failed to open dynamic library nvcuda.dll
Demose
Post by Demose »
folding at home is only using 2% of my GPU and when I go to the system info tab the error :Not detected: Failed to open dynamic library 'nvcuda.dll' : The specified module could not be found.
Image: https://ibb.co/dgNwVz
bollix47
Re: failed to open dynamic library nvcuda.dll
Post by bollix47 »
You don't need any nvidia .dll files since you're using an AMD GPU. Where are you seeing the 2% usage? If it's in windows task manager that's more than likely the amount of CPU being used by folding to feed your GPU. Use GPU-z to see the actual GPU usage.
Demose
Post by Demose »
OK according to GPU-z it is using 100%, so what is up with that error message?
bollix47
Post by bollix47 »
It's not an error message ... it's an information message telling you that your GPU does not support CUDA which is quite correct since CUDA is an nvidia language, not AMD. We don't use it at this point on either since we're using opencl but we did in the past and may in the future, just not on AMD GPUs. They will either continue to use opencl or maybe something else.
In addition, for nVidia setups that message is an important one for debugging purposes. The driver installers from nVidia install OpenCL support as part of the same bit that installs CUDA support. So if CUDA is missing, and it is a nVidia GPU, OpenCL is also probably not properly installed.
