GPU stats not showing up but CPU are???
dwayman
Post by dwayman »
F@H client crashed this morning, when I restarted things were wrong. Folding was at half, key was missing, and all the setting were back to default. I set up everything as previous and now I am getting CPU/GPU stats from a second machine but this one with two GPU's (GeForce Nvidia 1080Ti) are not showing up any stats at all. So far I have a least 6 work units missing. I have checked the forum and didn't see any complaint the stats server isn't working.
*********************** Log Started 2018-09-22T20:08:35Z ***********************
20:08:35:************************* Folding@home Client *************************
20:08:35:        Website: https://foldingathome.org/
20:08:35:      Copyright: (c) 2009-2018 foldingathome.org
20:08:35:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:08:35:           Args: --open-web-control
20:08:35:         Config: C:\Users\Don\AppData\Roaming\FAHClient\config.xml
20:08:35:******************************** Build ********************************
20:08:35:        Version: 7.5.1
20:08:35:           Date: May 11 2018
20:08:35:           Time: 13:06:32
20:08:35:     Repository: Git
20:08:35:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:08:35:         Branch: master
20:08:35:       Compiler: Visual C++ 2008
20:08:35:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:08:35:       Platform: win32 10
20:08:35:           Bits: 32
20:08:35:           Mode: Release
20:08:35:******************************* System ********************************
20:08:35:            CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
20:08:35:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
20:08:35:           CPUs: 8
20:08:35:         Memory: 39.96GiB
20:08:35:    Free Memory: 36.41GiB
20:08:35:        Threads: WINDOWS_THREADS
20:08:35:     OS Version: 6.2
20:08:35:    Has Battery: false
20:08:35:     On Battery: false
20:08:35:     UTC Offset: -4
20:08:35:            PID: 1728
20:08:35:            CWD: C:\Users\Don\AppData\Roaming\FAHClient
20:08:35:             OS: Windows 10 Enterprise
20:08:35:        OS Arch: AMD64
20:08:35:           GPUs: 2
20:08:35:          GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:7 GP102 [GeForce GTX 1080 Ti] 11380
20:08:35:          GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:7 GP102 [GeForce GTX 1080 Ti] 11380
20:08:35:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.0
20:08:35:  CUDA Device 1: Platform:0 Device:1 Bus:2 Slot:0 Compute:6.1 Driver:10.0
20:08:35:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:411.63
20:08:35:OpenCL Device 1: Platform:0 Device:1 Bus:2 Slot:0 Compute:1.2 Driver:411.63
20:08:35:  Win32 Service: false
20:08:35:***********************************************************************
20:08:35:<config>
20:08:35:  <!-- Folding Core -->
20:08:35:  <checkpoint v='30'/>
20:08:35:
20:08:35:  <!-- Folding Slot Configuration -->
20:08:35:  <client-type v='advanced'/>
20:08:35:  <max-packet-size v='big'/>
20:08:35:
20:08:35:  <!-- Network -->
20:08:35:  <proxy v=':8080'/>
20:08:35:
20:08:35:  <!-- Slot Control -->
20:08:35:  <power v='full'/>
20:08:35:
20:08:35:  <!-- User Information -->
20:08:35:  <passkey v='********************************'/>
20:08:35:
20:08:35:  <!-- Folding Slots -->
20:08:35:  <slot id='1' type='GPU'>
20:08:35:    <paused v='true'/>
20:08:35:  </slot>
20:08:35:  <slot id='2' type='GPU'>
20:08:35:  </slot>
20:08:35:</config>
20:08:35:Trying to access database...
20:08:35:Successfully acquired database lock
20:08:35:Enabled folding slot 01: PAUSED gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 (by user)
20:08:35:Enabled folding slot 02: PAUSED gpu:1:GP102 [GeForce GTX 1080 Ti] 11380 (by user)
20:08:40:7:127.0.0.1:New Web connection
20:10:23:FS01:Unpaused
20:10:23:FS02:Unpaused
20:10:23:WU00:FS01:Starting
20:10:23:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Don\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 1728 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
20:10:23:WU00:FS01:Started FahCore on PID 3284
20:10:23:WU00:FS01:Core PID:13392
20:10:23:WU00:FS01:FahCore 0x21 started
20:10:23:WU02:FS02:Starting
20:10:23:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Don\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 1728 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:10:23:WU02:FS02:Started FahCore on PID 12516
20:10:23:WU02:FS02:Core PID:10000
20:10:23:WU02:FS02:FahCore 0x21 started
20:10:23:WU00:FS01:0x21:*********************** Log Started 2018-09-22T20:10:23Z ***********************
20:10:23:WU00:FS01:0x21:Project: 13815 (Run 0, Clone 17, Gen 433)
20:10:23:WU00:FS01:0x21:Unit: 0x000001b680fccb045b33ea6a0c260833
20:10:23:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
20:10:23:WU00:FS01:0x21:Machine: 1
20:10:23:WU00:FS01:0x21:Digital signatures verified
20:10:23:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
20:10:23:WU00:FS01:0x21:Version 0.0.18
20:10:23:WU00:FS01:0x21:  Found a checkpoint file
20:10:24:WU02:FS02:0x21:*********************** Log Started 2018-09-22T20:10:23Z ***********************
20:10:24:WU02:FS02:0x21:Project: 11726 (Run 0, Clone 1841, Gen 40)
20:10:24:WU02:FS02:0x21:Unit: 0x000000358ca304e75b95ba69fc70e3ff
20:10:24:WU02:FS02:0x21:CPU: 0x00000000000000000000000000000000
20:10:24:WU02:FS02:0x21:Machine: 2
20:10:24:WU02:FS02:0x21:Digital signatures verified
20:10:24:WU02:FS02:0x21:Folding@home GPU Core21 Folding@home Core
20:10:24:WU02:FS02:0x21:Version 0.0.18
20:10:24:WU02:FS02:0x21:  Found a checkpoint file
20:10:27:WU02:FS02:0x21:Completed 3750000 out of 5000000 steps (75%)
20:10:27:WU02:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:10:37:Removing old file 'configs/config-20180920-112135.xml'
20:10:37:Saving configuration to config.xml
20:10:37:<config>
20:10:37:  <!-- Folding Core -->
20:10:37:  <checkpoint v='30'/>
20:10:37:
20:10:37:  <!-- Folding Slot Configuration -->
20:10:37:  <client-type v='advanced'/>
20:10:37:  <max-packet-size v='big'/>
20:10:37:
20:10:37:  <!-- Network -->
20:10:37:  <proxy v=':8080'/>
20:10:37:
20:10:37:  <!-- Slot Control -->
20:10:37:  <power v='full'/>
20:10:37:
20:10:37:  <!-- User Information -->
20:10:37:  <passkey v='********************************'/>
20:10:37:  <team v='169927'/>
20:10:37:  <user v='dwayman'/>
20:10:37:
20:10:37:  <!-- Folding Slots -->
20:10:37:  <slot id='1' type='GPU'/>
20:10:37:  <slot id='2' type='GPU'/>
20:10:37:</config>
20:10:38:WU00:FS01:0x21:Completed 1000000 out of 1500000 steps (66%)
20:10:38:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:11:29:WU00:FS01:0x21:Completed 1005000 out of 1500000 steps (67%)
20:11:40:WU02:FS02:0x21:Completed 3800000 out of 5000000 steps (76%)
20:12:54:WU02:FS02:0x21:Completed 3850000 out of 5000000 steps (77%)
20:13:12:WU00:FS01:0x21:Completed 1020000 out of 1500000 steps (68%)
20:14:08:WU02:FS02:0x21:Completed 3900000 out of 5000000 steps (78%)
20:14:54:WU00:FS01:0x21:Completed 1035000 out of 1500000 steps (69%)
20:15:22:WU02:FS02:0x21:Completed 3950000 out of 5000000 steps (79%)
20:16:36:WU02:FS02:0x21:Completed 4000000 out of 5000000 steps (80%)
20:16:36:WU00:FS01:0x21:Completed 1050000 out of 1500000 steps (70%)
20:17:23:Removing old file 'configs/config-20180922-111004.xml'
20:17:23:Saving configuration to config.xml
20:17:23:<config>
20:17:23:  <!-- Folding Core -->
20:17:23:  <checkpoint v='30'/>
20:17:23:
20:17:23:  <!-- Folding Slot Configuration -->
20:17:23:  <client-type v='advanced'/>
20:17:23:  <max-packet-size v='big'/>
20:17:23:
20:17:23:  <!-- Network -->
20:17:23:  <proxy v=':8080'/>
20:17:23:
20:17:23:  <!-- Slot Control -->
20:17:23:  <power v='full'/>
20:17:23:
20:17:23:  <!-- User Information -->
20:17:23:  <passkey v='********************************'/>
20:17:23:  <team v='169927'/>
20:17:23:  <user v='dwayman'/>
20:17:23:
20:17:23:  <!-- Folding Slots -->
20:17:23:  <slot id='1' type='GPU'/>
20:17:23:  <slot id='2' type='GPU'/>
20:17:23:</config>
20:17:51:WU02:FS02:0x21:Completed 4050000 out of 5000000 steps (81%)
20:18:18:WU00:FS01:0x21:Completed 1065000 out of 1500000 steps (71%)
20:19:05:WU02:FS02:0x21:Completed 4100000 out of 5000000 steps (82%)
20:20:00:WU00:FS01:0x21:Completed 1080000 out of 1500000 steps (72%)
20:20:19:WU02:FS02:0x21:Completed 4150000 out of 5000000 steps (83%)
20:21:32:WU02:FS02:0x21:Completed 4200000 out of 5000000 steps (84%)
20:21:42:WU00:FS01:0x21:Completed 1095000 out of 1500000 steps (73%)
dwayman
Re: GPU stats not showing up but CPU are???
Post by dwayman »
Removed F@H from computer, reinstalled and restarted and manually added all info. Seems to be working via the donnor points search but in the process I lost 734751 points because for some reason F@H crashed. Are those points gone for good or is there a way to request them to be added back??
Thank you
Unless the results were successfully uploaded before the deadline, the points are lost. If tyou can locate a log saying the Wu was received by the server yet no points were received, please report the PRCG of the WU(s).
dwayman
Post by dwayman »
Messed up on the log. Cleared and the reset it so I lost everything. Does F@H save logs?
By default FAH saves the last 16 logs in folder at the same location as the current log. Each has its name modified to include a timestamp.
SteveWillis
Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Post by SteveWillis »
On Linux fah saves old logs in the sub folder "logs" of the folder holding logs.txt /var/lib/fahclient/logs. I can't comment on windows.
dwayman
Post by dwayman »
13:31:34:WU01:FS01:Connecting to 65.254.110.245:8080
13:31:34:WU01:FS01:Assigned to work server 140.163.4.231
13:31:34:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.231
13:31:34:WU01:FS01:Connecting to 140.163.4.231:8080
13:31:35:WU01:FS01:Downloading 5.42MiB
13:31:40:WU01:FS01:Download complete
13:31:40:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11715 run:2 clone:138 gen:80 core:0x21 unit:0x0000005d8ca304e75b29c35786174c51
13:32:14:WU02:FS02:0x21:Completed 1365000 out of 1500000 steps (91%)
13:32:25:WU00:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
13:32:26:WU00:FS01:0x21:Saving result file logfile_01.txt
13:32:26:WU00:FS01:0x21:Saving result file checkpointState.xml
13:32:26:WU00:FS01:0x21:Saving result file checkpt.crc
13:32:26:WU00:FS01:0x21:Saving result file log.txt
13:32:26:WU00:FS01:0x21:Saving result file positions.xtc
13:32:26:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
13:32:27:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:32:27:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11728 run:0 clone:749 gen:69 core:0x21 unit:0x0000004a8ca304e75b99807d9ec97af7
13:32:27:WU00:FS01:Uploading 9.39MiB to 140.163.4.231
13:32:27:WU01:FS01:Starting
13:32:27:WU00:FS01:Connecting to 140.163.4.231:8080
13:32:27:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Don\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 2720 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
13:32:27:WU01:FS01:Started FahCore on PID 2236
13:32:27:WU01:FS01:Core PID:1332
13:32:27:WU01:FS01:FahCore 0x21 started
13:32:27:WU01:FS01:0x21:*********************** Log Started 2018-09-22T13:32:27Z ***********************
13:32:27:WU01:FS01:0x21:Project: 11715 (Run 2, Clone 138, Gen 80)
13:32:27:WU01:FS01:0x21:Unit: 0x0000005d8ca304e75b29c35786174c51
13:32:27:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
13:32:27:WU01:FS01:0x21:Machine: 1
13:32:27:WU01:FS01:0x21:Reading tar file core.xml
13:32:27:WU01:FS01:0x21:Reading tar file integrator.xml
13:32:27:WU01:FS01:0x21:Reading tar file state.xml
13:32:27:WU01:FS01:0x21:Reading tar file system.xml
13:32:27:WU01:FS01:0x21:Digital signatures verified
13:32:27:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
13:32:27:WU01:FS01:0x21:Version 0.0.18
13:32:29:WU01:FS01:0x21:Completed 0 out of 10000000 steps (0%)
13:32:29:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
13:32:33:WU00:FS01:Upload 69.25%
13:32:35:WU00:FS01:Upload complete
13:32:36:WU00:FS01:Server responded WORK_ACK (400)
13:32:36:WU00:FS01:Final credit estimate, 82603.00 points
13:32:36:WU00:FS01:Cleaning up
13:33:42:WU01:FS01:0x21:Completed 100000 out of 10000000 steps (1%)
13:33:43:WU02:FS02:0x21:Completed 1380000 out of 1500000 steps (92%)
13:34:54:WU01:FS01:0x21:Completed 200000 out of 10000000 steps (2%)
13:35:12:WU02:FS02:0x21:Completed 1395000 out of 1500000 steps (93%)
13:35:36:WARNING:FS01:Size of positions 221 does not match topology 220
13:36:07:WU01:FS01:0x21:Completed 300000 out of 10000000 steps (3%)
13:36:41:WU02:FS02:0x21:Completed 1410000 out of 1500000 steps (94%)
13:37:20:WU01:FS01:0x21:Completed 400000 out of 10000000 steps (4%)
13:38:10:WU02:FS02:0x21:Completed 1425000 out of 1500000 steps (95%)
13:38:32:WU01:FS01:0x21:Completed 500000 out of 10000000 steps (5%)
13:38:37:WARNING:FS01:Size of positions 221 does not match topology 220
13:39:15:Removing old file 'configs/config-20180831-022417.xml'
13:39:15:Saving configuration to config.xml
13:39:15:<config>
13:39:15:  <!-- Network -->
13:39:15:  <proxy v=':8080'/>
13:39:15:
13:39:15:  <!-- Slot Control -->
13:39:15:  <power v='full'/>
13:39:15:
13:39:15:  <!-- User Information -->
13:39:15:  <passkey v='********************************'/>
13:39:15:
13:39:15:  <!-- Folding Slots -->
13:39:15:  <slot id='1' type='GPU'/>
13:39:15:  <slot id='2' type='GPU'/>
13:39:15:</config>
13:39:39:WU02:FS02:0x21:Completed 1440000 out of 1500000 steps (96%)
13:39:44:WU01:FS01:0x21:Completed 600000 out of 10000000 steps (6%)
13:39:52:Removing old file 'configs/config-20180831-162928.xml'
13:39:52:Saving configuration to config.xml
13:39:52:<config>
13:39:52:  <!-- Folding Core -->
13:39:52:  <checkpoint v='30'/>
13:39:52:
13:39:52:  <!-- Network -->
13:39:52:  <proxy v=':8080'/>
13:39:52:
13:39:52:  <!-- Slot Control -->
13:39:52:  <power v='full'/>
13:39:52:
13:39:52:  <!-- User Information -->
13:39:52:  <passkey v='********************************'/>
13:39:52:
13:39:52:  <!-- Folding Slots -->
13:39:52:  <slot id='1' type='GPU'/>
13:39:52:  <slot id='2' type='GPU'/>
13:39:52:</config>
13:40:16:Removing old file 'configs/config-20180831-163016.xml'
13:40:16:Saving configuration to config.xml
13:40:16:<config>
13:40:16:  <!-- Folding Core -->
13:40:16:  <checkpoint v='30'/>
13:40:16:
13:40:16:  <!-- Network -->
13:40:16:  <proxy v=':8080'/>
13:40:16:
13:40:16:  <!-- Slot Control -->
13:40:16:  <power v='full'/>
13:40:16:
13:40:16:  <!-- User Information -->
13:40:16:  <passkey v='********************************'/>
13:40:16:
13:40:16:  <!-- Folding Slots -->
13:40:16:  <slot id='1' type='GPU'/>
13:40:16:  <slot id='2' type='GPU'/>
13:40:16:</config>
13:40:23:Removing old file 'configs/config-20180907-051349.xml'
13:40:23:Saving configuration to config.xml
13:40:23:<config>
13:40:23:  <!-- Folding Core -->
13:40:23:  <checkpoint v='30'/>
13:40:23:
13:40:23:  <!-- Folding Slot Configuration -->
13:40:23:  <max-packet-size v='big'/>
13:40:23:
13:40:23:  <!-- Network -->
13:40:23:  <proxy v=':8080'/>
13:40:23:
13:40:23:  <!-- Slot Control -->
13:40:23:  <power v='full'/>
13:40:23:
13:40:23:  <!-- User Information -->
13:40:23:  <passkey v='********************************'/>
13:40:23:
13:40:23:  <!-- Folding Slots -->
13:40:23:  <slot id='1' type='GPU'/>
13:40:23:  <slot id='2' type='GPU'/>
13:40:23:</config>
13:40:57:WU01:FS01:0x21:Completed 700000 out of 10000000 steps (7%)
13:41:08:WU02:FS02:0x21:Completed 1455000 out of 1500000 steps (97%)
13:41:17:Removing old file 'configs/config-20180907-051418.xml'
13:41:17:Saving configuration to config.xml
13:41:17:<config>
13:41:17:  <!-- Folding Core -->
13:41:17:  <checkpoint v='30'/>
13:41:17:
13:41:17:  <!-- Folding Slot Configuration -->
13:41:17:  <max-packet-size v='big'/>
13:41:17:
13:41:17:  <!-- Network -->
13:41:17:  <proxy v=':8080'/>
13:41:17:
13:41:17:  <!-- Slot Control -->
13:41:17:  <power v='full'/>
13:41:17:
13:41:17:  <!-- User Information -->
13:41:17:  <passkey v='********************************'/>
13:41:17:
13:41:17:  <!-- Folding Slots -->
13:41:17:  <slot id='1' type='GPU'/>
13:41:17:  <slot id='2' type='GPU'/>
13:41:17:</config>
13:41:43:WARNING:FS01:Size of positions 221 does not match topology 220
13:42:15:WU01:FS01:0x21:Completed 800000 out of 10000000 steps (8%)
13:42:40:WU02:FS02:0x21:Completed 1470000 out of 1500000 steps (98%)
13:43:27:WU01:FS01:0x21:Completed 900000 out of 10000000 steps (9%)
13:44:10:WU02:FS02:0x21:Completed 1485000 out of 1500000 steps (99%)
13:44:10:WU00:FS02:Connecting to 65.254.110.245:8080
13:44:11:WU00:FS02:Assigned to work server 128.252.203.4
13:44:11:WU00:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GP102 [GeForce GTX 1080 Ti] 11380 from 128.252.203.4
13:44:11:WU00:FS02:Connecting to 128.252.203.4:8080
13:44:11:WU00:FS02:Downloading 71.91MiB
13:44:17:WU00:FS02:Download 6.61%
13:44:23:WU00:FS02:Download 14.25%
13:44:29:WU00:FS02:Download 21.82%
13:44:35:WU00:FS02:Download 29.47%
13:44:40:WU01:FS01:0x21:Completed 1000000 out of 10000000 steps (10%)
13:44:41:WU00:FS02:Download 37.11%
13:44:45:WARNING:FS01:Size of positions 221 does not match topology 220
13:44:47:WU00:FS02:Download 44.68%
13:44:53:WU00:FS02:Download 52.33%
13:44:59:WU00:FS02:Download 60.06%
13:45:05:WU00:FS02:Download 67.71%
13:45:11:WU00:FS02:Download 75.36%
13:45:17:WU00:FS02:Download 83.01%
13:45:23:WU00:FS02:Download 90.74%
13:45:29:WU00:FS02:Download 98.31%
13:45:30:WU00:FS02:Download complete
13:45:30:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13815 run:0 clone:206 gen:188 core:0x21 unit:0x000000c680fccb045b3f790bf599e676
13:45:40:WU02:FS02:0x21:Completed 1500000 out of 1500000 steps (100%)
13:45:44:WU02:FS02:0x21:Saving result file logfile_01.txt
13:45:44:WU02:FS02:0x21:Saving result file checkpointState.xml
13:45:45:WU02:FS02:0x21:Saving result file checkpt.crc
13:45:45:WU02:FS02:0x21:Saving result file log.txt
13:45:45:WU02:FS02:0x21:Saving result file positions.xtc
13:45:45:WU02:FS02:0x21:Folding@home Core Shutdown: FINISHED_UNIT
13:45:45:WU02:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:45:45:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:13815 run:0 clone:81 gen:250 core:0x21 unit:0x0000010080fccb045b33ea6b213d96d4
13:45:45:WU02:FS02:Uploading 41.53MiB to 128.252.203.4
13:45:45:WU02:FS02:Connecting to 128.252.203.4:8080
13:45:45:WU00:FS02:Starting
13:45:45:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Don\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 2720 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:45:45:WU00:FS02:Started FahCore on PID 10584
13:45:45:WU00:FS02:Core PID:12124
13:45:45:WU00:FS02:FahCore 0x21 started
13:45:46:WU00:FS02:0x21:*********************** Log Started 2018-09-22T13:45:45Z ***********************
13:45:46:WU00:FS02:0x21:Project: 13815 (Run 0, Clone 206, Gen 188)
13:45:46:WU00:FS02:0x21:Unit: 0x000000c680fccb045b3f790bf599e676
13:45:46:WU00:FS02:0x21:CPU: 0x00000000000000000000000000000000
13:45:46:WU00:FS02:0x21:Machine: 2
13:45:46:WU00:FS02:0x21:Reading tar file core.xml
13:45:46:WU00:FS02:0x21:Reading tar file integrator.xml
13:45:46:WU00:FS02:0x21:Reading tar file state.xml
13:45:46:WU00:FS02:0x21:Reading tar file system.xml
13:45:46:WU00:FS02:0x21:Digital signatures verified
13:45:46:WU00:FS02:0x21:Folding@home GPU Core21 Folding@home Core
13:45:46:WU00:FS02:0x21:Version 0.0.18
13:45:51:WU02:FS02:Upload 12.34%
13:45:54:WU01:FS01:0x21:Completed 1100000 out of 10000000 steps (11%)
13:45:57:WU02:FS02:Upload 26.64%
13:46:00:WU00:FS02:0x21:Completed 0 out of 1500000 steps (0%)
13:46:00:WU00:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
13:46:03:WU02:FS02:Upload 40.94%
13:46:09:WU02:FS02:Upload 51.62%
13:46:15:WU02:FS02:Upload 65.92%
13:46:21:WU02:FS02:Upload 77.36%
13:46:27:WU02:FS02:Upload 91.35%
13:46:31:WU02:FS02:Upload complete
13:46:31:WU02:FS02:Server responded WORK_ACK (400)
13:46:31:WU02:FS02:Final credit estimate, 136630.00 points
13:46:31:WU02:FS02:Cleaning up
13:47:07:WU01:FS01:0x21:Completed 1200000 out of 10000000 steps (12%)
13:47:46:WU00:FS02:0x21:Completed 15000 out of 1500000 steps (1%)
13:47:49:WARNING:FS01:Size of positions 221 does not match topology 220
13:48:21:WU01:FS01:0x21:Completed 1300000 out of 10000000 steps (13%)
13:49:15:WU00:FS02:0x21:Completed 30000 out of 1500000 steps (2%)
13:49:33:WU01:FS01:0x21:Completed 1400000 out of 10000000 steps (14%)
13:50:45:WU00:FS02:0x21:Completed 45000 out of 1500000 steps (3%)
13:50:46:WU01:FS01:0x21:Completed 1500000 out of 10000000 steps (15%)
13:50:52:WARNING:FS01:Size of positions 221 does not match topology 220
13:52:02:WU01:FS01:0x21:Completed 1600000 out of 10000000 steps (16%)
13:52:17:WU00:FS02:0x21:Completed 60000 out of 1500000 steps (4%)
13:53:16:WU01:FS01:0x21:Completed 1700000 out of 10000000 steps (17%)
13:53:49:WU00:FS02:0x21:Completed 75000 out of 1500000 steps (5%)
13:53:59:WARNING:FS01:Size of positions 221 does not match topology 220
13:54:31:WU01:FS01:0x21:Completed 1800000 out of 10000000 steps (18%)
13:55:21:WU00:FS02:0x21:Completed 90000 out of 1500000 steps (6%)
13:55:46:WU01:FS01:0x21:Completed 1900000 out of 10000000 steps (19%)
13:56:53:WU00:FS02:0x21:Completed 105000 out of 1500000 steps (7%)
13:57:00:WU01:FS01:0x21:Completed 2000000 out of 10000000 steps (20%)
13:57:05:WARNING:FS01:Size of positions 221 does not match topology 220
13:58:14:WU01:FS01:0x21:Completed 2100000 out of 10000000 steps (21%)
13:58:24:WU00:FS02:0x21:Completed 120000 out of 1500000 steps (8%)
13:59:29:WU01:FS01:0x21:Completed 2200000 out of 10000000 steps (22%)
13:59:55:WU00:FS02:0x21:Completed 135000 out of 1500000 steps (9%)
14:00:11:WARNING:FS01:Size of positions 221 does not match topology 220
14:00:44:WU01:FS01:0x21:Completed 2300000 out of 10000000 steps (23%)
14:01:27:WU00:FS02:0x21:Completed 150000 out of 1500000 steps (10%)
14:01:57:WU01:FS01:0x21:Completed 2400000 out of 10000000 steps (24%)
14:02:58:WU00:FS02:0x21:Completed 165000 out of 1500000 steps (11%)
14:03:11:WU01:FS01:0x21:Completed 2500000 out of 10000000 steps (25%)
14:03:17:WARNING:FS01:Size of positions 221 does not match topology 220
14:04:25:WU01:FS01:0x21:Completed 2600000 out of 10000000 steps (26%)
14:04:29:WU00:FS02:0x21:Completed 180000 out of 1500000 steps (12%)
14:05:40:WU01:FS01:0x21:Completed 2700000 out of 10000000 steps (27%)
14:06:01:WU00:FS02:0x21:Completed 195000 out of 1500000 steps (13%)
14:06:23:WARNING:FS01:Size of positions 221 does not match topology 220
14:06:57:WU01:FS01:0x21:Completed 2800000 out of 10000000 steps (28%)
14:07:33:WU00:FS02:0x21:Completed 210000 out of 1500000 steps (14%)
14:08:11:WU01:FS01:0x21:Completed 2900000 out of 10000000 steps (29%)
14:09:04:WU00:FS02:0x21:Completed 225000 out of 1500000 steps (15%)
14:09:26:WU01:FS01:0x21:Completed 3000000 out of 10000000 steps (30%)
14:09:31:WARNING:FS01:Size of positions 221 does not match topology 220
14:10:36:WU00:FS02:0x21:Completed 240000 out of 1500000 steps (16%)
14:10:40:WU01:FS01:0x21:Completed 3100000 out of 10000000 steps (31%)
14:11:54:WU01:FS01:0x21:Completed 3200000 out of 10000000 steps (32%)
14:12:12:WU00:FS02:0x21:Completed 255000 out of 1500000 steps (17%)
14:12:37:WARNING:FS01:Size of positions 221 does not match topology 220
14:13:09:WU01:FS01:0x21:Completed 3300000 out of 10000000 steps (33%)
14:13:44:WU00:FS02:0x21:Completed 270000 out of 1500000 steps (18%)
14:14:23:WU01:FS01:0x21:Completed 3400000 out of 10000000 steps (34%)
14:15:16:WU00:FS02:0x21:Completed 285000 out of 1500000 steps (19%)
14:15:37:WU01:FS01:0x21:Completed 3500000 out of 10000000 steps (35%)
14:15:42:WARNING:FS01:Size of positions 221 does not match topology 220
14:16:46:WU00:FS02:0x21:Completed 300000 out of 1500000 steps (20%)
14:16:50:WU01:FS01:0x21:Completed 3600000 out of 10000000 steps (36%)
14:18:04:WU01:FS01:0x21:Completed 3700000 out of 10000000 steps (37%)
14:18:17:WU00:FS02:0x21:Completed 315000 out of 1500000 steps (21%)
14:18:47:WARNING:FS01:Size of positions 221 does not match topology 220
14:19:19:WU01:FS01:0x21:Completed 3800000 out of 10000000 steps (38%)
14:19:49:WU00:FS02:0x21:Completed 330000 out of 1500000 steps (22%)
14:20:33:WU01:FS01:0x21:Completed 3900000 out of 10000000 steps (39%)
14:21:19:WU00:FS02:0x21:Completed 345000 out of 1500000 steps (23%)
14:21:47:WU01:FS01:0x21:Completed 4000000 out of 10000000 steps (40%)
14:21:52:WARNING:FS01:Size of positions 221 does not match topology 220
14:22:51:WU00:FS02:0x21:Completed 360000 out of 1500000 steps (24%)
14:23:02:WU01:FS01:0x21:Completed 4100000 out of 10000000 steps (41%)
14:24:16:WU01:FS01:0x21:Completed 4200000 out of 10000000 steps (42%)
14:24:22:WU00:FS02:0x21:Completed 375000 out of 1500000 steps (25%)
14:24:58:WARNING:FS01:Size of positions 221 does not match topology 220
14:25:30:WU01:FS01:0x21:Completed 4300000 out of 10000000 steps (43%)
14:25:53:WU00:FS02:0x21:Completed 390000 out of 1500000 steps (26%)
14:26:43:WU01:FS01:0x21:Completed 4400000 out of 10000000 steps (44%)
14:27:24:WU00:FS02:0x21:Completed 405000 out of 1500000 steps (27%)
14:27:56:WU01:FS01:0x21:Completed 4500000 out of 10000000 steps (45%)
14:28:02:WARNING:FS01:Size of positions 221 does not match topology 220
14:28:53:WU00:FS02:0x21:Completed 420000 out of 1500000 steps (28%)
14:29:10:WU01:FS01:0x21:Completed 4600000 out of 10000000 steps (46%)
14:30:23:WU01:FS01:0x21:Completed 4700000 out of 10000000 steps (47%)
14:30:23:WU00:FS02:0x21:Completed 435000 out of 1500000 steps (29%)
14:31:04:WARNING:FS01:Size of positions 221 does not match topology 220
14:31:36:WU01:FS01:0x21:Completed 4800000 out of 10000000 steps (48%)
14:31:53:WU00:FS02:0x21:Completed 450000 out of 1500000 steps (30%)
14:32:49:WU01:FS01:0x21:Completed 4900000 out of 10000000 steps (49%)
14:33:23:WU00:FS02:0x21:Completed 465000 out of 1500000 steps (31%)
14:34:02:WU01:FS01:0x21:Completed 5000000 out of 10000000 steps (50%)
14:34:07:WARNING:FS01:Size of positions 221 does not match topology 220
14:34:53:WU00:FS02:0x21:Completed 480000 out of 1500000 steps (32%)
14:35:15:WU01:FS01:0x21:Completed 5100000 out of 10000000 steps (51%)
14:36:23:WU00:FS02:0x21:Completed 495000 out of 1500000 steps (33%)
14:36:28:WU01:FS01:0x21:Completed 5200000 out of 10000000 steps (52%)
14:37:12:WARNING:FS01:Size of positions 221 does not match topology 220
14:37:44:WU01:FS01:0x21:Completed 5300000 out of 10000000 steps (53%)
14:38:00:WU00:FS02:0x21:Completed 510000 out of 1500000 steps (34%)
14:38:57:WU01:FS01:0x21:Completed 5400000 out of 10000000 steps (54%)
14:39:30:WU00:FS02:0x21:Completed 525000 out of 1500000 steps (35%)
14:40:10:WU01:FS01:0x21:Completed 5500000 out of 10000000 steps (55%)
14:40:15:WARNING:FS01:Size of positions 221 does not match topology 220
14:40:59:WU00:FS02:0x21:Completed 540000 out of 1500000 steps (36%)
14:41:24:WU01:FS01:0x21:Completed 5600000 out of 10000000 steps (56%)
14:42:29:WU00:FS02:0x21:Completed 555000 out of 1500000 steps (37%)
14:42:36:WU01:FS01:0x21:Completed 5700000 out of 10000000 steps (57%)
14:43:18:WARNING:FS01:Size of positions 221 does not match topology 220
14:43:50:WU01:FS01:0x21:Completed 5800000 out of 10000000 steps (58%)
14:43:59:WU00:FS02:0x21:Completed 570000 out of 1500000 steps (38%)
14:45:03:WU01:FS01:0x21:Completed 5900000 out of 10000000 steps (59%)
14:45:30:WU00:FS02:0x21:Completed 585000 out of 1500000 steps (39%)
14:46:17:WU01:FS01:0x21:Completed 6000000 out of 10000000 steps (60%)
14:46:22:WARNING:FS01:Size of positions 221 does not match topology 220
14:47:02:WU00:FS02:0x21:Completed 600000 out of 1500000 steps (40%)
14:47:33:WU01:FS01:0x21:Completed 6100000 out of 10000000 steps (61%)
14:48:38:WU00:FS02:0x21:Completed 615000 out of 1500000 steps (41%)
14:48:57:WU01:FS01:0x21:Completed 6200000 out of 10000000 steps (62%)
14:49:46:WARNING:FS01:Size of positions 221 does not match topology 220
14:50:17:WU00:FS02:0x21:Completed 630000 out of 1500000 steps (42%)
14:50:22:WU01:FS01:0x21:Completed 6300000 out of 10000000 steps (63%)
14:51:41:WU01:FS01:0x21:Completed 6400000 out of 10000000 steps (64%)
14:51:52:WU00:FS02:0x21:Completed 645000 out of 1500000 steps (43%)
14:53:03:WU01:FS01:0x21:Completed 6500000 out of 10000000 steps (65%)
14:53:09:WARNING:FS01:Size of positions 221 does not match topology 220
14:53:29:WU00:FS02:0x21:Completed 660000 out of 1500000 steps (44%)
14:54:21:WU01:FS01:0x21:Completed 6600000 out of 10000000 steps (66%)
14:55:02:WU00:FS02:0x21:Completed 675000 out of 1500000 steps (45%)
14:55:36:WU01:FS01:0x21:Completed 6700000 out of 10000000 steps (67%)
14:56:19:WARNING:FS01:Size of positions 221 does not match topology 220
14:56:34:WU00:FS02:0x21:Completed 690000 out of 1500000 steps (46%)
14:56:52:WU01:FS01:0x21:Completed 6800000 out of 10000000 steps (68%)
14:58:07:WU00:FS02:0x21:Completed 705000 out of 1500000 steps (47%)
14:58:08:WU01:FS01:0x21:Completed 6900000 out of 10000000 steps (69%)
14:59:24:WU01:FS01:0x21:Completed 7000000 out of 10000000 steps (70%)
14:59:29:WARNING:FS01:Size of positions 221 does not match topology 220
14:59:41:WU00:FS02:0x21:Completed 720000 out of 1500000 steps (48%)
15:00:40:WU01:FS01:0x21:Completed 7100000 out of 10000000 steps (71%)
15:01:14:WU00:FS02:0x21:Completed 735000 out of 1500000 steps (49%)
15:01:57:WU01:FS01:0x21:Completed 7200000 out of 10000000 steps (72%)
15:02:41:WARNING:FS01:Size of positions 221 does not match topology 220
15:02:48:WU00:FS02:0x21:Completed 750000 out of 1500000 steps (50%)
15:03:14:WU01:FS01:0x21:Completed 7300000 out of 10000000 steps (73%)
15:04:25:WU00:FS02:0x21:Completed 765000 out of 1500000 steps (51%)
15:04:29:WU01:FS01:0x21:Completed 7400000 out of 10000000 steps (74%)
15:05:44:WU01:FS01:0x21:Completed 7500000 out of 10000000 steps (75%)
15:05:49:WARNING:FS01:Size of positions 221 does not match topology 220
15:05:58:WU00:FS02:0x21:Completed 780000 out of 1500000 steps (52%)
15:06:59:WU01:FS01:0x21:Completed 7600000 out of 10000000 steps (76%)
15:07:31:WU00:FS02:0x21:Completed 795000 out of 1500000 steps (53%)
15:08:14:WU01:FS01:0x21:Completed 7700000 out of 10000000 steps (77%)
15:08:56:WARNING:FS01:Size of positions 221 does not match topology 220
15:09:03:WU00:FS02:0x21:Completed 810000 out of 1500000 steps (54%)
15:09:29:WU01:FS01:0x21:Completed 7800000 out of 10000000 steps (78%)
15:10:35:WU00:FS02:0x21:Completed 825000 out of 1500000 steps (55%)
15:10:43:WU01:FS01:0x21:Completed 7900000 out of 10000000 steps (79%)
15:11:56:WU01:FS01:0x21:Completed 8000000 out of 10000000 steps (80%)
15:12:01:WARNING:FS01:Size of positions 221 does not match topology 220
15:12:05:WU00:FS02:0x21:Completed 840000 out of 1500000 steps (56%)
15:13:09:WU01:FS01:0x21:Completed 8100000 out of 10000000 steps (81%)
15:13:35:WU00:FS02:0x21:Completed 855000 out of 1500000 steps (57%)
15:14:22:WU01:FS01:0x21:Completed 8200000 out of 10000000 steps (82%)
15:15:04:WARNING:FS01:Size of positions 221 does not match topology 220
15:15:05:WU00:FS02:0x21:Completed 870000 out of 1500000 steps (58%)
15:15:36:WU01:FS01:0x21:Completed 8300000 out of 10000000 steps (83%)
15:16:35:WU00:FS02:0x21:Completed 885000 out of 1500000 steps (59%)
15:16:49:WU01:FS01:0x21:Completed 8400000 out of 10000000 steps (84%)
15:18:01:WU01:FS01:0x21:Completed 8500000 out of 10000000 steps (85%)
15:18:05:WU00:FS02:0x21:Completed 900000 out of 1500000 steps (60%)
15:18:07:WARNING:FS01:Size of positions 221 does not match topology 220
15:19:14:WU01:FS01:0x21:Completed 8600000 out of 10000000 steps (86%)
15:19:35:WU00:FS02:0x21:Completed 915000 out of 1500000 steps (61%)
15:20:27:WU01:FS01:0x21:Completed 8700000 out of 10000000 steps (87%)
15:21:05:WU00:FS02:0x21:Completed 930000 out of 1500000 steps (62%)
15:21:09:WARNING:FS01:Size of positions 221 does not match topology 220
15:21:41:WU01:FS01:0x21:Completed 8800000 out of 10000000 steps (88%)
15:22:40:WU00:FS02:0x21:Completed 945000 out of 1500000 steps (63%)
15:23:00:WU01:FS01:0x21:Completed 8900000 out of 10000000 steps (89%)
15:24:11:WU00:FS02:0x21:Completed 960000 out of 1500000 steps (64%)
15:24:14:WU01:FS01:0x21:Completed 9000000 out of 10000000 steps (90%)
15:24:19:WARNING:FS01:Size of positions 221 does not match topology 220
15:25:28:WU01:FS01:0x21:Completed 9100000 out of 10000000 steps (91%)
15:25:42:WU00:FS02:0x21:Completed 975000 out of 1500000 steps (65%)
15:26:42:WU01:FS01:0x21:Completed 9200000 out of 10000000 steps (92%)
15:27:13:WU00:FS02:0x21:Completed 990000 out of 1500000 steps (66%)
15:27:25:WARNING:FS01:Size of positions 221 does not match topology 220
15:27:58:WU01:FS01:0x21:Completed 9300000 out of 10000000 steps (93%)
15:28:50:WU00:FS02:0x21:Completed 1005000 out of 1500000 steps (67%)
15:29:12:WU01:FS01:0x21:Completed 9400000 out of 10000000 steps (94%)
15:30:21:WU00:FS02:0x21:Completed 1020000 out of 1500000 steps (68%)
15:30:26:WU01:FS01:0x21:Completed 9500000 out of 10000000 steps (95%)
15:30:32:WARNING:FS01:Size of positions 221 does not match topology 220
15:31:40:WU01:FS01:0x21:Completed 9600000 out of 10000000 steps (96%)
15:31:51:WU00:FS02:0x21:Completed 1035000 out of 1500000 steps (69%)
15:32:53:WU01:FS01:0x21:Completed 9700000 out of 10000000 steps (97%)
15:33:21:WU00:FS02:0x21:Completed 1050000 out of 1500000 steps (70%)
15:33:34:WARNING:FS01:Size of positions 221 does not match topology 220
15:34:06:WU01:FS01:0x21:Completed 9800000 out of 10000000 steps (98%)
15:34:51:WU00:FS02:0x21:Completed 1065000 out of 1500000 steps (71%)
15:35:19:WU01:FS01:0x21:Completed 9900000 out of 10000000 steps (99%)
15:35:19:WU02:FS01:Connecting to 65.254.110.245:8080
15:35:19:WU02:FS01:Assigned to work server 128.252.203.4
15:35:20:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 128.252.203.4
15:35:20:WU02:FS01:Connecting to 128.252.203.4:8080
15:35:20:WU02:FS01:Downloading 71.90MiB
15:35:26:WU02:FS01:Download 6.61%
15:35:32:WU02:FS01:Download 14.08%
15:35:38:WU02:FS01:Download 21.56%
15:35:44:WU02:FS01:Download 29.03%
15:35:50:WU02:FS01:Download 36.51%
15:35:56:WU02:FS01:Download 43.98%
15:36:02:WU02:FS01:Download 51.37%
15:36:08:WU02:FS01:Download 58.67%
15:36:14:WU02:FS01:Download 66.24%
15:36:20:WU02:FS01:Download 73.45%
15:36:24:WU00:FS02:0x21:Completed 1080000 out of 1500000 steps (72%)
15:36:26:WU02:FS01:Download 80.40%
15:36:32:WU02:FS01:Download 87.36%
15:36:37:WU01:FS01:0x21:Completed 10000000 out of 10000000 steps (100%)
15:36:37:WU01:FS01:0x21:Saving result file logfile_01.txt
15:36:37:WU01:FS01:0x21:Saving result file checkpointState.xml
15:36:37:WU01:FS01:0x21:Saving result file checkpt.crc
15:36:37:WU01:FS01:0x21:Saving result file log.txt
15:36:37:WU01:FS01:0x21:Saving result file positions.xtc
15:36:37:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
15:36:37:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:36:37:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11715 run:2 clone:138 gen:80 core:0x21 unit:0x0000005d8ca304e75b29c35786174c51
15:36:37:WU01:FS01:Uploading 4.71MiB to 140.163.4.231
15:36:37:WU01:FS01:Connecting to 140.163.4.231:8080
15:36:38:WU02:FS01:Download 94.31%
15:36:42:WU02:FS01:Download complete
15:36:43:WU01:FS01:Upload 63.75%
15:36:43:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13815 run:0 clone:231 gen:106 core:0x21 unit:0x0000007180fccb045b3f790b0be83ece
15:36:43:WU02:FS01:Starting
15:36:43:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Don\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 2720 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
15:36:43:WU02:FS01:Started FahCore on PID 5644
15:36:43:WU02:FS01:Core PID:3800
15:36:43:WU02:FS01:FahCore 0x21 started
15:36:43:WU02:FS01:0x21:*********************** Log Started 2018-09-22T15:36:43Z ***********************
15:36:43:WU02:FS01:0x21:Project: 13815 (Run 0, Clone 231, Gen 106)
15:36:43:WU02:FS01:0x21:Unit: 0x0000007180fccb045b3f790b0be83ece
15:36:43:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
15:36:43:WU02:FS01:0x21:Machine: 1
15:36:43:WU02:FS01:0x21:Reading tar file core.xml
15:36:43:WU02:FS01:0x21:Reading tar file integrator.xml
15:36:43:WU02:FS01:0x21:Reading tar file state.xml
15:36:43:WU02:FS01:0x21:Reading tar file system.xml
15:36:43:WU02:FS01:0x21:Digital signatures verified
15:36:43:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
15:36:43:WU02:FS01:0x21:Version 0.0.18
15:36:45:WU01:FS01:Upload complete
15:36:45:WU01:FS01:Server responded WORK_ACK (400)
15:36:45:WU01:FS01:Final credit estimate, 91576.00 points
15:36:45:WU01:FS01:Cleaning up
15:36:58:WU02:FS01:0x21:Completed 0 out of 1500000 steps (0%)
15:36:58:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:37:55:WU00:FS02:0x21:Completed 1095000 out of 1500000 steps (73%)
15:38:40:WU02:FS01:0x21:Completed 15000 out of 1500000 steps (1%)
15:39:25:WU00:FS02:0x21:Completed 1110000 out of 1500000 steps (74%)
15:40:12:WU02:FS01:0x21:Completed 30000 out of 1500000 steps (2%)
15:40:56:WU00:FS02:0x21:Completed 1125000 out of 1500000 steps (75%)
15:41:43:WU02:FS01:0x21:Completed 45000 out of 1500000 steps (3%)
15:42:27:WU00:FS02:0x21:Completed 1140000 out of 1500000 steps (76%)
15:43:13:WU02:FS01:0x21:Completed 60000 out of 1500000 steps (4%)
15:43:57:WU00:FS02:0x21:Completed 1155000 out of 1500000 steps (77%)
15:44:43:WU02:FS01:0x21:Completed 75000 out of 1500000 steps (5%)
15:45:27:WU00:FS02:0x21:Completed 1170000 out of 1500000 steps (78%)
15:46:13:WU02:FS01:0x21:Completed 90000 out of 1500000 steps (6%)
15:46:57:WU00:FS02:0x21:Completed 1185000 out of 1500000 steps (79%)
15:47:44:WU02:FS01:0x21:Completed 105000 out of 1500000 steps (7%)
15:48:27:WU00:FS02:0x21:Completed 1200000 out of 1500000 steps (80%)
15:49:14:WU02:FS01:0x21:Completed 120000 out of 1500000 steps (8%)
15:49:56:WU00:FS02:0x21:Completed 1215000 out of 1500000 steps (81%)
15:50:44:WU02:FS01:0x21:Completed 135000 out of 1500000 steps (9%)
15:51:26:WU00:FS02:0x21:Completed 1230000 out of 1500000 steps (82%)
15:52:15:WU02:FS01:0x21:Completed 150000 out of 1500000 steps (10%)
15:52:56:WU00:FS02:0x21:Completed 1245000 out of 1500000 steps (83%)
15:53:45:WU02:FS01:0x21:Completed 165000 out of 1500000 steps (11%)
15:54:30:WU00:FS02:0x21:Completed 1260000 out of 1500000 steps (84%)
15:55:15:WU02:FS01:0x21:Completed 180000 out of 1500000 steps (12%)
15:56:01:WU00:FS02:0x21:Completed 1275000 out of 1500000 steps (85%)
15:56:46:WU02:FS01:0x21:Completed 195000 out of 1500000 steps (13%)
15:57:31:WU00:FS02:0x21:Completed 1290000 out of 1500000 steps (86%)
15:58:16:WU02:FS01:0x21:Completed 210000 out of 1500000 steps (14%)
15:59:00:WU00:FS02:0x21:Completed 1305000 out of 1500000 steps (87%)
15:59:46:WU02:FS01:0x21:Completed 225000 out of 1500000 steps (15%)
16:00:30:WU00:FS02:0x21:Completed 1320000 out of 1500000 steps (88%)
16:01:16:WU02:FS01:0x21:Completed 240000 out of 1500000 steps (16%)
16:02:00:WU00:FS02:0x21:Completed 1335000 out of 1500000 steps (89%)
16:02:51:WU02:FS01:0x21:Completed 255000 out of 1500000 steps (17%)
16:03:30:WU00:FS02:0x21:Completed 1350000 out of 1500000 steps (90%)
16:04:21:WU02:FS01:0x21:Completed 270000 out of 1500000 steps (18%)
16:05:00:WU00:FS02:0x21:Completed 1365000 out of 1500000 steps (91%)
16:05:51:WU02:FS01:0x21:Completed 285000 out of 1500000 steps (19%)
16:06:30:WU00:FS02:0x21:Completed 1380000 out of 1500000 steps (92%)
16:07:22:WU02:FS01:0x21:Completed 300000 out of 1500000 steps (20%)
16:08:00:WU00:FS02:0x21:Completed 1395000 out of 1500000 steps (93%)
16:08:52:WU02:FS01:0x21:Completed 315000 out of 1500000 steps (21%)
16:09:30:WU00:FS02:0x21:Completed 1410000 out of 1500000 steps (94%)
16:10:22:WU02:FS01:0x21:Completed 330000 out of 1500000 steps (22%)
16:11:00:WU00:FS02:0x21:Completed 1425000 out of 1500000 steps (95%)
16:11:52:WU02:FS01:0x21:Completed 345000 out of 1500000 steps (23%)
16:12:30:WU00:FS02:0x21:Completed 1440000 out of 1500000 steps (96%)
16:13:23:WU02:FS01:0x21:Completed 360000 out of 1500000 steps (24%)
16:14:00:WU00:FS02:0x21:Completed 1455000 out of 1500000 steps (97%)
16:14:53:WU02:FS01:0x21:Completed 375000 out of 1500000 steps (25%)
16:15:30:WU00:FS02:0x21:Completed 1470000 out of 1500000 steps (98%)
16:16:23:WU02:FS01:0x21:Completed 390000 out of 1500000 steps (26%)
16:17:01:WU00:FS02:0x21:Completed 1485000 out of 1500000 steps (99%)
16:17:01:WU01:FS02:Connecting to 65.254.110.245:8080
16:17:02:WU01:FS02:Assigned to work server 140.163.4.231
16:17:02:WU01:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.231
16:17:02:WU01:FS02:Connecting to 140.163.4.231:8080
16:17:02:WU01:FS02:Downloading 25.28MiB
16:17:08:WU01:FS02:Download 22.25%
16:17:14:WU01:FS02:Download 48.22%
16:17:20:WU01:FS02:Download 77.39%
16:17:24:WU01:FS02:Download complete
16:17:24:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11718 run:0 clone:919 gen:50 core:0x21 unit:0x000000428ca304e75b846ae67faecbf2
16:17:54:WU02:FS01:0x21:Completed 405000 out of 1500000 steps (27%)
16:18:31:WU00:FS02:0x21:Completed 1500000 out of 1500000 steps (100%)
16:18:35:WU00:FS02:0x21:Saving result file logfile_01.txt
16:18:35:WU00:FS02:0x21:Saving result file checkpointState.xml
16:18:36:WU00:FS02:0x21:Saving result file checkpt.crc
16:18:36:WU00:FS02:0x21:Saving result file log.txt
16:18:36:WU00:FS02:0x21:Saving result file positions.xtc
16:18:36:WU00:FS02:0x21:Folding@home Core Shutdown: FINISHED_UNIT
16:18:36:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:18:36:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:13815 run:0 clone:206 gen:188 core:0x21 unit:0x000000c680fccb045b3f790bf599e676
16:18:36:WU00:FS02:Uploading 41.57MiB to 128.252.203.4
16:18:36:WU00:FS02:Connecting to 128.252.203.4:8080
16:18:36:WU01:FS02:Starting
16:18:36:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Don\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 2720 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:18:36:WU01:FS02:Started FahCore on PID 4840
16:18:36:WU01:FS02:Core PID:10644
16:18:36:WU01:FS02:FahCore 0x21 started
16:18:37:WU01:FS02:0x21:*********************** Log Started 2018-09-22T16:18:36Z ***********************
16:18:37:WU01:FS02:0x21:Project: 11718 (Run 0, Clone 919, Gen 50)
16:18:37:WU01:FS02:0x21:Unit: 0x000000428ca304e75b846ae67faecbf2
16:18:37:WU01:FS02:0x21:CPU: 0x00000000000000000000000000000000
16:18:37:WU01:FS02:0x21:Machine: 2
16:18:37:WU01:FS02:0x21:Reading tar file core.xml
16:18:37:WU01:FS02:0x21:Reading tar file integrator.xml
16:18:37:WU01:FS02:0x21:Reading tar file state.xml
16:18:37:WU01:FS02:0x21:Reading tar file system.xml
16:18:37:WU01:FS02:0x21:Digital signatures verified
16:18:37:WU01:FS02:0x21:Folding@home GPU Core21 Folding@home Core
16:18:37:WU01:FS02:0x21:Version 0.0.18
16:18:42:WU01:FS02:0x21:Completed 0 out of 5000000 steps (0%)
16:18:42:WU01:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:18:42:WU00:FS02:Upload 11.88%
16:18:48:WU00:FS02:Upload 24.96%
16:18:54:WU00:FS02:Upload 38.19%
16:19:00:WU00:FS02:Upload 51.27%
16:19:06:WU00:FS02:Upload 64.50%
16:19:12:WU00:FS02:Upload 77.73%
16:19:18:WU00:FS02:Upload 90.96%
16:19:22:WU00:FS02:Upload complete
16:19:22:WU00:FS02:Server responded WORK_ACK (400)
16:19:22:WU00:FS02:Final credit estimate, 146508.00 points
16:19:22:WU00:FS02:Cleaning up
16:19:24:WU02:FS01:0x21:Completed 420000 out of 1500000 steps (28%)
16:20:06:WU01:FS02:0x21:Completed 50000 out of 5000000 steps (1%)
16:20:54:WU02:FS01:0x21:Completed 435000 out of 1500000 steps (29%)
16:21:31:WU01:FS02:0x21:Completed 100000 out of 5000000 steps (2%)
16:22:24:WU02:FS01:0x21:Completed 450000 out of 1500000 steps (30%)
16:22:56:WU01:FS02:0x21:Completed 150000 out of 5000000 steps (3%)
16:23:55:WU02:FS01:0x21:Completed 465000 out of 1500000 steps (31%)
16:24:21:WU01:FS02:0x21:Completed 200000 out of 5000000 steps (4%)
16:25:25:WU02:FS01:0x21:Completed 480000 out of 1500000 steps (32%)
16:25:45:WU01:FS02:0x21:Completed 250000 out of 5000000 steps (5%)
16:25:52:WARNING:FS02:Size of positions 5845 does not match topology 5844
16:26:55:WU02:FS01:0x21:Completed 495000 out of 1500000 steps (33%)
16:27:11:WU01:FS02:0x21:Completed 300000 out of 5000000 steps (6%)
16:28:30:WU02:FS01:0x21:Completed 510000 out of 1500000 steps (34%)
16:28:36:WU01:FS02:0x21:Completed 350000 out of 5000000 steps (7%)
16:30:00:WU02:FS01:0x21:Completed 525000 out of 1500000 steps (35%)
16:30:01:WU01:FS02:0x21:Completed 400000 out of 5000000 steps (8%)
16:31:26:WU01:FS02:0x21:Completed 450000 out of 5000000 steps (9%)
16:31:30:WU02:FS01:0x21:Completed 540000 out of 1500000 steps (36%)
16:32:51:WU01:FS02:0x21:Completed 500000 out of 5000000 steps (10%)
16:32:57:WARNING:FS02:Size of positions 5845 does not match topology 5844
16:33:01:WU02:FS01:0x21:Completed 555000 out of 1500000 steps (37%)
16:34:21:WU01:FS02:0x21:Completed 550000 out of 5000000 steps (11%)
16:34:36:WU02:FS01:0x21:Completed 570000 out of 1500000 steps (38%)
16:35:48:WU01:FS02:0x21:Completed 600000 out of 5000000 steps (12%)
16:36:09:WU02:FS01:0x21:Completed 585000 out of 1500000 steps (39%)
16:37:14:WU01:FS02:0x21:Completed 650000 out of 5000000 steps (13%)
16:37:41:WU02:FS01:0x21:Completed 600000 out of 1500000 steps (40%)
16:38:39:WU01:FS02:0x21:Completed 700000 out of 5000000 steps (14%)
16:39:13:WU02:FS01:0x21:Completed 615000 out of 1500000 steps (41%)
16:40:05:WU01:FS02:0x21:Completed 750000 out of 5000000 steps (15%)
16:40:11:WARNING:FS02:Size of positions 5845 does not match topology 5844
16:40:45:WU02:FS01:0x21:Completed 630000 out of 1500000 steps (42%)
16:41:32:WU01:FS02:0x21:Completed 800000 out of 5000000 steps (16%)
16:42:17:WU02:FS01:0x21:Completed 645000 out of 1500000 steps (43%)
16:42:59:WU01:FS02:0x21:Completed 850000 out of 5000000 steps (17%)
16:43:49:WU02:FS01:0x21:Completed 660000 out of 1500000 steps (44%)
16:44:25:WU01:FS02:0x21:Completed 900000 out of 5000000 steps (18%)
16:45:21:WU02:FS01:0x21:Completed 675000 out of 1500000 steps (45%)
16:45:51:WU01:FS02:0x21:Completed 950000 out of 5000000 steps (19%)
16:46:52:WU02:FS01:0x21:Completed 690000 out of 1500000 steps (46%)
16:47:16:WU01:FS02:0x21:Completed 1000000 out of 5000000 steps (20%)
16:47:23:WARNING:FS02:Size of positions 5845 does not match topology 5844
16:48:23:WU02:FS01:0x21:Completed 705000 out of 1500000 steps (47%)
16:48:43:WU01:FS02:0x21:Completed 1050000 out of 5000000 steps (21%)
16:49:55:WU02:FS01:0x21:Completed 720000 out of 1500000 steps (48%)
16:50:09:WU01:FS02:0x21:Completed 1100000 out of 5000000 steps (22%)
16:51:26:WU02:FS01:0x21:Completed 735000 out of 1500000 steps (49%)
16:51:35:WU01:FS02:0x21:Completed 1150000 out of 5000000 steps (23%)
16:52:58:WU02:FS01:0x21:Completed 750000 out of 1500000 steps (50%)
16:53:01:WU01:FS02:0x21:Completed 1200000 out of 5000000 steps (24%)
16:54:27:WU01:FS02:0x21:Completed 1250000 out of 5000000 steps (25%)
16:54:33:WARNING:FS02:Size of positions 5845 does not match topology 5844
16:54:35:WU02:FS01:0x21:Completed 765000 out of 1500000 steps (51%)
16:55:57:WU01:FS02:0x21:Completed 1300000 out of 5000000 steps (26%)
16:56:09:WU02:FS01:0x21:Completed 780000 out of 1500000 steps (52%)
16:57:23:WU01:FS02:0x21:Completed 1350000 out of 5000000 steps (27%)
16:57:41:WU02:FS01:0x21:Completed 795000 out of 1500000 steps (53%)
16:58:49:WU01:FS02:0x21:Completed 1400000 out of 5000000 steps (28%)
16:59:12:WU02:FS01:0x21:Completed 810000 out of 1500000 steps (54%)
17:00:13:WU01:FS02:0x21:Completed 1450000 out of 5000000 steps (29%)
17:00:42:WU02:FS01:0x21:Completed 825000 out of 1500000 steps (55%)
17:01:38:WU01:FS02:0x21:Completed 1500000 out of 5000000 steps (30%)
17:01:44:WARNING:FS02:Size of positions 5845 does not match topology 5844
17:02:12:WU02:FS01:0x21:Completed 840000 out of 1500000 steps (56%)
17:03:04:WU01:FS02:0x21:Completed 1550000 out of 5000000 steps (31%)
17:03:42:WU02:FS01:0x21:Completed 855000 out of 1500000 steps (57%)
17:04:28:WU01:FS02:0x21:Completed 1600000 out of 5000000 steps (32%)
17:05:13:WU02:FS01:0x21:Completed 870000 out of 1500000 steps (58%)
17:05:53:WU01:FS02:0x21:Completed 1650000 out of 5000000 steps (33%)
17:06:43:WU02:FS01:0x21:Completed 885000 out of 1500000 steps (59%)
17:07:18:WU01:FS02:0x21:Completed 1700000 out of 5000000 steps (34%)
17:08:13:WU02:FS01:0x21:Completed 900000 out of 1500000 steps (60%)
17:08:42:WU01:FS02:0x21:Completed 1750000 out of 5000000 steps (35%)
17:08:48:WARNING:FS02:Size of positions 5845 does not match topology 5844
17:09:43:WU02:FS01:0x21:Completed 915000 out of 1500000 steps (61%)
17:10:08:WU01:FS02:0x21:Completed 1800000 out of 5000000 steps (36%)
17:11:13:WU02:FS01:0x21:Completed 930000 out of 1500000 steps (62%)
17:11:32:WU01:FS02:0x21:Completed 1850000 out of 5000000 steps (37%)
17:12:43:WU02:FS01:0x21:Completed 945000 out of 1500000 steps (63%)
17:12:57:WU01:FS02:0x21:Completed 1900000 out of 5000000 steps (38%)
17:14:13:WU02:FS01:0x21:Completed 960000 out of 1500000 steps (64%)
17:14:22:WU01:FS02:0x21:Completed 1950000 out of 5000000 steps (39%)
17:15:43:WU02:FS01:0x21:Completed 975000 out of 1500000 steps (65%)
17:15:46:WU01:FS02:0x21:Completed 2000000 out of 5000000 steps (40%)
17:15:52:WARNING:FS02:Size of positions 5845 does not match topology 5844
******************************* Date: 2018-09-22 *******************************
17:17:12:WU01:FS02:0x21:Completed 2050000 out of 5000000 steps (41%)
17:17:13:WU02:FS01:0x21:Completed 990000 out of 1500000 steps (66%)
17:18:37:WU01:FS02:0x21:Completed 2100000 out of 5000000 steps (42%)
17:18:47:WU02:FS01:0x21:Completed 1005000 out of 1500000 steps (67%)
17:20:01:WU01:FS02:0x21:Completed 2150000 out of 5000000 steps (43%)
17:20:17:WU02:FS01:0x21:Completed 1020000 out of 1500000 steps (68%)
17:21:26:WU01:FS02:0x21:Completed 2200000 out of 5000000 steps (44%)
17:21:47:WU02:FS01:0x21:Completed 1035000 out of 1500000 steps (69%)
17:22:50:WU01:FS02:0x21:Completed 2250000 out of 5000000 steps (45%)
17:22:56:WARNING:FS02:Size of positions 5845 does not match topology 5844
17:23:17:WU02:FS01:0x21:Completed 1050000 out of 1500000 steps (70%)
17:24:16:WU01:FS02:0x21:Completed 2300000 out of 5000000 steps (46%)
17:24:47:WU02:FS01:0x21:Completed 1065000 out of 1500000 steps (71%)
17:25:40:WU01:FS02:0x21:Completed 2350000 out of 5000000 steps (47%)
17:26:17:WU02:FS01:0x21:Completed 1080000 out of 1500000 steps (72%)
17:27:05:WU01:FS02:0x21:Completed 2400000 out of 5000000 steps (48%)
17:27:47:WU02:FS01:0x21:Completed 1095000 out of 1500000 steps (73%)
17:28:30:WU01:FS02:0x21:Completed 2450000 out of 5000000 steps (49%)
17:29:17:WU02:FS01:0x21:Completed 1110000 out of 1500000 steps (74%)
17:29:54:WU01:FS02:0x21:Completed 2500000 out of 5000000 steps (50%)
17:30:00:WARNING:FS02:Size of positions 5845 does not match topology 5844
17:30:47:WU02:FS01:0x21:Completed 1125000 out of 1500000 steps (75%)
17:31:20:WU01:FS02:0x21:Completed 2550000 out of 5000000 steps (51%)
17:32:16:WU02:FS01:0x21:Completed 1140000 out of 1500000 steps (76%)
17:32:45:WU01:FS02:0x21:Completed 2600000 out of 5000000 steps (52%)
17:33:46:WU02:FS01:0x21:Completed 1155000 out of 1500000 steps (77%)
17:34:09:WU01:FS02:0x21:Completed 2650000 out of 5000000 steps (53%)
17:35:16:WU02:FS01:0x21:Completed 1170000 out of 1500000 steps (78%)
17:35:33:WU01:FS02:0x21:Completed 2700000 out of 5000000 steps (54%)
17:36:46:WU02:FS01:0x21:Completed 1185000 out of 1500000 steps (79%)
17:36:58:WU01:FS02:0x21:Completed 2750000 out of 5000000 steps (55%)
17:37:04:WARNING:FS02:Size of positions 5845 does not match topology 5844
17:38:16:WU02:FS01:0x21:Completed 1200000 out of 1500000 steps (80%)
17:38:24:WU01:FS02:0x21:Completed 2800000 out of 5000000 steps (56%)
17:39:46:WU02:FS01:0x21:Completed 1215000 out of 1500000 steps (81%)
17:39:48:WU01:FS02:0x21:Completed 2850000 out of 5000000 steps (57%)
17:41:13:WU01:FS02:0x21:Completed 2900000 out of 5000000 steps (58%)
17:41:16:WU02:FS01:0x21:Completed 1230000 out of 1500000 steps (82%)
17:42:37:WU01:FS02:0x21:Completed 2950000 out of 5000000 steps (59%)
17:42:46:WU02:FS01:0x21:Completed 1245000 out of 1500000 steps (83%)
17:44:02:WU01:FS02:0x21:Completed 3000000 out of 5000000 steps (60%)
17:44:08:WARNING:FS02:Size of positions 5845 does not match topology 5844
17:44:21:WU02:FS01:0x21:Completed 1260000 out of 1500000 steps (84%)
17:45:28:WU01:FS02:0x21:Completed 3050000 out of 5000000 steps (61%)
17:45:51:WU02:FS01:0x21:Completed 1275000 out of 1500000 steps (85%)
17:46:52:WU01:FS02:0x21:Completed 3100000 out of 5000000 steps (62%)
17:47:21:WU02:FS01:0x21:Completed 1290000 out of 1500000 steps (86%)
17:48:17:WU01:FS02:0x21:Completed 3150000 out of 5000000 steps (63%)
17:48:51:WU02:FS01:0x21:Completed 1305000 out of 1500000 steps (87%)
17:49:41:WU01:FS02:0x21:Completed 3200000 out of 5000000 steps (64%)
17:50:20:WU02:FS01:0x21:Completed 1320000 out of 1500000 steps (88%)
17:51:06:WU01:FS02:0x21:Completed 3250000 out of 5000000 steps (65%)
17:51:12:WARNING:FS02:Size of positions 5845 does not match topology 5844
17:51:50:WU02:FS01:0x21:Completed 1335000 out of 1500000 steps (89%)
17:52:32:WU01:FS02:0x21:Completed 3300000 out of 5000000 steps (66%)
17:53:20:WU02:FS01:0x21:Completed 1350000 out of 1500000 steps (90%)
17:53:56:WU01:FS02:0x21:Completed 3350000 out of 5000000 steps (67%)
17:54:50:WU02:FS01:0x21:Completed 1365000 out of 1500000 steps (91%)
17:55:21:WU01:FS02:0x21:Completed 3400000 out of 5000000 steps (68%)
17:56:20:WU02:FS01:0x21:Completed 1380000 out of 1500000 steps (92%)
17:56:45:WU01:FS02:0x21:Completed 3450000 out of 5000000 steps (69%)
17:57:50:WU02:FS01:0x21:Completed 1395000 out of 1500000 steps (93%)
17:58:10:WU01:FS02:0x21:Completed 3500000 out of 5000000 steps (70%)
17:58:16:WARNING:FS02:Size of positions 5845 does not match topology 5844
17:59:20:WU02:FS01:0x21:Completed 1410000 out of 1500000 steps (94%)
17:59:36:WU01:FS02:0x21:Completed 3550000 out of 5000000 steps (71%)
18:00:50:WU02:FS01:0x21:Completed 1425000 out of 1500000 steps (95%)
18:01:00:WU01:FS02:0x21:Completed 3600000 out of 5000000 steps (72%)
18:02:20:WU02:FS01:0x21:Completed 1440000 out of 1500000 steps (96%)
18:02:25:WU01:FS02:0x21:Completed 3650000 out of 5000000 steps (73%)
18:03:49:WU01:FS02:0x21:Completed 3700000 out of 5000000 steps (74%)
18:03:50:WU02:FS01:0x21:Completed 1455000 out of 1500000 steps (97%)
18:05:14:WU01:FS02:0x21:Completed 3750000 out of 5000000 steps (75%)
18:05:20:WU02:FS01:0x21:Completed 1470000 out of 1500000 steps (98%)
18:05:20:WARNING:FS02:Size of positions 5845 does not match topology 5844
18:06:40:WU01:FS02:0x21:Completed 3800000 out of 5000000 steps (76%)
18:06:49:WU02:FS01:0x21:Completed 1485000 out of 1500000 steps (99%)
18:06:50:WU00:FS01:Connecting to 65.254.110.245:8080
18:06:51:WU00:FS01:Assigned to work server 128.252.203.4
18:06:51:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 128.252.203.4
18:06:51:WU00:FS01:Connecting to 128.252.203.4:8080
18:06:52:WU00:FS01:Downloading 71.90MiB
18:06:58:WU00:FS01:Download 8.08%
18:07:04:WU00:FS01:Download 16.26%
18:07:10:WU00:FS01:Download 23.64%
18:07:16:WU00:FS01:Download 32.08%
18:07:22:WU00:FS01:Download 40.42%
18:07:28:WU00:FS01:Download 48.85%
18:07:34:WU00:FS01:Download 57.11%
18:07:40:WU00:FS01:Download 65.54%
18:07:46:WU00:FS01:Download 73.89%
18:07:52:WU00:FS01:Download 82.32%
18:07:58:WU00:FS01:Download 90.75%
18:08:04:WU00:FS01:Download 98.84%
18:08:04:WU01:FS02:0x21:Completed 3850000 out of 5000000 steps (77%)
18:08:04:WU00:FS01:Download complete
18:08:04:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13815 run:0 clone:17 gen:433 core:0x21 unit:0x000001b680fccb045b33ea6a0c260833
18:08:19:WU02:FS01:0x21:Completed 1500000 out of 1500000 steps (100%)
18:08:24:WU02:FS01:0x21:Saving result file logfile_01.txt
18:08:24:WU02:FS01:0x21:Saving result file checkpointState.xml
18:08:24:WU02:FS01:0x21:Saving result file checkpt.crc
18:08:24:WU02:FS01:0x21:Saving result file log.txt
18:08:24:WU02:FS01:0x21:Saving result file positions.xtc
18:08:24:WU02:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
18:08:25:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:08:25:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:13815 run:0 clone:231 gen:106 core:0x21 unit:0x0000007180fccb045b3f790b0be83ece
18:08:25:WU02:FS01:Uploading 41.53MiB to 128.252.203.4
18:08:25:WU00:FS01:Starting
18:08:25:WU02:FS01:Connecting to 128.252.203.4:8080
18:08:25:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Don\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 2720 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
18:08:25:WU00:FS01:Started FahCore on PID 11564
18:08:25:WU00:FS01:Core PID:13856
18:08:25:WU00:FS01:FahCore 0x21 started
18:08:26:WU00:FS01:0x21:*********************** Log Started 2018-09-22T18:08:25Z ***********************
18:08:26:WU00:FS01:0x21:Project: 13815 (Run 0, Clone 17, Gen 433)
18:08:26:WU00:FS01:0x21:Unit: 0x000001b680fccb045b33ea6a0c260833
18:08:26:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
18:08:26:WU00:FS01:0x21:Machine: 1
18:08:26:WU00:FS01:0x21:Reading tar file core.xml
18:08:26:WU00:FS01:0x21:Reading tar file integrator.xml
18:08:26:WU00:FS01:0x21:Reading tar file state.xml
18:08:26:WU00:FS01:0x21:Reading tar file system.xml
18:08:26:WU00:FS01:0x21:Digital signatures verified
18:08:26:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
18:08:26:WU00:FS01:0x21:Version 0.0.18
18:08:31:WU02:FS01:Upload 12.79%
18:08:37:WU02:FS01:Upload 26.94%
18:08:40:WU00:FS01:0x21:Completed 0 out of 1500000 steps (0%)
18:08:40:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:08:43:WU02:FS01:Upload 41.39%
18:08:49:WU02:FS01:Upload 55.69%
18:08:55:WU02:FS01:Upload 70.14%
18:09:01:WU02:FS01:Upload 83.98%
18:09:07:WU02:FS01:Upload 98.28%
18:09:08:WU02:FS01:Upload complete
18:09:08:WU02:FS01:Server responded WORK_ACK (400)
18:09:08:WU02:FS01:Final credit estimate, 147166.00 points
18:09:08:WU02:FS01:Cleaning up
18:09:29:WU01:FS02:0x21:Completed 3900000 out of 5000000 steps (78%)
18:10:26:WU00:FS01:0x21:Completed 15000 out of 1500000 steps (1%)
18:10:54:WU01:FS02:0x21:Completed 3950000 out of 5000000 steps (79%)
18:11:56:WU00:FS01:0x21:Completed 30000 out of 1500000 steps (2%)
18:12:18:WU01:FS02:0x21:Completed 4000000 out of 5000000 steps (80%)
18:12:24:WARNING:FS02:Size of positions 5845 does not match topology 5844
18:13:27:WU00:FS01:0x21:Completed 45000 out of 1500000 steps (3%)
18:13:44:WU01:FS02:0x21:Completed 4050000 out of 5000000 steps (81%)
18:14:58:WU00:FS01:0x21:Completed 60000 out of 1500000 steps (4%)
18:15:09:WU01:FS02:0x21:Completed 4100000 out of 5000000 steps (82%)
18:16:28:WU00:FS01:0x21:Completed 75000 out of 1500000 steps (5%)
18:16:33:WU01:FS02:0x21:Completed 4150000 out of 5000000 steps (83%)
18:17:58:WU01:FS02:0x21:Completed 4200000 out of 5000000 steps (84%)
18:17:59:WU00:FS01:0x21:Completed 90000 out of 1500000 steps (6%)
18:19:22:WU01:FS02:0x21:Completed 4250000 out of 5000000 steps (85%)
18:19:28:WARNING:FS02:Size of positions 5845 does not match topology 5844
18:19:29:WU00:FS01:0x21:Completed 105000 out of 1500000 steps (7%)
18:20:48:WU01:FS02:0x21:Completed 4300000 out of 5000000 steps (86%)
18:20:59:WU00:FS01:0x21:Completed 120000 out of 1500000 steps (8%)
18:22:13:WU01:FS02:0x21:Completed 4350000 out of 5000000 steps (87%)
18:22:30:WU00:FS01:0x21:Completed 135000 out of 1500000 steps (9%)
18:23:37:WU01:FS02:0x21:Completed 4400000 out of 5000000 steps (88%)
18:24:00:WU00:FS01:0x21:Completed 150000 out of 1500000 steps (10%)
18:25:02:WU01:FS02:0x21:Completed 4450000 out of 5000000 steps (89%)
18:25:31:WU00:FS01:0x21:Completed 165000 out of 1500000 steps (11%)
18:26:26:WU01:FS02:0x21:Completed 4500000 out of 5000000 steps (90%)
18:26:33:WARNING:FS02:Size of positions 5845 does not match topology 5844
18:27:06:WU00:FS01:0x21:Completed 180000 out of 1500000 steps (12%)
18:27:57:WU01:FS02:0x21:Completed 4550000 out of 5000000 steps (91%)
18:28:38:WU00:FS01:0x21:Completed 195000 out of 1500000 steps (13%)
18:29:23:WU01:FS02:0x21:Completed 4600000 out of 5000000 steps (92%)
18:30:11:WU00:FS01:0x21:Completed 210000 out of 1500000 steps (14%)
18:30:49:WU01:FS02:0x21:Completed 4650000 out of 5000000 steps (93%)
18:31:43:WU00:FS01:0x21:Completed 225000 out of 1500000 steps (15%)
18:32:15:WU01:FS02:0x21:Completed 4700000 out of 5000000 steps (94%)
18:33:15:WU00:FS01:0x21:Completed 240000 out of 1500000 steps (16%)
18:33:41:WU01:FS02:0x21:Completed 4750000 out of 5000000 steps (95%)
18:33:47:WARNING:FS02:Size of positions 5845 does not match topology 5844
18:34:51:WU00:FS01:0x21:Completed 255000 out of 1500000 steps (17%)
18:35:07:WU01:FS02:0x21:Completed 4800000 out of 5000000 steps (96%)
18:36:25:WU00:FS01:0x21:Completed 270000 out of 1500000 steps (18%)
18:36:36:WU01:FS02:0x21:Completed 4850000 out of 5000000 steps (97%)
18:37:57:WU00:FS01:0x21:Completed 285000 out of 1500000 steps (19%)
18:38:02:WU01:FS02:0x21:Completed 4900000 out of 5000000 steps (98%)
18:39:28:WU01:FS02:0x21:Completed 4950000 out of 5000000 steps (99%)
18:39:28:WU02:FS02:Connecting to 65.254.110.245:8080
18:39:28:WU02:FS02:Assigned to work server 140.163.4.231
18:39:28:WU02:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.231
18:39:28:WU02:FS02:Connecting to 140.163.4.231:8080
18:39:29:WU02:FS02:Downloading 19.84MiB
18:39:29:WU00:FS01:0x21:Completed 300000 out of 1500000 steps (20%)
18:39:35:WU02:FS02:Download 34.34%
18:39:41:WU02:FS02:Download 72.46%
18:39:45:WU02:FS02:Download complete
18:39:46:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11726 run:0 clone:1841 gen:40 core:0x21 unit:0x000000358ca304e75b95ba69fc70e3ff
18:40:53:WU01:FS02:0x21:Completed 5000000 out of 5000000 steps (100%)
18:40:54:WU01:FS02:0x21:Saving result file logfile_01.txt
18:40:54:WU01:FS02:0x21:Saving result file checkpointState.xml
18:40:54:WU01:FS02:0x21:Saving result file checkpt.crc
18:40:54:WU01:FS02:0x21:Saving result file log.txt
18:40:54:WU01:FS02:0x21:Saving result file positions.xtc
18:40:54:WU01:FS02:0x21:Folding@home Core Shutdown: FINISHED_UNIT
18:40:54:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:40:54:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:11718 run:0 clone:919 gen:50 core:0x21 unit:0x000000428ca304e75b846ae67faecbf2
18:40:54:WU01:FS02:Uploading 15.09MiB to 140.163.4.231
18:40:54:WU01:FS02:Connecting to 140.163.4.231:8080
18:40:55:WU02:FS02:Starting
18:40:55:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Don\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 2720 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
18:40:55:WU02:FS02:Started FahCore on PID 14112
18:40:55:WU02:FS02:Core PID:3236
18:40:55:WU02:FS02:FahCore 0x21 started
18:40:55:WU02:FS02:0x21:*********************** Log Started 2018-09-22T18:40:55Z ***********************
18:40:55:WU02:FS02:0x21:Project: 11726 (Run 0, Clone 1841, Gen 40)
18:40:55:WU02:FS02:0x21:Unit: 0x000000358ca304e75b95ba69fc70e3ff
18:40:55:WU02:FS02:0x21:CPU: 0x00000000000000000000000000000000
18:40:55:WU02:FS02:0x21:Machine: 2
18:40:55:WU02:FS02:0x21:Reading tar file core.xml
18:40:55:WU02:FS02:0x21:Reading tar file integrator.xml
18:40:55:WU02:FS02:0x21:Reading tar file state.xml
18:40:55:WU02:FS02:0x21:Reading tar file system.xml
18:40:55:WU02:FS02:0x21:Digital signatures verified
18:40:55:WU02:FS02:0x21:Folding@home GPU Core21 Folding@home Core
18:40:55:WU02:FS02:0x21:Version 0.0.18
18:40:59:WU02:FS02:0x21:Completed 0 out of 5000000 steps (0%)
18:40:59:WU02:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:41:00:WU01:FS02:Upload 40.60%
18:41:00:WU00:FS01:0x21:Completed 315000 out of 1500000 steps (21%)
18:41:06:WU01:FS02:Upload 89.89%
18:41:07:WU01:FS02:Upload complete
18:41:07:WU01:FS02:Server responded WORK_ACK (400)
18:41:07:WU01:FS02:Final credit estimate, 130273.00 points
18:41:07:WU01:FS02:Cleaning up
Reason: fixed missing Code tag, mis-set option
The config files displayed in the most recent log are missing two important settings:
<team v='xxxxx'/>
<user v='zzzzzzzz'/>
FAH as successfully credited those WUs to
<team v='0'/>
<user v='Anonymous'/>
in accordance with the config that you recreated.
Here's one of them:
Hi Anonymous (team 0), Your WU (P11728 R0 C749 G69) was added to the stats database on Mon Sep 24 19:23:49 CDT 2018 for 7450 points of credit.
