Driver issues associated with the Windows 10 roll-out
phrost
Posts: 56 Joined: Mon Sep 09, 2013 5:00 pm
Post
by phrost » Wed May 02, 2018 1:51 pm
So I have two computers I fold on.
Home PC: Windows 10 Enterprise (with latest spring update), MSI x370 motherboard, nvidia 1080ti and 1070ti, latest nvidia drivers. I'm using the latest beta F@H client, everything is fine on this one.
Work PC: Windows 10 Home (with latest spring update), ASUS z370 motherboard, nvidia 1080 and 1070ti, latest nvidia drivers. I'm using the latest beta F@H client, and it was working fine all the way up until 397.31. Now, my CPU will fold but both of my GPU's show "ready".
I tried fresh installing the driver and F@H (deleting settings), but it didn't help. The only thing that helps is installing the previous month's 391.35 driver. It's very strange since my two PC's are very similar. Here's a screenshot of the info tab.
and here's the older driver that's working fine
bollix47
Posts: 2982 Joined: Sun Dec 02, 2007 5:04 am
Post
by bollix47 » Wed May 02, 2018 8:27 pm
At any time did you perhaps click on the Pause button?
If so you need to click on the Fold button.
phrost
Post
by phrost » Wed May 02, 2018 8:27 pm
i didn't pause, and the fold button doesn't do anything
i can only pause/unpause the cpu not the gpu
bollix47
Post
by bollix47 » Wed May 02, 2018 8:31 pm
Please copy the 1st 100 lines of log.txt and paste it in a post here.
phrost
Post
by phrost » Wed May 02, 2018 8:36 pm
i had already installed the previous nvidia drivers, do you want me to install the new ones and post the log or is it ok if i already post the log?
bollix47
Post
by bollix47 » Wed May 02, 2018 8:41 pm
The new ones are the ones that are not working so if you want help figuring out why I guess you'll have to install the new ones and post the new log or you can just run the previous ones and be happy with that. Your choice.
phrost
Post
by phrost » Wed May 02, 2018 8:42 pm
ok i'll do that. i wasn't trying to be rude i wasn't sure if it mattered which drivers i have for the log... anyway doing that now
phrost
Post
by phrost » Wed May 02, 2018 8:50 pm
so that's strange... the last 5 times i tried to troubleshoot this, i always did a clean driver install. this time, since i was in a hurry i just did a regular driver install and F@H seems to be working again. i even rebooted my PC and it's still working. I wonder what the problem was?
*********************** Log Started 2018-05-02T20:48:21Z ***********************
20:48:21:************************* Folding@home Client *************************
20:48:21: Website: http://folding.stanford.edu/
20:48:21: Copyright: (c) 2009-2016 Stanford University
20:48:21: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:48:21: Args:
20:48:21: Config: C:\Users\Phrost\AppData\Roaming\FAHClient\config.xml
20:48:21:******************************** Build ********************************
20:48:21: Version: 7.4.16
20:48:21: Date: Jan 6 2017
20:48:21: Time: 00:25:14
20:48:21: Repository: Git
20:48:21: Revision: a9e9e27dc2ee6ff01398c439677bc27f6cb74032
20:48:21: Branch: master
20:48:21: Compiler: Visual C++ 2008
20:48:21: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox -arch:SSE /MT
20:48:21: Platform: win32 10
20:48:21: Bits: 32
20:48:21: Mode: Release
20:48:21:******************************* System ********************************
20:48:21: CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
20:48:21: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
20:48:21: CPUs: 12
20:48:21: Memory: 15.94GiB
20:48:21: Free Memory: 13.89GiB
20:48:21: Threads: WINDOWS_THREADS
20:48:21: OS Version: 6.2
20:48:21: Has Battery: false
20:48:21: On Battery: false
20:48:21: UTC Offset: -4
20:48:21: PID: 9284
20:48:21: CWD: C:\Users\Phrost\AppData\Roaming\FAHClient
20:48:21: OS: Windows 10 Home
20:48:21: OS Arch: AMD64
20:48:21: GPUs: 2
20:48:21: GPU 0: Bus:3 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070 Ti] 8186
20:48:21: GPU 1: Bus:1 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1080] 8873
20:48:21: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:9.2
20:48:21: CUDA Device 1: Platform:0 Device:1 Bus:3 Slot:0 Compute:6.1 Driver:9.2
20:48:21:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:397.31
20:48:21:OpenCL Device 1: Platform:0 Device:1 Bus:3 Slot:0 Compute:1.2 Driver:397.31
20:48:21: Win32 Service: false
20:48:21:***********************************************************************
20:48:21:<config>
20:48:21: <!-- Slot Control -->
20:48:21: <power v='FULL'/>
20:48:21:
20:48:21: <!-- User Information -->
20:48:21: <passkey v='********************************'/>
20:48:21: <team v='224497'/>
20:48:21: <user v='PhrostByte_ALL_1MkacxwShGSs15VkhSUD4pG5hcd4aamqoX'/>
20:48:21:
20:48:21: <!-- Folding Slots -->
20:48:21: <slot id='0' type='CPU'/>
20:48:21: <slot id='1' type='GPU'/>
20:48:21: <slot id='2' type='GPU'/>
20:48:21:</config>
20:48:21:Trying to access database...
20:48:21:Successfully acquired database lock
20:48:21:Enabled folding slot 00: READY cpu:10
20:48:21:Enabled folding slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186
20:48:21:Enabled folding slot 02: READY gpu:1:GP104 [GeForce GTX 1080] 8873
20:48:21:WU00:FS02:Starting
20:48:21:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Phrost\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 9284 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:48:21:WU00:FS02:Started FahCore on PID 7632
20:48:21:WU00:FS02:Core PID:10168
20:48:21:WU00:FS02:FahCore 0x21 started
20:48:22:WU02:FS01:Starting
20:48:22:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Phrost\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 9284 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
20:48:22:WU02:FS01:Started FahCore on PID 10208
20:48:22:WU02:FS01:Core PID:9264
20:48:22:WU02:FS01:FahCore 0x21 started
20:48:22:WU03:FS00:Starting
20:48:22:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Phrost\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 704 -lifeline 9284 -checkpoint 15 -np 10
20:48:22:WU03:FS00:Started FahCore on PID 8960
20:48:22:WU03:FS00:Core PID:10268
20:48:22:WU03:FS00:FahCore 0xa4 started
20:48:22:WU00:FS02:0x21:*********************** Log Started 2018-05-02T20:48:22Z ***********************
20:48:22:WU00:FS02:0x21:Project: 11710 (Run 1, Clone 259, Gen 82)
20:48:22:WU00:FS02:0x21:Unit: 0x0000006d8ca304e75814df3b706efa61
20:48:22:WU00:FS02:0x21:CPU: 0x00000000000000000000000000000000
20:48:22:WU00:FS02:0x21:Machine: 2
20:48:22:WU00:FS02:0x21:Digital signatures verified
20:48:22:WU00:FS02:0x21:Folding@home GPU Core21 Folding@home Core
20:48:22:WU00:FS02:0x21:Version 0.0.18
20:48:22:WU00:FS02:0x21: Found a checkpoint file
20:48:22:WU02:FS01:0x21:*********************** Log Started 2018-05-02T20:48:22Z ***********************
20:48:22:WU02:FS01:0x21:Project: 11713 (Run 27, Clone 7, Gen 14)
20:48:22:WU02:FS01:0x21:Unit: 0x0000000f8ca304e75ae6351a29570ea7
20:48:22:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
20:48:22:WU02:FS01:0x21:Machine: 1
20:48:22:WU02:FS01:0x21:Digital signatures verified
20:48:22:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
20:48:22:WU02:FS01:0x21:Version 0.0.18
20:48:22:WU02:FS01:0x21: Found a checkpoint file
20:48:22:WU03:FS00:0xa4:
20:48:22:WU03:FS00:0xa4:*------------------------------*
20:48:22:WU03:FS00:0xa4:Folding@Home Gromacs GB Core
20:48:22:WU03:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
20:48:22:WU03:FS00:0xa4:Preparing to commence simulation
20:48:22:WU03:FS00:0xa4:- Looking at optimizations...
20:48:22:WU03:FS00:0xa4:- Files status OK
20:48:22:WU03:FS00:0xa4:- Expanded 343354 -> 549812 (decompressed 160.1 percent)
20:48:22:WU03:FS00:0xa4:Called DecompressByteArray: compressed_data_size=343354 data_size=549812, decompressed_data_size=549812 diff=0
20:48:22:WU03:FS00:0xa4:- Digital signature verified
20:48:22:WU03:FS00:0xa4:Project: 8644 (Run 2190, Clone 0, Gen 53)
20:48:22:WU03:FS00:0xa4:Assembly optimizations on if available.
20:48:22:WU03:FS00:0xa4:Entering M.D.
20:48:23:WARNING:FS01:Size of positions 2578 does not match topology 2576
20:48:25:WU00:FS02:0x21:Completed 6500000 out of 7500000 steps (86%)
20:48:25:WU00:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:48:25:WU02:FS01:0x21:Completed 3000000 out of 7500000 steps (40%)
20:48:25:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:48:28:WU03:FS00:0xa4:Using Gromacs checkpoints
20:48:28:WU03:FS00:0xa4:Mapping NT from 10 to 10
20:48:28:WU03:FS00:0xa4:Resuming from checkpoint
20:48:28:WU03:FS00:0xa4:Verified 03/wudata_01.log
20:48:28:WU03:FS00:0xa4:Verified 03/wudata_01.trr
20:48:28:WU03:FS00:0xa4:Verified 03/wudata_01.xtc
20:48:28:WU03:FS00:0xa4:Verified 03/wudata_01.edr
20:48:28:WU03:FS00:0xa4:Completed 274690 out of 2500000 steps (10%)
20:48:30:WU03:FS00:0xa4:Completed 275000 out of 2500000 steps (11%)
20:49:12:WU00:FS02:0x21:Completed 6525000 out of 7500000 steps (87%)
Mod edit: changed Quote tags to Code tags for log file, please use these when posting log files.
bollix47
Post
by bollix47 » Wed May 02, 2018 9:02 pm
All looks good in that log ... except for the topology messages which you can ignore. They have been removed in a later version of the core which has yet to be force released.
As to why I can only think that something went wrong during the installation(s). When I install a driver from nvidia on windows I always choose the Custom install and remove the check next to everything (that of course is not possible for the actual drivers) and put a check next to Perform a clean install. It could be that that has changed in that one of the check boxes may now be for OpenCL. If I get a chance I'll try to install the same drivers and if I see anything unusual I'll post here.
Glad to see you're up and running again.
phrost
Post
by phrost » Wed May 02, 2018 9:07 pm
thanks the help. i also do clean install/custom but i only remove the two 3d vision things
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Thu May 03, 2018 3:00 pm
phrost wrote: i had already installed the previous nvidia drivers, do you want me to install the new ones and post the log or is it ok if i already post the log?
It's past the point of this decision mattering any more, but I will observe that running on previous Windows drivers contains an element of risk. Sooner or later Win10 will decide to force the upgrade of older drivers and break FAH by not installing OpenCL.
phrost
Post
by phrost » Fri May 04, 2018 3:35 am
after updating to 397.55 on my home PC it happened again, so strange... reinstall didn't help either. cards are still paused
*********************** Log Started 2018-05-04T03:37:11Z ***********************
03:37:11:************************* Folding@home Client *************************
03:37:11: Website: http://folding.stanford.edu/
03:37:11: Copyright: (c) 2009-2016 Stanford University
03:37:11: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:37:11: Args: --open-web-control
03:37:11: Config: C:\Users\Dima\AppData\Roaming\FAHClient\config.xml
03:37:11:******************************** Build ********************************
03:37:11: Version: 7.4.16
03:37:11: Date: Jan 6 2017
03:37:11: Time: 00:25:14
03:37:11: Repository: Git
03:37:11: Revision: a9e9e27dc2ee6ff01398c439677bc27f6cb74032
03:37:11: Branch: master
03:37:11: Compiler: Visual C++ 2008
03:37:11: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox -arch:SSE /MT
03:37:11: Platform: win32 10
03:37:11: Bits: 32
03:37:11: Mode: Release
03:37:11:******************************* System ********************************
03:37:11: CPU: AMD Ryzen 5 1600X Six-Core Processor
03:37:11: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
03:37:11: CPUs: 12
03:37:11: Memory: 15.95GiB
03:37:11: Free Memory: 8.69GiB
03:37:11: Threads: WINDOWS_THREADS
03:37:11: OS Version: 6.2
03:37:11: Has Battery: false
03:37:11: On Battery: false
03:37:11: UTC Offset: -4
03:37:11: PID: 2452
03:37:11: CWD: C:\Users\Dima\AppData\Roaming\FAHClient
03:37:11: OS: Windows 10 Enterprise
03:37:11: OS Arch: AMD64
03:37:11: GPUs: 1
03:37:11: GPU 0: Bus:29 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070 Ti] 8186
03:37:11:CUDA Device 0: Platform:0 Device:0 Bus:29 Slot:0 Compute:6.1 Driver:9.2
03:37:11: OpenCL: Not detected: clGetPlatformIDs() returned -1001
03:37:11:Win32 Service: false
03:37:11:***********************************************************************
03:37:11:<config>
03:37:11: <!-- Slot Control -->
03:37:11: <power v='FULL'/>
03:37:11:
03:37:11: <!-- User Information -->
03:37:11: <passkey v='********************************'/>
03:37:11: <team v='224497'/>
03:37:11: <user v='PhrostByte_ALL_1MkacxwShGSs15VkhSUD4pG5hcd4aamqoX'/>
03:37:11:
03:37:11: <!-- Folding Slots -->
03:37:11: <slot id='0' type='CPU'/>
03:37:11: <slot id='1' type='GPU'/>
03:37:11:</config>
03:37:11:Trying to access database...
03:37:11:Successfully acquired database lock
03:37:11:Enabled folding slot 00: READY cpu:11
03:37:11:Enabled folding slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186
03:37:11:WU01:FS01:Starting
03:37:11:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
03:37:11:WU00:FS00:Starting
03:37:11:WARNING:WU00:FS00:AS lowered CPUs from 11 to 10
03:37:11:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dima\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 2452 -checkpoint 15 -np 10
03:37:11:WU00:FS00:Started FahCore on PID 9820
03:37:11:WU00:FS00:Core PID:8220
03:37:11:WU00:FS00:FahCore 0xa4 started
03:37:12:WU01:FS01:Starting
03:37:12:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
03:37:12:WU00:FS00:0xa4:
03:37:12:WU00:FS00:0xa4:*------------------------------*
03:37:12:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
03:37:12:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
03:37:12:WU00:FS00:0xa4:Preparing to commence simulation
03:37:12:WU00:FS00:0xa4:- Looking at optimizations...
03:37:12:WU00:FS00:0xa4:- Files status OK
03:37:12:WU00:FS00:0xa4:- Expanded 820759 -> 1946552 (decompressed 237.1 percent)
03:37:12:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=820759 data_size=1946552, decompressed_data_size=1946552 diff=0
03:37:12:WU00:FS00:0xa4:- Digital signature verified
03:37:12:WU00:FS00:0xa4:Project: 14049 (Run 8, Clone 605, Gen 36)
03:37:12:WU00:FS00:0xa4:Assembly optimizations on if available.
03:37:12:WU00:FS00:0xa4:Entering M.D.
03:37:16:13:127.0.0.1:New Web connection
03:37:18:WU00:FS00:0xa4:Using Gromacs checkpoints
03:37:18:WU00:FS00:0xa4:Mapping NT from 10 to 10
03:37:18:WU00:FS00:0xa4:Resuming from checkpoint
03:37:18:WU00:FS00:0xa4:Verified 00/wudata_01.log
03:37:18:WU00:FS00:0xa4:Verified 00/wudata_01.trr
03:37:18:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
03:37:18:WU00:FS00:0xa4:Verified 00/wudata_01.edr
03:37:18:WU00:FS00:0xa4:Completed 488340 out of 2500000 steps (19%)
phrost
Post
by phrost » Fri May 04, 2018 3:48 am
and here's what happened when i tried setting my opencl-index and cuda-index manually to 0
03:47:11:WU00:FS00:0xa4:Completed 25000 out of 2500000 steps (1%)
03:47:20:WU01:FS01:Starting
03:47:20:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dima\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4852 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:47:20:WU01:FS01:Started FahCore on PID 3616
03:47:20:WU01:FS01:Core PID:3032
03:47:20:WU01:FS01:FahCore 0x21 started
03:47:20:WU01:FS01:0x21:*********************** Log Started 2018-05-04T03:47:20Z ***********************
03:47:20:WU01:FS01:0x21:Project: 11713 (Run 27, Clone 18, Gen 13)
03:47:20:WU01:FS01:0x21:Unit: 0x000000158ca304e75ae6351b20b397fa
03:47:20:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:47:20:WU01:FS01:0x21:Machine: 1
03:47:20:WU01:FS01:0x21:Reading tar file core.xml
03:47:20:WU01:FS01:0x21:Reading tar file integrator.xml
03:47:20:WU01:FS01:0x21:Reading tar file state.xml
03:47:20:WU01:FS01:0x21:Reading tar file system.xml
03:47:20:WU01:FS01:0x21:Digital signatures verified
03:47:20:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:47:20:WU01:FS01:0x21:Version 0.0.18
03:47:20:WU01:FS01:0x21:ERROR:126: Bad platformId size.
03:47:20:WU01:FS01:0x21:Saving result file logfile_01.txt
03:47:20:WU01:FS01:0x21:Saving result file log.txt
03:47:20:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:47:21:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:47:21:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11713 run:27 clone:18 gen:13 core:0x21 unit:0x000000158ca304e75ae6351b20b397fa
03:47:21:WU01:FS01:Uploading 5.50KiB to 140.163.4.231
03:47:21:WU01:FS01:Connecting to 140.163.4.231:8080
03:47:21:WU01:FS01:Upload complete
03:47:21:WU01:FS01:Server responded WORK_ACK (400)
03:47:21:WU01:FS01:Cleaning up
03:47:21:WU01:FS01:Connecting to 171.67.108.45:80
03:47:21:WU01:FS01:Assigned to work server 155.247.166.219
03:47:21:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186 from 155.247.166.219
03:47:21:WU01:FS01:Connecting to 155.247.166.219:8080
03:47:23:WU01:FS01:Downloading 904.12KiB
03:47:23:WU01:FS01:Download complete
03:47:23:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13783 run:476 clone:3 gen:175 core:0x21 unit:0x000000cf0002894b5a833fad00e21f36
03:47:23:WU01:FS01:Starting
03:47:23:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dima\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4852 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:47:23:WU01:FS01:Started FahCore on PID 4868
03:47:23:WU01:FS01:Core PID:7044
03:47:23:WU01:FS01:FahCore 0x21 started
03:47:24:WU01:FS01:0x21:*********************** Log Started 2018-05-04T03:47:23Z ***********************
03:47:24:WU01:FS01:0x21:Project: 13783 (Run 476, Clone 3, Gen 175)
03:47:24:WU01:FS01:0x21:Unit: 0x000000cf0002894b5a833fad00e21f36
03:47:24:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:47:24:WU01:FS01:0x21:Machine: 1
03:47:24:WU01:FS01:0x21:Reading tar file core.xml
03:47:24:WU01:FS01:0x21:Reading tar file integrator.xml
03:47:24:WU01:FS01:0x21:Reading tar file state.xml
03:47:24:WU01:FS01:0x21:Reading tar file system.xml
03:47:24:WU01:FS01:0x21:Digital signatures verified
03:47:24:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:47:24:WU01:FS01:0x21:Version 0.0.18
03:47:24:WU01:FS01:0x21:ERROR:126: Bad platformId size.
03:47:24:WU01:FS01:0x21:Saving result file logfile_01.txt
03:47:24:WU01:FS01:0x21:Saving result file log.txt
03:47:24:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:47:24:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:47:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13783 run:476 clone:3 gen:175 core:0x21 unit:0x000000cf0002894b5a833fad00e21f36
03:47:24:WU01:FS01:Uploading 1.89KiB to 155.247.166.219
03:47:24:WU01:FS01:Connecting to 155.247.166.219:8080
03:47:24:WU01:FS01:Upload complete
03:47:24:WU01:FS01:Server responded WORK_ACK (400)
03:47:24:WU01:FS01:Cleaning up
03:47:24:WU02:FS01:Connecting to 171.67.108.45:80
03:47:24:WU02:FS01:Assigned to work server 155.247.166.219
03:47:24:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186 from 155.247.166.219
03:47:24:WU02:FS01:Connecting to 155.247.166.219:8080
03:47:26:WU02:FS01:Downloading 904.80KiB
03:47:26:WU02:FS01:Download complete
03:47:26:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13783 run:73 clone:1 gen:163 core:0x21 unit:0x000000b10002894b5a833f72b3dde0d4
03:47:26:WU02:FS01:Starting
03:47:26:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dima\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 4852 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:47:26:WU02:FS01:Started FahCore on PID 2324
03:47:26:WU02:FS01:Core PID:10168
03:47:26:WU02:FS01:FahCore 0x21 started
03:47:27:WU02:FS01:0x21:*********************** Log Started 2018-05-04T03:47:26Z ***********************
03:47:27:WU02:FS01:0x21:Project: 13783 (Run 73, Clone 1, Gen 163)
03:47:27:WU02:FS01:0x21:Unit: 0x000000b10002894b5a833f72b3dde0d4
03:47:27:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:47:27:WU02:FS01:0x21:Machine: 1
03:47:27:WU02:FS01:0x21:Reading tar file core.xml
03:47:27:WU02:FS01:0x21:Reading tar file integrator.xml
03:47:27:WU02:FS01:0x21:Reading tar file state.xml
03:47:27:WU02:FS01:0x21:Reading tar file system.xml
03:47:27:WU02:FS01:0x21:Digital signatures verified
03:47:27:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:47:27:WU02:FS01:0x21:Version 0.0.18
03:47:27:WU02:FS01:0x21:ERROR:126: Bad platformId size.
03:47:27:WU02:FS01:0x21:Saving result file logfile_01.txt
03:47:27:WU02:FS01:0x21:Saving result file log.txt
03:47:27:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:47:27:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:47:27:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13783 run:73 clone:1 gen:163 core:0x21 unit:0x000000b10002894b5a833f72b3dde0d4
03:47:27:WU02:FS01:Uploading 1.89KiB to 155.247.166.219
03:47:27:WU02:FS01:Connecting to 155.247.166.219:8080
03:47:27:WU02:FS01:Upload complete
03:47:27:WU02:FS01:Server responded WORK_ACK (400)
03:47:27:WU02:FS01:Cleaning up
03:47:27:WU01:FS01:Connecting to 171.67.108.45:80
03:47:28:WU01:FS01:Assigned to work server 155.247.166.219
03:47:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186 from 155.247.166.219
03:47:28:WU01:FS01:Connecting to 155.247.166.219:8080
03:47:29:WU01:FS01:Downloading 905.11KiB
03:47:29:WU01:FS01:Download complete
03:47:29:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13782 run:769 clone:0 gen:192 core:0x21 unit:0x000000d00002894b5a78cf1347865d75
03:47:29:WU01:FS01:Starting
03:47:29:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dima\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4852 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:47:29:WU01:FS01:Started FahCore on PID 10380
03:47:29:WU01:FS01:Core PID:7024
03:47:29:WU01:FS01:FahCore 0x21 started
03:47:30:WU01:FS01:0x21:*********************** Log Started 2018-05-04T03:47:29Z ***********************
03:47:30:WU01:FS01:0x21:Project: 13782 (Run 769, Clone 0, Gen 192)
03:47:30:WU01:FS01:0x21:Unit: 0x000000d00002894b5a78cf1347865d75
03:47:30:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:47:30:WU01:FS01:0x21:Machine: 1
03:47:30:WU01:FS01:0x21:Reading tar file core.xml
03:47:30:WU01:FS01:0x21:Reading tar file integrator.xml
03:47:30:WU01:FS01:0x21:Reading tar file state.xml
03:47:30:WU01:FS01:0x21:Reading tar file system.xml
03:47:30:WU01:FS01:0x21:Digital signatures verified
03:47:30:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:47:30:WU01:FS01:0x21:Version 0.0.18
03:47:30:WU01:FS01:0x21:ERROR:126: Bad platformId size.
03:47:30:WU01:FS01:0x21:Saving result file logfile_01.txt
03:47:30:WU01:FS01:0x21:Saving result file log.txt
03:47:30:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:47:30:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:47:30:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13782 run:769 clone:0 gen:192 core:0x21 unit:0x000000d00002894b5a78cf1347865d75
03:47:30:WU01:FS01:Uploading 1.88KiB to 155.247.166.219
03:47:30:WU01:FS01:Connecting to 155.247.166.219:8080
03:47:30:WU01:FS01:Upload complete
03:47:30:WU01:FS01:Server responded WORK_ACK (400)
03:47:30:WU01:FS01:Cleaning up
03:47:30:WU02:FS01:Connecting to 171.67.108.45:80
03:47:31:WU02:FS01:Assigned to work server 140.163.4.231
03:47:31:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186 from 140.163.4.231
03:47:31:WU02:FS01:Connecting to 140.163.4.231:8080
03:47:31:WU02:FS01:Downloading 16.53MiB
03:47:32:WU02:FS01:Download complete
03:47:33:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11713 run:7 clone:82 gen:154 core:0x21 unit:0x000000ac8ca304e75a5a521e3dcca427
03:47:33:WU02:FS01:Starting
03:47:33:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dima\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 4852 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:47:33:WU02:FS01:Started FahCore on PID 11520
03:47:33:WU02:FS01:Core PID:11828
03:47:33:WU02:FS01:FahCore 0x21 started
03:47:33:WU02:FS01:0x21:*********************** Log Started 2018-05-04T03:47:33Z ***********************
03:47:33:WU02:FS01:0x21:Project: 11713 (Run 7, Clone 82, Gen 154)
03:47:33:WU02:FS01:0x21:Unit: 0x000000ac8ca304e75a5a521e3dcca427
03:47:33:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:47:33:WU02:FS01:0x21:Machine: 1
03:47:33:WU02:FS01:0x21:Reading tar file core.xml
03:47:33:WU02:FS01:0x21:Reading tar file integrator.xml
03:47:33:WU02:FS01:0x21:Reading tar file state.xml
03:47:33:WU02:FS01:0x21:Reading tar file system.xml
03:47:33:WU02:FS01:0x21:Digital signatures verified
03:47:33:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:47:33:WU02:FS01:0x21:Version 0.0.18
03:47:33:WU02:FS01:0x21:ERROR:126: Bad platformId size.
03:47:33:WU02:FS01:0x21:Saving result file logfile_01.txt
03:47:33:WU02:FS01:0x21:Saving result file log.txt
03:47:33:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:47:34:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:47:34:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11713 run:7 clone:82 gen:154 core:0x21 unit:0x000000ac8ca304e75a5a521e3dcca427
03:47:34:WU02:FS01:Uploading 5.50KiB to 140.163.4.231
03:47:34:WU02:FS01:Connecting to 140.163.4.231:8080
03:47:34:WU02:FS01:Upload complete
03:47:34:WU02:FS01:Server responded WORK_ACK (400)
03:47:34:WU02:FS01:Cleaning up
03:47:34:WU01:FS01:Connecting to 171.67.108.45:80
03:47:34:WU01:FS01:Assigned to work server 140.163.4.231
03:47:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186 from 140.163.4.231
03:47:34:WU01:FS01:Connecting to 140.163.4.231:8080
03:47:35:WU01:FS01:Downloading 16.52MiB
03:47:36:WU01:FS01:Download complete
03:47:36:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11713 run:20 clone:141 gen:95 core:0x21 unit:0x000000708ca304e75a5cfe20bb03248a
03:47:36:WU01:FS01:Starting
03:47:36:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dima\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4852 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:47:36:WU01:FS01:Started FahCore on PID 3352
03:47:36:WU01:FS01:Core PID:5568
03:47:36:WU01:FS01:FahCore 0x21 started
03:47:37:WU01:FS01:0x21:*********************** Log Started 2018-05-04T03:47:36Z ***********************
03:47:37:WU01:FS01:0x21:Project: 11713 (Run 20, Clone 141, Gen 95)
03:47:37:WU01:FS01:0x21:Unit: 0x000000708ca304e75a5cfe20bb03248a
03:47:37:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:47:37:WU01:FS01:0x21:Machine: 1
03:47:37:WU01:FS01:0x21:Reading tar file core.xml
03:47:37:WU01:FS01:0x21:Reading tar file integrator.xml
03:47:37:WU01:FS01:0x21:Reading tar file state.xml
03:47:37:WU01:FS01:0x21:Reading tar file system.xml
03:47:37:WU01:FS01:0x21:Digital signatures verified
03:47:37:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:47:37:WU01:FS01:0x21:Version 0.0.18
03:47:37:WU01:FS01:0x21:ERROR:126: Bad platformId size.
03:47:37:WU01:FS01:0x21:Saving result file logfile_01.txt
03:47:37:WU01:FS01:0x21:Saving result file log.txt
03:47:37:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:47:37:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:47:37:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11713 run:20 clone:141 gen:95 core:0x21 unit:0x000000708ca304e75a5cfe20bb03248a
03:47:37:WU01:FS01:Uploading 5.50KiB to 140.163.4.231
03:47:37:WU01:FS01:Connecting to 140.163.4.231:8080
03:47:37:WU01:FS01:Upload complete
03:47:37:WU01:FS01:Server responded WORK_ACK (400)
03:47:37:WU01:FS01:Cleaning up
03:47:37:WU02:FS01:Connecting to 171.67.108.45:80
03:47:38:WU02:FS01:Assigned to work server 140.163.4.231
03:47:38:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186 from 140.163.4.231
03:47:38:WU02:FS01:Connecting to 140.163.4.231:8080
03:47:38:WU02:FS01:Downloading 16.51MiB
03:47:40:WU02:FS01:Download complete
03:47:40:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11713 run:12 clone:189 gen:42 core:0x21 unit:0x000000328ca304e75adf7783cef9d1a0
03:47:40:WU02:FS01:Starting
03:47:40:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dima\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 4852 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:47:40:WU02:FS01:Started FahCore on PID 9536
03:47:40:WU02:FS01:Core PID:616
03:47:40:WU02:FS01:FahCore 0x21 started
03:47:41:WU02:FS01:0x21:*********************** Log Started 2018-05-04T03:47:40Z ***********************
03:47:41:WU02:FS01:0x21:Project: 11713 (Run 12, Clone 189, Gen 42)
03:47:41:WU02:FS01:0x21:Unit: 0x000000328ca304e75adf7783cef9d1a0
03:47:41:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:47:41:WU02:FS01:0x21:Machine: 1
03:47:41:WU02:FS01:0x21:Reading tar file core.xml
03:47:41:WU02:FS01:0x21:Reading tar file integrator.xml
03:47:41:WU02:FS01:0x21:Reading tar file state.xml
03:47:41:WU02:FS01:0x21:Reading tar file system.xml
03:47:41:WU02:FS01:0x21:Digital signatures verified
03:47:41:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:47:41:WU02:FS01:0x21:Version 0.0.18
03:47:41:WU02:FS01:0x21:ERROR:126: Bad platformId size.
03:47:41:WU02:FS01:0x21:Saving result file logfile_01.txt
03:47:41:WU02:FS01:0x21:Saving result file log.txt
03:47:41:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:47:41:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:47:41:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11713 run:12 clone:189 gen:42 core:0x21 unit:0x000000328ca304e75adf7783cef9d1a0
03:47:41:WU02:FS01:Uploading 5.50KiB to 140.163.4.231
03:47:41:WU02:FS01:Connecting to 140.163.4.231:8080
03:47:41:WU02:FS01:Upload complete
03:47:42:WU02:FS01:Server responded WORK_ACK (400)
03:47:42:WU02:FS01:Cleaning up
03:47:42:WU01:FS01:Connecting to 171.67.108.45:80
03:47:42:WU01:FS01:Assigned to work server 140.163.4.231
03:47:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186 from 140.163.4.231
03:47:42:WU01:FS01:Connecting to 140.163.4.231:8080
03:47:42:WU01:FS01:Downloading 16.52MiB
03:47:44:WU01:FS01:Download complete
03:47:44:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11713 run:5 clone:39 gen:153 core:0x21 unit:0x000000b08ca304e759d021c170d6e8a9
03:47:44:WU01:FS01:Starting
03:47:44:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dima\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4852 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:47:44:WU01:FS01:Started FahCore on PID 6956
03:47:44:WU01:FS01:Core PID:7884
03:47:44:WU01:FS01:FahCore 0x21 started
03:47:44:WU01:FS01:0x21:*********************** Log Started 2018-05-04T03:47:44Z ***********************
03:47:44:WU01:FS01:0x21:Project: 11713 (Run 5, Clone 39, Gen 153)
03:47:44:WU01:FS01:0x21:Unit: 0x000000b08ca304e759d021c170d6e8a9
03:47:44:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:47:44:WU01:FS01:0x21:Machine: 1
03:47:44:WU01:FS01:0x21:Reading tar file core.xml
03:47:44:WU01:FS01:0x21:Reading tar file integrator.xml
03:47:44:WU01:FS01:0x21:Reading tar file state.xml
03:47:44:WU01:FS01:0x21:Reading tar file system.xml
03:47:45:WU01:FS01:0x21:Digital signatures verified
03:47:45:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:47:45:WU01:FS01:0x21:Version 0.0.18
03:47:45:WU01:FS01:0x21:ERROR:126: Bad platformId size.
03:47:45:WU01:FS01:0x21:Saving result file logfile_01.txt
03:47:45:WU01:FS01:0x21:Saving result file log.txt
03:47:45:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:47:45:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:47:45:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11713 run:5 clone:39 gen:153 core:0x21 unit:0x000000b08ca304e759d021c170d6e8a9
03:47:45:WU01:FS01:Uploading 5.50KiB to 140.163.4.231
03:47:45:WU01:FS01:Connecting to 140.163.4.231:8080
03:47:45:WU01:FS01:Upload complete
03:47:45:WU01:FS01:Server responded WORK_ACK (400)
03:47:45:WU01:FS01:Cleaning up
03:47:45:WU02:FS01:Connecting to 171.67.108.45:80
03:47:46:WU02:FS01:Assigned to work server 155.247.166.219
03:47:46:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186 from 155.247.166.219
03:47:46:WU02:FS01:Connecting to 155.247.166.219:8080
03:47:47:WU02:FS01:Downloading 903.03KiB
03:47:47:WU02:FS01:Download complete
03:47:47:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13783 run:628 clone:3 gen:159 core:0x21 unit:0x000000b40002894b5a833fc66289df96
03:47:47:WU02:FS01:Starting
03:47:47:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dima\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 4852 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:47:47:WU02:FS01:Started FahCore on PID 2052
03:47:47:WU02:FS01:Core PID:6508
03:47:47:WU02:FS01:FahCore 0x21 started
03:47:48:WU02:FS01:0x21:*********************** Log Started 2018-05-04T03:47:47Z ***********************
03:47:48:WU02:FS01:0x21:Project: 13783 (Run 628, Clone 3, Gen 159)
03:47:48:WU02:FS01:0x21:Unit: 0x000000b40002894b5a833fc66289df96
03:47:48:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:47:48:WU02:FS01:0x21:Machine: 1
03:47:48:WU02:FS01:0x21:Reading tar file core.xml
03:47:48:WU02:FS01:0x21:Reading tar file integrator.xml
03:47:48:WU02:FS01:0x21:Reading tar file state.xml
03:47:48:WU02:FS01:0x21:Reading tar file system.xml
03:47:48:WU02:FS01:0x21:Digital signatures verified
03:47:48:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:47:48:WU02:FS01:0x21:Version 0.0.18
03:47:48:WU02:FS01:0x21:ERROR:126: Bad platformId size.
03:47:48:WU02:FS01:0x21:Saving result file logfile_01.txt
03:47:48:WU02:FS01:0x21:Saving result file log.txt
03:47:48:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:47:48:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:47:48:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13783 run:628 clone:3 gen:159 core:0x21 unit:0x000000b40002894b5a833fc66289df96
03:47:48:WU02:FS01:Uploading 1.88KiB to 155.247.166.219
03:47:48:WU02:FS01:Connecting to 155.247.166.219:8080
03:47:48:WU02:FS01:Upload complete
03:47:48:WU02:FS01:Server responded WORK_ACK (400)
03:47:48:WU02:FS01:Cleaning up
03:47:48:WU01:FS01:Connecting to 171.67.108.45:80
03:47:49:WU01:FS01:Assigned to work server 155.247.166.219
03:47:49:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186 from 155.247.166.219
03:47:49:WU01:FS01:Connecting to 155.247.166.219:8080
03:47:50:WU01:FS01:Downloading 904.00KiB
03:47:51:WU01:FS01:Download complete
03:47:51:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13782 run:703 clone:2 gen:145 core:0x21 unit:0x000000a40002894b5a78cf0e2009a427
03:47:51:WU01:FS01:Starting
03:47:51:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Dima\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4852 -checkpoint 15 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
03:47:51:WU01:FS01:Started FahCore on PID 1908
03:47:51:WU01:FS01:Core PID:11088
03:47:51:WU01:FS01:FahCore 0x21 started
03:47:52:WU01:FS01:0x21:*********************** Log Started 2018-05-04T03:47:51Z ***********************
03:47:52:WU01:FS01:0x21:Project: 13782 (Run 703, Clone 2, Gen 145)
03:47:52:WU01:FS01:0x21:Unit: 0x000000a40002894b5a78cf0e2009a427
03:47:52:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:47:52:WU01:FS01:0x21:Machine: 1
03:47:52:WU01:FS01:0x21:Reading tar file core.xml
03:47:52:WU01:FS01:0x21:Reading tar file integrator.xml
03:47:52:WU01:FS01:0x21:Reading tar file state.xml
03:47:52:WU01:FS01:0x21:Reading tar file system.xml
03:47:52:WU01:FS01:0x21:Digital signatures verified
03:47:52:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:47:52:WU01:FS01:0x21:Version 0.0.18
03:47:52:WU01:FS01:0x21:ERROR:126: Bad platformId size.
03:47:52:WU01:FS01:0x21:Saving result file logfile_01.txt
03:47:52:WU01:FS01:0x21:Saving result file log.txt
03:47:52:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:47:52:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:47:52:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13782 run:703 clone:2 gen:145 core:0x21 unit:0x000000a40002894b5a78cf0e2009a427
03:47:52:WU01:FS01:Uploading 1.88KiB to 155.247.166.219
03:47:52:WU01:FS01:Connecting to 155.247.166.219:8080
03:47:52:WU01:FS01:Upload complete
03:47:52:WU01:FS01:Server responded WORK_ACK (400)
03:47:52:WU01:FS01:Cleaning up
Posts: 2040 Joined: Sat Dec 01, 2012 3:43 pm
Hardware configuration: Folding@Home Client 7.6.13 (1 GPU slots) Windows 7 64bit Intel Core i5 2500k@4Ghz Nvidia gtx 1080ti driver 441
Post
by foldy » Fri May 04, 2018 8:03 am
These nvidia 397 drivers are evil, they also crash my GTA V and many other gamers are complaining. The latest 397.55 hotfix driver does not address any of the issues. If we have FAH problems with these drivers we need to report this at nvidia.
This is the current nvidia driver forum thread
https://forums.geforce.com/default/topi ... er-397-55/
This is the nvidia report feedback site
http://www.nvidia.com/object/driverqual ... rance.html
Posts: 6516 Joined: Sun Dec 02, 2007 10:38 am
Post
by toTOW » Fri May 04, 2018 10:09 am
phrost wrote: 03:37:11: OpenCL: Not detected: clGetPlatformIDs() returned -1001
Something broke your OpenCL installation ...
The error number means that the OpenCL platform called hasn't been found.
Either OpenCL in these drivers is broken, or you have conflicting platforms installed (more than one, the NV one).
edit : by the way, 397.31 are doing fine on my 3 machines (980/980M/1070 on Windows 10 64 bits).
