I'm getting really low Points Per WU
kwerboom
Post by kwerboom »
Hi. I didn't know where to post this problem I'm having, but this is a stats issue with a GPU based core so I'm assuming this is the right place. Yesterday, before I went to bed I waited for a WU to finish. Its final credit estimate was listed as the following:
11:03:03:WU01:FS01:Final credit estimate, 23967.00 points
Yet when I went to check Extreme Overclocking after turning my computer on again, it showed the following got posted 3 hours later:
12.27, 9am | 7,850 | 3
I thought this was strange, so I waited for another WU to get finished. It showed the following estimated:
00:25:35:WU00:FS01:Final credit estimate, 24040.00 points
Again I checked Extreme Overclocking, it showed the following getting posted:
12.27, 9pm | 6,000 | 1
I thought maybe the I had entered the wrong Passkey, so I rechecked and retried the Passkey for the new profile name. The WU uploaded with the following estimated:
06:30:13:WU01:FS01:Final credit estimate, 22547.00 points
I rechecked Extreme Overclocking, it showed the following getting posted:
12.28, 3am | 5,900 | 1
I recently switched to Curecoin's team (224497). I had a little bit of a snafu setting up a merged folding profile initially using the profile name kwerboom_ALL_BB814ghPZ4spNv3DwfqdsQr8nEjCbQ1o5J before realizing that I had grabbed the wrong cryptocurrency address from the wrong place and switching to kwerboom_ALL_1L83cGY1wM9qfMsptnzqdCxmPty2VNTcym. I got a Passkey for the first one and then reapplied for a new Passkey for the second. I'm not sure if this problem I'm having is something caused on my end or if I just ran into a glitch in the system. I could use some help. Thank you.
kwerboom
Re: I'm getting really low Points Per WU
Post by kwerboom »
Yesterday's log file:
 *********************** Log Started 2017-12-26T21:37:14Z ***********************
21:37:14:************************* Folding@home Client *************************
21:37:14:        Website: http://folding.stanford.edu/
21:37:14:      Copyright: (c) 2009-2016 Stanford University
21:37:14:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:37:14:           Args:
21:37:14:         Config: C:\Users\Keith\AppData\Roaming\FAHClient\config.xml
21:37:14:******************************** Build ********************************
21:37:14:        Version: 7.4.16
21:37:14:           Date: Jan 6 2017
21:37:14:           Time: 00:25:14
21:37:14:     Repository: Git
21:37:14:       Revision: a9e9e27dc2ee6ff01398c439677bc27f6cb74032
21:37:14:         Branch: master
21:37:14:       Compiler: Visual C++ 2008
21:37:14:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox -arch:SSE /MT
21:37:14:       Platform: win32 10
21:37:14:           Bits: 32
21:37:14:           Mode: Release
21:37:14:******************************* System ********************************
21:37:14:            CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
21:37:14:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
21:37:14:           CPUs: 8
21:37:14:         Memory: 15.94GiB
21:37:14:    Free Memory: 12.50GiB
21:37:14:        Threads: WINDOWS_THREADS
21:37:14:     OS Version: 6.2
21:37:14:    Has Battery: false
21:37:14:     On Battery: false
21:37:14:     UTC Offset: -6
21:37:14:            PID: 15844
21:37:14:            CWD: C:\Users\Keith\AppData\Roaming\FAHClient
21:37:14:             OS: Windows 10 Pro
21:37:14:        OS Arch: AMD64
21:37:14:           GPUs: 1
21:37:14:          GPU 0: Bus:1 Slot:0 Func:0 ATI:5 Tahiti PRO [Radeon R9 280/HD
21:37:14:                 7900/8950]
21:37:14:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
21:37:14:                 specified module could not be found.
21:37:14:
21:37:14:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:0 Compute:1.2 Driver:2527.7
21:37:14:  Win32 Service: false
21:37:14:***********************************************************************
21:37:14:<config>
21:37:14:  <!-- Folding Core -->
21:37:14:  <checkpoint v='9'/>
21:37:14:  <core-priority v='low'/>
21:37:14:
21:37:14:  <!-- Network -->
21:37:14:  <proxy v=':8080'/>
21:37:14:
21:37:14:  <!-- Slot Control -->
21:37:14:  <pause-on-battery v='false'/>
21:37:14:
21:37:14:  <!-- User Information -->
21:37:14:  <passkey v='********************************'/>
21:37:14:  <team v='50959'/>
21:37:14:  <user v='kwerboom'/>
21:37:14:
21:37:14:  <!-- Folding Slots -->
21:37:14:  <slot id='1' type='GPU'/>
21:37:14:</config>
21:37:14:Trying to access database...
21:37:14:Successfully acquired database lock
21:37:14:Enabled folding slot 01: READY gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950]
21:37:14:WU00:FS01:Starting
21:37:14:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 15844 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
21:37:14:WU00:FS01:Started FahCore on PID 20100
21:37:14:WU00:FS01:Core PID:13872
21:37:14:WU00:FS01:FahCore 0x21 started
21:37:14:WU00:FS01:0x21:*********************** Log Started 2017-12-26T21:37:14Z ***********************
21:37:14:WU00:FS01:0x21:Project: 9414 (Run 2596, Clone 1, Gen 495)
21:37:14:WU00:FS01:0x21:Unit: 0x0000024aab436c9d585e06a468576f96
21:37:14:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
21:37:14:WU00:FS01:0x21:Machine: 1
21:37:14:WU00:FS01:0x21:Digital signatures verified
21:37:14:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
21:37:14:WU00:FS01:0x21:Version 0.0.18
21:37:14:WU00:FS01:0x21:  Found a checkpoint file
21:37:15:WARNING:FS01:Size of positions 392 does not match topology 389
21:37:17:WU00:FS01:0x21:Completed 2700000 out of 6250000 steps (43%)
21:37:17:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:39:55:WU00:FS01:0x21:Completed 2750000 out of 6250000 steps (44%)
21:40:01:WARNING:FS01:Size of positions 392 does not match topology 389
21:42:40:WARNING:FS01:Size of positions 392 does not match topology 389
21:43:15:WU00:FS01:0x21:Completed 2812500 out of 6250000 steps (45%)
21:45:19:WARNING:FS01:Size of positions 392 does not match topology 389
21:46:39:WU00:FS01:0x21:Completed 2875000 out of 6250000 steps (46%)
21:48:11:WARNING:FS01:Size of positions 392 does not match topology 389
21:50:07:WU00:FS01:0x21:Completed 2937500 out of 6250000 steps (47%)
21:50:52:WARNING:FS01:Size of positions 392 does not match topology 389
21:53:26:WU00:FS01:0x21:Completed 3000000 out of 6250000 steps (48%)
21:53:31:WARNING:FS01:Size of positions 392 does not match topology 389
21:56:10:WARNING:FS01:Size of positions 392 does not match topology 389
21:56:45:WU00:FS01:0x21:Completed 3062500 out of 6250000 steps (49%)
21:58:50:WARNING:FS01:Size of positions 392 does not match topology 389
22:00:04:WU00:FS01:0x21:Completed 3125000 out of 6250000 steps (50%)
22:01:29:WARNING:FS01:Size of positions 392 does not match topology 389
22:03:24:WU00:FS01:0x21:Completed 3187500 out of 6250000 steps (51%)
22:04:09:WARNING:FS01:Size of positions 392 does not match topology 389
22:06:42:WU00:FS01:0x21:Completed 3250000 out of 6250000 steps (52%)
22:06:48:WARNING:FS01:Size of positions 392 does not match topology 389
22:08:22:FS01:Paused
22:08:22:FS01:Shutting core down
22:08:22:WU00:FS01:0x21:WARNING:Console control signal 1 on PID 13872
22:08:22:WU00:FS01:0x21:Exiting, please wait. . .
22:08:22:WU00:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
22:08:22:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
22:08:45:Removing old file 'configs/config-20171225-033659.xml'
22:08:45:Saving configuration to config.xml
22:08:45:<config>
22:08:45:  <!-- Folding Core -->
22:08:45:  <checkpoint v='9'/>
22:08:45:  <core-priority v='low'/>
22:08:45:
22:08:45:  <!-- Network -->
22:08:45:  <proxy v=':8080'/>
22:08:45:
22:08:45:  <!-- Slot Control -->
22:08:45:  <pause-on-battery v='false'/>
22:08:45:
22:08:45:  <!-- User Information -->
22:08:45:  <passkey v='********************************'/>
22:08:45:  <team v='50959'/>
22:08:45:  <user v='kwerboom'/>
22:08:45:
22:08:45:  <!-- Folding Slots -->
22:08:45:  <slot id='1' type='GPU'>
22:08:45:    <paused v='true'/>
22:08:45:  </slot>
22:08:45:</config>
22:49:19:FS01:Unpaused
22:49:19:WU00:FS01:Starting
22:49:19:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 15844 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
22:49:19:WU00:FS01:Started FahCore on PID 14464
22:49:19:WU00:FS01:Core PID:15560
22:49:19:WU00:FS01:FahCore 0x21 started
22:49:19:WU00:FS01:0x21:*********************** Log Started 2017-12-26T22:49:19Z ***********************
22:49:19:WU00:FS01:0x21:Project: 9414 (Run 2596, Clone 1, Gen 495)
22:49:19:WU00:FS01:0x21:Unit: 0x0000024aab436c9d585e06a468576f96
22:49:19:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
22:49:19:WU00:FS01:0x21:Machine: 1
22:49:19:WU00:FS01:0x21:Digital signatures verified
22:49:19:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
22:49:19:WU00:FS01:0x21:Version 0.0.18
22:49:19:WU00:FS01:0x21:  Found a checkpoint file
22:49:20:WARNING:FS01:Size of positions 392 does not match topology 389
22:49:22:WU00:FS01:0x21:Completed 3250000 out of 6250000 steps (52%)
22:49:22:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:49:25:Removing old file 'configs/config-20171225-040022.xml'
22:49:25:Saving configuration to config.xml
22:49:25:<config>
22:49:25:  <!-- Folding Core -->
22:49:25:  <checkpoint v='9'/>
22:49:25:  <core-priority v='low'/>
22:49:25:
22:49:25:  <!-- Network -->
22:49:25:  <proxy v=':8080'/>
22:49:25:
22:49:25:  <!-- Slot Control -->
22:49:25:  <pause-on-battery v='false'/>
22:49:25:
22:49:25:  <!-- User Information -->
22:49:25:  <passkey v='********************************'/>
22:49:25:  <team v='50959'/>
22:49:25:  <user v='kwerboom'/>
22:49:25:
22:49:25:  <!-- Folding Slots -->
22:49:25:  <slot id='1' type='GPU'/>
22:49:25:</config>
22:52:06:WARNING:FS01:Size of positions 392 does not match topology 389
22:52:41:WU00:FS01:0x21:Completed 3312500 out of 6250000 steps (53%)
22:54:44:WARNING:FS01:Size of positions 392 does not match topology 389
22:55:58:WU00:FS01:0x21:Completed 3375000 out of 6250000 steps (54%)
22:57:22:WARNING:FS01:Size of positions 392 does not match topology 389
22:59:16:WU00:FS01:0x21:Completed 3437500 out of 6250000 steps (55%)
23:00:00:WARNING:FS01:Size of positions 392 does not match topology 389
23:02:34:WU00:FS01:0x21:Completed 3500000 out of 6250000 steps (56%)
23:02:39:WARNING:FS01:Size of positions 392 does not match topology 389
23:05:17:WARNING:FS01:Size of positions 392 does not match topology 389
23:05:52:WU00:FS01:0x21:Completed 3562500 out of 6250000 steps (57%)
23:07:56:WARNING:FS01:Size of positions 392 does not match topology 389
23:09:10:WU00:FS01:0x21:Completed 3625000 out of 6250000 steps (58%)
23:10:34:WARNING:FS01:Size of positions 392 does not match topology 389
23:12:27:WU00:FS01:0x21:Completed 3687500 out of 6250000 steps (59%)
23:13:12:WARNING:FS01:Size of positions 392 does not match topology 389
23:15:45:WU00:FS01:0x21:Completed 3750000 out of 6250000 steps (60%)
23:15:51:WARNING:FS01:Size of positions 392 does not match topology 389
23:18:29:WARNING:FS01:Size of positions 392 does not match topology 389
23:19:04:WU00:FS01:0x21:Completed 3812500 out of 6250000 steps (61%)
23:21:07:WARNING:FS01:Size of positions 392 does not match topology 389
23:22:22:WU00:FS01:0x21:Completed 3875000 out of 6250000 steps (62%)
23:23:46:WARNING:FS01:Size of positions 392 does not match topology 389
23:25:39:WU00:FS01:0x21:Completed 3937500 out of 6250000 steps (63%)
23:26:24:WARNING:FS01:Size of positions 392 does not match topology 389
23:28:57:WU00:FS01:0x21:Completed 4000000 out of 6250000 steps (64%)
23:29:03:WARNING:FS01:Size of positions 392 does not match topology 389
23:31:41:WARNING:FS01:Size of positions 392 does not match topology 389
23:32:16:WU00:FS01:0x21:Completed 4062500 out of 6250000 steps (65%)
23:34:20:WARNING:FS01:Size of positions 392 does not match topology 389
23:35:34:WU00:FS01:0x21:Completed 4125000 out of 6250000 steps (66%)
23:36:58:WARNING:FS01:Size of positions 392 does not match topology 389
23:38:51:WU00:FS01:0x21:Completed 4187500 out of 6250000 steps (67%)
23:39:36:WARNING:FS01:Size of positions 392 does not match topology 389
23:42:09:WU00:FS01:0x21:Completed 4250000 out of 6250000 steps (68%)
23:42:15:WARNING:FS01:Size of positions 392 does not match topology 389
23:44:53:WARNING:FS01:Size of positions 392 does not match topology 389
23:45:28:WU00:FS01:0x21:Completed 4312500 out of 6250000 steps (69%)
23:47:32:WARNING:FS01:Size of positions 392 does not match topology 389
23:48:46:WU00:FS01:0x21:Completed 4375000 out of 6250000 steps (70%)
23:50:11:WARNING:FS01:Size of positions 392 does not match topology 389
23:52:04:WU00:FS01:0x21:Completed 4437500 out of 6250000 steps (71%)
23:52:49:WARNING:FS01:Size of positions 392 does not match topology 389
23:55:22:WU00:FS01:0x21:Completed 4500000 out of 6250000 steps (72%)
23:55:27:WARNING:FS01:Size of positions 392 does not match topology 389
23:58:05:WARNING:FS01:Size of positions 392 does not match topology 389
23:58:40:WU00:FS01:0x21:Completed 4562500 out of 6250000 steps (73%)
00:00:43:WARNING:FS01:Size of positions 392 does not match topology 389
00:01:57:WU00:FS01:0x21:Completed 4625000 out of 6250000 steps (74%)
00:03:21:WARNING:FS01:Size of positions 392 does not match topology 389
00:05:13:WU00:FS01:0x21:Completed 4687500 out of 6250000 steps (75%)
00:05:58:WARNING:FS01:Size of positions 392 does not match topology 389
00:08:30:WU00:FS01:0x21:Completed 4750000 out of 6250000 steps (76%)
00:08:35:WARNING:FS01:Size of positions 392 does not match topology 389
00:11:13:WARNING:FS01:Size of positions 392 does not match topology 389
00:11:48:WU00:FS01:0x21:Completed 4812500 out of 6250000 steps (77%)
00:13:52:WARNING:FS01:Size of positions 392 does not match topology 389
00:15:06:WU00:FS01:0x21:Completed 4875000 out of 6250000 steps (78%)
00:16:29:WARNING:FS01:Size of positions 392 does not match topology 389
00:18:22:WU00:FS01:0x21:Completed 4937500 out of 6250000 steps (79%)
00:19:07:WARNING:FS01:Size of positions 392 does not match topology 389
00:21:40:WU00:FS01:0x21:Completed 5000000 out of 6250000 steps (80%)
00:21:46:WARNING:FS01:Size of positions 392 does not match topology 389
00:21:53:FS01:Paused
00:21:53:FS01:Shutting core down
00:21:53:WU00:FS01:0x21:WARNING:Console control signal 1 on PID 15560
00:21:53:WU00:FS01:0x21:Exiting, please wait. . .
00:21:54:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:21:56:Removing old file 'configs/config-20171225-044607.xml'
00:21:56:Saving configuration to config.xml
00:21:56:<config>
00:21:56:  <!-- Folding Core -->
00:21:56:  <checkpoint v='9'/>
00:21:56:  <core-priority v='low'/>
00:21:56:
00:21:56:  <!-- Network -->
00:21:56:  <proxy v=':8080'/>
00:21:56:
00:21:56:  <!-- Slot Control -->
00:21:56:  <pause-on-battery v='false'/>
00:21:56:
00:21:56:  <!-- User Information -->
00:21:56:  <passkey v='********************************'/>
00:21:56:  <team v='50959'/>
00:21:56:  <user v='kwerboom'/>
00:21:56:
00:21:56:  <!-- Folding Slots -->
00:21:56:  <slot id='1' type='GPU'>
00:21:56:    <paused v='true'/>
00:21:56:  </slot>
00:21:56:</config>
00:56:55:FS01:Unpaused
00:56:55:WU00:FS01:Starting
00:56:55:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 15844 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
00:56:55:WU00:FS01:Started FahCore on PID 20128
00:56:55:WU00:FS01:Core PID:11620
00:56:55:WU00:FS01:FahCore 0x21 started
00:56:56:WARNING:FS01:Size of positions 392 does not match topology 389
00:56:56:WU00:FS01:0x21:*********************** Log Started 2017-12-27T00:56:55Z ***********************
00:56:56:WU00:FS01:0x21:Project: 9414 (Run 2596, Clone 1, Gen 495)
00:56:56:WU00:FS01:0x21:Unit: 0x0000024aab436c9d585e06a468576f96
00:56:56:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:56:56:WU00:FS01:0x21:Machine: 1
00:56:56:WU00:FS01:0x21:Digital signatures verified
00:56:56:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:56:56:WU00:FS01:0x21:Version 0.0.18
00:56:56:WU00:FS01:0x21:  Found a checkpoint file
00:56:59:WU00:FS01:0x21:Completed 5000000 out of 6250000 steps (80%)
00:56:59:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:57:31:Removing old file 'configs/config-20171225-050425.xml'
00:57:31:Saving configuration to config.xml
00:57:31:<config>
00:57:31:  <!-- Folding Core -->
00:57:31:  <checkpoint v='9'/>
00:57:31:  <core-priority v='low'/>
00:57:31:
00:57:31:  <!-- Network -->
00:57:31:  <proxy v=':8080'/>
00:57:31:
00:57:31:  <!-- Slot Control -->
00:57:31:  <pause-on-battery v='false'/>
00:57:31:
00:57:31:  <!-- User Information -->
00:57:31:  <passkey v='********************************'/>
00:57:31:  <team v='50959'/>
00:57:31:  <user v='kwerboom'/>
00:57:31:
00:57:31:  <!-- Folding Slots -->
00:57:31:  <slot id='1' type='GPU'/>
00:57:31:</config>
00:59:44:WARNING:FS01:Size of positions 392 does not match topology 389
01:00:19:WU00:FS01:0x21:Completed 5062500 out of 6250000 steps (81%)
01:02:24:WARNING:FS01:Size of positions 392 does not match topology 389
01:03:38:WU00:FS01:0x21:Completed 5125000 out of 6250000 steps (82%)
01:05:02:WARNING:FS01:Size of positions 392 does not match topology 389
01:06:56:WU00:FS01:0x21:Completed 5187500 out of 6250000 steps (83%)
01:07:40:WARNING:FS01:Size of positions 392 does not match topology 389
01:10:13:WU00:FS01:0x21:Completed 5250000 out of 6250000 steps (84%)
01:10:18:WARNING:FS01:Size of positions 392 does not match topology 389
01:12:56:WARNING:FS01:Size of positions 392 does not match topology 389
01:13:30:WU00:FS01:0x21:Completed 5312500 out of 6250000 steps (85%)
01:15:33:WARNING:FS01:Size of positions 392 does not match topology 389
01:16:47:WU00:FS01:0x21:Completed 5375000 out of 6250000 steps (86%)
01:18:11:WARNING:FS01:Size of positions 392 does not match topology 389
01:20:03:WU00:FS01:0x21:Completed 5437500 out of 6250000 steps (87%)
01:20:47:WARNING:FS01:Size of positions 392 does not match topology 389
01:23:19:WU00:FS01:0x21:Completed 5500000 out of 6250000 steps (88%)
01:23:24:WARNING:FS01:Size of positions 392 does not match topology 389
01:26:04:WARNING:FS01:Size of positions 392 does not match topology 389
01:26:40:WU00:FS01:0x21:Completed 5562500 out of 6250000 steps (89%)
01:28:45:WARNING:FS01:Size of positions 392 does not match topology 389
01:30:00:WU00:FS01:0x21:Completed 5625000 out of 6250000 steps (90%)
01:31:25:WARNING:FS01:Size of positions 392 does not match topology 389
01:33:20:WU00:FS01:0x21:Completed 5687500 out of 6250000 steps (91%)
01:34:05:WARNING:FS01:Size of positions 392 does not match topology 389
01:36:40:WU00:FS01:0x21:Completed 5750000 out of 6250000 steps (92%)
01:36:45:WARNING:FS01:Size of positions 392 does not match topology 389
01:39:25:WARNING:FS01:Size of positions 392 does not match topology 389
01:40:00:WU00:FS01:0x21:Completed 5812500 out of 6250000 steps (93%)
01:42:05:WARNING:FS01:Size of positions 392 does not match topology 389
01:43:20:WU00:FS01:0x21:Completed 5875000 out of 6250000 steps (94%)
01:44:45:WARNING:FS01:Size of positions 392 does not match topology 389
01:46:40:WU00:FS01:0x21:Completed 5937500 out of 6250000 steps (95%)
01:47:25:WARNING:FS01:Size of positions 392 does not match topology 389
01:50:00:WU00:FS01:0x21:Completed 6000000 out of 6250000 steps (96%)
01:50:06:WARNING:FS01:Size of positions 392 does not match topology 389
01:52:46:WARNING:FS01:Size of positions 392 does not match topology 389
01:53:21:WU00:FS01:0x21:Completed 6062500 out of 6250000 steps (97%)
01:55:26:WARNING:FS01:Size of positions 392 does not match topology 389
01:56:41:WU00:FS01:0x21:Completed 6125000 out of 6250000 steps (98%)
01:58:07:WARNING:FS01:Size of positions 392 does not match topology 389
02:00:02:WU00:FS01:0x21:Completed 6187500 out of 6250000 steps (99%)
02:00:03:WU01:FS01:Connecting to 171.67.108.45:80
02:00:04:WU01:FS01:Assigned to work server 171.67.108.157
02:00:04:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950] from 171.67.108.157
02:00:04:WU01:FS01:Connecting to 171.67.108.157:8080
02:00:04:WU01:FS01:Downloading 8.80MiB
02:00:10:WU01:FS01:Download 37.65%
02:00:16:WU01:FS01:Download 55.41%
02:00:22:WU01:FS01:Download 66.07%
02:00:28:WU01:FS01:Download 80.28%
02:00:34:WU01:FS01:Download 86.67%
02:00:40:WU01:FS01:Download 95.20%
02:00:41:WU01:FS01:Download complete
02:00:41:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9431 run:573 clone:1 gen:492 core:0x21 unit:0x0000023aab436c9d586fdd38df6fbe9d
02:00:48:WARNING:FS01:Size of positions 392 does not match topology 389
02:03:23:WU00:FS01:0x21:Completed 6250000 out of 6250000 steps (100%)
02:03:23:WU00:FS01:0x21:Saving result file logfile_01.txt
02:03:23:WU00:FS01:0x21:Saving result file checkpointState.xml
02:03:23:WU00:FS01:0x21:Saving result file checkpt.crc
02:03:23:WU00:FS01:0x21:Saving result file log.txt
02:03:23:WU00:FS01:0x21:Saving result file positions.xtc
02:03:23:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
02:03:24:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:03:24:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9414 run:2596 clone:1 gen:495 core:0x21 unit:0x0000024aab436c9d585e06a468576f96
02:03:24:WU00:FS01:Uploading 7.76MiB to 171.67.108.157
02:03:24:WU00:FS01:Connecting to 171.67.108.157:8080
02:03:24:WU01:FS01:Starting
02:03:24:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 15844 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
02:03:24:WU01:FS01:Started FahCore on PID 9272
02:03:24:WU01:FS01:Core PID:14352
02:03:24:WU01:FS01:FahCore 0x21 started
02:03:24:WU01:FS01:0x21:*********************** Log Started 2017-12-27T02:03:24Z ***********************
02:03:24:WU01:FS01:0x21:Project: 9431 (Run 573, Clone 1, Gen 492)
02:03:24:WU01:FS01:0x21:Unit: 0x0000023aab436c9d586fdd38df6fbe9d
02:03:24:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
02:03:24:WU01:FS01:0x21:Machine: 1
02:03:24:WU01:FS01:0x21:Reading tar file core.xml
02:03:24:WU01:FS01:0x21:Reading tar file integrator.xml
02:03:24:WU01:FS01:0x21:Reading tar file state.xml
02:03:24:WU01:FS01:0x21:Reading tar file system.xml
02:03:24:WU01:FS01:0x21:Digital signatures verified
02:03:24:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
02:03:24:WU01:FS01:0x21:Version 0.0.18
02:03:28:WU01:FS01:0x21:Completed 0 out of 6250000 steps (0%)
02:03:28:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:03:30:WU00:FS01:Upload 6.44%
02:03:38:WU00:FS01:Upload 18.52%
02:03:44:WU00:FS01:Upload 21.74%
02:03:50:WU00:FS01:Upload 28.98%
02:03:56:WU00:FS01:Upload 35.43%
02:04:02:WU00:FS01:Upload 41.87%
02:04:14:WU00:FS01:Upload 45.89%
02:04:20:WU00:FS01:Upload 53.14%
02:04:27:WU00:FS01:Upload 58.77%
02:04:35:WU00:FS01:Upload 64.41%
02:04:41:WU00:FS01:Upload 73.27%
02:04:48:WU00:FS01:Upload 78.90%
02:04:57:WU00:FS01:Upload 82.12%
02:05:03:WU00:FS01:Upload 88.56%
02:05:10:WU00:FS01:Upload 94.20%
02:05:16:WU00:FS01:Upload 96.62%
02:05:28:WU00:FS01:Upload complete
02:05:28:WU00:FS01:Server responded WORK_ACK (400)
02:05:28:WU00:FS01:Final credit estimate, 20585.00 points
02:05:28:WU00:FS01:Cleaning up
02:06:12:WARNING:FS01:Size of positions 346 does not match topology 334
02:06:32:FS01:Paused
02:06:32:FS01:Shutting core down
02:06:32:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 14352
02:06:32:WU01:FS01:0x21:Exiting, please wait. . .
02:06:32:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
02:06:32:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
02:06:39:Removing old file 'configs/config-20171225-053859.xml'
02:06:39:Saving configuration to config.xml
02:06:39:<config>
02:06:39:  <!-- Folding Core -->
02:06:39:  <checkpoint v='9'/>
02:06:39:  <core-priority v='low'/>
02:06:39:
02:06:39:  <!-- Network -->
02:06:39:  <proxy v=':8080'/>
02:06:39:
02:06:39:  <!-- Slot Control -->
02:06:39:  <pause-on-battery v='false'/>
02:06:39:
02:06:39:  <!-- User Information -->
02:06:39:  <passkey v='********************************'/>
02:06:39:  <team v='50959'/>
02:06:39:  <user v='kwerboom'/>
02:06:39:
02:06:39:  <!-- Folding Slots -->
02:06:39:  <slot id='1' type='GPU'>
02:06:39:    <paused v='true'/>
02:06:39:  </slot>
02:06:39:</config>
02:47:43:FS01:Unpaused
02:47:43:WU01:FS01:Starting
02:47:43:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 15844 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
02:47:43:WU01:FS01:Started FahCore on PID 6724
02:47:43:WU01:FS01:Core PID:936
02:47:43:WU01:FS01:FahCore 0x21 started
02:47:44:WARNING:FS01:Size of positions 346 does not match topology 334
02:47:44:WU01:FS01:0x21:*********************** Log Started 2017-12-27T02:47:44Z ***********************
02:47:44:WU01:FS01:0x21:Project: 9431 (Run 573, Clone 1, Gen 492)
02:47:44:WU01:FS01:0x21:Unit: 0x0000023aab436c9d586fdd38df6fbe9d
02:47:44:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
02:47:44:WU01:FS01:0x21:Machine: 1
02:47:44:WU01:FS01:0x21:Digital signatures verified
02:47:44:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
02:47:44:WU01:FS01:0x21:Version 0.0.18
02:47:44:WU01:FS01:0x21:  Found a checkpoint file
02:47:47:WU01:FS01:0x21:Completed 50000 out of 6250000 steps (0%)
02:47:47:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:48:20:Removing old file 'configs/config-20171225-064201.xml'
02:48:20:Saving configuration to config.xml
02:48:20:<config>
02:48:20:  <!-- Folding Core -->
02:48:20:  <checkpoint v='9'/>
02:48:20:  <core-priority v='low'/>
02:48:20:
02:48:20:  <!-- Network -->
02:48:20:  <proxy v=':8080'/>
02:48:20:
02:48:20:  <!-- Slot Control -->
02:48:20:  <pause-on-battery v='false'/>
02:48:20:
02:48:20:  <!-- User Information -->
02:48:20:  <passkey v='********************************'/>
02:48:20:  <team v='50959'/>
02:48:20:  <user v='kwerboom'/>
02:48:20:
02:48:20:  <!-- Folding Slots -->
02:48:20:  <slot id='1' type='GPU'/>
02:48:20:</config>
02:48:27:WU01:FS01:0x21:Completed 62500 out of 6250000 steps (1%)
02:50:44:WARNING:FS01:Size of positions 346 does not match topology 334
02:52:06:WU01:FS01:0x21:Completed 125000 out of 6250000 steps (2%)
02:53:34:WARNING:FS01:Size of positions 346 does not match topology 334
02:55:35:WU01:FS01:0x21:Completed 187500 out of 6250000 steps (3%)
02:56:24:WARNING:FS01:Size of positions 346 does not match topology 334
02:59:01:WU01:FS01:0x21:Completed 250000 out of 6250000 steps (4%)
02:59:07:WARNING:FS01:Size of positions 346 does not match topology 334
03:01:58:WARNING:FS01:Size of positions 346 does not match topology 334
03:02:36:WU01:FS01:0x21:Completed 312500 out of 6250000 steps (5%)
03:04:48:WARNING:FS01:Size of positions 346 does not match topology 334
03:06:00:WU01:FS01:0x21:Completed 375000 out of 6250000 steps (6%)
03:07:24:WARNING:FS01:Size of positions 346 does not match topology 334
03:09:16:WU01:FS01:0x21:Completed 437500 out of 6250000 steps (7%)
03:10:01:WARNING:FS01:Size of positions 346 does not match topology 334
03:12:32:WU01:FS01:0x21:Completed 500000 out of 6250000 steps (8%)
03:12:38:WARNING:FS01:Size of positions 346 does not match topology 334
03:15:17:WARNING:FS01:Size of positions 346 does not match topology 334
03:15:52:WU01:FS01:0x21:Completed 562500 out of 6250000 steps (9%)
03:17:55:WARNING:FS01:Size of positions 346 does not match topology 334
03:19:09:WU01:FS01:0x21:Completed 625000 out of 6250000 steps (10%)
03:20:33:WARNING:FS01:Size of positions 346 does not match topology 334
03:22:26:WU01:FS01:0x21:Completed 687500 out of 6250000 steps (11%)
03:23:12:WARNING:FS01:Size of positions 346 does not match topology 334
03:25:45:WU01:FS01:0x21:Completed 750000 out of 6250000 steps (12%)
03:25:50:WARNING:FS01:Size of positions 346 does not match topology 334
03:28:29:WARNING:FS01:Size of positions 346 does not match topology 334
03:29:03:WU01:FS01:0x21:Completed 812500 out of 6250000 steps (13%)
03:31:07:WARNING:FS01:Size of positions 346 does not match topology 334
03:32:21:WU01:FS01:0x21:Completed 875000 out of 6250000 steps (14%)
03:33:45:WARNING:FS01:Size of positions 346 does not match topology 334
03:35:38:WU01:FS01:0x21:Completed 937500 out of 6250000 steps (15%)
03:36:22:WARNING:FS01:Size of positions 346 does not match topology 334
******************************* Date: 2017-12-27 *******************************
03:38:57:WU01:FS01:0x21:Completed 1000000 out of 6250000 steps (16%)
03:39:03:WARNING:FS01:Size of positions 346 does not match topology 334
03:41:39:WARNING:FS01:Size of positions 346 does not match topology 334
03:42:12:WU01:FS01:0x21:Completed 1062500 out of 6250000 steps (17%)
03:44:14:WARNING:FS01:Size of positions 346 does not match topology 334
03:45:27:WU01:FS01:0x21:Completed 1125000 out of 6250000 steps (18%)
03:46:50:WARNING:FS01:Size of positions 346 does not match topology 334
03:48:42:WU01:FS01:0x21:Completed 1187500 out of 6250000 steps (19%)
03:49:26:WARNING:FS01:Size of positions 346 does not match topology 334
03:51:59:WU01:FS01:0x21:Completed 1250000 out of 6250000 steps (20%)
03:52:04:WARNING:FS01:Size of positions 346 does not match topology 334
03:54:42:WARNING:FS01:Size of positions 346 does not match topology 334
03:55:16:WU01:FS01:0x21:Completed 1312500 out of 6250000 steps (21%)
03:57:18:WARNING:FS01:Size of positions 346 does not match topology 334
03:58:32:WU01:FS01:0x21:Completed 1375000 out of 6250000 steps (22%)
03:59:57:WARNING:FS01:Size of positions 346 does not match topology 334
04:01:53:WU01:FS01:0x21:Completed 1437500 out of 6250000 steps (23%)
04:02:40:WARNING:FS01:Size of positions 346 does not match topology 334
04:05:22:WU01:FS01:0x21:Completed 1500000 out of 6250000 steps (24%)
04:05:27:WARNING:FS01:Size of positions 346 does not match topology 334
04:08:04:WARNING:FS01:Size of positions 346 does not match topology 334
04:08:38:WU01:FS01:0x21:Completed 1562500 out of 6250000 steps (25%)
04:10:40:WARNING:FS01:Size of positions 346 does not match topology 334
04:11:53:WU01:FS01:0x21:Completed 1625000 out of 6250000 steps (26%)
04:13:16:WARNING:FS01:Size of positions 346 does not match topology 334
04:15:09:WU01:FS01:0x21:Completed 1687500 out of 6250000 steps (27%)
04:15:54:WARNING:FS01:Size of positions 346 does not match topology 334
04:18:27:WU01:FS01:0x21:Completed 1750000 out of 6250000 steps (28%)
04:18:33:WARNING:FS01:Size of positions 346 does not match topology 334
04:21:09:WARNING:FS01:Size of positions 346 does not match topology 334
04:21:43:WU01:FS01:0x21:Completed 1812500 out of 6250000 steps (29%)
04:23:44:WARNING:FS01:Size of positions 346 does not match topology 334
04:24:57:WU01:FS01:0x21:Completed 1875000 out of 6250000 steps (30%)
04:26:19:WARNING:FS01:Size of positions 346 does not match topology 334
04:26:25:Removing old file 'configs/config-20171225-085108.xml'
04:26:25:Saving configuration to config.xml
04:26:25:<config>
04:26:25:  <!-- Folding Core -->
04:26:25:  <checkpoint v='9'/>
04:26:25:  <core-priority v='low'/>
04:26:25:
04:26:25:  <!-- Network -->
04:26:25:  <proxy v=':8080'/>
04:26:25:
04:26:25:  <!-- Slot Control -->
04:26:25:  <pause-on-battery v='false'/>
04:26:25:
04:26:25:  <!-- User Information -->
04:26:25:  <passkey v='********************************'/>
04:26:25:  <team v='224497'/>
04:26:25:  <user v='kwerboom_ALL_BB814ghPZ4spNv3DwfqdsQr8nEjCbQ1o5J'/>
04:26:25:
04:26:25:  <!-- Folding Slots -->
04:26:25:  <slot id='1' type='GPU'/>
04:26:25:</config>
04:26:57:Removing old file 'configs/config-20171225-185850.xml'
04:26:57:Saving configuration to config.xml
04:26:57:<config>
04:26:57:  <!-- Folding Core -->
04:26:57:  <checkpoint v='9'/>
04:26:57:  <core-priority v='low'/>
04:26:57:
04:26:57:  <!-- Network -->
04:26:57:  <proxy v=':8080'/>
04:26:57:
04:26:57:  <!-- Slot Control -->
04:26:57:  <pause-on-battery v='false'/>
04:26:57:
04:26:57:  <!-- User Information -->
04:26:57:  <passkey v='********************************'/>
04:26:57:  <team v='224497'/>
04:26:57:  <user v='kwerboom_ALL_BB814ghPZ4spNv3DwfqdsQr8nEjCbQ1o5J'/>
04:26:57:
04:26:57:  <!-- Folding Slots -->
04:26:57:  <slot id='1' type='GPU'/>
04:26:57:</config>
04:28:58:WU01:FS01:0x21:Completed 1937500 out of 6250000 steps (31%)
04:30:06:WARNING:FS01:Size of positions 346 does not match topology 334
04:33:56:WU01:FS01:0x21:Completed 2000000 out of 6250000 steps (32%)
04:34:02:WARNING:FS01:Size of positions 346 does not match topology 334
04:37:43:WARNING:FS01:Size of positions 346 does not match topology 334
04:38:34:WU01:FS01:0x21:Completed 2062500 out of 6250000 steps (33%)
04:41:25:WARNING:FS01:Size of positions 346 does not match topology 334
04:43:10:WU01:FS01:0x21:Completed 2125000 out of 6250000 steps (34%)
04:45:03:WARNING:FS01:Size of positions 346 does not match topology 334
04:47:38:WU01:FS01:0x21:Completed 2187500 out of 6250000 steps (35%)
04:48:38:WARNING:FS01:Size of positions 346 does not match topology 334
04:51:58:WU01:FS01:0x21:Completed 2250000 out of 6250000 steps (36%)
04:52:05:WARNING:FS01:Size of positions 346 does not match topology 334
04:55:43:WARNING:FS01:Size of positions 346 does not match topology 334
04:56:32:WU01:FS01:0x21:Completed 2312500 out of 6250000 steps (37%)
04:59:30:WARNING:FS01:Size of positions 346 does not match topology 334
05:01:15:WU01:FS01:0x21:Completed 2375000 out of 6250000 steps (38%)
05:03:12:WARNING:FS01:Size of positions 346 does not match topology 334
05:05:55:WU01:FS01:0x21:Completed 2437500 out of 6250000 steps (39%)
05:06:54:WARNING:FS01:Size of positions 346 does not match topology 334
05:10:44:WU01:FS01:0x21:Completed 2500000 out of 6250000 steps (40%)
05:10:50:WARNING:FS01:Size of positions 346 does not match topology 334
05:13:54:WARNING:FS01:Size of positions 346 does not match topology 334
05:14:31:WU01:FS01:0x21:Completed 2562500 out of 6250000 steps (41%)
05:16:46:WARNING:FS01:Size of positions 346 does not match topology 334
05:18:00:WU01:FS01:0x21:Completed 2625000 out of 6250000 steps (42%)
05:19:24:WARNING:FS01:Size of positions 346 does not match topology 334
05:20:19:FS01:Paused
05:20:19:FS01:Shutting core down
05:20:19:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 936
05:20:19:WU01:FS01:0x21:Exiting, please wait. . .
05:20:19:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
05:20:20:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
05:20:50:Removing old file 'configs/config-20171226-014429.xml'
05:20:50:Saving configuration to config.xml
05:20:50:<config>
05:20:50:  <!-- Folding Core -->
05:20:50:  <checkpoint v='9'/>
05:20:50:  <core-priority v='low'/>
05:20:50:
05:20:50:  <!-- Network -->
05:20:50:  <proxy v=':8080'/>
05:20:50:
05:20:50:  <!-- Slot Control -->
05:20:50:  <pause-on-battery v='false'/>
05:20:50:
05:20:50:  <!-- User Information -->
05:20:50:  <passkey v='********************************'/>
05:20:50:  <team v='224497'/>
05:20:50:  <user v='kwerboom_ALL_BB814ghPZ4spNv3DwfqdsQr8nEjCbQ1o5J'/>
05:20:50:
05:20:50:  <!-- Folding Slots -->
05:20:50:  <slot id='1' type='GPU'>
05:20:50:    <paused v='true'/>
05:20:50:  </slot>
05:20:50:</config>
06:00:33:FS01:Unpaused
06:00:33:WU01:FS01:Starting
06:00:33:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 15844 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
06:00:33:WU01:FS01:Started FahCore on PID 17688
06:00:33:WU01:FS01:Core PID:9868
06:00:33:WU01:FS01:FahCore 0x21 started
06:00:34:WU01:FS01:0x21:*********************** Log Started 2017-12-27T06:00:33Z ***********************
06:00:34:WU01:FS01:0x21:Project: 9431 (Run 573, Clone 1, Gen 492)
06:00:34:WU01:FS01:0x21:Unit: 0x0000023aab436c9d586fdd38df6fbe9d
06:00:34:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:00:34:WU01:FS01:0x21:Machine: 1
06:00:34:WU01:FS01:0x21:Digital signatures verified
06:00:34:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:00:34:WU01:FS01:0x21:Version 0.0.18
06:00:34:WU01:FS01:0x21:  Found a checkpoint file
06:00:34:WARNING:FS01:Size of positions 346 does not match topology 334
06:00:37:WU01:FS01:0x21:Completed 2650000 out of 6250000 steps (42%)
06:00:37:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:01:30:Removing old file 'configs/config-20171226-022206.xml'
06:01:30:Saving configuration to config.xml
06:01:30:<config>
06:01:30:  <!-- Folding Core -->
06:01:30:  <checkpoint v='9'/>
06:01:30:  <core-priority v='low'/>
06:01:30:
06:01:30:  <!-- Network -->
06:01:30:  <proxy v=':8080'/>
06:01:30:
06:01:30:  <!-- Slot Control -->
06:01:30:  <pause-on-battery v='false'/>
06:01:30:
06:01:30:  <!-- User Information -->
06:01:30:  <passkey v='********************************'/>
06:01:30:  <team v='224497'/>
06:01:30:  <user v='kwerboom_ALL_BB814ghPZ4spNv3DwfqdsQr8nEjCbQ1o5J'/>
06:01:30:
06:01:30:  <!-- Folding Slots -->
06:01:30:  <slot id='1' type='GPU'/>
06:01:30:</config>
06:02:35:WU01:FS01:0x21:Completed 2687500 out of 6250000 steps (43%)
06:03:21:WARNING:FS01:Size of positions 346 does not match topology 334
06:05:55:WU01:FS01:0x21:Completed 2750000 out of 6250000 steps (44%)
06:06:00:WARNING:FS01:Size of positions 346 does not match topology 334
06:08:39:WARNING:FS01:Size of positions 346 does not match topology 334
06:09:14:WU01:FS01:0x21:Completed 2812500 out of 6250000 steps (45%)
06:11:19:WARNING:FS01:Size of positions 346 does not match topology 334
06:12:33:WU01:FS01:0x21:Completed 2875000 out of 6250000 steps (46%)
06:13:57:WARNING:FS01:Size of positions 346 does not match topology 334
06:15:53:WU01:FS01:0x21:Completed 2937500 out of 6250000 steps (47%)
06:16:38:WARNING:FS01:Size of positions 346 does not match topology 334
06:19:12:WU01:FS01:0x21:Completed 3000000 out of 6250000 steps (48%)
06:19:17:WARNING:FS01:Size of positions 346 does not match topology 334
06:21:57:WARNING:FS01:Size of positions 346 does not match topology 334
06:22:32:WU01:FS01:0x21:Completed 3062500 out of 6250000 steps (49%)
06:24:37:WARNING:FS01:Size of positions 346 does not match topology 334
06:25:52:WU01:FS01:0x21:Completed 3125000 out of 6250000 steps (50%)
06:27:17:WARNING:FS01:Size of positions 346 does not match topology 334
06:29:12:WU01:FS01:0x21:Completed 3187500 out of 6250000 steps (51%)
06:29:57:WARNING:FS01:Size of positions 346 does not match topology 334
06:32:30:WU01:FS01:0x21:Completed 3250000 out of 6250000 steps (52%)
06:32:36:WARNING:FS01:Size of positions 346 does not match topology 334
06:35:14:WARNING:FS01:Size of positions 346 does not match topology 334
06:35:49:WU01:FS01:0x21:Completed 3312500 out of 6250000 steps (53%)
06:37:53:WARNING:FS01:Size of positions 346 does not match topology 334
06:39:06:WU01:FS01:0x21:Completed 3375000 out of 6250000 steps (54%)
06:40:31:WARNING:FS01:Size of positions 346 does not match topology 334
06:42:25:WU01:FS01:0x21:Completed 3437500 out of 6250000 steps (55%)
06:43:10:WARNING:FS01:Size of positions 346 does not match topology 334
06:45:43:WU01:FS01:0x21:Completed 3500000 out of 6250000 steps (56%)
06:45:48:WARNING:FS01:Size of positions 346 does not match topology 334
06:48:27:WARNING:FS01:Size of positions 346 does not match topology 334
06:49:02:WU01:FS01:0x21:Completed 3562500 out of 6250000 steps (57%)
06:51:06:WARNING:FS01:Size of positions 346 does not match topology 334
06:52:20:WU01:FS01:0x21:Completed 3625000 out of 6250000 steps (58%)
06:53:44:WARNING:FS01:Size of positions 346 does not match topology 334
06:55:38:WU01:FS01:0x21:Completed 3687500 out of 6250000 steps (59%)
06:56:23:WARNING:FS01:Size of positions 346 does not match topology 334
06:58:56:WU01:FS01:0x21:Completed 3750000 out of 6250000 steps (60%)
06:59:02:WARNING:FS01:Size of positions 346 does not match topology 334
07:00:19:FS01:Paused
07:00:19:FS01:Shutting core down
07:00:19:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 9868
07:00:19:WU01:FS01:0x21:Exiting, please wait. . .
07:00:19:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
07:00:28:Removing old file 'configs/config-20171226-055738.xml'
07:00:28:Saving configuration to config.xml
07:00:28:<config>
07:00:28:  <!-- Folding Core -->
07:00:28:  <checkpoint v='9'/>
07:00:28:  <core-priority v='low'/>
07:00:28:
07:00:28:  <!-- Network -->
07:00:28:  <proxy v=':8080'/>
07:00:28:
07:00:28:  <!-- Slot Control -->
07:00:28:  <pause-on-battery v='false'/>
07:00:28:
07:00:28:  <!-- User Information -->
07:00:28:  <passkey v='********************************'/>
07:00:28:  <team v='224497'/>
07:00:28:  <user v='kwerboom_ALL_BB814ghPZ4spNv3DwfqdsQr8nEjCbQ1o5J'/>
07:00:28:
07:00:28:  <!-- Folding Slots -->
07:00:28:  <slot id='1' type='GPU'>
07:00:28:    <paused v='true'/>
07:00:28:  </slot>
07:00:28:</config>
08:34:54:FS01:Unpaused
08:34:54:FS01:Finishing
08:34:54:WU01:FS01:Starting
08:34:54:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 15844 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
08:34:54:WU01:FS01:Started FahCore on PID 4892
08:34:54:WU01:FS01:Core PID:15448
08:34:54:WU01:FS01:FahCore 0x21 started
08:34:54:WU01:FS01:0x21:*********************** Log Started 2017-12-27T08:34:54Z ***********************
08:34:54:WU01:FS01:0x21:Project: 9431 (Run 573, Clone 1, Gen 492)
08:34:54:WU01:FS01:0x21:Unit: 0x0000023aab436c9d586fdd38df6fbe9d
08:34:54:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
08:34:54:WU01:FS01:0x21:Machine: 1
08:34:54:WU01:FS01:0x21:Digital signatures verified
08:34:54:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
08:34:54:WU01:FS01:0x21:Version 0.0.18
08:34:54:WU01:FS01:0x21:  Found a checkpoint file
08:34:55:WARNING:FS01:Size of positions 346 does not match topology 334
08:34:58:WU01:FS01:0x21:Completed 3750000 out of 6250000 steps (60%)
08:34:58:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:35:01:Removing old file 'configs/config-20171226-064121.xml'
08:35:01:Saving configuration to config.xml
08:35:01:<config>
08:35:01:  <!-- Folding Core -->
08:35:01:  <checkpoint v='9'/>
08:35:01:  <core-priority v='low'/>
08:35:01:
08:35:01:  <!-- Network -->
08:35:01:  <proxy v=':8080'/>
08:35:01:
08:35:01:  <!-- Slot Control -->
08:35:01:  <pause-on-battery v='false'/>
08:35:01:
08:35:01:  <!-- User Information -->
08:35:01:  <passkey v='********************************'/>
08:35:01:  <team v='224497'/>
08:35:01:  <user v='kwerboom_ALL_BB814ghPZ4spNv3DwfqdsQr8nEjCbQ1o5J'/>
08:35:01:
08:35:01:  <!-- Folding Slots -->
08:35:01:  <slot id='1' type='GPU'/>
08:35:01:</config>
08:37:40:WARNING:FS01:Size of positions 346 does not match topology 334
08:38:13:WU01:FS01:0x21:Completed 3812500 out of 6250000 steps (61%)
08:40:17:WARNING:FS01:Size of positions 346 does not match topology 334
08:41:31:WU01:FS01:0x21:Completed 3875000 out of 6250000 steps (62%)
08:42:54:WARNING:FS01:Size of positions 346 does not match topology 334
08:44:48:WU01:FS01:0x21:Completed 3937500 out of 6250000 steps (63%)
08:45:32:WARNING:FS01:Size of positions 346 does not match topology 334
08:48:05:WU01:FS01:0x21:Completed 4000000 out of 6250000 steps (64%)
08:48:11:WARNING:FS01:Size of positions 346 does not match topology 334
08:50:49:WARNING:FS01:Size of positions 346 does not match topology 334
08:51:23:WU01:FS01:0x21:Completed 4062500 out of 6250000 steps (65%)
08:53:27:WARNING:FS01:Size of positions 346 does not match topology 334
08:54:41:WU01:FS01:0x21:Completed 4125000 out of 6250000 steps (66%)
08:56:05:WARNING:FS01:Size of positions 346 does not match topology 334
08:57:59:WU01:FS01:0x21:Completed 4187500 out of 6250000 steps (67%)
08:58:44:WARNING:FS01:Size of positions 346 does not match topology 334
09:01:17:WU01:FS01:0x21:Completed 4250000 out of 6250000 steps (68%)
09:01:22:WARNING:FS01:Size of positions 346 does not match topology 334
09:04:01:WARNING:FS01:Size of positions 346 does not match topology 334
09:04:35:WU01:FS01:0x21:Completed 4312500 out of 6250000 steps (69%)
09:06:40:WARNING:FS01:Size of positions 346 does not match topology 334
09:07:54:WU01:FS01:0x21:Completed 4375000 out of 6250000 steps (70%)
09:09:18:WARNING:FS01:Size of positions 346 does not match topology 334
09:11:12:WU01:FS01:0x21:Completed 4437500 out of 6250000 steps (71%)
09:11:57:WARNING:FS01:Size of positions 346 does not match topology 334
09:14:30:WU01:FS01:0x21:Completed 4500000 out of 6250000 steps (72%)
09:14:35:WARNING:FS01:Size of positions 346 does not match topology 334
09:17:14:WARNING:FS01:Size of positions 346 does not match topology 334
09:17:48:WU01:FS01:0x21:Completed 4562500 out of 6250000 steps (73%)
09:19:52:WARNING:FS01:Size of positions 346 does not match topology 334
09:21:06:WU01:FS01:0x21:Completed 4625000 out of 6250000 steps (74%)
09:22:36:WARNING:FS01:Size of positions 346 does not match topology 334
09:24:40:WU01:FS01:0x21:Completed 4687500 out of 6250000 steps (75%)
09:25:29:WARNING:FS01:Size of positions 346 does not match topology 334
09:28:12:WU01:FS01:0x21:Completed 4750000 out of 6250000 steps (76%)
09:28:17:WARNING:FS01:Size of positions 346 does not match topology 334
09:30:56:WARNING:FS01:Size of positions 346 does not match topology 334
09:31:30:WU01:FS01:0x21:Completed 4812500 out of 6250000 steps (77%)
09:33:33:WARNING:FS01:Size of positions 346 does not match topology 334
09:34:47:WU01:FS01:0x21:Completed 4875000 out of 6250000 steps (78%)
09:36:11:WARNING:FS01:Size of positions 346 does not match topology 334
09:38:04:WU01:FS01:0x21:Completed 4937500 out of 6250000 steps (79%)
09:38:48:WARNING:FS01:Size of positions 346 does not match topology 334
09:41:21:WU01:FS01:0x21:Completed 5000000 out of 6250000 steps (80%)
09:41:26:WARNING:FS01:Size of positions 346 does not match topology 334
09:44:13:WARNING:FS01:Size of positions 346 does not match topology 334
09:44:51:WU01:FS01:0x21:Completed 5062500 out of 6250000 steps (81%)
09:47:05:WARNING:FS01:Size of positions 346 does not match topology 334
09:48:26:WU01:FS01:0x21:Completed 5125000 out of 6250000 steps (82%)
09:49:56:WARNING:FS01:Size of positions 346 does not match topology 334
09:51:56:WU01:FS01:0x21:Completed 5187500 out of 6250000 steps (83%)
09:52:44:WARNING:FS01:Size of positions 346 does not match topology 334
09:55:30:WU01:FS01:0x21:Completed 5250000 out of 6250000 steps (84%)
09:55:35:WARNING:FS01:Size of positions 346 does not match topology 334
09:58:22:WARNING:FS01:Size of positions 346 does not match topology 334
09:59:00:WU01:FS01:0x21:Completed 5312500 out of 6250000 steps (85%)
10:01:15:WARNING:FS01:Size of positions 346 does not match topology 334
10:02:31:WU01:FS01:0x21:Completed 5375000 out of 6250000 steps (86%)
10:03:55:WARNING:FS01:Size of positions 346 does not match topology 334
10:05:48:WU01:FS01:0x21:Completed 5437500 out of 6250000 steps (87%)
10:06:32:WARNING:FS01:Size of positions 346 does not match topology 334
10:09:05:WU01:FS01:0x21:Completed 5500000 out of 6250000 steps (88%)
10:09:10:WARNING:FS01:Size of positions 346 does not match topology 334
10:11:49:WARNING:FS01:Size of positions 346 does not match topology 334
10:12:23:WU01:FS01:0x21:Completed 5562500 out of 6250000 steps (89%)
10:14:37:WARNING:FS01:Size of positions 346 does not match topology 334
10:15:57:WU01:FS01:0x21:Completed 5625000 out of 6250000 steps (90%)
10:17:22:WARNING:FS01:Size of positions 346 does not match topology 334
10:19:15:WU01:FS01:0x21:Completed 5687500 out of 6250000 steps (91%)
10:20:00:WARNING:FS01:Size of positions 346 does not match topology 334
10:22:32:WU01:FS01:0x21:Completed 5750000 out of 6250000 steps (92%)
10:22:37:WARNING:FS01:Size of positions 346 does not match topology 334
10:25:41:WARNING:FS01:Size of positions 346 does not match topology 334
10:26:30:WU01:FS01:0x21:Completed 5812500 out of 6250000 steps (93%)
10:29:27:WARNING:FS01:Size of positions 346 does not match topology 334
10:31:19:WU01:FS01:0x21:Completed 5875000 out of 6250000 steps (94%)
10:33:18:WARNING:FS01:Size of positions 346 does not match topology 334
10:33:56:Removing old file 'configs/config-20171226-080342.xml'
10:33:56:Saving configuration to config.xml
10:33:56:<config>
10:33:56:  <!-- Folding Core -->
10:33:56:  <checkpoint v='9'/>
10:33:56:  <core-priority v='low'/>
10:33:56:
10:33:56:  <!-- Network -->
10:33:56:  <proxy v=':8080'/>
10:33:56:
10:33:56:  <!-- Slot Control -->
10:33:56:  <pause-on-battery v='false'/>
10:33:56:
10:33:56:  <!-- User Information -->
10:33:56:  <passkey v='********************************'/>
10:33:56:  <team v='224497'/>
10:33:56:  <user v='kwerboom_ALL_1L83cGY1wM9qfMsptnzqdCxmPty2VNTcym'/>
10:33:56:
10:33:56:  <!-- Folding Slots -->
10:33:56:  <slot id='1' type='GPU'/>
10:33:56:</config>
10:33:58:Removing old file 'configs/config-20171226-084422.xml'
10:33:58:Saving configuration to config.xml
10:33:58:<config>
10:33:58:  <!-- Folding Core -->
10:33:58:  <checkpoint v='9'/>
10:33:58:  <core-priority v='low'/>
10:33:58:
10:33:58:  <!-- Network -->
10:33:58:  <proxy v=':8080'/>
10:33:58:
10:33:58:  <!-- Slot Control -->
10:33:58:  <pause-on-battery v='false'/>
10:33:58:
10:33:58:  <!-- User Information -->
10:33:58:  <passkey v='********************************'/>
10:33:58:  <team v='224497'/>
10:33:58:  <user v='kwerboom_ALL_1L83cGY1wM9qfMsptnzqdCxmPty2VNTcym'/>
10:33:58:
10:33:58:  <!-- Folding Slots -->
10:33:58:  <slot id='1' type='GPU'/>
10:33:58:</config>
10:35:52:WU01:FS01:0x21:Completed 5937500 out of 6250000 steps (95%)
10:36:50:WARNING:FS01:Size of positions 346 does not match topology 334
10:40:20:WU01:FS01:0x21:Completed 6000000 out of 6250000 steps (96%)
10:40:26:WARNING:FS01:Size of positions 346 does not match topology 334
10:44:16:WARNING:FS01:Size of positions 346 does not match topology 334
10:45:09:WU01:FS01:0x21:Completed 6062500 out of 6250000 steps (97%)
10:48:08:WARNING:FS01:Size of positions 346 does not match topology 334
10:50:06:WU01:FS01:0x21:Completed 6125000 out of 6250000 steps (98%)
10:52:12:WARNING:FS01:Size of positions 346 does not match topology 334
10:54:59:WU01:FS01:0x21:Completed 6187500 out of 6250000 steps (99%)
10:56:02:WARNING:FS01:Size of positions 346 does not match topology 334
10:59:48:WU01:FS01:0x21:Completed 6250000 out of 6250000 steps (100%)
10:59:49:WU01:FS01:0x21:Saving result file logfile_01.txt
10:59:49:WU01:FS01:0x21:Saving result file checkpointState.xml
10:59:50:WU01:FS01:0x21:Saving result file checkpt.crc
10:59:50:WU01:FS01:0x21:Saving result file log.txt
10:59:50:WU01:FS01:0x21:Saving result file positions.xtc
10:59:50:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
10:59:50:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:59:50:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9431 run:573 clone:1 gen:492 core:0x21 unit:0x0000023aab436c9d586fdd38df6fbe9d
10:59:50:WU01:FS01:Uploading 13.61MiB to 171.67.108.157
10:59:50:WU01:FS01:Connecting to 171.67.108.157:8080
10:59:56:WU01:FS01:Upload 3.67%
11:00:02:WU01:FS01:Upload 7.34%
11:00:08:WU01:FS01:Upload 11.02%
11:00:14:WU01:FS01:Upload 16.53%
11:00:20:WU01:FS01:Upload 17.90%
11:00:26:WU01:FS01:Upload 22.49%
11:00:32:WU01:FS01:Upload 26.17%
11:00:40:WU01:FS01:Upload 28.92%
11:00:46:WU01:FS01:Upload 32.13%
11:00:52:WU01:FS01:Upload 35.81%
11:00:59:WU01:FS01:Upload 39.48%
11:01:05:WU01:FS01:Upload 42.23%
11:01:11:WU01:FS01:Upload 45.91%
11:01:18:WU01:FS01:Upload 49.12%
11:01:26:WU01:FS01:Upload 53.25%
11:01:32:WU01:FS01:Upload 53.71%
11:01:38:WU01:FS01:Upload 59.68%
11:01:44:WU01:FS01:Upload 63.35%
11:01:50:WU01:FS01:Upload 66.10%
11:01:56:WU01:FS01:Upload 69.78%
11:02:02:WU01:FS01:Upload 73.91%
11:02:08:WU01:FS01:Upload 75.75%
11:02:14:WU01:FS01:Upload 79.88%
11:02:20:WU01:FS01:Upload 84.01%
11:02:30:WU01:FS01:Upload 85.84%
11:02:36:WU01:FS01:Upload 90.44%
11:02:44:WU01:FS01:Upload 94.57%
11:02:50:WU01:FS01:Upload 96.86%
11:03:03:WU01:FS01:Upload complete
11:03:03:WU01:FS01:Server responded WORK_ACK (400)
11:03:03:WU01:FS01:Cleaning up
kwerboom
Post by kwerboom »
Today's log file:
*********************** Log Started 2017-12-27T18:49:13Z ***********************
18:49:13:************************* Folding@home Client *************************
18:49:13:        Website: http://folding.stanford.edu/
18:49:13:      Copyright: (c) 2009-2016 Stanford University
18:49:13:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:49:13:           Args:
18:49:13:         Config: C:\Users\Keith\AppData\Roaming\FAHClient\config.xml
18:49:13:******************************** Build ********************************
18:49:13:        Version: 7.4.16
18:49:13:           Date: Jan 6 2017
18:49:13:           Time: 00:25:14
18:49:13:     Repository: Git
18:49:13:       Revision: a9e9e27dc2ee6ff01398c439677bc27f6cb74032
18:49:13:         Branch: master
18:49:13:       Compiler: Visual C++ 2008
18:49:13:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox -arch:SSE /MT
18:49:13:       Platform: win32 10
18:49:13:           Bits: 32
18:49:13:           Mode: Release
18:49:13:******************************* System ********************************
18:49:13:            CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
18:49:13:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:49:13:           CPUs: 8
18:49:13:         Memory: 15.94GiB
18:49:13:    Free Memory: 11.91GiB
18:49:13:        Threads: WINDOWS_THREADS
18:49:13:     OS Version: 6.2
18:49:13:    Has Battery: false
18:49:13:     On Battery: false
18:49:13:     UTC Offset: -6
18:49:13:            PID: 2384
18:49:13:            CWD: C:\Users\Keith\AppData\Roaming\FAHClient
18:49:13:             OS: Windows 10 Pro
18:49:13:        OS Arch: AMD64
18:49:13:           GPUs: 1
18:49:13:          GPU 0: Bus:1 Slot:0 Func:0 ATI:5 Tahiti PRO [Radeon R9 280/HD
18:49:13:                 7900/8950]
18:49:13:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:49:13:                 specified module could not be found.
18:49:13:
18:49:13:OpenCL Device 0: Platform:0 Device:0 Bus:0 Slot:0 Compute:1.2 Driver:2527.7
18:49:13:  Win32 Service: false
18:49:13:***********************************************************************
18:49:13:<config>
18:49:13:  <!-- Folding Core -->
18:49:13:  <checkpoint v='9'/>
18:49:13:  <core-priority v='low'/>
18:49:13:
18:49:13:  <!-- Network -->
18:49:13:  <proxy v=':8080'/>
18:49:13:
18:49:13:  <!-- Slot Control -->
18:49:13:  <pause-on-battery v='false'/>
18:49:13:
18:49:13:  <!-- User Information -->
18:49:13:  <passkey v='********************************'/>
18:49:13:  <team v='224497'/>
18:49:13:  <user v='kwerboom_ALL_1L83cGY1wM9qfMsptnzqdCxmPty2VNTcym'/>
18:49:13:
18:49:13:  <!-- Folding Slots -->
18:49:13:  <slot id='1' type='GPU'/>
18:49:13:</config>
18:49:13:Trying to access database...
18:49:13:Successfully acquired database lock
18:49:13:Enabled folding slot 01: READY gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950]
18:49:14:WU00:FS01:Connecting to 171.67.108.45:80
18:49:15:WU00:FS01:Assigned to work server 171.67.108.157
18:49:15:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950] from 171.67.108.157
18:49:15:WU00:FS01:Connecting to 171.67.108.157:8080
18:49:15:WU00:FS01:Downloading 5.16MiB
18:49:21:WU00:FS01:Download 8.48%
18:49:27:WU00:FS01:Download 35.12%
18:49:33:WU00:FS01:Download 56.92%
18:49:39:WU00:FS01:Download 89.61%
18:49:40:WU00:FS01:Download complete
18:49:40:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9415 run:1993 clone:0 gen:626 core:0x21 unit:0x000002d8ab436c9d585e06dbb201ed95
18:49:40:WU00:FS01:Starting
18:49:40:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 2384 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
18:49:40:WU00:FS01:Started FahCore on PID 19936
18:49:40:WU00:FS01:Core PID:16156
18:49:40:WU00:FS01:FahCore 0x21 started
18:49:41:WU00:FS01:0x21:*********************** Log Started 2017-12-27T18:49:40Z ***********************
18:49:41:WU00:FS01:0x21:Project: 9415 (Run 1993, Clone 0, Gen 626)
18:49:41:WU00:FS01:0x21:Unit: 0x000002d8ab436c9d585e06dbb201ed95
18:49:41:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
18:49:41:WU00:FS01:0x21:Machine: 1
18:49:41:WU00:FS01:0x21:Reading tar file core.xml
18:49:41:WU00:FS01:0x21:Reading tar file integrator.xml
18:49:41:WU00:FS01:0x21:Reading tar file state.xml
18:49:41:WU00:FS01:0x21:Reading tar file system.xml
18:49:41:WU00:FS01:0x21:Digital signatures verified
18:49:41:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
18:49:41:WU00:FS01:0x21:Version 0.0.18
18:49:44:WU00:FS01:0x21:Completed 0 out of 6250000 steps (0%)
18:49:44:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:52:27:WARNING:FS01:Size of positions 394 does not match topology 391
18:53:01:WU00:FS01:0x21:Completed 62500 out of 6250000 steps (1%)
18:55:07:WARNING:FS01:Size of positions 394 does not match topology 391
18:56:22:WU00:FS01:0x21:Completed 125000 out of 6250000 steps (2%)
18:57:48:WARNING:FS01:Size of positions 394 does not match topology 391
18:59:43:WU00:FS01:0x21:Completed 187500 out of 6250000 steps (3%)
19:00:28:WARNING:FS01:Size of positions 394 does not match topology 391
19:03:04:WU00:FS01:0x21:Completed 250000 out of 6250000 steps (4%)
19:03:09:WARNING:FS01:Size of positions 394 does not match topology 391
19:05:50:WARNING:FS01:Size of positions 394 does not match topology 391
19:06:25:WU00:FS01:0x21:Completed 312500 out of 6250000 steps (5%)
19:08:30:WARNING:FS01:Size of positions 394 does not match topology 391
19:09:45:WU00:FS01:0x21:Completed 375000 out of 6250000 steps (6%)
19:11:11:WARNING:FS01:Size of positions 394 does not match topology 391
19:13:06:WU00:FS01:0x21:Completed 437500 out of 6250000 steps (7%)
19:13:52:WARNING:FS01:Size of positions 394 does not match topology 391
19:16:27:WU00:FS01:0x21:Completed 500000 out of 6250000 steps (8%)
19:16:33:WARNING:FS01:Size of positions 394 does not match topology 391
19:19:13:WARNING:FS01:Size of positions 394 does not match topology 391
19:19:48:WU00:FS01:0x21:Completed 562500 out of 6250000 steps (9%)
19:21:54:WARNING:FS01:Size of positions 394 does not match topology 391
19:23:09:WU00:FS01:0x21:Completed 625000 out of 6250000 steps (10%)
19:24:34:WARNING:FS01:Size of positions 394 does not match topology 391
19:26:29:WU00:FS01:0x21:Completed 687500 out of 6250000 steps (11%)
19:27:14:WARNING:FS01:Size of positions 394 does not match topology 391
19:29:50:WU00:FS01:0x21:Completed 750000 out of 6250000 steps (12%)
19:29:55:WARNING:FS01:Size of positions 394 does not match topology 391
19:32:35:WARNING:FS01:Size of positions 394 does not match topology 391
19:33:10:WU00:FS01:0x21:Completed 812500 out of 6250000 steps (13%)
19:35:15:WARNING:FS01:Size of positions 394 does not match topology 391
19:36:30:WU00:FS01:0x21:Completed 875000 out of 6250000 steps (14%)
19:37:56:WARNING:FS01:Size of positions 394 does not match topology 391
19:39:50:WU00:FS01:0x21:Completed 937500 out of 6250000 steps (15%)
19:40:36:WARNING:FS01:Size of positions 394 does not match topology 391
19:43:11:WU00:FS01:0x21:Completed 1000000 out of 6250000 steps (16%)
19:43:16:WARNING:FS01:Size of positions 394 does not match topology 391
19:45:56:WARNING:FS01:Size of positions 394 does not match topology 391
19:46:31:WU00:FS01:0x21:Completed 1062500 out of 6250000 steps (17%)
19:48:36:WARNING:FS01:Size of positions 394 does not match topology 391
19:49:51:WU00:FS01:0x21:Completed 1125000 out of 6250000 steps (18%)
19:51:16:WARNING:FS01:Size of positions 394 does not match topology 391
19:53:11:WU00:FS01:0x21:Completed 1187500 out of 6250000 steps (19%)
19:53:56:WARNING:FS01:Size of positions 394 does not match topology 391
19:56:31:WU00:FS01:0x21:Completed 1250000 out of 6250000 steps (20%)
19:56:36:WARNING:FS01:Size of positions 394 does not match topology 391
19:59:16:WARNING:FS01:Size of positions 394 does not match topology 391
19:59:51:WU00:FS01:0x21:Completed 1312500 out of 6250000 steps (21%)
20:01:56:WARNING:FS01:Size of positions 394 does not match topology 391
20:03:11:WU00:FS01:0x21:Completed 1375000 out of 6250000 steps (22%)
20:04:36:WARNING:FS01:Size of positions 394 does not match topology 391
20:06:31:WU00:FS01:0x21:Completed 1437500 out of 6250000 steps (23%)
20:07:16:WARNING:FS01:Size of positions 394 does not match topology 391
20:09:51:WU00:FS01:0x21:Completed 1500000 out of 6250000 steps (24%)
20:09:56:WARNING:FS01:Size of positions 394 does not match topology 391
20:12:36:WARNING:FS01:Size of positions 394 does not match topology 391
20:13:12:WU00:FS01:0x21:Completed 1562500 out of 6250000 steps (25%)
20:15:17:WARNING:FS01:Size of positions 394 does not match topology 391
20:16:32:WU00:FS01:0x21:Completed 1625000 out of 6250000 steps (26%)
20:17:57:WARNING:FS01:Size of positions 394 does not match topology 391
20:19:52:WU00:FS01:0x21:Completed 1687500 out of 6250000 steps (27%)
20:20:37:WARNING:FS01:Size of positions 394 does not match topology 391
20:23:12:WU00:FS01:0x21:Completed 1750000 out of 6250000 steps (28%)
20:23:17:WARNING:FS01:Size of positions 394 does not match topology 391
20:25:57:WARNING:FS01:Size of positions 394 does not match topology 391
20:26:32:WU00:FS01:0x21:Completed 1812500 out of 6250000 steps (29%)
20:28:37:WARNING:FS01:Size of positions 394 does not match topology 391
20:29:52:WU00:FS01:0x21:Completed 1875000 out of 6250000 steps (30%)
20:31:17:WARNING:FS01:Size of positions 394 does not match topology 391
20:33:12:WU00:FS01:0x21:Completed 1937500 out of 6250000 steps (31%)
20:33:57:WARNING:FS01:Size of positions 394 does not match topology 391
20:36:32:WU00:FS01:0x21:Completed 2000000 out of 6250000 steps (32%)
20:36:37:WARNING:FS01:Size of positions 394 does not match topology 391
20:39:17:WARNING:FS01:Size of positions 394 does not match topology 391
20:39:52:WU00:FS01:0x21:Completed 2062500 out of 6250000 steps (33%)
20:41:57:WARNING:FS01:Size of positions 394 does not match topology 391
20:43:12:WU00:FS01:0x21:Completed 2125000 out of 6250000 steps (34%)
20:44:37:WARNING:FS01:Size of positions 394 does not match topology 391
20:46:32:WU00:FS01:0x21:Completed 2187500 out of 6250000 steps (35%)
20:47:17:WARNING:FS01:Size of positions 394 does not match topology 391
20:49:51:WU00:FS01:0x21:Completed 2250000 out of 6250000 steps (36%)
20:49:57:WARNING:FS01:Size of positions 394 does not match topology 391
20:52:36:WARNING:FS01:Size of positions 394 does not match topology 391
20:53:11:WU00:FS01:0x21:Completed 2312500 out of 6250000 steps (37%)
20:55:16:WARNING:FS01:Size of positions 394 does not match topology 391
20:56:30:WU00:FS01:0x21:Completed 2375000 out of 6250000 steps (38%)
20:57:56:WARNING:FS01:Size of positions 394 does not match topology 391
20:59:50:WU00:FS01:0x21:Completed 2437500 out of 6250000 steps (39%)
21:00:36:WARNING:FS01:Size of positions 394 does not match topology 391
21:03:10:WU00:FS01:0x21:Completed 2500000 out of 6250000 steps (40%)
21:03:15:WARNING:FS01:Size of positions 394 does not match topology 391
21:05:55:WARNING:FS01:Size of positions 394 does not match topology 391
21:06:30:WU00:FS01:0x21:Completed 2562500 out of 6250000 steps (41%)
21:08:35:WARNING:FS01:Size of positions 394 does not match topology 391
21:09:50:WU00:FS01:0x21:Completed 2625000 out of 6250000 steps (42%)
21:11:15:WARNING:FS01:Size of positions 394 does not match topology 391
21:13:10:WU00:FS01:0x21:Completed 2687500 out of 6250000 steps (43%)
21:13:55:WARNING:FS01:Size of positions 394 does not match topology 391
21:16:30:WU00:FS01:0x21:Completed 2750000 out of 6250000 steps (44%)
21:16:35:WARNING:FS01:Size of positions 394 does not match topology 391
21:19:15:WARNING:FS01:Size of positions 394 does not match topology 391
21:19:50:WU00:FS01:0x21:Completed 2812500 out of 6250000 steps (45%)
21:21:55:WARNING:FS01:Size of positions 394 does not match topology 391
21:23:10:WU00:FS01:0x21:Completed 2875000 out of 6250000 steps (46%)
21:24:35:WARNING:FS01:Size of positions 394 does not match topology 391
21:26:30:WU00:FS01:0x21:Completed 2937500 out of 6250000 steps (47%)
21:27:16:WARNING:FS01:Size of positions 394 does not match topology 391
21:29:51:WU00:FS01:0x21:Completed 3000000 out of 6250000 steps (48%)
21:29:56:WARNING:FS01:Size of positions 394 does not match topology 391
21:32:37:WARNING:FS01:Size of positions 394 does not match topology 391
21:33:12:WU00:FS01:0x21:Completed 3062500 out of 6250000 steps (49%)
21:35:17:WARNING:FS01:Size of positions 394 does not match topology 391
21:36:32:WU00:FS01:0x21:Completed 3125000 out of 6250000 steps (50%)
21:37:58:WARNING:FS01:Size of positions 394 does not match topology 391
21:39:53:WU00:FS01:0x21:Completed 3187500 out of 6250000 steps (51%)
21:40:38:WARNING:FS01:Size of positions 394 does not match topology 391
21:43:13:WU00:FS01:0x21:Completed 3250000 out of 6250000 steps (52%)
21:43:18:WARNING:FS01:Size of positions 394 does not match topology 391
21:45:59:WARNING:FS01:Size of positions 394 does not match topology 391
21:46:34:WU00:FS01:0x21:Completed 3312500 out of 6250000 steps (53%)
21:48:39:WARNING:FS01:Size of positions 394 does not match topology 391
21:49:54:WU00:FS01:0x21:Completed 3375000 out of 6250000 steps (54%)
21:51:19:WARNING:FS01:Size of positions 394 does not match topology 391
21:53:14:WU00:FS01:0x21:Completed 3437500 out of 6250000 steps (55%)
21:54:00:WARNING:FS01:Size of positions 394 does not match topology 391
21:56:35:WU00:FS01:0x21:Completed 3500000 out of 6250000 steps (56%)
21:56:40:WARNING:FS01:Size of positions 394 does not match topology 391
21:59:20:WARNING:FS01:Size of positions 394 does not match topology 391
21:59:56:WU00:FS01:0x21:Completed 3562500 out of 6250000 steps (57%)
22:02:01:WARNING:FS01:Size of positions 394 does not match topology 391
22:03:16:WU00:FS01:0x21:Completed 3625000 out of 6250000 steps (58%)
22:04:41:WARNING:FS01:Size of positions 394 does not match topology 391
22:06:36:WU00:FS01:0x21:Completed 3687500 out of 6250000 steps (59%)
22:07:21:WARNING:FS01:Size of positions 394 does not match topology 391
22:09:56:WU00:FS01:0x21:Completed 3750000 out of 6250000 steps (60%)
22:10:01:WARNING:FS01:Size of positions 394 does not match topology 391
22:12:41:WARNING:FS01:Size of positions 394 does not match topology 391
22:13:16:WU00:FS01:0x21:Completed 3812500 out of 6250000 steps (61%)
22:15:21:WARNING:FS01:Size of positions 394 does not match topology 391
22:16:36:WU00:FS01:0x21:Completed 3875000 out of 6250000 steps (62%)
22:18:02:WARNING:FS01:Size of positions 394 does not match topology 391
22:19:57:WU00:FS01:0x21:Completed 3937500 out of 6250000 steps (63%)
22:20:42:WARNING:FS01:Size of positions 394 does not match topology 391
22:23:17:WU00:FS01:0x21:Completed 4000000 out of 6250000 steps (64%)
22:23:22:WARNING:FS01:Size of positions 394 does not match topology 391
22:26:03:WARNING:FS01:Size of positions 394 does not match topology 391
22:26:38:WU00:FS01:0x21:Completed 4062500 out of 6250000 steps (65%)
22:28:44:WARNING:FS01:Size of positions 394 does not match topology 391
22:29:59:WU00:FS01:0x21:Completed 4125000 out of 6250000 steps (66%)
22:31:24:WARNING:FS01:Size of positions 394 does not match topology 391
22:33:20:WU00:FS01:0x21:Completed 4187500 out of 6250000 steps (67%)
22:34:05:WARNING:FS01:Size of positions 394 does not match topology 391
22:36:40:WU00:FS01:0x21:Completed 4250000 out of 6250000 steps (68%)
22:36:46:WARNING:FS01:Size of positions 394 does not match topology 391
22:39:26:WARNING:FS01:Size of positions 394 does not match topology 391
22:40:02:WU00:FS01:0x21:Completed 4312500 out of 6250000 steps (69%)
22:42:07:WARNING:FS01:Size of positions 394 does not match topology 391
22:43:23:WU00:FS01:0x21:Completed 4375000 out of 6250000 steps (70%)
22:44:48:WARNING:FS01:Size of positions 394 does not match topology 391
22:46:43:WU00:FS01:0x21:Completed 4437500 out of 6250000 steps (71%)
22:47:28:WARNING:FS01:Size of positions 394 does not match topology 391
22:50:03:WU00:FS01:0x21:Completed 4500000 out of 6250000 steps (72%)
22:50:08:WARNING:FS01:Size of positions 394 does not match topology 391
22:52:49:WARNING:FS01:Size of positions 394 does not match topology 391
22:53:24:WU00:FS01:0x21:Completed 4562500 out of 6250000 steps (73%)
22:55:30:WARNING:FS01:Size of positions 394 does not match topology 391
22:56:46:WU00:FS01:0x21:Completed 4625000 out of 6250000 steps (74%)
22:58:12:WARNING:FS01:Size of positions 394 does not match topology 391
23:00:08:WU00:FS01:0x21:Completed 4687500 out of 6250000 steps (75%)
23:00:53:WARNING:FS01:Size of positions 394 does not match topology 391
23:03:29:WU00:FS01:0x21:Completed 4750000 out of 6250000 steps (76%)
23:03:34:WARNING:FS01:Size of positions 394 does not match topology 391
23:06:16:WARNING:FS01:Size of positions 394 does not match topology 391
23:06:51:WU00:FS01:0x21:Completed 4812500 out of 6250000 steps (77%)
23:08:57:WARNING:FS01:Size of positions 394 does not match topology 391
23:10:12:WU00:FS01:0x21:Completed 4875000 out of 6250000 steps (78%)
23:11:38:WARNING:FS01:Size of positions 394 does not match topology 391
23:13:33:WU00:FS01:0x21:Completed 4937500 out of 6250000 steps (79%)
23:14:18:WARNING:FS01:Size of positions 394 does not match topology 391
23:16:54:WU00:FS01:0x21:Completed 5000000 out of 6250000 steps (80%)
23:16:59:WARNING:FS01:Size of positions 394 does not match topology 391
23:19:40:WARNING:FS01:Size of positions 394 does not match topology 391
23:20:15:WU00:FS01:0x21:Completed 5062500 out of 6250000 steps (81%)
23:22:21:WARNING:FS01:Size of positions 394 does not match topology 391
23:23:36:WU00:FS01:0x21:Completed 5125000 out of 6250000 steps (82%)
23:25:02:WARNING:FS01:Size of positions 394 does not match topology 391
23:26:57:WU00:FS01:0x21:Completed 5187500 out of 6250000 steps (83%)
23:27:42:WARNING:FS01:Size of positions 394 does not match topology 391
23:30:18:WU00:FS01:0x21:Completed 5250000 out of 6250000 steps (84%)
23:30:23:WARNING:FS01:Size of positions 394 does not match topology 391
23:33:03:WARNING:FS01:Size of positions 394 does not match topology 391
23:33:39:WU00:FS01:0x21:Completed 5312500 out of 6250000 steps (85%)
23:35:44:WARNING:FS01:Size of positions 394 does not match topology 391
23:36:59:WU00:FS01:0x21:Completed 5375000 out of 6250000 steps (86%)
23:38:25:WARNING:FS01:Size of positions 394 does not match topology 391
23:40:20:WU00:FS01:0x21:Completed 5437500 out of 6250000 steps (87%)
23:41:05:WARNING:FS01:Size of positions 394 does not match topology 391
23:43:41:WU00:FS01:0x21:Completed 5500000 out of 6250000 steps (88%)
23:43:46:WARNING:FS01:Size of positions 394 does not match topology 391
23:46:26:WARNING:FS01:Size of positions 394 does not match topology 391
23:47:01:WU00:FS01:0x21:Completed 5562500 out of 6250000 steps (89%)
23:49:07:WARNING:FS01:Size of positions 394 does not match topology 391
23:50:22:WU00:FS01:0x21:Completed 5625000 out of 6250000 steps (90%)
23:51:47:WARNING:FS01:Size of positions 394 does not match topology 391
23:53:42:WU00:FS01:0x21:Completed 5687500 out of 6250000 steps (91%)
23:54:27:WARNING:FS01:Size of positions 394 does not match topology 391
23:57:02:WU00:FS01:0x21:Completed 5750000 out of 6250000 steps (92%)
23:57:07:WARNING:FS01:Size of positions 394 does not match topology 391
23:59:48:WARNING:FS01:Size of positions 394 does not match topology 391
00:00:23:WU00:FS01:0x21:Completed 5812500 out of 6250000 steps (93%)
00:02:29:WARNING:FS01:Size of positions 394 does not match topology 391
00:03:44:WU00:FS01:0x21:Completed 5875000 out of 6250000 steps (94%)
00:05:09:WARNING:FS01:Size of positions 394 does not match topology 391
00:07:05:WU00:FS01:0x21:Completed 5937500 out of 6250000 steps (95%)
00:07:50:WARNING:FS01:Size of positions 394 does not match topology 391
00:10:26:WU00:FS01:0x21:Completed 6000000 out of 6250000 steps (96%)
00:10:31:WARNING:FS01:Size of positions 394 does not match topology 391
00:13:11:WARNING:FS01:Size of positions 394 does not match topology 391
00:13:46:WU00:FS01:0x21:Completed 6062500 out of 6250000 steps (97%)
00:15:51:WARNING:FS01:Size of positions 394 does not match topology 391
00:17:06:WU00:FS01:0x21:Completed 6125000 out of 6250000 steps (98%)
00:18:32:WARNING:FS01:Size of positions 394 does not match topology 391
00:20:27:WU00:FS01:0x21:Completed 6187500 out of 6250000 steps (99%)
00:20:28:WU01:FS01:Connecting to 171.67.108.45:80
00:20:28:WU01:FS01:Assigned to work server 171.67.108.157
00:20:28:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950] from 171.67.108.157
00:20:28:WU01:FS01:Connecting to 171.67.108.157:8080
00:20:29:WU01:FS01:Downloading 5.15MiB
00:20:33:WU01:FS01:Download complete
00:20:33:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9414 run:2330 clone:0 gen:746 core:0x21 unit:0x00000364ab436c9d585e06a2ff0d50c3
00:21:13:WARNING:FS01:Size of positions 394 does not match topology 391
00:23:48:WU00:FS01:0x21:Completed 6250000 out of 6250000 steps (100%)
00:23:49:WU00:FS01:0x21:Saving result file logfile_01.txt
00:23:49:WU00:FS01:0x21:Saving result file checkpointState.xml
00:23:49:WU00:FS01:0x21:Saving result file checkpt.crc
00:23:49:WU00:FS01:0x21:Saving result file log.txt
00:23:49:WU00:FS01:0x21:Saving result file positions.xtc
00:23:49:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
00:23:49:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:23:49:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9415 run:1993 clone:0 gen:626 core:0x21 unit:0x000002d8ab436c9d585e06dbb201ed95
00:23:49:WU00:FS01:Uploading 7.77MiB to 171.67.108.157
00:23:49:WU01:FS01:Starting
00:23:49:WU00:FS01:Connecting to 171.67.108.157:8080
00:23:49:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 2384 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
00:23:49:WU01:FS01:Started FahCore on PID 15324
00:23:49:WU01:FS01:Core PID:4440
00:23:49:WU01:FS01:FahCore 0x21 started
00:23:50:WU01:FS01:0x21:*********************** Log Started 2017-12-28T00:23:50Z ***********************
00:23:50:WU01:FS01:0x21:Project: 9414 (Run 2330, Clone 0, Gen 746)
00:23:50:WU01:FS01:0x21:Unit: 0x00000364ab436c9d585e06a2ff0d50c3
00:23:50:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:23:50:WU01:FS01:0x21:Machine: 1
00:23:50:WU01:FS01:0x21:Reading tar file core.xml
00:23:50:WU01:FS01:0x21:Reading tar file integrator.xml
00:23:50:WU01:FS01:0x21:Reading tar file state.xml
00:23:50:WU01:FS01:0x21:Reading tar file system.xml
00:23:50:WU01:FS01:0x21:Digital signatures verified
00:23:50:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:23:50:WU01:FS01:0x21:Version 0.0.18
00:23:52:WU01:FS01:0x21:Completed 0 out of 6250000 steps (0%)
00:23:52:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:23:55:WU00:FS01:Upload 6.43%
00:24:01:WU00:FS01:Upload 18.49%
00:24:09:WU00:FS01:Upload 22.52%
00:24:15:WU00:FS01:Upload 30.56%
00:24:24:WU00:FS01:Upload 36.99%
00:24:30:WU00:FS01:Upload 45.83%
00:24:36:WU00:FS01:Upload 52.27%
00:24:42:WU00:FS01:Upload 58.70%
00:24:48:WU00:FS01:Upload 65.13%
00:24:54:WU00:FS01:Upload 71.57%
00:25:00:WU00:FS01:Upload 78.80%
00:25:12:WU00:FS01:Upload 83.63%
00:25:18:WU00:FS01:Upload 91.67%
00:25:25:WU00:FS01:Upload 97.30%
00:25:35:WU00:FS01:Upload complete
00:25:35:WU00:FS01:Server responded WORK_ACK (400)
00:25:35:WU00:FS01:Final credit estimate, 24040.00 points
00:25:35:WU00:FS01:Cleaning up
00:26:37:WARNING:FS01:Size of positions 392 does not match topology 389
00:27:11:WU01:FS01:0x21:Completed 62500 out of 6250000 steps (1%)
00:29:16:WARNING:FS01:Size of positions 392 does not match topology 389
00:30:30:WU01:FS01:0x21:Completed 125000 out of 6250000 steps (2%)
00:31:55:WARNING:FS01:Size of positions 392 does not match topology 389
00:33:50:WU01:FS01:0x21:Completed 187500 out of 6250000 steps (3%)
00:34:35:WARNING:FS01:Size of positions 392 does not match topology 389
00:37:09:WU01:FS01:0x21:Completed 250000 out of 6250000 steps (4%)
00:37:14:WARNING:FS01:Size of positions 392 does not match topology 389
00:39:54:WARNING:FS01:Size of positions 392 does not match topology 389
00:40:29:WU01:FS01:0x21:Completed 312500 out of 6250000 steps (5%)
00:42:33:WARNING:FS01:Size of positions 392 does not match topology 389
00:43:48:WU01:FS01:0x21:Completed 375000 out of 6250000 steps (6%)
00:45:13:WARNING:FS01:Size of positions 392 does not match topology 389
00:47:07:WU01:FS01:0x21:Completed 437500 out of 6250000 steps (7%)
00:47:52:WARNING:FS01:Size of positions 392 does not match topology 389
******************************* Date: 2017-12-28 *******************************
00:50:26:WU01:FS01:0x21:Completed 500000 out of 6250000 steps (8%)
00:50:31:WARNING:FS01:Size of positions 392 does not match topology 389
00:53:10:WARNING:FS01:Size of positions 392 does not match topology 389
00:53:45:WU01:FS01:0x21:Completed 562500 out of 6250000 steps (9%)
00:55:49:WARNING:FS01:Size of positions 392 does not match topology 389
00:57:04:WU01:FS01:0x21:Completed 625000 out of 6250000 steps (10%)
00:58:29:WARNING:FS01:Size of positions 392 does not match topology 389
01:00:23:WU01:FS01:0x21:Completed 687500 out of 6250000 steps (11%)
01:01:08:WARNING:FS01:Size of positions 392 does not match topology 389
01:03:42:WU01:FS01:0x21:Completed 750000 out of 6250000 steps (12%)
01:03:47:WARNING:FS01:Size of positions 392 does not match topology 389
01:06:26:WARNING:FS01:Size of positions 392 does not match topology 389
01:07:01:WU01:FS01:0x21:Completed 812500 out of 6250000 steps (13%)
01:09:05:WARNING:FS01:Size of positions 392 does not match topology 389
01:10:19:WU01:FS01:0x21:Completed 875000 out of 6250000 steps (14%)
01:11:42:WARNING:FS01:Size of positions 392 does not match topology 389
01:13:36:WU01:FS01:0x21:Completed 937500 out of 6250000 steps (15%)
01:14:21:WARNING:FS01:Size of positions 392 does not match topology 389
01:16:54:WU01:FS01:0x21:Completed 1000000 out of 6250000 steps (16%)
01:16:59:WARNING:FS01:Size of positions 392 does not match topology 389
01:19:37:WARNING:FS01:Size of positions 392 does not match topology 389
01:20:12:WU01:FS01:0x21:Completed 1062500 out of 6250000 steps (17%)
01:22:16:WARNING:FS01:Size of positions 392 does not match topology 389
01:23:30:WU01:FS01:0x21:Completed 1125000 out of 6250000 steps (18%)
01:24:54:WARNING:FS01:Size of positions 392 does not match topology 389
01:26:48:WU01:FS01:0x21:Completed 1187500 out of 6250000 steps (19%)
01:27:33:WARNING:FS01:Size of positions 392 does not match topology 389
01:30:06:WU01:FS01:0x21:Completed 1250000 out of 6250000 steps (20%)
01:30:11:WARNING:FS01:Size of positions 392 does not match topology 389
01:32:50:WARNING:FS01:Size of positions 392 does not match topology 389
01:33:25:WU01:FS01:0x21:Completed 1312500 out of 6250000 steps (21%)
01:35:28:WARNING:FS01:Size of positions 392 does not match topology 389
01:36:42:WU01:FS01:0x21:Completed 1375000 out of 6250000 steps (22%)
01:38:07:WARNING:FS01:Size of positions 392 does not match topology 389
01:40:01:WU01:FS01:0x21:Completed 1437500 out of 6250000 steps (23%)
01:40:45:WARNING:FS01:Size of positions 392 does not match topology 389
01:43:17:WU01:FS01:0x21:Completed 1500000 out of 6250000 steps (24%)
01:43:22:WARNING:FS01:Size of positions 392 does not match topology 389
01:45:59:WARNING:FS01:Size of positions 392 does not match topology 389
01:46:33:WU01:FS01:0x21:Completed 1562500 out of 6250000 steps (25%)
01:48:36:WARNING:FS01:Size of positions 392 does not match topology 389
01:49:49:WU01:FS01:0x21:Completed 1625000 out of 6250000 steps (26%)
01:51:13:WARNING:FS01:Size of positions 392 does not match topology 389
01:53:05:WU01:FS01:0x21:Completed 1687500 out of 6250000 steps (27%)
01:53:49:WARNING:FS01:Size of positions 392 does not match topology 389
01:56:23:WU01:FS01:0x21:Completed 1750000 out of 6250000 steps (28%)
01:56:28:WARNING:FS01:Size of positions 392 does not match topology 389
01:59:07:WARNING:FS01:Size of positions 392 does not match topology 389
01:59:42:WU01:FS01:0x21:Completed 1812500 out of 6250000 steps (29%)
02:01:46:WARNING:FS01:Size of positions 392 does not match topology 389
02:03:01:WU01:FS01:0x21:Completed 1875000 out of 6250000 steps (30%)
02:04:25:WARNING:FS01:Size of positions 392 does not match topology 389
02:06:19:WU01:FS01:0x21:Completed 1937500 out of 6250000 steps (31%)
02:07:04:WARNING:FS01:Size of positions 392 does not match topology 389
02:09:38:WU01:FS01:0x21:Completed 2000000 out of 6250000 steps (32%)
02:09:43:WARNING:FS01:Size of positions 392 does not match topology 389
02:12:22:WARNING:FS01:Size of positions 392 does not match topology 389
02:12:57:WU01:FS01:0x21:Completed 2062500 out of 6250000 steps (33%)
02:15:01:WARNING:FS01:Size of positions 392 does not match topology 389
02:16:15:WU01:FS01:0x21:Completed 2125000 out of 6250000 steps (34%)
02:17:39:WARNING:FS01:Size of positions 392 does not match topology 389
02:19:33:WU01:FS01:0x21:Completed 2187500 out of 6250000 steps (35%)
02:20:17:WARNING:FS01:Size of positions 392 does not match topology 389
02:22:51:WU01:FS01:0x21:Completed 2250000 out of 6250000 steps (36%)
02:22:56:WARNING:FS01:Size of positions 392 does not match topology 389
02:25:35:WARNING:FS01:Size of positions 392 does not match topology 389
02:26:09:WU01:FS01:0x21:Completed 2312500 out of 6250000 steps (37%)
02:28:13:WARNING:FS01:Size of positions 392 does not match topology 389
02:29:28:WU01:FS01:0x21:Completed 2375000 out of 6250000 steps (38%)
02:30:52:WARNING:FS01:Size of positions 392 does not match topology 389
02:32:46:WU01:FS01:0x21:Completed 2437500 out of 6250000 steps (39%)
02:33:30:WARNING:FS01:Size of positions 392 does not match topology 389
02:36:01:WU01:FS01:0x21:Completed 2500000 out of 6250000 steps (40%)
02:36:06:WARNING:FS01:Size of positions 392 does not match topology 389
02:38:44:WARNING:FS01:Size of positions 392 does not match topology 389
02:39:19:WU01:FS01:0x21:Completed 2562500 out of 6250000 steps (41%)
02:41:22:WARNING:FS01:Size of positions 392 does not match topology 389
02:42:36:WU01:FS01:0x21:Completed 2625000 out of 6250000 steps (42%)
02:44:00:WARNING:FS01:Size of positions 392 does not match topology 389
02:45:54:WU01:FS01:0x21:Completed 2687500 out of 6250000 steps (43%)
02:46:39:WARNING:FS01:Size of positions 392 does not match topology 389
02:46:49:FS01:Paused
02:46:49:FS01:Shutting core down
02:46:49:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 4440
02:46:49:WU01:FS01:0x21:Exiting, please wait. . .
02:46:50:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
02:47:03:Removing old file 'configs/config-20171226-092058.xml'
02:47:03:Saving configuration to config.xml
02:47:03:<config>
02:47:03:  <!-- Folding Core -->
02:47:03:  <checkpoint v='9'/>
02:47:03:  <core-priority v='low'/>
02:47:03:
02:47:03:  <!-- Network -->
02:47:03:  <proxy v=':8080'/>
02:47:03:
02:47:03:  <!-- Slot Control -->
02:47:03:  <pause-on-battery v='false'/>
02:47:03:
02:47:03:  <!-- User Information -->
02:47:03:  <passkey v='********************************'/>
02:47:03:  <team v='224497'/>
02:47:03:  <user v='kwerboom_ALL_1L83cGY1wM9qfMsptnzqdCxmPty2VNTcym'/>
02:47:03:
02:47:03:  <!-- Folding Slots -->
02:47:03:  <slot id='1' type='GPU'>
02:47:03:    <paused v='true'/>
02:47:03:  </slot>
02:47:03:</config>
03:19:52:FS01:Unpaused
03:19:52:WU01:FS01:Starting
03:19:52:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 2384 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
03:19:52:WU01:FS01:Started FahCore on PID 13616
03:19:52:WU01:FS01:Core PID:1856
03:19:52:WU01:FS01:FahCore 0x21 started
03:19:53:WARNING:FS01:Size of positions 392 does not match topology 389
03:19:53:WU01:FS01:0x21:*********************** Log Started 2017-12-28T03:19:52Z ***********************
03:19:53:WU01:FS01:0x21:Project: 9414 (Run 2330, Clone 0, Gen 746)
03:19:53:WU01:FS01:0x21:Unit: 0x00000364ab436c9d585e06a2ff0d50c3
03:19:53:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:19:53:WU01:FS01:0x21:Machine: 1
03:19:53:WU01:FS01:0x21:Digital signatures verified
03:19:53:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:19:53:WU01:FS01:0x21:Version 0.0.18
03:19:53:WU01:FS01:0x21:  Found a checkpoint file
03:19:55:WU01:FS01:0x21:Completed 2700000 out of 6250000 steps (43%)
03:19:55:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:20:36:Removing old file 'configs/config-20171226-093916.xml'
03:20:36:Saving configuration to config.xml
03:20:36:<config>
03:20:36:  <!-- Folding Core -->
03:20:36:  <checkpoint v='9'/>
03:20:36:  <core-priority v='low'/>
03:20:36:
03:20:36:  <!-- Network -->
03:20:36:  <proxy v=':8080'/>
03:20:36:
03:20:36:  <!-- Slot Control -->
03:20:36:  <pause-on-battery v='false'/>
03:20:36:
03:20:36:  <!-- User Information -->
03:20:36:  <passkey v='********************************'/>
03:20:36:  <team v='224497'/>
03:20:36:  <user v='kwerboom_ALL_1L83cGY1wM9qfMsptnzqdCxmPty2VNTcym'/>
03:20:36:
03:20:36:  <!-- Folding Slots -->
03:20:36:  <slot id='1' type='GPU'/>
03:20:36:</config>
03:22:33:WU01:FS01:0x21:Completed 2750000 out of 6250000 steps (44%)
03:22:38:WARNING:FS01:Size of positions 392 does not match topology 389
03:25:16:WARNING:FS01:Size of positions 392 does not match topology 389
03:25:50:WU01:FS01:0x21:Completed 2812500 out of 6250000 steps (45%)
03:27:54:WARNING:FS01:Size of positions 392 does not match topology 389
03:29:08:WU01:FS01:0x21:Completed 2875000 out of 6250000 steps (46%)
03:30:32:WARNING:FS01:Size of positions 392 does not match topology 389
03:32:25:WU01:FS01:0x21:Completed 2937500 out of 6250000 steps (47%)
03:33:09:WARNING:FS01:Size of positions 392 does not match topology 389
03:35:41:WU01:FS01:0x21:Completed 3000000 out of 6250000 steps (48%)
03:35:46:WARNING:FS01:Size of positions 392 does not match topology 389
03:38:23:WARNING:FS01:Size of positions 392 does not match topology 389
03:38:57:WU01:FS01:0x21:Completed 3062500 out of 6250000 steps (49%)
03:41:00:WARNING:FS01:Size of positions 392 does not match topology 389
03:42:13:WU01:FS01:0x21:Completed 3125000 out of 6250000 steps (50%)
03:43:36:WARNING:FS01:Size of positions 392 does not match topology 389
03:45:28:WU01:FS01:0x21:Completed 3187500 out of 6250000 steps (51%)
03:46:12:WARNING:FS01:Size of positions 392 does not match topology 389
03:48:43:WU01:FS01:0x21:Completed 3250000 out of 6250000 steps (52%)
03:48:48:WARNING:FS01:Size of positions 392 does not match topology 389
03:51:23:WARNING:FS01:Size of positions 392 does not match topology 389
03:51:57:WU01:FS01:0x21:Completed 3312500 out of 6250000 steps (53%)
03:53:59:WARNING:FS01:Size of positions 392 does not match topology 389
03:55:11:WU01:FS01:0x21:Completed 3375000 out of 6250000 steps (54%)
03:56:34:WARNING:FS01:Size of positions 392 does not match topology 389
03:58:26:WU01:FS01:0x21:Completed 3437500 out of 6250000 steps (55%)
03:59:10:WARNING:FS01:Size of positions 392 does not match topology 389
04:01:42:WU01:FS01:0x21:Completed 3500000 out of 6250000 steps (56%)
04:01:47:WARNING:FS01:Size of positions 392 does not match topology 389
04:04:24:WARNING:FS01:Size of positions 392 does not match topology 389
04:04:58:WU01:FS01:0x21:Completed 3562500 out of 6250000 steps (57%)
04:07:01:WARNING:FS01:Size of positions 392 does not match topology 389
04:08:14:WU01:FS01:0x21:Completed 3625000 out of 6250000 steps (58%)
04:09:38:WARNING:FS01:Size of positions 392 does not match topology 389
04:11:31:WU01:FS01:0x21:Completed 3687500 out of 6250000 steps (59%)
04:12:15:WARNING:FS01:Size of positions 392 does not match topology 389
04:14:47:WU01:FS01:0x21:Completed 3750000 out of 6250000 steps (60%)
04:14:52:WARNING:FS01:Size of positions 392 does not match topology 389
04:17:29:WARNING:FS01:Size of positions 392 does not match topology 389
04:18:03:WU01:FS01:0x21:Completed 3812500 out of 6250000 steps (61%)
04:20:06:WARNING:FS01:Size of positions 392 does not match topology 389
04:21:20:WU01:FS01:0x21:Completed 3875000 out of 6250000 steps (62%)
04:22:43:WARNING:FS01:Size of positions 392 does not match topology 389
04:24:35:WU01:FS01:0x21:Completed 3937500 out of 6250000 steps (63%)
04:25:20:WARNING:FS01:Size of positions 392 does not match topology 389
04:27:50:WU01:FS01:0x21:Completed 4000000 out of 6250000 steps (64%)
04:27:55:WARNING:FS01:Size of positions 392 does not match topology 389
04:30:31:WARNING:FS01:Size of positions 392 does not match topology 389
04:31:05:WU01:FS01:0x21:Completed 4062500 out of 6250000 steps (65%)
04:33:06:WARNING:FS01:Size of positions 392 does not match topology 389
04:34:19:WU01:FS01:0x21:Completed 4125000 out of 6250000 steps (66%)
04:35:42:WARNING:FS01:Size of positions 392 does not match topology 389
04:37:34:WU01:FS01:0x21:Completed 4187500 out of 6250000 steps (67%)
04:38:18:WARNING:FS01:Size of positions 392 does not match topology 389
04:40:52:WU01:FS01:0x21:Completed 4250000 out of 6250000 steps (68%)
04:40:57:WARNING:FS01:Size of positions 392 does not match topology 389
04:43:52:WARNING:FS01:Size of positions 392 does not match topology 389
04:44:30:WU01:FS01:0x21:Completed 4312500 out of 6250000 steps (69%)
04:46:36:WARNING:FS01:Size of positions 392 does not match topology 389
04:47:50:WU01:FS01:0x21:Completed 4375000 out of 6250000 steps (70%)
04:49:13:WARNING:FS01:Size of positions 392 does not match topology 389
04:51:05:WU01:FS01:0x21:Completed 4437500 out of 6250000 steps (71%)
04:51:49:WARNING:FS01:Size of positions 392 does not match topology 389
04:54:20:WU01:FS01:0x21:Completed 4500000 out of 6250000 steps (72%)
04:54:25:WARNING:FS01:Size of positions 392 does not match topology 389
04:57:01:WARNING:FS01:Size of positions 392 does not match topology 389
04:57:36:WU01:FS01:0x21:Completed 4562500 out of 6250000 steps (73%)
04:59:38:WARNING:FS01:Size of positions 392 does not match topology 389
05:00:51:WU01:FS01:0x21:Completed 4625000 out of 6250000 steps (74%)
05:02:14:WARNING:FS01:Size of positions 392 does not match topology 389
05:04:06:WU01:FS01:0x21:Completed 4687500 out of 6250000 steps (75%)
05:04:50:WARNING:FS01:Size of positions 392 does not match topology 389
05:07:22:WU01:FS01:0x21:Completed 4750000 out of 6250000 steps (76%)
05:07:27:WARNING:FS01:Size of positions 392 does not match topology 389
05:10:03:WARNING:FS01:Size of positions 392 does not match topology 389
05:10:38:WU01:FS01:0x21:Completed 4812500 out of 6250000 steps (77%)
05:12:40:WARNING:FS01:Size of positions 392 does not match topology 389
05:13:53:WU01:FS01:0x21:Completed 4875000 out of 6250000 steps (78%)
05:15:16:WARNING:FS01:Size of positions 392 does not match topology 389
05:17:08:WU01:FS01:0x21:Completed 4937500 out of 6250000 steps (79%)
05:17:53:WARNING:FS01:Size of positions 392 does not match topology 389
05:20:24:WU01:FS01:0x21:Completed 5000000 out of 6250000 steps (80%)
05:20:29:WARNING:FS01:Size of positions 392 does not match topology 389
05:23:06:WARNING:FS01:Size of positions 392 does not match topology 389
05:23:40:WU01:FS01:0x21:Completed 5062500 out of 6250000 steps (81%)
05:25:42:WARNING:FS01:Size of positions 392 does not match topology 389
05:26:55:WU01:FS01:0x21:Completed 5125000 out of 6250000 steps (82%)
05:28:18:WARNING:FS01:Size of positions 392 does not match topology 389
05:30:10:WU01:FS01:0x21:Completed 5187500 out of 6250000 steps (83%)
05:30:54:WARNING:FS01:Size of positions 392 does not match topology 389
05:33:25:WU01:FS01:0x21:Completed 5250000 out of 6250000 steps (84%)
05:33:30:WARNING:FS01:Size of positions 392 does not match topology 389
05:36:06:WARNING:FS01:Size of positions 392 does not match topology 389
05:36:40:WU01:FS01:0x21:Completed 5312500 out of 6250000 steps (85%)
05:38:43:WARNING:FS01:Size of positions 392 does not match topology 389
05:39:56:WU01:FS01:0x21:Completed 5375000 out of 6250000 steps (86%)
05:41:19:WARNING:FS01:Size of positions 392 does not match topology 389
05:43:11:WU01:FS01:0x21:Completed 5437500 out of 6250000 steps (87%)
05:43:55:WARNING:FS01:Size of positions 392 does not match topology 389
05:46:44:WU01:FS01:0x21:Completed 5500000 out of 6250000 steps (88%)
05:46:49:WARNING:FS01:Size of positions 392 does not match topology 389
05:49:43:WARNING:FS01:Size of positions 392 does not match topology 389
05:50:22:WU01:FS01:0x21:Completed 5562500 out of 6250000 steps (89%)
05:52:36:WARNING:FS01:Size of positions 392 does not match topology 389
05:53:55:WU01:FS01:0x21:Completed 5625000 out of 6250000 steps (90%)
05:55:27:WARNING:FS01:Size of positions 392 does not match topology 389
05:57:32:WU01:FS01:0x21:Completed 5687500 out of 6250000 steps (91%)
05:58:20:WARNING:FS01:Size of positions 392 does not match topology 389
06:01:10:WU01:FS01:0x21:Completed 5750000 out of 6250000 steps (92%)
06:01:15:WARNING:FS01:Size of positions 392 does not match topology 389
06:04:07:WARNING:FS01:Size of positions 392 does not match topology 389
06:04:46:WU01:FS01:0x21:Completed 5812500 out of 6250000 steps (93%)
06:07:02:WARNING:FS01:Size of positions 392 does not match topology 389
06:08:24:WU01:FS01:0x21:Completed 5875000 out of 6250000 steps (94%)
06:09:57:WARNING:FS01:Size of positions 392 does not match topology 389
06:11:49:WU01:FS01:0x21:Completed 5937500 out of 6250000 steps (95%)
06:12:33:WARNING:FS01:Size of positions 392 does not match topology 389
06:15:04:WU01:FS01:0x21:Completed 6000000 out of 6250000 steps (96%)
06:15:09:WARNING:FS01:Size of positions 392 does not match topology 389
06:17:45:WARNING:FS01:Size of positions 392 does not match topology 389
06:18:20:WU01:FS01:0x21:Completed 6062500 out of 6250000 steps (97%)
06:20:22:WARNING:FS01:Size of positions 392 does not match topology 389
06:21:39:WU01:FS01:0x21:Completed 6125000 out of 6250000 steps (98%)
06:23:11:WARNING:FS01:Size of positions 392 does not match topology 389
06:25:10:WU01:FS01:0x21:Completed 6187500 out of 6250000 steps (99%)
06:25:10:WU00:FS01:Connecting to 171.67.108.45:80
06:25:10:WU00:FS01:Assigned to work server 171.67.108.157
06:25:10:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950] from 171.67.108.157
06:25:10:WU00:FS01:Connecting to 171.67.108.157:8080
06:25:11:WU00:FS01:Downloading 5.16MiB
06:25:15:WU00:FS01:Download complete
06:25:16:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9415 run:1342 clone:3 gen:191 core:0x21 unit:0x000000e1ab436c9d585e06d5dc3f4003
06:25:54:WARNING:FS01:Size of positions 392 does not match topology 389
06:28:24:WU01:FS01:0x21:Completed 6250000 out of 6250000 steps (100%)
06:28:25:WU01:FS01:0x21:Saving result file logfile_01.txt
06:28:25:WU01:FS01:0x21:Saving result file checkpointState.xml
06:28:25:WU01:FS01:0x21:Saving result file checkpt.crc
06:28:25:WU01:FS01:0x21:Saving result file log.txt
06:28:25:WU01:FS01:0x21:Saving result file positions.xtc
06:28:25:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
06:28:25:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:28:26:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9414 run:2330 clone:0 gen:746 core:0x21 unit:0x00000364ab436c9d585e06a2ff0d50c3
06:28:26:WU01:FS01:Uploading 7.77MiB to 171.67.108.157
06:28:26:WU01:FS01:Connecting to 171.67.108.157:8080
06:28:26:WU00:FS01:Starting
06:28:26:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 2384 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
06:28:26:WU00:FS01:Started FahCore on PID 17104
06:28:26:WU00:FS01:Core PID:19092
06:28:26:WU00:FS01:FahCore 0x21 started
06:28:26:WU00:FS01:0x21:*********************** Log Started 2017-12-28T06:28:26Z ***********************
06:28:26:WU00:FS01:0x21:Project: 9415 (Run 1342, Clone 3, Gen 191)
06:28:26:WU00:FS01:0x21:Unit: 0x000000e1ab436c9d585e06d5dc3f4003
06:28:26:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:28:26:WU00:FS01:0x21:Machine: 1
06:28:26:WU00:FS01:0x21:Reading tar file core.xml
06:28:26:WU00:FS01:0x21:Reading tar file integrator.xml
06:28:26:WU00:FS01:0x21:Reading tar file state.xml
06:28:26:WU00:FS01:0x21:Reading tar file system.xml
06:28:26:WU00:FS01:0x21:Digital signatures verified
06:28:26:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:28:26:WU00:FS01:0x21:Version 0.0.18
06:28:29:WU00:FS01:0x21:Completed 0 out of 6250000 steps (0%)
06:28:29:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:28:32:WU01:FS01:Upload 7.24%
06:28:40:WU01:FS01:Upload 19.30%
06:28:46:WU01:FS01:Upload 23.32%
06:28:52:WU01:FS01:Upload 30.55%
06:28:59:WU01:FS01:Upload 36.98%
06:29:05:WU01:FS01:Upload 40.20%
06:29:11:WU01:FS01:Upload 47.44%
06:29:17:WU01:FS01:Upload 53.87%
06:29:23:WU01:FS01:Upload 58.69%
06:29:29:WU01:FS01:Upload 65.13%
06:29:35:WU01:FS01:Upload 71.56%
06:29:43:WU01:FS01:Upload 77.99%
06:29:49:WU01:FS01:Upload 82.81%
06:29:55:WU01:FS01:Upload 89.25%
06:30:02:WU01:FS01:Upload 95.68%
06:30:08:WU01:FS01:Upload 99.70%
06:30:13:WU01:FS01:Upload complete
06:30:13:WU01:FS01:Server responded WORK_ACK (400)
06:30:13:WU01:FS01:Final credit estimate, 22547.00 points
06:30:13:WU01:FS01:Cleaning up
06:31:12:WARNING:FS01:Size of positions 394 does not match topology 391
06:31:47:WU00:FS01:0x21:Completed 62500 out of 6250000 steps (1%)
06:33:51:WARNING:FS01:Size of positions 394 does not match topology 391
06:35:05:WU00:FS01:0x21:Completed 125000 out of 6250000 steps (2%)
06:36:29:WARNING:FS01:Size of positions 394 does not match topology 391
06:38:23:WU00:FS01:0x21:Completed 187500 out of 6250000 steps (3%)
06:39:08:WARNING:FS01:Size of positions 394 does not match topology 391
06:41:41:WU00:FS01:0x21:Completed 250000 out of 6250000 steps (4%)
06:41:46:WARNING:FS01:Size of positions 394 does not match topology 391
06:44:27:WARNING:FS01:Size of positions 394 does not match topology 391
06:45:02:WU00:FS01:0x21:Completed 312500 out of 6250000 steps (5%)
06:47:05:WARNING:FS01:Size of positions 394 does not match topology 391
06:48:19:WU00:FS01:0x21:Completed 375000 out of 6250000 steps (6%)
06:49:43:WARNING:FS01:Size of positions 394 does not match topology 391
06:51:37:WU00:FS01:0x21:Completed 437500 out of 6250000 steps (7%)
06:52:22:WARNING:FS01:Size of positions 394 does not match topology 391
06:54:56:WU00:FS01:0x21:Completed 500000 out of 6250000 steps (8%)
06:55:02:WARNING:FS01:Size of positions 394 does not match topology 391
06:57:41:WARNING:FS01:Size of positions 394 does not match topology 391
06:58:16:WU00:FS01:0x21:Completed 562500 out of 6250000 steps (9%)
07:00:20:WARNING:FS01:Size of positions 394 does not match topology 391
07:01:35:WU00:FS01:0x21:Completed 625000 out of 6250000 steps (10%)
07:02:59:WARNING:FS01:Size of positions 394 does not match topology 391
07:04:54:WU00:FS01:0x21:Completed 687500 out of 6250000 steps (11%)
07:05:39:WARNING:FS01:Size of positions 394 does not match topology 391
07:08:12:WU00:FS01:0x21:Completed 750000 out of 6250000 steps (12%)
07:08:17:WARNING:FS01:Size of positions 394 does not match topology 391
07:11:05:WARNING:FS01:Size of positions 394 does not match topology 391
07:11:40:WU00:FS01:0x21:Completed 812500 out of 6250000 steps (13%)
07:13:44:WARNING:FS01:Size of positions 394 does not match topology 391
07:14:58:WU00:FS01:0x21:Completed 875000 out of 6250000 steps (14%)
07:16:22:WARNING:FS01:Size of positions 394 does not match topology 391
07:18:21:WU00:FS01:0x21:Completed 937500 out of 6250000 steps (15%)
07:19:10:WARNING:FS01:Size of positions 394 does not match topology 391
07:22:03:WU00:FS01:0x21:Completed 1000000 out of 6250000 steps (16%)
07:22:08:WARNING:FS01:Size of positions 394 does not match topology 391
07:25:06:WARNING:FS01:Size of positions 394 does not match topology 391
07:25:46:WU00:FS01:0x21:Completed 1062500 out of 6250000 steps (17%)
07:28:04:WARNING:FS01:Size of positions 394 does not match topology 391
07:29:28:WU00:FS01:0x21:Completed 1125000 out of 6250000 steps (18%)
07:30:49:FS01:Paused
07:30:49:FS01:Shutting core down
07:30:50:WU00:FS01:0x21:WARNING:Console control signal 1 on PID 19092
07:30:50:WU00:FS01:0x21:Exiting, please wait. . .
07:30:50:WU00:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
07:30:50:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
07:31:43:Removing old file 'configs/config-20171226-220845.xml'
07:31:43:Saving configuration to config.xml
07:31:43:<config>
07:31:43:  <!-- Folding Core -->
07:31:43:  <checkpoint v='9'/>
07:31:43:  <core-priority v='low'/>
07:31:43:
07:31:43:  <!-- Network -->
07:31:43:  <proxy v=':8080'/>
07:31:43:
07:31:43:  <!-- Slot Control -->
07:31:43:  <pause-on-battery v='false'/>
07:31:43:
07:31:43:  <!-- User Information -->
07:31:43:  <passkey v='********************************'/>
07:31:43:  <team v='224497'/>
07:31:43:  <user v='kwerboom_ALL_1L83cGY1wM9qfMsptnzqdCxmPty2VNTcym'/>
07:31:43:
07:31:43:  <!-- Folding Slots -->
07:31:43:  <slot id='1' type='GPU'>
07:31:43:    <paused v='true'/>
07:31:43:  </slot>
07:31:43:</config>
08:09:43:FS01:Unpaused
08:09:43:WU00:FS01:Starting
08:09:43:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 2384 -checkpoint 9 -gpu-vendor ati -opencl-platform 0 -opencl-device 0 -gpu 0
08:09:43:WU00:FS01:Started FahCore on PID 9820
08:09:43:WU00:FS01:Core PID:1180
08:09:43:WU00:FS01:FahCore 0x21 started
08:09:43:WU00:FS01:0x21:*********************** Log Started 2017-12-28T08:09:43Z ***********************
08:09:43:WU00:FS01:0x21:Project: 9415 (Run 1342, Clone 3, Gen 191)
08:09:43:WU00:FS01:0x21:Unit: 0x000000e1ab436c9d585e06d5dc3f4003
08:09:43:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
08:09:43:WU00:FS01:0x21:Machine: 1
08:09:43:WU00:FS01:0x21:Digital signatures verified
08:09:43:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
08:09:43:WU00:FS01:0x21:Version 0.0.18
08:09:43:WU00:FS01:0x21:  Found a checkpoint file
08:09:46:WU00:FS01:0x21:Completed 1100000 out of 6250000 steps (17%)
08:09:46:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:10:21:Removing old file 'configs/config-20171226-224925.xml'
08:10:21:Saving configuration to config.xml
08:10:21:<config>
08:10:21:  <!-- Folding Core -->
08:10:21:  <checkpoint v='9'/>
08:10:21:  <core-priority v='low'/>
08:10:21:
08:10:21:  <!-- Network -->
08:10:21:  <proxy v=':8080'/>
08:10:21:
08:10:21:  <!-- Slot Control -->
08:10:21:  <pause-on-battery v='false'/>
08:10:21:
08:10:21:  <!-- User Information -->
08:10:21:  <passkey v='********************************'/>
08:10:21:  <team v='224497'/>
08:10:21:  <user v='kwerboom_ALL_1L83cGY1wM9qfMsptnzqdCxmPty2VNTcym'/>
08:10:21:
08:10:21:  <!-- Folding Slots -->
08:10:21:  <slot id='1' type='GPU'/>
08:10:21:</config>
08:11:05:WU00:FS01:0x21:Completed 1125000 out of 6250000 steps (18%)
08:12:30:WARNING:FS01:Size of positions 394 does not match topology 391
08:14:24:WU00:FS01:0x21:Completed 1187500 out of 6250000 steps (19%)
08:15:09:WARNING:FS01:Size of positions 394 does not match topology 391
08:17:43:WU00:FS01:0x21:Completed 1250000 out of 6250000 steps (20%)
08:17:48:WARNING:FS01:Size of positions 394 does not match topology 391
08:20:28:WARNING:FS01:Size of positions 394 does not match topology 391
08:21:03:WU00:FS01:0x21:Completed 1312500 out of 6250000 steps (21%)
08:23:07:WARNING:FS01:Size of positions 394 does not match topology 391
08:24:21:WU00:FS01:0x21:Completed 1375000 out of 6250000 steps (22%)
08:25:46:WARNING:FS01:Size of positions 394 does not match topology 391
08:27:40:WU00:FS01:0x21:Completed 1437500 out of 6250000 steps (23%)
08:28:25:WARNING:FS01:Size of positions 394 does not match topology 391
08:30:59:WU00:FS01:0x21:Completed 1500000 out of 6250000 steps (24%)
08:31:04:WARNING:FS01:Size of positions 394 does not match topology 391
08:33:43:WARNING:FS01:Size of positions 394 does not match topology 391
08:34:18:WU00:FS01:0x21:Completed 1562500 out of 6250000 steps (25%)
08:36:22:WARNING:FS01:Size of positions 394 does not match topology 391
08:37:36:WU00:FS01:0x21:Completed 1625000 out of 6250000 steps (26%)
08:39:00:WARNING:FS01:Size of positions 394 does not match topology 391
08:40:54:WU00:FS01:0x21:Completed 1687500 out of 6250000 steps (27%)
08:41:38:WARNING:FS01:Size of positions 394 does not match topology 391
08:44:11:WU00:FS01:0x21:Completed 1750000 out of 6250000 steps (28%)
08:44:16:WARNING:FS01:Size of positions 394 does not match topology 391
08:46:54:WARNING:FS01:Size of positions 394 does not match topology 391
08:47:28:WU00:FS01:0x21:Completed 1812500 out of 6250000 steps (29%)
08:49:31:WARNING:FS01:Size of positions 394 does not match topology 391
08:50:44:WU00:FS01:0x21:Completed 1875000 out of 6250000 steps (30%)
08:52:08:WARNING:FS01:Size of positions 394 does not match topology 391
08:54:02:WU00:FS01:0x21:Completed 1937500 out of 6250000 steps (31%)
08:54:47:WARNING:FS01:Size of positions 394 does not match topology 391
08:57:17:WU00:FS01:0x21:Completed 2000000 out of 6250000 steps (32%)
08:57:22:WARNING:FS01:Size of positions 394 does not match topology 391
09:00:01:WARNING:FS01:Size of positions 394 does not match topology 391
09:00:35:WU00:FS01:0x21:Completed 2062500 out of 6250000 steps (33%)
09:02:39:WARNING:FS01:Size of positions 394 does not match topology 391
09:03:53:WU00:FS01:0x21:Completed 2125000 out of 6250000 steps (34%)
09:05:18:WARNING:FS01:Size of positions 394 does not match topology 391
09:07:11:WU00:FS01:0x21:Completed 2187500 out of 6250000 steps (35%)
09:07:56:WARNING:FS01:Size of positions 394 does not match topology 391
09:10:29:WU00:FS01:0x21:Completed 2250000 out of 6250000 steps (36%)
09:10:34:WARNING:FS01:Size of positions 394 does not match topology 391
09:13:12:WARNING:FS01:Size of positions 394 does not match topology 391
09:13:47:WU00:FS01:0x21:Completed 2312500 out of 6250000 steps (37%)
09:15:50:WARNING:FS01:Size of positions 394 does not match topology 391
09:17:04:WU00:FS01:0x21:Completed 2375000 out of 6250000 steps (38%)
09:18:28:WARNING:FS01:Size of positions 394 does not match topology 391
09:20:22:WU00:FS01:0x21:Completed 2437500 out of 6250000 steps (39%)
09:21:07:WARNING:FS01:Size of positions 394 does not match topology 391
09:23:40:WU00:FS01:0x21:Completed 2500000 out of 6250000 steps (40%)
09:23:45:WARNING:FS01:Size of positions 394 does not match topology 391
09:26:23:WARNING:FS01:Size of positions 394 does not match topology 391
09:26:58:WU00:FS01:0x21:Completed 2562500 out of 6250000 steps (41%)
09:29:02:WARNING:FS01:Size of positions 394 does not match topology 391
09:30:16:WU00:FS01:0x21:Completed 2625000 out of 6250000 steps (42%)
09:31:40:WARNING:FS01:Size of positions 394 does not match topology 391
09:33:33:WU00:FS01:0x21:Completed 2687500 out of 6250000 steps (43%)
09:34:18:WARNING:FS01:Size of positions 394 does not match topology 391
09:36:51:WU00:FS01:0x21:Completed 2750000 out of 6250000 steps (44%)
09:36:56:WARNING:FS01:Size of positions 394 does not match topology 391
09:39:33:WARNING:FS01:Size of positions 394 does not match topology 391
09:40:07:WU00:FS01:0x21:Completed 2812500 out of 6250000 steps (45%)
09:42:11:WARNING:FS01:Size of positions 394 does not match topology 391
09:43:24:WU00:FS01:0x21:Completed 2875000 out of 6250000 steps (46%)
09:44:47:WARNING:FS01:Size of positions 394 does not match topology 391
09:46:40:WU00:FS01:0x21:Completed 2937500 out of 6250000 steps (47%)
09:47:25:WARNING:FS01:Size of positions 394 does not match topology 391
09:49:56:WU00:FS01:0x21:Completed 3000000 out of 6250000 steps (48%)
09:50:01:WARNING:FS01:Size of positions 394 does not match topology 391
09:52:39:WARNING:FS01:Size of positions 394 does not match topology 391
09:53:13:WU00:FS01:0x21:Completed 3062500 out of 6250000 steps (49%)
09:55:16:WARNING:FS01:Size of positions 394 does not match topology 391
09:56:29:WU00:FS01:0x21:Completed 3125000 out of 6250000 steps (50%)
09:57:52:WARNING:FS01:Size of positions 394 does not match topology 391
09:59:44:WU00:FS01:0x21:Completed 3187500 out of 6250000 steps (51%)
10:00:29:WARNING:FS01:Size of positions 394 does not match topology 391
10:02:59:WU00:FS01:0x21:Completed 3250000 out of 6250000 steps (52%)
10:03:05:WARNING:FS01:Size of positions 394 does not match topology 391
10:05:41:WARNING:FS01:Size of positions 394 does not match topology 391
10:06:15:WU00:FS01:0x21:Completed 3312500 out of 6250000 steps (53%)
10:08:16:WARNING:FS01:Size of positions 394 does not match topology 391
10:09:29:WU00:FS01:0x21:Completed 3375000 out of 6250000 steps (54%)
10:10:52:WARNING:FS01:Size of positions 394 does not match topology 391
10:12:44:WU00:FS01:0x21:Completed 3437500 out of 6250000 steps (55%)
10:13:28:WARNING:FS01:Size of positions 394 does not match topology 391
10:16:00:WU00:FS01:0x21:Completed 3500000 out of 6250000 steps (56%)
10:16:05:WARNING:FS01:Size of positions 394 does not match topology 391
10:18:42:WARNING:FS01:Size of positions 394 does not match topology 391
10:19:16:WU00:FS01:0x21:Completed 3562500 out of 6250000 steps (57%)
10:21:18:WARNING:FS01:Size of positions 394 does not match topology 391
10:22:32:WU00:FS01:0x21:Completed 3625000 out of 6250000 steps (58%)
10:23:55:WARNING:FS01:Size of positions 394 does not match topology 391
10:25:48:WU00:FS01:0x21:Completed 3687500 out of 6250000 steps (59%)
Re: I'm getting really low Points Per WU
Post by foldy »
You need to fold 10 work units with the new passkey until the bonus kicks in.
To expand on foldy's answer, the qualification is based on a passkey and username combination. A new combination needs to have 10 WU's completed before the QRB is awarded for future WU returns. After that you have to maintain at least an 80% return rate to continue receiving bonus points.
At this point your new username with your passkey has been credited for the return of 6 WU's. After you have returned 4 more, then you will get the QRB. The client has no way of checking whether or not your current username and passkey has been qualified for the QRB, it bases its estimated points award on whether or not a passkey has been entered and saved in the client configuration.
kwerboom
Post by kwerboom »
foldy wrote:You need to fold 10 work units with the new passkey until the bonus kicks in.
Joe_H wrote:To expand on foldy's answer, the qualification is based on a passkey and username combination. A new combination needs to have 10 WU's completed before the QRB is awarded for future WU returns. After that you have to maintain at least an 80% return rate to continue receiving bonus points.
I didn't realize there was a 10 WU minimum for Passkey. Thank you for explaining that. I'll look forward to bonus kicking in with WU number 11.
SteveWillis
Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Post by SteveWillis »
10 WU and 80% successful I believe, to pick a nit.
