Linux install guide
FAH provides a V7 client installer for Debian / Mint / Ubuntu / RedHat / CentOS / Fedora. Installation on other distros may or may not be easy but if you can offer help to others, they would appreciate it.
leggazoid
Linux install guide
Post by leggazoid »
Linux install guide...
Install Xubuntu (or any flavor) 17.10
sudo apt-add-repository ppa:graphics-drivers/ppa
sudo apt update
sudo apt full-upgrade
sudo apt install nvidia-387
sudo nvidia-xconfig -a --cool-bits=31 --allow-empty-initial-configuration
wget http://launchpadlibrarian.net/109052632/python-support_1.0.15_all.deb
sudo apt install ./python-support_1.0.15_all.deb
wget https://folding.stanford.edu/releases/public/release/fahclient/debian-testing-64bit/v7.4/fahclient_7.4.4_amd64.deb
sudo apt install ./fahclient_7.4.4_amd64.deb
wget https://folding.stanford.edu/releases/public/release/fahcontrol/debian-testing-64bit/v7.4/fahcontrol_7.4.4-1_all.deb
sudo apt install ./fahcontrol_7.4.4-1_all.deb
wget http://fah-web.stanford.edu/file-releases/public/GPUs.txt
sudo cp GPUs.txt /var/lib/fahclient/
leggazoid
Re: Linux install guide
Post by leggazoid »
Not sure if cool-bits=31 still works for overclocking on nvidia-387 drivers?
reavy
Post by reavy »
Thanks very much for this guide! It's been helpful for me.
I also needed
sudo apt-get install software-properties-common python-software-properties
to get the apt-add-repository command. For some reason those two packages weren't already installed on my system.
SteveWillis
Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Post by SteveWillis »
leggazoid wrote:Not sure if cool-bits=31 still works for overclocking on nvidia-387 drivers?
It does.
leggazoid
Post by leggazoid »
Install Xubuntu (or any flavor) 18.04.3
sudo apt update
sudo apt install nvidia-430
sudo reboot
wget https://folding.stanford.edu/releases/public/release/fahclient/debian-testing-64bit/v7.4/fahclient_7.5.1_amd64.deb
sudo apt install ./fahclient_7.5.1_amd64.deb
wget https://folding.stanford.edu/releases/public/release/fahcontrol/debian-testing-64bit/v7.4/fahcontrol_7.5.1-1_all.deb
sudo apt install ./fahcontrol_7.5.1-1_all.deb
sudo systemctl restart FAHClient.service
# (Fan control that works with ssh and you can use over clocking the same way)
sudo systemctl restart lightdm.service
sudo DISPLAY=:0 XAUTHORITY=/var/run/lightdm/root/:0 nvidia-settings -a 'GPUFanControlState=1' -a 'GPUTargetFanSpeed=100'
The client will automatically update the GPUs.txt file. If you copy it manually, you run the risk to break permissions on the file and to permanently break auto-update feature.
toTOW wrote:The client will automatically update the GPUs.txt file. If you copy it manually, you run the risk to break permissions on the file and to permanently break auto-update feature.
Agreed. FAH configures special permissions for its files.
When FAH is first installed, one of the FIRST things it attempts to do is download GPUs.txt. That must happen before your GPU can be configured, and it may not if the rebooted system doesn't connect to the internet quickly enough so that it's available before FAH's initial startup. FAH should still update it later, so be patient if your GPU doesn't set up immediately.
Adam_Ford
Post by Adam_Ford »
if you change the option from gpu=false to true it should download gpus.txt
lazyacevw
Post by lazyacevw »
FWIW, I have Linux Mint 19.3 Tricia with 5.4.7-050407-generic kernel. I was able to get my 3950X up and folding by simply installing fahclient v7.5.1 and terminal/FAHControl. I could not add my GPU however so.....
Here are the minimal steps I have found to get FAH up and running with my GPU without having to install any additional packages. Trying other methods I found messed up Steam and I couldn't play games (thank goodness for Timeshift!) I also hate installing unnecessary packages:
Installing F@H:
## Download fahclient, fahcontrol, and optionally fahviewer from https://foldingathome.org/start-folding/ and save to your desktop
## Double click on each package, one at a time and have Package Installer install the packages.
sudo nvidia-xconfig --cool-bits=4
sudo gedit /etc/fahclient/config.xml
## Within the config.xml, change the gpu-entry from 'false' to 'true' and save.
sudo wget https://fah-web.stanford.edu/file-releases/public/GPUs.txt -P /var/lib/fahclient
sudo chown fahclient:root /var/lib/fahclient/GPUs.txt
sudo /etc/init.d/FAHClient restart
## Open FAHControl and select <Configure>, <Slots>, <Add>, <GPU>, <OK>, and <Save>.
## Optionally, I added extra slot options for my CPU (client-type, bigadv) and for my GPU (client-type, advanced). Read more about that here: https://foldingathome.org/support/faq/installation-guides/configuration-guide/
The GPU.txt file was not automatically downloaded by fahclient, so that is why I downloaded it in the above steps. Maybe it's because my config.xml had the gpu entry set to false?
If you don't already have nvidia drivers installed, I have included what I can remember from the process. I chose v440. Please correct me if I mis-remembered anything about the nvidia drivers! I had to install gcc-7 and gcc-9 because it turns out, nvidia installation will fail if you are running an upgraded kernel unless you also install the gcc compilers that were used to compile that kernel. Had to read /var/lib/dkms/nvidia/440.44/build/make.log to figure that out.
Nvidia Drivers:
sudo apt-get purge nvidia*
sudo dpkg --add-architecture i386
sudo apt update
sudo apt install build-essential libc6:i386
sudo bash -c "echo blacklist nouveau > /etc/modprobe.d/blacklist-nvidia-nouveau.conf"
sudo bash -c "echo options nouveau modeset=0 >> /etc/modprobe.d/blacklist-nvidia-nouveau.conf"
sudo apt install software-properties-common
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt update
sudo apt install gcc-7 g++-7 gcc-9 g++-9
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-9 90 --slave /usr/bin/g++ g++ /usr/bin/g++-9 --slave /usr/bin/gcov gcov /usr/bin/gcov-9
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 70 --slave /usr/bin/g++ g++ /usr/bin/g++-7 --slave /usr/bin/gcov gcov /usr/bin/gcov-7
sudo update-initramfs -u
sudo reboot
## Hit CTRL+ALT+F1
sudo telinit 3
sudo CC="gcc-7.2.0" bash ~/Desktop/NVIDIA-Linux-x86_64-440.44.run
sudo reboot
Dr_Rob
Post by Dr_Rob »
I am a long-time folder with Windows, but I am a nube to Linux. I have been attempting to use Linux and fold with gpus without success.
After trying Ubuntu 19 and Mint 20 I am understanding Python 3 has replaced 2 when installing FAHcontrol. But trying Ubuntu 18.04.3 I still get the python dependency error following the commands above posted by leggazoid » Mon Aug 12, 2019 10:24 pm .
As FAH and Linux evolve, can anyone point me to a workable sequence where I can initialize and monitor the gpus. Thank you.
Knish
Post by Knish »
when setting up fah on linux, does anyone ever get something where adding a gpu slot just doesn't take? Eventually a manual edit of config.xml to have slot 1 = GPU finally makes it work, but is there a faster way?
Knish
Post by Knish »
Dr_Rob, for remote monitoring, try this https://linustechtips.com/main/topic/99 ... ahcontrol/ or there's another program called HFM.net and this forum has an entire stickied thread about it
MeeLee
Post by MeeLee »
You have to boot into GRUB, and select 'recovery', then boot into shell.
From there, you need to install the 'nvidia driver.run' file.
The driver install from the .run files is necessary, if you want to run more than 1 GPU on OpenCL.
You then need to install the OpenCL drivers, (sudo apt install ocl-icd-opencl-dev), before you can fold on GPUs in Linux.
ipkh
Post by ipkh »
Original post is outdated.
Ubuntu and its derivatives only need to have the Nvidia proprietary driver selected and installed via the additional drivers app. This pulls in the required compute packages.
Then use this forked copy of fahcontrol once you have installed the client.
https://github.com/cdberkstresser/fah-control/releases
MeeLee
Post by MeeLee »
ipkh wrote:Original post is outdated.
That is, if you run 1 gpu, or aren't in need of overclocking, adjusting power levels, or adjusting the fan curve.
I tested a few ubuntu variants from 19.04 to 20.04, and none of them seem to be able to run 2 GPUs properly.
Probably not an issue with RTX 3090 GPUs, which you'll want to run no more than 1 per system anyway.
