failure to connect to the collection server
djgibbons
Post by djgibbons »
I have a NVidia Quadro K4200 running driver 390.65. The current job is 100% complete but there is a failure to connect to the collection server. The log has this information:
14:03:00:WU01:FS00:Trying to send results to collection server
14:03:00:WU01:FS00:Uploading 94.63KiB to 171.67.108.25
14:03:00:WU01:FS00:Connecting to 171.67.108.25:8080
14:03:21:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
14:03:21:WU01:FS00:Connecting to 171.67.108.25:80
14:03:42:ERROR:WU01:FS00:Exception: Failed to connect to 171.67.108.25:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
This has been going on for many days now. The GPU job is stuck in SEND status. Apparently there is hundreds of billions of years left to complete the work.
1) Is this a normal state?
2) Is there a way to help the SEND take place?
Duncan
Hardware configuration: Mac Pro 2.8 quad 12 GB smp4
MacBook Pro 2.9 i7 8 GB smp2
Re: failure to connect to the collection server
You have shown too little of the log entry, what is the WU that is being returned and what is the WS it also is being uploaded to? The CS is the fallback, so returns are first tried to the WS before the CS.
171.67.108.25 is not shown on the Server Status page, so it is either an old CS that was configured for the project at some time in the past, or a new one that has not been added yet to the page. The best that I can tell is that it is not accepting connections, I tried the address in a browser window. We need the WU and WS information to check if the WS is down.
iMac 2.8 i7 12 GB smp8, Mac Pro 2.8 quad 12 GB smp6
MacBook Pro 2.9 i7 8 GB smp3
See the signature block below (in this post).
Do you connect through a proxy serveror is this a normal home connection?
djgibbons
Post by djgibbons »
This is a normal home connection. Log below with (xx%) lines and repetition deleted as needed:
*********************** Log Started 2018-01-21T18:00:24Z ***********************
18:00:24:************************* Folding@home Client *************************
18:00:24:      Website: http://folding.stanford.edu/
18:00:24:    Copyright: (c) 2009-2014 Stanford University
18:00:24:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:00:24:         Args: --open-web-control
18:00:24:       Config: C:/Users/Duncan/AppData/Roaming/FAHClient/config.xml
18:00:24:******************************** Build ********************************
18:00:24:      Version: 7.4.4
18:00:24:         Date: Mar 4 2014
18:00:24:         Time: 20:26:54
18:00:24:      SVN Rev: 4130
18:00:24:       Branch: fah/trunk/client
18:00:24:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
18:00:24:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
18:00:24:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
18:00:24:     Platform: win32 XP
18:00:24:         Bits: 32
18:00:24:         Mode: Release
18:00:24:******************************* System ********************************
18:00:24:          CPU: Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz
18:00:24:       CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
18:00:24:         CPUs: 8
18:00:24:       Memory: 7.99GiB
18:00:24:  Free Memory: 5.76GiB
18:00:24:      Threads: WINDOWS_THREADS
18:00:24:   OS Version: 6.2
18:00:24:  Has Battery: false
18:00:24:   On Battery: false
18:00:24:   UTC Offset: -5
18:00:24:          PID: 9192
18:00:24:          CWD: C:/Users/Duncan/AppData/Roaming/FAHClient
18:00:24:           OS: Windows 10 Pro
18:00:24:      OS Arch: AMD64
18:00:24:         GPUs: 1
18:00:24:        GPU 0: NVIDIA:3 GK104 [Quadro K4200]
18:00:24:         CUDA: 3.0
18:00:24:  CUDA Driver: 9010
18:00:24:Win32 Service: false
18:00:24:***********************************************************************
18:00:25:<config>
18:00:25:  <!-- Network -->
18:00:25:  <proxy v=':8080'/>
18:00:25:
18:00:25:  <!-- Slot Control -->
18:00:25:  <pause-on-battery v='false'/>
18:00:25:  <power v='LIGHT'/>
18:00:25:
18:00:25:  <!-- User Information -->
18:00:25:  <user v='Duncan_Gibbons'/>
18:00:25:
18:00:25:  <!-- Folding Slots -->
18:00:25:  <slot id='0' type='GPU'>
18:00:25:    <idle v='true'/>
18:00:25:  </slot>
18:00:25:  <slot id='1' type='CPU'>
18:00:25:  </slot>
18:00:25:</config>
18:00:25:Trying to access database...
18:00:25:Successfully acquired database lock
18:00:25:Enabled folding slot 00: PAUSED gpu:0:GK104 [Quadro K4200] (waiting for idle)
18:00:25:Enabled folding slot 01: PAUSED cpu:4 (waiting for idle)
18:00:25:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:5771 run:13 clone:150 gen:3784 core:0x11 unit:0x7293eb0553c5269f0ec80096000d168b
18:00:25:WU01:FS00:Uploading 94.63KiB to 171.67.108.11
18:00:25:WU01:FS00:Connecting to 171.67.108.11:8080
18:00:34:WU02:FS01:Starting
18:00:34:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Duncan/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 9192 -checkpoint 15 -np 4
18:00:34:WU02:FS01:Started FahCore on PID 11364
18:00:34:WU02:FS01:Core PID:11396
18:00:34:WU02:FS01:FahCore 0xa4 started
18:00:35:WU02:FS01:0xa4:
18:00:35:WU02:FS01:0xa4:*------------------------------*
18:00:35:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
18:00:35:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
18:00:35:WU02:FS01:0xa4:Preparing to commence simulation
18:00:35:WU02:FS01:0xa4:- Looking at optimizations...
18:00:35:WU02:FS01:0xa4:- Files status OK
18:00:35:WU02:FS01:0xa4:- Expanded 739106 -> 1929672 (decompressed 261.0 percent)
18:00:35:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=739106 data_size=1929672, decompressed_data_size=1929672 diff=0
18:00:35:WU02:FS01:0xa4:- Digital signature verified
18:00:35:WU02:FS01:0xa4:Project: 14005 (Run 0, Clone 524, Gen 6)
18:00:35:WU02:FS01:0xa4:Assembly optimizations on if available.
18:00:35:WU02:FS01:0xa4:Entering M.D.
18:00:41:WU02:FS01:0xa4:Using Gromacs checkpoints
18:00:41:WU02:FS01:0xa4:Mapping NT from 4 to 4
18:00:41:WU02:FS01:0xa4:Resuming from checkpoint
18:00:41:WU02:FS01:0xa4:Verified 02/wudata_01.log
18:00:41:WU02:FS01:0xa4:Verified 02/wudata_01.trr
18:00:41:WU02:FS01:0xa4:Verified 02/wudata_01.xtc
18:00:41:WU02:FS01:0xa4:Verified 02/wudata_01.edr
18:00:41:WU02:FS01:0xa4:Completed 52790 out of 2500000 steps  (2%)
18:01:26:Removing old file 'configs/config-20171230-195107.xml'
18:01:26:Saving configuration to config.xml
18:01:26:<config>
18:01:26:  <!-- Network -->
18:01:26:  <proxy v=':8080'/>
18:01:26:
18:01:26:  <!-- Slot Control -->
18:01:26:  <pause-on-battery v='false'/>
18:01:26:  <power v='LIGHT'/>
18:01:26:
18:01:26:  <!-- User Information -->
18:01:26:  <user v='Duncan_Gibbons'/>
18:01:26:
18:01:26:  <!-- Folding Slots -->
18:01:26:  <slot id='0' type='GPU'/>
18:01:26:  <slot id='1' type='CPU'/>
18:01:26:</config>
18:01:28:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
18:01:28:WU01:FS00:Connecting to 171.67.108.25:80
18:01:49:ERROR:WU01:FS00:Exception: Failed to connect to 171.67.108.25:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
******************************* Date: 2018-01-22 *******************************
02:40:14:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:5771 run:13 clone:150 gen:3784 core:0x11 unit:0x7293eb0553c5269f0ec80096000d168b
02:40:15:WU01:FS00:Uploading 94.63KiB to 171.67.108.11
02:40:15:WU01:FS00:Connecting to 171.67.108.11:8080
02:40:36:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:40:36:WU01:FS00:Connecting to 171.67.108.11:80
02:40:57:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
******************************* Date: 2018-01-23 *******************************
02:02:15:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:5771 run:13 clone:150 gen:3784 core:0x11 unit:0x7293eb0553c5269f0ec80096000d168b
02:02:15:WU01:FS00:Uploading 94.63KiB to 171.67.108.11
02:02:15:WU01:FS00:Connecting to 171.67.108.11:8080
02:02:36:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:02:36:WU01:FS00:Connecting to 171.67.108.11:80
02:02:57:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
15:59:50:WU00:FS01:Connecting to 171.67.108.45:8080
15:59:51:WU00:FS01:Assigned to work server 155.247.166.219
15:59:51:WU00:FS01:Requesting new work unit for slot 01: RUNNING cpu:4 from 155.247.166.219
15:59:51:WU00:FS01:Connecting to 155.247.166.219:8080
15:59:51:WU00:FS01:Downloading 141.38KiB
15:59:51:WU00:FS01:Download complete
15:59:51:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13743 run:20 clone:18 gen:47 core:0xa7 unit:0x000000300002894b59d5a2cae00f1174
16:28:10:WU02:FS01:0xa4:Completed 2500000 out of 2500000 steps  (100%)
16:28:11:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
16:28:21:WU02:FS01:0xa4:
16:28:21:WU02:FS01:0xa4:Finished Work Unit:
16:28:21:WU02:FS01:0xa4:- Reading up to 4508208 from "02/wudata_01.trr": Read 4508208
16:28:21:WU02:FS01:0xa4:trr file hash check passed.
16:28:21:WU02:FS01:0xa4:- Reading up to 501844 from "02/wudata_01.xtc": Read 501844
16:28:21:WU02:FS01:0xa4:xtc file hash check passed.
16:28:21:WU02:FS01:0xa4:edr file hash check passed.
16:28:21:WU02:FS01:0xa4:logfile size: 65250
16:28:21:WU02:FS01:0xa4:Leaving Run
16:28:26:WU02:FS01:0xa4:- Writing 5112370 bytes of core data to disk...
16:28:27:WU02:FS01:0xa4:Done: 5111858 -> 4341216 (compressed to 84.9 percent)
16:28:27:WU02:FS01:0xa4:  ... Done.
16:28:27:WU02:FS01:0xa4:- Shutting down core
16:28:27:WU02:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
16:28:28:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:28:28:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:14005 run:0 clone:524 gen:6 core:0xa4 unit:0x000000060002894c59e4cffd66316bdc
16:28:28:WU02:FS01:Uploading 4.14MiB to 155.247.166.220
16:28:28:WU00:FS01:Starting
16:28:28:WU02:FS01:Connecting to 155.247.166.220:8080
16:28:28:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Duncan/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 9192 -checkpoint 15 -np 4
16:28:28:WU00:FS01:Started FahCore on PID 3296
16:28:28:WU00:FS01:Core PID:5824
16:28:28:WU00:FS01:FahCore 0xa7 started
16:28:29:WU00:FS01:0xa7:*********************** Log Started 2018-01-23T16:28:29Z ***********************
16:28:29:WU00:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
16:28:29:WU00:FS01:0xa7:       Type: 0xa7
16:28:29:WU00:FS01:0xa7:       Core: Gromacs
16:28:29:WU00:FS01:0xa7:    Website: http://folding.stanford.edu/
16:28:29:WU00:FS01:0xa7:  Copyright: (c) 2009-2016 Stanford University
16:28:29:WU00:FS01:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:28:29:WU00:FS01:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 3296 -checkpoint 15 -np 4
16:28:29:WU00:FS01:0xa7:     Config: <none>
16:28:29:WU00:FS01:0xa7:************************************ Build *************************************
16:28:29:WU00:FS01:0xa7:    Version: 0.0.16
16:28:29:WU00:FS01:0xa7:       Date: Oct 31 2017
16:28:29:WU00:FS01:0xa7:       Time: 14:04:33
16:28:29:WU00:FS01:0xa7: Repository: Git
16:28:29:WU00:FS01:0xa7:   Revision: 2f0a8a3d0b0698be48154fe99a0216f289060932
16:28:29:WU00:FS01:0xa7:     Branch: master
16:28:29:WU00:FS01:0xa7:   Compiler: Visual C++ 2008
16:28:29:WU00:FS01:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:28:29:WU00:FS01:0xa7:   Platform: win32 10
16:28:29:WU00:FS01:0xa7:       Bits: 64
16:28:29:WU00:FS01:0xa7:       Mode: Release
16:28:29:WU00:FS01:0xa7:       SIMD: sse2
16:28:29:WU00:FS01:0xa7:************************************ System ************************************
16:28:29:WU00:FS01:0xa7:        CPU: Unknown
16:28:29:WU00:FS01:0xa7:     CPU ID:
16:28:29:WU00:FS01:0xa7:       CPUs: 8
16:28:29:WU00:FS01:0xa7:     Memory: 7.99GiB
16:28:29:WU00:FS01:0xa7:Free Memory: 5.73GiB
16:28:29:WU00:FS01:0xa7:    Threads: WINDOWS_THREADS
16:28:29:WU00:FS01:0xa7: OS Version: 6.2
16:28:29:WU00:FS01:0xa7:Has Battery: false
16:28:29:WU00:FS01:0xa7: On Battery: false
16:28:29:WU00:FS01:0xa7: UTC Offset: -5
16:28:29:WU00:FS01:0xa7:        PID: 5824
16:28:29:WU00:FS01:0xa7:        CWD: C:\Users\Duncan\AppData\Roaming\FAHClient\work
16:28:29:WU00:FS01:0xa7:         OS: Windows 10 Pro
16:28:29:WU00:FS01:0xa7:    OS Arch: AMD64
16:28:29:WU00:FS01:0xa7:********************************************************************************
16:28:29:WU00:FS01:0xa7:Project: 13743 (Run 20, Clone 18, Gen 47)
16:28:29:WU00:FS01:0xa7:Unit: 0x000000300002894b59d5a2cae00f1174
16:28:29:WU00:FS01:0xa7:Reading tar file core.xml
16:28:29:WU00:FS01:0xa7:Reading tar file frame47.tpr
16:28:29:WU00:FS01:0xa7:Digital signatures verified
16:28:29:WU00:FS01:0xa7:Calling: mdrun -s frame47.tpr -o frame47.trr -cpt 15 -nt 4
16:28:29:WU00:FS01:0xa7:Steps: first=117500000 total=2500000
16:28:30:WU00:FS01:0xa7:Completed 1 out of 2500000 steps (0%)
16:28:33:WU02:FS01:Upload complete
16:28:33:WU02:FS01:Server responded WORK_ACK (400)
16:28:33:WU02:FS01:Final credit estimate, 3666.00 points
16:28:33:WU02:FS01:Cleaning up
16:32:32:WU00:FS01:0xa7:Completed 25000 out of 2500000 steps (1%)
16:36:37:WU00:FS01:0xa7:Completed 50000 out of 2500000 steps (2%)
20:02:15:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:5771 run:13 clone:150 gen:3784 core:0x11 unit:0x7293eb0553c5269f0ec80096000d168b
20:02:15:WU01:FS00:Uploading 94.63KiB to 171.67.108.11
20:02:15:WU01:FS00:Connecting to 171.67.108.11:8080
20:02:36:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
20:02:36:WU01:FS00:Connecting to 171.67.108.11:80
20:02:57:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:19:53:WU00:FS01:0xa7:Completed 2475000 out of 2500000 steps (99%)
23:19:54:WU02:FS01:Connecting to 171.67.108.45:8080
23:19:55:WU02:FS01:Assigned to work server 155.247.166.219
23:19:55:WU02:FS01:Requesting new work unit for slot 01: RUNNING cpu:4 from 155.247.166.219
23:19:55:WU02:FS01:Connecting to 155.247.166.219:8080
23:19:56:WU02:FS01:Downloading 1.08MiB
23:19:56:WU02:FS01:Download complete
23:19:56:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8635 run:1 clone:131 gen:152 core:0xa4 unit:0x000000a60002894b582b55aec1ce2c57
23:25:58:WU00:FS01:0xa7:Completed 2500000 out of 2500000 steps (100%)
23:25:59:WU00:FS01:0xa7:Saving result file ..\logfile_01.txt
23:25:59:WU00:FS01:0xa7:Saving result file frame47.trr
23:25:59:WU00:FS01:0xa7:Saving result file md.log
23:25:59:WU00:FS01:0xa7:Saving result file science.log
23:25:59:WU00:FS01:0xa7:Saving result file traj_comp.xtc
23:26:00:WU00:FS01:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
23:26:01:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:26:01:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:13743 run:20 clone:18 gen:47 core:0xa7 unit:0x000000300002894b59d5a2cae00f1174
23:26:01:WU00:FS01:Uploading 1.66MiB to 155.247.166.219
23:26:01:WU02:FS01:Starting
23:26:01:WU00:FS01:Connecting to 155.247.166.219:8080
23:26:01:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Duncan/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 9192 -checkpoint 15 -np 4
23:26:01:WU02:FS01:Started FahCore on PID 10716
23:26:01:WU02:FS01:Core PID:7728
23:26:01:WU02:FS01:FahCore 0xa4 started
23:26:02:WU02:FS01:0xa4:
23:26:02:WU02:FS01:0xa4:*------------------------------*
23:26:02:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
23:26:02:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
23:26:02:WU02:FS01:0xa4:Preparing to commence simulation
23:26:02:WU02:FS01:0xa4:- Looking at optimizations...
23:26:02:WU02:FS01:0xa4:- Created dyn
23:26:02:WU02:FS01:0xa4:- Files status OK
23:26:02:WU02:FS01:0xa4:- Expanded 1128446 -> 2619636 (decompressed 232.1 percent)
23:26:02:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1128446 data_size=2619636, decompressed_data_size=2619636 diff=0
23:26:02:WU02:FS01:0xa4:- Digital signature verified
23:26:02:WU02:FS01:0xa4:Project: 8635 (Run 1, Clone 131, Gen 152)
23:26:02:WU02:FS01:0xa4:Assembly optimizations on if available.
23:26:02:WU02:FS01:0xa4:Entering M.D.
23:26:03:WU00:FS01:Upload complete
23:26:03:WU00:FS01:Server responded WORK_ACK (400)
23:26:03:WU00:FS01:Final credit estimate, 731.00 points
23:26:03:WU00:FS01:Cleaning up
23:26:08:WU02:FS01:0xa4:Mapping NT from 4 to 4
23:26:08:WU02:FS01:0xa4:Completed 0 out of 1250000 steps  (0%)
23:50:46:WU02:FS01:0xa4:Completed 12500 out of 1250000 steps  (1%)
00:13:04:WU02:FS01:0xa4:Completed 25000 out of 1250000 steps  (2%)
******************************* Date: 2018-01-24 *******************************
******************************* Date: 2018-01-25 *******************************
13:24:56:WU02:FS01:0xa4:Completed 1237500 out of 1250000 steps  (99%)
13:24:56:WU00:FS01:Connecting to 171.67.108.45:8080
13:24:56:WU00:FS01:Assigned to work server 155.247.166.219
13:24:56:WU00:FS01:Requesting new work unit for slot 01: RUNNING cpu:4 from 155.247.166.219
13:24:57:WU00:FS01:Connecting to 155.247.166.219:8080
13:24:57:WU00:FS01:Downloading 177.35KiB
13:24:57:WU00:FS01:Download complete
13:24:57:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13740 run:113 clone:18 gen:33 core:0xa7 unit:0x000000210002894b59d62fd21bf8948e
13:47:23:WU02:FS01:0xa4:Completed 1250000 out of 1250000 steps  (100%)
13:47:25:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
13:47:35:WU02:FS01:0xa4:
13:47:35:WU02:FS01:0xa4:Finished Work Unit:
13:47:35:WU02:FS01:0xa4:- Reading up to 5122368 from "02/wudata_01.trr": Read 5122368
13:47:35:WU02:FS01:0xa4:trr file hash check passed.
13:47:35:WU02:FS01:0xa4:- Reading up to 186448 from "02/wudata_01.xtc": Read 186448
13:47:35:WU02:FS01:0xa4:xtc file hash check passed.
13:47:35:WU02:FS01:0xa4:edr file hash check passed.
13:47:35:WU02:FS01:0xa4:logfile size: 44813
13:47:35:WU02:FS01:0xa4:Leaving Run
13:47:38:WU02:FS01:0xa4:- Writing 5373329 bytes of core data to disk...
13:47:39:WU02:FS01:0xa4:Done: 5372817 -> 4419403 (compressed to 82.2 percent)
13:47:39:WU02:FS01:0xa4:  ... Done.
13:47:40:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:47:41:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:8635 run:1 clone:131 gen:152 core:0xa4 unit:0x000000a60002894b582b55aec1ce2c57
13:47:41:WU02:FS01:Uploading 4.22MiB to 155.247.166.219
13:47:41:WU00:FS01:Starting
13:47:41:WU02:FS01:Connecting to 155.247.166.219:8080
13:47:41:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Duncan/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 9192 -checkpoint 15 -np 4
13:47:41:WU00:FS01:Started FahCore on PID 9484
13:47:41:WU00:FS01:Core PID:11160
13:47:41:WU00:FS01:FahCore 0xa7 started
13:47:41:WU00:FS01:0xa7:*********************** Log Started 2018-01-25T13:47:41Z ***********************
13:47:41:WU00:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
13:47:41:WU00:FS01:0xa7:       Type: 0xa7
13:47:41:WU00:FS01:0xa7:       Core: Gromacs
13:47:41:WU00:FS01:0xa7:    Website: http://folding.stanford.edu/
13:47:41:WU00:FS01:0xa7:  Copyright: (c) 2009-2016 Stanford University
13:47:41:WU00:FS01:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:47:41:WU00:FS01:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 9484 -checkpoint 15 -np 4
13:47:42:WU00:FS01:0xa7:     Config: <none>
13:47:42:WU00:FS01:0xa7:************************************ Build *************************************
13:47:42:WU00:FS01:0xa7:    Version: 0.0.16
13:47:42:WU00:FS01:0xa7:       Date: Oct 31 2017
13:47:42:WU00:FS01:0xa7:       Time: 14:04:33
13:47:42:WU00:FS01:0xa7: Repository: Git
13:47:42:WU00:FS01:0xa7:   Revision: 2f0a8a3d0b0698be48154fe99a0216f289060932
13:47:42:WU00:FS01:0xa7:     Branch: master
13:47:42:WU00:FS01:0xa7:   Compiler: Visual C++ 2008
13:47:42:WU00:FS01:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:47:42:WU00:FS01:0xa7:   Platform: win32 10
13:47:42:WU00:FS01:0xa7:       Bits: 64
13:47:42:WU00:FS01:0xa7:       Mode: Release
13:47:42:WU00:FS01:0xa7:       SIMD: sse2
13:47:42:WU00:FS01:0xa7:************************************ System ************************************
13:47:42:WU00:FS01:0xa7:        CPU: Unknown
13:47:42:WU00:FS01:0xa7:     CPU ID:
13:47:42:WU00:FS01:0xa7:       CPUs: 8
13:47:42:WU00:FS01:0xa7:     Memory: 7.99GiB
13:47:42:WU00:FS01:0xa7:Free Memory: 5.83GiB
13:47:42:WU00:FS01:0xa7:    Threads: WINDOWS_THREADS
13:47:42:WU00:FS01:0xa7: OS Version: 6.2
13:47:42:WU00:FS01:0xa7:Has Battery: false
13:47:42:WU00:FS01:0xa7: On Battery: false
13:47:42:WU00:FS01:0xa7: UTC Offset: -5
13:47:42:WU00:FS01:0xa7:        PID: 11160
13:47:42:WU00:FS01:0xa7:        CWD: C:\Users\Duncan\AppData\Roaming\FAHClient\work
13:47:42:WU00:FS01:0xa7:         OS: Windows 10 Pro
13:47:42:WU00:FS01:0xa7:    OS Arch: AMD64
13:47:42:WU00:FS01:0xa7:********************************************************************************
13:47:42:WU00:FS01:0xa7:Project: 13740 (Run 113, Clone 18, Gen 33)
13:47:42:WU00:FS01:0xa7:Unit: 0x000000210002894b59d62fd21bf8948e
13:47:42:WU00:FS01:0xa7:Reading tar file core.xml
13:47:42:WU00:FS01:0xa7:Reading tar file frame33.tpr
13:47:42:WU00:FS01:0xa7:Digital signatures verified
13:47:42:WU00:FS01:0xa7:Calling: mdrun -s frame33.tpr -o frame33.trr -cpt 15 -nt 4
13:47:42:WU00:FS01:0xa7:Steps: first=82500000 total=2500000
13:47:42:WU00:FS01:0xa7:Completed 1 out of 2500000 steps (0%)
13:47:45:WU02:FS01:Upload complete
13:47:46:WU02:FS01:Server responded WORK_ACK (400)
13:47:46:WU02:FS01:Final credit estimate, 2888.00 points
13:47:46:WU02:FS01:Cleaning up
13:51:42:WU00:FS01:0xa7:Completed 25000 out of 2500000 steps (1%)
13:55:58:WU00:FS01:0xa7:Completed 50000 out of 2500000 steps (2%)
20:36:43:WU00:FS01:0xa7:Completed 2475000 out of 2500000 steps (99%)
20:36:44:WU02:FS01:Connecting to 171.67.108.45:8080
20:36:45:WU02:FS01:Assigned to work server 155.247.166.220
20:36:45:WU02:FS01:Requesting new work unit for slot 01: RUNNING cpu:4 from 155.247.166.220
20:36:45:WU02:FS01:Connecting to 155.247.166.220:8080
20:36:46:WU02:FS01:Downloading 344.40KiB
20:36:46:WU02:FS01:Download complete
20:36:47:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8616 run:1264 clone:0 gen:2 core:0xa4 unit:0x000000030002894c57b79616d56f633a
20:40:48:WU00:FS01:0xa7:Completed 2500000 out of 2500000 steps (100%)
20:40:49:WU00:FS01:0xa7:Saving result file ..\logfile_01.txt
20:40:49:WU00:FS01:0xa7:Saving result file frame33.trr
20:40:49:WU00:FS01:0xa7:Saving result file md.log
20:40:49:WU00:FS01:0xa7:Saving result file science.log
20:40:49:WU00:FS01:0xa7:Saving result file traj_comp.xtc
20:40:50:WU00:FS01:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
20:40:50:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:40:50:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:13740 run:113 clone:18 gen:33 core:0xa7 unit:0x000000210002894b59d62fd21bf8948e
20:40:50:WU00:FS01:Uploading 1.66MiB to 155.247.166.219
20:40:50:WU00:FS01:Connecting to 155.247.166.219:8080
20:40:50:WU02:FS01:Starting
20:40:50:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Duncan/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 9192 -checkpoint 15 -np 4
20:40:51:WU02:FS01:Started FahCore on PID 2668
20:40:51:WU02:FS01:Core PID:1612
20:40:51:WU02:FS01:FahCore 0xa4 started
20:40:51:WU02:FS01:0xa4:
20:40:51:WU02:FS01:0xa4:*------------------------------*
20:40:51:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
20:40:51:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
20:40:51:WU02:FS01:0xa4:Preparing to commence simulation
20:40:51:WU02:FS01:0xa4:- Looking at optimizations...
20:40:51:WU02:FS01:0xa4:- Created dyn
20:40:51:WU02:FS01:0xa4:- Files status OK
20:40:51:WU02:FS01:0xa4:- Expanded 352151 -> 597116 (decompressed 169.5 percent)
20:40:51:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=352151 data_size=597116, decompressed_data_size=597116 diff=0
20:40:51:WU02:FS01:0xa4:- Digital signature verified
20:40:51:WU02:FS01:0xa4:Project: 8616 (Run 1264, Clone 0, Gen 2)
20:40:51:WU02:FS01:0xa4:Assembly optimizations on if available.
20:40:51:WU02:FS01:0xa4:Entering M.D.
20:40:52:WU00:FS01:Upload complete
20:40:52:WU00:FS01:Server responded WORK_ACK (400)
20:40:52:WU00:FS01:Final credit estimate, 739.00 points
20:40:53:WU00:FS01:Cleaning up
20:40:57:WU02:FS01:0xa4:Mapping NT from 4 to 4
20:40:57:WU02:FS01:0xa4:Completed 0 out of 2500000 steps  (0%)
20:51:34:WU02:FS01:0xa4:Completed 25000 out of 2500000 steps  (1%)
******************************* Date: 2018-01-26 *******************************
02:02:16:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:5771 run:13 clone:150 gen:3784 core:0x11 unit:0x7293eb0553c5269f0ec80096000d168b
02:02:16:WU01:FS00:Uploading 94.63KiB to 171.67.108.11
02:02:16:WU01:FS00:Connecting to 171.67.108.11:8080
02:02:37:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:02:37:WU01:FS00:Connecting to 171.67.108.11:80
02:02:58:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:14:42:WU02:FS01:0xa4:Completed 2475000 out of 2500000 steps  (99%)
14:14:43:WU00:FS01:Connecting to 171.67.108.45:8080
14:14:44:WU00:FS01:Assigned to work server 155.247.166.219
14:14:44:WU00:FS01:Requesting new work unit for slot 01: RUNNING cpu:4 from 155.247.166.219
14:14:44:WU00:FS01:Connecting to 155.247.166.219:8080
14:14:44:WU00:FS01:Downloading 142.08KiB
14:14:44:WU00:FS01:Download complete
14:14:45:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13749 run:168 clone:17 gen:27 core:0xa7 unit:0x0000001d0002894b59d5492bbe04f025
14:29:01:WU02:FS01:0xa4:Completed 2500000 out of 2500000 steps  (100%)
14:29:01:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
14:29:11:WU02:FS01:0xa4:
14:29:11:WU02:FS01:0xa4:Finished Work Unit:
14:29:11:WU02:FS01:0xa4:- Reading up to 1953936 from "02/wudata_01.trr": Read 1953936
14:29:11:WU02:FS01:0xa4:trr file hash check passed.
14:29:11:WU02:FS01:0xa4:- Reading up to 2462032 from "02/wudata_01.xtc": Read 2462032
14:29:11:WU02:FS01:0xa4:xtc file hash check passed.
14:29:11:WU02:FS01:0xa4:edr file hash check passed.
14:29:11:WU02:FS01:0xa4:logfile size: 61350
14:29:11:WU02:FS01:0xa4:Leaving Run
14:29:13:WU02:FS01:0xa4:- Writing 4508498 bytes of core data to disk...
14:29:14:WU02:FS01:0xa4:Done: 4507986 -> 4191674 (compressed to 92.9 percent)
14:29:15:WU02:FS01:0xa4:  ... Done.
14:29:15:WU02:FS01:0xa4:- Shutting down core
14:29:15:WU02:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
14:29:15:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:29:16:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:8616 run:1264 clone:0 gen:2 core:0xa4 unit:0x000000030002894c57b79616d56f633a
14:29:16:WU02:FS01:Uploading 4.00MiB to 155.247.166.220
14:29:16:WU00:FS01:Starting
14:29:16:WU02:FS01:Connecting to 155.247.166.220:8080
14:29:16:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Duncan/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 9192 -checkpoint 15 -np 4
14:29:16:WU00:FS01:Started FahCore on PID 5640
14:29:16:WU00:FS01:Core PID:972
14:29:16:WU00:FS01:FahCore 0xa7 started
14:29:17:WU00:FS01:0xa7:*********************** Log Started 2018-01-26T14:29:16Z ***********************
14:29:17:WU00:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
14:29:17:WU00:FS01:0xa7:       Type: 0xa7
14:29:17:WU00:FS01:0xa7:       Core: Gromacs
14:29:17:WU00:FS01:0xa7:    Website: http://folding.stanford.edu/
14:29:17:WU00:FS01:0xa7:  Copyright: (c) 2009-2016 Stanford University
14:29:17:WU00:FS01:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:29:17:WU00:FS01:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 5640 -checkpoint 15 -np 4
14:29:17:WU00:FS01:0xa7:     Config: <none>
14:29:17:WU00:FS01:0xa7:************************************ Build *************************************
14:29:17:WU00:FS01:0xa7:    Version: 0.0.16
14:29:17:WU00:FS01:0xa7:       Date: Oct 31 2017
14:29:17:WU00:FS01:0xa7:       Time: 14:04:33
14:29:17:WU00:FS01:0xa7: Repository: Git
14:29:17:WU00:FS01:0xa7:   Revision: 2f0a8a3d0b0698be48154fe99a0216f289060932
14:29:17:WU00:FS01:0xa7:     Branch: master
14:29:17:WU00:FS01:0xa7:   Compiler: Visual C++ 2008
14:29:17:WU00:FS01:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:29:17:WU00:FS01:0xa7:   Platform: win32 10
14:29:17:WU00:FS01:0xa7:       Bits: 64
14:29:17:WU00:FS01:0xa7:       Mode: Release
14:29:17:WU00:FS01:0xa7:       SIMD: sse2
14:29:17:WU00:FS01:0xa7:************************************ System ************************************
14:29:17:WU00:FS01:0xa7:        CPU: Unknown
14:29:17:WU00:FS01:0xa7:     CPU ID:
14:29:17:WU00:FS01:0xa7:       CPUs: 8
14:29:17:WU00:FS01:0xa7:     Memory: 7.99GiB
14:29:17:WU00:FS01:0xa7:Free Memory: 4.30GiB
14:29:17:WU00:FS01:0xa7:    Threads: WINDOWS_THREADS
14:29:17:WU00:FS01:0xa7: OS Version: 6.2
14:29:17:WU00:FS01:0xa7:Has Battery: false
14:29:17:WU00:FS01:0xa7: On Battery: false
14:29:17:WU00:FS01:0xa7: UTC Offset: -5
14:29:17:WU00:FS01:0xa7:        PID: 972
14:29:17:WU00:FS01:0xa7:        CWD: C:\Users\Duncan\AppData\Roaming\FAHClient\work
14:29:17:WU00:FS01:0xa7:         OS: Windows 10 Pro
14:29:17:WU00:FS01:0xa7:    OS Arch: AMD64
14:29:17:WU00:FS01:0xa7:********************************************************************************
14:29:17:WU00:FS01:0xa7:Project: 13749 (Run 168, Clone 17, Gen 27)
14:29:17:WU00:FS01:0xa7:Unit: 0x0000001d0002894b59d5492bbe04f025
14:29:17:WU00:FS01:0xa7:Reading tar file core.xml
14:29:17:WU00:FS01:0xa7:Reading tar file frame27.tpr
14:29:17:WU00:FS01:0xa7:Digital signatures verified
14:29:17:WU00:FS01:0xa7:Calling: mdrun -s frame27.tpr -o frame27.trr -cpt 15 -nt 4
14:29:17:WU00:FS01:0xa7:Steps: first=67500000 total=2500000
14:29:18:WU00:FS01:0xa7:Completed 1 out of 2500000 steps (0%)
14:29:20:WU02:FS01:Upload complete
14:29:20:WU02:FS01:Server responded WORK_ACK (400)
14:29:20:WU02:FS01:Final credit estimate, 1593.00 points
14:29:20:WU02:FS01:Cleaning up
14:34:54:WU00:FS01:0xa7:Completed 25000 out of 2500000 steps (1%)
14:40:29:WU00:FS01:0xa7:Completed 50000 out of 2500000 steps (2%)
23:34:43:WU00:FS01:0xa7:Completed 2475000 out of 2500000 steps (99%)
23:34:44:WU02:FS01:Connecting to 171.67.108.45:8080
23:34:45:WU02:FS01:Assigned to work server 155.247.166.219
23:34:45:WU02:FS01:Requesting new work unit for slot 01: RUNNING cpu:4 from 155.247.166.219
23:34:45:WU02:FS01:Connecting to 155.247.166.219:8080
23:34:46:WU02:FS01:Downloading 1.08MiB
23:34:46:WU02:FS01:Download complete
23:34:47:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8631 run:5 clone:20 gen:154 core:0xa4 unit:0x000000ad0002894b57f6ecd5c0c214ff
23:38:48:WU00:FS01:0xa7:Completed 2500000 out of 2500000 steps (100%)
23:38:49:WU00:FS01:0xa7:Saving result file ..\logfile_01.txt
23:38:49:WU00:FS01:0xa7:Saving result file frame27.trr
23:38:49:WU00:FS01:0xa7:Saving result file md.log
23:38:49:WU00:FS01:0xa7:Saving result file science.log
23:38:49:WU00:FS01:0xa7:Saving result file traj_comp.xtc
23:38:49:WU00:FS01:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
23:38:50:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:38:50:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:13749 run:168 clone:17 gen:27 core:0xa7 unit:0x0000001d0002894b59d5492bbe04f025
23:38:50:WU00:FS01:Uploading 1.66MiB to 155.247.166.219
23:38:50:WU02:FS01:Starting
23:38:50:WU00:FS01:Connecting to 155.247.166.219:8080
23:38:50:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Duncan/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 9192 -checkpoint 15 -np 4
23:38:50:WU02:FS01:Started FahCore on PID 8912
23:38:50:WU02:FS01:Core PID:10204
23:38:50:WU02:FS01:FahCore 0xa4 started
23:38:51:WU02:FS01:0xa4:
23:38:51:WU02:FS01:0xa4:*------------------------------*
23:38:51:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
23:38:51:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
23:38:51:WU02:FS01:0xa4:Preparing to commence simulation
23:38:51:WU02:FS01:0xa4:- Looking at optimizations...
23:38:51:WU02:FS01:0xa4:- Created dyn
23:38:51:WU02:FS01:0xa4:- Files status OK
23:38:51:WU02:FS01:0xa4:- Expanded 1129657 -> 2621880 (decompressed 232.0 percent)
23:38:51:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1129657 data_size=2621880, decompressed_data_size=2621880 diff=0
23:38:51:WU02:FS01:0xa4:- Digital signature verified
23:38:51:WU02:FS01:0xa4:Project: 8631 (Run 5, Clone 20, Gen 154)
23:38:51:WU02:FS01:0xa4:Assembly optimizations on if available.
23:38:51:WU02:FS01:0xa4:Entering M.D.
23:38:52:WU00:FS01:Upload complete
23:38:52:WU00:FS01:Server responded WORK_ACK (400)
23:38:52:WU00:FS01:Final credit estimate, 650.00 points
23:38:52:WU00:FS01:Cleaning up
23:38:57:WU02:FS01:0xa4:Mapping NT from 4 to 4
23:38:57:WU02:FS01:0xa4:Completed 0 out of 1250000 steps  (0%)
00:00:48:WU02:FS01:0xa4:Completed 12500 out of 1250000 steps  (1%)
00:22:46:WU02:FS01:0xa4:Completed 25000 out of 1250000 steps  (2%)
******************************* Date: 2018-01-27 *******************************
02:02:17:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:5771 run:13 clone:150 gen:3784 core:0x11 unit:0x7293eb0553c5269f0ec80096000d168b
02:02:17:WU01:FS00:Uploading 94.63KiB to 171.67.108.11
02:02:17:WU01:FS00:Connecting to 171.67.108.11:8080
02:02:38:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:02:38:WU01:FS00:Connecting to 171.67.108.11:80
02:02:59:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
******************************* Date: 2018-01-28 *******************************
02:03:00:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:30:27:WU02:FS01:0xa4:Completed 1237500 out of 1250000 steps  (99%)
12:30:28:WU00:FS01:Connecting to 171.67.108.45:8080
12:30:29:WU00:FS01:Assigned to work server 171.67.108.158
12:30:29:WU00:FS01:Requesting new work unit for slot 01: RUNNING cpu:4 from 171.67.108.158
12:30:29:WU00:FS01:Connecting to 171.67.108.158:8080
12:30:31:WU00:FS01:Downloading 806.39KiB
12:30:31:WU00:FS01:Download complete
12:30:31:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9033 run:556 clone:2 gen:1044 core:0xa4 unit:0x00000477ab436c9e5698313dd620dd6d
12:53:07:WU02:FS01:0xa4:Completed 1250000 out of 1250000 steps  (100%)
12:53:08:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
12:53:18:WU02:FS01:0xa4:
12:53:18:WU02:FS01:0xa4:Finished Work Unit:
12:53:18:WU02:FS01:0xa4:- Reading up to 5134080 from "02/wudata_01.trr": Read 5134080
12:53:18:WU02:FS01:0xa4:trr file hash check passed.
12:53:18:WU02:FS01:0xa4:- Reading up to 188604 from "02/wudata_01.xtc": Read 188604
12:53:18:WU02:FS01:0xa4:xtc file hash check passed.
12:53:18:WU02:FS01:0xa4:edr file hash check passed.
12:53:18:WU02:FS01:0xa4:logfile size: 45280
12:53:18:WU02:FS01:0xa4:Leaving Run
12:53:20:WU02:FS01:0xa4:- Writing 5387664 bytes of core data to disk...
12:53:22:WU02:FS01:0xa4:Done: 5387152 -> 4430892 (compressed to 82.2 percent)
12:53:22:WU02:FS01:0xa4:  ... Done.
12:53:23:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:53:23:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:8631 run:5 clone:20 gen:154 core:0xa4 unit:0x000000ad0002894b57f6ecd5c0c214ff
12:53:23:WU02:FS01:Uploading 4.23MiB to 155.247.166.219
12:53:23:WU00:FS01:Starting
12:53:23:WU02:FS01:Connecting to 155.247.166.219:8080
12:53:23:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Duncan/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 9192 -checkpoint 15 -np 4
12:53:23:WU00:FS01:Started FahCore on PID 9272
12:53:23:WU00:FS01:Core PID:3768
12:53:23:WU00:FS01:FahCore 0xa4 started
12:53:24:WU00:FS01:0xa4:
12:53:24:WU00:FS01:0xa4:*------------------------------*
12:53:24:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
12:53:24:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
12:53:24:WU00:FS01:0xa4:Preparing to commence simulation
12:53:24:WU00:FS01:0xa4:- Looking at optimizations...
12:53:24:WU00:FS01:0xa4:- Created dyn
12:53:24:WU00:FS01:0xa4:- Files status OK
12:53:24:WU00:FS01:0xa4:- Expanded 825228 -> 1401332 (decompressed 169.8 percent)
12:53:24:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=825228 data_size=1401332, decompressed_data_size=1401332 diff=0
12:53:24:WU00:FS01:0xa4:- Digital signature verified
12:53:24:WU00:FS01:0xa4:Project: 9033 (Run 556, Clone 2, Gen 1044)
12:53:24:WU00:FS01:0xa4:Assembly optimizations on if available.
12:53:24:WU00:FS01:0xa4:Entering M.D.
12:53:28:WU02:FS01:Upload complete
12:53:28:WU02:FS01:Server responded WORK_ACK (400)
12:53:28:WU02:FS01:Final credit estimate, 2945.00 points
12:53:28:WU02:FS01:Cleaning up
12:53:30:WU00:FS01:0xa4:Mapping NT from 4 to 4
12:53:30:WU00:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
12:59:31:WU00:FS01:0xa4:Completed 2500 out of 250000 steps  (1%)
13:05:33:WU00:FS01:0xa4:Completed 5000 out of 250000 steps  (2%)
14:28:33:26:127.0.0.1:New Web connection
20:02:18:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:5771 run:13 clone:150 gen:3784 core:0x11 unit:0x7293eb0553c5269f0ec80096000d168b
20:02:18:WU01:FS00:Uploading 94.63KiB to 171.67.108.11
20:02:18:WU01:FS00:Connecting to 171.67.108.11:8080
20:02:39:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
20:02:39:WU01:FS00:Connecting to 171.67.108.11:80
20:03:00:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:29:47:WU00:FS01:0xa4:Completed 247500 out of 250000 steps  (99%)
23:29:48:WU02:FS01:Connecting to 171.67.108.45:8080
23:29:49:WU02:FS01:Assigned to work server 155.247.166.219
23:29:49:WU02:FS01:Requesting new work unit for slot 01: RUNNING cpu:4 from 155.247.166.219
23:29:49:WU02:FS01:Connecting to 155.247.166.219:8080
23:29:49:WU02:FS01:Downloading 867.45KiB
23:29:50:WU02:FS01:Download complete
23:29:50:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8633 run:5 clone:48 gen:244 core:0xa4 unit:0x0000010c0002894b57f6f35e36d7262a
23:35:54:WU00:FS01:0xa4:Completed 250000 out of 250000 steps  (100%)
23:35:56:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
23:36:06:WU00:FS01:0xa4:
23:36:06:WU00:FS01:0xa4:Finished Work Unit:
23:36:06:WU00:FS01:0xa4:- Reading up to 811392 from "00/wudata_01.trr": Read 811392
23:36:06:WU00:FS01:0xa4:trr file hash check passed.
23:36:06:WU00:FS01:0xa4:- Reading up to 745728 from "00/wudata_01.xtc": Read 745728
23:36:06:WU00:FS01:0xa4:xtc file hash check passed.
23:36:06:WU00:FS01:0xa4:edr file hash check passed.
23:36:06:WU00:FS01:0xa4:logfile size: 25142
23:36:06:WU00:FS01:0xa4:Leaving Run
23:36:08:WU00:FS01:0xa4:- Writing 1584750 bytes of core data to disk...
23:36:08:WU00:FS01:0xa4:Done: 1584238 -> 1537577 (compressed to 97.0 percent)
23:36:08:WU00:FS01:0xa4:  ... Done.
23:36:09:WU00:FS01:0xa4:- Shutting down core
23:36:09:WU00:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
23:36:09:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:36:09:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9033 run:556 clone:2 gen:1044 core:0xa4 unit:0x00000477ab436c9e5698313dd620dd6d
23:36:09:WU00:FS01:Uploading 1.47MiB to 171.67.108.158
23:36:09:WU02:FS01:Starting
23:36:09:WU00:FS01:Connecting to 171.67.108.158:8080
23:36:09:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Duncan/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 9192 -checkpoint 15 -np 4
23:36:09:WU02:FS01:Started FahCore on PID 11504
23:36:10:WU02:FS01:Core PID:1312
23:36:10:WU02:FS01:FahCore 0xa4 started
23:36:10:WU02:FS01:0xa4:
23:36:10:WU02:FS01:0xa4:*------------------------------*
23:36:10:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
23:36:10:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
23:36:10:WU02:FS01:0xa4:Preparing to commence simulation
23:36:10:WU02:FS01:0xa4:- Looking at optimizations...
23:36:10:WU02:FS01:0xa4:- Created dyn
23:36:10:WU02:FS01:0xa4:- Files status OK
23:36:10:WU02:FS01:0xa4:- Expanded 887760 -> 2072336 (decompressed 233.4 percent)
23:36:10:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=887760 data_size=2072336, decompressed_data_size=2072336 diff=0
23:36:10:WU02:FS01:0xa4:- Digital signature verified
23:36:10:WU02:FS01:0xa4:Project: 8633 (Run 5, Clone 48, Gen 244)
23:36:10:WU02:FS01:0xa4:Assembly optimizations on if available.
23:36:10:WU02:FS01:0xa4:Entering M.D.
23:36:12:WU00:FS01:Upload complete
23:36:12:WU00:FS01:Server responded WORK_ACK (400)
23:36:12:WU00:FS01:Final credit estimate, 760.00 points
23:36:12:WU00:FS01:Cleaning up
23:36:16:WU02:FS01:0xa4:Mapping NT from 4 to 4
23:36:16:WU02:FS01:0xa4:Completed 0 out of 1250000 steps  (0%)
23:53:13:WU02:FS01:0xa4:Completed 12500 out of 1250000 steps  (1%)
00:10:20:WU02:FS01:0xa4:Completed 25000 out of 1250000 steps  (2%)
******************************* Date: 2018-01-29 *******************************
02:02:18:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:5771 run:13 clone:150 gen:3784 core:0x11 unit:0x7293eb0553c5269f0ec80096000d168b
02:02:18:WU01:FS00:Uploading 94.63KiB to 171.67.108.11
02:02:18:WU01:FS00:Connecting to 171.67.108.11:8080
02:02:39:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
02:02:39:WU01:FS00:Connecting to 171.67.108.11:80
Mod edit: added code tags to log file listing
It looks like you updated an older machine and changed the video card to a Quadro K4200, but it still had an old WU from years in the past. The WU trying to be uploaded is project:5771 run:13 clone:150 gen:3784 and was run on Core_11. That would have been assigned over 3 1/2 years ago, all Core_11 projects are now done. So both the WS and CS for that project are no longer in service. The folding client should have discarded the WU as it is long past its expiration, but that might be due to it being not correctly detecting that due to the 3+ years of being out of date.
From the log it looks like you haven't enabled folding o the GPU, or it is sending the wrong configuration information to the Assignment Server and not getting a WU. Probably the best way to fix this is to set the client to Finish, and uninstall it with its data after the current work is completed. Then reinstall the client.
One additional note, I did not see a passkey configured. You may want to get one and set that as part of your reinstalling of the client.
In addition to Joe_H's suggestions, there's one more thing I'd suggest:
> 18:00:25: </slot>
I have not found a good reason to use the "idle" option for a CPU slot. Operating systems do an excellent job of managing CPU priority. There's no perceptible lag introduced when foreground tasks supersede FAH's CPU processing whereas when the idle state comes an goes over the course of normal foreground usage there is a measurable loss in throughput.
I wish I could make a similar claim for a GPU slot but GPUs cannot be interrupted quickly and cleanly so the idle setting is a useful setting for slower GPUs -- depending on whether you notice screen-lag or not.
djgibbons
Post by djgibbons »
Thank you, Gentlemen. I will try these things to see if it clears the issue.
djgibbons
Post by djgibbons »
The uninstall/re-install seems to have worked. Regarding the 'waiting for idle' status on the GPU job, does the screen saver affect idle status? Or does this simply mean that graceful GPU interrupts are being used?
Your OS sets a IDLE status indicator whenever it detects the right conditions. Both screen-savers and FAH query the status of that indicator.
darth_grom
Post by darth_grom »
I am having the same issue with a package that has been sitting in the send cue for past several hours now. Is there anything I can do to clear/push it?
*********************** Log Started 2020-04-09T15:41:32Z ***********************
15:41:33:WU01:FS01:Connecting to 65.254.110.245:8080
15:41:33:WU01:FS01:Assigned to work server 13.90.152.57
15:41:33:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 13.90.152.57
15:41:33:WU01:FS01:Connecting to 13.90.152.57:8080
15:42:45:WU01:FS01:Downloading 86.23MiB
15:42:51:WU01:FS01:Download 18.70%
15:42:57:WU01:FS01:Download 45.15%
15:43:03:WU01:FS01:Download 71.75%
15:43:09:WU01:FS01:Download 94.44%
15:43:10:WU01:FS01:Download complete
15:43:10:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11781 run:0 clone:1186 gen:48 core:0x22 unit:0x000000480d5a98395e73c52c9638f680
15:43:10:WU01:FS01:Starting
15:43:10:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Darth\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 10824 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:43:10:WU01:FS01:Started FahCore on PID 13620
15:43:10:WU01:FS01:Core PID:13624
15:43:10:WU01:FS01:FahCore 0x22 started
15:43:11:WU01:FS01:0x22:*********************** Log Started 2020-04-09T15:43:10Z ***********************
15:43:11:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:43:11:WU01:FS01:0x22:       Type: 0x22
15:43:11:WU01:FS01:0x22:       Core: Core22
15:43:11:WU01:FS01:0x22:    Website: https://foldingathome.org/
15:43:11:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
15:43:11:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:43:11:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
15:43:11:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 13620 -checkpoint 15
15:43:11:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
15:43:11:WU01:FS01:0x22:             0 -gpu 0
15:43:11:WU01:FS01:0x22:     Config: <none>
15:43:11:WU01:FS01:0x22:************************************ Build *************************************
15:43:11:WU01:FS01:0x22:    Version: 0.0.2
15:43:11:WU01:FS01:0x22:       Date: Dec 6 2019
15:43:11:WU01:FS01:0x22:       Time: 21:30:31
15:43:11:WU01:FS01:0x22: Repository: Git
15:43:11:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
15:43:11:WU01:FS01:0x22:     Branch: HEAD
15:43:11:WU01:FS01:0x22:   Compiler: Visual C++ 2008
15:43:11:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:43:11:WU01:FS01:0x22:   Platform: win32 10
15:43:11:WU01:FS01:0x22:       Bits: 64
15:43:11:WU01:FS01:0x22:       Mode: Release
15:43:11:WU01:FS01:0x22:************************************ System ************************************
15:43:11:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
15:43:11:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
15:43:11:WU01:FS01:0x22:       CPUs: 8
15:43:11:WU01:FS01:0x22:     Memory: 31.93GiB
15:43:11:WU01:FS01:0x22:Free Memory: 27.60GiB
15:43:11:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
15:43:11:WU01:FS01:0x22: OS Version: 6.2
15:43:11:WU01:FS01:0x22:Has Battery: false
15:43:11:WU01:FS01:0x22: On Battery: false
15:43:11:WU01:FS01:0x22: UTC Offset: -4
15:43:11:WU01:FS01:0x22:        PID: 13624
15:43:11:WU01:FS01:0x22:        CWD: C:\Users\Darth\AppData\Roaming\FAHClient\work
15:43:11:WU01:FS01:0x22:         OS: Windows 10 Home
15:43:11:WU01:FS01:0x22:    OS Arch: AMD64
15:43:11:WU01:FS01:0x22:********************************************************************************
15:43:11:WU01:FS01:0x22:Project: 11781 (Run 0, Clone 1186, Gen 48)
15:43:11:WU01:FS01:0x22:Unit: 0x000000480d5a98395e73c52c9638f680
15:43:11:WU01:FS01:0x22:Reading tar file core.xml
15:43:11:WU01:FS01:0x22:Reading tar file integrator.xml
15:43:11:WU01:FS01:0x22:Reading tar file state.xml
15:43:12:WU01:FS01:0x22:Reading tar file system.xml
15:43:13:WU01:FS01:0x22:Digital signatures verified
15:43:13:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:43:13:WU01:FS01:0x22:Version 0.0.2
15:43:38:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
15:43:38:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:45:41:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
15:47:43:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
15:49:46:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
15:51:47:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
15:53:49:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
15:55:58:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
15:58:01:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
16:00:04:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
16:02:07:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
16:04:10:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
16:06:20:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
16:08:25:WU01:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
16:10:28:WU01:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
16:12:30:WU01:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
16:14:33:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
16:16:49:WU01:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
16:18:58:WU01:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
16:21:08:WU01:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
16:23:17:WU01:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
16:25:26:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
16:27:42:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
16:29:50:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
16:31:59:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
16:34:07:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
16:36:15:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
16:38:30:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
16:40:38:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
16:42:46:WU01:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
16:44:54:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
16:47:00:WU01:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
16:49:12:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
16:51:16:WU01:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
16:53:21:WU01:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
16:55:25:WU01:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
16:57:30:WU01:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
16:59:41:WU01:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
17:01:46:WU01:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
17:03:51:WU01:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
17:05:55:WU01:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
17:08:00:WU01:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
17:10:16:WU01:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
17:12:25:WU01:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
17:14:33:WU01:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
17:16:40:WU01:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
17:18:49:WU01:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
17:21:08:WU01:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
17:23:17:WU01:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
17:25:28:WU01:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
17:27:38:WU01:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
17:29:43:WU01:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
17:31:57:WU01:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
17:34:01:WU01:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
17:36:06:WU01:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
17:38:12:WU01:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
17:40:17:WU01:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
17:42:31:WU01:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
17:44:37:WU01:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
17:46:43:WU01:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
17:48:55:WU01:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
17:51:05:WU01:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
17:53:20:WU01:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
17:55:29:WU01:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
17:57:37:WU01:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
17:59:46:WU01:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
18:01:54:WU01:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
18:04:09:WU01:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
18:06:19:WU01:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
18:08:28:WU01:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
18:10:35:WU01:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
18:12:38:WU01:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
18:14:49:WU01:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
18:16:53:WU01:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
18:18:55:WU01:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
18:20:58:WU01:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
18:23:03:WU01:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
18:25:18:WU01:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
18:27:20:WU01:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
18:29:24:WU01:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
18:31:26:WU01:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
18:33:28:WU01:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
18:35:40:WU01:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
18:37:43:WU01:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
18:39:44:WU01:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
18:41:46:WU01:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
18:43:48:WU01:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
18:45:59:WU01:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
18:48:01:WU01:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
18:50:03:WU01:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
18:52:07:WU01:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
18:54:12:WU01:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
18:56:22:WU01:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
18:58:24:WU01:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
19:00:28:WU01:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
19:02:27:WU01:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
19:04:27:WU01:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
19:06:31:WU01:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
19:08:31:WU01:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
19:10:31:WU01:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
19:12:31:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
19:12:31:WU02:FS01:Connecting to 65.254.110.245:8080
19:12:31:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:12:31:WU02:FS01:Connecting to 18.218.241.186:80
19:12:31:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:12:31:ERROR:WU02:FS01:Exception: Could not get an assignment
19:12:32:WU02:FS01:Connecting to 65.254.110.245:8080
19:12:32:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:12:32:WU02:FS01:Connecting to 18.218.241.186:80
19:12:32:WU02:FS01:Assigned to work server 13.82.98.119
19:12:32:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 13.82.98.119
19:12:32:WU02:FS01:Connecting to 13.82.98.119:8080
19:12:32:ERROR:WU02:FS01:Exception: Server did not assign work unit
19:13:32:WU02:FS01:Connecting to 65.254.110.245:8080
19:13:32:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:13:32:WU02:FS01:Connecting to 18.218.241.186:80
19:13:32:WU02:FS01:Assigned to work server 140.163.4.231
19:13:32:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 140.163.4.231
19:13:32:WU02:FS01:Connecting to 140.163.4.231:8080
19:14:00:WU02:FS01:Downloading 11.98MiB
19:14:03:WU02:FS01:Download complete
19:14:04:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
19:14:31:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
19:14:35:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
19:14:35:WU01:FS01:0x22:Saving result file checkpointState.xml
19:14:36:WU01:FS01:0x22:Saving result file checkpt.crc
19:14:36:WU01:FS01:0x22:Saving result file positions.xtc
19:14:36:WU01:FS01:0x22:Saving result file science.log
19:14:36:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
19:14:36:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:14:36:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11781 run:0 clone:1186 gen:48 core:0x22 unit:0x000000480d5a98395e73c52c9638f680
19:14:36:WU01:FS01:Uploading 55.24MiB to 13.90.152.57
19:14:36:WU01:FS01:Connecting to 13.90.152.57:8080
19:14:36:WU02:FS01:Starting
19:14:36:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Darth\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 10824 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:14:36:WU02:FS01:Started FahCore on PID 10284
19:14:36:WU02:FS01:Core PID:7244
19:14:36:WU02:FS01:FahCore 0x22 started
19:14:37:WU02:FS01:0x22:*********************** Log Started 2020-04-09T19:14:36Z ***********************
19:14:37:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:14:37:WU02:FS01:0x22:       Type: 0x22
19:14:37:WU02:FS01:0x22:       Core: Core22
19:14:37:WU02:FS01:0x22:    Website: https://foldingathome.org/
19:14:37:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
19:14:37:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:14:37:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
19:14:37:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 10284 -checkpoint 15
19:14:37:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
19:14:37:WU02:FS01:0x22:             0 -gpu 0
19:14:37:WU02:FS01:0x22:     Config: <none>
19:14:37:WU02:FS01:0x22:************************************ Build *************************************
19:14:37:WU02:FS01:0x22:    Version: 0.0.2
19:14:37:WU02:FS01:0x22:       Date: Dec 6 2019
19:14:37:WU02:FS01:0x22:       Time: 21:30:31
19:14:37:WU02:FS01:0x22: Repository: Git
19:14:37:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
19:14:37:WU02:FS01:0x22:     Branch: HEAD
19:14:37:WU02:FS01:0x22:   Compiler: Visual C++ 2008
19:14:37:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:14:37:WU02:FS01:0x22:   Platform: win32 10
19:14:37:WU02:FS01:0x22:       Bits: 64
19:14:37:WU02:FS01:0x22:       Mode: Release
19:14:37:WU02:FS01:0x22:************************************ System ************************************
19:14:37:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
19:14:37:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
19:14:37:WU02:FS01:0x22:       CPUs: 8
19:14:37:WU02:FS01:0x22:     Memory: 31.93GiB
19:14:37:WU02:FS01:0x22:Free Memory: 26.87GiB
19:14:37:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
19:14:37:WU02:FS01:0x22: OS Version: 6.2
19:14:37:WU02:FS01:0x22:Has Battery: false
19:14:37:WU02:FS01:0x22: On Battery: false
19:14:37:WU02:FS01:0x22: UTC Offset: -4
19:14:37:WU02:FS01:0x22:        PID: 7244
19:14:37:WU02:FS01:0x22:        CWD: C:\Users\Darth\AppData\Roaming\FAHClient\work
19:14:37:WU02:FS01:0x22:         OS: Windows 10 Home
19:14:37:WU02:FS01:0x22:    OS Arch: AMD64
19:14:37:WU02:FS01:0x22:********************************************************************************
19:14:37:WU02:FS01:0x22:Project: 11747 (Run 0, Clone 4554, Gen 17)
19:14:37:WU02:FS01:0x22:Unit: 0x000000238ca304e75e6a7fdcd6413d18
19:14:37:WU02:FS01:0x22:Reading tar file core.xml
19:14:37:WU02:FS01:0x22:Reading tar file integrator.xml
19:14:37:WU02:FS01:0x22:Reading tar file state.xml
19:14:38:WU02:FS01:0x22:Reading tar file system.xml
19:14:39:WU02:FS01:0x22:Digital signatures verified
19:14:39:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:14:39:WU02:FS01:0x22:Version 0.0.2
19:14:51:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
19:14:51:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:14:57:WU01:FS01:Upload 0.34%
19:15:03:WU01:FS01:Upload 2.15%
19:15:09:WU01:FS01:Upload 4.07%
19:15:15:WU01:FS01:Upload 5.54%
19:15:21:WU01:FS01:Upload 7.47%
19:15:27:WU01:FS01:Upload 9.50%
19:15:33:WU01:FS01:Upload 11.32%
19:15:39:WU01:FS01:Upload 13.13%
19:15:45:WU01:FS01:Upload 14.94%
19:15:51:WU01:FS01:Upload 17.09%
19:15:57:WU01:FS01:Upload 18.67%
19:16:03:WU01:FS01:Upload 20.37%
19:16:09:WU01:FS01:Upload 22.06%
19:16:15:WU01:FS01:Upload 23.76%
19:16:21:WU01:FS01:Upload 25.57%
19:16:27:WU01:FS01:Upload 27.04%
19:16:33:WU01:FS01:Upload 28.29%
19:16:37:WU02:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
19:16:39:WU01:FS01:Upload 29.87%
19:16:45:WU01:FS01:Upload 31.57%
19:16:51:WU01:FS01:Upload 33.04%
19:16:57:WU01:FS01:Upload 34.74%
19:17:03:WU01:FS01:Upload 36.55%
19:17:09:WU01:FS01:Upload 38.02%
19:17:15:WU01:FS01:Upload 39.94%
19:17:21:WU01:FS01:Upload 41.53%
19:17:27:WU01:FS01:Upload 43.11%
19:17:33:WU01:FS01:Upload 44.92%
19:17:39:WU01:FS01:Upload 46.73%
19:17:45:WU01:FS01:Upload 48.09%
19:17:51:WU01:FS01:Upload 49.67%
19:17:57:WU01:FS01:Upload 50.69%
19:18:03:WU01:FS01:Upload 51.82%
19:18:09:WU01:FS01:Upload 52.95%
19:18:15:WU01:FS01:Upload 54.09%
19:18:21:WU01:FS01:Upload 55.44%
19:18:23:WU02:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
19:18:27:WU01:FS01:Upload 57.03%
19:18:33:WU01:FS01:Upload 58.27%
19:18:39:WU01:FS01:Upload 59.86%
19:18:45:WU01:FS01:Upload 60.65%
19:18:51:WU01:FS01:Upload 62.23%
19:18:57:WU01:FS01:Upload 63.93%
19:19:03:WU01:FS01:Upload 65.40%
19:19:09:WU01:FS01:Upload 67.10%
19:19:15:WU01:FS01:Upload 68.57%
19:19:21:WU01:FS01:Upload 70.49%
19:19:27:WU01:FS01:Upload 72.19%
19:19:33:WU01:FS01:Upload 73.21%
19:19:39:WU01:FS01:Upload 74.34%
19:19:45:WU01:FS01:Upload 76.04%
19:19:51:WU01:FS01:Upload 77.73%
19:19:57:WU01:FS01:Upload 79.32%
19:20:03:WU01:FS01:Upload 81.02%
19:20:09:WU01:FS01:Upload 82.94%
19:20:09:WU02:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
19:20:15:WU01:FS01:Upload 84.18%
19:20:21:WU01:FS01:Upload 85.77%
19:20:27:WU01:FS01:Upload 87.69%
19:20:33:WU01:FS01:Upload 89.39%
19:20:39:WU01:FS01:Upload 90.86%
19:20:45:WU01:FS01:Upload 92.22%
19:20:51:WU01:FS01:Upload 93.80%
19:20:57:WU01:FS01:Upload 95.16%
19:21:03:WU01:FS01:Upload 96.97%
19:21:09:WU01:FS01:Upload 98.33%
19:21:15:WU01:FS01:Upload 99.91%
19:21:17:WU01:FS01:Upload complete
19:21:17:WU01:FS01:Server responded WORK_ACK (400)
19:21:17:WU01:FS01:Final credit estimate, 105480.00 points
19:21:17:WU01:FS01:Cleaning up
19:21:55:WU02:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
19:23:41:WU02:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
19:25:31:WU02:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
19:27:18:WU02:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
19:29:05:WU02:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
19:30:53:WU02:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
19:32:40:WU02:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
19:34:31:WU02:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
19:36:19:WU02:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
19:38:07:WU02:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
19:39:55:WU02:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
19:41:43:WU02:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
19:43:34:WU02:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
19:45:23:WU02:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
19:47:12:WU02:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
19:49:02:WU02:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
19:50:52:WU02:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
19:52:48:WU02:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
19:54:38:WU02:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
19:56:27:WU02:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
19:58:16:WU02:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
20:00:06:WU02:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
20:02:01:WU02:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
20:03:49:WU02:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
20:05:38:WU02:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
20:07:27:WU02:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
20:09:15:WU02:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
20:11:09:WU02:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
20:12:58:WU02:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
20:14:47:WU02:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
20:16:38:WU02:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
20:18:25:WU02:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
20:20:20:WU02:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
20:22:08:WU02:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
20:23:56:WU02:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
20:25:46:WU02:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
20:27:36:WU02:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
20:29:32:WU02:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
20:31:22:WU02:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
20:33:11:WU02:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
20:34:59:WU02:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
20:36:46:WU02:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
20:38:41:WU02:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
20:40:29:WU02:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
20:42:17:WU02:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
20:44:05:WU02:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
20:45:54:WU02:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
20:47:48:WU02:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
20:49:37:WU02:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
20:51:27:WU02:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
20:53:17:WU02:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
20:55:05:WU02:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
20:56:59:WU02:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
20:58:46:WU02:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
21:00:35:WU02:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
21:02:24:WU02:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
21:04:12:WU02:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
21:06:09:WU02:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
21:07:57:WU02:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
21:09:45:WU02:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
21:11:34:WU02:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
21:13:24:WU02:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
21:15:20:WU02:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
21:17:10:WU02:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
21:18:58:WU02:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
21:20:47:WU02:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
21:22:36:WU02:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
21:24:32:WU02:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
21:26:21:WU02:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
21:28:09:WU02:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
21:30:00:WU02:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
21:31:51:WU02:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
21:33:45:WU02:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
21:35:32:WU02:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
21:37:19:WU02:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
21:39:07:WU02:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
21:40:54:WU02:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
******************************* Date: 2020-04-09 *******************************
21:42:48:WU02:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
21:44:35:WU02:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
21:46:23:WU02:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
21:48:10:WU02:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
21:49:57:WU02:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
21:51:52:WU02:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
21:53:40:WU02:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
21:55:28:WU02:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
21:57:15:WU02:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
21:59:02:WU02:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
22:00:56:WU02:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
22:02:43:WU02:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
22:04:30:WU02:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
22:06:15:WU02:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
22:08:02:WU02:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
22:09:56:WU02:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
22:11:43:WU02:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
22:13:30:WU02:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
22:15:17:WU02:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
22:15:18:WU01:FS01:Connecting to 65.254.110.245:8080
22:15:18:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:15:18:WU01:FS01:Connecting to 18.218.241.186:80
22:15:18:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:15:18:ERROR:WU01:FS01:Exception: Could not get an assignment
22:15:19:WU01:FS01:Connecting to 65.254.110.245:8080
22:15:19:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:15:19:WU01:FS01:Connecting to 18.218.241.186:80
22:15:19:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:15:19:ERROR:WU01:FS01:Exception: Could not get an assignment
22:16:19:WU01:FS01:Connecting to 65.254.110.245:8080
22:16:19:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:16:19:WU01:FS01:Connecting to 18.218.241.186:80
22:16:19:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:16:19:ERROR:WU01:FS01:Exception: Could not get an assignment
22:17:04:WU02:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
22:17:11:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
22:17:11:WU02:FS01:0x22:Saving result file checkpointState.xml
22:17:15:WU02:FS01:0x22:Saving result file checkpt.crc
22:17:15:WU02:FS01:0x22:Saving result file positions.xtc
22:17:17:WU02:FS01:0x22:Saving result file science.log
22:17:17:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
22:17:18:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:17:18:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
22:17:18:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
22:17:18:WU02:FS01:Connecting to 140.163.4.231:8080
22:17:39:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
22:17:39:WU02:FS01:Connecting to 140.163.4.231:80
22:17:56:WU01:FS01:Connecting to 65.254.110.245:8080
22:17:56:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:17:56:WU01:FS01:Connecting to 18.218.241.186:80
22:17:56:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:17:56:ERROR:WU01:FS01:Exception: Could not get an assignment
22:18:00:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:18:00:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
22:18:00:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
22:18:00:WU02:FS01:Connecting to 140.163.4.231:8080
22:18:22:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
22:18:22:WU02:FS01:Connecting to 140.163.4.231:80
22:18:43:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:19:01:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
22:19:01:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
22:19:01:WU02:FS01:Connecting to 140.163.4.231:8080
22:19:22:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
22:19:22:WU02:FS01:Connecting to 140.163.4.231:80
22:19:43:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:20:33:WU01:FS01:Connecting to 65.254.110.245:8080
22:20:34:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:20:34:WU01:FS01:Connecting to 18.218.241.186:80
22:20:34:WU01:FS01:Assigned to work server 128.252.203.10
22:20:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 128.252.203.10
22:20:34:WU01:FS01:Connecting to 128.252.203.10:8080
22:20:38:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
22:20:38:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
22:20:38:WU02:FS01:Connecting to 140.163.4.231:8080
22:20:55:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
22:20:55:WU01:FS01:Connecting to 128.252.203.10:80
22:20:59:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
22:20:59:WU02:FS01:Connecting to 140.163.4.231:80
22:21:20:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:21:52:WU01:FS01:Downloading 29.59MiB
22:21:58:WU01:FS01:Download 56.18%
22:22:00:WU01:FS01:Download complete
22:22:00:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11761 run:0 clone:11082 gen:2 core:0x22 unit:0x0000000980fccb0a5e70f05c76720941
22:22:00:WU01:FS01:Starting
22:22:00:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Darth\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 10824 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
22:22:00:WU01:FS01:Started FahCore on PID 11768
22:22:00:WU01:FS01:Core PID:5656
22:22:00:WU01:FS01:FahCore 0x22 started
22:22:01:WU01:FS01:0x22:*********************** Log Started 2020-04-09T22:22:00Z ***********************
22:22:01:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:22:01:WU01:FS01:0x22:       Type: 0x22
22:22:01:WU01:FS01:0x22:       Core: Core22
22:22:01:WU01:FS01:0x22:    Website: https://foldingathome.org/
22:22:01:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
22:22:01:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
22:22:01:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
22:22:01:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 11768 -checkpoint 15
22:22:01:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
22:22:01:WU01:FS01:0x22:             0 -gpu 0
22:22:01:WU01:FS01:0x22:     Config: <none>
22:22:01:WU01:FS01:0x22:************************************ Build *************************************
22:22:01:WU01:FS01:0x22:    Version: 0.0.2
22:22:01:WU01:FS01:0x22:       Date: Dec 6 2019
22:22:01:WU01:FS01:0x22:       Time: 21:30:31
22:22:01:WU01:FS01:0x22: Repository: Git
22:22:01:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
22:22:01:WU01:FS01:0x22:     Branch: HEAD
22:22:01:WU01:FS01:0x22:   Compiler: Visual C++ 2008
22:22:01:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:22:01:WU01:FS01:0x22:   Platform: win32 10
22:22:01:WU01:FS01:0x22:       Bits: 64
22:22:01:WU01:FS01:0x22:       Mode: Release
22:22:01:WU01:FS01:0x22:************************************ System ************************************
22:22:01:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
22:22:01:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
22:22:01:WU01:FS01:0x22:       CPUs: 8
22:22:01:WU01:FS01:0x22:     Memory: 31.93GiB
22:22:01:WU01:FS01:0x22:Free Memory: 26.24GiB
22:22:01:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
22:22:01:WU01:FS01:0x22: OS Version: 6.2
22:22:01:WU01:FS01:0x22:Has Battery: false
22:22:01:WU01:FS01:0x22: On Battery: false
22:22:01:WU01:FS01:0x22: UTC Offset: -4
22:22:01:WU01:FS01:0x22:        PID: 5656
22:22:01:WU01:FS01:0x22:        CWD: C:\Users\Darth\AppData\Roaming\FAHClient\work
22:22:01:WU01:FS01:0x22:         OS: Windows 10 Home
22:22:01:WU01:FS01:0x22:    OS Arch: AMD64
22:22:01:WU01:FS01:0x22:********************************************************************************
22:22:01:WU01:FS01:0x22:Project: 11761 (Run 0, Clone 11082, Gen 2)
22:22:01:WU01:FS01:0x22:Unit: 0x0000000980fccb0a5e70f05c76720941
22:22:01:WU01:FS01:0x22:Reading tar file core.xml
22:22:01:WU01:FS01:0x22:Reading tar file integrator.xml
22:22:01:WU01:FS01:0x22:Reading tar file state.xml
22:22:01:WU01:FS01:0x22:Reading tar file system.xml
22:22:01:WU01:FS01:0x22:Digital signatures verified
22:22:01:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:22:01:WU01:FS01:0x22:Version 0.0.2
22:22:08:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
22:22:08:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:23:15:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
22:23:15:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
22:23:15:WU02:FS01:Connecting to 140.163.4.231:8080
22:23:21:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
22:23:36:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
22:23:36:WU02:FS01:Connecting to 140.163.4.231:80
22:23:57:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:24:37:WU01:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
22:25:55:WU01:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
22:27:10:WU01:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
22:27:29:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
22:27:29:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
22:27:29:WU02:FS01:Connecting to 140.163.4.231:8080
22:27:51:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
22:27:51:WU02:FS01:Connecting to 140.163.4.231:80
22:28:12:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:28:25:WU01:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
22:29:41:WU01:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
22:30:55:WU01:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
22:32:12:WU01:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
22:33:27:WU01:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
22:34:21:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
22:34:21:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
22:34:21:WU02:FS01:Connecting to 140.163.4.231:8080
22:34:42:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
22:34:42:WU02:FS01:Connecting to 140.163.4.231:80
22:34:42:WU01:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
22:35:03:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
22:35:59:WU01:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
22:37:14:WU01:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
22:38:32:WU01:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
22:39:47:WU01:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
22:41:02:WU01:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
22:42:19:WU01:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
22:43:34:WU01:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
22:44:50:WU01:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
22:45:26:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
22:45:26:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
22:45:26:WU02:FS01:Connecting to 140.163.4.231:8080
22:45:47:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
22:45:47:WU02:FS01:Connecting to 140.163.4.231:80
22:45:50:WU02:FS01:Upload 0.29%
22:46:04:WU01:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
22:46:58:WU02:FS01:Upload 0.57%
22:46:58:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
22:47:18:WU01:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
22:48:35:WU01:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
22:49:49:WU01:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
22:51:05:WU01:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
22:52:19:WU01:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
22:53:33:WU01:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
22:54:52:WU01:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
22:56:07:WU01:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
22:57:24:WU01:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
22:58:39:WU01:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
22:59:55:WU01:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
23:01:12:WU01:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
23:02:28:WU01:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
23:03:23:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
23:03:23:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
23:03:23:WU02:FS01:Connecting to 140.163.4.231:8080
23:03:44:WU01:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
23:03:44:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
23:03:44:WU02:FS01:Connecting to 140.163.4.231:80
23:04:06:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:05:00:WU01:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
23:06:15:WU01:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
23:07:31:WU01:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
23:08:46:WU01:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
23:10:03:WU01:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
23:11:18:WU01:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
23:12:32:WU01:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
23:13:49:WU01:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
23:15:04:WU01:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
23:16:21:WU01:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
23:17:35:WU01:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
23:18:50:WU01:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
23:20:06:WU01:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
23:21:21:WU01:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
23:22:39:WU01:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
23:23:54:WU01:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
23:25:09:WU01:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
23:26:27:WU01:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
23:27:43:WU01:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
23:29:02:WU01:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
23:30:17:WU01:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
23:31:34:WU01:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
23:32:25:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
23:32:25:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
23:32:25:WU02:FS01:Connecting to 140.163.4.231:8080
23:32:46:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
23:32:46:WU02:FS01:Connecting to 140.163.4.231:80
23:32:54:WU01:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
23:33:07:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:34:12:WU01:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
23:35:29:WU01:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
23:36:44:WU01:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
23:37:59:WU01:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
23:39:16:WU01:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
23:40:32:WU01:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
23:41:49:WU01:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
23:43:04:WU01:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
23:44:19:WU01:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
23:45:36:WU01:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
23:46:53:WU01:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
23:48:11:WU01:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
23:49:26:WU01:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
23:50:41:WU01:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
23:51:58:WU01:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
23:53:13:WU01:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
23:54:30:WU01:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
23:55:45:WU01:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
23:57:01:WU01:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
23:58:17:WU01:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
23:59:33:WU01:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
00:00:50:WU01:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
00:02:06:WU01:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
00:03:23:WU01:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
00:04:41:WU01:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
00:05:59:WU01:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
00:06:43:FS01:Finishing
00:07:16:WU01:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
00:07:48:FS01:Paused
00:07:48:FS01:Shutting core down
00:07:48:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 5656
00:07:48:WU01:FS01:0x22:Exiting, please wait. . .
00:07:48:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
00:07:48:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:07:57:FS01:Unpaused
00:07:57:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
00:07:57:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
00:07:57:WU02:FS01:Connecting to 140.163.4.231:8080
00:07:58:WU01:FS01:Starting
00:07:58:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Darth\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 10824 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
00:07:58:WU01:FS01:Started FahCore on PID 2652
00:07:58:WU01:FS01:Core PID:13044
00:07:58:WU01:FS01:FahCore 0x22 started
00:07:58:WU01:FS01:0x22:*********************** Log Started 2020-04-10T00:07:58Z ***********************
00:07:58:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:07:58:WU01:FS01:0x22:       Type: 0x22
00:07:58:WU01:FS01:0x22:       Core: Core22
00:07:58:WU01:FS01:0x22:    Website: https://foldingathome.org/
00:07:58:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
00:07:58:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
00:07:58:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
00:07:58:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 2652 -checkpoint 15
00:07:58:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
00:07:58:WU01:FS01:0x22:             0 -gpu 0
00:07:58:WU01:FS01:0x22:     Config: <none>
00:07:58:WU01:FS01:0x22:************************************ Build *************************************
00:07:58:WU01:FS01:0x22:    Version: 0.0.2
00:07:58:WU01:FS01:0x22:       Date: Dec 6 2019
00:07:58:WU01:FS01:0x22:       Time: 21:30:31
00:07:58:WU01:FS01:0x22: Repository: Git
00:07:58:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
00:07:58:WU01:FS01:0x22:     Branch: HEAD
00:07:58:WU01:FS01:0x22:   Compiler: Visual C++ 2008
00:07:58:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:07:58:WU01:FS01:0x22:   Platform: win32 10
00:07:58:WU01:FS01:0x22:       Bits: 64
00:07:58:WU01:FS01:0x22:       Mode: Release
00:07:58:WU01:FS01:0x22:************************************ System ************************************
00:07:58:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
00:07:58:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
00:07:58:WU01:FS01:0x22:       CPUs: 8
00:07:58:WU01:FS01:0x22:     Memory: 31.93GiB
00:07:58:WU01:FS01:0x22:Free Memory: 25.51GiB
00:07:58:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
00:07:58:WU01:FS01:0x22: OS Version: 6.2
00:07:58:WU01:FS01:0x22:Has Battery: false
00:07:58:WU01:FS01:0x22: On Battery: false
00:07:58:WU01:FS01:0x22: UTC Offset: -4
00:07:58:WU01:FS01:0x22:        PID: 13044
00:07:58:WU01:FS01:0x22:        CWD: C:\Users\Darth\AppData\Roaming\FAHClient\work
00:07:58:WU01:FS01:0x22:         OS: Windows 10 Home
00:07:58:WU01:FS01:0x22:    OS Arch: AMD64
00:07:58:WU01:FS01:0x22:********************************************************************************
00:07:58:WU01:FS01:0x22:Project: 11761 (Run 0, Clone 11082, Gen 2)
00:07:58:WU01:FS01:0x22:Unit: 0x0000000980fccb0a5e70f05c76720941
00:07:58:WU01:FS01:0x22:Digital signatures verified
00:07:58:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:07:58:WU01:FS01:0x22:Version 0.0.2
00:07:58:WU01:FS01:0x22:  Found a checkpoint file
00:08:04:WU01:FS01:0x22:Completed 1650000 out of 2000000 steps (82%)
00:08:04:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:08:42:WU01:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
00:09:11:WU02:FS01:Upload 0.57%
00:09:11:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
00:09:35:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
00:09:35:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
00:09:35:WU02:FS01:Connecting to 140.163.4.231:8080
00:09:42:FS01:Finishing
00:09:55:WU01:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
00:09:56:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
00:09:56:WU02:FS01:Connecting to 140.163.4.231:80
00:10:17:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:11:10:WU01:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
00:12:12:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
00:12:12:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
00:12:12:WU02:FS01:Connecting to 140.163.4.231:8080
00:12:28:WU01:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
00:12:33:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
00:12:33:WU02:FS01:Connecting to 140.163.4.231:80
00:12:55:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:13:43:WU01:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
00:15:00:WU01:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
00:16:15:WU01:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
00:16:26:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11747 run:0 clone:4554 gen:17 core:0x22 unit:0x000000238ca304e75e6a7fdcd6413d18
00:16:26:WU02:FS01:Uploading 21.92MiB to 140.163.4.231
00:16:26:WU02:FS01:Connecting to 140.163.4.231:8080
00:16:48:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
00:16:48:WU02:FS01:Connecting to 140.163.4.231:80
00:17:09:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:17:30:WU01:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
00:18:46:WU01:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
00:20:01:WU01:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
Re: failure to connect to the collection server
Welcome to the F@H Forum darth_grom,
Please note that the F@H Servers are under a massive load: viewtopic.php?f=24&t=33193
There's nothing that you can do for now as the client will automatically try to upload the completed WU.
