Points
Ricorocks
Points
Post by Ricorocks »
Are point servers down? When will they be working again?
Re: Points
No. They are temporarily not out of order.
I got points 2 hours ago at https://folding.extremeoverclocking.com, I am expecting more in one hour.
[ and it is still giving me points an hour later]
Re: Points
@Ricorocks
Something is wrong with SOME of the stats, but I'm not sure what it is. Please report the PRCG of a couple of WUs you've completed recently (for which you may not have received credit).
Ricorocks
Re: Points
Post by Ricorocks »
Hi Guys,
For the last week or more, all I get is "Loading" & nothing more. All Gpu's & CPu's fine
ChrisS
Re: Points
Post by ChrisS »
Simply press the refresh button on your browser.
Ricorocks
Re: Points
Post by Ricorocks »
Tried refresh browser, still loading! NO Help
I looked at statistics:
449 Ricoocks 820,258,430 23,745 today's numbers
Last time I saw points on any of my 3 folders it was 775,000,000, I do appox 1.2mil per day.
Re: Points
Ricorocks wrote:Tried refresh browser, still loading! NO Help
Post the log.
Re: Points
How are you looking at the stats and getting the "Loading" message? Is it through the web control for folding, or by another means. What version of the client are you using?
Basically, the stats are working for almost everyone, please give enough information so we have a chance of figuring out what is different for your attempts to look at the stats.
Re: Points
Which of your accounts are you looking at? Have you checked that the spelling of your account name matches EXACTLY what you're looking at?
Ricorocks
Re: Points
Post by Ricorocks »
I did not change anything on my three folders, one day points, next am "loading" & all three show Ricoocks see image
[2018-06-18_17-33-24.jpg](https://postimg.cc/image/hh6taxqxp/)
bollix47
Re: Points
Post by bollix47 »
I can confirm that I'm seeing Loading ... on the Web Control page in Windows 10 Home but using Windows 10 Pro & linux I see the data loaded. I will look further into this tomorrow when I will have more time. Hopefully someone will come up with a solution before then.
@Ricorocks Which o/s are you using? Also, your EOC stats shows you are getting points just fine:
https://folding.extremeoverclocking.com ... =&u=713897
Re: Points
Which version of the client, 7.4.4 or the current version 7.5.1? Also, when was your system restarted last, it may need to update its cached DNS entries if it has been a while. The servers are in the process of moving, and while most things are redirected to the new server there have been some glitches associated with that.
bollix47
Re: Points
Post by bollix47 »
I agree with Joe's comments above.
@Ricorocks
The first thing I would try is clearing your DNS cache:
close your browser
open a command prompt
enter the following one at a time:
ipconfig /displaydns
ipconfig /flushdns
The last display should confirm that the DNS cache has been flushed by displaying a lot fewer entries... if it doesn't then repeat the above but open the command prompt as Administrator.
Try Web Control again.
If the above doesn't work continue below.
I made numerous changes on my non-working system to get it looking like the system that did work:
Changed Windows Defender Firewall to Private and made sure both Private & Public had a check mark for fahclient.
Cleared my browser's (Chrome) cache & cookies. (I have doubts about this step as the page now loads properly on other browsers (Firefox & Edge) where I did not clear those items but neither worked previously)
I could not tell you which item fixed it but it is now working properly and I can't repeat the problem even if I try to reverse some of the above steps which could point to a DNS problem that somehow got fixed during my attempts. Your Web Control page does open but it doesn't fetch your stats and the location of those stats has changed so that may be what is causing the problem.
@Joe_H In my case I saw the problem on both 7.4.16 & 7.5.1
Ricorocks
Re: Points
Post by Ricorocks »
I'll answer what I can now, then try ipconfig
I only know of one account, & use this only "Ricoocks", OS folders 2 win10, 1 Win7 all 64bit. Fah client used all 3 machines ver. 7.4.4
The logs are too big to post here & suggestions as to which portion might be helpful. Also above I linked to a jpg (like dropbox), I can try to post the full log there, if that would be helpful.
Tried the ipconfig all three at elevated command prompt, this did not restore points at web control
Ricorocks
Re: Points
Post by Ricorocks »
Aint that strange, all three machines said Loading, at the same time, the previous day points were showing
I saw from Joe_H - I was a little behind in client ver. I installed over the top of 7.4.4 to 7.5.1 and behold & low! I see 824,617,604 points
pretty soon I'll be a billionaire, I heard billionaires get a free rubber chicken dinner at Stanford. LOL as in kidding.
Thank you all for helping & guidance!
