thanatos2k
Posts: 11 Joined: Thu Aug 11, 2016 7:46 pm
Post
by thanatos2k » Fri Jun 08, 2018 3:17 am
New install just hangs after this point:
*********************** Log Started 2018-06-08T03:10:47Z ***********************
03:10:47:************************* Folding@home Client *************************
03:10:47: Website: https://foldingathome.org/
03:10:47: Copyright: (c) 2009-2018 foldingathome.org
03:10:47: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:10:47: Args: --open-web-control
03:10:47: Config: <none>
03:10:47:******************************** Build ********************************
03:10:47: Version: 7.5.1
03:10:47: Date: May 11 2018
03:10:47: Time: 13:06:32
03:10:47: Repository: Git
03:10:47: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
03:10:47: Branch: master
03:10:47: Compiler: Visual C++ 2008
03:10:47: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:10:47: Platform: win32 10
03:10:47: Bits: 32
03:10:47: Mode: Release
03:10:47:******************************* System ********************************
03:10:47: CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
03:10:47: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
03:10:47: CPUs: 8
03:10:47: Memory: 15.96GiB
03:10:47: Free Memory: 11.81GiB
03:10:47: Threads: WINDOWS_THREADS
03:10:47: OS Version: 6.2
03:10:47: Has Battery: false
03:10:47: On Battery: false
03:10:47: UTC Offset: -5
03:10:47: PID: 14616
03:10:47: CWD: d:\fahdata
03:10:47: OS: Windows 10 Enterprise
03:10:47: OS Arch: AMD64
03:10:47: GPUs: 0
03:10:47:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:9.2
03:10:47: OpenCL: Not detected
03:10:47:Win32 Service: false
03:10:47:***********************************************************************
03:10:47:<config>
03:10:47: <!-- Folding Slots -->
03:10:47:</config>
03:10:47:Connecting to assign1.foldingathome.org:8080
03:10:48:Updated GPUs.txt
03:10:48:Read GPUs.txt
03:10:48:Trying to access database...
03:10:48:Successfully acquired database lock
03:10:48:Enabled folding slot 00: PAUSED cpu:6 (not configured)
If I paste in my config file from another rig, still hangs at the same point.
*********************** Log Started 2018-06-08T03:14:59Z ***********************
03:14:59:************************* Folding@home Client *************************
03:14:59: Website: https://foldingathome.org/
03:14:59: Copyright: (c) 2009-2018 foldingathome.org
03:14:59: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:14:59: Args: --open-web-control
03:14:59: Config: d:\fahdata\config.xml
03:14:59:******************************** Build ********************************
03:14:59: Version: 7.5.1
03:14:59: Date: May 11 2018
03:14:59: Time: 13:06:32
03:14:59: Repository: Git
03:14:59: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
03:14:59: Branch: master
03:14:59: Compiler: Visual C++ 2008
03:14:59: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:14:59: Platform: win32 10
03:14:59: Bits: 32
03:14:59: Mode: Release
03:14:59:******************************* System ********************************
03:14:59: CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
03:14:59: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
03:14:59: CPUs: 8
03:14:59: Memory: 15.96GiB
03:14:59: Free Memory: 11.78GiB
03:14:59: Threads: WINDOWS_THREADS
03:14:59: OS Version: 6.2
03:14:59: Has Battery: false
03:14:59: On Battery: false
03:14:59: UTC Offset: -5
03:14:59: PID: 6956
03:14:59: CWD: d:\fahdata
03:14:59: OS: Windows 10 Enterprise
03:14:59: OS Arch: AMD64
03:14:59: GPUs: 1
03:14:59: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM206 [GeForce GTX 950] 1572
03:14:59:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:9.2
03:14:59: OpenCL: Not detected
03:14:59:Win32 Service: false
03:14:59:***********************************************************************
03:14:59:<config>
03:14:59: <!-- Folding Core -->
03:14:59: <checkpoint v='30'/>
03:14:59:
03:14:59: <!-- Network -->
03:14:59: <proxy v=':8080'/>
03:14:59:
03:14:59: <!-- Slot Control -->
03:14:59: <pause-on-start v='true'/>
03:14:59: <power v='FULL'/>
03:14:59:
03:14:59: <!-- User Information -->
03:14:59: <passkey v='********************************'/>
03:14:59: <team v='111065'/>
03:14:59: <user v='thanatos2k'/>
03:14:59:
03:14:59: <!-- Folding Slots -->
03:14:59: <slot id='1' type='GPU'/>
03:14:59: <slot id='0' type='CPU'/>
03:14:59:</config>
03:14:59:Trying to access database...
03:14:59:Successfully acquired database lock
Currently running 398.11, but have tried with 397.93, 397.64, 391.35, and 391.01.
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Fri Jun 08, 2018 5:55 am
The error OpenCL: Not detected suggests that you have not installed the right drivers for you GPU. The drivers installed by Microsoft do not include support for OpenCL. If you download the same or newer version directly from NVidia, they'll include OpenCL.
I'm not sure about the message Enabled folding slot 00: PAUSED cpu:6 (not configured) . Restarting FAHClient should configure the CPU.
thanatos2k
Post
by thanatos2k » Fri Jun 08, 2018 12:36 pm
I'm only installing the drivers from nVidia directly, and all the version I've listed are downloaded from them directly, doing clean installs each time.
The paused message was when I was running a clean install, but the advanced config utility never opened for me to configure it. So I copied the config file from another rig that works and that error cleared but still hangs after "Successfully acquired database lock". I'll see if I can troubleshoot openCL more.
Posts: 2040 Joined: Sat Dec 01, 2012 3:43 pm
Hardware configuration: Folding@Home Client 7.6.13 (1 GPU slots) Windows 7 64bit Intel Core i5 2500k@4Ghz Nvidia gtx 1080ti driver 441
Post
by foldy » Fri Jun 08, 2018 1:22 pm
Did you try to reboot your PC? This sounds like another FahClient.exe is still running and blocking the newly started FAH.
thanatos2k
Post
by thanatos2k » Fri Jun 08, 2018 3:35 pm
Yeah i've rebooted between clean installs on the video drivers even though that's not necessary any more. Also tried two different user accounts between clean uninstall/reinstall of the FAH client. I'm about to go on a trip so I think I might just pop a spare SSD in there and do a clean windows install on that to get it running and mess with why OpenCL isn't working when I get back.
thanatos2k
Post
by thanatos2k » Sat Jun 09, 2018 3:52 am
Well, I've got the client running again, manually specifying the cuda/opencl index and reinstalling the drivers again got it up. But now the GPU is in a "failed" state. Here's the last bit from the log.
03:49:42:WU00:FS01:Running FahCore: D:\fahclient/FAHCoreWrapper.exe D:\fahclient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 1132 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:49:42:WU00:FS01:Started FahCore on PID 5380
03:49:42:WU00:FS01:Core PID:9404
03:49:42:WU00:FS01:FahCore 0x21 started
03:49:42:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:49:42:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11713 run:6 clone:480 gen:30 core:0x21 unit:0x0000002b8ca304e75adf74e8ae949ff2
03:49:42:WU00:FS01:Uploading 5.50KiB to 140.163.4.231
03:49:42:WU00:FS01:Connecting to 140.163.4.231:8080
03:49:42:WU00:FS01:Upload complete
03:49:42:WU02:FS01:Connecting to 65.254.110.245:8080
03:49:43:WU00:FS01:Server responded WORK_ACK (400)
03:49:43:WU00:FS01:Cleaning up
03:49:43:WU02:FS01:Assigned to work server 140.163.4.231
03:49:43:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 950] 1572 from 140.163.4.231
03:49:43:WU02:FS01:Connecting to 140.163.4.231:8080
03:49:44:WU02:FS01:Downloading 16.52MiB
03:49:45:WU02:FS01:Download complete
03:49:45:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11713 run:26 clone:330 gen:87 core:0x21 unit:0x0000006f8ca304e75adf7ee0ab8ee299
03:49:45:WU02:FS01:Starting
03:49:45:WU02:FS01:Running FahCore: D:\fahclient/FAHCoreWrapper.exe D:\fahclient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 1132 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:49:45:WU02:FS01:Started FahCore on PID 7564
03:49:46:WU02:FS01:Core PID:9320
03:49:46:WU02:FS01:FahCore 0x21 started
03:49:46:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:49:46:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11713 run:26 clone:330 gen:87 core:0x21 unit:0x0000006f8ca304e75adf7ee0ab8ee299
03:49:46:WU02:FS01:Uploading 5.50KiB to 140.163.4.231
03:49:46:WU02:FS01:Connecting to 140.163.4.231:8080
03:49:46:WU02:FS01:Upload complete
03:49:46:WU00:FS01:Connecting to 65.254.110.245:8080
03:49:47:WU02:FS01:Server responded WORK_ACK (400)
03:49:47:WU02:FS01:Cleaning up
03:49:47:WU00:FS01:Assigned to work server 140.163.4.231
03:49:47:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 950] 1572 from 140.163.4.231
03:49:47:WU00:FS01:Connecting to 140.163.4.231:8080
03:49:48:WU00:FS01:Downloading 16.53MiB
03:49:49:WU00:FS01:Download complete
03:49:49:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11713 run:4 clone:252 gen:83 core:0x21 unit:0x000000738ca304e75adf737f6a370579
03:49:49:WU00:FS01:Starting
03:49:49:WU00:FS01:Running FahCore: D:\fahclient/FAHCoreWrapper.exe D:\fahclient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 1132 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:49:49:WU00:FS01:Started FahCore on PID 4904
03:49:49:WU00:FS01:Core PID:5348
03:49:49:WU00:FS01:FahCore 0x21 started
03:49:50:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:49:50:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11713 run:4 clone:252 gen:83 core:0x21 unit:0x000000738ca304e75adf737f6a370579
03:49:50:WU00:FS01:Uploading 5.50KiB to 140.163.4.231
03:49:50:WU00:FS01:Connecting to 140.163.4.231:8080
03:49:50:WU00:FS01:Upload complete
03:49:50:WU02:FS01:Connecting to 65.254.110.245:8080
03:49:50:WU00:FS01:Server responded WORK_ACK (400)
03:49:50:WU00:FS01:Cleaning up
03:49:51:WU02:FS01:Assigned to work server 140.163.4.231
03:49:51:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 950] 1572 from 140.163.4.231
03:49:51:WU02:FS01:Connecting to 140.163.4.231:8080
03:49:52:WU02:FS01:Downloading 16.53MiB
03:49:53:WU02:FS01:Download complete
03:49:54:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11713 run:10 clone:489 gen:30 core:0x21 unit:0x0000002e8ca304e75adf76ec60aa6237
03:49:54:WU02:FS01:Starting
03:49:54:WU02:FS01:Running FahCore: D:\fahclient/FAHCoreWrapper.exe D:\fahclient\cores/cores.foldingathome.org/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 705 -lifeline 1132 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:49:54:WU02:FS01:Started FahCore on PID 6336
03:49:54:WU02:FS01:Core PID:7356
03:49:54:WU02:FS01:FahCore 0x21 started
03:49:54:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:49:54:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11713 run:10 clone:489 gen:30 core:0x21 unit:0x0000002e8ca304e75adf76ec60aa6237
03:49:55:WU02:FS01:Uploading 5.50KiB to 140.163.4.231
03:49:55:WU02:FS01:Connecting to 140.163.4.231:8080
03:49:55:WU02:FS01:Upload complete
03:49:55:WU02:FS01:Server responded WORK_ACK (400)
03:49:55:WU02:FS01:Cleaning up
Posts: 6447 Joined: Sun Dec 02, 2007 10:38 am
Post
by toTOW » Sat Jun 09, 2018 3:25 pm
So something is still wrong with your OpenCL install ... or the index you specified is not correct and the core can't access the GPU.
Post
by bruce » Sat Jun 09, 2018 4:57 pm
You can get the client running with those steps, but it does not provide you with a GPU configuration that's supported.
From your first post I see
03:10:47: GPUs: 0
What has changed in that regard?
Changing the GPU index values is useless since as far as FAH is concerned, you don't have an OpenCL GPU.
I also see
03:10:47: CPUs: 8
so the client can be started with a CPU slot and it will work (without using the GPU).
