No appropriate work server was available
zoidbergo
Post by zoidbergo »
My client is stuck at "Attempting to get work packet". Tried turning my firewall off, didn't change the problem. Running windows 7, Nvidia GTX 1060.
Here's my log file:
[16:14:06] - Ask before connecting: Yes
[16:14:06] - User name: zoidbergo (Team 12679)
[16:14:06] - User ID: 6CB79FC5AD9692C
[16:14:06] - Machine ID: 1
[16:14:06]
[16:14:06] Loaded queue successfully.
[16:14:06] Initialization complete
[16:14:06] - Preparing to get new work unit...
[16:14:06] - Presenting message box asking to network.
[16:14:08] + Attempting to get work packet
[16:14:08] - Connecting to assignment server
[16:14:08] + No appropriate work server was available; will try again in a bit.
[16:14:08] + Couldn't get work instructions.
[16:14:08] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[16:14:17] + Attempting to get work packet
[16:14:17] - Connecting to assignment server
[16:14:17] + No appropriate work server was available; will try again in a bit.
[16:14:17] + Couldn't get work instructions.
[16:14:17] - Attempt #2  to get work failed, and no other work to do.
[16:14:34] + Attempting to get work packet
[16:14:34] - Connecting to assignment server
Any ideas?
bollix47
Re: No appropriate work server was available
Post by bollix47 »
Welcome to the folding@home support forum zoidbergo.
One of the more commonly used servers is down at the moment. Returning finished work to it and getting new work from it won't be possible until it is 'fixed'. Other servers are handing out work but sometimes it takes a while to get a WU from them due to lower availability.
We are seeing a lot of reports for the same problem ... we can only be patient until the problems at Stanford are corrected.
Issue is being discussed here : viewtopic.php?f=18&t=30766
zoidbergo
Post by zoidbergo »
From that thread it seems like the server is back up, but I haven't seen any change. I'm still trying every day but my problem persists.
bollix47
Post by bollix47 »
We would need to see the first 100 lines of your log.txt file which shows your system setup and your folding configuration. The log you've supplied above doesn't look like a version 7 log. Where did you get it? If you installed using the defaults log.txt should be in your Data Directory. Since you're using windows you should be able to access that directory via Start > All Programs > Fahclient > Data Directory.
Here's a link that might help you find and post the correct log:
viewtopic.php?f=24&t=26036
p.s. If you're still using version 6 (which the supplied log suggests) switching to version 7 would be advisable:
http://folding.stanford.edu/start-folding/
zoidbergo
Post by zoidbergo »
I can't believe it took me this long to figure out I just downloaded an old version. The new version works. Thanks!
