I have 4 GPUs down waiting for WUs
SteveWillis
Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Post by SteveWillis »
GTX 1080 and 1080TI on Linux on 3 different rigs
2018-06-05:21:23:16:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
2018-06-05:21:23:16:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
2018-06-05:21:23:16:ERROR:WU02:FS01:Exception: Could not get an assignment
2018-06-05:21:23:56:WARNING:WU03:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
2018-06-05:21:23:56:WARNING:WU03:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Re: I have 4 GPUs down waiting for WUs
Now 5
Holdolin
Post by Holdolin »
I have 4 1080Ti's now idle as well :(
Hypocritus
Failing To Receive any WUs for GPUs (Multiple Servers)
Post by Hypocritus »
This started about an hour or two ago. I upgraded the client on one machine to see if that would fix it, but no luck.
Old Client (7.4.4)
21:38:48:WU03:FS01:Connecting to 171.67.108.45:80
21:38:49:WARNING:WU03:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
21:38:49:WU03:FS01:Connecting to 171.64.65.35:80
21:38:49:WARNING:WU03:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:38:49:ERROR:WU03:FS01:Exception: Could not get an assignment
New Client (7.5.1)
21:41:49:WU00:FS01:Connecting to 65.254.110.245:8080
21:41:49:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:41:49:WU00:FS01:Connecting to 18.218.241.186:80
21:41:49:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:41:49:ERROR:WU00:FS01:Exception: Could not get an assignment
bollix47
Post by bollix47 »
Reported to PG ... I'm in the same boat :e?:
It appears that we only have one active project at the moment and it's server is down but they are checking out the problem.
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
I'm going again :-)
rafwiewiora
Scientist
Post by rafwiewiora »
Should be all good now - catching up on assignments - sorry for trouble / thanks for reporting! (Some WS - AS connectivity issue - looking into what happened exactly).
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Thanks for taking care of it so quickly!!!
Holdolin
Post by Holdolin »
rafwiewiora wrote:Should be all good now - catching up on assignments - sorry for trouble / thanks for reporting! (Some WS - AS connectivity issue - looking into what happened exactly).
Thanks for takin care of it :)
