Fedora 27 GPU not found
goodyca
Post by goodyca »
I am running FAH version 7.4.4 on Fadora 27 with kernel 4.14.13-300.fc27.x86_64. I am running nvidia driver version 387.34-1.fc27.x86_64. I have install CUDA 9-1-9.1.85-1.x86_64. I have 1 GPU installed: GeForce GTX 1050 Ti. When I try to add a slot for the GPU, I get the following error:
"On client "local" 127.0.0.1:36330: No available GPUs"
FAH appears to be finding CUDA. Here is the start of the FAH log file:
*********************** Log Started 2018-01-22T18:30:40Z ***********************
18:30:40:************************* Folding@home Client *************************
18:30:40:    Website: http://folding.stanford.edu/
18:30:40:  Copyright: (c) 2009-2014 Stanford University
18:30:40:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:30:40:       Args: --child --lifeline 1360 /etc/fahclient/config.xml --run-as
18:30:40:             fahclient --pid-file=/var/run/fahclient.pid --daemon
18:30:40:     Config: /etc/fahclient/config.xml
18:30:40:******************************** Build ********************************
18:30:40:    Version: 7.4.4
18:30:40:       Date: Mar 4 2014
18:30:40:       Time: 12:01:17
18:30:40:    SVN Rev: 4130
18:30:40:     Branch: fah/trunk/client
18:30:40:   Compiler: GNU 4.1.2 20080704 (Red Hat 4.1.2-46)
18:30:40:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
18:30:40:             -fno-unsafe-math-optimizations -msse2
18:30:40:   Platform: linux2 2.6.18-164.11.1.el5
18:30:40:       Bits: 64
18:30:40:       Mode: Release
18:30:40:******************************* System ********************************
18:30:40:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
18:30:40:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:30:40:       CPUs: 12
18:30:40:     Memory: 7.73GiB
18:30:40:Free Memory: 7.14GiB
18:30:40:    Threads: POSIX_THREADS
18:30:40: OS Version: 4.14
18:30:40:Has Battery: false
18:30:40: On Battery: false
18:30:40: UTC Offset: -6
18:30:40:        PID: 1362
18:30:40:        CWD: /var/lib/fahclient
18:30:40:         OS: Linux 4.14.13-300.fc27.x86_64 x86_64
18:30:40:    OS Arch: AMD64
18:30:40:       GPUs: 0
18:30:40:       CUDA: 6.1
18:30:40:CUDA Driver: 9010
18:30:40:***********************************************************************
Re: Fedora 27 GPU not found
I am not an expert, but while we wait for one, here is a relevant link http://security-plus-data-science.blogs ... ra-27.html
SteveWillis
Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Post by SteveWillis »
Do you have the latest /var/lib/fahclient/GPUs.txt installed?
fah.stanford.edu/file-releases/public/GPUs.txt
goodyca
Post by goodyca »
SteveWillis wrote:Do you have the latest /var/lib/fahclient/GPUs.txt installed?
I didn't have a GPUs.txt file in the /var/lib/fahclient directory. I added the contents of the URL to the directory in a file named GPUs.txt. Restarting the FAHClient service allowed FAH to find the GPU and it is now folding.
Thank you for the assistance.
In most cases, it's not necessary to manually download GPUs.txt.
When FAHClient starts, it's supposed to download the file if needed. (Sometimes, though, FAHClient gets started before the internet connection is available and I can't get it yet.) Could that be what happened in your case?
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
My experience is that with Linux it is ALWAYS necessary to manually download GPUs.txt. At least for me, I've had to do it every time on my rigs.
It must depend on the distro of Linux you use and the steps you follow. I recently set up a Ubuntu 16.04 system and installed the folding client, it downloaded the GPUs.txt file just fine.
goodyca
Post by goodyca »
bruce wrote:In most cases, it's not necessary to manually download GPUs.txt.
I don't think so. The internet connection is available when the computer is started.
It's a race condition so it's hard to say if it's broken or not. It takes a short time for the internet connection to be started. The very first thing that FAHClient does is try to download GPUs.txt.
If you try to test it, be sure to FINISH the GPU WU first as it's likely to dump it. You can see the message only if you remove GPUs.txt, open a text window and then
"/etc/init.d/FAHClient start -v"
It's supposed to retry later, but not immediately.
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
I don't see that there is a problem. Once you download and install the file you are good to go until you upgrade to a GPU that isn't included in the file or have to reinstall the OS and the apps. Then download the newest one. At least that's my experience. Not worth wasting time on for me.
