155.247.166.220 error uploading WU
hi there.
FAHControl shows "Collection Server" as 0.0.0.0.
After WU is finished, it shows this error:
"15:06:29:WU00:FS00:Uploading 25.70MiB to 155.247.166.220
15:06:29:WU00:FS00:Connecting to 155.247.166.220:8080
15:06:30:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
15:06:30:WU00:FS00:Connecting to 155.247.166.220:80
15:06:51:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond."
Any ideas?
Thanks
Any ideas?
Thanks
Re: error uploading WU
Yes, that server is having problems right now. The client should retry until the server is fixed.
What project was that?
(The owner of the project needs to add a setting for the Collection Server for a long-term fix.)
parkut
- Hardware configuration: Running exclusively Linux headless blades. All are dedicated crunching machines.
Re: 155.247.166.220 error uploading WU
I have (2) WU's stuck on upload : Failed to connect to 155.247.166.220
Machine-107 .. project:13795 run:18 clone:12 gen:36
Machine-104 .. project:14004 run:0 clone:5 gen:34
Both show Collection server 0.0.0.0
Project seems to be 13797, here is the log:bruce wrote:Yes, that server is having problems right now. The client should retry until the server is fixed.
14:21:01:WU00:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
14:21:02:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
14:21:02:WU00:FS00:0xa7:Saving result file ener.edr
14:21:02:WU00:FS00:0xa7:Saving result file frame0.trr
14:21:05:WU00:FS00:0xa7:Saving result file md.log
14:21:05:WU00:FS00:0xa7:Saving result file pullf.xvg
14:21:05:WU00:FS00:0xa7:Saving result file pullx.xvg
14:21:05:WU00:FS00:0xa7:Saving result file science.log
14:21:05:WU00:FS00:0xa7:Saving result file traj_comp.xtc
14:21:05:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
14:21:06:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:21:06:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13797 run:17 clone:18 gen:0 core:0xa7 unit:0x000000000002894c5a13683b0c19086c
14:21:06:WU00:FS00:Uploading 25.70MiB to 155.247.166.220
14:21:06:WU00:FS00:Connecting to 155.247.166.220:8080
14:21:07:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
14:21:07:WU00:FS00:Connecting to 155.247.166.220:80
14:21:28:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:21:28:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13797 run:17 clone:18 gen:0 core:0xa7 unit:0x000000000002894c5a13683b0c19086c
still failing to upload the data.... any feedback on what's going on?
Vvoelz Lab at Temple U. has had more than it's share of troubles. When something gets fixed, it often breaks again. I don't have enough information to figure out what the problem is, but it's not uncommon for the Campus Networking security folks to have different ideas about what needs to be done than the scientists actually running the servers. The red-tape
required to resolve such issues can be very complex.
Right now, that server is listed as DOWN. Since your WU was assigned without a Collection Server, the WU has to wait until it can get through to that particular server. We can hope that it's down temporarily to make some permanent change that will improve its apparent unreliability, but I don't have any facts, either way.
Is this still the same WU you reported issues with uploading on Wednesday? That server was brought back up later in the day on Wednesday, and accepted thousands of WU's from that time until it went down Saturday morning.
So if it is the same WU, then you have some problem in addition to the WS being down.
hey all, i don't keep FAH Client 24/7, so i wouldn't know if the server was up.
i tried today and i managed to upload the WU, although it showed "WARNING:WU02:FS01:Past final deadline 2018-02-12T15:05:08Z, dumping", hope my folding didn't go to waste
Thanks for the help!
Regards
<code>
14:06:58:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13797 run:17 clone:18 gen:0 core:0xa7 unit:0x000000000002894c5a13683b0c19086c
14:06:58:WARNING:WU02:FS01:Past final deadline 2018-02-12T15:05:08Z, dumping
14:06:58:WU00:FS00:Uploading 25.70MiB to 155.247.166.220
14:06:58:WU00:FS00:Connecting to 155.247.166.220:8080
14:06:58:WU02:FS01:Cleaning up
14:07:04:WU00:FS00:Upload 8.76%
14:07:10:WU00:FS00:Upload 16.54%
14:07:16:WU00:FS00:Upload 24.08%
14:07:22:WU00:FS00:Upload 35.02%
14:07:28:WU00:FS00:Upload 43.05%
14:07:34:WU00:FS00:Upload 50.83%
14:07:40:WU00:FS00:Upload 60.32%
14:07:46:WU00:FS00:Upload 74.67%
14:07:52:WU00:FS00:Upload 84.40%
14:07:58:WU00:FS00:Upload 97.53%
14:08:02:WU00:FS00:Upload complete
14:08:02:WU00:FS00:Server responded WORK_ACK (400)
14:08:02:WU00:FS00:Final credit estimate, 2214.00 points
14:08:02:WU00:FS00:Cleaning up
</code>
Regards
<code>
</code>
It depends on your definition of "going to waste"jinjonBoo wrote:i tried today and i managed to upload the WU, although it showed "WARNING:WU02:FS01:Past final deadline 2018-02-12T15:05:08Z, dumping", hope my folding didn't go to waste:
From a points perspective, you did receive a small credit, but the points always decrease when you hold on to a WU longer than necessary.
From a scientific perspective, a WU that is returned after the deadline is rarely useful.
FAH generates a new WU whenever a WU is completed, and to guarantee that progress is being made the deadlines are strictly enforced. When a WU passes the Preferred Deadline, it's assumed to be lost and it is duplicated and reassigned to someone else who will (hopefully) complete it in a reasonable amount of time. They earn full credit for the WU. If, as in your case, the WU is returned later, partial credit may or may not be awarded.
Here are the particulars on your WU. In this case, the completed WU was returned on 2017-11-05 and the analysis of that trajectory could be continued. When your WU arrived on 2018-02-15, it was no longer needed so it was discarded.
Hi xxxxxx (team yyyy), Days taken to complete WU: 0.17
Your WU (P13797 R17 C18 G0) was added to the stats database on 2017-11-05 03:06:15 for 16892.8 points of credit.
Hi jinjonBoo (team 223650), Days taken to complete WU: 9.06
Your WU (P13797 R17 C18 G0) was added to the stats database on 2018-02-15 06:18:17 for 2214.3 points of credit.
