I run 4 machines on FAH 24/7 under ChristopherS
Twin Zeon Hex Core, 10 cores used/slot + GTX750Ti & GTX980
Zeon Hex Core + HT, 10 cores used/slot + GTX750 & GTX960
i7 2600 Quad Core + HT, 6 cores used/slot, GTX1060 (3Gb)
i5 2320 Quad Core, 3 cores used/slot, GTX750Ti
What sort of output should I get for that lot? I'm racking up 700,000/day, is that good or bad? And I have a special passkey I'm sure.
Is my performance up to par?
Re: Is my performance up to par?
From what I can see on EOC ( https://folding.extremeoverclocking.com ... =&u=754538 ) your PPD looks like it will be closer to somewhere between 800-900 K and with your hardware that would seem to be about right if running on Windows. EOC averages the most recent 7 days to create an average PPD so your eventual PPD will be higher than what EOC is currently showing. https://folding.extremeoverclocking.com/?nav=FAQ
You should be able to see your current PPD estimate using FAHControl (aka Advanced Control). If you have trouble with FAHControl try changing it's theme from Default to something else in the Preferences. I use Win7-basic and do not have any of the reported display problems that occur when using the Default theme.
My 700 thousand output is average over the last 30 days, since I last checked it. 42 mill at present, make 50 mill by end of June, your chart suggests in one week!
artoar_11
- Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
When I calculate your PPD only from GPUs, I get an amount of ~ 960k. GPUs+CPUs PPD should be more than 1 million.
750Ti = 80 000 (x3)
960 = 160 000
980 = 420 000
1050Ti= 180 000
https://docs.google.com/spreadsheets/d/ ... /pub?gid=2
EDIT: Is there a mistake in statistics? ChristopherS has only got 6+ million points. Why "Points Total" 42+ million?
750Ti = 80 000 (x3)
960 = 160 000
980 = 420 000
1050Ti= 180 000
I'm not unhappy with what I get with 4 machines, but higher would be nice.
Think I made an error with my GPU details, sorry. Have now corrected it.
Nathan_P
Not currently folding
I would try pausing the cpu folding and seeing what impact that has, looking at the hardware list you are below what you should be getting
1060 ~ 300k
980 ~ 400k PPD
960 ~ 150k PPD
750Ti ~ 75kEach
750 ~ 50k
1060 ~ 300k
980 ~ 400k PPD
960 ~ 150k PPD
750Ti ~ 75kEach
750 ~ 50k
I have made sure that there are enough CPU cores to feed the GPU's, but I might try that, thanks. I am happy with what I get, even if is is abit on the low side.
It has been mentioned before in the forum, but you have to take the figures in that google spreadsheet as being only indicative of a possible PPD for a GPU. The numbers tend to be reported on the highest resulting PPD which is not the average over a number of different projects. The results are also for various values of overclocked cards.
