WU's showing completed but not showing up in account.
Locked
MrScott
Post by MrScott »
Jan 13, 2018 was the last update to my account. I have not idea how to check for system issues as all appears to be running just fine. THe system runs 24/7 and the LOG ERROR WARNING Filter shows 2 warnings on the 14th and 4 today the 15th on January 2018.
I've also had to reinstall F@H 4 times since starting. If I have to shut the system down for some reason F@H will not connect. THe web app also is not working. I get a constant jumping or cycling as it trys to connect so, I don't bother with it any longer. I love volunteering my 56 THread Dual Xeon with GTX980 GPU to your cause, but I hate to think your not receiving the WU that are processes just fine.
Please help. I will gladly send you any system info you may require to troubleshoot my issues.
Below is an example of what the log reads so, what's the what? I have 600GB of Disk space available and a 250MG per Sec HS Internet connection.
18:35:42:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
18:35:42:WU00:FS00:0xa7:Saving result file frame42.trr
18:35:42:WU00:FS00:0xa7:Saving result file md.log
18:35:42:WU00:FS00:0xa7:Saving result file science.log
18:35:42:WU00:FS00:0xa7:Saving result file traj_comp.xtc
18:35:43:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:35:43:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:35:43:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13745 run:148 clone:14 gen:42 core:0xa7 unit:0x0000002e0002894b59d57c0e7b2e7ded
18:35:43:WU00:FS00:Uploading 1.66MiB to 155.247.166.219
18:35:43:WU00:FS00:Connecting to 155.247.166.219:8080
18:35:45:WU00:FS00:Upload complete
18:35:45:WU00:FS00:Server responded WORK_ACK (400)
18:35:45:WU00:FS00:Final credit estimate, 2861.00 points
18:35:45:WU00:FS00:Cleaning up
******************************* Date: 2018-01-15 *******************************
Thanks,
Sea Isle Design Group, LLC
Team: 233751
Re: WU's showing completed but not showing up in account.
The stats server went down Saturday moning, and since it's a holiday weekend, it won'd be corrected until Tuesday.
You’ll still get your credits then.
Please see this topic for updates: viewtopic.php?f=18&t=29107
Locked
