F@H visualization is only showing demo
Mrmajik45
Post by Mrmajik45 »
On your Visualization program it's only showing the demo program. But i have it folding. Can you help?
ReactOS Donator ~ $5.00 | Linux Mint Donator ~ $1.00 in BTC
ChristianVirtual
Re: F@H visualization is only showing demo
Post by ChristianVirtual »
Welcome to the forum Mrmajik45
Can you please share more details about your system (e. Windows, Linux, Mac) and which project you want to visualuze (CPU or GPU based); ideally give us the concrete assigned Workunit ID or project.
Thx
Mrmajik45
Post by Mrmajik45 »
Windows 10 Pro. Project 13812. CPU "It won't use my Intel gpu :(" It says it can't find it. But my gpu supports OpenCL 1.2 FULL
The FAHViewer problem has already been reported: https://github.com/FoldingAtHome/fah-control/issues/31
Presumably your CPU runs a number of SMP threads. You can manually reconfigure it to use fewer CPUs which should allow the battery to charge but of course will delay the completion of the active WU and reduce your PPD.
A word of warning, however. When the current WU is almost finished, a new assignment will be downloaded. You'll need to manually increase the number of active CPUs back to 2 BEFORE the next WU downloads.. Though I haven't tested it, if a WU is downloaded when a reduced CPU count is active, it can't be reconfigured to use more than that number until the next WU downloads.
Thanks for submitting your enhancement request.
Another word of warning. Enhancements generally take a long, long time to be considered.
Post by foldy »
Intel integrated GPU is currently not supported by FAH but only Nvidia and AMD dedicated GPUs.
Mrmajik45
Post by Mrmajik45 »
Uh it's not a Mac. I'm not using Boot camp. It's just Windows.
Response from Mod:
Oops.
Earlier post corrected.
