Bad GPU work units (114 = 0x72)
~shadowlegend~
I can't fold the gpu just starts over all the time.
*********************** Log Started 2018-10-15T13:13:20Z ***********************
13:15:57:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
13:15:57:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
13:19:05:WU01:FS01:0x21:ERROR:114: Max Retries Reached
13:19:06:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:20:38:WU02:FS01:0x21:ERROR:114: Max Retries Reached
13:20:38:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:22:59:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 2304
13:23:00:WARNING:WU01:Slot ID 1 no longer exists and there are no other matching slots, dumping
13:23:08:WARNING:WU00:FS00:Changed SMP threads from 3 to 4 this can cause some work units to fail
13:23:08:WARNING:WU00:FS00:AS lowered CPUs from 4 to 2
13:23:40:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 14248
13:24:08:WARNING:WU00:FS00:Changed SMP threads from 4 to 3 this can cause some work units to fail
13:24:08:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
13:26:49:WU01:FS01:0x21:ERROR:114: Max Retries Reached
13:26:50:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:30:16:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
Re: Bad work units.
We'll need more information to help you. We need the first couple of pages of the log (showing your configuration and FAHClient starting) plus a little more before the segment you posted ... what WU was downloaded and is failing to start.
~shadowlegend~
Re: Bad work units.
bruce wrote:We'll need more information to help you. We need the first couple of pages of the log (showing your configuration and FAHClient starting) plus a little more before the segment you posted ... what WU was downloaded and is failing to start.
*********************** Log Started 2018-10-16T13:34:16Z ***********************
13:34:16:************************* Folding@home Client *************************
13:34:16: Website: https://foldingathome.org/
13:34:16: Copyright: (c) 2009-2018 foldingathome.org
13:34:16: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:34:16: Args:
13:34:16: Config: C:\Users\simon\AppData\Roaming\FAHClient\config.xml
13:34:16:******************************** Build ********************************
13:34:16: Version: 7.5.1
13:34:16: Date: May 11 2018
13:34:16: Time: 13:06:32
13:34:16: Repository: Git
13:34:16: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
13:34:16: Branch: master
13:34:16: Compiler: Visual C++ 2008
13:34:16: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:34:16: Platform: win32 10
13:34:16: Bits: 32
13:34:16: Mode: Release
13:34:16:******************************* System ********************************
13:34:16: CPU: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
13:34:16: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
13:34:16: CPUs: 4
13:34:16: Memory: 7.89GiB
13:34:16: Free Memory: 3.53GiB
13:34:16: Threads: WINDOWS_THREADS
13:34:16: OS Version: 6.2
13:34:16: Has Battery: false
13:34:16: On Battery: false
13:34:16: UTC Offset: 2
13:34:16: PID: 9772
13:34:16: CWD: C:\Users\simon\AppData\Roaming\FAHClient
13:34:16: OS: Windows 10 Enterprise
13:34:16: OS Arch: AMD64
13:34:16: GPUs: 1
13:34:16: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:3 GK104 [GeForce GTX 760] 2258
13:34:16: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:10.0
13:34:16:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
13:34:16:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:411.63
13:34:16: Win32 Service: false
13:34:16:***********************************************************************
13:34:17:<config>
13:34:17: <!-- Network -->
13:34:17: <proxy v=':8080'/>
13:34:17:
13:34:17: <!-- Slot Control -->
13:34:17: <power v='full'/>
13:34:17:
13:34:17: <!-- User Information -->
13:34:17: <passkey v='********************************'/>
13:34:17: <team v='143016'/>
13:34:17: <user v='~shadowlegend~'/>
13:34:17:
13:34:17: <!-- Folding Slots -->
13:34:17: <slot id='0' type='CPU'>
13:34:17: <paused v='true'/>
13:34:17: </slot>
13:34:17: <slot id='1' type='GPU'>
13:34:17: </slot>
13:34:17:</config>
13:34:17:Trying to access database...
13:34:17:Successfully acquired database lock
13:34:17:Enabled folding slot 00: PAUSED cpu:3 (by user)
13:34:17:Enabled folding slot 01: PAUSED gpu:0:GK104 [GeForce GTX 760] 2258 (by user)
14:52:36:FS00:Unpaused
14:52:36:FS01:Unpaused
14:52:36:WU02:FS01:Starting
14:52:36:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 9772 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
14:52:37:WU02:FS01:Started FahCore on PID 4808
14:52:37:WU02:FS01:Core PID:6164
14:52:37:WU02:FS01:FahCore 0x21 started
14:52:37:WU00:FS00:Starting
14:52:37:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
14:52:37:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 705 -lifeline 9772 -checkpoint 15 -np 2
14:52:37:WU00:FS00:Started FahCore on PID 15688
14:52:37:WU00:FS00:Core PID:15840
14:52:37:WU00:FS00:FahCore 0xa4 started
14:52:37:WU02:FS01:0x21:*********************** Log Started 2018-10-16T14:52:37Z ***********************
14:52:37:WU02:FS01:0x21:Project: 11726 (Run 0, Clone 2815, Gen 1)
14:52:37:WU02:FS01:0x21:Unit: 0x000000018ca304e75bbcea69af285741
14:52:37:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
14:52:37:WU02:FS01:0x21:Machine: 1
14:52:37:WU02:FS01:0x21:Digital signatures verified
14:52:37:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
14:52:37:WU02:FS01:0x21:Version 0.0.18
14:52:38:WU00:FS00:0xa4:
14:52:38:WU00:FS00:0xa4:*------------------------------*
14:52:38:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
14:52:38:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:52:38:WU00:FS00:0xa4:Preparing to commence simulation
14:52:38:WU00:FS00:0xa4:- Looking at optimizations...
14:52:38:WU00:FS00:0xa4:- Files status OK
14:52:38:WU00:FS00:0xa4:- Expanded 826012 -> 1402156 (decompressed 169.7 percent)
14:52:38:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826012 data_size=1402156, decompressed_data_size=1402156 diff=0
14:52:38:WU00:FS00:0xa4:- Digital signature verified
14:52:38:WU00:FS00:0xa4:Project: 9035 (Run 328, Clone 2, Gen 2051)
14:52:38:WU00:FS00:0xa4:Assembly optimizations on if available.
14:52:38:WU00:FS00:0xa4:Entering M.D.
14:52:43:WU00:FS00:0xa4:Using Gromacs checkpoints
14:52:43:WU00:FS00:0xa4:Mapping NT from 2 to 2
14:52:44:WU00:FS00:0xa4:Resuming from checkpoint
14:52:44:WU00:FS00:0xa4:Verified 00/wudata_01.log
14:52:44:WU00:FS00:0xa4:Verified 00/wudata_01.trr
14:52:44:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
14:52:44:WU00:FS00:0xa4:Verified 00/wudata_01.edr
14:52:44:WU00:FS00:0xa4:Completed 60185 out of 250000 steps (24%)
14:52:45:WU02:FS01:0x21:Completed 0 out of 5000000 steps (0%)
14:52:45:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:53:35:Removing old file 'configs/config-20181015-131623.xml'
14:53:35:Saving configuration to config.xml
14:53:35:<config>
14:53:35: <!-- Network -->
14:53:35: <proxy v=':8080'/>
14:53:35:
14:53:35: <!-- Slot Control -->
14:53:35: <power v='full'/>
14:53:35:
14:53:35: <!-- User Information -->
14:53:35: <passkey v='********************************'/>
14:53:35: <team v='143016'/>
14:53:35: <user v='~shadowlegend~'/>
14:53:35:
14:53:35: <!-- Folding Slots -->
14:53:35: <slot id='0' type='CPU'/>
14:53:35: <slot id='1' type='GPU'/>
14:53:35:</config>
15:02:45:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:03:01:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
15:03:11:WU02:FS01:0x21:ERROR:114: Max Retries Reached
15:03:11:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
I don't know how to find the work unit that i downloaded. But every single work unit on the gpu fails. It downloads a unit. then i get around 0.10% - 1%. Then it downloads a new one. And it happens over and over again.
Mod edit: added Code tags to log file listing
Re: Bad work units.
I am shooting in the dark, but a good first step is to download the Driver from the vendor site. (Nvidia in this case)
https://www.geforce.com/drivers/results/138697
That should be the latest for your card. It may offer to install Experience, Phys, Audio, etc. But if all you use it for is F@H, all you need is the video display driver.
Re: Bad work units.
Here's another shot in the dark.
I think what's happening is that your GPU work unit is trying to process using your CPU's opencl driver instead of the GPU's opencl driver. To attempt to rectify that you could try removing the CPU opencl driver or, using FAHControl, go into Configuration > Slots > gpu and change the opencl-index from -1 to 1.
~shadowlegend~
Re: Bad work units.
I tried both and it only got up to 1%bollix47 wrote:Here's another shot in the dark.
Re: Bad work units.
I can think of two possibilities:
1) Your OpenCL drivers for the Intel GPU are interfering with the use of the GeForce GTX 760 (as suggested above).
2) Your NVidia GPU needs to be updated. (There are a couple of revisions beyond Driver:411.63)
3) Your GPU is producing Calculation errors
(Either one might lead us to a bug in the current version of FAHClient that needs to be fixed, so any details you can provide would be helpful.) If it's a hardware problem, it's difficult for us to diagnose.
First, you can manually override the GPU choice and see if that helps. Using FAHControl, open Configure and select a GPU slot. Change the setting for opencl-index from -1 to 0 for one GPU and to 1 for the other one. Second, if that gives you the same result, interchange the 1 and 0 assignments and try again. (In fact, maybe you need to use 0 and 2.)
Third, reset both to -1 and install the latest driver package from NVidia.com.
Re: Bad work units.
Additional information, in case you're interested.
FAH has never supported Intel GPUs -- mostly because of problems with their drivers. In your case, drivers are present for both devices, and FAHClient is supposed to be smart enough to ignore the Intel GPU while enabling your GTX 760. Notice that both OpenCL devices are detected and assigned the opencl-device index values of 0 and 2 -- but it only enables one of them
> GPUs: 1
For a reason that I don't understand, they're identified as OpenCL Device 0 and OpenCL Device 2, skipping device 1. (The CUDA device is correctly identified as CUDA Device 0, but that's not important, in your case, since FAHCore_21 needs to find a supported OpenCL device and that the OpenCL Device 2 is NOT being enabled.) A bug-fix might tell the FAHCore to use OpenCL Device 2 or it might legitimately be called OpenCL Device 1 as long as it's consistent.
This can be seen later, when the FAHCore is called and it is passed values that are wrong.
> GPUs: 1
~shadowlegend~
Re: Bad work units.
i tried everything. and nothing works. i wish i could provide more information but i am not good at computers.bruce wrote:I can think of two possibilities:
Re: Bad work units.
OK. No problem.~shadowlegend~ wrote:i tried everything. and nothing works. i wish i could provide more information but i am not good at computers.
I'm happy to give step-by-step instructions.
After a reboot, post the first few pages of the log again.
~shadowlegend~
Re: Bad work units.
Before i started
*********************** Log Started 2018-10-17T17:47:54Z ***********************
17:47:54:************************* Folding@home Client *************************
17:47:54: Website: https://foldingathome.org/
17:47:54: Copyright: (c) 2009-2018 foldingathome.org
17:47:54: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:47:54: Args:
17:47:54: Config: C:\Users\simon\AppData\Roaming\FAHClient\config.xml
17:47:54:******************************** Build ********************************
17:47:54: Version: 7.5.1
17:47:54: Date: May 11 2018
17:47:54: Time: 13:06:32
17:47:54: Repository: Git
17:47:54: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:47:54: Branch: master
17:47:54: Compiler: Visual C++ 2008
17:47:54: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:47:54: Platform: win32 10
17:47:54: Bits: 32
17:47:54: Mode: Release
17:47:54:******************************* System ********************************
17:47:54: CPU: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
17:47:54: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
17:47:54: CPUs: 4
17:47:54: Memory: 7.89GiB
17:47:54: Free Memory: 3.62GiB
17:47:54: Threads: WINDOWS_THREADS
17:47:54: OS Version: 6.2
17:47:54: Has Battery: false
17:47:54: On Battery: false
17:47:54: UTC Offset: 2
17:47:54: PID: 11128
17:47:54: CWD: C:\Users\simon\AppData\Roaming\FAHClient
17:47:54: OS: Windows 10 Enterprise
17:47:54: OS Arch: AMD64
17:47:54: GPUs: 1
17:47:54: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:3 GK104 [GeForce GTX 760] 2258
17:47:54: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:10.0
17:47:54:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
17:47:54:OpenCL Device 1: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:416.34
17:47:54: Win32 Service: false
17:47:54:***********************************************************************
17:47:54:<config>
17:47:54: <!-- Network -->
17:47:54: <proxy v=':8080'/>
17:47:54:
17:47:54: <!-- Slot Control -->
17:47:54: <power v='full'/>
17:47:54:
17:47:54: <!-- User Information -->
17:47:54: <passkey v='********************************'/>
17:47:54: <team v='143016'/>
17:47:54: <user v='~shadowlegend~'/>
17:47:54:
17:47:54: <!-- Folding Slots -->
17:47:54: <slot id='0' type='CPU'>
17:47:54: <paused v='true'/>
17:47:54: </slot>
17:47:54: <slot id='1' type='GPU'>
17:47:54: </slot>
17:47:54:</config>
17:47:54:Trying to access database...
17:47:54:Successfully acquired database lock
17:47:54:Enabled folding slot 00: PAUSED cpu:3 (by user)
17:47:54:Enabled folding slot 01: PAUSED gpu:0:GK104 [GeForce GTX 760] 2258 (by user)
After i started.
17:50:34:FS00:Unpaused
17:50:34:FS01:Unpaused
17:50:34:WU02:FS01:Starting
17:50:34:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 11128 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
17:50:34:WU02:FS01:Started FahCore on PID 13336
17:50:34:WU02:FS01:Core PID:8868
17:50:34:WU02:FS01:FahCore 0x21 started
17:50:34:WU00:FS00:Starting
17:50:34:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
17:50:34:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 705 -lifeline 11128 -checkpoint 15 -np 2
17:50:35:WU00:FS00:Started FahCore on PID 5672
17:50:35:WU00:FS00:Core PID:3688
17:50:35:WU00:FS00:FahCore 0xa4 started
17:50:35:WU02:FS01:0x21:*********************** Log Started 2018-10-17T17:50:35Z ***********************
17:50:35:WU02:FS01:0x21:Project: 11728 (Run 0, Clone 1749, Gen 255)
17:50:35:WU02:FS01:0x21:Unit: 0x0000013c8ca304e75ba032663305647e
17:50:35:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
17:50:35:WU02:FS01:0x21:Machine: 1
17:50:35:WU02:FS01:0x21:Digital signatures verified
17:50:35:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
17:50:35:WU02:FS01:0x21:Version 0.0.18
17:50:35:WU00:FS00:0xa4:
17:50:35:WU00:FS00:0xa4:*------------------------------*
17:50:35:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
17:50:35:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:50:35:WU00:FS00:0xa4:Preparing to commence simulation
17:50:35:WU00:FS00:0xa4:- Looking at optimizations...
17:50:35:WU00:FS00:0xa4:- Files status OK
17:50:35:WU00:FS00:0xa4:- Expanded 826012 -> 1402156 (decompressed 169.7 percent)
17:50:35:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826012 data_size=1402156, decompressed_data_size=1402156 diff=0
17:50:35:WU00:FS00:0xa4:- Digital signature verified
17:50:35:WU00:FS00:0xa4:Project: 9035 (Run 328, Clone 2, Gen 2051)
17:50:35:WU00:FS00:0xa4:Assembly optimizations on if available.
17:50:35:WU00:FS00:0xa4:Entering M.D.
17:50:39:WU02:FS01:0x21:Completed 0 out of 5000000 steps (0%)
17:50:39:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:50:41:WU00:FS00:0xa4:Using Gromacs checkpoints
17:50:41:WU00:FS00:0xa4:Mapping NT from 2 to 2
17:50:41:WU00:FS00:0xa4:Resuming from checkpoint
17:50:41:WU00:FS00:0xa4:Verified 00/wudata_01.log
17:50:41:WU00:FS00:0xa4:Verified 00/wudata_01.trr
17:50:41:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
17:50:41:WU00:FS00:0xa4:Verified 00/wudata_01.edr
17:50:41:WU00:FS00:0xa4:Completed 101575 out of 250000 steps (40%)
17:50:57:Removing old file 'configs/config-20181016-235717.xml'
17:50:57:Saving configuration to config.xml
17:50:57:<config>
17:50:57: <!-- Network -->
17:50:57: <proxy v=':8080'/>
17:50:57:
17:50:57: <!-- Slot Control -->
17:50:57: <power v='full'/>
17:50:57:
17:50:57: <!-- User Information -->
17:50:57: <passkey v='********************************'/>
17:50:57: <team v='143016'/>
17:50:57: <user v='~shadowlegend~'/>
17:50:57:
17:50:57: <!-- Folding Slots -->
17:50:57: <slot id='0' type='CPU'/>
17:50:57: <slot id='1' type='GPU'/>
17:50:57:</config>
17:51:48:WU00:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
17:54:44:WU00:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
17:54:53:WU02:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
17:56:06:WU02:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
17:56:11:WU02:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
17:56:11:WU02:FS01:0x21:ERROR:114: Max Retries Reached
17:56:11:WU02:FS01:0x21:Saving result file logfile_01.txt
17:56:11:WU02:FS01:0x21:Saving result file badstate-0.xml
17:56:11:WU02:FS01:0x21:Saving result file badstate-1.xml
17:56:11:WU02:FS01:0x21:Saving result file badstate-2.xml
17:56:11:WU02:FS01:0x21:Saving result file log.txt
17:56:11:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
17:56:12:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:56:12:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11728 run:0 clone:1749 gen:255 core:0x21 unit:0x0000013c8ca304e75ba032663305647e
17:56:12:WU02:FS01:Uploading 9.93MiB to 140.163.4.231
17:56:12:WU02:FS01:Connecting to 140.163.4.231:8080
17:56:12:WU01:FS01:Connecting to 65.254.110.245:8080
17:56:13:WU01:FS01:Assigned to work server 140.163.4.231
17:56:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK104 [GeForce GTX 760] 2258 from 140.163.4.231
17:56:13:WU01:FS01:Connecting to 140.163.4.231:8080
17:56:14:WU01:FS01:Downloading 20.07MiB
17:56:18:WU02:FS01:Upload 61.66%
17:56:20:WU01:FS01:Download 50.75%
17:56:23:WU01:FS01:Download complete
17:56:23:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11719 run:0 clone:2666 gen:15 core:0x21 unit:0x000000118ca304e75bbce9690a94fc3f
17:56:23:WU01:FS01:Starting
17:56:23:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 11128 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
17:56:23:WU01:FS01:Started FahCore on PID 6540
17:56:23:WU01:FS01:Core PID:4352
17:56:23:WU01:FS01:FahCore 0x21 started
17:56:23:WU02:FS01:Upload complete
17:56:24:WU02:FS01:Server responded WORK_ACK (400)
17:56:24:WU02:FS01:Cleaning up
17:56:24:WU01:FS01:0x21:*********************** Log Started 2018-10-17T17:56:23Z ***********************
17:56:24:WU01:FS01:0x21:Project: 11719 (Run 0, Clone 2666, Gen 15)
17:56:24:WU01:FS01:0x21:Unit: 0x000000118ca304e75bbce9690a94fc3f
17:56:24:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
17:56:24:WU01:FS01:0x21:Machine: 1
17:56:24:WU01:FS01:0x21:Reading tar file core.xml
17:56:24:WU01:FS01:0x21:Reading tar file integrator.xml
17:56:24:WU01:FS01:0x21:Reading tar file state.xml
17:56:24:WU01:FS01:0x21:Reading tar file system.xml
17:56:24:WU01:FS01:0x21:Digital signatures verified
17:56:24:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
17:56:24:WU01:FS01:0x21:Version 0.0.18
17:56:29:WU01:FS01:0x21:Completed 0 out of 5000000 steps (0%)
17:56:29:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:47:54: Args:
17:47:54: Bits: 32
17:47:54: CPUs: 4
17:47:54: GPUs: 1
17:47:54:<config>
17:47:54:
17:47:54:
17:47:54:
17:47:54: </slot>
17:47:54: </slot>
17:47:54:</config>
After i started.
17:50:57:<config>
17:50:57:
17:50:57:
17:50:57:
17:50:57:</config>
Re: Bad work units.
OK. You successfully updated NVidia Driver:from 411.63 to 416.34.
FAH attempted to resume processing the WU that had been started before the update Project: 11728 (Run 0, Clone 1749, Gen 255) and it failed 3x and it was returned with an error:FAULTY. Unfortunately that doesn't prove anything since it was probably corrupted earlier. A fresh WU: Project: 11719 (Run 0, Clone 2666, Gen 15) was downloaded and started. We'll see what happens next.
Project: 11728 (Run 0, Clone 1749, Gen 255) was received and awarded a (very) small number of points for the incomplete submission.
~shadowlegend~
Re: Bad work units.
this happened.bruce wrote:OK. You successfully updated NVidia Driver:from 411.63 to 416.34.
20:32:39:FS00:Unpaused
20:32:39:FS01:Unpaused
20:32:39:WU00:FS00:Starting
20:32:39:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
20:32:39:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 705 -lifeline 11128 -checkpoint 15 -np 2
20:32:40:WU00:FS00:Started FahCore on PID 12492
20:32:40:WU00:FS00:Core PID:2564
20:32:40:WU00:FS00:FahCore 0xa4 started
20:32:40:WU01:FS01:Starting
20:32:40:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 11128 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
20:32:40:WU01:FS01:Started FahCore on PID 1580
20:32:40:WU01:FS01:Core PID:3148
20:32:40:WU01:FS01:FahCore 0x21 started
20:32:40:WU00:FS00:0xa4:
20:32:40:WU00:FS00:0xa4:*------------------------------*
20:32:40:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
20:32:40:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
20:32:40:WU00:FS00:0xa4:Preparing to commence simulation
20:32:40:WU00:FS00:0xa4:- Looking at optimizations...
20:32:40:WU00:FS00:0xa4:- Files status OK
20:32:40:WU00:FS00:0xa4:- Expanded 826012 -> 1402156 (decompressed 169.7 percent)
20:32:40:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826012 data_size=1402156, decompressed_data_size=1402156 diff=0
20:32:40:WU00:FS00:0xa4:- Digital signature verified
20:32:40:WU00:FS00:0xa4:Project: 9035 (Run 328, Clone 2, Gen 2051)
20:32:40:WU00:FS00:0xa4:Assembly optimizations on if available.
20:32:40:WU00:FS00:0xa4:Entering M.D.
20:32:40:WU01:FS01:0x21:*********************** Log Started 2018-10-17T20:32:40Z ***********************
20:32:40:WU01:FS01:0x21:Project: 11719 (Run 0, Clone 2666, Gen 15)
20:32:40:WU01:FS01:0x21:Unit: 0x000000118ca304e75bbce9690a94fc3f
20:32:40:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
20:32:40:WU01:FS01:0x21:Machine: 1
20:32:40:WU01:FS01:0x21:Digital signatures verified
20:32:40:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
20:32:40:WU01:FS01:0x21:Version 0.0.18
20:32:46:WU00:FS00:0xa4:Using Gromacs checkpoints
20:32:46:WU01:FS01:0x21:Completed 0 out of 5000000 steps (0%)
20:32:46:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:32:46:WU00:FS00:0xa4:Mapping NT from 2 to 2
20:32:46:WU00:FS00:0xa4:Resuming from checkpoint
20:32:46:WU00:FS00:0xa4:Verified 00/wudata_01.log
20:32:46:WU00:FS00:0xa4:Verified 00/wudata_01.trr
20:32:46:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
20:32:46:WU00:FS00:0xa4:Verified 00/wudata_01.edr
20:32:46:WU00:FS00:0xa4:Completed 101575 out of 250000 steps (40%)
20:33:37:Removing old file 'configs/config-20181017-013655.xml'
20:33:37:Saving configuration to config.xml
20:33:37:<config>
20:33:37: <!-- Network -->
20:33:37: <proxy v=':8080'/>
20:33:37:
20:33:37: <!-- Slot Control -->
20:33:37: <power v='full'/>
20:33:37:
20:33:37: <!-- User Information -->
20:33:37: <passkey v='********************************'/>
20:33:37: <team v='143016'/>
20:33:37: <user v='~shadowlegend~'/>
20:33:37:
20:33:37: <!-- Folding Slots -->
20:33:37: <slot id='0' type='CPU'/>
20:33:37: <slot id='1' type='GPU'/>
20:33:37:</config>
20:33:52:WU00:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
20:36:51:WU00:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
20:39:31:WU01:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
20:39:51:WU00:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
20:41:50:WU01:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
20:42:43:WU01:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
20:42:43:WU01:FS01:0x21:ERROR:114: Max Retries Reached
20:42:43:WU01:FS01:0x21:Saving result file logfile_01.txt
20:42:43:WU01:FS01:0x21:Saving result file badstate-0.xml
20:42:43:WU01:FS01:0x21:Saving result file badstate-1.xml
20:42:43:WU01:FS01:0x21:Saving result file badstate-2.xml
20:42:43:WU01:FS01:0x21:Saving result file log.txt
20:42:43:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
20:42:44:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:42:44:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11719 run:0 clone:2666 gen:15 core:0x21 unit:0x000000118ca304e75bbce9690a94fc3f
20:42:44:WU01:FS01:Uploading 14.43MiB to 140.163.4.231
20:42:44:WU01:FS01:Connecting to 140.163.4.231:8080
20:42:44:WU02:FS01:Connecting to 65.254.110.245:8080
20:42:46:WU02:FS01:Assigned to work server 140.163.4.231
20:42:46:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GK104 [GeForce GTX 760] 2258 from 140.163.4.231
20:42:46:WU02:FS01:Connecting to 140.163.4.231:8080
20:42:46:WU02:FS01:Downloading 14.57MiB
20:42:48:WU00:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
20:42:50:WU01:FS01:Upload 4.77%
20:42:52:WU02:FS01:Download 36.47%
20:42:56:WU01:FS01:Upload 9.96%
20:42:58:WU02:FS01:Download 79.38%
20:42:59:WU02:FS01:Download complete
20:42:59:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11728 run:0 clone:141 gen:146 core:0x21 unit:0x000000a08ca304e75b95bb1f9524651a
20:42:59:WU02:FS01:Starting
20:42:59:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 11128 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
20:43:00:WU02:FS01:Started FahCore on PID 9508
20:43:00:WU02:FS01:Core PID:4924
20:43:00:WU02:FS01:FahCore 0x21 started
20:43:00:WU02:FS01:0x21:*********************** Log Started 2018-10-17T20:43:00Z ***********************
20:43:00:WU02:FS01:0x21:Project: 11728 (Run 0, Clone 141, Gen 146)
20:43:00:WU02:FS01:0x21:Unit: 0x000000a08ca304e75b95bb1f9524651a
20:43:00:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
20:43:00:WU02:FS01:0x21:Machine: 1
20:43:00:WU02:FS01:0x21:Reading tar file core.xml
20:43:00:WU02:FS01:0x21:Reading tar file integrator.xml
20:43:00:WU02:FS01:0x21:Reading tar file state.xml
20:43:00:WU02:FS01:0x21:Reading tar file system.xml
20:43:00:WU02:FS01:0x21:Digital signatures verified
20:43:00:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
20:43:00:WU02:FS01:0x21:Version 0.0.18
20:43:02:WU01:FS01:Upload 57.19%
20:43:02:FS00:Paused
20:43:02:FS01:Paused
20:43:02:FS00:Shutting core down
20:43:02:FS01:Shutting core down
20:43:02:WU02:FS01:0x21:WARNING:Console control signal 1 on PID 4924
20:43:02:WU02:FS01:0x21:Exiting, please wait. . .
20:43:04:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:43:10:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:43:16:WU01:FS01:Upload 74.08%
20:43:24:WU01:FS01:Upload 74.52%
20:43:30:WU01:FS01:Upload 85.35%
20:43:35:WU01:FS01:Upload complete
20:43:35:WU01:FS01:Server responded WORK_ACK (400)
20:43:35:WU01:FS01:Cleaning up
20:43:47:Removing old file 'configs/config-20181017-013756.xml'
20:43:47:Saving configuration to config.xml
20:43:47:<config>
20:43:47: <!-- Network -->
20:43:47: <proxy v=':8080'/>
20:43:47:
20:43:47: <!-- Slot Control -->
20:43:47: <power v='full'/>
20:43:47:
20:43:47: <!-- User Information -->
20:43:47: <passkey v='********************************'/>
20:43:47: <team v='143016'/>
20:43:47: <user v='~shadowlegend~'/>
20:43:47:
20:43:47: <!-- Folding Slots -->
20:43:47: <slot id='0' type='CPU'>
20:43:47: <paused v='true'/>
20:43:47: </slot>
20:43:47: <slot id='1' type='GPU'>
20:43:47: </slot>
20:43:47:</config>
Re: Bad work units.
Yes
You're are still getting bad state on WUs which are being started with the parameter strings "... -opencl-device 0 -cuda-device 0 -gpu 0" so the driver update didn't fix the problem. I can't say I'm surprised. We didn't do any damage, but we have eliminated one possibility but we don't have enough information to isolate the bug yet. It's going to take some trial-and-error.
Pause the GPU slot.
Open FAHControl. and click on Configure + slots. Select one of the GPUs (probably the second one) and click EDIT and then modify the value -1 in the opencl-index to be 1 then OK, Save. Since the bug in FAHClient is inserting incorrect values, this may or may not work. If not, tell us what the error message says. If it appears to work, unpause the GPU slot and report what happens.
If that doesn't work, change the 1 to 0.
If that doesn't work, there are a couple other things to try.
I hope you're patient.
Pause the GPU slot.
~shadowlegend~
Re: Bad work units.
bruce wrote:Yes
Pause the GPU slot.
When i changed to 1
*********************** Log Started 2018-10-18T00:22:42Z ***********************
00:22:42:************************* Folding@home Client *************************
00:22:42: Website: https://foldingathome.org/
00:22:42: Copyright: (c) 2009-2018 foldingathome.org
00:22:42: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:22:42: Args: --open-web-control
00:22:42: Config: C:\Users\simon\AppData\Roaming\FAHClient\config.xml
00:22:42:******************************** Build ********************************
00:22:42: Version: 7.5.1
00:22:42: Date: May 11 2018
00:22:42: Time: 13:06:32
00:22:42: Repository: Git
00:22:42: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:22:42: Branch: master
00:22:42: Compiler: Visual C++ 2008
00:22:42: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:22:42: Platform: win32 10
00:22:42: Bits: 32
00:22:42: Mode: Release
00:22:42:******************************* System ********************************
00:22:42: CPU: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
00:22:42: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:22:42: CPUs: 4
00:22:42: Memory: 7.89GiB
00:22:42: Free Memory: 3.15GiB
00:22:42: Threads: WINDOWS_THREADS
00:22:42: OS Version: 6.2
00:22:42: Has Battery: false
00:22:42: On Battery: false
00:22:42: UTC Offset: 2
00:22:42: PID: 7760
00:22:42: CWD: C:\Users\simon\AppData\Roaming\FAHClient
00:22:42: OS: Windows 10 Enterprise
00:22:42: OS Arch: AMD64
00:22:42: GPUs: 1
00:22:42: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:3 GK104 [GeForce GTX 760] 2258
00:22:42: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:10.0
00:22:42:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
00:22:42:OpenCL Device 1: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:416.34
00:22:42: Win32 Service: false
00:22:42:***********************************************************************
00:22:42:<config>
00:22:42: <!-- Network -->
00:22:42: <proxy v=':8080'/>
00:22:42:
00:22:42: <!-- Slot Control -->
00:22:42: <power v='full'/>
00:22:42:
00:22:42: <!-- User Information -->
00:22:42: <passkey v='********************************'/>
00:22:42: <team v='143016'/>
00:22:42: <user v='~shadowlegend~'/>
00:22:42:
00:22:42: <!-- Folding Slots -->
00:22:42: <slot id='0' type='CPU'>
00:22:42: <paused v='true'/>
00:22:42: </slot>
00:22:42: <slot id='1' type='GPU'>
00:22:42: <opencl-index v='1'/>
00:22:42: </slot>
00:22:42:</config>
00:22:42:Trying to access database...
00:22:42:Successfully acquired database lock
00:22:42:Enabled folding slot 00: PAUSED cpu:3 (by user)
00:22:42:ERROR:FS01:OpenCL GPU not found for 'opencl-index' = 1 with vendor ID = 0x10de, please correct this by removing the manually configured 'opencl-index' option.
00:22:42:Enabled folding slot 01: PAUSED gpu:0:GK104 [GeForce GTX 760] 2258 (by user)
00:23:05:FS00:Unpaused
00:23:05:FS01:Unpaused
00:23:05:WU02:FS01:Starting
00:23:05:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 7760 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 1 -cuda-device 0 -gpu 1
00:23:05:WU02:FS01:Started FahCore on PID 2728
00:23:05:WU02:FS01:Core PID:3788
00:23:05:WU02:FS01:FahCore 0x21 started
00:23:05:WU00:FS00:Starting
00:23:05:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
00:23:05:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 705 -lifeline 7760 -checkpoint 15 -np 2
00:23:06:WU00:FS00:Started FahCore on PID 3488
00:23:06:WU00:FS00:Core PID:11056
00:23:06:WU00:FS00:FahCore 0xa4 started
00:23:06:WU02:FS01:0x21:*********************** Log Started 2018-10-18T00:23:06Z ***********************
00:23:06:WU02:FS01:0x21:Project: 11728 (Run 0, Clone 141, Gen 146)
00:23:06:WU02:FS01:0x21:Unit: 0x000000a08ca304e75b95bb1f9524651a
00:23:06:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:23:06:WU02:FS01:0x21:Machine: 1
00:23:06:WU02:FS01:0x21:Reading tar file core.xml
00:23:06:WU02:FS01:0x21:Reading tar file integrator.xml
00:23:06:WU02:FS01:0x21:Reading tar file state.xml
00:23:06:WU02:FS01:0x21:Reading tar file system.xml
00:23:06:WU02:FS01:0x21:Digital signatures verified
00:23:06:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:23:06:WU02:FS01:0x21:Version 0.0.18
00:23:06:WU00:FS00:0xa4:
00:23:06:WU00:FS00:0xa4:*------------------------------*
00:23:06:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
00:23:06:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
00:23:06:WU00:FS00:0xa4:Preparing to commence simulation
00:23:06:WU00:FS00:0xa4:- Looking at optimizations...
00:23:06:WU00:FS00:0xa4:- Files status OK
00:23:06:WU00:FS00:0xa4:- Expanded 826012 -> 1402156 (decompressed 169.7 percent)
00:23:06:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826012 data_size=1402156, decompressed_data_size=1402156 diff=0
00:23:06:WU00:FS00:0xa4:- Digital signature verified
00:23:06:WU00:FS00:0xa4:Project: 9035 (Run 328, Clone 2, Gen 2051)
00:23:06:WU00:FS00:0xa4:Assembly optimizations on if available.
00:23:06:WU00:FS00:0xa4:Entering M.D.
00:23:10:WU02:FS01:0x21:Completed 0 out of 5000000 steps (0%)
00:23:10:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:23:12:WU00:FS00:0xa4:Using Gromacs checkpoints
00:23:12:WU00:FS00:0xa4:Mapping NT from 2 to 2
00:23:12:WU00:FS00:0xa4:Resuming from checkpoint
00:23:12:WU00:FS00:0xa4:Verified 00/wudata_01.log
00:23:12:WU00:FS00:0xa4:Verified 00/wudata_01.trr
00:23:12:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
00:23:12:WU00:FS00:0xa4:Verified 00/wudata_01.edr
00:23:12:WU00:FS00:0xa4:Completed 101575 out of 250000 steps (40%)
00:23:43:Removing old file 'configs/config-20181017-142055.xml'
00:23:43:Saving configuration to config.xml
00:23:43:<config>
00:23:43: <!-- Network -->
00:23:43: <proxy v=':8080'/>
00:23:43:
00:23:43: <!-- Slot Control -->
00:23:43: <power v='full'/>
00:23:43:
00:23:43: <!-- User Information -->
00:23:43: <passkey v='********************************'/>
00:23:43: <team v='143016'/>
00:23:43: <user v='~shadowlegend~'/>
00:23:43:
00:23:43: <!-- Folding Slots -->
00:23:43: <slot id='0' type='CPU'/>
00:23:43: <slot id='1' type='GPU'>
00:23:43: <opencl-index v='1'/>
00:23:43: </slot>
00:23:43:</config>
00:24:18:WU00:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
00:27:19:WU00:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
00:27:42:WU02:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:28:27:WU02:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:29:23:WU02:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:29:23:WU02:FS01:0x21:ERROR:114: Max Retries Reached
00:29:23:WU02:FS01:0x21:Saving result file logfile_01.txt
00:29:23:WU02:FS01:0x21:Saving result file badstate-0.xml
00:29:23:WU02:FS01:0x21:Saving result file badstate-1.xml
00:29:23:WU02:FS01:0x21:Saving result file badstate-2.xml
00:29:23:WU02:FS01:0x21:Saving result file log.txt
00:29:23:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
00:29:24:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:29:24:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11728 run:0 clone:141 gen:146 core:0x21 unit:0x000000a08ca304e75b95bb1f9524651a
00:29:24:WU02:FS01:Uploading 10.06MiB to 140.163.4.231
00:29:24:WU02:FS01:Connecting to 140.163.4.231:8080
00:29:24:WU01:FS01:Connecting to 65.254.110.245:8080
00:29:25:WU01:FS01:Assigned to work server 140.163.4.231
00:29:25:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK104 [GeForce GTX 760] 2258 from 140.163.4.231
00:29:25:WU01:FS01:Connecting to 140.163.4.231:8080
00:29:26:WU01:FS01:Downloading 11.29MiB
00:29:30:WU02:FS01:Upload 61.51%
00:29:31:WU01:FS01:Download complete
00:29:31:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11720 run:0 clone:1073 gen:169 core:0x21 unit:0x000000d88ca304e75b8d8e26c160f330
00:29:31:WU01:FS01:Starting
00:29:31:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 7760 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 1 -cuda-device 0 -gpu 1
00:29:31:WU01:FS01:Started FahCore on PID 6004
00:29:32:WU01:FS01:Core PID:9824
00:29:32:WU01:FS01:FahCore 0x21 started
00:29:32:WU01:FS01:0x21:*********************** Log Started 2018-10-18T00:29:32Z ***********************
00:29:32:WU01:FS01:0x21:Project: 11720 (Run 0, Clone 1073, Gen 169)
00:29:32:WU01:FS01:0x21:Unit: 0x000000d88ca304e75b8d8e26c160f330
00:29:32:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:29:32:WU01:FS01:0x21:Machine: 1
00:29:32:WU01:FS01:0x21:Reading tar file core.xml
00:29:32:WU01:FS01:0x21:Reading tar file integrator.xml
00:29:32:WU01:FS01:0x21:Reading tar file state.xml
00:29:32:WU01:FS01:0x21:Reading tar file system.xml
00:29:32:WU01:FS01:0x21:Digital signatures verified
00:29:32:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:29:32:WU01:FS01:0x21:Version 0.0.18
00:29:35:WU01:FS01:0x21:Completed 0 out of 5000000 steps (0%)
00:29:35:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:29:35:WU02:FS01:Upload complete
00:29:35:WU02:FS01:Server responded WORK_ACK (400)
00:29:35:WU02:FS01:Cleaning up
00:29:39:FS00:Paused
00:29:39:FS01:Paused
00:29:39:FS00:Shutting core down
00:29:39:FS01:Shutting core down
00:29:40:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 9824
00:29:40:WU01:FS01:0x21:Exiting, please wait. . .
00:29:40:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:29:46:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
00:29:49:Removing old file 'configs/config-20181017-142112.xml'
00:29:49:Saving configuration to config.xml
00:29:49:<config>
00:29:49: <!-- Network -->
00:29:49: <proxy v=':8080'/>
00:29:49:
00:29:49: <!-- Slot Control -->
00:29:49: <power v='full'/>
00:29:49:
00:29:49: <!-- User Information -->
00:29:49: <passkey v='********************************'/>
00:29:49: <team v='143016'/>
00:29:49: <user v='~shadowlegend~'/>
00:29:49:
00:29:49: <!-- Folding Slots -->
00:29:49: <slot id='0' type='CPU'>
00:29:49: <paused v='true'/>
00:29:49: </slot>
00:29:49: <slot id='1' type='GPU'>
00:29:49: <opencl-index v='1'/>
00:29:49: </slot>
00:29:49:</config>
When i changed to 0
*********************** Log Started 2018-10-18T00:31:44Z ***********************
00:31:44:************************* Folding@home Client *************************
00:31:44: Website: https://foldingathome.org/
00:31:44: Copyright: (c) 2009-2018 foldingathome.org
00:31:44: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:31:44: Args: --open-web-control
00:31:44: Config: C:\Users\simon\AppData\Roaming\FAHClient\config.xml
00:31:44:******************************** Build ********************************
00:31:44: Version: 7.5.1
00:31:44: Date: May 11 2018
00:31:44: Time: 13:06:32
00:31:44: Repository: Git
00:31:44: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:31:44: Branch: master
00:31:44: Compiler: Visual C++ 2008
00:31:44: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:31:44: Platform: win32 10
00:31:44: Bits: 32
00:31:44: Mode: Release
00:31:44:******************************* System ********************************
00:31:44: CPU: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
00:31:44: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:31:44: CPUs: 4
00:31:44: Memory: 7.89GiB
00:31:44: Free Memory: 2.95GiB
00:31:44: Threads: WINDOWS_THREADS
00:31:44: OS Version: 6.2
00:31:44: Has Battery: false
00:31:44: On Battery: false
00:31:44: UTC Offset: 2
00:31:44: PID: 8624
00:31:44: CWD: C:\Users\simon\AppData\Roaming\FAHClient
00:31:44: OS: Windows 10 Enterprise
00:31:44: OS Arch: AMD64
00:31:44: GPUs: 1
00:31:44: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:3 GK104 [GeForce GTX 760] 2258
00:31:44: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:10.0
00:31:44:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
00:31:44:OpenCL Device 1: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:416.34
00:31:44: Win32 Service: false
00:31:44:***********************************************************************
00:31:44:<config>
00:31:44: <!-- Network -->
00:31:44: <proxy v=':8080'/>
00:31:44:
00:31:44: <!-- Slot Control -->
00:31:44: <power v='full'/>
00:31:44:
00:31:44: <!-- User Information -->
00:31:44: <passkey v='********************************'/>
00:31:44: <team v='143016'/>
00:31:44: <user v='~shadowlegend~'/>
00:31:44:
00:31:44: <!-- Folding Slots -->
00:31:44: <slot id='0' type='CPU'>
00:31:44: <paused v='true'/>
00:31:44: </slot>
00:31:44: <slot id='1' type='GPU'>
00:31:44: <opencl-index v='0'/>
00:31:44: </slot>
00:31:44:</config>
00:31:45:Trying to access database...
00:31:45:Successfully acquired database lock
00:31:45:Enabled folding slot 00: PAUSED cpu:3 (by user)
00:31:45:Enabled folding slot 01: PAUSED gpu:0:GK104 [GeForce GTX 760] 2258 (by user)
00:31:47:10:127.0.0.1:New Web connection
00:32:19:FS00:Unpaused
00:32:19:FS01:Unpaused
00:32:19:WU01:FS01:Starting
00:32:19:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 8624 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
00:32:19:WU01:FS01:Started FahCore on PID 3832
00:32:19:WU01:FS01:Core PID:3488
00:32:19:WU01:FS01:FahCore 0x21 started
00:32:19:WU00:FS00:Starting
00:32:19:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
00:32:19:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 705 -lifeline 8624 -checkpoint 15 -np 2
00:32:19:WU00:FS00:Started FahCore on PID 4992
00:32:19:WU00:FS00:Core PID:6588
00:32:19:WU00:FS00:FahCore 0xa4 started
00:32:19:WU01:FS01:0x21:*********************** Log Started 2018-10-18T00:32:19Z ***********************
00:32:19:WU01:FS01:0x21:Project: 11720 (Run 0, Clone 1073, Gen 169)
00:32:19:WU01:FS01:0x21:Unit: 0x000000d88ca304e75b8d8e26c160f330
00:32:19:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:32:19:WU01:FS01:0x21:Machine: 1
00:32:19:WU01:FS01:0x21:Digital signatures verified
00:32:19:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:32:19:WU01:FS01:0x21:Version 0.0.18
00:32:19:WU00:FS00:0xa4:
00:32:19:WU00:FS00:0xa4:*------------------------------*
00:32:19:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
00:32:19:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
00:32:19:WU00:FS00:0xa4:Preparing to commence simulation
00:32:19:WU00:FS00:0xa4:- Looking at optimizations...
00:32:19:WU00:FS00:0xa4:- Files status OK
00:32:19:WU00:FS00:0xa4:- Expanded 826012 -> 1402156 (decompressed 169.7 percent)
00:32:19:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826012 data_size=1402156, decompressed_data_size=1402156 diff=0
00:32:19:WU00:FS00:0xa4:- Digital signature verified
00:32:19:WU00:FS00:0xa4:Project: 9035 (Run 328, Clone 2, Gen 2051)
00:32:19:WU00:FS00:0xa4:Assembly optimizations on if available.
00:32:19:WU00:FS00:0xa4:Entering M.D.
00:32:22:WU01:FS01:0x21:Completed 0 out of 5000000 steps (0%)
00:32:22:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:32:25:WU00:FS00:0xa4:Using Gromacs checkpoints
00:32:25:WU00:FS00:0xa4:Mapping NT from 2 to 2
00:32:25:WU00:FS00:0xa4:Resuming from checkpoint
00:32:25:WU00:FS00:0xa4:Verified 00/wudata_01.log
00:32:25:WU00:FS00:0xa4:Verified 00/wudata_01.trr
00:32:25:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
00:32:25:WU00:FS00:0xa4:Verified 00/wudata_01.edr
00:32:25:WU00:FS00:0xa4:Completed 101575 out of 250000 steps (40%)
00:32:46:Removing old file 'configs/config-20181017-143122.xml'
00:32:46:Saving configuration to config.xml
00:32:46:<config>
00:32:46: <!-- Network -->
00:32:46: <proxy v=':8080'/>
00:32:46:
00:32:46: <!-- Slot Control -->
00:32:46: <power v='full'/>
00:32:46:
00:32:46: <!-- User Information -->
00:32:46: <passkey v='********************************'/>
00:32:46: <team v='143016'/>
00:32:46: <user v='~shadowlegend~'/>
00:32:46:
00:32:46: <!-- Folding Slots -->
00:32:46: <slot id='0' type='CPU'/>
00:32:46: <slot id='1' type='GPU'>
00:32:46: <opencl-index v='0'/>
00:32:46: </slot>
00:32:46:</config>
00:33:41:WU00:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
00:35:12:WU01:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:36:01:WU01:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:36:47:WU01:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:36:47:WU01:FS01:0x21:ERROR:114: Max Retries Reached
00:36:47:WU01:FS01:0x21:Saving result file logfile_01.txt
00:36:47:WU01:FS01:0x21:Saving result file badstate-0.xml
00:36:47:WU01:FS01:0x21:Saving result file badstate-1.xml
00:36:47:WU01:FS01:0x21:Saving result file badstate-2.xml
00:36:47:WU01:FS01:0x21:Saving result file log.txt
00:36:47:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
00:36:47:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:36:47:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11720 run:0 clone:1073 gen:169 core:0x21 unit:0x000000d88ca304e75b8d8e26c160f330
00:36:47:WU01:FS01:Uploading 7.67MiB to 140.163.4.231
00:36:47:WU01:FS01:Connecting to 140.163.4.231:8080
00:36:48:WU02:FS01:Connecting to 65.254.110.245:8080
00:36:49:WU02:FS01:Assigned to work server 140.163.4.231
00:36:49:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GK104 [GeForce GTX 760] 2258 from 140.163.4.231
00:36:49:WU02:FS01:Connecting to 140.163.4.231:8080
00:36:50:WU02:FS01:Downloading 25.28MiB
00:36:51:WU00:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
00:36:53:WU01:FS01:Upload 76.62%
00:36:56:WU02:FS01:Download 50.20%
00:36:57:WU01:FS01:Upload complete
00:36:57:WU01:FS01:Server responded WORK_ACK (400)
00:36:57:WU01:FS01:Cleaning up
00:37:00:WU02:FS01:Download complete
00:37:00:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11718 run:0 clone:2129 gen:25 core:0x21 unit:0x0000001f8ca304e75bbce89eabbb4ef6
00:37:00:WU02:FS01:Starting
00:37:00:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\simon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 8624 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
00:37:00:WU02:FS01:Started FahCore on PID 12896
00:37:00:WU02:FS01:Core PID:6044
00:37:00:WU02:FS01:FahCore 0x21 started
00:37:01:WU02:FS01:0x21:*********************** Log Started 2018-10-18T00:37:00Z ***********************
00:37:01:WU02:FS01:0x21:Project: 11718 (Run 0, Clone 2129, Gen 25)
00:37:01:WU02:FS01:0x21:Unit: 0x0000001f8ca304e75bbce89eabbb4ef6
00:37:01:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:37:01:WU02:FS01:0x21:Machine: 1
00:37:01:WU02:FS01:0x21:Reading tar file core.xml
00:37:01:WU02:FS01:0x21:Reading tar file integrator.xml
00:37:01:WU02:FS01:0x21:Reading tar file state.xml
00:37:01:WU02:FS01:0x21:Reading tar file system.xml
00:37:01:WU02:FS01:0x21:Digital signatures verified
00:37:01:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:37:01:WU02:FS01:0x21:Version 0.0.18
00:37:08:WU02:FS01:0x21:Completed 0 out of 5000000 steps (0%)
00:37:08:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:37:46:WU02:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:40:00:WU00:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
00:40:20:WU02:FS01:0x21:ERROR:exception: Error downloading array energyBuffer: clEnqueueReadBuffer (-5)
00:40:20:WU02:FS01:0x21:Saving result file logfile_01.txt
00:40:20:WU02:FS01:0x21:Saving result file badstate-0.xml
00:40:20:WU02:FS01:0x21:Saving result file log.txt
00:40:20:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
00:40:21:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:40:21:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11718 run:0 clone:2129 gen:25 core:0x21 unit:0x0000001f8ca304e75bbce89eabbb4ef6
00:40:21:WU02:FS01:Uploading 5.95MiB to 140.163.4.231
00:40:21:WU02:FS01:Connecting to 140.163.4.231:8080
00:40:21:WU01:FS01:Connecting to 65.254.110.245:8080
00:40:21:WU01:FS01:Assigned to work server 140.163.4.231
00:40:21:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK104 [GeForce GTX 760] 2258 from 140.163.4.231
00:40:21:WU01:FS01:Connecting to 140.163.4.231:8080
00:40:22:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
00:40:22:WU02:FS01:Connecting to 140.163.4.231:80
00:40:23:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
00:40:23:WU01:FS01:Connecting to 140.163.4.231:80
00:40:23:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: No connection could be made because the target machine actively refused it.
00:40:24:WU02:FS01:Trying to send results to collection server
00:40:24:WU02:FS01:Uploading 5.95MiB to 128.252.203.2
00:40:24:WU02:FS01:Connecting to 128.252.203.2:8080
00:40:25:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: No connection could be made because the target machine actively refused it.
00:40:25:WU01:FS01:Connecting to 65.254.110.245:8080
00:40:26:WU01:FS01:Assigned to work server 140.163.4.231
00:40:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK104 [GeForce GTX 760] 2258 from 140.163.4.231
00:40:26:WU01:FS01:Connecting to 140.163.4.231:8080
00:40:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
00:40:27:WU01:FS01:Connecting to 140.163.4.231:80
00:40:28:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: No connection could be made because the target machine actively refused it.
00:40:30:WU02:FS01:Upload complete
00:40:31:WU02:FS01:Server responded WORK_ACK (400)
00:40:31:WU02:FS01:Cleaning up
00:41:21:FS00:Paused
00:41:21:FS01:Paused
00:41:21:FS00:Shutting core down
00:41:29:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
btw i only have 1 gpu
