Broken "Passkey" link on WebControl
Denys Romaniuk
Post by Denys Romaniuk »
I just installed fah-installer_7.5.1_x86.exe on Windows 10.
And I found a small bug...
Open WebControl.
Press "Change Identity" link.
A "Change Identity" window appears.
In Passkey column, press "Get a Passkey" link.
"404 Not Found" error appears.
The link points to https://apps.foldingathome.org/paskey/create/
But it should point to https://apps.foldingathome.org/passkey/create
We have "/paskey/" in the wrong link and "/passkey/" in the right link.
bollix47
Re: Broken "Passkey" link on WebControl
Post by bollix47 »
Thanks for the report ... I've sent a notification to the person responsible for fixing the link. Although your second link does work the actual link is:
https://apps.foldingathome.org/getpasskey.py
SteveWillis
Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Post by SteveWillis »
If you already had a passkey and know what it was you don't need a new one.
