Could you add Nvidia RTX 2080 & 2080 Ti?
fevaoctwh
Post by fevaoctwh »
Card Name: NVIDIA GeForce RTX 2080
Device ID: 10DE 1E87 - 10DE 12A6
*********************** Log Started 2018-09-23T14:26:30Z ***********************
14:26:30:************************* Folding@home Client *************************
14:26:30:        Website: https://foldingathome.org/
14:26:30:      Copyright: (c) 2009-2018 foldingathome.org
14:26:30:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:26:30:           Args: --open-web-control
14:26:30:         Config: <none>
14:26:30:******************************** Build ********************************
14:26:30:        Version: 7.5.1
14:26:30:           Date: May 11 2018
14:26:30:           Time: 13:06:32
14:26:30:     Repository: Git
14:26:30:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:26:30:         Branch: master
14:26:30:       Compiler: Visual C++ 2008
14:26:30:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:26:30:       Platform: win32 10
14:26:30:           Bits: 32
14:26:30:           Mode: Release
14:26:30:******************************* System ********************************
14:26:30:            CPU: Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz
14:26:30:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
14:26:30:           CPUs: 8
14:26:30:         Memory: 23.94GiB
14:26:30:    Free Memory: 19.06GiB
14:26:30:        Threads: WINDOWS_THREADS
14:26:30:     OS Version: 6.2
14:26:30:    Has Battery: false
14:26:30:     On Battery: false
14:26:30:     UTC Offset: 8
14:26:30:            PID: 2368
14:26:30:            CWD: C:\Users\fevao\AppData\Roaming\FAHClient
14:26:30:             OS: Windows 10 Enterprise
14:26:30:        OS Arch: AMD64
14:26:30:           GPUs: 0
14:26:30:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.0
14:26:30:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:411.63
14:26:30:  Win32 Service: false
14:26:30:***********************************************************************
14:26:30:<config>
14:26:30:  <!-- Folding Slots -->
14:26:30:</config>
14:26:30:Connecting to assign1.foldingathome.org:8080
14:26:31:Updated GPUs.txt
14:26:31:Read GPUs.txt
14:26:31:Trying to access database...
14:26:31:Successfully acquired database lock
14:26:31:Enabled folding slot 00: PAUSED cpu:7 (not configured)
14:27:32:Saving configuration to config.xml
14:27:32:<config>
14:27:32:  <!-- Folding Slots -->
14:27:32:  <slot id='0' type='CPU'/>
14:27:32:</config>
14:27:32:Set client configured
14:27:32:WU00:FS00:Connecting to 65.254.110.245:8080
14:27:33:WU00:FS00:Connecting to 65.254.110.245:8080
14:27:35:WU00:FS00:Assigned to work server 128.252.203.4
14:27:35:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 128.252.203.4
14:27:35:WU00:FS00:Connecting to 128.252.203.4:8080
14:27:36:WU00:FS00:Downloading 1.92MiB
14:27:42:WU00:FS00:Download 13.05%
14:27:50:WU00:FS00:Download 19.58%
14:27:58:WU00:FS00:Download 26.11%
14:28:05:WU00:FS00:Download 35.90%
14:28:14:WU00:FS00:Download 42.43%
fahclient --lspci
0x8086:0x8c2d:0:26:0:Intel Corporation:Intel(R) 8 Series/C220 Series USB EHCI #2 - 8C2D
0x8086:0x8c20:0:27:0:Intel Corporation:High Definition Audio Controller
0x8086:0x0c01:0:1:0:Intel Corporation:PCI-to-PCI Bridge
0x8086:0x8c26:0:29:0:Intel Corporation:Intel(R) 8 Series/C220 Series USB EHCI #1 - 8C26
0x10de:0x10f8:1:0:1:NVIDIA Corporation:High Definition Audio Controller
0x10de:0x1ad9:1:0:3:NVIDIA Corporation:NVIDIA USB Type-C Port Policy Controller
0x8086:0x8c31:0:20:0:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0x8c3a:0:22:0:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x8c10:0:28:0:Intel Corporation:Intel(R) 8 Series/C220 Series PCI Express Root Port #1 - 8C10
0x8086:0x0c08:0:0:0:Intel Corporation:PCI standard host CPU bridge
0x8086:0x8c18:0:28:4:Intel Corporation:Intel(R) 8 Series/C220 Series PCI Express Root Port #5 - 8C18
0x8086:0x8c22:0:31:3:Intel Corporation:Intel(R) 8 Series/C220 Series SMBus Controller - 8C22
0x10de:0x1e87:1:0:0:NVIDIA Corporation:NVIDIA GeForce RTX 2080
0x8086:0x8c44:0:31:0:Intel Corporation:Intel(R) Z87 LPC Controller - 8C44
0x10de:0x1ad8:1:0:2:NVIDIA Corporation:USB xHCI Compliant Host Controller
0x8086:0x8c02:0:31:2:Intel Corporation:Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller
0x10ec:0x8168:3:0:0:Realtek Semiconductor Co., Ltd.:Realtek PCIe GBE Family Controller
fevaoctwh
Re: Could you add Nvidia RTX 2080?
Post by fevaoctwh »
For your reference
Added GPU slot with "client-type: advanced"
Esti PPD is around 1.44M
GPU Load (GPU-Z), stable at 88%
Temp 75 - 77C degrees
PRCG 11728 (0, 862, 55)
Fahcore 21
*********************** Log Started 2018-09-24T04:37:42Z ***********************
04:37:42:************************* Folding@home Client *************************
04:37:42:        Website: https://foldingathome.org/
04:37:42:      Copyright: (c) 2009-2018 foldingathome.org
04:37:42:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:37:42:           Args: --open-web-control
04:37:42:         Config: C:\Users\fevao\AppData\Roaming\FAHClient\config.xml
04:37:42:******************************** Build ********************************
04:37:42:        Version: 7.5.1
04:37:42:           Date: May 11 2018
04:37:42:           Time: 13:06:32
04:37:42:     Repository: Git
04:37:42:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
04:37:42:         Branch: master
04:37:42:       Compiler: Visual C++ 2008
04:37:42:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:37:42:       Platform: win32 10
04:37:42:           Bits: 32
04:37:42:           Mode: Release
04:37:42:******************************* System ********************************
04:37:42:            CPU: Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz
04:37:42:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
04:37:42:           CPUs: 8
04:37:42:         Memory: 23.94GiB
04:37:42:    Free Memory: 18.43GiB
04:37:42:        Threads: WINDOWS_THREADS
04:37:42:     OS Version: 6.2
04:37:42:    Has Battery: false
04:37:42:     On Battery: false
04:37:42:     UTC Offset: 8
04:37:42:            PID: 19292
04:37:42:            CWD: C:\Users\fevao\AppData\Roaming\FAHClient
04:37:42:             OS: Windows 10 Enterprise
04:37:42:        OS Arch: AMD64
04:37:42:           GPUs: 0
04:37:42:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.0
04:37:42:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:411.63
04:37:42:  Win32 Service: false
04:37:42:***********************************************************************
04:37:42:<config>
04:37:42:  <!-- Folding Slot Configuration -->
04:37:42:  <cause v='CANCER'/>
04:37:42:
04:37:42:  <!-- Network -->
04:37:42:  <proxy v=':8080'/>
04:37:42:
04:37:42:  <!-- Slot Control -->
04:37:42:  <pause-on-battery v='false'/>
04:37:42:  <power v='full'/>
04:37:42:
04:37:42:  <!-- User Information -->
04:37:42:  <passkey v='********************************'/>
04:37:42:  <team v='3213'/>
04:37:42:  <user v='FlyingCat'/>
04:37:42:
04:37:42:  <!-- Folding Slots -->
04:37:42:  <slot id='0' type='CPU'>
04:37:42:    <cpus v='8'/>
04:37:42:    <paused v='true'/>
04:37:42:  </slot>
04:37:42:</config>
04:37:42:Connecting to assign1.foldingathome.org:8080
04:37:43:Updated GPUs.txt
04:37:43:Read GPUs.txt
04:37:43:Trying to access database...
04:37:43:Successfully acquired database lock
04:37:43:Enabled folding slot 00: PAUSED cpu:8 (by user)
04:38:34:Adding folding slot 01: READY gpu:0:TU104-400A-A1 [GeForce RTX 2080]
04:38:34:Removing old file 'configs/config-20180923-144717.xml'
04:38:34:Saving configuration to config.xml
04:38:34:<config>
04:38:34:  <!-- Folding Slot Configuration -->
04:38:34:  <cause v='CANCER'/>
04:38:34:
04:38:34:  <!-- Network -->
04:38:34:  <proxy v=':8080'/>
04:38:34:
04:38:34:  <!-- Slot Control -->
04:38:34:  <pause-on-battery v='false'/>
04:38:34:  <power v='full'/>
04:38:34:
04:38:34:  <!-- User Information -->
04:38:34:  <passkey v='********************************'/>
04:38:34:  <team v='3213'/>
04:38:34:  <user v='FlyingCat'/>
04:38:34:
04:38:34:  <!-- Folding Slots -->
04:38:34:  <slot id='0' type='CPU'>
04:38:34:    <cpus v='8'/>
04:38:34:    <paused v='true'/>
04:38:34:  </slot>
04:38:34:  <slot id='1' type='GPU'>
04:38:34:    <client-type v='advanced'/>
04:38:34:  </slot>
04:38:34:</config>
04:38:35:WU00:FS01:Connecting to 65.254.110.245:8080
04:38:35:WU00:FS01:Assigned to work server 140.163.4.231
04:38:35:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104-400A-A1 [GeForce RTX 2080] from 140.163.4.231
04:38:35:WU00:FS01:Connecting to 140.163.4.231:8080
04:38:36:WU00:FS01:Downloading 14.57MiB
04:38:42:WU00:FS01:Download 4.72%
04:38:44:Removing old file 'configs/config-20180923-144801.xml'
04:38:44:Saving configuration to config.xml
04:38:44:<config>
04:38:44:  <!-- Folding Slot Configuration -->
04:38:44:  <cause v='CANCER'/>
04:38:44:
04:38:44:  <!-- Network -->
04:38:44:  <proxy v=':8080'/>
04:38:44:
04:38:44:  <!-- Slot Control -->
04:38:44:  <pause-on-battery v='false'/>
04:38:44:  <power v='full'/>
04:38:44:
04:38:44:  <!-- User Information -->
04:38:44:  <passkey v='********************************'/>
04:38:44:  <team v='3213'/>
04:38:44:  <user v='FlyingCat'/>
04:38:44:
04:38:44:  <!-- Folding Slots -->
04:38:44:  <slot id='0' type='CPU'>
04:38:44:    <cpus v='8'/>
04:38:44:    <paused v='true'/>
04:38:44:  </slot>
04:38:44:  <slot id='1' type='GPU'>
04:38:44:    <client-type v='advanced'/>
04:38:44:  </slot>
04:38:44:</config>
04:38:48:WU00:FS01:Download 10.73%
04:38:54:WU00:FS01:Download 16.31%
04:39:00:WU00:FS01:Download 22.31%
04:39:06:WU00:FS01:Download 28.32%
04:39:12:WU00:FS01:Download 32.18%
04:39:18:WU00:FS01:Download 35.19%
04:39:24:WU00:FS01:Download 38.62%
04:39:30:WU00:FS01:Download 50.20%
04:39:36:WU00:FS01:Download 67.37%
04:39:42:WU00:FS01:Download 75.95%
04:39:48:WU00:FS01:Download 81.10%
04:39:54:WU00:FS01:Download 86.68%
04:40:00:WU00:FS01:Download 94.83%
04:40:05:WU00:FS01:Download complete
04:40:05:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11728 run:0 clone:862 gen:55 core:0x21 unit:0x0000003b8ca304e75b99808319bbca82
04:40:05:WU00:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah
04:40:05:WU00:FS01:Connecting to cores.foldingathome.org:80
04:40:06:WU00:FS01:FahCore 21: Downloading 3.47MiB
04:40:12:WU00:FS01:FahCore 21: 61.20%
04:40:14:WU00:FS01:FahCore 21: Download complete
04:40:14:WU00:FS01:Valid core signature
04:40:14:WU00:FS01:Unpacked 11.80MiB to cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe
04:40:14:WU00:FS01:Starting
04:40:14:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\fevao\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 19292 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
04:40:14:WU00:FS01:Started FahCore on PID 5040
04:40:14:WU00:FS01:Core PID:15120
04:40:14:WU00:FS01:FahCore 0x21 started
04:40:15:WU00:FS01:0x21:*********************** Log Started 2018-09-24T04:40:14Z ***********************
04:40:15:WU00:FS01:0x21:Project: 11728 (Run 0, Clone 862, Gen 55)
04:40:15:WU00:FS01:0x21:Unit: 0x0000003b8ca304e75b99808319bbca82
04:40:15:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:40:15:WU00:FS01:0x21:Machine: 1
04:40:15:WU00:FS01:0x21:Reading tar file core.xml
04:40:15:WU00:FS01:0x21:Reading tar file integrator.xml
04:40:15:WU00:FS01:0x21:Reading tar file state.xml
04:40:15:WU00:FS01:0x21:Reading tar file system.xml
04:40:15:WU00:FS01:0x21:Digital signatures verified
04:40:15:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:40:15:WU00:FS01:0x21:Version 0.0.18
04:40:23:WU00:FS01:0x21:Completed 0 out of 5000000 steps (0%)
04:40:23:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:41:12:WU00:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
04:42:02:WU00:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
04:42:51:WU00:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
04:43:41:WU00:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
04:44:32:WU00:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
04:45:24:WU00:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
04:46:15:WU00:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
04:47:06:WU00:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
04:47:57:WU00:FS01:0x21:Completed 450000 out of 5000000 steps (9%)
04:48:48:WU00:FS01:0x21:Completed 500000 out of 5000000 steps (10%)
04:49:32:Removing old file 'configs/config-20180923-144811.xml'
04:49:32:Saving configuration to config.xml
04:49:32:<config>
04:49:32:  <!-- Folding Slot Configuration -->
04:49:32:  <cause v='CANCER'/>
04:49:32:
04:49:32:  <!-- Network -->
04:49:32:  <proxy v=':8080'/>
04:49:32:
04:49:32:  <!-- Slot Control -->
04:49:32:  <pause-on-battery v='false'/>
04:49:32:  <power v='full'/>
04:49:32:
04:49:32:  <!-- User Information -->
04:49:32:  <passkey v='********************************'/>
04:49:32:  <team v='3213'/>
04:49:32:  <user v='FlyingCat'/>
04:49:32:
04:49:32:  <!-- Folding Slots -->
04:49:32:  <slot id='0' type='CPU'>
04:49:32:    <cpus v='8'/>
04:49:32:    <paused v='true'/>
04:49:32:  </slot>
04:49:32:  <slot id='1' type='GPU'>
04:49:32:    <client-type v='advanced'/>
04:49:32:  </slot>
04:49:32:</config>
04:49:40:WU00:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
04:49:55:Removing old file 'configs/config-20180923-144832.xml'
04:49:55:Saving configuration to config.xml
04:49:55:<config>
04:49:55:  <!-- Folding Slot Configuration -->
04:49:55:  <cause v='CANCER'/>
04:49:55:
04:49:55:  <!-- Network -->
04:49:55:  <proxy v=':8080'/>
04:49:55:
04:49:55:  <!-- Slot Control -->
04:49:55:  <pause-on-battery v='false'/>
04:49:55:  <power v='full'/>
04:49:55:
04:49:55:  <!-- User Information -->
04:49:55:  <passkey v='********************************'/>
04:49:55:  <team v='3213'/>
04:49:55:  <user v='FlyingCat'/>
04:49:55:
04:49:55:  <!-- Folding Slots -->
04:49:55:  <slot id='0' type='CPU'>
04:49:55:    <cpus v='8'/>
04:49:55:    <paused v='true'/>
04:49:55:  </slot>
04:49:55:  <slot id='1' type='GPU'>
04:49:55:    <client-type v='advanced'/>
04:49:55:  </slot>
04:49:55:</config>
04:50:31:WU00:FS01:0x21:Completed 600000 out of 5000000 steps (12%)
04:51:21:WU00:FS01:0x21:Completed 650000 out of 5000000 steps (13%)
04:52:12:WU00:FS01:0x21:Completed 700000 out of 5000000 steps (14%)
04:53:03:WU00:FS01:0x21:Completed 750000 out of 5000000 steps (15%)
04:53:56:WU00:FS01:0x21:Completed 800000 out of 5000000 steps (16%)
04:54:49:WU00:FS01:0x21:Completed 850000 out of 5000000 steps (17%)
04:55:40:WU00:FS01:0x21:Completed 900000 out of 5000000 steps (18%)
04:56:32:WU00:FS01:0x21:Completed 950000 out of 5000000 steps (19%)
04:57:23:WU00:FS01:0x21:Completed 1000000 out of 5000000 steps (20%)
04:58:15:WU00:FS01:0x21:Completed 1050000 out of 5000000 steps (21%)
04:59:05:WU00:FS01:0x21:Completed 1100000 out of 5000000 steps (22%)
04:59:56:WU00:FS01:0x21:Completed 1150000 out of 5000000 steps (23%)
05:00:46:WU00:FS01:0x21:Completed 1200000 out of 5000000 steps (24%)
05:01:37:WU00:FS01:0x21:Completed 1250000 out of 5000000 steps (25%)
05:02:28:WU00:FS01:0x21:Completed 1300000 out of 5000000 steps (26%)
05:03:18:WU00:FS01:0x21:Completed 1350000 out of 5000000 steps (27%)
05:04:09:WU00:FS01:0x21:Completed 1400000 out of 5000000 steps (28%)
05:04:59:WU00:FS01:0x21:Completed 1450000 out of 5000000 steps (29%)
05:05:49:WU00:FS01:0x21:Completed 1500000 out of 5000000 steps (30%)
05:06:41:WU00:FS01:0x21:Completed 1550000 out of 5000000 steps (31%)
05:07:32:WU00:FS01:0x21:Completed 1600000 out of 5000000 steps (32%)
05:07:58:FS00:Unpaused
05:07:58:FS00:Finishing
05:07:58:FS01:Finishing
05:08:13:Removing old file 'configs/config-20180923-144853.xml'
05:08:13:Saving configuration to config.xml
05:08:13:<config>
05:08:13:  <!-- Folding Slot Configuration -->
05:08:13:  <cause v='CANCER'/>
05:08:13:
05:08:13:  <!-- Network -->
05:08:13:  <proxy v=':8080'/>
05:08:13:
05:08:13:  <!-- Slot Control -->
05:08:13:  <pause-on-battery v='false'/>
05:08:13:  <power v='full'/>
05:08:13:
05:08:13:  <!-- User Information -->
05:08:13:  <passkey v='********************************'/>
05:08:13:  <team v='3213'/>
05:08:13:  <user v='FlyingCat'/>
05:08:13:
05:08:13:  <!-- Folding Slots -->
05:08:13:  <slot id='0' type='CPU'>
05:08:13:    <cpus v='8'/>
05:08:13:  </slot>
05:08:13:  <slot id='1' type='GPU'>
05:08:13:    <client-type v='advanced'/>
05:08:13:  </slot>
05:08:13:</config>
05:08:22:WU00:FS01:0x21:Completed 1650000 out of 5000000 steps (33%)
05:09:13:WU00:FS01:0x21:Completed 1700000 out of 5000000 steps (34%)
05:10:04:WU00:FS01:0x21:Completed 1750000 out of 5000000 steps (35%)
05:10:57:WU00:FS01:0x21:Completed 1800000 out of 5000000 steps (36%)
05:11:48:WU00:FS01:0x21:Completed 1850000 out of 5000000 steps (37%)
05:12:38:WU00:FS01:0x21:Completed 1900000 out of 5000000 steps (38%)
05:13:29:WU00:FS01:0x21:Completed 1950000 out of 5000000 steps (39%)
05:14:20:WU00:FS01:0x21:Completed 2000000 out of 5000000 steps (40%)
05:15:12:WU00:FS01:0x21:Completed 2050000 out of 5000000 steps (41%)
05:16:03:WU00:FS01:0x21:Completed 2100000 out of 5000000 steps (42%)
05:16:55:WU00:FS01:0x21:Completed 2150000 out of 5000000 steps (43%)
05:17:46:WU00:FS01:0x21:Completed 2200000 out of 5000000 steps (44%)
05:18:36:WU00:FS01:0x21:Completed 2250000 out of 5000000 steps (45%)
05:19:28:WU00:FS01:0x21:Completed 2300000 out of 5000000 steps (46%)
05:20:20:WU00:FS01:0x21:Completed 2350000 out of 5000000 steps (47%)
05:21:10:WU00:FS01:0x21:Completed 2400000 out of 5000000 steps (48%)
05:22:01:WU00:FS01:0x21:Completed 2450000 out of 5000000 steps (49%)
05:22:52:WU00:FS01:0x21:Completed 2500000 out of 5000000 steps (50%)
05:23:44:WU00:FS01:0x21:Completed 2550000 out of 5000000 steps (51%)
05:24:35:WU00:FS01:0x21:Completed 2600000 out of 5000000 steps (52%)
05:25:26:WU00:FS01:0x21:Completed 2650000 out of 5000000 steps (53%)
05:26:17:WU00:FS01:0x21:Completed 2700000 out of 5000000 steps (54%)
05:27:08:WU00:FS01:0x21:Completed 2750000 out of 5000000 steps (55%)
05:27:59:WU00:FS01:0x21:Completed 2800000 out of 5000000 steps (56%)
05:28:50:WU00:FS01:0x21:Completed 2850000 out of 5000000 steps (57%)
05:29:41:WU00:FS01:0x21:Completed 2900000 out of 5000000 steps (58%)
05:30:31:WU00:FS01:0x21:Completed 2950000 out of 5000000 steps (59%)
05:31:21:WU00:FS01:0x21:Completed 3000000 out of 5000000 steps (60%)
05:32:12:WU00:FS01:0x21:Completed 3050000 out of 5000000 steps (61%)
05:33:04:WU00:FS01:0x21:Completed 3100000 out of 5000000 steps (62%)
05:33:55:WU00:FS01:0x21:Completed 3150000 out of 5000000 steps (63%)
05:34:47:WU00:FS01:0x21:Completed 3200000 out of 5000000 steps (64%)
05:35:39:WU00:FS01:0x21:Completed 3250000 out of 5000000 steps (65%)
05:36:31:WU00:FS01:0x21:Completed 3300000 out of 5000000 steps (66%)
05:37:22:WU00:FS01:0x21:Completed 3350000 out of 5000000 steps (67%)
05:38:12:WU00:FS01:0x21:Completed 3400000 out of 5000000 steps (68%)
05:39:02:WU00:FS01:0x21:Completed 3450000 out of 5000000 steps (69%)
05:39:52:WU00:FS01:0x21:Completed 3500000 out of 5000000 steps (70%)
05:40:44:WU00:FS01:0x21:Completed 3550000 out of 5000000 steps (71%)
05:41:34:WU00:FS01:0x21:Completed 3600000 out of 5000000 steps (72%)
05:42:25:WU00:FS01:0x21:Completed 3650000 out of 5000000 steps (73%)
05:43:16:WU00:FS01:0x21:Completed 3700000 out of 5000000 steps (74%)
05:44:07:WU00:FS01:0x21:Completed 3750000 out of 5000000 steps (75%)
05:44:58:WU00:FS01:0x21:Completed 3800000 out of 5000000 steps (76%)
05:45:48:WU00:FS01:0x21:Completed 3850000 out of 5000000 steps (77%)
05:46:39:WU00:FS01:0x21:Completed 3900000 out of 5000000 steps (78%)
05:47:29:WU00:FS01:0x21:Completed 3950000 out of 5000000 steps (79%)
05:48:20:WU00:FS01:0x21:Completed 4000000 out of 5000000 steps (80%)
05:49:12:WU00:FS01:0x21:Completed 4050000 out of 5000000 steps (81%)
05:50:02:WU00:FS01:0x21:Completed 4100000 out of 5000000 steps (82%)
05:50:52:WU00:FS01:0x21:Completed 4150000 out of 5000000 steps (83%)
05:51:43:WU00:FS01:0x21:Completed 4200000 out of 5000000 steps (84%)
05:52:34:WU00:FS01:0x21:Completed 4250000 out of 5000000 steps (85%)
05:53:26:WU00:FS01:0x21:Completed 4300000 out of 5000000 steps (86%)
05:54:18:WU00:FS01:0x21:Completed 4350000 out of 5000000 steps (87%)
05:55:11:WU00:FS01:0x21:Completed 4400000 out of 5000000 steps (88%)
05:56:03:WU00:FS01:0x21:Completed 4450000 out of 5000000 steps (89%)
05:56:56:WU00:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
05:57:50:WU00:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
05:58:42:WU00:FS01:0x21:Completed 4600000 out of 5000000 steps (92%)
05:59:35:WU00:FS01:0x21:Completed 4650000 out of 5000000 steps (93%)
06:00:28:WU00:FS01:0x21:Completed 4700000 out of 5000000 steps (94%)
06:01:21:WU00:FS01:0x21:Completed 4750000 out of 5000000 steps (95%)
06:02:14:WU00:FS01:0x21:Completed 4800000 out of 5000000 steps (96%)
06:03:07:WU00:FS01:0x21:Completed 4850000 out of 5000000 steps (97%)
06:04:00:WU00:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
06:04:52:WU00:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
06:05:45:WU00:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
06:05:46:WU00:FS01:0x21:Saving result file logfile_01.txt
06:05:46:WU00:FS01:0x21:Saving result file checkpointState.xml
06:05:47:WU00:FS01:0x21:Saving result file checkpt.crc
06:05:47:WU00:FS01:0x21:Saving result file log.txt
06:05:47:WU00:FS01:0x21:Saving result file positions.xtc
06:05:47:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
06:05:47:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:05:47:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11728 run:0 clone:862 gen:55 core:0x21 unit:0x0000003b8ca304e75b99808319bbca82
06:05:47:WU00:FS01:Uploading 9.39MiB to 140.163.4.231
06:05:47:WU00:FS01:Connecting to 140.163.4.231:8080
06:05:53:WU00:FS01:Upload 13.32%
06:05:59:WU00:FS01:Upload 31.29%
06:06:05:WU00:FS01:Upload 49.93%
06:06:11:WU00:FS01:Upload 68.58%
06:06:17:WU00:FS01:Upload 87.89%
06:06:21:WU00:FS01:Upload complete
06:06:21:WU00:FS01:Server responded WORK_ACK (400)
06:06:21:WU00:FS01:Final credit estimate, 82650.00 points
06:06:21:WU00:FS01:Cleaning up
Calcii
Post by Calcii »
Core frequency?
fevaoctwh
Post by fevaoctwh »
Maintained around 1900
Maybe the Turing Core is now only using the CUDA part for the computing. Tensor and RT parts probably are just idle. Hope it could be stronger in the future, especially the tensor cores are labelled as "AI".
RTX 2080, TU-104, is the 545mm monster... 2080ti is even bigger...
Ran FAHBench with the following settings:
Compute: OpenCL
Precision: Single
WU: dhfr
Accuracy Check: Enabled
NaN Check: 0-disabled
Run Length: 1 min
Score: 138.529
Scaled Score: 138.529
Atoms: 23558
Post by foldy »
Project 11728 TPF only 51 sec on Windows, maybe would be even faster on Linux.
fevaoctwh
Post by fevaoctwh »
Yep, and this is only 2080. Ti should be 30% faster
Calcii
Post by Calcii »
foldy wrote:Project 11728 TPF only 51 sec on Windows, maybe would be even faster on Linux.
10% faster
bcavnaugh
Post by bcavnaugh »
What settings did you add to the GPUs.txt file?
Looks like the GPUs.txt file was updated and the RTX 2080 was added :D
0x10de:0x1e87:2:7:TU104-400A-A1 [GeForce RTX 2080]
Do we also need to add client-type =advanced?
Thanks for any help with this.
Now a we need it the Ti Version added.
Those are independent settings.
the existence of a valid setting for a NVidia GPU in GPUs.txt enables the client-server connection to download an assignment for a GPU that's a Fermi or greater. The drivers downloaded from NVidia are responsible for converting OpenCL directives (or potentially CUDA directives, though FAHCore_21 doesn't use them) to specific directives for each of the GPUs supported by that driver set.
Independently, FAH projects are classified as beta/advanced/fah which represents the risk associated with that particular project. New projects are first classified as beta until a reasonable number of WUs have been successfully returned -- or until a problem is found and corrected. Then the project is reclassified as advanced -- a stage that might be called "late beta" -- until the project is deemed safe enough to be released to fah.
The advanced setting is NOT required when new hardware/drivers are released by the GPU manufacturer. Both NVidia and AMD/ATI have a pretty good track record of releasing stable drivers so FAH trusts them (... although there have been cases where problems were discovered), FAH hasn't set up a post-release testing for the drivers ... and we can't really do anything about them anyway ... though you'd probably immediately find a number of comments here if a bad set did get released.
arcDaniel
Nvidia RTX 2080ti
Post by arcDaniel »
Can you please add the Nvidia RTX 2080ti
Device ID: 10DE 1E07-10DE 12A4
Thanks!
Re: Could you add Nvidia RTX 2080 & 2080 Ti?
Done.
Please report the PPD performance once it has stabilized.
arcDaniel
Post by arcDaniel »
Yes I will do that, thanks!
arcDaniel
Post by arcDaniel »
Sorry, I have made a mistake, my Device ID is:
10DE 1E07 - 3842 2383
fir the RTX2080ti
Sorry, the last one, was apperently the ID from a 2080ti posted on an other Forum. Now that I have mine mounted an checked, I saw the change.
Sorry, can you please add that ID?
scott@bjorn3d
Post by scott@bjorn3d »
I you sure on the ID? That ID was pulled from GPU-Z and looks like a NVIDIA ID. I was the one that pulled it and put it on EVGA site. It looks close to the other ID as far as an NVIDIA part.
arcDaniel
Post by arcDaniel »
I got it from my GPU-Z
