goodyca
Posts: 187 Joined: Sun Dec 02, 2007 12:36 pm
Post
by goodyca » Fri Jul 06, 2018 3:47 pm
The subject WU was completed July 5th at 22:44 UTC, but no credit was given.
19:31:54:WU01:FS00:Connecting to 65.254.110.245:8080
19:31:54:WU01:FS00:Assigned to work server 155.247.166.219
19:31:54:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:12 from 155.247.166.219
19:31:54:WU01:FS00:Connecting to 155.247.166.219:8080
19:31:55:WU01:FS00:Downloading 595.23KiB
19:31:56:WU01:FS00:Download complete
19:31:56:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14057 run:7 clone:70 gen:12 core:0xa7 unit:0x0000001f0002894b5aeb601302dde927
19:32:54:WU01:FS00:Starting
19:32:54:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/AVX/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 2253 -checkpoint 15 -np 12
19:32:54:WU01:FS00:Started FahCore on PID 8269
19:32:54:WU01:FS00:Core PID:8273
19:32:54:WU01:FS00:FahCore 0xa7 started
19:32:55:WU01:FS00:0xa7:*********************** Log Started 2018-07-05T19:32:55Z ***********************
19:32:55:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:32:55:WU01:FS00:0xa7: Type: 0xa7
19:32:55:WU01:FS00:0xa7: Core: Gromacs
19:32:55:WU01:FS00:0xa7: Website: https://foldingathome.org/
19:32:55:WU01:FS00:0xa7: Copyright: (c) 2009-2018 foldingathome.org
19:32:55:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:32:55:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 8269 -checkpoint 15 -np
19:32:55:WU01:FS00:0xa7: 12
19:32:55:WU01:FS00:0xa7: Config: <none>
19:32:55:WU01:FS00:0xa7:************************************ Build *************************************
19:32:55:WU01:FS00:0xa7: Version: 0.0.17
19:32:55:WU01:FS00:0xa7: Date: Apr 27 2018
19:32:55:WU01:FS00:0xa7: Time: 19:09:21
19:32:55:WU01:FS00:0xa7: Repository: Git
19:32:55:WU01:FS00:0xa7: Revision: 21359963583d09ec2063ef946399441c4df4ccd7
19:32:55:WU01:FS00:0xa7: Branch: master
19:32:55:WU01:FS00:0xa7: Compiler: GNU 6.3.0 20170516
19:32:55:WU01:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops
19:32:55:WU01:FS00:0xa7: Platform: linux2 4.14.0-3-amd64
19:32:55:WU01:FS00:0xa7: Bits: 64
19:32:55:WU01:FS00:0xa7: Mode: Release
19:32:55:WU01:FS00:0xa7: SIMD: avx_256
19:32:55:WU01:FS00:0xa7:************************************ System ************************************
19:32:55:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4930K CPU @ 3.40GHz
19:32:55:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
19:32:55:WU01:FS00:0xa7: CPUs: 12
19:32:55:WU01:FS00:0xa7: Memory: 7.72GiB
19:32:55:WU01:FS00:0xa7:Free Memory: 2.05GiB
19:32:55:WU01:FS00:0xa7: Threads: POSIX_THREADS
19:32:55:WU01:FS00:0xa7: OS Version: 4.17
19:32:55:WU01:FS00:0xa7:Has Battery: false
19:32:55:WU01:FS00:0xa7: On Battery: false
19:32:55:WU01:FS00:0xa7: UTC Offset: -5
19:32:55:WU01:FS00:0xa7: PID: 8273
19:32:55:WU01:FS00:0xa7: CWD: /var/lib/fahclient/work
19:32:55:WU01:FS00:0xa7: OS: Linux 4.17.3-200.fc28.x86_64 x86_64
19:32:55:WU01:FS00:0xa7: OS Arch: AMD64
19:32:55:WU01:FS00:0xa7:********************************************************************************
19:32:55:WU01:FS00:0xa7:Project: 14057 (Run 7, Clone 70, Gen 12)
19:32:55:WU01:FS00:0xa7:Unit: 0x0000001f0002894b5aeb601302dde927
19:32:55:WU01:FS00:0xa7:Reading tar file core.xml
19:32:55:WU01:FS00:0xa7:Reading tar file frame12.tpr
19:32:55:WU01:FS00:0xa7:Digital signatures verified
19:32:55:WU01:FS00:0xa7:Calling: mdrun -s frame12.tpr -o frame12.trr -cpt 15 -nt 12
19:32:55:WU01:FS00:0xa7:Steps: first=30000000 total=2500000
19:32:55:WU01:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
19:34:50:WU01:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
19:36:45:WU01:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
19:38:39:WU01:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
22:40:38:WU01:FS00:0xa7:Completed 2450000 out of 2500000 steps (98%)
******************************* Date: 2018-07-05 *******************************
22:42:35:WU01:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
22:44:28:WU01:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
22:44:29:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
22:44:29:WU01:FS00:0xa7:Saving result file ener.edr
22:44:29:WU01:FS00:0xa7:Saving result file frame12.trr
22:44:30:WU01:FS00:0xa7:Saving result file md.log
22:44:30:WU01:FS00:0xa7:Saving result file pullf.xvg
22:44:30:WU01:FS00:0xa7:Saving result file pullx.xvg
22:44:30:WU01:FS00:0xa7:Saving result file science.log
22:44:30:WU01:FS00:0xa7:Saving result file traj_comp.xtc
22:44:30:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
22:44:30:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:44:30:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14057 run:7 clone:70 gen:12 core:0xa7 unit:0x0000001f0002894b5aeb601302dde927
22:44:30:WU01:FS00:Uploading 4.77MiB to 155.247.166.219
22:44:30:WU01:FS00:Connecting to 155.247.166.219:8080
22:44:36:WU01:FS00:Upload 36.65%
22:44:42:WU01:FS00:Upload 62.83%
22:44:48:WU01:FS00:Upload 95.56%
22:44:49:WU01:FS00:Upload complete
22:44:49:WU01:FS00:Server responded WORK_ACK (400)
22:44:49:WU01:FS00:Final credit estimate, 9715.00 points
22:44:49:WU01:FS00:Cleaning up
Posts: 8158 Joined: Tue Apr 21, 2009 4:41 pm
Hardware configuration: Mac Studio M1 Max 32 GB smp6 Mac Hack i7-7700K 48 GB smp4
Post
by Joe_H » Fri Jul 06, 2018 4:00 pm
If you think you are missing credit, it is from a different WU.
Hi goodyca (team 439), Your WU (P14057 R7 CF G12) was added to the stats database on Fri Jul 06 10:59:05 CDT 2018 for 810 points of credit.
What does appear is that it did not get the estimated bonus points, and was not credited until today.
goodyca
Post
by goodyca » Fri Jul 06, 2018 7:23 pm
Is there any reason for the missing bonus?
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Fri Jul 06, 2018 8:23 pm
goodyca wrote: Is there any reason for the missing bonus?
Any chance that you changed either your passkey or your user name (even slightly)?
goodyca
Post
by goodyca » Sat Jul 07, 2018 10:38 am
No. I have used the same user name and passkey from the time passkeys were first used.
goodyca
Post
by goodyca » Sat Jul 07, 2018 12:14 pm
The subject WU was completed July 7th at 05:21 UTC, but no credit was given.
00:00:23:WU00:FS01:Connecting to 65.254.110.245:8080
00:00:23:WU00:FS01:Assigned to work server 128.252.203.4
00:00:23:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP107 [GeForce GTX 1050 Ti] 2138 from 128.252.203.4
00:00:23:WU00:FS01:Connecting to 128.252.203.4:8080
00:00:24:WU00:FS01:Downloading 11.66MiB
00:00:25:WU00:FS01:Download complete
00:00:25:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13816 run:0 clone:2725 gen:4 core:0x21 unit:0x0000000480fccb045b3f79129a822318
00:00:26:WU00:FS01:Starting
00:00:26:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 705 -lifeline 1744 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
00:00:26:WU00:FS01:Started FahCore on PID 16221
00:00:26:WU00:FS01:Core PID:16225
00:00:26:WU00:FS01:FahCore 0x21 started
00:00:26:WU00:FS01:0x21:*********************** Log Started 2018-07-07T00:00:26Z ***********************
00:00:26:WU00:FS01:0x21:Project: 13816 (Run 0, Clone 2725, Gen 4)
00:00:26:WU00:FS01:0x21:Unit: 0x0000000480fccb045b3f79129a822318
00:00:26:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:00:26:WU00:FS01:0x21:Machine: 1
00:00:26:WU00:FS01:0x21:Reading tar file core.xml
00:00:26:WU00:FS01:0x21:Reading tar file integrator.xml
00:00:26:WU00:FS01:0x21:Reading tar file state.xml
00:00:26:WU00:FS01:0x21:Reading tar file system.xml
00:00:26:WU00:FS01:0x21:Digital signatures verified
00:00:26:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:00:26:WU00:FS01:0x21:Version 0.0.18
00:00:28:WU00:FS01:0x21:Completed 0 out of 5000000 steps (0%)
00:00:28:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:03:41:WU00:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
00:06:53:WU00:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
00:10:05:WU00:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
05:14:33:WU00:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
05:17:46:WU00:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
05:20:59:WU00:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
05:21:00:WU00:FS01:0x21:Saving result file logfile_01.txt
05:21:00:WU00:FS01:0x21:Saving result file checkpointState.xml
05:21:00:WU00:FS01:0x21:Saving result file checkpt.crc
05:21:00:WU00:FS01:0x21:Saving result file log.txt
05:21:00:WU00:FS01:0x21:Saving result file positions.xtc
05:21:00:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
05:21:00:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:21:00:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:13816 run:0 clone:2725 gen:4 core:0x21 unit:0x0000000480fccb045b3f79129a822318
05:21:00:WU00:FS01:Uploading 6.42MiB to 128.252.203.4
05:21:00:WU00:FS01:Connecting to 128.252.203.4:8080
05:21:06:WU00:FS01:Upload 37.95%
05:21:13:WU00:FS01:Upload 81.73%
05:21:18:WU00:FS01:Upload complete
05:21:18:WU00:FS01:Server responded WORK_ACK (400)
05:21:18:WU00:FS01:Final credit estimate, 39958.00 points
05:21:18:WU00:FS01:Cleaning up
goodyca
Post
by goodyca » Sun Jul 08, 2018 12:07 pm
The subject WU was completed July 8th at 02:09 UTC, but no credit was given.
21:26:16:WU01:FS00:Connecting to 65.254.110.245:8080
21:26:16:WU01:FS00:Assigned to work server 128.252.203.2
21:26:16:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 128.252.203.2
21:26:16:WU01:FS00:Connecting to 128.252.203.2:8080
21:26:17:WU01:FS00:Downloading 4.53MiB
21:26:19:WU01:FS00:Download complete
21:26:19:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13809 run:0 clone:627 gen:193 core:0xa7 unit:0x000000da80fccb025a91909f9976f986
21:27:29:WU01:FS00:Starting
21:27:29:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/AVX/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1408 -checkpoint 15 -np 8
21:27:29:WU01:FS00:Started FahCore on PID 20091
21:27:29:WU01:FS00:Core PID:20095
21:27:29:WU01:FS00:FahCore 0xa7 started
21:27:29:WU01:FS00:0xa7:*********************** Log Started 2018-07-07T21:27:29Z ***********************
21:27:29:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:27:29:WU01:FS00:0xa7: Type: 0xa7
21:27:29:WU01:FS00:0xa7: Core: Gromacs
21:27:29:WU01:FS00:0xa7: Website: https://foldingathome.org/
21:27:29:WU01:FS00:0xa7: Copyright: (c) 2009-2018 foldingathome.org
21:27:29:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:27:29:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 20091 -checkpoint 15 -np
21:27:29:WU01:FS00:0xa7: 8
21:27:29:WU01:FS00:0xa7: Config: <none>
21:27:29:WU01:FS00:0xa7:************************************ Build *************************************
21:27:29:WU01:FS00:0xa7: Version: 0.0.17
21:27:29:WU01:FS00:0xa7: Date: Apr 27 2018
21:27:29:WU01:FS00:0xa7: Time: 19:09:21
21:27:29:WU01:FS00:0xa7: Repository: Git
21:27:29:WU01:FS00:0xa7: Revision: 21359963583d09ec2063ef946399441c4df4ccd7
21:27:29:WU01:FS00:0xa7: Branch: master
21:27:29:WU01:FS00:0xa7: Compiler: GNU 6.3.0 20170516
21:27:29:WU01:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops
21:27:29:WU01:FS00:0xa7: Platform: linux2 4.14.0-3-amd64
21:27:29:WU01:FS00:0xa7: Bits: 64
21:27:29:WU01:FS00:0xa7: Mode: Release
21:27:29:WU01:FS00:0xa7: SIMD: avx_256
21:27:29:WU01:FS00:0xa7:************************************ System ************************************
21:27:29:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz
21:27:29:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
21:27:29:WU01:FS00:0xa7: CPUs: 8
21:27:29:WU01:FS00:0xa7: Memory: 7.71GiB
21:27:29:WU01:FS00:0xa7:Free Memory: 1.58GiB
21:27:29:WU01:FS00:0xa7: Threads: POSIX_THREADS
21:27:29:WU01:FS00:0xa7: OS Version: 4.17
21:27:29:WU01:FS00:0xa7:Has Battery: false
21:27:29:WU01:FS00:0xa7: On Battery: false
21:27:29:WU01:FS00:0xa7: UTC Offset: -5
21:27:29:WU01:FS00:0xa7: PID: 20095
21:27:29:WU01:FS00:0xa7: CWD: /var/lib/fahclient/work
21:27:29:WU01:FS00:0xa7: OS: Linux 4.17.3-200.fc28.x86_64 x86_64
21:27:29:WU01:FS00:0xa7: OS Arch: AMD64
21:27:29:WU01:FS00:0xa7:********************************************************************************
21:27:29:WU01:FS00:0xa7:Project: 13809 (Run 0, Clone 627, Gen 193)
21:27:29:WU01:FS00:0xa7:Unit: 0x000000da80fccb025a91909f9976f986
21:27:29:WU01:FS00:0xa7:Reading tar file core.xml
21:27:29:WU01:FS00:0xa7:Reading tar file frame193.tpr
21:27:29:WU01:FS00:0xa7:Digital signatures verified
21:27:29:WU01:FS00:0xa7:Calling: mdrun -s frame193.tpr -o frame193.trr -x frame193.xtc -cpt 15 -nt 8
21:27:29:WU01:FS00:0xa7:Steps: first=48250000 total=250000
21:27:32:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
21:30:22:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
21:33:11:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
21:35:59:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
02:03:08:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
02:05:56:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
02:08:44:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
02:08:46:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
02:08:47:WU01:FS00:0xa7:Saving result file frame193.trr
02:08:47:WU01:FS00:0xa7:Saving result file frame193.xtc
02:08:47:WU01:FS00:0xa7:Saving result file md.log
02:08:47:WU01:FS00:0xa7:Saving result file science.log
02:08:47:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
02:08:47:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:08:47:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13809 run:0 clone:627 gen:193 core:0xa7 unit:0x000000da80fccb025a91909f9976f986
02:08:47:WU01:FS00:Uploading 7.60MiB to 128.252.203.2
02:08:47:WU01:FS00:Connecting to 128.252.203.2:8080
02:08:53:WU01:FS00:Upload 33.73%
02:08:59:WU01:FS00:Upload 66.63%
02:09:05:WU01:FS00:Upload 96.24%
02:09:08:WU01:FS00:Upload complete
02:09:08:WU01:FS00:Server responded WORK_ACK (400)
02:09:08:WU01:FS00:Final credit estimate, 9305.00 points
02:09:08:WU01:FS00:Cleaning up
Post
by Joe_H » Sun Jul 08, 2018 3:52 pm
I have sent a message to the persons managing this WS and the stats database about this WU and the one you previously reported - viewtopic.php?f=19&t=30916.
jcoffland
Posts: 1018 Joined: Fri Oct 10, 2008 6:42 pm
Post
by jcoffland » Mon Jul 09, 2018 12:45 am
Ok, I've fixed it. Looks like the new stats system is missing some credits. The credit logs are all still there though so they will get processed eventually.
jcoffland
Post
by jcoffland » Mon Jul 09, 2018 12:46 am
Working on it.
jcoffland
Post
by jcoffland » Tue Jul 10, 2018 7:06 am
All missing points should be credited now. I made some improvements to the new collection code to avoid such problems in the future. Let me know if you see anything else that looks wrong.
