Please add the Quadro P2000 to the GPU whitelist
Iwilsonp
Post by Iwilsonp »
Name: Nvidia Quadro P2000
Device ID: 10DE 1CBA-1028 087D
Thanks!
EDIT: consolidating posts:
Here's the output of fahclient -lspci
0x8086:0x1578:5:0:0:Intel Corporation:PCI Express Upstream Switch Port
0x8086:0x15db:58:0:0:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0x3e9b:0:2:0:Intel Corporation:Intel(R) UHD Graphics 630
0x1b21:0x1142:10:0:0:ASMedia Technology Inc.:ASMedia USB3.0 eXtensible Host Controller
0x8086:0x1911:0:8:0:Intel Corporation:Intel(R) Gaussian Mixture Model - 1911
0x8086:0x1903:0:4:0:Intel Corporation:Intel(R) Dynamic Platform and Thermal Framework Processor Participant
0x10de:0x1cba:1:0:0:NVIDIA Corporation:NVIDIA Quadro P2000
0x8086:0xa36d:0:20:0:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0xa369:0:21:1:Intel Corporation:Intel(R) Serial IO I2C Host Controller - A369
0x8086:0xa340:0:27:0:Intel Corporation:Intel(R) PCI Express Root Port #17 - A340
0x8086:0xa30e:0:31:0:Intel Corporation:C240 Series Chipset Family LPC Controller (CM246) - A30E
0x8086:0x15da:3:0:0:Intel Corporation:PCI Express Downstream Switch Port
0x8086:0x15da:3:1:0:Intel Corporation:PCI Express Downstream Switch Port
0x8086:0x15da:3:2:0:Intel Corporation:PCI Express Downstream Switch Port
0x168c:0x003e:59:0:0:Qualcomm Atheros:Qualcomm(R) QCA6174A Extended Range 802.11ac MU-MIMO Wireless Adapter
0x8086:0xa36f:0:20:2:Intel Corporation:PCI standard RAM Controller
0x8086:0xa324:0:31:5:Intel Corporation:Intel(R) SPI (flash) Controller - A324
0x10ec:0x525a:60:0:0:Realtek Semiconductor Co., Ltd.:Realtek PCIE CardReader
0x8086:0x3ec4:0:0:0:Intel Corporation:Intel(R) Host Bridge/DRAM Registers - 3EC4
0x8086:0xa360:0:22:0:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x282a:0:23:0:Intel Corporation:Intel(R) Chipset SATA/PCIe RST Premium Controller
0x8086:0x1578:6:1:0:Intel Corporation:PCI Express Downstream Switch Port
0x8086:0x1578:6:4:0:Intel Corporation:PCI Express Downstream Switch Port
0x8086:0xa368:0:21:0:Intel Corporation:Intel(R) Serial IO I2C Host Controller - A368
0x8086:0xa379:0:18:0:Intel Corporation:Intel(R) Thermal Subsystem - A379
0x8086:0x1578:8:0:0:Intel Corporation:PCI Express Upstream Switch Port
0x8086:0x15d9:4:0:0:Intel Corporation:Thunderbolt(TM) Controller - 15D9
0x8086:0xa348:0:31:3:Intel Corporation:Intel(R) Smart Sound Technology (Intel(R) SST) Audio Controller
0x8086:0xa323:0:31:4:Intel Corporation:Intel(R) SMBus - A323
0x8086:0xa33c:0:28:4:Intel Corporation:Intel(R) PCI Express Root Port #5 - A33C
0x8086:0x1901:0:1:0:Intel Corporation:Intel(R) PCIe Controller (x16) - 1901
0x8086:0x15da:2:0:0:Intel Corporation:PCI Express Upstream Switch Port
0x8086:0x1578:9:1:0:Intel Corporation:PCI Express Downstream Switch Port
0x8086:0x1578:9:4:0:Intel Corporation:PCI Express Downstream Switch Port
0x8086:0xa338:0:28:0:Intel Corporation:Intel(R) PCI Express Root Port #1 - A338
And the log file:
*********************** Log Started 2018-10-07T19:00:21Z ***********************
19:00:21:************************* Folding@home Client *************************
19:00:21:        Website: https://foldingathome.org/
19:00:21:      Copyright: (c) 2009-2018 foldingathome.org
19:00:21:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:00:21:           Args:
19:00:21:         Config: C:\Users\Peter\AppData\Roaming\FAHClient\config.xml
19:00:21:******************************** Build ********************************
19:00:21:        Version: 7.5.1
19:00:21:           Date: May 11 2018
19:00:21:           Time: 13:06:32
19:00:21:     Repository: Git
19:00:21:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
19:00:21:         Branch: master
19:00:21:       Compiler: Visual C++ 2008
19:00:21:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:00:21:       Platform: win32 10
19:00:21:           Bits: 32
19:00:21:           Mode: Release
19:00:21:******************************* System ********************************
19:00:21:            CPU: Intel(R) Core(TM) i9-8950HK CPU @ 2.90GHz
19:00:21:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
19:00:21:           CPUs: 12
19:00:21:         Memory: 31.74GiB
19:00:21:    Free Memory: 26.89GiB
19:00:21:        Threads: WINDOWS_THREADS
19:00:21:     OS Version: 6.2
19:00:21:    Has Battery: true
19:00:21:     On Battery: false
19:00:21:     UTC Offset: -4
19:00:21:            PID: 3420
19:00:21:            CWD: C:\Users\Peter\AppData\Roaming\FAHClient
19:00:21:             OS: Windows 10 Enterprise
19:00:21:        OS Arch: AMD64
19:00:21:           GPUs: 0
19:00:21:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:9.1
19:00:21:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:23.20
19:00:21:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:391.3
19:00:21:  Win32 Service: false
19:00:21:***********************************************************************
19:00:21:<config>
19:00:21:  <!-- Network -->
19:00:21:  <proxy v=':8080'/>
19:00:21:
19:00:21:  <!-- Slot Control -->
19:00:21:  <power v='full'/>
19:00:21:
19:00:21:  <!-- User Information -->
19:00:21:  <passkey v='********************************'/>
19:00:21:  <user v='Iwilsonp'/>
19:00:21:
19:00:21:  <!-- Folding Slots -->
19:00:21:  <slot id='0' type='CPU'>
19:00:21:    <cpus v='10'/>
19:00:21:  </slot>
19:00:21:</config>
19:00:21:Trying to access database...
19:00:21:Successfully acquired database lock
19:00:21:Enabled folding slot 00: READY cpu:10
19:00:21:WU00:FS00:Starting
19:00:21:WARNING:WU00:FS00:AS lowered CPUs from 10 to 4
19:00:21:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Peter\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 705 -lifeline 3420 -checkpoint 15 -np 4
19:00:21:WU00:FS00:Started FahCore on PID 12824
19:00:21:WU00:FS00:Core PID:5884
19:00:21:WU00:FS00:FahCore 0xa4 started
19:00:21:WU00:FS00:0xa4:
19:00:21:WU00:FS00:0xa4:*------------------------------*
19:00:21:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
19:00:21:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
19:00:21:WU00:FS00:0xa4:Preparing to commence simulation
19:00:21:WU00:FS00:0xa4:- Ensuring status. Please wait.
19:00:31:WU00:FS00:0xa4:- Looking at optimizations...
19:00:31:WU00:FS00:0xa4:- Working with standard loops on this execution.
19:00:31:WU00:FS00:0xa4:- Previous termination of core was improper.
19:00:31:WU00:FS00:0xa4:- Files status OK
19:00:31:WU00:FS00:0xa4:- Expanded 343354 -> 549812 (decompressed 160.1 percent)
19:00:31:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=343354 data_size=549812, decompressed_data_size=549812 diff=0
19:00:31:WU00:FS00:0xa4:- Digital signature verified
19:00:31:WU00:FS00:0xa4:Project: 8644 (Run 574, Clone 0, Gen 47)
19:00:31:WU00:FS00:0xa4:Entering M.D.
19:00:37:WU00:FS00:0xa4:Mapping NT from 4 to 4
19:00:37:WU00:FS00:0xa4:Completed 0 out of 2500000 steps  (0%)
19:02:53:WU00:FS00:0xa4:Completed 25000 out of 2500000 steps  (1%)
19:05:10:WU00:FS00:0xa4:Completed 50000 out of 2500000 steps  (2%)
Imbellis
Re: Please add the Quadro P2000 to the GPU whitelist
Post by Imbellis »
I was about to request the same then found this thread. Happy it had already been requested.
I added some GP107 based cards that were missing : Quadro P2000 Mobile, Quadro P1000 Mobile, Quadro P600 Mobile, GTX 1050 Ti Mobile and GTX 1050 Mobile.
We're still having troubles with the GPUs.txt editor that allow us to add GPUs to the list so I don't know when they will be taken into account. I'll let your know when I get confirmation.
Everything should be fine now.
Iwilsonp
Post by Iwilsonp »
Confirmed - folding is up and running on my Quadro P2000. Thank you!
thanks for letting us know!
