screensaver/viewer stays in demo mode -> not working 7.5.1
Djfe
Post by Djfe »
*********************** Log Started 2018-06-21T21:01:13Z ***********************
21:01:13:************************* Folding@home Client *************************
21:01:13:        Website: https://foldingathome.org/
21:01:13:      Copyright: (c) 2009-2018 foldingathome.org
21:01:13:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:01:13:           Args: --open-web-control
21:01:13:         Config: C:\ProgramData\FAHClient\config.xml
21:01:13:******************************** Build ********************************
21:01:13:        Version: 7.5.1
21:01:13:           Date: May 11 2018
21:01:13:           Time: 13:06:32
21:01:13:     Repository: Git
21:01:13:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
21:01:13:         Branch: master
21:01:13:       Compiler: Visual C++ 2008
21:01:13:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:01:13:       Platform: win32 10
21:01:13:           Bits: 32
21:01:13:           Mode: Release
21:01:13:******************************* System ********************************
21:01:13:            CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
21:01:13:         CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
21:01:13:           CPUs: 8
21:01:13:         Memory: 15.94GiB
21:01:13:    Free Memory: 7.40GiB
21:01:13:        Threads: WINDOWS_THREADS
21:01:13:     OS Version: 6.2
21:01:13:    Has Battery: false
21:01:13:     On Battery: false
21:01:13:     UTC Offset: 2
21:01:13:            PID: 15372
21:01:13:            CWD: C:\ProgramData\FAHClient
21:01:13:             OS: Windows 10 Enterprise
21:01:13:        OS Arch: AMD64
21:01:13:           GPUs: 1
21:01:13:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM204 [GeForce GTX 980] 4612
21:01:13:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:9.2
21:01:13:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:398.11
21:01:13:  Win32 Service: false
21:01:13:***********************************************************************
21:01:13:<config>
21:01:13:  <!-- Network -->
21:01:13:  <proxy v=':8080'/>
21:01:13:
21:01:13:  <!-- Slot Control -->
21:01:13:  <pause-on-battery v='false'/>
21:01:13:  <power v='FULL'/>
21:01:13:
21:01:13:  <!-- User Information -->
21:01:13:  <passkey v='********************************'/>
21:01:13:  <team v='223518'/>
21:01:13:  <user v='Djfe'/>
21:01:13:
21:01:13:  <!-- Folding Slots -->
21:01:13:  <slot id='0' type='CPU'>
21:01:13:    <idle v='true'/>
21:01:13:  </slot>
21:01:13:  <slot id='1' type='GPU'>
21:01:13:  </slot>
21:01:13:</config>
21:01:13:Trying to access database...
21:01:13:Successfully acquired database lock
21:01:13:Enabled folding slot 00: PAUSED cpu:7 (waiting for idle)
21:01:13:Enabled folding slot 01: PAUSED gpu:0:GM204 [GeForce GTX 980] 4612 (waiting for idle)
21:01:16:7:127.0.0.1:New Web connection
21:03:21:ERROR:Receive error: 10053: Eine bestehende Verbindung wurde softwaregesteuert
21:03:21:ERROR:durch den Hostcomputer abgebrochen.
21:03:37:ERROR:Receive error: 10053: Eine bestehende Verbindung wurde softwaregesteuert
21:03:37:ERROR:durch den Hostcomputer abgebrochen.
21:03:53:ERROR:Receive error: 10053: Eine bestehende Verbindung wurde softwaregesteuert
21:03:53:ERROR:durch den Hostcomputer abgebrochen.
21:04:09:ERROR:Receive error: 10053: Eine bestehende Verbindung wurde softwaregesteuert
21:04:09:ERROR:durch den Hostcomputer abgebrochen.
Hi everyone,
how can I check whether the screensaver is working?
Because it doesn't seem to be working.
My client is not paused and waits on idle. (config-wise)
Even when wait on idle is disabled the viewer(button in advanced panel next to the slider) only shows demo mode :/
But at least it's running then, though it's always running.
Does anyone know what the aborted connection errors mean? Are they related only to the viewer?
Regards,
Djfe
Re: screensaver/viewer stays in demo mode -> not working 7.5
This is a known issue from the public beta test. The last post on this is here - viewtopic.php?f=104&t=30811&p=301595&hilit=Demo#p301595. Hopefully it will be fixed in an update sometime in the near future, but currently resources are tied up in moving the folding site to its new location - foldingathome.org.
Djfe
Post by Djfe »
Thx for your quick answer!
Does the screensaver work though?
Else I will deactivate it until the next update or return to the previous version.
