Change username / team automatically
foldinghomealone2
I'm folding for several teams and use different usernames and passkeys.
Is there a way to change username, passkey and team automatically / with a script?
I'm using FAHClient 7.4.4 and Win10.
Thanks
Thanks
SteveWillis
- Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Re: Change username / team automatically
You do know that you don't have to change your passkey with different usernames and teams?
foldinghomealone2
My information ist that if I create a username, I have to request a passkey.
If I change my username and teamnumber I need to change passkey information in the client as well to get QRB.
However, I still don't understand how I can change user-information automatically / with a script...
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Your information is incorrect you will still get QRB and I have confirmed it. However I'm not sure if you still have to finish 10 WUs on a new name/team pair or not.
In fact, here is a link to a page where you can enter your passkey and get the points earned on any and all username/teams you have folded on, on that passkey.
http://fah-web.stanford.edu/cgi-bin/mai ... =userstats
User1 with Passkey1 presumably has completed 10 WU and is receiving bonus points for Team1. If he moves to Team2, nothing changes except the team receiving the credit. The pair (User1+Passkey1) has already been qualified.
User2 can start folding start folding using any Passkey but no bonus will be received until until that specific pair of (user+passkey) has completed 10 WUs. You can qualify as many user names with a single passkey as you want or, conversely, you can qualify as many passkeys with a single user name as you want, but each PAIR must be qualified.
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
On linux
FAHClient --help
gives what I believe are all the command line commands. I don't see anything there for what you want
FAHClient --help
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
OK, when I tried this (remember I'm on Linux)
sudo /etc/init.d/FAHClient stop
sudo FAHClient --user=MWseRJKu23TQb8pJiRYMVGLJwEW87q29Az --team=234020
It actually started the client using the specified user and team name (yes that's a user name, not a passkey)
but it didn't recognize any of my GPUs and just started a cpu FS. Maybe that will give you something to work on.
Actually it did show the GPUs but they were all on "Ready" and wouldn't start folding.
Required work on your part:
Take a look at /etc/init.d/FAHClient. It starts FAHClient in a particular directory and runs with the permissions of the daemonn (which runs as a different user). Just starting FAHClient is insufficient.
I am a new user. I have two accounts using the same Team and Passkey. I messed up matching the two user names. How can I correct them so they match?
Jim
Jim
Going forward, just make certain the two usernames match. However once awarded points stay with the username and team the WU was submitted with, so any points earned in the past will stay with the misspelled username.JimH wrote:I am a new user. I have two accounts using the same Team and Passkey. I messed up matching the two user names. How can I correct them so they match?
Jim
foldinghomealone2
When I try to use FAH w/o FUI with command line options then it always aborts the downloaded WU.
I use:
FAHclient --config config.xml
It starts downloading with all the parameters from config.xml but after download the WU fails and the next WU is downloaded.
When I close the command line window and start advanced control it folds just normally.
For information: Maybe this problem is related to an still existing problem which was addressed a while a go:
viewtopic.php?f=61&t=30181
I use:
*********************** Log Started 2018-04-01T09:41:57Z ***********************
09:41:57:************************* Folding@home Client *************************
09:41:57: Website: http://folding.stanford.edu/
09:41:57: Copyright: (c) 2009-2014 Stanford University
09:41:57: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:41:57: Args: --config config.xml
09:41:57: Config: C:/Users/xxx/AppData/Roaming/FAHClient/config.xml
09:41:57:******************************** Build ********************************
09:41:57: Version: 7.4.4
09:41:57: Date: Mar 4 2014
09:41:57: Time: 20:26:54
09:41:57: SVN Rev: 4130
09:41:57: Branch: fah/trunk/client
09:41:57: Compiler: Intel(R) C++ MSVC 1500 mode 1200
09:41:57: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
09:41:57: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
09:41:57: Platform: win32 XP
09:41:57: Bits: 32
09:41:57: Mode: Release
09:41:57:******************************* System ********************************
09:41:57: CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
09:41:57: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
09:41:57: CPUs: 4
09:41:57: Memory: 15.44GiB
09:41:57: Free Memory: 10.29GiB
09:41:57: Threads: WINDOWS_THREADS
09:41:57: OS Version: 6.2
09:41:57: Has Battery: false
09:41:57: On Battery: false
09:41:57: UTC Offset: 2
09:41:57: PID: 12868
09:41:57: CWD: C:/Users/xxx/AppData/Roaming/FAHClient
09:41:57: OS: Windows 10 Home
09:41:57: OS Arch: AMD64
09:41:57: GPUs: 1
09:41:57: GPU 0: NVIDIA:7 GP102 [GeForce GTX 1080 Ti] 11380
09:41:57: CUDA: 6.1
09:41:57: CUDA Driver: 9010
09:41:57:Win32 Service: false
09:41:57:***********************************************************************
09:41:57:<config>
09:41:57: <!-- Folding Core -->
09:41:57: <core-priority v='low'/>
09:41:57:
09:41:57: <!-- Folding Slot Configuration -->
09:41:57: <client-type v='beta'/>
09:41:57: <max-packet-size v='big'/>
09:41:57:
09:41:57: <!-- Network -->
09:41:57: <proxy v=':8080'/>
09:41:57:
09:41:57: <!-- Slot Control -->
09:41:57: <power v='full'/>
09:41:57:
09:41:57: <!-- User Information -->
09:41:57: <passkey v='********************************'/>
09:41:57: <team v='224497'/>
09:41:57: <user v='fldnghmln_ALL_1MGiKLsXSVkrAYNkBcjq94gZKKRfpDUmMb'/>
09:41:57:
09:41:57: <!-- Work Unit Control -->
09:41:57: <next-unit-percentage v='100'/>
09:41:57:
09:41:57: <!-- Folding Slots -->
09:41:57: <slot id='0' type='GPU'/>
09:41:57:</config>
09:41:57:Trying to access database...
09:41:57:Successfully acquired database lock
09:41:57:Enabled folding slot 00: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380
09:41:58:WU00:FS00:Connecting to 171.67.108.45:80
09:41:59:WU00:FS00:Assigned to work server 155.247.166.219
09:41:59:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 155.247.166.219
09:41:59:WU00:FS00:Connecting to 155.247.166.219:8080
09:42:00:ERROR:WU00:FS00:Exception: Server did not assign work unit
09:42:00:WU00:FS00:Connecting to 171.67.108.45:80
09:42:01:WU00:FS00:Assigned to work server 155.247.166.219
09:42:01:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 155.247.166.219
09:42:01:WU00:FS00:Connecting to 155.247.166.219:8080
09:42:03:WU00:FS00:Downloading 903.05KiB
09:42:04:WU00:FS00:Download complete
09:42:04:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13781 run:764 clone:3 gen:64 core:0x21 unit:0x000000490002894b5a8264d9d497b890
09:42:04:WU00:FS00:Starting
09:42:04:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xxx/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/beta/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 12868 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
09:42:10:WU00:FS00:Started FahCore on PID 6468
09:42:10:WU00:FS00:Core PID:1040
09:42:10:WU00:FS00:FahCore 0x21 started
09:42:11:WU00:FS00:0x21:*********************** Log Started 2018-04-01T09:42:10Z ***********************
09:42:11:WU00:FS00:0x21:Project: 13781 (Run 764, Clone 3, Gen 64)
09:42:11:WU00:FS00:0x21:Unit: 0x000000490002894b5a8264d9d497b890
09:42:11:WU00:FS00:0x21:CPU: 0x00000000000000000000000000000000
09:42:11:WU00:FS00:0x21:Machine: 0
09:42:11:WU00:FS00:0x21:Reading tar file core.xml
09:42:11:WU00:FS00:0x21:Reading tar file integrator.xml
09:42:11:WU00:FS00:0x21:Reading tar file state.xml
09:42:11:WU00:FS00:0x21:Reading tar file system.xml
09:42:11:WU00:FS00:0x21:Digital signatures verified
09:42:11:WU00:FS00:0x21:Folding@home GPU Core21 Folding@home Core
09:42:11:WU00:FS00:0x21:Version 0.0.20
09:42:12:WU00:FS00:0x21:ERROR:exception: Error initializing context: clCreateContext (999)
09:42:12:WU00:FS00:0x21:Saving result file logfile_01.txt
09:42:12:WU00:FS00:0x21:Saving result file log.txt
09:42:12:WU00:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:42:12:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:42:12:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:13781 run:764 clone:3 gen:64 core:0x21 unit:0x000000490002894b5a8264d9d497b890
09:42:12:WU00:FS00:Uploading 2.34KiB to 155.247.166.219
09:42:12:WU00:FS00:Connecting to 155.247.166.219:8080
09:42:13:WU01:FS00:Connecting to 171.67.108.45:80
09:42:13:WU00:FS00:Upload complete
09:42:13:WU00:FS00:Server responded WORK_ACK (400)
09:42:13:WU00:FS00:Cleaning up
09:42:14:WU01:FS00:Assigned to work server 155.247.166.219
09:42:14:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 155.247.166.219
09:42:14:WU01:FS00:Connecting to 155.247.166.219:8080
09:42:16:WU01:FS00:Downloading 903.35KiB
09:42:17:WU01:FS00:Download complete
09:42:17:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13782 run:450 clone:0 gen:76 core:0x21 unit:0x0000004e0002894b5a78cef705c0f3ea
09:42:17:WU01:FS00:Starting
09:42:17:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xxx/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/beta/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 12868 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
09:42:17:WU01:FS00:Started FahCore on PID 12880
09:42:17:WU01:FS00:Core PID:9484
09:42:17:WU01:FS00:FahCore 0x21 started
09:42:18:WU01:FS00:0x21:*********************** Log Started 2018-04-01T09:42:17Z ***********************
09:42:18:WU01:FS00:0x21:Project: 13782 (Run 450, Clone 0, Gen 76)
09:42:18:WU01:FS00:0x21:Unit: 0x0000004e0002894b5a78cef705c0f3ea
09:42:18:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
09:42:18:WU01:FS00:0x21:Machine: 0
09:42:18:WU01:FS00:0x21:Reading tar file core.xml
09:42:18:WU01:FS00:0x21:Reading tar file integrator.xml
09:42:18:WU01:FS00:0x21:Reading tar file state.xml
09:42:18:WU01:FS00:0x21:Reading tar file system.xml
09:42:18:WU01:FS00:0x21:Digital signatures verified
09:42:18:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
09:42:18:WU01:FS00:0x21:Version 0.0.20
09:42:19:WU01:FS00:0x21:ERROR:exception: Error initializing context: clCreateContext (999)
09:42:19:WU01:FS00:0x21:Saving result file logfile_01.txt
09:42:19:WU01:FS00:0x21:Saving result file log.txt
09:42:19:WU01:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:42:20:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:42:20:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:13782 run:450 clone:0 gen:76 core:0x21 unit:0x0000004e0002894b5a78cef705c0f3ea
09:42:20:WU01:FS00:Uploading 2.35KiB to 155.247.166.219
09:42:20:WU01:FS00:Connecting to 155.247.166.219:8080
09:42:20:WU01:FS00:Upload complete
09:42:20:WU01:FS00:Server responded WORK_ACK (400)
09:42:20:WU01:FS00:Cleaning up
09:42:20:WU00:FS00:Connecting to 171.67.108.45:80
09:42:20:WU00:FS00:Assigned to work server 155.247.166.219
09:42:20:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 155.247.166.219
09:42:20:WU00:FS00:Connecting to 155.247.166.219:8080
09:42:23:WU00:FS00:Downloading 902.53KiB
09:42:24:WU00:FS00:Download complete
09:42:24:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13781 run:398 clone:4 gen:54 core:0x21 unit:0x000000480002894b5a8264b08e218d76
09:42:24:WU00:FS00:Starting
09:42:24:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xxx/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/beta/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 12868 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
09:42:24:WU00:FS00:Started FahCore on PID 11968
09:42:24:WU00:FS00:Core PID:4432
09:42:24:WU00:FS00:FahCore 0x21 started
09:42:25:WU00:FS00:0x21:*********************** Log Started 2018-04-01T09:42:24Z ***********************
09:42:25:WU00:FS00:0x21:Project: 13781 (Run 398, Clone 4, Gen 54)
09:42:25:WU00:FS00:0x21:Unit: 0x000000480002894b5a8264b08e218d76
09:42:25:WU00:FS00:0x21:CPU: 0x00000000000000000000000000000000
09:42:25:WU00:FS00:0x21:Machine: 0
09:42:25:WU00:FS00:0x21:Reading tar file core.xml
09:42:25:WU00:FS00:0x21:Reading tar file integrator.xml
09:42:25:WU00:FS00:0x21:Reading tar file state.xml
09:42:25:WU00:FS00:0x21:Reading tar file system.xml
09:42:25:WU00:FS00:0x21:Digital signatures verified
09:42:25:WU00:FS00:0x21:Folding@home GPU Core21 Folding@home Core
09:42:25:WU00:FS00:0x21:Version 0.0.20
09:42:26:WU00:FS00:0x21:ERROR:exception: Error initializing context: clCreateContext (999)
09:42:26:WU00:FS00:0x21:Saving result file logfile_01.txt
09:42:26:WU00:FS00:0x21:Saving result file log.txt
09:42:26:WU00:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:42:27:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:42:27:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:13781 run:398 clone:4 gen:54 core:0x21 unit:0x000000480002894b5a8264b08e218d76
09:42:27:WU00:FS00:Uploading 2.36KiB to 155.247.166.219
09:42:27:WU00:FS00:Connecting to 155.247.166.219:8080
09:42:27:WU00:FS00:Upload complete
09:42:27:WU00:FS00:Server responded WORK_ACK (400)
09:42:27:WU00:FS00:Cleaning up
09:42:27:WU01:FS00:Connecting to 171.67.108.45:80
09:42:27:WU01:FS00:Assigned to work server 155.247.166.219
09:42:27:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 155.247.166.219
09:42:27:WU01:FS00:Connecting to 155.247.166.219:8080
09:42:28:ERROR:WU01:FS00:Exception: Server did not assign work unit
09:42:28:WU01:FS00:Connecting to 171.67.108.45:80
09:42:28:WU01:FS00:Assigned to work server 171.67.108.157
09:42:28:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 171.67.108.157
09:42:28:WU01:FS00:Connecting to 171.67.108.157:8080
09:42:29:WU01:FS00:Downloading 5.16MiB
09:42:33:WU01:FS00:Download complete
09:42:33:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9415 run:1674 clone:3 gen:634 core:0x21 unit:0x000002f7ab436c9d585e06d8f41435dc
09:42:33:WU01:FS00:Starting
09:42:33:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xxx/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/beta/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 12868 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
09:42:33:WU01:FS00:Started FahCore on PID 9844
09:42:33:WU01:FS00:Core PID:9296
09:42:33:WU01:FS00:FahCore 0x21 started
09:42:34:WU01:FS00:0x21:*********************** Log Started 2018-04-01T09:42:33Z ***********************
09:42:34:WU01:FS00:0x21:Project: 9415 (Run 1674, Clone 3, Gen 634)
09:42:34:WU01:FS00:0x21:Unit: 0x000002f7ab436c9d585e06d8f41435dc
09:42:34:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
09:42:34:WU01:FS00:0x21:Machine: 0
09:42:34:WU01:FS00:0x21:Reading tar file core.xml
09:42:34:WU01:FS00:0x21:Reading tar file integrator.xml
09:42:34:WU01:FS00:0x21:Reading tar file state.xml
09:42:34:WU01:FS00:0x21:Reading tar file system.xml
09:42:34:WU01:FS00:0x21:Digital signatures verified
09:42:34:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
09:42:34:WU01:FS00:0x21:Version 0.0.20
09:42:35:WU01:FS00:0x21:ERROR:exception: Error initializing context: clCreateContext (999)
09:42:35:WU01:FS00:0x21:Saving result file logfile_01.txt
09:42:35:WU01:FS00:0x21:Saving result file log.txt
09:42:35:WU01:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:42:35:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:42:35:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9415 run:1674 clone:3 gen:634 core:0x21 unit:0x000002f7ab436c9d585e06d8f41435dc
09:42:35:WU01:FS00:Uploading 7.50KiB to 171.67.108.157
09:42:35:WU01:FS00:Connecting to 171.67.108.157:8080
09:42:35:WU00:FS00:Connecting to 171.67.108.45:80
09:42:35:WU01:FS00:Upload complete
09:42:35:WU01:FS00:Server responded WORK_ACK (400)
09:42:35:WU01:FS00:Cleaning up
09:42:36:WU00:FS00:Assigned to work server 171.67.108.157
09:42:36:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 171.67.108.157
09:42:36:WU00:FS00:Connecting to 171.67.108.157:8080
09:42:37:WU00:FS00:Downloading 5.18MiB
09:42:40:WU00:FS00:Download complete
09:42:40:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9414 run:86 clone:3 gen:494 core:0x21 unit:0x00000250ab436c9d585e0690d438bc23
09:42:40:WU00:FS00:Starting
09:42:40:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xxx/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/beta/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 12868 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
09:42:40:WU00:FS00:Started FahCore on PID 3700
09:42:40:WU00:FS00:Core PID:11984
09:42:40:WU00:FS00:FahCore 0x21 started
09:42:40:WU00:FS00:0x21:*********************** Log Started 2018-04-01T09:42:40Z ***********************
09:42:40:WU00:FS00:0x21:Project: 9414 (Run 86, Clone 3, Gen 494)
09:42:40:WU00:FS00:0x21:Unit: 0x00000250ab436c9d585e0690d438bc23
09:42:40:WU00:FS00:0x21:CPU: 0x00000000000000000000000000000000
09:42:40:WU00:FS00:0x21:Machine: 0
09:42:40:WU00:FS00:0x21:Reading tar file core.xml
09:42:40:WU00:FS00:0x21:Reading tar file integrator.xml
09:42:40:WU00:FS00:0x21:Reading tar file state.xml
09:42:40:WU00:FS00:0x21:Reading tar file system.xml
09:42:40:WU00:FS00:0x21:Digital signatures verified
09:42:40:WU00:FS00:0x21:Folding@home GPU Core21 Folding@home Core
09:42:40:WU00:FS00:0x21:Version 0.0.20
09:42:41:WU00:FS00:0x21:ERROR:exception: Error initializing context: clCreateContext (999)
09:42:41:WU00:FS00:0x21:Saving result file logfile_01.txt
09:42:41:WU00:FS00:0x21:Saving result file log.txt
09:42:41:WU00:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
09:42:41:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:42:41:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9414 run:86 clone:3 gen:494 core:0x21 unit:0x00000250ab436c9d585e0690d438bc23
09:42:41:WU00:FS00:Uploading 7.50KiB to 171.67.108.157
09:42:41:WU00:FS00:Connecting to 171.67.108.157:8080
09:42:42:WU01:FS00:Connecting to 171.67.108.45:80
09:42:42:WU00:FS00:Upload complete
09:42:42:WU00:FS00:Server responded WORK_ACK (400)
09:42:42:WU00:FS00:Cleaning up
09:42:42:WU01:FS00:Assigned to work server 171.67.108.157
09:42:42:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 171.67.108.157
09:42:42:WU01:FS00:Connecting to 171.67.108.157:8080
09:42:43:WU01:FS00:Downloading 8.82MiB
When you try to run FAHClient from the command line, is FAHClient already running by being auto started on login? That would cause a conflict with your FAHClient process attempting to open files locked by the existing FAHClient process.
foldinghomealone2
No, when it's running then it gives an error message about same processes...
I tried both after closing of advanced client / FAHcontrol and after new installation. Both with same result of aborted WUs.
When you open the Command window, what is the current directory? Is that where you put config.xml? Why are you trying to start FAHClient.exe when it's already running?
If you install FAH with the default settings, a reboot will restart FAHClient with a current directory (recommended my Microsoft) of %APPDATA%/FAHClient and it will start WebControl. You can close WebControl and start FAHControl if you prefer. Neither is required since the background process FAHClient just keeps processing one active WU per slot unless a Control application requests a change. A preconfigured copy of Config.xml is providedd, but it can be edited using FAHControl. We strongly recommend that you do not use other editors.
When you log on to WIndows, the FAHClient service is started along with a copy of WebControl. An environment variable $APPDATA% is preset to a hidden directory containing your Windows UseName. (Mine is %APPDATA% = C:\users\Bruce\AppData\Roaming, so for me, the default location for all of FAH's files is C:\users\Bruce\AppData\Roaming\FAH\FAHClient.
If you have installed for "anybody" instead of "just for me" the directory will be different.
When you open the Command window, that will NOT be the current directory. To do whatever you're attempting to do, you MUST set the current directory to the actual place where both FAHClient and FAHControl will find all of their files or FAH WILL NOT WORK. When FAH starts at boot time, it sets the directory where its files are stored, including where it finds config.xml... or maybe you want to use the full path name.
If you read the instructions in the signature block of my first post on this page (above) it will explain how to find the fah.log. Once you find that log, near the top you'll see it reports where FAH actually running. I believe that if FAH ALWAYS uses the same Current Directory, it will solve all of your problems. If your system contains multiple copies of fah.log, you'll see the results of not being consistent.
Note: FAH may have attempted to write it's files in locations where the user doesn't have permissions to write (like C:\WINDOWS\system32) and that will cause FAHClient to abort ... or it may force you to run with Admin privileges. Both are unnecessary if you're willing to use FAH's defaults.
In Linux and in MacOS-X FAHClient is designed to run as a service, not as a user application. FAHClient for Windows follows that same pattern as closely as Microsoft will allow. The FAHControl software is designe to run as a user application. During FAH's installation, Windows shortcuts are provided for all of the things you're expected to need. If you choose not to use them or you choose to modify how FAH runs, you're on your own.
There is no such thing as "advanced client" You're thinking of the Advanced Control program AKA FAHControl.foldinghomealone2 wrote:No, when it's running then it gives an error message about same processes...
FAHClient.exe is run as a background service. It should be started automatically at boot time and only one copy can run, so attempting to start FAHClient.exe is always a mistake, especially if your not very careful of the current working directory and you never try to run more than one copy.
Either FAHControl.exe or WebControl is designed to be used by you to manage what FAHClient is doing ... downloading WU, invoking a FAHCore_xx, and uploading results... plus responding to requests from FAHControl.
