171.67.108.157 and 171.67.108.45 connection refused
Kuno
Post by Kuno »
So apparently curecoin had 700 million ppd added today and I'm just wondering if it's a coincidence that I suddenly am unable to get work units?
18:57:06:WU01:FS01:Connecting to 171.67.108.45:80
18:57:06:WU01:FS01:Assigned to work server 171.67.108.157
18:57:06:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1080] 8873 from 171.67.108.157
18:57:06:WU01:FS01:Connecting to 171.67.108.157:8080
18:57:06:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
18:57:06:WU00:FS01:0x21:Saving result file logfile_01.txt
18:57:06:WU00:FS01:0x21:Saving result file checkpointState.xml
18:57:06:WU00:FS01:0x21:Saving result file checkpt.crc
18:57:06:WU00:FS01:0x21:Saving result file log.txt
18:57:06:WU00:FS01:0x21:Saving result file positions.xtc
18:57:06:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
18:57:07:ERROR:WU01:FS01:Exception: Failed to connect to 171.67.108.157:80: Connection refused
18:57:07:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:57:07:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9431 run:367 clone:2 gen:373 core:0x21 unit:0x000001bdab436c9d586fdd36607dfbb4
18:57:07:WU00:FS01:Uploading 13.69MiB to 171.67.108.157
18:57:07:WU00:FS01:Connecting to 171.67.108.157:8080
18:57:07:WU01:FS01:Connecting to 171.67.108.45:80
18:57:07:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
18:57:07:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 171.67.108.157:80: Connection refused
18:57:07:WU00:FS01:Trying to send results to collection server
18:57:07:WU00:FS01:Uploading 13.69MiB to 171.67.108.46
18:57:07:WU00:FS01:Connecting to 171.67.108.46:8080
18:57:07:WU01:FS01:Assigned to work server 171.67.108.157
18:57:07:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 171.67.108.157
18:57:07:WU01:FS01:Connecting to 171.67.108.157:8080
18:57:08:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
18:57:08:WU01:FS01:Connecting to 171.67.108.157:80
18:57:09:ERROR:WU01:FS01:Exception: Failed to connect to 171.67.108.157:80: Connection refused
18:57:13:WU00:FS01:Upload 27.85%
18:57:19:WU00:FS01:Upload 40.64%
18:57:25:WU00:FS01:Upload 51.14%
18:57:31:WU00:FS01:Upload 66.66%
18:57:37:WU00:FS01:Upload 79.90%
18:57:43:WU00:FS01:Upload 89.49%
18:57:49:WU00:FS01:Upload 96.34%
18:57:53:WU00:FS01:Upload complete
18:57:53:WU00:FS01:Server responded WORK_ACK (400)
18:57:53:WU00:FS01:Final credit estimate, 57213.00 points
18:57:53:WU00:FS01:Cleaning up
18:58:07:WU01:FS01:Connecting to 171.67.108.45:80
18:58:08:WU01:FS01:Assigned to work server 171.67.108.157
18:58:08:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 171.67.108.157
18:58:08:WU01:FS01:Connecting to 171.67.108.157:8080
18:58:08:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
18:58:08:ERROR:WU01:FS01:Exception: Failed to connect to 171.67.108.157:80: Connection refused
18:59:45:WU01:FS01:Connecting to 171.67.108.45:80
18:59:45:WU01:FS01:Assigned to work server 171.67.108.157
18:59:45:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 171.67.108.157
18:59:45:WU01:FS01:Connecting to 171.67.108.157:8080
18:59:45:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
18:59:45:ERROR:WU01:FS01:Exception: Failed to connect to 171.67.108.157:80: Connection refused
******************************* Date: 2017-12-02 *******************************
19:02:22:WU01:FS01:Connecting to 171.67.108.45:80
19:02:22:WU01:FS01:Assigned to work server 171.67.108.157
19:02:22:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 171.67.108.157
19:02:22:WU01:FS01:Connecting to 171.67.108.157:8080
19:02:23:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:02:23:WU01:FS01:Connecting to 171.67.108.157:80
19:02:23:ERROR:WU01:FS01:Exception: Failed to connect to 171.67.108.157:80: Connection refused
19:06:36:WU01:FS01:Connecting to 171.67.108.45:80
19:06:36:WU01:FS01:Assigned to work server 171.67.108.157
19:06:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] 8873 from 171.67.108.157
19:06:36:WU01:FS01:Connecting to 171.67.108.157:8080
19:06:37:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
19:06:37:WU01:FS01:Connecting to 171.67.108.157:80
19:06:37:ERROR:WU01:FS01:Exception: Failed to connect to 171.67.108.157:80: Connection refused
Mod edit: added Code tags to log
drougnor
Re: 171.67.108.157 and 171.67.108.45 connection refused
Post by drougnor »
EVGA is running a folding contest and this also is going to be stepping on our toes. My dual card rig is only hitting those two servers, regardless of what flags I'm attempting to use. . . .
d
There is no indication in your log of connection problems with the AS 171.67.108.45, not once is it showing a connection refused. However the WS it is assigning your system to is currently down, it shows up that way on the Server Status page. Its log page shows it has been down since about 11 AM PST, or 19:00Z as shown on the client and in log files.
Are your machines still being assigned to 171.67.108.157 for work? If so the AS is not switching like it should to a WS that is up. I can try to get someone to check the AS server in that case and get it to move on to a server that is up.
HaloJones
Post by HaloJones »
same problem so not isolated to one user
4070 super
HaloJones wrote:same problem so not isolated to one user
Same question to you, is the AS currently pointing your WU request at the WS that is down? It went down about an hour ago, so the AS should have updated and stopped assigning to it.
Hypocritus
Post by Hypocritus »
I have 62 GPU folding slots, and haven't received any new work for about an hour.
I can confirm that through Comcast in Washington, DC, I cannot receive any WUs from anywhere. 171.67.108.157 seems to be the only server sent to me, and I continue to get
20:04:07:WU00:FS09:Assigned to work server 171.67.108.157
20:04:07:WU00:FS09:Requesting new work unit for slot 09: READY gpu:18:GP104 [GeForce GTX 1070] 6463 from 171.67.108.157
20:04:07:WU00:FS09:Connecting to 171.67.108.157:8080
20:04:07:WARNING:WU00:FS09:WorkServer connection failed on port 8080 trying 80
20:04:07:ERROR:WU00:FS09:Exception: Failed to connect to 171.67.108.157:80: Connection refused
20:04:24:WU08:FS01:0x21:Completed 5437500 out of 6250000 steps (87%)
20:04:25:WU09:FS05:Connecting to 171.67.108.45:80
20:04:25:WARNING:WU09:FS05:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
20:04:25:WU09:FS05:Connecting to 171.64.65.35:80
20:04:26:WU09:FS05:Assigned to work server 171.67.108.157
20:04:26:WU09:FS05:Requesting new work unit for slot 05: READY gpu:10:GP104 [GeForce GTX 1070] 6463 from 171.67.108.157
20:04:26:WU09:FS05:Connecting to 171.67.108.157:8080
20:04:26:WARNING:WU09:FS05:WorkServer connection failed on port 8080 trying 80
20:04:26:ERROR:WU09:FS05:Exception: Failed to connect to 171.67.108.157:80: Connection refused
JiiPee
Post by JiiPee »
And here, this just keeps looping
20:02:24:FS01:Unpaused
20:02:24:WU00:FS01:Connecting to 171.67.108.45:80
20:02:25:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': No WUs available for this configuration
20:02:25:WU00:FS01:Connecting to 171.64.65.35:80
20:02:26:WU00:FS01:Assigned to work server 171.67.108.157
20:02:26:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:[Radeon Rx vega] from 171.67.108.157
20:02:26:WU00:FS01:Connecting to 171.67.108.157:8080
20:02:27:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
20:02:27:WU00:FS01:Connecting to 171.67.108.157:80
20:02:29:ERROR:WU00:FS01:Exception: Failed to connect to 171.67.108.157:80: No connection could be made because the target machine actively refused it.
HaloJones
Post by HaloJones »
19:57:31:WU00:FS01:Connecting to 171.67.108.45:80
19:57:32:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
19:57:32:WU00:FS01:Connecting to 171.64.65.35:80
19:57:33:WU00:FS01:Assigned to work server 171.67.108.157
19:57:33:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] 5632 from 171.67.108.157
19:57:33:WU00:FS01:Connecting to 171.67.108.157:8080
19:57:33:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
19:57:33:ERROR:WU00:FS01:Exception: Failed to connect to 171.67.108.157:80: Connection refused
4070 super
Hypocritus
I can confirm that I DO get CPU WUs, but not GPU WUs
20:09:41:WU05:FS05:Connecting to 171.67.108.157:8080
20:09:41:WARNING:WU05:FS05:WorkServer connection failed on port 8080 trying 80
20:09:41:WU06:FS06:Assigned to work server 171.67.108.157
20:09:41:WU06:FS06:Requesting new work unit for slot 06: READY gpu:5:GP102 [GeForce GTX 1080 Ti] 11380 from 171.67.108.157
20:09:41:WU06:FS06:Connecting to 171.67.108.157:8080
20:09:41:WARNING:WU06:FS06:WorkServer connection failed on port 8080 trying 80
20:09:41:ERROR:WU05:FS05:Exception: Failed to connect to 171.67.108.157:80: Connection refused
20:09:42:ERROR:WU06:FS06:Exception: Failed to connect to 171.67.108.157:80: Connection refused
20:10:35:WU00:FS00:0xa7:Completed 275000 out of 2500000 steps (11%)
20:11:31:WU00:FS00:0xa7:Completed 300000 out of 2500000 steps (12%)
20:12:28:WU00:FS00:0xa7:Completed 325000 out of 2500000 steps (13%)
Thank you for current information. I have sent a message to PG about the problem.
Hypocritus
Ok, something's happening. Now I get
20:33:33:WU02:FS00:Connecting to 171.67.108.45:80
20:33:34:WU04:FS04:Connecting to 171.67.108.45:80
20:33:34:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
20:33:34:WU02:FS00:Connecting to 171.64.65.35:80
20:33:34:WU03:FS01:Connecting to 171.67.108.45:80
20:33:34:WARNING:WU04:FS04:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
20:33:34:WU04:FS04:Connecting to 171.64.65.35:80
20:33:34:WARNING:WU02:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
20:33:34:ERROR:WU02:FS00:Exception: Could not get an assignment
But still no GPU WUs
Aurum
Assignment Servers are Down
Post by Aurum »
20:17:34:WU00:FS03:Connecting to 171.67.108.45:80
20:17:34:WARNING:WU00:FS03:Failed to get assignment from '171.67.108.45:80': No WUs available for this configuration
20:17:34:WU00:FS03:Connecting to 171.64.65.35:80
20:17:34:WARNING:WU00:FS03:Failed to get assignment from '171.64.65.35:80': No WUs available for this configuration
20:17:34:ERROR:WU00:FS03:Exception: Could not get an assignment
20:19:25:WU05:FS02:Connecting to 171.67.108.45:80
20:19:25:WARNING:WU05:FS02:Failed to get assignment from '171.67.108.45:80': No WUs available for this configuration
20:19:25:WU05:FS02:Connecting to 171.64.65.35:80
20:19:25:WARNING:WU05:FS02:Failed to get assignment from '171.64.65.35:80': No WUs available for this configuration
20:19:25:ERROR:WU05:FS02:Exception: Could not get an assignment
20:20:40:WU02:FS01:Connecting to 171.67.108.45:80
20:20:40:WARNING:WU02:FS01:Failed to get assignment from '171.67.108.45:80': No WUs available for this configuration
20:20:40:WU02:FS01:Connecting to 171.64.65.35:80
20:20:40:WARNING:WU02:FS01:Failed to get assignment from '171.64.65.35:80': No WUs available for this configuration
20:20:40:ERROR:WU02:FS01:Exception: Could not get an assignment
20:35:30:WU00:FS03:Connecting to 171.67.108.45:80
20:35:30:WARNING:WU00:FS03:Failed to get assignment from '171.67.108.45:80': No WUs available for this configuration
20:35:30:WU00:FS03:Connecting to 171.64.65.35:80
20:35:31:WARNING:WU00:FS03:Failed to get assignment from '171.64.65.35:80': No WUs available for this configuration
20:35:31:ERROR:WU00:FS03:Exception: Could not get an assignment
20:37:21:WU05:FS02:Connecting to 171.67.108.45:80
20:37:22:WARNING:WU05:FS02:Failed to get assignment from '171.67.108.45:80': No WUs available for this configuration
20:37:22:WU05:FS02:Connecting to 171.64.65.35:80
20:37:22:WARNING:WU05:FS02:Failed to get assignment from '171.64.65.35:80': No WUs available for this configuration
20:37:22:ERROR:WU05:FS02:Exception: Could not get an assignment
In Science We Trust Image
Nathan_P
Not currently folding
Post by Nathan_P »
I've got 2 gpus with no work and 2 more about to finish, given that my only cpu slot also has been struggling for work its doing to be a very low producing weekend
Nathan_P
Post by Nathan_P »
Kuno wrote:
HaloJones wrote:
drougnor wrote:EVGA is running a folding contest and this also is going to be stepping on our toes. My dual card rig is only hitting those two servers, regardless of what flags I'm attempting to use. . . .
d
Did EVGA deign to tell the admins to lay on extra units?
The contest EVGA is running isn't going to matter when team Curecoin had 700 million PPD added. They were on target to hit 1.8 BILLION points today, from 1 billion on the 30th. It seems Stanford wasn't ready for the output of work units to literally double in one day.
I've found 5 users alone have added nearly 150m PPD between them, and a few of the established players have seen some 30-40m PPD jumps as well.
Hypocritus
Looks like we're back up everyone!
