Linux (Centos 7.5, and Ubuntu 14.05LTS) a7 core failures
parkut
Post by parkut »
I am seeing core failures across dozens of machines I manage. This has been going on for several weeks now.
I did spot discussion of a similar (or same) issue here: viewtopic.php?f=72&t=30851
But, the proposed fix for Ubuntu systems did not resolve the issue. Is there a cure?
18:02:04:WU01:FS00:Starting
18:02:04:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/AVX/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 704 -lifeline 25424 -checkpoint 15 -np 8
18:02:04:WU01:FS00:Started FahCore on PID 25450
18:02:04:WU01:FS00:Core PID:25454
18:02:04:WU01:FS00:FahCore 0xa7 started
18:02:04:WARNING:WU01:FS00:FahCore returned: FAILED_2 (1 = 0x1)
18:02:04:WARNING:WU01:FS00:Too many errors, failing
18:02:04:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:14062 run:4 clone:41 gen:73 core:0xa7 unit:0x000000610002894b5b0c332146e26004
18:02:04:WU01:FS00:Connecting to 155.247.166.219:8080
18:02:05:WU01:FS00:Server responded WORK_ACK (400)
18:02:05:WU01:FS00:Cleaning up
# ldd FahCore_a7
./FahCore_a7: /lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by ./FahCore_a7)
./FahCore_a7: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./FahCore_a7)
        linux-vdso.so.1 =>  (0x00007ffee01bf000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f966972e000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007f966952a000)
        libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f9669223000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f9668f21000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f9668d0b000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f966893e000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f966acbb000)
Re: Linux (Centos 7.5, and Ubuntu 14.05LTS) a7 core failures
Ubuntu 14.04 (aka Trusty Tahr) was released in April of 2014, not May. There is no 14.05. You probably meant 14.04.05 LTS.
I did get a new version of Core_a7 yesterday so there's a chance it has been fixed. II don't know what changed when Version: 0.0.17 replaced Version: 0.0.16. The logs you posted don't show the applicable version number which is displayed when FAHCore_a7 starts.
As you've been told, the missing those entry points are in a version updated C++ libs and gcc. The instructions to update Ubuntu are here Another reasonable possibility is to update your OS to a later version. Support for 14.04 will be ending soon anyway.
I did get a new version of Core_a7 yesterday so there's a chance it has been fixed. Version: 0.0.17 replaced Version: 0.0.16.
I have the same issue and core A7 started to fail on 14.04, probably after an update that broke the libs ... :(
