Just started getting ALL "bad work units" RX 560
GPU timpster
Post by GPU timpster »
Hello, I've restarted my computer and when I restarted my PC, FAH is giving the card all "bad work units", which I know their not bad, something happened, changed in a way that makes the card not work with FAH GPU work units. I'm not sure what, but I've reset the card to default settings with no change and I have no idea what to do now.
Here is log
1:52:30:Enabled folding slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308
01:52:30:Enabled folding slot 00: PAUSED gpu:1:Baffin [Polaris11] (by user)
01:52:31:WU00:FS01:Connecting to 171.67.108.45:80
01:52:32:WU00:FS01:Assigned to work server 171.67.108.157
01:52:32:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 171.67.108.157
01:52:32:WU00:FS01:Connecting to 171.67.108.157:8080
01:52:34:WU00:FS01:Downloading 5.15MiB
01:52:36:WU00:FS01:Download complete
01:52:36:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9414 run:1328 clone:2 gen:260 core:0x21 unit:0x0000013fab436c9d585e069a64d20c96
01:52:36:WU00:FS01:Starting
01:52:36:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Timbuck/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 7452 -checkpoint 8 -gpu 0 -gpu-vendor nvidia
01:52:36:WU00:FS01:Started FahCore on PID 7336
01:52:37:WU00:FS01:Core PID:5808
01:52:37:WU00:FS01:FahCore 0x21 started
01:52:37:WU00:FS01:0x21:*********************** Log Started 2018-01-31T01:52:37Z ***********************
01:52:37:WU00:FS01:0x21:Project: 9414 (Run 1328, Clone 2, Gen 260)
01:52:37:WU00:FS01:0x21:Unit: 0x0000013fab436c9d585e069a64d20c96
01:52:37:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
01:52:37:WU00:FS01:0x21:Machine: 1
01:52:37:WU00:FS01:0x21:Reading tar file core.xml
01:52:37:WU00:FS01:0x21:Reading tar file integrator.xml
01:52:37:WU00:FS01:0x21:Reading tar file state.xml
01:52:37:WU00:FS01:0x21:Reading tar file system.xml
01:52:37:WU00:FS01:0x21:Digital signatures verified
01:52:37:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
01:52:37:WU00:FS01:0x21:Version 0.0.18
01:52:39:WU00:FS01:0x21:Completed 0 out of 6250000 steps (0%)
01:52:39:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:53:01:FS00:Unpaused
01:53:01:WU01:FS00:Starting
01:53:01:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Timbuck/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 7452 -checkpoint 8 -gpu 1 -gpu-vendor ati
01:53:01:WU01:FS00:Started FahCore on PID 2352
01:53:02:WU01:FS00:Core PID:2652
01:53:02:WU01:FS00:FahCore 0x21 started
01:53:02:WU01:FS00:0x21:*********************** Log Started 2018-01-31T01:53:02Z ***********************
01:53:02:WU01:FS00:0x21:Project: 9414 (Run 1639, Clone 1, Gen 316)
01:53:02:WU01:FS00:0x21:Unit: 0x0000017cab436c9d585e069cfe7ceb7d
01:53:02:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
01:53:02:WU01:FS00:0x21:Machine: 0
01:53:02:WU01:FS00:0x21:Reading tar file core.xml
01:53:02:WU01:FS00:0x21:Reading tar file integrator.xml
01:53:02:WU01:FS00:0x21:Reading tar file state.xml
01:53:02:WU01:FS00:0x21:Reading tar file system.xml
01:53:02:WU01:FS00:0x21:Digital signatures verified
01:53:02:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
01:53:02:WU01:FS00:0x21:Version 0.0.18
01:53:06:WU01:FS00:0x21:ERROR:NaNs detected in forces. 0 0
01:53:06:WU01:FS00:0x21:Saving result file logfile_01.txt
01:53:06:WU01:FS00:0x21:Saving result file log.txt
01:53:06:WU01:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
01:53:07:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
01:53:07:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9414 run:1639 clone:1 gen:316 core:0x21 unit:0x0000017cab436c9d585e069cfe7ceb7d
01:53:07:WU01:FS00:Uploading 7.00KiB to 171.67.108.157
01:53:07:WU01:FS00:Connecting to 171.67.108.157:8080
01:53:07:WU02:FS00:Connecting to 171.67.108.45:80
01:53:07:WU01:FS00:Upload complete
01:53:07:WU01:FS00:Server responded WORK_ACK (400)
01:53:07:WU01:FS00:Cleaning up
01:53:08:WU02:FS00:Assigned to work server 171.67.108.157
01:53:08:WU02:FS00:Requesting new work unit for slot 00: READY gpu:1:Baffin [Polaris11] from 171.67.108.157
01:53:08:WU02:FS00:Connecting to 171.67.108.157:8080
01:53:09:WU02:FS00:Downloading 8.87MiB
01:53:12:WU02:FS00:Download complete
01:53:12:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9431 run:1779 clone:1 gen:384 core:0x21 unit:0x000001c6ab436c9d586fdd410ab4a9cc
01:53:12:WU02:FS00:Starting
01:53:12:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Timbuck/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 7452 -checkpoint 8 -gpu 1 -gpu-vendor ati
01:53:13:WU02:FS00:Started FahCore on PID 8132
01:53:13:WU02:FS00:Core PID:5224
01:53:13:WU02:FS00:FahCore 0x21 started
01:53:13:WU02:FS00:0x21:*********************** Log Started 2018-01-31T01:53:13Z ***********************
01:53:13:WU02:FS00:0x21:Project: 9431 (Run 1779, Clone 1, Gen 384)
01:53:13:WU02:FS00:0x21:Unit: 0x000001c6ab436c9d586fdd410ab4a9cc
01:53:13:WU02:FS00:0x21:CPU: 0x00000000000000000000000000000000
01:53:13:WU02:FS00:0x21:Machine: 0
01:53:13:WU02:FS00:0x21:Reading tar file core.xml
01:53:13:WU02:FS00:0x21:Reading tar file integrator.xml
01:53:13:WU02:FS00:0x21:Reading tar file state.xml
01:53:13:WU02:FS00:0x21:Reading tar file system.xml
01:53:13:WU02:FS00:0x21:Digital signatures verified
01:53:13:WU02:FS00:0x21:Folding@home GPU Core21 Folding@home Core
01:53:13:WU02:FS00:0x21:Version 0.0.18
01:53:18:WU02:FS00:0x21:ERROR:NaNs detected in forces. 0 0
01:53:18:WU02:FS00:0x21:Saving result file logfile_01.txt
01:53:18:WU02:FS00:0x21:Saving result file log.txt
01:53:18:WU02:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
01:53:19:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
01:53:19:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9431 run:1779 clone:1 gen:384 core:0x21 unit:0x000001c6ab436c9d586fdd410ab4a9cc
01:53:19:WU02:FS00:Uploading 7.00KiB to 171.67.108.157
01:53:19:WU02:FS00:Connecting to 171.67.108.157:8080
01:53:19:WU01:FS00:Connecting to 171.67.108.45:80
01:53:20:WU01:FS00:Assigned to work server 171.67.108.157
01:53:20:WU01:FS00:Requesting new work unit for slot 00: READY gpu:1:Baffin [Polaris11] from 171.67.108.157
01:53:20:WU01:FS00:Connecting to 171.67.108.157:8080
01:53:22:WU01:FS00:Downloading 5.14MiB
01:53:23:WU01:FS00:Download complete
01:53:24:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9414 run:2062 clone:0 gen:557 core:0x21 unit:0x000002a7ab436c9d585e06a0ea82f6e1
01:53:24:WU01:FS00:Starting
01:53:24:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Timbuck/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 7452 -checkpoint 8 -gpu 1 -gpu-vendor ati
01:53:24:WU01:FS00:Started FahCore on PID 7740
01:53:24:WU01:FS00:Core PID:7208
01:53:24:WU01:FS00:FahCore 0x21 started
01:53:24:WU01:FS00:0x21:*********************** Log Started 2018-01-31T01:53:24Z ***********************
01:53:24:WU01:FS00:0x21:Project: 9414 (Run 2062, Clone 0, Gen 557)
01:53:24:WU01:FS00:0x21:Unit: 0x000002a7ab436c9d585e06a0ea82f6e1
01:53:24:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
01:53:24:WU01:FS00:0x21:Machine: 0
01:53:24:WU01:FS00:0x21:Reading tar file core.xml
01:53:24:WU01:FS00:0x21:Reading tar file integrator.xml
01:53:24:WU01:FS00:0x21:Reading tar file state.xml
01:53:24:WU01:FS00:0x21:Reading tar file system.xml
01:53:24:WU01:FS00:0x21:Digital signatures verified
01:53:24:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
01:53:24:WU01:FS00:0x21:Version 0.0.18
01:53:26:WU02:FS00:Upload complete
01:53:26:WU02:FS00:Server responded WORK_ACK (400)
01:53:26:WU02:FS00:Cleaning up
01:53:28:WU01:FS00:0x21:ERROR:NaNs detected in forces. 0 0
01:53:28:WU01:FS00:0x21:Saving result file logfile_01.txt
01:53:28:WU01:FS00:0x21:Saving result file log.txt
01:53:28:WU01:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
01:53:29:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
01:53:29:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9414 run:2062 clone:0 gen:557 core:0x21 unit:0x000002a7ab436c9d585e06a0ea82f6e1
01:53:29:WU01:FS00:Uploading 7.00KiB to 171.67.108.157
01:53:29:WU01:FS00:Connecting to 171.67.108.157:8080
01:53:29:WU02:FS00:Connecting to 171.67.108.45:80
01:53:29:WU01:FS00:Upload complete
01:53:30:WU01:FS00:Server responded WORK_ACK (400)
01:53:30:WU01:FS00:Cleaning up
01:53:30:WU02:FS00:Assigned to work server 171.67.108.157
01:53:30:WU02:FS00:Requesting new work unit for slot 00: READY gpu:1:Baffin [Polaris11] from 171.67.108.157
01:53:30:WU02:FS00:Connecting to 171.67.108.157:8080
01:53:31:Removing old file 'configs/config-20180122-004744.xml'
01:53:31:Saving configuration to config.xml
01:53:31:<config>
01:53:31:  <!-- Folding Core -->
01:53:31:  <checkpoint v='8'/>
01:53:31:
01:53:31:  <!-- Network -->
01:53:31:  <proxy v=':8080'/>
01:53:31:
01:53:31:  <!-- Slot Control -->
01:53:31:  <pause-on-battery v='false'/>
01:53:31:  <power v='full'/>
01:53:31:
01:53:31:  <!-- User Information -->
01:53:31:  <passkey v='********************************'/>
01:53:31:  <team v='111065'/>
01:53:31:  <user v='Timpster'/>
01:53:31:
01:53:31:  <!-- Folding Slots -->
01:53:31:  <slot id='1' type='GPU'/>
01:53:31:  <slot id='0' type='GPU'/>
01:53:31:</config>
01:53:31:WU02:FS00:Downloading 5.15MiB
01:53:33:WU02:FS00:Download complete
01:53:33:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9414 run:366 clone:1 gen:702 core:0x21 unit:0x0000034cab436c9d585e069234720e85
01:53:33:WU02:FS00:Starting
01:53:33:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Timbuck/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 7452 -checkpoint 8 -gpu 1 -gpu-vendor ati
01:53:33:WU02:FS00:Started FahCore on PID 8072
01:53:33:WU02:FS00:Core PID:2748
01:53:33:WU02:FS00:FahCore 0x21 started
01:53:34:WU02:FS00:0x21:*********************** Log Started 2018-01-31T01:53:33Z ***********************
01:53:34:WU02:FS00:0x21:Project: 9414 (Run 366, Clone 1, Gen 702)
01:53:34:WU02:FS00:0x21:Unit: 0x0000034cab436c9d585e069234720e85
01:53:34:WU02:FS00:0x21:CPU: 0x00000000000000000000000000000000
01:53:34:WU02:FS00:0x21:Machine: 0
01:53:34:WU02:FS00:0x21:Reading tar file core.xml
01:53:34:WU02:FS00:0x21:Reading tar file integrator.xml
01:53:34:WU02:FS00:0x21:Reading tar file state.xml
01:53:34:WU02:FS00:0x21:Reading tar file system.xml
01:53:34:WU02:FS00:0x21:Digital signatures verified
01:53:34:WU02:FS00:0x21:Folding@home GPU Core21 Folding@home Core
01:53:34:WU02:FS00:0x21:Version 0.0.18
01:53:36:FS00:Paused
01:53:36:FS00:Shutting core down
01:53:36:WU02:FS00:0x21:WARNING:Console control signal 1 on PID 2748
01:53:36:WU02:FS00:0x21:Exiting, please wait. . .
01:53:38:WU02:FS00:0x21:ERROR:NaNs detected in forces. 0 0
01:53:38:WU02:FS00:0x21:Saving result file logfile_01.txt
01:53:38:WU02:FS00:0x21:Saving result file log.txt
01:53:38:WU02:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
01:53:39:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
I have again, restarted my PC but with no changes. The only changes I made were allowing windows 10 (with Microsoft system configuration tool--msconfig) to use 4GB of ram, unchecking the box for "maximum memory" and setting the maximum CPUs to "8*, as well as changing some services. If you need a list of my services, I'll provide a screenshot, multiple, to show them all.
SteveWillis
Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Re: Just started getting ALL "bad work units" RX 560
Post by SteveWillis »
If it was me I'd try reversing my changes. If that fixes it then making the changes one at a time to see what made the difference. Probably easier said than done though.
You have not listed the Configuration portion of the log, we are just making up the help. Guessing in the dark.
You have at least two GPUs, so you need one CPU per GPU devoted to feeding them. This makes it unlikely that 8 is the correct number of CPUs, as few CPUs have 10 cores. Because F@H hates prime numbers and multiples of large primes, 6 CPUs may be you best choice if you have 8 cores. (we have no way to tell, you did not give us your configuration)
You have Windows 10 , so one or both GPU drivers may change at any time, I would do a clean install of the latest driver for both cards, from the Nvidia and AMD web sites.
Guessing in the dark: Are you overclocking the GPU?
If so, reset the clocking to the originally specified values.
GPU timpster
MSConfig shows the date for all changes made, so I checked all the boxes (in a group) till the date different. I also just now reinstalled the AMD drivers, and rebooted, with no positive changes in WU dropping. I still receive all "bad work unit" errors for every WU.
Config
9:17:00:<config>
19:17:00:  <!-- Folding Core -->
19:17:00:  <checkpoint v='8'/>
19:17:00:
19:17:00:  <!-- Network -->
19:17:00:  <proxy v=':8080'/>
19:17:00:
19:17:00:  <!-- Slot Control -->
19:17:00:  <pause-on-battery v='false'/>
19:17:00:  <power v='full'/>
19:17:00:
19:17:00:  <!-- User Information -->
19:17:00:  <passkey v='********************************'/>
19:17:00:  <team v='111065'/>
19:17:00:  <user v='Timpster'/>
19:17:00:
19:17:00:  <!-- Folding Slots -->
19:17:00:  <slot id='1' type='GPU'/>
19:17:00:  <slot id='0' type='CPU'>
19:17:00:    <cpus v='4'/>
19:17:00:  </slot>
19:17:00:  <slot id='2' type='GPU'>
19:17:00:    <paused v='true'/>
19:17:00:  </slot>
19:17:00:</config>
Slot 2 is the AMD card, I have it paused for now, and I've deleted and re-added it numerous times. I don't know what could be the cause. I've reset all the settings in MSConfig, not using any of the "boot" options, and as stated reset my selection of services.
Reset my clock speeds for the card to the default, it's as if FAH can't use my amd gpu correctly anymore: log again
19:17:00:<config>
19:17:00:
19:17:00:
19:17:00:
19:17:00:
19:17:00:  </slot>
19:17:00:  </slot>
19:17:00:</config>
19:17:33:WU00:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
19:18:49:WU00:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
19:19:23:WU03:FS01:0x21:Completed 3875000 out of 6250000 steps (62%)
19:20:06:WU00:FS00:0xa7:Completed 100000 out of 2500000 steps (4%)
19:21:23:WU00:FS00:0xa7:Completed 125000 out of 2500000 steps (5%)
19:21:25:FS02:Unpaused
19:21:25:WU02:FS02:Starting
19:21:25:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Timbuck/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6752 -checkpoint 8 -gpu 1 -gpu-vendor ati
19:21:25:WU02:FS02:Started FahCore on PID 3632
19:21:25:WU02:FS02:Core PID:8084
19:21:25:WU02:FS02:FahCore 0x21 started
19:21:26:WU02:FS02:0x21:*********************** Log Started 2018-01-31T19:21:25Z ***********************
19:21:26:WU02:FS02:0x21:Project: 9414 (Run 1808, Clone 1, Gen 460)
19:21:26:WU02:FS02:0x21:Unit: 0x00000233ab436c9d585e069e4eb30fbf
19:21:26:WU02:FS02:0x21:CPU: 0x00000000000000000000000000000000
19:21:26:WU02:FS02:0x21:Machine: 2
19:21:26:WU02:FS02:0x21:Reading tar file core.xml
19:21:26:WU02:FS02:0x21:Reading tar file integrator.xml
19:21:26:WU02:FS02:0x21:Reading tar file state.xml
19:21:26:WU02:FS02:0x21:Reading tar file system.xml
19:21:26:WU02:FS02:0x21:Digital signatures verified
19:21:26:WU02:FS02:0x21:Folding@home GPU Core21 Folding@home Core
19:21:26:WU02:FS02:0x21:Version 0.0.18
19:21:31:WU02:FS02:0x21:ERROR:NaNs detected in forces. 0 0
19:21:31:WU02:FS02:0x21:Saving result file logfile_01.txt
19:21:32:WU02:FS02:0x21:Saving result file log.txt
19:21:32:WU02:FS02:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
19:21:32:WARNING:WU02:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:21:32:WU02:FS02:Sending unit results: id:02 state:SEND error:FAULTY project:9414 run:1808 clone:1 gen:460 core:0x21 unit:0x00000233ab436c9d585e069e4eb30fbf
19:21:32:WU02:FS02:Uploading 7.00KiB to 171.67.108.157
19:21:32:WU02:FS02:Connecting to 171.67.108.157:8080
19:21:32:WU01:FS02:Connecting to 171.67.108.45:80
19:21:33:WU01:FS02:Assigned to work server 171.67.108.157
19:21:33:WU01:FS02:Requesting new work unit for slot 02: READY gpu:1:Baffin [Polaris11] from 171.67.108.157
19:21:33:WU01:FS02:Connecting to 171.67.108.157:8080
19:21:33:WU02:FS02:Upload complete
19:21:33:WU02:FS02:Server responded WORK_ACK (400)
19:21:33:WU02:FS02:Cleaning up
19:21:34:WU01:FS02:Downloading 5.17MiB
19:21:37:FS02:Paused
19:21:40:WU01:FS02:Download 35.09%
19:21:41:WU01:FS02:Download complete
19:21:41:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9414 run:413 clone:0 gen:795 core:0x21 unit:0x000003b0ab436c9d585e06926905311b
