving result file positions.xtc
04:20:00:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
04:20:00:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:20:00:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11726 run:0 clone:370 gen:144 core:0x21 unit:0x000000b48ca304e75b8d8f168b33d1f3
04:20:00:WU00:FS01:Uploading 12.43MiB to 140.163.4.231
04:20:00:WU00:FS01:Connecting to 140.163.4.231:8080
04:20:01:WU01:FS01:Starting
04:20:01:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\_FAH_\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 4024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
04:20:01:WU01:FS01:Started FahCore on PID 17032
04:20:01:WU01:FS01:Core PID:15816
04:20:01:WU01:FS01:FahCore 0x21 started
04:20:01:WU01:FS01:0x21:*********************** Log Started 2018-10-17T04:20:01Z ***********************
04:20:01:WU01:FS01:0x21:Project: 11728 (Run 0, Clone 907, Gen 190)
04:20:01:WU01:FS01:0x21:Unit: 0x000000d38ca304e75b998085057407bf
04:20:01:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:20:01:WU01:FS01:0x21:Machine: 1
04:20:01:WU01:FS01:0x21:Reading tar file core.xml
04:20:01:WU01:FS01:0x21:Reading tar file integrator.xml
04:20:01:WU01:FS01:0x21:Reading tar file state.xml
04:20:01:WU01:FS01:0x21:Reading tar file system.xml
04:20:01:WU01:FS01:0x21:Digital signatures verified
04:20:01:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:20:01:WU01:FS01:0x21:Version 0.0.18
04:20:07:WU01:FS01:0x21:Completed 0 out of 5000000 steps (0%)
04:20:07:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:20:22:WU00:FS01:Upload complete
04:20:22:WU00:FS01:Server responded WORK_ACK (400)
04:20:22:WU00:FS01:Final credit estimate, 94339.00 points
04:20:22:WU00:FS01:Cleaning up
04:21:14:WU01:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
04:22:21:WU01:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
06:11:49:WU01:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
06:12:57:WU01:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
06:12:58:WU00:FS01:Connecting to 65.254.110.245:8080
06:12:59:WU00:FS01:Assigned to work server 140.163.4.231
06:12:59:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.231
06:12:59:WU00:FS01:Connecting to 140.163.4.231:8080
06:13:09:WU00:FS01:Downloading 25.27MiB
06:13:15:WU00:FS01:Download 65.78%
06:13:21:WU00:FS01:Download 94.22%
06:13:22:WU00:FS01:Download complete
06:13:22:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11718 run:0 clone:1740 gen:64 core:0x21 unit:0x000000588ca304e75b89903b4b91f4f6
06:14:06:WU01:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
06:14:08:WU01:FS01:0x21:Saving result file logfile_01.txt
06:14:08:WU01:FS01:0x21:Saving result file checkpointState.xml
06:14:08:WU01:FS01:0x21:Saving result file checkpt.crc
06:14:08:WU01:FS01:0x21:Saving result file log.txt
06:14:08:WU01:FS01:0x21:Saving result file positions.xtc
06:14:08:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
06:14:09:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:14:09:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11728 run:0 clone:907 gen:190 core:0x21 unit:0x000000d38ca304e75b998085057407bf
06:14:09:WU01:FS01:Uploading 9.39MiB to 140.163.4.231
06:14:09:WU01:FS01:Connecting to 140.163.4.231:8080
06:14:09:WU00:FS01:Starting
06:14:09:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\_FAH_\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
06:14:09:WU00:FS01:Started FahCore on PID 11156
06:14:09:WU00:FS01:Core PID:13176
06:14:09:WU00:FS01:FahCore 0x21 started
06:14:09:WU00:FS01:0x21:*********************** Log Started 2018-10-17T06:14:09Z ***********************
06:14:09:WU00:FS01:0x21:Project: 11718 (Run 0, Clone 1740, Gen 64)
06:14:09:WU00:FS01:0x21:Unit: 0x000000588ca304e75b89903b4b91f4f6
06:14:09:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:14:09:WU00:FS01:0x21:Machine: 1
06:14:09:WU00:FS01:0x21:Reading tar file core.xml
06:14:09:WU00:FS01:0x21:Reading tar file integrator.xml
06:14:09:WU00:FS01:0x21:Reading tar file state.xml
06:14:09:WU00:FS01:0x21:Reading tar file system.xml
06:14:09:WU00:FS01:0x21:Digital signatures verified
06:14:09:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:14:09:WU00:FS01:0x21:Version 0.0.18
06:14:13:WU01:FS01:Upload complete
06:14:13:WU01:FS01:Server responded WORK_ACK (400)
06:14:13:WU01:FS01:Final credit estimate, 71978.00 points
06:14:13:WU01:FS01:Cleaning up
06:14:20:WU00:FS01:0x21:Completed 0 out of 5000000 steps (0%)
06:14:20:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:16:12:WU00:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
06:18:04:WU00:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
09:16:49:WU00:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
09:18:40:WU00:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
09:18:41:WU01:FS01:Connecting to 65.254.110.245:8080
09:18:42:WU01:FS01:Assigned to work server 140.163.4.231
09:18:42:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.231
09:18:42:WU01:FS01:Connecting to 140.163.4.231:8080
09:19:38:WU01:FS01:Downloading 20.07MiB
09:19:44:WU01:FS01:Download 54.49%
09:19:50:WU01:FS01:Download 57.91%
09:19:56:WU01:FS01:Download 61.65%
09:20:02:WU01:FS01:Download 74.10%
09:20:08:WU01:FS01:Download 88.73%
09:20:14:WU01:FS01:Download 95.58%
09:20:20:WU01:FS01:Download 99.63%
09:20:21:WU01:FS01:Download complete
09:20:21:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11719 run:0 clone:800 gen:79 core:0x21 unit:0x000000628ca304e75b846b48d2ec44a1
09:20:31:WU00:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
09:20:34:WU00:FS01:0x21:Saving result file logfile_01.txt
09:20:34:WU00:FS01:0x21:Saving result file checkpointState.xml
09:20:34:WU00:FS01:0x21:Saving result file checkpt.crc
09:20:34:WU00:FS01:0x21:Saving result file log.txt
09:20:34:WU00:FS01:0x21:Saving result file positions.xtc
09:20:34:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
09:20:34:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:20:34:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11718 run:0 clone:1740 gen:64 core:0x21 unit:0x000000588ca304e75b89903b4b91f4f6
09:20:34:WU00:FS01:Uploading 15.08MiB to 140.163.4.231
09:20:34:WU00:FS01:Connecting to 140.163.4.231:8080
09:20:34:WU01:FS01:Starting
09:20:34:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\_FAH_\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 4024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
09:20:35:WU01:FS01:Started FahCore on PID 10268
09:20:35:WU01:FS01:Core PID:15656
09:20:35:WU01:FS01:FahCore 0x21 started
09:20:35:WU01:FS01:0x21:*********************** Log Started 2018-10-17T09:20:35Z ***********************
09:20:35:WU01:FS01:0x21:Project: 11719 (Run 0, Clone 800, Gen 79)
09:20:35:WU01:FS01:0x21:Unit: 0x000000628ca304e75b846b48d2ec44a1
09:20:35:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
09:20:35:WU01:FS01:0x21:Machine: 1
09:20:35:WU01:FS01:0x21:Reading tar file core.xml
09:20:35:WU01:FS01:0x21:Reading tar file integrator.xml
09:20:35:WU01:FS01:0x21:Reading tar file state.xml
09:20:35:WU01:FS01:0x21:Reading tar file system.xml
09:20:35:WU01:FS01:0x21:Digital signatures verified
09:20:35:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
09:20:35:WU01:FS01:0x21:Version 0.0.18
09:20:43:WU01:FS01:0x21:Completed 0 out of 5000000 steps (0%)
09:20:43:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:20:45:WU00:FS01:Upload complete
09:20:45:WU00:FS01:Server responded WORK_ACK (400)
09:20:45:WU00:FS01:Final credit estimate, 114122.00 points
09:20:45:WU00:FS01:Cleaning up
09:22:18:WU01:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
09:23:52:WU01:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
14:28:29:WU01:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
14:29:53:WU01:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
14:29:54:WU00:FS01:Connecting to 65.254.110.245:8080
14:29:55:WU00:FS01:Assigned to work server 140.163.4.231
14:29:55:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.231
14:29:55:WU00:FS01:Connecting to 140.163.4.231:8080
14:30:06:WU00:FS01:Downloading 20.07MiB
14:30:12:WU00:FS01:Download 86.25%
14:30:14:WU00:FS01:Download complete
14:30:14:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11719 run:0 clone:809 gen:120 core:0x21 unit:0x0000009b8ca304e75b846b49d9a276eb
14:31:16:WU01:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
14:31:19:WU01:FS01:0x21:Saving result file logfile_01.txt
14:31:19:WU01:FS01:0x21:Saving result file checkpointState.xml
14:31:19:WU01:FS01:0x21:Saving result file checkpt.crc
14:31:19:WU01:FS01:0x21:Saving result file log.txt
14:31:19:WU01:FS01:0x21:Saving result file positions.xtc
14:31:19:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
14:31:20:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:31:20:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11719 run:0 clone:800 gen:79 core:0x21 unit:0x000000628ca304e75b846b48d2ec44a1
14:31:20:WU01:FS01:Uploading 13.45MiB to 140.163.4.231
14:31:20:WU01:FS01:Connecting to 140.163.4.231:8080
14:31:20:WU00:FS01:Starting
14:31:20:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\_FAH_\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4024 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:31:20:WU00:FS01:Started FahCore on PID 15252
14:31:20:WU00:FS01:Core PID:17828
14:31:20:WU00:FS01:FahCore 0x21 started
14:31:21:WU00:FS01:0x21:*********************** Log Started 2018-10-17T14:31:20Z ***********************
14:31:21:WU00:FS01:0x21:Project: 11719 (Run 0, Clone 809, Gen 120)
14:31:21:WU00:FS01:0x21:Unit: 0x0000009b8ca304e75b846b49d9a276eb
14:31:21:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
14:31:21:WU00:FS01:0x21:Machine: 1
14:31:21:WU00:FS01:0x21:Reading tar file core.xml
14:31:21:WU00:FS01:0x21:Reading tar file integrator.xml
14:31:21:WU00:FS01:0x21:Reading tar file state.xml
14:31:21:WU00:FS01:0x21:Reading tar file system.xml
14:31:21:WU00:FS01:0x21:Digital signatures verified
14:31:21:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
14:31:21:WU00:FS01:0x21:Version 0.0.18
14:31:29:WU00:FS01:0x21:Completed 0 out of 5000000 steps (0%)
14:31:29:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:31:30:WU01:FS01:Upload complete
14:31:30:WU01:FS01:Server responded WORK_ACK (400)
14:31:30:WU01:FS01:Final credit estimate, 72675.00 points
14:31:30:WU01:FS01:Cleaning up
14:32:52:WU00:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
14:34:15:WU00:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
parkut
Post by parkut »
I am not seeing any "expired" work units - the (5) that were downloaded, completed and submitted look normal
sago
Post by sago »
Thanks Parkut, that is exactly my thoughts. Hence, i'm not sure why the Bonus Status site says i have expired WU.
Anyways, i'll try to do a clean install later and fold a few more WU then post my findings. Thanks.
To use (https://apps.foldingathome.org/bonus) (and to do additional research for you) I need your exact username and passkey.
That image is too small for me to read. It looks like maybe you're using "sago" and 2# but in any case, please send them to me in a Private Message. The passkey should be a long string of hex digits obtained from the FAH website.
sago
Post by sago »
Hi Bruce, that image posted above is clickable :) here is the exact image when you click it
OK, with the name ^sago^ I was able to find some information on https://apps.foldingathome.org/cpu showing that 4 Windows slots have recently returned WUs.
Two are from the same machine: One CPU slot and one GPU slot with CPUids starting with 66F8AC... and 67F8AC... The other two are from independent FAH installations.
Are all four of they yours?
sago
Post by sago »
Hi Bruce, from the 4 Windows slots - i can confirm that the last entry with CPUids starting with 4175C75... was from my machine. And i can confirm that the returned WU from that machine was dumped since i did a re-install and the GPU won't start, i tried to switch slots and it dumped the WU. My reinstall is now good and is folding as expected.
For the other 3 Windows slots - since i did a clean reinstall, the logs were also deleted. Hence i could not trace those WU. But i think the CPUid with 67F8AC5.. was the last WU i folded and successfully uploaded before i did a re-install.
I now have a clean re-install and i have also enabled CPU folding so i can do more WU. Will keep you guys posted. Thanks for all the help.
Good.
WUs Finished 10
WUs Expired 0
% Finished 100%
Bonus Active True
As you've figured out, your machine now has a fresh CPUid and a fresh passkey and you should be good-to-go.
sago
Post by sago »
Thanks Bruce, doing a fresh FAH reinstall and new passkey seems to work. I got my QRB back. You may now close this thread? Thanks again.
