uninstall components question
dschief
Hardware configuration: Gigabyte Z790 UD AC , i7-14700K (x2) Win11
ASUS Z97_K , i5-4460 (x2) Win10 & UBUNTU 24.04
GPU's ASUS RTX1660 x2, RTX3050 x2
EVGA1060
Post by dschief »
have several boxes with the following NV packages installed in addition to the basic Driver..
NV 3D Vision Control 369.04
NV 3D Vision Driver 388.43
NV PhysX system software 9.17.0524
folding is running fine, just wondering if it's safe to un-install any or all of these 3 ??
Re: uninstall components question
Personally, I avoid installing those as I never use them.
Yes, everything in your list is useless for FAH. You only need the graphics driver.
You can also remove the audio driver if you don't need audio over HDMI, and the Geforce Experience too (it often crashed the drivers on automatic updates so I prefer to avoid it and update manually).
