Can't upload results to 155.247.166.220
Ken_g6
Post by Ken_g6 »
15:15:52:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: Connection timed out
Ow! I'm getting a headache centered around my Temple. :ewink:
goodyca
Re: Can't upload results to 155.247.166.220
Post by goodyca »
I'm also seeing the same error for the subject server.
JeansOn
Post by JeansOn »
Me too.
cann't upload ...
17:48:10:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14009 run:0 clone:209 gen:10 core:0xa4 unit:0x0000000c0002894c59e4d13ca4f92f03
17:48:10:WU00:FS00:Uploading 4.15MiB to 155.247.166.220
17:48:10:WU00:FS00:Connecting to 155.247.166.220:8080
17:48:12:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
17:48:12:WU00:FS00:Connecting to 155.247.166.220:80
17:48:31:WU01:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
17:48:33:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
AJMSmith
Post by AJMSmith »
I'm getting the same response on 2 machines ... the log for the server shows it accepting up to 2:00 am PST today and rejecting from 2:20 am so with the server being EST it's almost 2:00 pm there now.
parkut
Post by parkut »
Seeing the same here across multiple machines. Problem started around 9 hours ago
10:34:41:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: Connection timed out
10:36:49:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: Connection timed out
10:38:56:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: Connection timed out
19:25:44:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: Connection timed out
19:27:27:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: Connection timed out
19:30:13:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: Connection timed out
The log you posted shows the client tried both ports 8080 and 80 but it does not mention attempts for a Collection Server. Is anybody seeing success or failures on a CS?
The log shows only one project: p14009. Presumably there are others.
goodyca
Post by goodyca »
The collection server is shown as 0.0.0.0
That's what I was looking for. Is it just p14009 that has a CS of 0.0.0.0?
I can get that fixed but I'd like to get it solved for any project on 155.247.166.220.
Unfortunately the fix will only apply to future assignments, but i think it's safe to say that someday *.220 will have a similar problem again.
parkut
Post by parkut »
At least one system just uploaded a WU
19:35:36:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13786 run:4 clone:50 gen:39 core:0xa4 unit:0x000000270002894c59d67ecc6575e5c2
19:35:36:WU01:FS00:Uploading 4.62MiB to 155.247.166.220
19:35:36:WU01:FS00:Connecting to 155.247.166.220:8080
19:35:43:WU01:FS00:Upload 12.19%
19:35:51:WU01:FS00:Upload 18.96%
19:36:05:WU01:FS00:Upload 32.50%
19:36:13:WU01:FS00:Upload 37.91%
19:36:26:WU01:FS00:Upload 47.39%
19:36:35:WU01:FS00:Upload 52.81%
19:36:45:WU01:FS00:Upload 58.22%
19:36:51:WU01:FS00:Upload 62.29%
19:36:58:WU01:FS00:Upload 67.70%
19:37:06:WU01:FS00:Upload 82.60%
19:37:34:WU01:FS00:Upload complete
19:37:34:WU01:FS00:Server responded WORK_ACK (400)
19:37:34:WU01:FS00:Final credit estimate, 6944.00 points
19:37:34:WU01:FS00:Cleaning up
JeansOn
Post by JeansOn »
results are uploaded.
Thx, Bruce
The CS is supposed to allow WUs to be uploaded when the primary WS is off-line. Somebody fixed the WS, but that doesn't take care of the CS=0.0.0.0 issue -- which will only be a problem the next time the WS goes down. We still need to fix the projects that don't have a CS.
parkut
Post by parkut »
all WU's have now been uploaded.
I have (4) machines showing CS = 0.0.0.0
p14018 - ETA 3 hrs, 30 min
p14018 - ETA 6 hrs, 15 min
p14006 - ETA 3 hrs, 40 min
p14019 - ETA 8 hrs, 0 min
ChristianVirtual
Post by ChristianVirtual »
I have one 14022 pending; retry in few hours ...
Last edited by ChristianVirtual on Thu Jan 18, 2018 9:03 pm, edited 1 time in total.
JeansOn
Post by JeansOn »
Bruce, I have searched in the whole log, but I didn't found anything like CS. I looked to an other log too.
If CS is so important, I can't believe that I couldn't find it in the log.
But I found "Collection Server" in the "status" tab of fah-Control.
If that's what you mean, I'll look at this point in future. ...
EDIT:
In this moment, NaCl doesn't take my upload too.
Spidermaster
Post by Spidermaster »
12:53:57:WU00:FS00:0xa4:Completed 2450000 out of 2500000 steps  (98%)
13:01:33:WU00:FS00:0xa4:Completed 2475000 out of 2500000 steps  (99%)
13:01:33:WU01:FS00:Connecting to 171.67.108.45:8080
13:01:33:WU01:FS00:Assigned to work server 171.67.108.158
13:01:33:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 171.67.108.158
13:01:33:WU01:FS00:Connecting to 171.67.108.158:8080
13:01:36:WU01:FS00:Downloading 807.21KiB
13:01:38:WU01:FS00:Download complete
13:01:38:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9038 run:416 clone:1 gen:677 core:0xa4 unit:0x000002f5ab436c9e569829b5ab280fba
13:09:12:WU00:FS00:0xa4:Completed 2500000 out of 2500000 steps  (100%)
13:09:12:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
13:09:22:WU00:FS00:0xa4:
13:09:22:WU00:FS00:0xa4:Finished Work Unit:
13:09:22:WU00:FS00:0xa4:- Reading up to 4508208 from "00/wudata_01.trr": Read 4508208
13:09:22:WU00:FS00:0xa4:trr file hash check passed.
13:09:22:WU00:FS00:0xa4:- Reading up to 501964 from "00/wudata_01.xtc": Read 501964
13:09:22:WU00:FS00:0xa4:xtc file hash check passed.
13:09:22:WU00:FS00:0xa4:edr file hash check passed.
13:09:22:WU00:FS00:0xa4:logfile size: 55666
13:09:22:WU00:FS00:0xa4:Leaving Run
13:09:24:WU00:FS00:0xa4:- Writing 5102906 bytes of core data to disk...
13:09:24:WU00:FS00:0xa4:Done: 5102394 -> 4405155 (compressed to 86.3 percent)
13:09:24:WU00:FS00:0xa4:  ... Done.
13:09:25:WU00:FS00:0xa4:- Shutting down core
13:09:25:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
13:09:26:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:09:26:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14005 run:0 clone:553 gen:0 core:0xa4 unit:0x000000000002894c59e4d000eccb4cb0
13:09:26:WU00:FS00:Uploading 4.20MiB to 155.247.166.220
13:09:26:WU00:FS00:Connecting to 155.247.166.220:8080
13:09:26:WU01:FS00:Starting
13:09:26:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Kenneth/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 7224 -checkpoint 15 -np 4
13:09:26:WU01:FS00:Started FahCore on PID 6312
13:09:26:WU01:FS00:Core PID:4792
13:09:26:WU01:FS00:FahCore 0xa4 started
13:09:27:WU01:FS00:0xa4:
13:09:27:WU01:FS00:0xa4:*------------------------------*
13:09:27:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
13:09:27:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
13:09:27:WU01:FS00:0xa4:Preparing to commence simulation
13:09:27:WU01:FS00:0xa4:- Looking at optimizations...
13:09:27:WU01:FS00:0xa4:- Created dyn
13:09:27:WU01:FS00:0xa4:- Files status OK
13:09:27:WU01:FS00:0xa4:- Expanded 826075 -> 1402860 (decompressed 169.8 percent)
13:09:27:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826075 data_size=1402860, decompressed_data_size=1402860 diff=0
13:09:27:WU01:FS00:0xa4:- Digital signature verified
13:09:27:WU01:FS00:0xa4:Project: 9038 (Run 416, Clone 1, Gen 677)
13:09:27:WU01:FS00:0xa4:Assembly optimizations on if available.
13:09:27:WU01:FS00:0xa4:Entering M.D.
13:09:30:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
13:09:30:WU00:FS00:Connecting to 155.247.166.220:80
13:09:32:WU01:FS00:0xa4:Mapping NT from 4 to 4
13:09:33:WU01:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
13:09:51:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:09:51:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14005 run:0 clone:553 gen:0 core:0xa4 unit:0x000000000002894c59e4d000eccb4cb0
13:09:51:WU00:FS00:Uploading 4.20MiB to 155.247.166.220
13:09:51:WU00:FS00:Connecting to 155.247.166.220:8080
13:09:55:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
13:09:55:WU00:FS00:Connecting to 155.247.166.220:80
13:10:16:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:10:51:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14005 run:0 clone:553 gen:0 core:0xa4 unit:0x000000000002894c59e4d000eccb4cb0
13:10:51:WU00:FS00:Uploading 4.20MiB to 155.247.166.220
13:10:51:WU00:FS00:Connecting to 155.247.166.220:8080
13:10:55:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
13:10:55:WU00:FS00:Connecting to 155.247.166.220:80
13:11:16:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:11:19:WU01:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
13:12:29:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14005 run:0 clone:553 gen:0 core:0xa4 unit:0x000000000002894c59e4d000eccb4cb0
13:12:29:WU00:FS00:Uploading 4.20MiB to 155.247.166.220
13:12:29:WU00:FS00:Connecting to 155.247.166.220:8080
13:12:32:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
13:12:32:WU00:FS00:Connecting to 155.247.166.220:80
13:12:53:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:12:57:WU01:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
13:14:35:WU01:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
13:15:06:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14005 run:0 clone:553 gen:0 core:0xa4 unit:0x000000000002894c59e4d000eccb4cb0
13:15:06:WU00:FS00:Uploading 4.20MiB to 155.247.166.220
13:15:06:WU00:FS00:Connecting to 155.247.166.220:8080
13:15:09:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
13:15:09:WU00:FS00:Connecting to 155.247.166.220:80
13:15:31:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:16:12:WU01:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
13:17:49:WU01:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
13:19:20:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14005 run:0 clone:553 gen:0 core:0xa4 unit:0x000000000002894c59e4d000eccb4cb0
13:19:20:WU00:FS00:Uploading 4.20MiB to 155.247.166.220
13:19:20:WU00:FS00:Connecting to 155.247.166.220:8080
13:19:24:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
13:19:24:WU00:FS00:Connecting to 155.247.166.220:80
13:19:26:WU01:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
13:19:45:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.220:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
13:21:02:WU01:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
13:22:39:WU01:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
13:24:16:WU01:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
13:25:53:WU01:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
Mod edit: added Code tags to log listing
