New FAHClient
New released client
The (previously beta) version of the FAH client -- 7.5.1 is now a public release: https://foldingathome.org/start-folding/
If you encounter difficulties, please use this topic.
(Some comments can already be found in the 7.5.1 beta topic need not be repeated here)
Re: New released client
Just downloaded 7.5 with no problems. As a Biochemistry graduate (admittedly from about 40 years ago) with a fairly basic computer based in the middle of rural England, may I just say how pleased I am as a "small guy" to contribute in some way to the science that this project supports. Good luck to all of you guys with the super number-crunchers and the work of the Pande team.
Congrats! That was a while coming to fruition!
- Hardware configuration: i7 2700K 4.5 GHz
GTX 980 1.418 GHz
DDR3 16Gb
Win 7x64 - Location: Russia, Ufa city
Start folding page needs to be updated with new link https://download.foldingathome.org/rele ... .1_x86.exe
This is a caching issue. The webpage does not set its caching timeout right. So you see the old site but when you refresh the browser page then you see the latest with the new link.
- Hardware configuration: OS: Windows 10 Home 64-bit
CPU: Intel Processor Cores 6, Threads 12, Specification: Intel Core i7-10710U CPU @ 1.10GHz
Motherboard: Manufacturer: Intel Corporation, Model NUC10i7FNB (U3E1)
Graphics: Monitor = BenQ GW2470 on Intel UHD Graphics
Current Resolution 1920x1080 pixels
Work Resolution 1920x1040 pixels
State Enabled, Primary
Monitor Width 1920
Monitor Height 1080
Monitor BPP 32 bits per pixel
Monitor Frequency 59 Hz
Intel UHD Graphics:
Manufacturer Intel
Model UHD Graphics - Contact:
New FAHClient
Hurrah! Finally!
Is there a description somewhere of what's different between this version and the previous one ?
There are change logs.
FAHClient:
7.5.1
OSX installer updates. @kbernhagen
FAHControl:
7.5.1
Fix for slot/queue highlighting. @informatoris
Install Gtk theme engines in correct place on Windows.
FAHViewer:
7.5.1
Fixed PyON message parsing.
FAHClient:
v7.5.0
Fixed client memory leak.
Some spelling fixes.
FAHControl:
Fixed inconsistent highlighting.
Fixed ``python setup.py install`` wo/ ``version.txt``.
Highlight Matching WU When Slot Is Selected. fah-issues/#1127
FAHClient:
v7.4.18:
Fixed user stats link in Web control.
Fixed create team link in Web control.
Fixes Google+ share link in Web control.
Automatically uninstall conflicting files in Windows installer.
More thorough termination of F@H apps in Windows installer.
Removed option to install for all users in Windows installer.
Fixed Windows CPUID problem which causes fail to assign to CPU slots.
FAHClient:
v7.4.17:
Updated assignment servers.
Use same AS for GPU slots.
Updated URLs to point to foldingathome.org.
FAHViewer:
v7.4.17:
Fixed terminate called. . .'cb::Socket::EndOfStream' on client exit.
FAHControl:
v7.4.17:
Changed Windows default theme to be same as Clearlooks-Vista.
Fixed major memory leak.
FAHClient:
v7.4.16:
Removed support for reading Gromacs trajectory files.
Skip over non-GPU OpenCL devices during detection.
Pass both CUDA and OpenCL device indices to GPU cores when available.
Fall back to guessing GPU indices when drivers cannot be loaded.
Added message to indicate why GPU drivers were not detected.
Don't inadvertently remove GPU index options from config.
Correctly handle PCI bus/dev IDs > 127.
Fixed AMD PCI bus/slot code.
Report GPU PCI function in info.
Fixed detection of multiple GPUs of the same type. #1161
max-packet-size=normal (the default) redefined to mean 25MiB. #1154
Report more CPUID feature flags, specifically to detect RDTSCP.
FAHViewer:
v7.4.16:
Read JSON files from command line.
Use basic mode by default.
Removed support for reading Gromacs format files .trn, .tpr, .xtc.
Removed ``--xyz <file>`` option. Not needed.
FAHClient:
7.5.1
FAHControl:
7.5.1
FAHViewer:
7.5.1
FAHClient:
v7.5.0
FAHControl:
FAHClient:
v7.4.18:
FAHClient:
v7.4.17:
FAHViewer:
v7.4.17:
FAHControl:
v7.4.17:
FAHClient:
v7.4.16:
FAHViewer:
v7.4.16:
I downloaded the new Mac OS v7.5.1 and my problem of "no stats" disappeared. The stats loaded on the Web Control page. The first time in 5 days. That was yesterday. This morning when I checked the stats had once again disappeared. Web Control show them as "loading". After 5 minutes....still "loading!"
Note that the 7.5.1 client won't install on older systems (Ubuntu 10.04 for instance).
- Hardware configuration: Xeon 1230v3 + Geforce RTX 2080
Looks OK to me, but the link to the current project still doesn't work in the GUI. Same goes for for "Work Server" and "Collection Server". Would it be possible to grey out the button "Viewer" if fahviewer ist not installed? I don't care much about visualization that is why I don't install fahviewer on my system. A simple check if /usr/bin/fahviewer exists would be enough.
You enhancement request to grey out buttons for software that you didn't install probably won't be accepted. FAH Development resources are limited (and expensive) and the first question that's going to be asked is "If we support this enhancement, how much additional throughput will FAH produce globally?" I suggest you don't click that button, since you know it's not going to work.
Some changes are being made to the locations of Work Servers / Collection Servers / Assignment Servers. I expect that problems with those links will be resolved shortly. If not, post enough information so that we can validate your problem. (Do check your firewall settings first.)
The links to Project Description / Work Servers logs / Collection Servers logs in FAHControl are disabled in FAHClient 7.5.1 permanently. Maybe they come back in a later FahClient release
