Description of project.
boboviz
Post by boboviz »
It's 3 days that i cannot see the description of project i'm crunching.
Only "Loading"
Re: Description of project.
A persistent "loading" message general means that FAHClient and FAHControl are not communicating. There are many possible causes so we'll need more information before we can really help you.
1) Please include the first few pages of your log (see below) and well as the last few if it's long.
2) Have you restarted your system
3) Is your firewall blocking messages associated with FAH?
boboviz
Post by boboviz »
3) No firewall
2) Restarted many times
1)
*********************** Log Started 2018-09-24T18:16:56Z ***********************
18:16:56:************************* Folding@home Client *************************
18:16:56:        Website: https://foldingathome.org/
18:16:56:      Copyright: (c) 2009-2018 foldingathome.org
18:16:56:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:16:56:           Args: --open-web-control
18:16:56:         Config: C:\Users\xxx\AppData\Roaming\FAHClient\config.xml
18:16:56:******************************** Build ********************************
18:16:56:        Version: 7.5.1
18:16:56:           Date: May 11 2018
18:16:56:           Time: 13:06:32
18:16:56:     Repository: Git
18:16:56:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:16:56:         Branch: master
18:16:56:       Compiler: Visual C++ 2008
18:16:56:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:16:56:       Platform: win32 10
18:16:56:           Bits: 32
18:16:56:           Mode: Release
18:16:56:******************************* System ********************************
18:16:56:            CPU: AMD FX(tm)-6300 Six-Core Processor
18:16:56:         CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
18:16:56:           CPUs: 6
18:16:56:         Memory: 15.98GiB
18:16:56:    Free Memory: 12.19GiB
18:16:56:        Threads: WINDOWS_THREADS
18:16:56:     OS Version: 6.2
18:16:56:    Has Battery: false
18:16:56:     On Battery: false
18:16:56:     UTC Offset: 2
18:16:56:            PID: 6052
18:16:56:            CWD: C:\Users\xxx\AppData\Roaming\FAHClient
18:16:56:             OS: Windows 10 Enterprise
18:16:56:        OS Arch: AMD64
18:16:56:           GPUs: 1
18:16:56:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Baffin [Polaris11]
18:16:56:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
18:16:56:                 Impossibile trovare il modulo specificato.
18:16:56:
18:16:56:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2527.8
18:16:56:  Win32 Service: false
18:16:56:***********************************************************************
18:16:56:<config>
18:16:56:  <!-- Folding Slot Configuration -->
18:16:56:  <cause v='CANCER'/>
18:16:56:
18:16:56:  <!-- Network -->
18:16:56:  <proxy v=':8080'/>
18:16:56:
18:16:56:  <!-- Slot Control -->
18:16:56:  <power v='FULL'/>
18:16:56:
18:16:56:  <!-- User Information -->
18:16:56:  <team v='61171'/>
18:16:56:  <user v='boboviz'/>
18:16:56:
18:16:56:  <!-- Folding Slots -->
18:16:56:  <slot id='1' type='GPU'/>
18:16:56:</config>
18:16:56:Trying to access database...
18:16:56:Successfully acquired database lock
18:16:56:Enabled folding slot 01: READY gpu:0:Baffin [Polaris11]
18:16:56:WU01:FS01:Starting
18:16:56:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\xxx\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 6052 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:16:56:WU01:FS01:Started FahCore on PID 6676
18:16:56:WU01:FS01:Core PID:6332
18:16:56:WU01:FS01:FahCore 0x21 started
18:16:56:WU01:FS01:0x21:*********************** Log Started 2018-09-24T18:16:56Z ***********************
18:16:56:WU01:FS01:0x21:Project: 11718 (Run 0, Clone 163, Gen 39)
18:16:56:WU01:FS01:0x21:Unit: 0x000000338ca304e75b846a3d8cebad1d
18:16:56:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
18:16:56:WU01:FS01:0x21:Machine: 1
18:16:56:WU01:FS01:0x21:Digital signatures verified
18:16:56:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
18:16:56:WU01:FS01:0x21:Version 0.0.18
18:16:56:WU01:FS01:0x21:  Found a checkpoint file
18:16:57:WARNING:FS01:Size of positions 5845 does not match topology 5844
18:16:59:8:127.0.0.1:New Web connection
18:17:15:WU01:FS01:0x21:Completed 2750000 out of 5000000 steps (55%)
18:17:15:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:25:30:WU01:FS01:0x21:Completed 2800000 out of 5000000 steps (56%)
18:33:43:WU01:FS01:0x21:Completed 2850000 out of 5000000 steps (57%)
18:41:54:WU01:FS01:0x21:Completed 2900000 out of 5000000 steps (58%)
18:50:07:WU01:FS01:0x21:Completed 2950000 out of 5000000 steps (59%)
18:58:20:WU01:FS01:0x21:Completed 3000000 out of 5000000 steps (60%)
18:58:28:WARNING:FS01:Size of positions 5845 does not match topology 5844
19:06:33:WU01:FS01:0x21:Completed 3050000 out of 5000000 steps (61%)
19:14:43:WU01:FS01:0x21:Completed 3100000 out of 5000000 steps (62%)
19:22:55:WU01:FS01:0x21:Completed 3150000 out of 5000000 steps (63%)
19:31:09:WU01:FS01:0x21:Completed 3200000 out of 5000000 steps (64%)
19:39:21:WU01:FS01:0x21:Completed 3250000 out of 5000000 steps (65%)
19:39:29:WARNING:FS01:Size of positions 5845 does not match topology 5844
19:47:37:WU01:FS01:0x21:Completed 3300000 out of 5000000 steps (66%)
19:55:47:WU01:FS01:0x21:Completed 3350000 out of 5000000 steps (67%)
20:03:58:WU01:FS01:0x21:Completed 3400000 out of 5000000 steps (68%)
20:12:10:WU01:FS01:0x21:Completed 3450000 out of 5000000 steps (69%)
20:20:21:WU01:FS01:0x21:Completed 3500000 out of 5000000 steps (70%)
20:20:29:WARNING:FS01:Size of positions 5845 does not match topology 5844
20:28:34:WU01:FS01:0x21:Completed 3550000 out of 5000000 steps (71%)
20:36:44:WU01:FS01:0x21:Completed 3600000 out of 5000000 steps (72%)
20:44:54:WU01:FS01:0x21:Completed 3650000 out of 5000000 steps (73%)
20:53:06:WU01:FS01:0x21:Completed 3700000 out of 5000000 steps (74%)
21:01:16:WU01:FS01:0x21:Completed 3750000 out of 5000000 steps (75%)
21:01:25:WARNING:FS01:Size of positions 5845 does not match topology 5844
21:09:30:WU01:FS01:0x21:Completed 3800000 out of 5000000 steps (76%)
21:10:50:35:127.0.0.1:New Web connection
21:17:43:WU01:FS01:0x21:Completed 3850000 out of 5000000 steps (77%)
21:25:56:WU01:FS01:0x21:Completed 3900000 out of 5000000 steps (78%)
21:34:07:WU01:FS01:0x21:Completed 3950000 out of 5000000 steps (79%)
21:42:25:WU01:FS01:0x21:Completed 4000000 out of 5000000 steps (80%)
21:42:33:WARNING:FS01:Size of positions 5845 does not match topology 5844
21:50:38:WU01:FS01:0x21:Completed 4050000 out of 5000000 steps (81%)
21:58:50:WU01:FS01:0x21:Completed 4100000 out of 5000000 steps (82%)
22:07:03:WU01:FS01:0x21:Completed 4150000 out of 5000000 steps (83%)
22:15:15:WU01:FS01:0x21:Completed 4200000 out of 5000000 steps (84%)
22:23:25:WU01:FS01:0x21:Completed 4250000 out of 5000000 steps (85%)
22:23:34:WARNING:FS01:Size of positions 5845 does not match topology 5844
22:31:41:WU01:FS01:0x21:Completed 4300000 out of 5000000 steps (86%)
22:39:53:WU01:FS01:0x21:Completed 4350000 out of 5000000 steps (87%)
22:48:03:WU01:FS01:0x21:Completed 4400000 out of 5000000 steps (88%)
22:56:15:WU01:FS01:0x21:Completed 4450000 out of 5000000 steps (89%)
23:04:24:WU01:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
23:04:32:WARNING:FS01:Size of positions 5845 does not match topology 5844
23:12:37:WU01:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
23:20:49:WU01:FS01:0x21:Completed 4600000 out of 5000000 steps (92%)
23:28:59:WU01:FS01:0x21:Completed 4650000 out of 5000000 steps (93%)
23:37:10:WU01:FS01:0x21:Completed 4700000 out of 5000000 steps (94%)
23:45:22:WU01:FS01:0x21:Completed 4750000 out of 5000000 steps (95%)
23:45:30:WARNING:FS01:Size of positions 5845 does not match topology 5844
23:53:36:WU01:FS01:0x21:Completed 4800000 out of 5000000 steps (96%)
00:01:48:WU01:FS01:0x21:Completed 4850000 out of 5000000 steps (97%)
00:10:01:WU01:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
******************************* Date: 2018-09-25 *******************************
Seems no errors about communication between FahClient and FahControl....
Mod edit: changed Quote tags to Code on log file
Are you able to open https://apps.foldingathome.org/project.py?p=+11718+ in your browser?
Which program is reporting persistent "loading" message? Is it WebControl or FAHControl or something else?
boboviz
Post by boboviz »
bruce wrote:Are you able to open https://apps.foldingathome.org/project.py?p=+11718+ in your browser?
Yes
The project desctiption is only on WebControl...
It's not a big problem, but i like to see what i'm crunching
boboviz
Post by boboviz »
Uh. It returns.
I do nothing, but now the description is visible....
boboviz wrote:Uh. It returns.
Yes, Based on the information discussed above (which were treated as a trouble report) a networking problem was identified and fixed.
