11:13:08:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11713 run:5 clone:269 gen:18 core:0x21 unit:0x0000001b8ca304e75adf74183284c129
11:13:08:WU00:FS01:Starting
11:13:08:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1149 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:13:08:WU00:FS01:Started FahCore on PID 5000
11:13:08:WU00:FS01:Core PID:5004
11:13:08:WU00:FS01:FahCore 0x21 started
11:13:09:WU00:FS01:0x21:*********************** Log Started 2018-05-21T11:13:08Z ***********************
11:13:09:WU00:FS01:0x21:Project: 11713 (Run 5, Clone 269, Gen 18)
11:13:09:WU00:FS01:0x21:Unit: 0x0000001b8ca304e75adf74183284c129
11:13:09:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:13:09:WU00:FS01:0x21:Machine: 1
11:13:09:WU00:FS01:0x21:Reading tar file core.xml
11:13:09:WU00:FS01:0x21:Reading tar file integrator.xml
11:13:09:WU00:FS01:0x21:Reading tar file state.xml
11:13:09:WU00:FS01:0x21:Reading tar file system.xml
11:13:09:WU00:FS01:0x21:Digital signatures verified
11:13:09:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:13:09:WU00:FS01:0x21:Version 0.0.18
11:13:10:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
11:13:10:WU00:FS01:Starting
11:13:10:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1149 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:13:10:WU00:FS01:Started FahCore on PID 5007
11:13:10:WU00:FS01:Core PID:5011
11:13:10:WU00:FS01:FahCore 0x21 started
11:13:10:WU00:FS01:0x21:*********************** Log Started 2018-05-21T11:13:10Z ***********************
11:13:10:WU00:FS01:0x21:Project: 11713 (Run 5, Clone 269, Gen 18)
11:13:10:WU00:FS01:0x21:Unit: 0x0000001b8ca304e75adf74183284c129
11:13:10:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:13:10:WU00:FS01:0x21:Machine: 1
11:13:10:WU00:FS01:0x21:Reading tar file core.xml
11:13:10:WU00:FS01:0x21:Reading tar file integrator.xml
11:13:10:WU00:FS01:0x21:Reading tar file state.xml
11:13:10:WU00:FS01:0x21:Reading tar file system.xml
11:13:10:WU00:FS01:0x21:Digital signatures verified
11:13:10:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:13:10:WU00:FS01:0x21:Version 0.0.18
11:13:11:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
11:14:10:WU00:FS01:Starting
11:14:10:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1149 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:14:10:WU00:FS01:Started FahCore on PID 5020
11:14:10:WU00:FS01:Core PID:5024
11:14:10:WU00:FS01:FahCore 0x21 started
11:14:11:WU00:FS01:0x21:*********************** Log Started 2018-05-21T11:14:10Z ***********************
11:14:11:WU00:FS01:0x21:Project: 11713 (Run 5, Clone 269, Gen 18)
11:14:11:WU00:FS01:0x21:Unit: 0x0000001b8ca304e75adf74183284c129
11:14:11:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:14:11:WU00:FS01:0x21:Machine: 1
11:14:11:WU00:FS01:0x21:Reading tar file core.xml
11:14:11:WU00:FS01:0x21:Reading tar file integrator.xml
11:14:11:WU00:FS01:0x21:Reading tar file state.xml
11:14:11:WU00:FS01:0x21:Reading tar file system.xml
11:14:11:WU00:FS01:0x21:Digital signatures verified
11:14:11:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:14:11:WU00:FS01:0x21:Version 0.0.18
11:14:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
11:15:10:WU00:FS01:Starting
11:15:10:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1149 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:15:10:WU00:FS01:Started FahCore on PID 5032
11:15:10:WU00:FS01:Core PID:5036
11:15:10:WU00:FS01:FahCore 0x21 started
11:15:11:WU00:FS01:0x21:*********************** Log Started 2018-05-21T11:15:10Z ***********************
11:15:11:WU00:FS01:0x21:Project: 11713 (Run 5, Clone 269, Gen 18)
11:15:11:WU00:FS01:0x21:Unit: 0x0000001b8ca304e75adf74183284c129
11:15:11:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:15:11:WU00:FS01:0x21:Machine: 1
11:15:11:WU00:FS01:0x21:Reading tar file core.xml
11:15:11:WU00:FS01:0x21:Reading tar file integrator.xml
11:15:11:WU00:FS01:0x21:Reading tar file state.xml
11:15:11:WU00:FS01:0x21:Reading tar file system.xml
11:15:11:WU00:FS01:0x21:Digital signatures verified
11:15:11:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:15:11:WU00:FS01:0x21:Version 0.0.18
11:15:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
11:16:10:WU00:FS01:Starting
11:16:10:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1149 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:16:10:WU00:FS01:Started FahCore on PID 5040
11:16:10:WU00:FS01:Core PID:5044
11:16:10:WU00:FS01:FahCore 0x21 started
11:16:11:WU00:FS01:0x21:*********************** Log Started 2018-05-21T11:16:10Z ***********************
11:16:11:WU00:FS01:0x21:Project: 11713 (Run 5, Clone 269, Gen 18)
11:16:11:WU00:FS01:0x21:Unit: 0x0000001b8ca304e75adf74183284c129
11:16:11:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:16:11:WU00:FS01:0x21:Machine: 1
11:16:11:WU00:FS01:0x21:Reading tar file core.xml
11:16:11:WU00:FS01:0x21:Reading tar file integrator.xml
11:16:11:WU00:FS01:0x21:Reading tar file state.xml
11:16:11:WU00:FS01:0x21:Reading tar file system.xml
11:16:11:WU00:FS01:0x21:Digital signatures verified
11:16:11:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:16:11:WU00:FS01:0x21:Version 0.0.18
11:16:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
11:17:10:WU00:FS01:Starting
11:17:10:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1149 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:17:10:WU00:FS01:Started FahCore on PID 5059
11:17:10:WU00:FS01:Core PID:5063
11:17:10:WU00:FS01:FahCore 0x21 started
11:17:11:WU00:FS01:0x21:*********************** Log Started 2018-05-21T11:17:10Z ***********************
11:17:11:WU00:FS01:0x21:Project: 11713 (Run 5, Clone 269, Gen 18)
11:17:11:WU00:FS01:0x21:Unit: 0x0000001b8ca304e75adf74183284c129
11:17:11:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:17:11:WU00:FS01:0x21:Machine: 1
11:17:11:WU00:FS01:0x21:Reading tar file core.xml
11:17:11:WU00:FS01:0x21:Reading tar file integrator.xml
11:17:11:WU00:FS01:0x21:Reading tar file state.xml
11:17:11:WU00:FS01:0x21:Reading tar file system.xml
11:17:11:WU00:FS01:0x21:Digital signatures verified
11:17:11:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:17:11:WU00:FS01:0x21:Version 0.0.18
11:17:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
11:18:10:WU00:FS01:Starting
11:18:10:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1149 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:18:10:WU00:FS01:Started FahCore on PID 5066
11:18:10:WU00:FS01:Core PID:5070
11:18:10:WU00:FS01:FahCore 0x21 started
11:18:11:WU00:FS01:0x21:*********************** Log Started 2018-05-21T11:18:10Z ***********************
11:18:11:WU00:FS01:0x21:Project: 11713 (Run 5, Clone 269, Gen 18)
11:18:11:WU00:FS01:0x21:Unit: 0x0000001b8ca304e75adf74183284c129
11:18:11:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:18:11:WU00:FS01:0x21:Machine: 1
11:18:11:WU00:FS01:0x21:Reading tar file core.xml
11:18:11:WU00:FS01:0x21:Reading tar file integrator.xml
11:18:11:WU00:FS01:0x21:Reading tar file state.xml
11:18:11:WU00:FS01:0x21:Reading tar file system.xml
11:18:11:WU00:FS01:0x21:Digital signatures verified
11:18:11:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:18:11:WU00:FS01:0x21:Version 0.0.18
11:18:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
11:19:10:WU00:FS01:Starting
11:19:10:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1149 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:19:10:WU00:FS01:Started FahCore on PID 5078
11:19:10:WU00:FS01:Core PID:5082
11:19:10:WU00:FS01:FahCore 0x21 started
11:19:11:WU00:FS01:0x21:*********************** Log Started 2018-05-21T11:19:10Z ***********************
11:19:11:WU00:FS01:0x21:Project: 11713 (Run 5, Clone 269, Gen 18)
11:19:11:WU00:FS01:0x21:Unit: 0x0000001b8ca304e75adf74183284c129
11:19:11:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:19:11:WU00:FS01:0x21:Machine: 1
11:19:11:WU00:FS01:0x21:Reading tar file core.xml
11:19:11:WU00:FS01:0x21:Reading tar file integrator.xml
11:19:11:WU00:FS01:0x21:Reading tar file state.xml
11:19:11:WU00:FS01:0x21:Reading tar file system.xml
11:19:11:WU00:FS01:0x21:Digital signatures verified
11:19:11:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:19:11:WU00:FS01:0x21:Version 0.0.18
11:19:12:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)Linux Mint 17.3 and a single GTX 1080 FE
