FahCore_a7 0.0.17 fails to start on Ubuntu 14.04 LTS
_r2w_ben
Post by _r2w_ben »
Either because of version 0.0.17 or the core URL switch, this machine has been trashing a7 work units until it is assigned an a4 work unit. It's an original Core 2 Duo without AVX and uses the SSE version of the core.
Last successful a7 with 0.0.16 from fahwebx.stanford.edu:
11:24:32:WU00:FS00:Connecting to 128.252.203.2:8080
11:24:32:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 704 -lifeline 2051 -checkpoint 15 -np 2
11:24:32:WU01:FS00:Started FahCore on PID 20144
11:24:32:WU01:FS00:Core PID:20148
11:24:32:WU01:FS00:FahCore 0xa7 started
11:24:33:WU01:FS00:0xa7:*********************** Log Started 2018-05-30T11:24:32Z ***********************
11:24:33:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:24:33:WU01:FS00:0xa7:       Type: 0xa7
11:24:33:WU01:FS00:0xa7:       Core: Gromacs
11:24:33:WU01:FS00:0xa7:    Website: http://folding.stanford.edu/
11:24:33:WU01:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
11:24:33:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:24:33:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 704 -lifeline 20144 -checkpoint 15 -np
11:24:33:WU01:FS00:0xa7:             2
11:24:33:WU01:FS00:0xa7:     Config: <none>
11:24:33:WU01:FS00:0xa7:************************************ Build *************************************
11:24:33:WU01:FS00:0xa7:    Version: 0.0.16
11:24:33:WU01:FS00:0xa7:       Date: Oct 31 2017
11:24:33:WU01:FS00:0xa7:       Time: 19:24:13
11:24:33:WU01:FS00:0xa7: Repository: Git
11:24:33:WU01:FS00:0xa7:   Revision: 2f0a8a3d0b0698be48154fe99a0216f289060932
11:24:33:WU01:FS00:0xa7:     Branch: master
11:24:33:WU01:FS00:0xa7:   Compiler: GNU 4.9.2
11:24:33:WU01:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops
11:24:33:WU01:FS00:0xa7:   Platform: linux2 4.9.0-1-amd64
11:24:33:WU01:FS00:0xa7:       Bits: 64
11:24:33:WU01:FS00:0xa7:       Mode: Release
11:24:33:WU01:FS00:0xa7:       SIMD: sse2
11:24:33:WU01:FS00:0xa7:************************************ System ************************************
11:24:33:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz
11:24:33:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 2
11:24:33:WU01:FS00:0xa7:       CPUs: 2
11:24:33:WU01:FS00:0xa7:     Memory: 1.95GiB
11:24:33:WU01:FS00:0xa7:Free Memory: 578.90MiB
11:24:33:WU01:FS00:0xa7:    Threads: POSIX_THREADS
11:24:33:WU01:FS00:0xa7: OS Version: 3.13
11:24:33:WU01:FS00:0xa7:Has Battery: false
11:24:33:WU01:FS00:0xa7: On Battery: false
11:24:33:WU01:FS00:0xa7: UTC Offset: -4
11:24:33:WU01:FS00:0xa7:        PID: 20148
11:24:33:WU01:FS00:0xa7:        CWD: /var/lib/fahclient/work
11:24:33:WU01:FS00:0xa7:         OS: Linux 3.13.0-142-generic x86_64
11:24:33:WU01:FS00:0xa7:    OS Arch: AMD64
11:24:33:WU01:FS00:0xa7:********************************************************************************
11:24:33:WU01:FS00:0xa7:Project: 14052 (Run 9, Clone 28, Gen 4)
11:24:33:WU01:FS00:0xa7:Unit: 0x000000050002894b5ae3712c9540d900
11:24:33:WU01:FS00:0xa7:Reading tar file core.xml
First failure after download from cores.foldingathome.org
23:41:37:WU01:FS00:Assigned to work server 128.252.203.2
23:41:37:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 128.252.203.2
23:41:37:WU01:FS00:Connecting to 128.252.203.2:8080
23:41:37:WU01:FS00:Downloading 4.57MiB
23:41:39:WU01:FS00:Download complete
23:41:39:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13812 run:0 clone:309 gen:129 core:0xa7 unit:0x0000008c80fccb025a98192772874880
23:41:39:WU01:FS00:Downloading core from http://cores.foldingathome.org/Linux/AMD64/Core_a7.fah
23:41:39:WU01:FS00:Connecting to cores.foldingathome.org:80
23:41:40:WU01:FS00:FahCore a7: Downloading 7.64MiB
23:41:41:WU01:FS00:FahCore a7: Download complete
23:41:41:WU01:FS00:Valid core signature
23:41:41:WU01:FS00:Unpacked 18.42MiB to cores/cores.foldingathome.org/Linux/AMD64/Core_a7.fah/FahCore_a7
23:50:37:WU01:FS00:Starting
23:50:37:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 704 -lifeline 2051 -checkpoint 15 -np 2
23:50:37:WU01:FS00:Started FahCore on PID 7021
23:50:37:WU01:FS00:Core PID:7025
23:50:37:WU01:FS00:FahCore 0xa7 started
^[[93m23:50:38:WARNING:WU01:FS00:FahCore returned: FAILED_2 (1 = 0x1)^[[0m
Config
*********************** Log Started 2018-06-05T23:45:50Z ***********************
23:45:50:************************* Folding@home Client *************************
23:45:50:    Website: http://folding.stanford.edu/
23:45:50:  Copyright: (c) 2009-2014 Stanford University
23:45:50:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:45:50:       Args: --child --lifeline 2123 /etc/fahclient/config.xml --run-as
23:45:50:             fahclient --pid-file=/var/run/fahclient.pid --daemon
23:45:50:     Config: /etc/fahclient/config.xml
23:45:50:******************************** Build ********************************
23:45:50:    Version: 7.4.4
23:45:50:       Date: Mar 4 2014
23:45:50:       Time: 12:02:38
23:45:50:    SVN Rev: 4130
23:45:50:     Branch: fah/trunk/client
23:45:50:   Compiler: GNU 4.4.7
23:45:50:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
23:45:50:             -fno-unsafe-math-optimizations -msse2
23:45:50:   Platform: linux2 3.2.0-1-amd64
23:45:50:       Bits: 64
23:45:50:       Mode: Release
23:45:50:******************************* System ********************************
23:45:50:        CPU: Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz
23:45:50:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 2
23:45:50:       CPUs: 2
23:45:50:     Memory: 1.95GiB
23:45:50:Free Memory: 1.65GiB
23:45:50:    Threads: POSIX_THREADS
23:45:50: OS Version: 3.13
23:45:50:Has Battery: false
23:45:50: On Battery: false
23:45:50: UTC Offset: -4
23:45:50:        PID: 2125
23:45:50:        CWD: /var/lib/fahclient
23:45:50:         OS: Linux 3.13.0-149-generic x86_64
23:45:50:    OS Arch: AMD64
23:45:50:       GPUs: 1
23:45:50:      GPU 0: UNSUPPORTED: [Rage 128 Pro Ultra TF]
23:45:50:       CUDA: Not detected
23:45:50:***********************************************************************
23:45:50:<config>
23:45:50:  <!-- Client Control -->
23:45:50:  <fold-anon v='true'/>
23:45:50:
23:45:50:  <!-- Folding Slot Configuration -->
23:45:50:  <gpu v='false'/>
23:45:50:
23:45:50:  <!-- Slot Control -->
23:45:50:  <power v='full'/>
23:45:50:
23:45:50:  <!-- User Information -->
23:45:50:  <passkey v='********************************'/>
23:45:50:  <team v='11108'/>
23:45:50:  <user v='_r2w_ben'/>
23:45:50:
23:45:50:  <!-- Folding Slots -->
23:45:50:  <slot id='0' type='CPU'/>
23:45:50:</config>
Is it possible the AVX version of the core was placed in the file location where the SSE version should be? Were there compiler or dependency changes between 0.0.16 and 0.0.17?
bollix47
Re: FahCore_a7 0.0.17 fails to start on Ubuntu 14.04 LTS
Post by bollix47 »
The only dependencies I'm aware of are minimum versions of glibc (2.17) and glibc++ (3.4.15).
If you navigate using Nautilus or Files to the sub directory containing FahCore_a7 and open a terminal there (right click - Open in Terminal - assuming you have nautilus-open-terminal installed ... otherwise you might have to navigate there using Terminal and the cd command) ... then you can type:
ldd FahCore_a7
to see if any dependency errors exist.
If your versions are too old you may be able to install newer ones by downloading the needed deb file.
_r2w_ben wrote:Is it possible the AVX version of the core was placed in the file location where the SSE version should be?
Yes, it's possible. How did you download/install FAHCore_a7?
Similar to what "bollix47" said (but not the same) navigate using Nautilus or Files to the sub directory containing FahCore_a7 (it's actually /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/Core_a7.fah) and open a terminal there (right click - Open in Terminal - assuming you have nautilus-open-terminal installed ... otherwise you might have to navigate there using Terminal and the cd command) ... then you can type:
./FahCore_a7
to execute that program. It will print useful information to the terminal, including a line that either reads SMID:sse2 or SMID: (something else).
_r2w_ben
Post by _r2w_ben »
bollix47 wrote:The only dependencies I'm aware of are minimum versions of glibc (2.17) and glibc++ (3.4.15).
Here's the output from ldd FahCore_a7:
./FahCore_a7: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by ./FahCore_a7)
./FahCore_a7: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./FahCore_a7)
        linux-vdso.so.1 =>  (0x00007fff101fc000)
        libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f97431a1000)
        libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f9742f9d000)
        libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f9742c99000)
        libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f9742993000)
        libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f974277d000)
        libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f97423b4000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f9744730000)
bruce wrote:Yes, it's possible. How did you download/install FAHCore_a7?
The core was automatically downloaded by FAHclient as indicated in the second log snippet.
Manually starting FahCore_a7 produces the same two dependency missing lines as above.
Edit: This looks similar.
https://github.com/FoldingAtHome/fah-issues/issues/1147
Have you installed the updates for 14.04 (v3.13)? Those pre-reqs may be included as part of the Long Term Support process.
Have you installed the updates for 14.04 (v3.13) or even to 14.04.5? Those pre-reqs may be included as part of Ubuntu's Long Term Support process.
(I've had problems finding CXXABI/GLIBCXX in the past and I don't remember what update I installed that fixed them.)
_r2w_ben
Post by _r2w_ben »
bruce wrote:Have you installed the updates for 14.04 (v3.13)? Those pre-reqs may be included as part of the Long Term Support process.
Yes, Ubuntu version is 14.04.5 LTS and kernel is currently 3.13.0-149.
In the issue I linked to, jcoffland mentioned compiling with one version older to keep FAHClient compatible with 14.04.5 LTS.
To me it looks FahCore_a7 0.0.17 was built with a newer compiler. In my first log snippet, you can see 0.0.16 mentions "Compiler: GNU 4.9.2". Since it doesn't start now, I can't see the current Compiler version. It's possible that the same compiler was used but a code change or bugfix used a feature not present in CXXABI_1.3.7.
Is there an accurate list of supported Linux distros? The Linux system requirements looks outdated since it mentions Ubuntu 11.04.
In case it's useful, here's some strings output.
strings /usr/lib/x86_64-linux-gnu/libstdc++.so.6 | grep CXXABI
CXXABI_1.3
CXXABI_1.3.1
CXXABI_1.3.2
CXXABI_1.3.3
CXXABI_1.3.4
CXXABI_1.3.5
CXXABI_1.3.6
CXXABI_1.3.7
strings /usr/lib/x86_64-linux-gnu/libstdc++.so.6 | grep GLIBCXX
GLIBCXX_3.4
GLIBCXX_3.4.1
GLIBCXX_3.4.2
GLIBCXX_3.4.3
GLIBCXX_3.4.4
GLIBCXX_3.4.5
GLIBCXX_3.4.6
GLIBCXX_3.4.7
GLIBCXX_3.4.8
GLIBCXX_3.4.9
GLIBCXX_3.4.10
GLIBCXX_3.4.11
GLIBCXX_3.4.12
GLIBCXX_3.4.13
GLIBCXX_3.4.14
GLIBCXX_3.4.15
GLIBCXX_3.4.16
GLIBCXX_3.4.17
GLIBCXX_3.4.18
GLIBCXX_3.4.19
strings /var/lib/fahclient/cores/cores.foldingathome.org/Linux/AMD64/Core_a7.fah/FahCore_a7 | grep CXXABI_1.3.9
CXXABI_1.3.9
_ZdlPvm@@CXXABI_1.3.9
Newer compilers are potentially the problem. Newer compilers generally come with newer versions of the libraries, but there's a pretty good chance that you CAN upgrade the library on your version of Ubuntu without causing any difficulties.
The entry CXXABI_1.3.9 is required by GROMACS (which is used in FAHCore_a7), so you need upgrade your library to a version that contains that entry. I may have upgraded my library or I may have installed it separately -- I don't remember.
This issue was closed in an earlier version of FAHClient but apparently has come back.
bollix47
Post by bollix47 »
Open a terminal & try the following:
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update
sudo apt-get upgrade
Restart the folding client.
Source: viewtopic.php?p=292007#p292007 (see EDIT)
https://askubuntu.com/questions/575505/ ... this-error
EXT64
Post by EXT64 »
I just hacked on my old Ubuntu 12.04 install to get it working with A7 V17 (V16 worked fine). Updating the C++ libs and gcc to the Trusty/Xenial versions did the trick.
Yes, upgrade the library. See viewtopic.php?f=72&t=30851&p=301826#p301826
Or the distribution ... those library issues are the reasons why I upgraded my old server to 16.04 ...
