*********************** Log Started 2018-03-24T22:40:18Z ***********************
02:47:39:WU01:FS01:Connecting to 171.67.108.45:80
02:47:39:WU01:FS01:Assigned to work server 155.247.166.219
02:47:39:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950] from 155.247.166.219
02:47:39:WU01:FS01:Connecting to 155.247.166.219:8080
02:48:00:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:48:00:WU01:FS01:Connecting to 155.247.166.219:80
02:48:21:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:48:22:WU01:FS01:Connecting to 171.67.108.45:80
02:48:22:WU01:FS01:Assigned to work server 155.247.166.219
02:48:22:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950] from 155.247.166.219
02:48:22:WU01:FS01:Connecting to 155.247.166.219:8080
02:48:43:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:48:43:WU01:FS01:Connecting to 155.247.166.219:80
02:49:04:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:49:22:WU01:FS01:Connecting to 171.67.108.45:80
02:49:22:WU01:FS01:Assigned to work server 155.247.166.219
02:49:22:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950] from 155.247.166.219
02:49:22:WU01:FS01:Connecting to 155.247.166.219:8080
02:49:43:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:49:43:WU01:FS01:Connecting to 155.247.166.219:80
02:50:04:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:50:59:WU01:FS01:Connecting to 171.67.108.45:80
02:50:59:WU01:FS01:Assigned to work server 155.247.166.219
02:50:59:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950] from 155.247.166.219
02:50:59:WU01:FS01:Connecting to 155.247.166.219:8080
02:51:20:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:51:20:WU01:FS01:Connecting to 155.247.166.219:80
02:51:41:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:53:36:WU01:FS01:Connecting to 171.67.108.45:80
02:53:37:WU01:FS01:Assigned to work server 155.247.166.219
02:53:37:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950] from 155.247.166.219
02:53:37:WU01:FS01:Connecting to 155.247.166.219:8080
02:53:41:WU01:FS01:Downloading 902.13KiB
02:53:47:WU01:FS01:Download 14.19%
02:53:52:WU01:FS01:Download complete
02:53:52:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13781 run:505 clone:1 gen:42 core:0x21 unit:0x0000002a0002894b5a8264ba3e971c73
02:53:52:WU01:FS01:Starting
02:53:52:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 7820 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
02:53:52:WU01:FS01:Started FahCore on PID 10264
02:53:52:WU01:FS01:Core PID:14788
02:53:52:WU01:FS01:FahCore 0x21 started
02:53:52:WU01:FS01:0x21:*********************** Log Started 2018-03-25T02:53:52Z ***********************
02:53:52:WU01:FS01:0x21:Project: 13781 (Run 505, Clone 1, Gen 42)
02:53:52:WU01:FS01:0x21:Unit: 0x0000002a0002894b5a8264ba3e971c73
02:53:52:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
02:53:52:WU01:FS01:0x21:Machine: 1
02:53:52:WU01:FS01:0x21:Reading tar file core.xml
02:53:52:WU01:FS01:0x21:Reading tar file integrator.xml
02:53:52:WU01:FS01:0x21:Reading tar file state.xml
02:53:52:WU01:FS01:0x21:Reading tar file system.xml
02:53:52:WU01:FS01:0x21:Digital signatures verified
02:53:52:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
02:53:52:WU01:FS01:0x21:Version 0.0.18
02:53:56:WU01:FS01:0x21:Completed 0 out of 5000000 steps (0%)
02:53:56:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:55:12:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 14788
02:55:12:WU01:FS01:0x21:Exiting, please wait. . .
02:55:12:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
02:55:13:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
03:03:05:WU01:FS01:Starting
03:03:05:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 7820 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
03:03:05:WU01:FS01:Started FahCore on PID 15376
03:03:05:WU01:FS01:Core PID:15296
03:03:05:WU01:FS01:FahCore 0x21 started
03:03:06:WU01:FS01:0x21:*********************** Log Started 2018-03-25T03:03:05Z ***********************
03:03:06:WU01:FS01:0x21:Project: 13781 (Run 505, Clone 1, Gen 42)
03:03:06:WU01:FS01:0x21:Unit: 0x0000002a0002894b5a8264ba3e971c73
03:03:06:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:03:06:WU01:FS01:0x21:Machine: 1
03:03:06:WU01:FS01:0x21:Digital signatures verified
03:03:06:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:03:06:WU01:FS01:0x21:Version 0.0.18
03:03:09:WU01:FS01:0x21:Completed 0 out of 5000000 steps (0%)
03:03:09:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:05:47:WU01:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
03:08:25:WU01:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
03:11:03:WU01:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
03:13:42:WU01:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
03:16:20:WU01:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
03:18:58:WU01:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
03:21:36:WU01:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
03:24:14:WU01:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
03:26:53:WU01:FS01:0x21:Completed 450000 out of 5000000 steps (9%)
03:29:31:WU01:FS01:0x21:Completed 500000 out of 5000000 steps (10%)
03:32:10:WU01:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
03:34:48:WU01:FS01:0x21:Completed 600000 out of 5000000 steps (12%)
03:37:27:WU01:FS01:0x21:Completed 650000 out of 5000000 steps (13%)
03:40:07:WU01:FS01:0x21:Completed 700000 out of 5000000 steps (14%)
03:42:46:WU01:FS01:0x21:Completed 750000 out of 5000000 steps (15%)
03:45:26:WU01:FS01:0x21:Completed 800000 out of 5000000 steps (16%)
03:48:06:WU01:FS01:0x21:Completed 850000 out of 5000000 steps (17%)
03:49:51:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 15296
03:49:51:WU01:FS01:0x21:Exiting, please wait. . .
03:49:52:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
03:49:52:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
******************************* Date: 2018-03-25 *******************************
04:47:29:WU01:FS01:Starting
04:47:29:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 7820 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
04:47:29:WU01:FS01:Started FahCore on PID 15104
04:47:29:WU01:FS01:Core PID:5292
04:47:29:WU01:FS01:FahCore 0x21 started
04:47:30:WU01:FS01:0x21:*********************** Log Started 2018-03-25T04:47:29Z ***********************
04:47:30:WU01:FS01:0x21:Project: 13781 (Run 505, Clone 1, Gen 42)
04:47:30:WU01:FS01:0x21:Unit: 0x0000002a0002894b5a8264ba3e971c73
04:47:30:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:47:30:WU01:FS01:0x21:Machine: 1
04:47:30:WU01:FS01:0x21:Digital signatures verified
04:47:30:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:47:30:WU01:FS01:0x21:Version 0.0.18
04:47:30:WU01:FS01:0x21: Found a checkpoint file
04:47:33:WU01:FS01:0x21:Completed 750000 out of 5000000 steps (15%)
04:47:33:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:50:12:WU01:FS01:0x21:Completed 800000 out of 5000000 steps (16%)
04:52:50:WU01:FS01:0x21:Completed 850000 out of 5000000 steps (17%)
04:55:29:WU01:FS01:0x21:Completed 900000 out of 5000000 steps (18%)
04:58:07:WU01:FS01:0x21:Completed 950000 out of 5000000 steps (19%)
05:00:46:WU01:FS01:0x21:Completed 1000000 out of 5000000 steps (20%)
05:03:24:WU01:FS01:0x21:Completed 1050000 out of 5000000 steps (21%)
05:06:03:WU01:FS01:0x21:Completed 1100000 out of 5000000 steps (22%)
05:08:41:WU01:FS01:0x21:Completed 1150000 out of 5000000 steps (23%)
05:11:19:WU01:FS01:0x21:Completed 1200000 out of 5000000 steps (24%)
05:13:57:WU01:FS01:0x21:Completed 1250000 out of 5000000 steps (25%)
05:16:36:WU01:FS01:0x21:Completed 1300000 out of 5000000 steps (26%)
05:19:14:WU01:FS01:0x21:Completed 1350000 out of 5000000 steps (27%)
05:21:52:WU01:FS01:0x21:Completed 1400000 out of 5000000 steps (28%)
05:24:31:WU01:FS01:0x21:Completed 1450000 out of 5000000 steps (29%)
05:27:10:WU01:FS01:0x21:Completed 1500000 out of 5000000 steps (30%)
05:29:48:WU01:FS01:0x21:Completed 1550000 out of 5000000 steps (31%)
05:32:27:WU01:FS01:0x21:Completed 1600000 out of 5000000 steps (32%)
05:35:05:WU01:FS01:0x21:Completed 1650000 out of 5000000 steps (33%)
05:37:43:WU01:FS01:0x21:Completed 1700000 out of 5000000 steps (34%)
05:40:21:WU01:FS01:0x21:Completed 1750000 out of 5000000 steps (35%)
05:43:00:WU01:FS01:0x21:Completed 1800000 out of 5000000 steps (36%)
05:45:38:WU01:FS01:0x21:Completed 1850000 out of 5000000 steps (37%)
05:48:16:WU01:FS01:0x21:Completed 1900000 out of 5000000 steps (38%)
05:50:55:WU01:FS01:0x21:Completed 1950000 out of 5000000 steps (39%)
05:53:33:WU01:FS01:0x21:Completed 2000000 out of 5000000 steps (40%)
05:56:12:WU01:FS01:0x21:Completed 2050000 out of 5000000 steps (41%)
05:58:52:WU01:FS01:0x21:Completed 2100000 out of 5000000 steps (42%)
06:01:30:WU01:FS01:0x21:Completed 2150000 out of 5000000 steps (43%)
06:04:09:WU01:FS01:0x21:Completed 2200000 out of 5000000 steps (44%)
06:06:48:WU01:FS01:0x21:Completed 2250000 out of 5000000 steps (45%)
06:09:28:WU01:FS01:0x21:Completed 2300000 out of 5000000 steps (46%)
06:12:07:WU01:FS01:0x21:Completed 2350000 out of 5000000 steps (47%)
06:14:46:WU01:FS01:0x21:Completed 2400000 out of 5000000 steps (48%)
06:17:25:WU01:FS01:0x21:Completed 2450000 out of 5000000 steps (49%)
06:20:03:WU01:FS01:0x21:Completed 2500000 out of 5000000 steps (50%)
06:22:43:WU01:FS01:0x21:Completed 2550000 out of 5000000 steps (51%)
06:25:21:WU01:FS01:0x21:Completed 2600000 out of 5000000 steps (52%)
06:28:00:WU01:FS01:0x21:Completed 2650000 out of 5000000 steps (53%)
06:30:39:WU01:FS01:0x21:Completed 2700000 out of 5000000 steps (54%)
06:33:18:WU01:FS01:0x21:Completed 2750000 out of 5000000 steps (55%)
06:35:57:WU01:FS01:0x21:Completed 2800000 out of 5000000 steps (56%)
06:38:35:WU01:FS01:0x21:Completed 2850000 out of 5000000 steps (57%)
06:41:14:WU01:FS01:0x21:Completed 2900000 out of 5000000 steps (58%)
06:43:53:WU01:FS01:0x21:Completed 2950000 out of 5000000 steps (59%)
06:46:32:WU01:FS01:0x21:Completed 3000000 out of 5000000 steps (60%)
06:49:11:WU01:FS01:0x21:Completed 3050000 out of 5000000 steps (61%)
06:51:50:WU01:FS01:0x21:Completed 3100000 out of 5000000 steps (62%)
06:54:28:WU01:FS01:0x21:Completed 3150000 out of 5000000 steps (63%)
06:57:06:WU01:FS01:0x21:Completed 3200000 out of 5000000 steps (64%)
06:59:45:WU01:FS01:0x21:Completed 3250000 out of 5000000 steps (65%)
07:02:24:WU01:FS01:0x21:Completed 3300000 out of 5000000 steps (66%)
07:05:03:WU01:FS01:0x21:Completed 3350000 out of 5000000 steps (67%)
07:07:41:WU01:FS01:0x21:Completed 3400000 out of 5000000 steps (68%)
07:10:20:WU01:FS01:0x21:Completed 3450000 out of 5000000 steps (69%)
07:12:58:WU01:FS01:0x21:Completed 3500000 out of 5000000 steps (70%)
07:15:37:WU01:FS01:0x21:Completed 3550000 out of 5000000 steps (71%)
07:18:15:WU01:FS01:0x21:Completed 3600000 out of 5000000 steps (72%)
07:20:54:WU01:FS01:0x21:Completed 3650000 out of 5000000 steps (73%)
07:23:33:WU01:FS01:0x21:Completed 3700000 out of 5000000 steps (74%)
07:26:11:WU01:FS01:0x21:Completed 3750000 out of 5000000 steps (75%)
07:28:50:WU01:FS01:0x21:Completed 3800000 out of 5000000 steps (76%)
07:31:28:WU01:FS01:0x21:Completed 3850000 out of 5000000 steps (77%)
07:34:07:WU01:FS01:0x21:Completed 3900000 out of 5000000 steps (78%)
07:36:45:WU01:FS01:0x21:Completed 3950000 out of 5000000 steps (79%)
07:39:23:WU01:FS01:0x21:Completed 4000000 out of 5000000 steps (80%)
07:42:01:WU01:FS01:0x21:Completed 4050000 out of 5000000 steps (81%)
07:44:40:WU01:FS01:0x21:Completed 4100000 out of 5000000 steps (82%)
07:47:18:WU01:FS01:0x21:Completed 4150000 out of 5000000 steps (83%)
07:49:57:WU01:FS01:0x21:Completed 4200000 out of 5000000 steps (84%)
07:52:35:WU01:FS01:0x21:Completed 4250000 out of 5000000 steps (85%)
07:55:14:WU01:FS01:0x21:Completed 4300000 out of 5000000 steps (86%)
07:57:52:WU01:FS01:0x21:Completed 4350000 out of 5000000 steps (87%)
08:00:30:WU01:FS01:0x21:Completed 4400000 out of 5000000 steps (88%)
08:03:09:WU01:FS01:0x21:Completed 4450000 out of 5000000 steps (89%)
08:05:47:WU01:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
08:08:26:WU01:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
08:11:04:WU01:FS01:0x21:Completed 4600000 out of 5000000 steps (92%)
08:13:43:WU01:FS01:0x21:Completed 4650000 out of 5000000 steps (93%)
08:16:21:WU01:FS01:0x21:Completed 4700000 out of 5000000 steps (94%)
08:18:59:WU01:FS01:0x21:Completed 4750000 out of 5000000 steps (95%)
08:21:38:WU01:FS01:0x21:Completed 4800000 out of 5000000 steps (96%)
08:24:17:WU01:FS01:0x21:Completed 4850000 out of 5000000 steps (97%)
08:26:55:WU01:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
08:29:33:WU01:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
08:32:11:WU01:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
08:32:12:WU01:FS01:0x21:Saving result file logfile_01.txt
08:32:12:WU01:FS01:0x21:Saving result file checkpointState.xml
08:32:12:WU01:FS01:0x21:Saving result file checkpt.crc
08:32:12:WU01:FS01:0x21:Saving result file log.txt
08:32:12:WU01:FS01:0x21:Saving result file positions.xtc
08:32:12:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
08:32:13:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:32:13:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13781 run:505 clone:1 gen:42 core:0x21 unit:0x0000002a0002894b5a8264ba3e971c73
08:32:13:WU01:FS01:Uploading 1.78MiB to 155.247.166.219
08:32:13:WU01:FS01:Connecting to 155.247.166.219:8080
08:32:34:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:32:34:WU01:FS01:Connecting to 155.247.166.219:80
08:32:55:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:32:55:WU01:FS01:Trying to send results to collection server
08:32:55:WU01:FS01:Uploading 1.78MiB to 155.247.166.220
08:32:55:WU01:FS01:Connecting to 155.247.166.220:8080
08:33:16:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:33:16:WU01:FS01:Connecting to 155.247.166.220:80
08:33:37:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:33:37:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13781 run:505 clone:1 gen:42 core:0x21 unit:0x0000002a0002894b5a8264ba3e971c73
08:33:37:WU01:FS01:Uploading 1.78MiB to 155.247.166.219
08:33:37:WU01:FS01:Connecting to 155.247.166.219:8080
08:33:58:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:33:58:WU01:FS01:Connecting to 155.247.166.219:80
08:34:19:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:34:19:WU01:FS01:Trying to send results to collection server
08:34:19:WU01:FS01:Uploading 1.78MiB to 155.247.166.220
08:34:19:WU01:FS01:Connecting to 155.247.166.220:8080
08:34:40:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:34:40:WU01:FS01:Connecting to 155.247.166.220:80
08:35:01:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:35:02:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13781 run:505 clone:1 gen:42 core:0x21 unit:0x0000002a0002894b5a8264ba3e971c73
08:35:02:WU01:FS01:Uploading 1.78MiB to 155.247.166.219
08:35:02:WU01:FS01:Connecting to 155.247.166.219:8080
08:35:23:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:35:23:WU01:FS01:Connecting to 155.247.166.219:80
08:35:44:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:35:44:WU01:FS01:Trying to send results to collection server
08:35:44:WU01:FS01:Uploading 1.78MiB to 155.247.166.220
08:35:44:WU01:FS01:Connecting to 155.247.166.220:8080
08:36:05:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:36:05:WU01:FS01:Connecting to 155.247.166.220:80
08:36:26:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:36:39:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13781 run:505 clone:1 gen:42 core:0x21 unit:0x0000002a0002894b5a8264ba3e971c73
08:36:39:WU01:FS01:Uploading 1.78MiB to 155.247.166.219
08:36:39:WU01:FS01:Connecting to 155.247.166.219:8080
08:37:00:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:37:00:WU01:FS01:Connecting to 155.247.166.219:80
08:37:21:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:37:21:WU01:FS01:Trying to send results to collection server
08:37:21:WU01:FS01:Uploading 1.78MiB to 155.247.166.220
08:37:21:WU01:FS01:Connecting to 155.247.166.220:8080
08:37:42:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:37:42:WU01:FS01:Connecting to 155.247.166.220:80
08:38:03:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:39:16:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13781 run:505 clone:1 gen:42 core:0x21 unit:0x0000002a0002894b5a8264ba3e971c73
08:39:16:WU01:FS01:Uploading 1.78MiB to 155.247.166.219
08:39:16:WU01:FS01:Connecting to 155.247.166.219:8080
08:39:37:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:39:37:WU01:FS01:Connecting to 155.247.166.219:80
08:39:58:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:39:58:WU01:FS01:Trying to send results to collection server
08:39:58:WU01:FS01:Uploading 1.78MiB to 155.247.166.220
08:39:58:WU01:FS01:Connecting to 155.247.166.220:8080
08:40:19:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:40:19:WU01:FS01:Connecting to 155.247.166.220:80
08:40:40:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:43:30:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13781 run:505 clone:1 gen:42 core:0x21 unit:0x0000002a0002894b5a8264ba3e971c73
08:43:30:WU01:FS01:Uploading 1.78MiB to 155.247.166.219
08:43:30:WU01:FS01:Connecting to 155.247.166.219:8080
08:43:51:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:43:51:WU01:FS01:Connecting to 155.247.166.219:80
08:44:12:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:44:12:WU01:FS01:Trying to send results to collection server
08:44:12:WU01:FS01:Uploading 1.78MiB to 155.247.166.220
08:44:12:WU01:FS01:Connecting to 155.247.166.220:8080
08:44:33:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:44:33:WU01:FS01:Connecting to 155.247.166.220:80
08:44:54:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:50:22:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13781 run:505 clone:1 gen:42 core:0x21 unit:0x0000002a0002894b5a8264ba3e971c73
08:50:22:WU01:FS01:Uploading 1.78MiB to 155.247.166.219
08:50:22:WU01:FS01:Connecting to 155.247.166.219:8080
08:50:43:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:50:43:WU01:FS01:Connecting to 155.247.166.219:80
08:51:04:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:51:04:WU01:FS01:Trying to send results to collection server
08:51:04:WU01:FS01:Uploading 1.78MiB to 155.247.166.220
08:51:04:WU01:FS01:Connecting to 155.247.166.220:8080
08:51:25:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
08:51:25:WU01:FS01:Connecting to 155.247.166.220:80
08:51:46:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:01:27:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13781 run:505 clone:1 gen:42 core:0x21 unit:0x0000002a0002894b5a8264ba3e971c73
09:01:27:WU01:FS01:Uploading 1.78MiB to 155.247.166.219
09:01:27:WU01:FS01:Connecting to 155.247.166.219:8080
09:01:48:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:01:48:WU01:FS01:Connecting to 155.247.166.219:80
09:02:09:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:02:09:WU01:FS01:Trying to send results to collection server
09:02:09:WU01:FS01:Uploading 1.78MiB to 155.247.166.220
09:02:09:WU01:FS01:Connecting to 155.247.166.220:8080
09:02:30:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:02:30:WU01:FS01:Connecting to 155.247.166.220:80
09:02:51:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:19:24:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13781 run:505 clone:1 gen:42 core:0x21 unit:0x0000002a0002894b5a8264ba3e971c73
09:19:24:WU01:FS01:Uploading 1.78MiB to 155.247.166.219
09:19:24:WU01:FS01:Connecting to 155.247.166.219:8080
09:19:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:19:45:WU01:FS01:Connecting to 155.247.166.219:80
09:20:06:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:20:06:WU01:FS01:Trying to send results to collection server
09:20:06:WU01:FS01:Uploading 1.78MiB to 155.247.166.220
09:20:06:WU01:FS01:Connecting to 155.247.166.220:8080
09:20:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:20:27:WU01:FS01:Connecting to 155.247.166.220:80
09:20:48:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:48:26:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13781 run:505 clone:1 gen:42 core:0x21 unit:0x0000002a0002894b5a8264ba3e971c73
09:48:26:WU01:FS01:Uploading 1.78MiB to 155.247.166.219
09:48:26:WU01:FS01:Connecting to 155.247.166.219:8080
09:48:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:48:47:WU01:FS01:Connecting to 155.247.166.219:80
09:49:08:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:49:08:WU01:FS01:Trying to send results to collection server
09:49:08:WU01:FS01:Uploading 1.78MiB to 155.247.166.220
09:49:08:WU01:FS01:Connecting to 155.247.166.220:8080
09:49:29:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
09:49:29:WU01:FS01:Connecting to 155.247.166.220:80
09:49:50:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:35:25:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13781 run:505 clone:1 gen:42 core:0x21 unit:0x0000002a0002894b5a8264ba3e971c73
10:35:25:WU01:FS01:Uploading 1.78MiB to 155.247.166.219
10:35:25:WU01:FS01:Connecting to 155.247.166.219:8080
10:35:46:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
10:35:46:WU01:FS01:Connecting to 155.247.166.219:80
10:36:07:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:36:07:WU01:FS01:Trying to send results to collection server
10:36:07:WU01:FS01:Uploading 1.78MiB to 155.247.166.220
10:36:07:WU01:FS01:Connecting to 155.247.166.220:8080
10:36:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
10:36:28:WU01:FS01:Connecting to 155.247.166.220:80
10:36:49:ERROR:WU01:FS01:Exception: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
