ERROR:WU00:FS00:Exception: Failed to connect
holybear
Post by holybear »
Good evening everyone!
Kind of a very stupid question.
I was trying to use FAH for the very first time today. Everything seemed to be ok, but for some reason I decided to reinstall it. And this is where problem occured. Each time now I have got the same error.
19:17:02:WU00:FS00:Downloading core from http....://fahwebx.stanford.edu/cores/Linux/AMD64/Core_a4.fah
19:17:02:WU00:FS00:Connecting to fahwebx.stanford.edu:80
91m19:17:03:ERROR:WU00:FS00:Exception: Failed to connect to fahwebx.stanford.edu:80: Connection refused
Could someone please give me a piece of advise how I can fix that?
Log file is attached.
*********************** Log Started 2018-04-03T19:11:47Z ***********************
19:11:47:************************* Folding@home Client *************************
19:11:47:    Website: http://folding.stanford.edu/
19:11:47:  Copyright: (c) 2009-2014 Stanford University
19:11:47:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:11:47:       Args:
19:11:47:     Config: /home/mykhailo/config.xml
19:11:47:******************************** Build ********************************
19:11:47:    Version: 7.4.4
19:11:47:       Date: Mar 4 2014
19:11:47:       Time: 12:02:38
19:11:47:    SVN Rev: 4130
19:11:47:     Branch: fah/trunk/client
19:11:47:   Compiler: GNU 4.4.7
19:11:47:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
19:11:47:             -fno-unsafe-math-optimizations -msse2
19:11:47:   Platform: linux2 3.2.0-1-amd64
19:11:47:       Bits: 64
19:11:47:       Mode: Release
19:11:47:******************************* System ********************************
19:11:47:        CPU: Intel(R) Core(TM) i3 CPU M 380 @ 2.53GHz
19:11:47:     CPU ID: GenuineIntel Family 6 Model 37 Stepping 5
19:11:47:       CPUs: 4
19:11:47:     Memory: 3.54GiB
19:11:47:Free Memory: 172.40MiB
19:11:47:    Threads: POSIX_THREADS
19:11:47: OS Version: 4.4
19:11:47:Has Battery: true
19:11:47: On Battery: false
19:11:47: UTC Offset: 2
19:11:47:        PID: 4775
19:11:47:        CWD: /home/mykhailo
19:11:47:         OS: Linux 4.4.0-116-generic x86_64
19:11:47:    OS Arch: AMD64
19:11:47:       GPUs: 1
19:11:47:      GPU 0: NVIDIA:2 GF106 [GeForce GT 555M SDDR3]
19:11:47:       CUDA: Not detected
19:11:47:***********************************************************************
19:11:47:<config>
19:11:47:  <!-- Folding Slots -->
19:11:47:  <slot id='0' type='CPU'/>
19:11:47:  <slot id='1' type='GPU'/>
19:11:47:</config>
19:11:47:Trying to access database...
19:11:47:Successfully acquired database lock
19:11:47:Enabled folding slot 00: READY cpu:2
19:11:47:Enabled folding slot 01: PAUSED gpu:0:GF106 [GeForce GT 555M SDDR3] (waiting for idle)
[91m19:11:47:ERROR:Exception: Could not bind socket to 0.0.0.0:7396: Address already in use[0m
[91m19:11:47:ERROR:Exception: Could not bind socket to 0.0.0.0:36330: Address already in use[0m
19:11:47:WU00:FS00:Downloading core from http://fahwebx.stanford.edu/cores/Linux/AMD64/Core_a4.fah
19:11:47:WU00:FS00:Connecting to fahwebx.stanford.edu:80
[91m19:11:48:ERROR:WU00:FS00:Exception: Failed to connect to fahwebx.stanford.edu:80: Connection refused[0m
19:12:47:WU00:FS00:Downloading core from http://fahwebx.stanford.edu/cores/Linux/AMD64/Core_a4.fah
19:12:47:WU00:FS00:Connecting to fahwebx.stanford.edu:80
[91m19:12:48:ERROR:WU00:FS00:Exception: Failed to connect to fahwebx.stanford.edu:80: Connection refused[0m
19:14:25:WU00:FS00:Downloading core from http://fahwebx.stanford.edu/cores/Linux/AMD64/Core_a4.fah
19:14:25:WU00:FS00:Connecting to fahwebx.stanford.edu:80
[91m19:14:25:ERROR:WU00:FS00:Exception: Failed to connect to fahwebx.stanford.edu:80: Connection refused[0m
19:17:02:WU00:FS00:Downloading core from http://fahwebx.stanford.edu/cores/Linux/AMD64/Core_a4.fah
[91m19:17:03:ERROR:WU00:FS00:Exception: Failed to connect to fahwebx.stanford.edu:80: Connection refused[0m
19:18:32:Caught signal SIGHUP(1) on PID 4775
19:18:32:Exiting, please wait. . .
19:18:33:Clean exit
Re: ERROR:WU00:FS00:Exception: Failed to connect
That server seems to have gone off-line. The staff that fix the problem have been notified.
Please be patient.
