Nvidia MED-XN71 as [xxx]
pcghx_nfsgame
Post by pcghx_nfsgame »
Hello,
the MED-XN71 is in the GPUs.txt yet but with [xxx] in the description.
lspci:
0x10de:0x1c30:NVIDIA Corporation:Nvidia MED-XN71
Logfile:
*********************** Log Started 2018-03-08T10:27:42Z ***********************
10:27:42:************************* Folding@home Client *************************
10:27:42:      Website: http://folding.stanford.edu/
10:27:42:    Copyright: (c) 2009-2014 Stanford University
10:27:42:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:27:42:         Args: --open-web-control
10:27:42:       Config: C:/Users/admin/AppData/Roaming/FAHClient/config.xml
10:27:42:******************************** Build ********************************
10:27:42:      Version: 7.4.4
10:27:42:         Date: Mar 4 2014
10:27:42:         Time: 20:26:54
10:27:42:      SVN Rev: 4130
10:27:42:       Branch: fah/trunk/client
10:27:42:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
10:27:42:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
10:27:42:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
10:27:42:     Platform: win32 XP
10:27:42:         Bits: 32
10:27:42:         Mode: Release
10:27:42:******************************* System ********************************
10:27:42:          CPU: Intel(R) Xeon(R) CPU E3-1240 v5 @ 3.50GHz
10:27:42:       CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
10:27:42:         CPUs: 8
10:27:42:       Memory: 7.93GiB
10:27:42:  Free Memory: 5.37GiB
10:27:42:      Threads: WINDOWS_THREADS
10:27:42:   OS Version: 6.1
10:27:42:  Has Battery: false
10:27:42:   On Battery: false
10:27:42:   UTC Offset: 1
10:27:42:          PID: 2888
10:27:42:          CWD: C:/Users/admin/AppData/Roaming/FAHClient
10:27:42:           OS: Windows 7 Professional
10:27:42:      OS Arch: AMD64
10:27:42:         GPUs: 1
10:27:42:        GPU 0: NVIDIA:5 GP106GL [xxx]
10:27:42:         CUDA: 6.1
10:27:42:  CUDA Driver: 9010
10:27:42:Win32 Service: false
10:27:42:***********************************************************************
10:27:42:<config>
The card got a GP106GL-chip (and some special features) like the Quadro P2000 - about 280.000PPD with P9415.
Re: Nvidia MED-XN71 as [xxx]
Post by foldy »
Are you folding on a medical healthcare device :-)
pcghx_nfsgame
Stability testing ;)
This is the only reference I found to this card : http://www.eizoglobal.com/products/radi ... index.html
I guess this is some kind of custom design aimed at driving specific screens used in medical applications.
Does GPU-Z tell us what it's characteristics are? (# shaders, ROPs, lock rates, etc.)
I took a guess at SP GFLOPS.
pcghx_nfsgame
I think I'm not allowed to post screenshots or links yet. But I can tell you like this:
1024 shaders, 40/64 ROPs/TMUs, 1481MHZ/1752MHz core/memory (no boost), 5120MB linked with 160bit bus width
