Not showing up in http://folding.stanford.edu/stats/donors
Someone on the curecoin forum mentioned that I should be showing up on this list (currently have 12,318 points as "dsoodak").
Re: Not showing up in http://folding.stanford.edu/stats/dono
Eventually your donor stats will show up when checking through the current folding.stanford.edu donor check. However this check has some thresholds that need to be reached before that happens. Clicking on your name in FAHControl will show your donor stats using the older fan-web.stanford.edu link. Clicking on "See Stats" in the web control will do the same.
Until you meet the thresholds needed to be seen on other statistic sites you can use the following link to kakaostats:
http://www.kakaostats.net/donor-log?donor=1682039
Thanks for the replies! Do you think cryptobullionpools.com doesn't add curecoins until you've made enough to show up on the main donors list?
You would have to ask them how they determine the rewards being given out. But most places use the download of the Donor list to keep track of folding stats. A link to that is on the stats page - http://folding.stanford.edu/statistics/. Your username shows up in that file like this:
dsoodak 12318 10 0
