New FAH software stopped on core download
Please give us the details of your continuing problem, including the first couple of pages of your log and including a segment with the first error messages.
Have you added an exception to your security software allowing FAHClient.exe to download from the internet? (Windows firewall or Norton AV or whatever else you might use)
Are you connecting from behind a proxy server? (Not common at home, but perhaps at a place of business.)
OntosChalmer
Re: FAH stopped on core download
Post by OntosChalmer »
*********************** Log Started 2018-06-05T22:55:09Z ***********************
22:55:09:************************* Folding@home Client *************************
22:55:09:        Website: https://foldingathome.org/
22:55:09:      Copyright: (c) 2009-2018 foldingathome.org
22:55:09:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:55:09:           Args:
22:55:09:         Config: D:\Others\FAHData\config.xml
22:55:09:******************************** Build ********************************
22:55:09:        Version: 7.5.1
22:55:09:           Date: May 11 2018
22:55:09:           Time: 13:06:32
22:55:09:     Repository: Git
22:55:09:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:55:09:         Branch: master
22:55:09:       Compiler: Visual C++ 2008
22:55:09:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:55:09:       Platform: win32 10
22:55:09:           Bits: 32
22:55:09:           Mode: Release
22:55:09:******************************* System ********************************
22:55:09:            CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
22:55:09:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
22:55:09:           CPUs: 12
22:55:09:         Memory: 15.93GiB
22:55:09:    Free Memory: 12.47GiB
22:55:09:        Threads: WINDOWS_THREADS
22:55:09:     OS Version: 6.2
22:55:09:    Has Battery: false
22:55:09:     On Battery: false
22:55:09:     UTC Offset: 8
22:55:09:            PID: 8196
22:55:09:            CWD: D:\Others\FAHData
22:55:09:             OS: Windows 10 Enterprise
22:55:09:        OS Arch: AMD64
22:55:09:           GPUs: 1
22:55:09:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
22:55:09:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:9.2
22:55:09:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:397.93
22:55:09:  Win32 Service: false
22:55:09:***********************************************************************
22:55:09:<config>
22:55:09:  <!-- Network -->
22:55:09:  <proxy v=':8080'/>
22:55:09:
22:55:09:  <!-- Slot Control -->
22:55:09:  <power v='full'/>
22:55:09:
22:55:09:  <!-- User Information -->
22:55:09:  <passkey v='********************************'/>
22:55:09:  <team v='224497'/>
22:55:09:  <user v='OntosChalmer'/>
22:55:09:
22:55:09:  <!-- Folding Slots -->
22:55:09:  <slot id='0' type='CPU'>
22:55:09:    <paused v='true'/>
22:55:09:  </slot>
22:55:09:  <slot id='1' type='GPU'>
22:55:09:  </slot>
22:55:09:</config>
22:55:09:Trying to access database...
22:55:09:Successfully acquired database lock
22:55:09:Enabled folding slot 00: PAUSED cpu:11 (by user)
22:55:09:Enabled folding slot 01: PAUSED gpu:0:GP104 [GeForce GTX 1070] 6463 (by user)
22:56:53:FS00:Unpaused
22:56:53:FS01:Unpaused
22:56:53:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
22:56:53:WU00:FS00:Connecting to cores.foldingathome.org:80
22:56:53:ERROR:WU00:FS00:Exception: Failed reading core package header.
22:56:53:WU01:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah
22:56:53:WU01:FS01:Connecting to cores.foldingathome.org:80
22:56:54:ERROR:WU01:FS01:Exception: Failed reading core package header.
I think my ISP may be using a proxy server, though I'm not 100% sure about it. It's Singtel, a Singaporean ISP. I'm connecting from home, and I did not set up a proxy server personally. I've folded 311 WU on older versions before this happened.
AshleyJ14
Need help, stuck at Update_core?
Post by AshleyJ14 »
Hello! :D I am new to this forum. A couple days ago my CPUs we're working fine and now none of them are running. In the F@H Log it says "failed reading core package header." I have an i3-7100U. All help is appreciated. I already tried uninstalling and reinstalling the client, but it still does not work. Thanks
Edit: I am not on a proxy. Not sure tho. I have the box unchexed for proxy configuration
*********************** Log Started 2018-06-05T22:05:22Z ***********************
22:05:22:************************* Folding@home Client *************************
22:05:22:        Website: https://foldingathome.org/
22:05:22:      Copyright: (c) 2009-2018 foldingathome.org
22:05:22:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:05:22:           Args: --open-web-control
22:05:22:         Config: C:\Users\Ashley\AppData\Roaming\FAHClient\config.xml
22:05:22:******************************** Build ********************************
22:05:22:        Version: 7.5.1
22:05:22:           Date: May 11 2018
22:05:22:           Time: 13:06:32
22:05:22:     Repository: Git
22:05:22:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:05:22:         Branch: master
22:05:22:       Compiler: Visual C++ 2008
22:05:22:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:05:22:       Platform: win32 10
22:05:22:           Bits: 32
22:05:22:           Mode: Release
22:05:22:******************************* System ********************************
22:05:22:            CPU: Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz
22:05:22:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 9
22:05:22:           CPUs: 4
22:05:22:         Memory: 7.87GiB
22:05:22:    Free Memory: 3.09GiB
22:05:22:        Threads: WINDOWS_THREADS
22:05:22:     OS Version: 6.2
22:05:22:    Has Battery: true
22:05:22:     On Battery: false
22:05:22:     UTC Offset: -4
22:05:22:            PID: 74032
22:05:22:            CWD: C:\Users\Ashley\AppData\Roaming\FAHClient
22:05:22:             OS: Windows 10 Home
22:05:22:        OS Arch: AMD64
22:05:22:           GPUs: 0
22:05:22:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
22:05:22:                 specified module could not be found.
22:05:22:
22:05:22:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:22.20
22:05:22:  Win32 Service: false
22:05:22:***********************************************************************
22:05:22:<config>
22:05:22:  <!-- Network -->
22:05:22:  <proxy v=':8080'/>
22:05:22:
22:05:22:  <!-- Slot Control -->
22:05:22:  <power v='FULL'/>
22:05:22:
22:05:22:  <!-- User Information -->
22:05:22:  <team v='143016'/>
22:05:22:  <user v='JasminBeifus102'/>
22:05:22:
22:05:22:  <!-- Folding Slots -->
22:05:22:  <slot id='0' type='CPU'/>
22:05:22:  <slot id='1' type='CPU'>
22:05:22:    <cpus v='4'/>
22:05:22:  </slot>
22:05:22:  <slot id='2' type='CPU'>
22:05:22:  </slot>
22:05:22:  <slot id='3' type='CPU'>
22:05:22:  </slot>
22:05:22:</config>
22:05:22:Trying to access database...
22:05:22:Successfully acquired database lock
22:05:22:Enabled folding slot 00: READY cpu:1
22:05:22:Enabled folding slot 01: READY cpu:4
22:05:22:Enabled folding slot 02: READY cpu:4
22:05:22:Enabled folding slot 03: READY cpu:4
22:05:22:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/Core_a4.fah
22:05:22:WU00:FS00:Connecting to cores.foldingathome.org:80
22:05:22:WU01:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
22:05:23:WU01:FS01:Connecting to cores.foldingathome.org:80
22:05:23:ERROR:WU00:FS00:Exception: Failed reading core package header.
22:05:24:ERROR:WU01:FS01:Exception: Failed reading core package header.
22:05:29:16:127.0.0.1:New Web connection
22:06:23:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/Core_a4.fah
22:06:23:WU00:FS00:Connecting to cores.foldingathome.org:80
22:06:23:ERROR:WU00:FS00:Exception: Failed reading core package header.
22:06:23:WU01:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
22:06:23:WU01:FS01:Connecting to cores.foldingathome.org:80
22:06:23:ERROR:WU01:FS01:Exception: Failed reading core package header.
22:07:05:Saving configuration to config.xml
22:07:05:<config>
22:07:05:  <!-- Network -->
22:07:05:  <proxy v=':8080'/>
22:07:05:
22:07:05:  <!-- Slot Control -->
22:07:05:  <power v='FULL'/>
22:07:05:
22:07:05:  <!-- User Information -->
22:07:05:  <team v='143016'/>
22:07:05:  <user v='JasminBeifus102'/>
22:07:05:
22:07:05:  <!-- Folding Slots -->
22:07:05:  <slot id='1' type='CPU'>
22:07:05:    <cpus v='4'/>
22:07:05:  </slot>
22:07:05:</config>
22:07:05:WARNING:WU00:FS00:Slot ID 0 no longer exists, migrating to FS01
22:07:05:WARNING:WU02:FS02:Slot ID 2 no longer exists, migrating to FS01
22:07:05:WARNING:WU03:FS03:Slot ID 3 no longer exists, migrating to FS01
22:07:24:Saving configuration to config.xml
22:07:24:<config>
22:07:24:  <!-- Network -->
22:07:24:  <proxy v=':8080'/>
22:07:24:
22:07:24:  <!-- Slot Control -->
22:07:24:  <power v='FULL'/>
22:07:24:
22:07:24:  <!-- User Information -->
22:07:24:  <team v='143016'/>
22:07:24:  <user v='JasminBeifus102'/>
22:07:24:
22:07:24:  <!-- Folding Slots -->
22:07:24:  <slot id='1' type='CPU'>
22:07:24:    <cpus v='4'/>
22:07:24:  </slot>
22:07:24:</config>
22:08:00:WU00:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/Core_a4.fah
22:08:00:WU00:FS01:Connecting to cores.foldingathome.org:80
22:08:00:ERROR:WU00:FS01:Exception: Failed reading core package header.
22:08:00:WU01:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
22:08:00:WU01:FS01:Connecting to cores.foldingathome.org:80
22:08:00:ERROR:WU01:FS01:Exception: Failed reading core package header.
22:08:13:FS01:Paused
22:08:17:FS01:Unpaused
22:08:17:FS01:Finishing
22:10:37:WU00:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/Core_a4.fah
22:10:37:WU00:FS01:Connecting to cores.foldingathome.org:80
22:10:37:ERROR:WU00:FS01:Exception: Failed reading core package header.
22:10:37:WU01:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
22:10:37:WU01:FS01:Connecting to cores.foldingathome.org:80
22:10:37:ERROR:WU01:FS01:Exception: Failed reading core package header.
22:14:51:WU00:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/Core_a4.fah
22:14:51:WU00:FS01:Connecting to cores.foldingathome.org:80
22:14:51:ERROR:WU00:FS01:Exception: Failed reading core package header.
22:14:52:WU01:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
22:14:52:WU01:FS01:Connecting to cores.foldingathome.org:80
22:14:52:ERROR:WU01:FS01:Exception: Failed reading core package header.
22:15:21:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
22:21:42:WU00:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/Core_a4.fah
22:21:42:WU00:FS01:Connecting to cores.foldingathome.org:80
22:21:42:ERROR:WU00:FS01:Exception: Failed reading core package header.
22:21:43:WU01:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
22:21:43:WU01:FS01:Connecting to cores.foldingathome.org:80
22:21:43:ERROR:WU01:FS01:Exception: Failed reading core package header.
22:32:48:WU00:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/Core_a4.fah
22:32:48:WU00:FS01:Connecting to cores.foldingathome.org:80
22:32:48:ERROR:WU00:FS01:Exception: Failed reading core package header.
22:32:49:WU01:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
22:32:49:WU01:FS01:Connecting to cores.foldingathome.org:80
22:32:50:ERROR:WU01:FS01:Exception: Failed reading core package header.
RAF_Moz_work
Post by RAF_Moz_work »
I have the same problem on over 20 machines for the last few days. Nothing changed on my end.
Edit: My browser downloads a file from this uri: http://cores.foldingathome.org/Win32/AM ... ore_a7.fah
*********************** Log Started 2018-06-05T09:38:22Z ***********************
09:38:22:************************* Folding@home Client *************************
09:38:22:      Website: https://foldingathome.org/
09:38:22:    Copyright: (c) 2009-2018 foldingathome.org
09:38:22:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:38:22:         Args:
09:38:22:       Config: C:\FAH_Data\config.xml
09:38:22:******************************** Build ********************************
09:38:22:      Version: 7.5.1
09:38:22:         Date: May 11 2018
09:38:22:         Time: 13:06:32
09:38:22:   Repository: Git
09:38:22:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
09:38:22:       Branch: master
09:38:22:     Compiler: Visual C++ 2008
09:38:22:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:38:22:     Platform: win32 10
09:38:22:         Bits: 32
09:38:22:         Mode: Release
09:38:22:******************************* System ********************************
09:38:22:          CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
09:38:22:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
09:38:22:         CPUs: 8
09:38:22:       Memory: 7.88GiB
09:38:22:  Free Memory: 5.41GiB
09:38:22:      Threads: WINDOWS_THREADS
09:38:22:   OS Version: 6.1
09:38:22:  Has Battery: false
09:38:22:   On Battery: false
09:38:22:   UTC Offset: 2
09:38:22:          PID: 6368
09:38:22:          CWD: C:\Windows\system32
09:38:22:           OS: Windows 7 Professional
09:38:22:      OS Arch: AMD64
09:38:22:         GPUs: 0
09:38:22:         CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
09:38:22:               specified module could not be found.
09:38:22:
09:38:22:Win32 Service: true
09:38:22:***********************************************************************
09:38:22:<config>
09:38:22:  <service-description v='Folding@home Client'/>
09:38:22:  <service-restart v='true'/>
09:38:22:  <service-restart-delay v='5000'/>
09:38:22:
09:38:22:  <!-- Client Control -->
09:38:22:  <client-threads v='6'/>
09:38:22:  <cycle-rate v='4'/>
09:38:22:  <cycles v='-1'/>
09:38:22:  <data-directory v='.'/>
09:38:22:  <disable-sleep-when-active v='true'/>
09:38:22:  <exec-directory v='C:\FAH_Program\FAHClient'/>
09:38:22:  <exit-when-done v='false'/>
09:38:22:  <fold-anon v='false'/>
09:38:22:  <open-web-control v='false'/>
09:38:22:
09:38:22:  <!-- Configuration -->
09:38:22:  <config-rotate v='true'/>
09:38:22:  <config-rotate-dir v='configs'/>
09:38:22:  <config-rotate-max v='16'/>
09:38:22:
09:38:22:  <!-- Debugging -->
09:38:22:  <assignment-servers>
09:38:22:    assign1.foldingathome.org:8080 assign2.foldingathome.org:80
09:38:22:  </assignment-servers>
09:38:22:  <auth-as v='true'/>
09:38:22:  <capture-directory v='capture'/>
09:38:22:  <capture-on-error v='false'/>
09:38:22:  <capture-packets v='false'/>
09:38:22:  <capture-requests v='false'/>
09:38:22:  <capture-responses v='false'/>
09:38:22:  <capture-sockets v='false'/>
09:38:22:  <core-exec v='FahCore_$type'/>
09:38:22:  <core-wrapper-exec v='FAHCoreWrapper'/>
09:38:22:  <debug-sockets v='false'/>
09:38:22:  <exception-locations v='true'/>
09:38:22:  <stack-traces v='false'/>
09:38:22:
09:38:22:  <!-- Error Handling -->
09:38:22:  <max-slot-errors v='10'/>
09:38:22:  <max-unit-errors v='5'/>
09:38:22:
09:38:22:  <!-- Folding Core -->
09:38:22:  <checkpoint v='15'/>
09:38:22:  <core-dir v='cores'/>
09:38:22:  <core-priority v='idle'/>
09:38:22:  <cpu-affinity v='false'/>
09:38:22:  <cpu-usage v='100'/>
09:38:22:  <gpu-usage v='100'/>
09:38:22:  <no-assembly v='false'/>
09:38:22:
09:38:22:  <!-- Folding Slot Configuration -->
09:38:22:  <cause v='ANY'/>
09:38:22:  <client-subtype v='STDCLI'/>
09:38:22:  <client-type v='normal'/>
09:38:22:  <cpu-species v='X86_PENTIUM_II'/>
09:38:22:  <cpu-type v='AMD64'/>
09:38:22:  <cpus v='-1'/>
09:38:22:  <disable-viz v='false'/>
09:38:22:  <gpu v='true'/>
09:38:22:  <max-packet-size v='normal'/>
09:38:22:  <os-species v='WIN_7'/>
09:38:22:  <os-type v='WIN32'/>
09:38:22:  <project-key v='0'/>
09:38:22:  <smp v='true'/>
09:38:22:
09:38:22:  <!-- GUI -->
09:38:22:  <gui-enabled v='true'/>
09:38:22:
09:38:22:  <!-- HTTP Server -->
09:38:22:  <allow v='127.0.0.1, 10.0.1.151'/>
09:38:22:  <connection-timeout v='60'/>
09:38:22:  <deny v='0/0'/>
09:38:22:  <http-addresses v='0:7396'/>
09:38:22:  <https-addresses v=''/>
09:38:22:  <max-connect-time v='900'/>
09:38:22:  <max-connections v='800'/>
09:38:22:  <max-request-length v='52428800'/>
09:38:22:  <min-connect-time v='300'/>
09:38:22:
09:38:22:  <!-- Logging -->
09:38:22:  <log v='log.txt'/>
09:38:22:  <log-color v='false'/>
09:38:22:  <log-crlf v='true'/>
09:38:22:  <log-date v='false'/>
09:38:22:  <log-date-periodically v='21600'/>
09:38:22:  <log-domain v='false'/>
09:38:22:  <log-header v='true'/>
09:38:22:  <log-level v='true'/>
09:38:22:  <log-no-info-header v='true'/>
09:38:22:  <log-redirect v='false'/>
09:38:22:  <log-rotate v='true'/>
09:38:22:  <log-rotate-dir v='logs'/>
09:38:22:  <log-rotate-max v='16'/>
09:38:22:  <log-short-level v='false'/>
09:38:22:  <log-simple-domains v='true'/>
09:38:22:  <log-thread-id v='false'/>
09:38:22:  <log-thread-prefix v='true'/>
09:38:22:  <log-time v='true'/>
09:38:22:  <log-to-screen v='true'/>
09:38:22:  <log-truncate v='false'/>
09:38:22:  <verbosity v='5'/>
09:38:22:
09:38:22:  <!-- Network -->
09:38:22:  <proxy v=':8080'/>
09:38:22:  <proxy-enable v='false'/>
09:38:22:  <proxy-pass v=''/>
09:38:22:  <proxy-user v=''/>
09:38:22:
09:38:22:  <!-- Process Control -->
09:38:22:  <child v='false'/>
09:38:22:  <daemon v='false'/>
09:38:22:  <pid v='false'/>
09:38:22:  <pid-file v='Folding@home Client.pid'/>
09:38:22:  <respawn v='false'/>
09:38:22:  <service v='true'/>
09:38:22:
09:38:22:  <!-- Remote Command Server -->
09:38:22:  <command-address v='0.0.0.0'/>
09:38:22:  <command-allow-no-pass v='127.0.0.1, 10.0.1.151'/>
09:38:22:  <command-deny-no-pass v='0/0'/>
09:38:22:  <command-enable v='true'/>
09:38:22:  <command-port v='36330'/>
09:38:22:
09:38:22:  <!-- Slot Control -->
09:38:22:  <idle v='false'/>
09:38:22:  <max-shutdown-wait v='60'/>
09:38:22:  <pause-on-battery v='true'/>
09:38:22:  <pause-on-start v='false'/>
09:38:22:  <paused v='false'/>
09:38:22:  <power v='full'/>
09:38:22:
09:38:22:  <!-- User Information -->
09:38:22:  <machine-id v='0'/>
09:38:22:  <passkey v='********************************'/>
09:38:22:  <team v='39340'/>
09:38:22:  <user v='RAF_Moz_work'/>
09:38:22:
09:38:22:  <!-- Web Server -->
09:38:22:  <web-allow v='127.0.0.1'/>
09:38:22:  <web-deny v='0/0'/>
09:38:22:  <web-enable v='true'/>
09:38:22:
09:38:22:  <!-- Web Server Sessions -->
09:38:22:  <session-cookie v='sid'/>
09:38:22:  <session-lifetime v='86400'/>
09:38:22:  <session-timeout v='3600'/>
09:38:22:
09:38:22:  <!-- Work Unit Control -->
09:38:22:  <dump-after-deadline v='true'/>
09:38:22:  <max-queue v='16'/>
09:38:22:  <max-units v='0'/>
09:38:22:  <next-unit-percentage v='99'/>
09:38:22:  <stall-detection-enabled v='false'/>
09:38:22:  <stall-percent v='5'/>
09:38:22:  <stall-timeout v='1800'/>
09:38:22:
09:38:22:  <!-- Folding Slots -->
09:38:22:  <slot id='0' type='CPU'/>
09:38:22:</config>
09:38:22:Trying to access database...
09:38:22:Upgrading database schema from version 13 to 16
09:38:22:Successfully acquired database lock
09:38:22:Enabled folding slot 00: READY cpu:8
09:38:22:ERROR:Exception: Failed to register systray icon: Success
09:38:22:Started thread 5 on PID 6368
09:38:22:Started thread 8 on PID 6368
09:38:22:Started thread 6 on PID 6368
09:38:22:Started thread 4 on PID 6368
09:38:22:Started thread 9 on PID 6368
09:38:22:Started thread 7 on PID 6368
09:38:22:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
09:38:22:WU00:FS00:Connecting to cores.foldingathome.org:80
09:38:23:ERROR:WU00:FS00:Exception: Failed reading core package header.
09:38:23:1:127.0.0.1 GET /ping?_=1528191503715&callback=jQuery1900667554992159449_1528191503714
09:38:24:2:127.0.0.1 GET /?nocache=0.04229814848216118
09:38:24:3:127.0.0.1 GET /css/normalize.css
09:38:24:4:127.0.0.1 GET /js/libs/jquery.selectbox-0.2.js
09:38:24:5:127.0.0.1 GET /js/jquery-1.10.2.min.js
09:38:24:6:127.0.0.1 GET /css/main.css
09:38:24:7:127.0.0.1 GET /js/main.js
09:38:24:7:127.0.0.1:New Web connection
09:38:24:8:127.0.0.1 GET /js/intercom.min.js
09:38:25:9:127.0.0.1 GET /images/facebook.png
09:38:25:10:127.0.0.1 GET /images/twitter.png
09:38:25:11:127.0.0.1 GET /images/mail.png
09:38:25:12:127.0.0.1 GET /images/report-bug.png
09:38:25:13:127.0.0.1 GET /images/template/bg.jpg
09:38:25:14:127.0.0.1 GET /images/template/logo_folding_home.png
09:38:26:15:127.0.0.1 GET /api/updates/set?_=1528191505169&sid=0af62c0975a2995b482b2d89a23d4de7&update_id=0&update_path=/api/basic&update_rate=1
09:38:26:16:127.0.0.1 GET /api/updates/set?_=1528191505170&sid=0af62c0975a2995b482b2d89a23d4de7&update_id=1&update_path=/api/slots&update_rate=1
09:38:26:17:127.0.0.1 GET /api/configured?_=1528191505171&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:26:18:127.0.0.1 GET /images/template/input_radio.png
09:38:26:19:127.0.0.1 GET /images/template/button_bg.png
09:38:27:20:127.0.0.1 GET /images/template/ui-progress-bg.png
09:38:27:21:127.0.0.1 GET /images/template/ui-icon-slider.png
09:38:27:22:127.0.0.1 GET /api/updates?_=1528191505172&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:27:22:127.0.0.1 GET /api/updates?_=1528191505176&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:27:23:127.0.0.1 GET /images/template/ui-bg-slider.png
09:38:27:24:127.0.0.1 GET /images/template/select-icons.png
09:38:28:25:127.0.0.1 GET /api/updates?_=1528191505177&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:29:25:127.0.0.1 GET /api/updates?_=1528191505178&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:30:22:127.0.0.1 GET /api/updates?_=1528191505179&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:32:25:127.0.0.1 GET /api/updates?_=1528191505180&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:33:22:127.0.0.1 GET /api/updates?_=1528191505181&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:35:25:127.0.0.1 GET /api/updates?_=1528191505182&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:36:22:127.0.0.1 GET /api/updates?_=1528191505183&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:38:25:127.0.0.1 GET /api/updates?_=1528191505184&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:41:25:127.0.0.1 GET /api/updates?_=1528191505185&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:44:22:127.0.0.1 GET /api/updates?_=1528191505186&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:46:25:127.0.0.1 GET /api/updates?_=1528191505187&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:49:25:127.0.0.1 GET /api/updates?_=1528191505188&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:52:22:127.0.0.1 GET /api/updates?_=1528191505189&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:54:25:127.0.0.1 GET /api/updates?_=1528191505190&sid=0af62c0975a2995b482b2d89a23d4de7
09:38:57:25:127.0.0.1 GET /api/updates?_=1528191505191&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:00:22:127.0.0.1 GET /api/updates?_=1528191505192&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:02:25:127.0.0.1 GET /api/updates?_=1528191505193&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:05:25:127.0.0.1 GET /api/updates?_=1528191505194&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:08:22:127.0.0.1 GET /api/updates?_=1528191505195&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:10:25:127.0.0.1 GET /api/updates?_=1528191505196&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:13:25:127.0.0.1 GET /api/updates?_=1528191505197&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:16:Started thread 10 on PID 6368
09:39:16:22:127.0.0.1 GET /api/updates?_=1528191505198&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:19:25:127.0.0.1 GET /api/updates?_=1528191505199&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:20:25:127.0.0.1 GET /api/updates?_=1528191505200&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:22:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
09:39:22:WU00:FS00:Connecting to cores.foldingathome.org:80
09:39:22:ERROR:WU00:FS00:Exception: Failed reading core package header.
09:39:22:22:127.0.0.1 GET /api/updates?_=1528191505201&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:23:25:127.0.0.1 GET /api/updates?_=1528191505202&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:25:22:127.0.0.1 GET /api/updates?_=1528191505203&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:26:25:127.0.0.1 GET /api/updates?_=1528191505204&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:28:22:127.0.0.1 GET /api/updates?_=1528191505205&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:29:25:127.0.0.1 GET /api/updates?_=1528191505206&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:31:22:127.0.0.1 GET /api/updates?_=1528191505207&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:32:25:127.0.0.1 GET /api/updates?_=1528191505208&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:34:22:127.0.0.1 GET /api/updates?_=1528191505209&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:35:25:127.0.0.1 GET /api/updates?_=1528191505210&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:37:22:127.0.0.1 GET /api/updates?_=1528191505211&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:38:25:127.0.0.1 GET /api/updates?_=1528191505212&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:40:22:127.0.0.1 GET /api/updates?_=1528191505213&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:41:25:127.0.0.1 GET /api/updates?_=1528191505214&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:43:22:127.0.0.1 GET /api/updates?_=1528191505215&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:46:22:127.0.0.1 GET /api/updates?_=1528191505216&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:49:22:127.0.0.1 GET /api/updates?_=1528191505217&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:52:25:127.0.0.1 GET /api/updates?_=1528191505218&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:54:25:127.0.0.1 GET /api/updates?_=1528191505219&sid=0af62c0975a2995b482b2d89a23d4de7
09:39:57:22:127.0.0.1 GET /api/updates?_=1528191505220&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:00:25:127.0.0.1 GET /api/updates?_=1528191505221&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:03:25:127.0.0.1 GET /api/updates?_=1528191505222&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:06:22:127.0.0.1 GET /api/updates?_=1528191505223&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:08:25:127.0.0.1 GET /api/updates?_=1528191505224&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:11:25:127.0.0.1 GET /api/updates?_=1528191505225&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:14:22:127.0.0.1 GET /api/updates?_=1528191505226&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:17:25:127.0.0.1 GET /api/updates?_=1528191505227&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:18:25:127.0.0.1 GET /api/updates?_=1528191505228&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:20:22:127.0.0.1 GET /api/updates?_=1528191505229&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:21:25:127.0.0.1 GET /api/updates?_=1528191505230&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:23:22:127.0.0.1 GET /api/updates?_=1528191505231&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:24:25:127.0.0.1 GET /api/updates?_=1528191505232&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:26:22:127.0.0.1 GET /api/updates?_=1528191505233&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:27:25:127.0.0.1 GET /api/updates?_=1528191505234&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:29:22:127.0.0.1 GET /api/updates?_=1528191505235&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:30:25:127.0.0.1 GET /api/updates?_=1528191505236&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:32:22:127.0.0.1 GET /api/updates?_=1528191505237&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:33:25:127.0.0.1 GET /api/updates?_=1528191505238&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:35:22:127.0.0.1 GET /api/updates?_=1528191505239&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:38:22:127.0.0.1 GET /api/updates?_=1528191505240&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:41:22:127.0.0.1 GET /api/updates?_=1528191505241&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:43:25:127.0.0.1 GET /api/updates?_=1528191505242&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:46:25:127.0.0.1 GET /api/updates?_=1528191505243&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:49:22:127.0.0.1 GET /api/updates?_=1528191505244&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:51:25:127.0.0.1 GET /api/updates?_=1528191505245&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:54:25:127.0.0.1 GET /api/updates?_=1528191505246&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:57:22:127.0.0.1 GET /api/updates?_=1528191505247&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:59:25:127.0.0.1 GET /api/updates?_=1528191505248&sid=0af62c0975a2995b482b2d89a23d4de7
09:40:59:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
09:40:59:WU00:FS00:Connecting to cores.foldingathome.org:80
09:40:59:ERROR:WU00:FS00:Exception: Failed reading core package header.
09:41:01:22:127.0.0.1 GET /api/updates?_=1528191505249&sid=0af62c0975a2995b482b2d89a23d4de7
09:41:02:22:127.0.0.1 GET /api/updates?_=1528191505250&sid=0af62c0975a2995b482b2d89a23d4de7
09:43:36:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
09:43:36:WU00:FS00:Connecting to cores.foldingathome.org:80
09:43:37:ERROR:WU00:FS00:Exception: Failed reading core package header.
09:45:39:Started thread 11 on PID 6368
09:47:51:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
09:47:51:WU00:FS00:Connecting to cores.foldingathome.org:80
09:47:51:ERROR:WU00:FS00:Exception: Failed reading core package header.
09:54:42:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
09:54:42:WU00:FS00:Connecting to cores.foldingathome.org:80
09:54:42:ERROR:WU00:FS00:Exception: Failed reading core package header.
10:05:48:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
10:05:48:WU00:FS00:Connecting to cores.foldingathome.org:80
10:05:48:ERROR:WU00:FS00:Exception: Failed reading core package header.
10:23:44:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
10:23:44:WU00:FS00:Connecting to cores.foldingathome.org:80
10:23:45:ERROR:WU00:FS00:Exception: Failed reading core package header.
10:52:47:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
10:52:47:WU00:FS00:Connecting to cores.foldingathome.org:80
10:52:47:ERROR:WU00:FS00:Exception: Failed reading core package header.
11:39:45:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
11:39:45:WU00:FS00:Connecting to cores.foldingathome.org:80
11:39:46:ERROR:WU00:FS00:Exception: Failed reading core package header.
12:55:46:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
12:55:46:WU00:FS00:Connecting to cores.foldingathome.org:80
12:55:47:ERROR:WU00:FS00:Exception: Failed reading core package header.
14:58:46:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
14:58:46:WU00:FS00:Connecting to cores.foldingathome.org:80
14:58:46:ERROR:WU00:FS00:Exception: Failed reading core package header.
******************************* Date: 2018-06-05 *******************************
18:17:47:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
18:17:47:WU00:FS00:Connecting to cores.foldingathome.org:80
18:17:47:ERROR:WU00:FS00:Exception: Failed reading core package header.
23:39:47:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
23:39:47:WU00:FS00:Connecting to cores.foldingathome.org:80
23:39:47:ERROR:WU00:FS00:Exception: Failed reading core package header.
******************************* Date: 2018-06-06 *******************************
05:39:47:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
05:39:47:WU00:FS00:Connecting to cores.foldingathome.org:80
05:39:47:ERROR:WU00:FS00:Exception: Failed reading core package header.
bollix47
Post by bollix47 »
This appears to be occurring with all non-standard installations.
Basically what is needed is a new core tree in your Work Directory.
A possible workaround until the automatic process is fixed:
There should be a tree in your work folder's sub directory called cores that looks like:
\fahwebx.stanford.edu\cores\Win32\AMD64\AVX\Core_a7.fah/FahCore_a7.exe
The new structure looks like:
\cores.foldingathome.org\Win32\AMD64\AVX\Core_a7.fah\FahCore_a7.exe
The new structure may already be in your working directory but without FahCore_a7.exe. Otherwise you would have to create the new structure.
Either way once you have the new structure under your working directory\cores you may be able to simply copy FahCore_a7.exe to the new tree under Core_a7.fah and restart folding. (mine also shows a file called libfftw3f-3.dll with the same date and time as FahCore_a7.exe so if you have that, copy it too)
Disclaimer: I had no problems with getting the core because my installs are default ... so no guarantees that the above will work and using my method is at your own risk.
OntosChalmer
bollix47 wrote:This appears to be occurring with all non-standard installations.
I noticed that the cores folder was missing from my AppData folder, so I created four folders:
(I created the first two as I reviewed my old install on my laptop that doesn't work, but still has the fahx.standord.edu folders)
..\FAHClient\cores\cores.foldingathome.org\cores\Win32\AMD64\AVX\Core_a7.fah
..\FAHClient\cores\cores.foldingathome.org\cores\Win32\AMD64\NVIDIA\Fermi\Core_21.fah
..\FAHClient\cores\cores.foldingathome.org\Win32\AMD64\AVX\Core_a7.fah
..\FAHClient\cores\cores.foldingathome.org\Win32\AMD64\NVIDIA\Fermi\Core_21.fah
Creating all four subfolders manually did not solve the issue.
bollix47
Post by bollix47 »
@OntosChalmer
Did you copy the file(s) from the old tree to the new one? It's not just a matter of creating the new tree, you need to copy the .exe and any .dll from the old structure to the new one.
Also, where was your old Data Directory? If it was under AppData\FAHClient and was working previously then there would have to have been a cores sub directory.
OntosChalmer
bollix47 wrote:@OntosChalmer
I ended up copying the executables (and DLLs) from my old laptop installation into the new folders. The old laptop installation isn't working, but didn't have its AppData cleared out yet.
Sadly, this hasn't fixed the issue as of now.
bollix47
Post by bollix47 »
There may be some security problem involved with using the new structure. i.e. The cores in the old location had already been allowed thru but the ones in the new location have not.
Another option would be to backup your config.xml file and completely uninstall Folding@home including Data and then reinstall without changing any defaults (other than your name, passkey & team #). Again, I've had no need to try that so I can't guarantee it will work.
OntosChalmer
@bollix47
This didn't work either. Thanks for the effort, though.
bollix47
Post by bollix47 »
Just to ensure the download/unpack routines still worked for me I decided to start a CPU slot on a heretofore GPU only Windows setup:
13:51:55:WU01:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
13:51:55:WU01:FS01:Connecting to cores.foldingathome.org:80
13:51:56:WU01:FS01:FahCore a7: Downloading 6.82MiB
13:51:57:WU01:FS01:FahCore a7: Download complete
13:51:57:WU01:FS01:Valid core signature
13:51:57:WU01:FS01:Unpacked 20.16MiB to cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe
13:51:57:WU01:FS01:Unpacked 2.64MiB to cores/cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah/libfftw3f-3.dll
13:51:57:WU01:FS01:Starting
As you can see the core downloaded and unpacked just fine, as it has for most people. Do you have some special security software or maybe a significant setting in the windows-supplied security software? I'm running out of ideas but it has to be something on your setup (one possibility is a permission problem) that most of us don't have or possibly something that's missing on your setup. Does the windows user you're using to fold have Admin rights? That probably isn't necessary but I will keep trying to narrow down the exact cause. :?
OntosChalmer
@bollix47
I'll be sodding damned.
I tried a different solution. My desktop had wireless functionality, so I decided, on a hunch, to tether my phone's 4G connection to my desktop.
17:16:20:WU00:FS00:Downloading core from http://cores.foldingathome.org/Win32/AMD64/AVX/Core_a7.fah
17:16:20:WU00:FS00:Connecting to cores.foldingathome.org:80
17:16:20:WU01:FS01:Downloading core from http://cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah
17:16:20:WU01:FS01:Connecting to cores.foldingathome.org:80
17:16:24:WU00:FS00:FahCore a7: Downloading 6.82MiB
17:16:24:WU01:FS01:FahCore 21: Downloading 3.47MiB
17:16:24:WU01:FS01:FahCore 21: Download complete
17:16:25:WU00:FS00:FahCore a7: Download complete
17:16:25:WU01:FS01:Valid core signature
17:16:25:WU01:FS01:Unpacked 11.80MiB to cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe
17:16:25:WU01:FS01:Starting
One possible issue is that I am using Cloudflare's DNS (1.1.1.1) and Google DNS (8.8.8.8) as my DNS servers. I didn't do that on my phone. I don't believe that it may be the issue, but it's the only difference I know. My phone uses the same ISP as my home internet, so it's probably not a proxy server issue.
Once this set of WUs finish, I'll make a note if future WUs have issues. For now, it's fixed, but I think I'll KIV it.
bollix47
Post by bollix47 »
I don't know anything about 1.1.1.1. It could be they're not up-to-date with the new addesses but in case it helps I use 8.8.8.8 and 8.8.4.4 and have not had a DNS problem.
It looks like you've solved or are close to solving your problem ... thanks for letting us know.
Hopefully this may help some of the others.
So you guys are saying there's a potential problem with one or more DNS servers. At least that's an unexplored possibility.
How about doing a tracert cores.foldingathome.org (or "traceroute ..." from Linux or MacOS) from a machine that is failing. In my case, it successfully ends at 65.254.110.241 (after 17 hops).
In a previous discussion of the same issue, we asked folks to open the full path to a FAHcore.exe in their browser and they were able to download the file. Nevertheless, one report said:
Tried downloading http://cores.foldingathome.org/Win32/AM ... ore_21.fah in my browser and it does download it. But the FAH client won't.
The only reason that a browser can download a file and some other .exe cannot is because known browsers are granted an automatic exception through the firewall. Since FAHClient.exe is BLOCKED from downloading the same file is that it's not on their exception list. FAHClient.exe works just like a browser and needs the same internet permissions as a browser but the people who provide firewalls don't know that. You have to do it yourself.
OntosChalmer
An update. Further WUs have downloaded and been executed successfully. The issue, for me, seems to be fixed. At least until there's another core update.
I tried doing a tracert using both 1.1.1.1 and 8.8.8.8. No issues with either tracert to cores.foldingathome.org. Strange.
