Fahwebx Appears to be Offline [was folding CPU]
tbolt38
Post by tbolt38 »
the link for the folding@home CPU isn't working...please advise.
Thank you,
Re: folding CPU
What link is that?
What were you trying to do? Can you post the log?
tbolt38
Re: folding CPU
Post by tbolt38 »
it is the link from your folding@home cpu...http://fahwebx.stanford.edu/nacl/?team=234020
says site can't be reached....it was working earlier this week/last week
Re: folding CPU
There appears to be a problem with this server, I have contacted some people to look into this.
BlackLotus
Need Help! Failed to connect to fahwebx.stanford.edu:80 ERRO
Post by BlackLotus »
Merged with existing topic - j
Brand new to FAH. Downloaded desktop application for Windows 7. Getting the following error. Checked antivirus and performed a reboot. As a result, I'm just stuck in Ready status. Any ideas on how to fix this? Also can't access the Chrome FAH Web App.
Thanks in advance for any insight!
*********************** Log Started 2018-04-04T01:49:59Z ***********************
01:49:59:************************* Folding@home Client *************************
01:49:59:      Website: http://folding.stanford.edu/
01:49:59:    Copyright: (c) 2009-2014 Stanford University
01:49:59:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:49:59:         Args:
01:49:59:       Config: C:/Users/Rodriguez/AppData/Roaming/FAHClient/config.xml
01:49:59:******************************** Build ********************************
01:49:59:      Version: 7.4.4
01:49:59:         Date: Mar 4 2014
01:49:59:         Time: 20:26:54
01:49:59:      SVN Rev: 4130
01:49:59:       Branch: fah/trunk/client
01:49:59:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:49:59:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:49:59:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
01:49:59:     Platform: win32 XP
01:49:59:         Bits: 32
01:49:59:         Mode: Release
01:49:59:******************************* System ********************************
01:49:59:          CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
01:49:59:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
01:49:59:         CPUs: 4
01:49:59:       Memory: 7.90GiB
01:49:59:  Free Memory: 5.17GiB
01:49:59:      Threads: WINDOWS_THREADS
01:49:59:   OS Version: 6.1
01:49:59:  Has Battery: false
01:49:59:   On Battery: false
01:49:59:   UTC Offset: -5
01:49:59:          PID: 1928
01:49:59:          CWD: C:/Users/Rodriguez/AppData/Roaming/FAHClient
01:49:59:           OS: Windows 7 Home Premium
01:49:59:      OS Arch: AMD64
01:49:59:         GPUs: 0
01:49:59:         CUDA: Not detected
01:49:59:Win32 Service: false
01:49:59:***********************************************************************
01:49:59:<config>
01:49:59:  <!-- Slot Control -->
01:49:59:  <power v='full'/>
01:49:59:
01:49:59:  <!-- User Information -->
01:49:59:  <passkey v='********************************'/>
01:49:59:  <team v='224497'/>
01:49:59:  <user v='BlackLotus'/>
01:49:59:
01:49:59:  <!-- Folding Slots -->
01:49:59:  <slot id='0' type='CPU'/>
01:49:59:</config>
01:49:59:Trying to access database...
01:49:59:Successfully acquired database lock
01:49:59:Enabled folding slot 00: READY cpu:4
01:50:00:WU00:FS00:Downloading core from http://fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah
01:50:00:WU00:FS00:Connecting to fahwebx.stanford.edu:80
01:50:01:ERROR:WU00:FS00:Exception: Failed to connect to fahwebx.stanford.edu:80: No connection could be made because the target machine actively refused it.
01:51:00:WU00:FS00:Downloading core from http://fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah
01:51:00:WU00:FS00:Connecting to fahwebx.stanford.edu:80
01:51:01:ERROR:WU00:FS00:Exception: Failed to connect to fahwebx.stanford.edu:80: No connection could be made because the target machine actively refused it.
Re: Fahwebx Appears to be Offline [was folding CPU]
The fahwebx.stanford.edu server should be operating properly now. The NaCl client is working again and I tested a download of a folding core from one of my systems.
BlackLotus
Thanks! Both are working now.
Also found out that I was trying to use my secondary user account and the FAH Windows files are stored on the Primary user account. Had to switch to Primary user to avoid an additional error.
