dos atack
Fer
dos atack
Post by Fer »
What does this mean?
2017/11/05 17:19:23 -- [DOS][Block][tcp_flag, scanner=no_flags][192.168.40.14:50644->171.67.108.101:8080][TCP][HLen=20, TLen=1492, Flag=, Seq=2458042415, Ack=4134012050, Win=260]
2017/11/05 16:02:54 -- [DOS][Block][tcp_flag, scanner=no_flags][192.168.40.14:53182->171.67.108.101:8080][TCP][HLen=20, TLen=292, Flag=, Seq=2006349853, Ack=442054501, Win=260]
2017/11/05 14:43:58 -- [DOS][Block][tcp_flag, scanner=no_flags][192.168.40.14:62760->171.67.108.157:8080][TCP][HLen=20, TLen=1232, Flag=, Seq=2764791203, Ack=2716285561, Win=260]
2017/11/05 11:50:48 -- [DOS][Block][tcp_flag, scanner=no_flags][192.168.40.14:61052->171.67.108.101:8080][TCP][HLen=20, TLen=1492, Flag=, Seq=2411862721, Ack=1284436542, Win=260]
2017/11/05 05:09:30 -- [DOS][Block][tcp_flag, scanner=no_flags][192.168.40.14:52941->171.67.108.157:8080][TCP][HLen=20, TLen=1232, Flag=, Seq=2368077989, Ack=2911238115, Win=260]
2017/11/05 02:16:16 -- [DOS][Block][tcp_flag, scanner=no_flags][192.168.40.14:55896->171.67.108.157:8080][TCP][HLen=20, TLen=1492, Flag=, Seq=3872167741, Ack=2096631885, Win=260]
2017/11/04 23:24:16 -- [DOS][Block][tcp_flag, scanner=no_flags][192.168.40.14:56310->171.67.108.157:8080][TCP][HLen=20, TLen=1492, Flag=, Seq=3120401658, Ack=1779036482, Win=260]
2017/11/04 20:31:48 -- [DOS][Block][tcp_flag, scanner=no_flags][192.168.40.14:50481->171.67.108.157:8080][TCP][HLen=20, TLen=1492, Flag=, Seq=1617405574, Ack=1574377160, Win=260]
Re: dos atack
I suspect DOS in this case does not refer to an attack type, but to something else. But without any context to where you are seeing these messages and what your system is being used for, can't be certain what is causing these messages. The only thing I can tell is that connections to a couple of the FAH Work Servers are being reported on.
If you are trying to use the FAH client on your computer, please post the first 100 or so lines of your log file. Directions on where to find it and how to post are here - viewtopic.php?f=18&t=26036. Let us know if you are successfully downloading WU's or not. If you are running any anti-malware app or firewal, let us know about that as well.
Fer
Re: dos atack
Post by Fer »
The massage came from the router firewal (Draytek 2925n+).
At that moment the system was idle and only running fha.
Pc running windows 10 64 bit with symantec endpoint protectoin Version 14(14.0 MP2) build 2415 ( 14.0.2415.0200) and zemana antimalware premium 2.74.2.150
Fha runs fine.
This is the fha log file.
10:50:49:WU00:FS01:Connecting to 171.67.108.101:8080
10:50:49:WU01:FS01:Starting
10:50:49:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/fer.ROEBROEKS/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 12724 -checkpoint 15 -gpu 0 -gpu-vendor ati
10:50:49:WU01:FS01:Started FahCore on PID 2024
10:50:49:WU01:FS01:Core PID:9480
10:50:49:WU01:FS01:FahCore 0x21 started
10:50:49:WU01:FS01:0x21:*********************** Log Started 2017-11-05T10:50:49Z ***********************
10:50:49:WU01:FS01:0x21:Project: 9415 (Run 398, Clone 1, Gen 307)
10:50:49:WU01:FS01:0x21:Unit: 0x00000163ab436c9d585e06cc44e533aa
10:50:49:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
10:50:49:WU01:FS01:0x21:Machine: 1
10:50:49:WU01:FS01:0x21:Reading tar file core.xml
10:50:49:WU01:FS01:0x21:Reading tar file integrator.xml
10:50:49:WU01:FS01:0x21:Reading tar file state.xml
10:50:49:WU01:FS01:0x21:Reading tar file system.xml
10:50:49:WU01:FS01:0x21:Digital signatures verified
10:50:49:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
10:50:49:WU01:FS01:0x21:Version 0.0.18
10:50:53:WU01:FS01:0x21:Completed 0 out of 6250000 steps (0%)
10:50:53:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
10:50:55:WU00:FS01:Upload 1.39%
10:51:02:WU00:FS01:Upload 2.32%
10:51:11:WU00:FS01:Upload 3.24%
10:51:22:WU00:FS01:Upload 4.17%
10:51:32:WU00:FS01:Upload 5.09%
10:51:41:WU00:FS01:Upload 6.02%
10:51:50:WU00:FS01:Upload 6.95%
10:51:56:WU00:FS01:Upload 7.41%
10:52:02:WU00:FS01:Upload 8.34%
10:52:11:WU00:FS01:Upload 9.72%
10:52:21:WU00:FS01:Upload 10.65%
10:52:31:WU00:FS01:Upload 11.58%
10:52:37:WU01:FS01:0x21:Completed 62500 out of 6250000 steps (1%)
10:52:40:WU00:FS01:Upload 12.50%
10:52:46:WU00:FS01:Upload 12.97%
10:52:58:WU00:FS01:Upload 13.89%
10:53:06:WU00:FS01:Upload 14.82%
10:53:15:WU00:FS01:Upload 15.74%
10:53:27:WU00:FS01:Upload 16.67%
10:53:37:WU00:FS01:Upload 17.60%
10:53:43:WU00:FS01:Upload 18.06%
10:53:54:WU00:FS01:Upload 18.99%
10:54:02:WU00:FS01:Upload 19.91%
10:54:13:WU00:FS01:Upload 20.84%
10:54:20:WU01:FS01:0x21:Completed 125000 out of 6250000 steps (2%)
10:54:22:WU00:FS01:Upload 21.76%
10:54:33:WU00:FS01:Upload 22.69%
10:54:39:WU00:FS01:Upload 23.15%
10:54:46:WU00:FS01:Upload 23.62%
10:54:55:WU00:FS01:Upload 24.54%
10:55:03:WU00:FS01:Upload 25.47%
10:55:12:WU00:FS01:Upload 26.39%
10:55:18:WU00:FS01:Upload 27.32%
10:55:24:WU00:FS01:Upload 28.25%
10:55:31:WU00:FS01:Upload 29.17%
10:55:37:WU00:FS01:Upload 29.64%
10:55:46:WU00:FS01:Upload 30.56%
10:55:52:WU00:FS01:Upload 31.02%
10:56:01:WU00:FS01:Upload 31.95%
10:56:04:WU01:FS01:0x21:Completed 187500 out of 6250000 steps (3%)
10:56:08:WU00:FS01:Upload 32.41%
10:56:19:WU00:FS01:Upload 33.34%
10:56:25:WU00:FS01:Upload 33.80%
10:56:34:WU00:FS01:Upload 34.73%
10:56:44:WU00:FS01:Upload 35.66%
10:56:50:WU00:FS01:Upload 36.12%
10:56:58:WU00:FS01:Upload 36.58%
10:57:07:WU00:FS01:Upload 37.51%
10:57:17:WU00:FS01:Upload 38.43%
10:57:25:WU00:FS01:Upload 39.36%
10:57:33:WU00:FS01:Upload 40.29%
10:57:43:WU00:FS01:Upload 41.21%
10:57:48:WU01:FS01:0x21:Completed 250000 out of 6250000 steps (4%)
10:57:51:WU00:FS01:Upload 42.14%
10:57:58:WU00:FS01:Upload 43.06%
10:58:07:WU00:FS01:Upload 43.99%
10:58:16:WU00:FS01:Upload 44.92%
10:58:25:WU00:FS01:Upload 45.38%
10:58:35:WU00:FS01:Upload 46.31%
10:58:44:WU00:FS01:Upload 47.23%
10:58:50:WU00:FS01:Upload 48.16%
10:58:56:WU00:FS01:Upload 48.62%
10:59:04:WU00:FS01:Upload 49.08%
10:59:14:WU00:FS01:Upload 50.01%
10:59:21:WU00:FS01:Upload 50.94%
10:59:30:WU00:FS01:Upload 51.86%
10:59:32:WU01:FS01:0x21:Completed 312500 out of 6250000 steps (5%)
10:59:36:WU00:FS01:Upload 52.33%
10:59:44:WU00:FS01:Upload 53.25%
10:59:53:WU00:FS01:Upload 53.71%
10:59:59:WU00:FS01:Upload 54.18%
11:00:08:WU00:FS01:Upload 55.10%
11:00:19:WU00:FS01:Upload 56.49%
11:00:31:WU00:FS01:Upload 57.42%
11:00:41:WU00:FS01:Upload 58.35%
11:00:48:WU00:FS01:Upload 59.27%
11:00:56:WU00:FS01:Upload 60.20%
11:01:06:WU00:FS01:Upload 61.12%
11:01:16:WU01:FS01:0x21:Completed 375000 out of 6250000 steps (6%)
11:01:17:WU00:FS01:Upload 62.05%
11:01:26:WU00:FS01:Upload 62.98%
11:01:34:WU00:FS01:Upload 63.90%
11:01:42:WU00:FS01:Upload 64.83%
11:01:53:WU00:FS01:Upload 65.75%
11:01:59:WU00:FS01:Upload 66.22%
11:02:09:WU00:FS01:Upload 67.14%
11:02:20:WU00:FS01:Upload 68.07%
11:02:26:WU00:FS01:Upload 68.53%
11:02:35:WU00:FS01:Upload 69.46%
11:02:41:WU00:FS01:Upload 69.92%
11:02:50:WU00:FS01:Upload 70.85%
11:03:00:WU01:FS01:0x21:Completed 437500 out of 6250000 steps (7%)
11:03:01:WU00:FS01:Upload 71.77%
11:03:11:WU00:FS01:Upload 72.70%
11:03:19:WU00:FS01:Upload 73.63%
11:03:25:WU00:FS01:Upload 74.09%
11:03:33:WU00:FS01:Upload 74.55%
11:03:39:WU00:FS01:Upload 75.02%
11:03:49:WU00:FS01:Upload 75.94%
11:03:55:WU00:FS01:Upload 76.87%
11:04:11:WU00:FS01:Upload 77.79%
11:04:21:WU00:FS01:Upload 78.72%
11:04:31:WU00:FS01:Upload 79.65%
11:04:40:WU00:FS01:Upload 80.57%
11:04:44:WU01:FS01:0x21:Completed 500000 out of 6250000 steps (8%)
11:04:55:WU00:FS01:Upload 81.50%
11:05:01:WU00:FS01:Upload 81.96%
11:05:11:WU00:FS01:Upload 82.89%
11:05:22:WU00:FS01:Upload 83.81%
11:05:32:WU00:FS01:Upload 84.74%
11:05:40:WU00:FS01:Upload 85.67%
11:05:51:WU00:FS01:Upload 86.59%
11:06:00:WU00:FS01:Upload 87.52%
11:06:12:WU00:FS01:Upload 88.44%
11:06:23:WU00:FS01:Upload 89.37%
11:06:28:WU01:FS01:0x21:Completed 562500 out of 6250000 steps (9%)
11:06:30:WU00:FS01:Upload 90.30%
11:06:36:WU00:FS01:Upload 91.22%
11:06:42:WU00:FS01:Upload 92.15%
11:06:52:WU00:FS01:Upload 93.07%
11:07:01:WU00:FS01:Upload 94.00%
11:07:11:WU00:FS01:Upload 94.93%
11:07:21:WU00:FS01:Upload 95.85%
11:07:30:WU00:FS01:Upload 96.78%
11:07:36:WU00:FS01:Upload 97.71%
11:07:44:WU00:FS01:Upload 98.17%
11:07:54:WU00:FS01:Upload 99.09%
11:08:01:WU00:FS01:Upload 100.00%
11:08:11:WU00:FS01:Upload complete
11:08:11:WU00:FS01:Server responded WORK_ACK (400)
11:08:11:WU00:FS01:Final credit estimate, 23391.00 points
11:08:11:WU00:FS01:Cleaning up
11:08:12:WU01:FS01:0x21:Completed 625000 out of 6250000 steps (10%)
11:09:56:WU01:FS01:0x21:Completed 687500 out of 6250000 steps (11%)
11:11:40:WU01:FS01:0x21:Completed 750000 out of 6250000 steps (12%)
11:13:24:WU01:FS01:0x21:Completed 812500 out of 6250000 steps (13%)
11:15:08:WU01:FS01:0x21:Completed 875000 out of 6250000 steps (14%)
11:16:52:WU01:FS01:0x21:Completed 937500 out of 6250000 steps (15%)
11:18:36:WU01:FS01:0x21:Completed 1000000 out of 6250000 steps (16%)
11:20:20:WU01:FS01:0x21:Completed 1062500 out of 6250000 steps (17%)
11:22:04:WU01:FS01:0x21:Completed 1125000 out of 6250000 steps (18%)
11:23:47:WU01:FS01:0x21:Completed 1187500 out of 6250000 steps (19%)
11:25:31:WU01:FS01:0x21:Completed 1250000 out of 6250000 steps (20%)
11:27:15:WU01:FS01:0x21:Completed 1312500 out of 6250000 steps (21%)
11:28:59:WU01:FS01:0x21:Completed 1375000 out of 6250000 steps (22%)
11:30:43:WU01:FS01:0x21:Completed 1437500 out of 6250000 steps (23%)
11:32:27:WU01:FS01:0x21:Completed 1500000 out of 6250000 steps (24%)
11:34:11:WU01:FS01:0x21:Completed 1562500 out of 6250000 steps (25%)
11:35:55:WU01:FS01:0x21:Completed 1625000 out of 6250000 steps (26%)
11:37:39:WU01:FS01:0x21:Completed 1687500 out of 6250000 steps (27%)
11:39:22:WU01:FS01:0x21:Completed 1750000 out of 6250000 steps (28%)
11:41:06:WU01:FS01:0x21:Completed 1812500 out of 6250000 steps (29%)
11:42:50:WU01:FS01:0x21:Completed 1875000 out of 6250000 steps (30%)
11:44:33:WU01:FS01:0x21:Completed 1937500 out of 6250000 steps (31%)
11:46:17:WU01:FS01:0x21:Completed 2000000 out of 6250000 steps (32%)
11:48:02:WU01:FS01:0x21:Completed 2062500 out of 6250000 steps (33%)
11:49:45:WU01:FS01:0x21:Completed 2125000 out of 6250000 steps (34%)
11:51:29:WU01:FS01:0x21:Completed 2187500 out of 6250000 steps (35%)
11:53:13:WU01:FS01:0x21:Completed 2250000 out of 6250000 steps (36%)
11:54:57:WU01:FS01:0x21:Completed 2312500 out of 6250000 steps (37%)
11:56:41:WU01:FS01:0x21:Completed 2375000 out of 6250000 steps (38%)
11:58:25:WU01:FS01:0x21:Completed 2437500 out of 6250000 steps (39%)
12:00:09:WU01:FS01:0x21:Completed 2500000 out of 6250000 steps (40%)
12:01:53:WU01:FS01:0x21:Completed 2562500 out of 6250000 steps (41%)
12:03:37:WU01:FS01:0x21:Completed 2625000 out of 6250000 steps (42%)
12:05:21:WU01:FS01:0x21:Completed 2687500 out of 6250000 steps (43%)
12:07:05:WU01:FS01:0x21:Completed 2750000 out of 6250000 steps (44%)
12:08:49:WU01:FS01:0x21:Completed 2812500 out of 6250000 steps (45%)
12:10:33:WU01:FS01:0x21:Completed 2875000 out of 6250000 steps (46%)
12:12:17:WU01:FS01:0x21:Completed 2937500 out of 6250000 steps (47%)
12:14:01:WU01:FS01:0x21:Completed 3000000 out of 6250000 steps (48%)
12:15:46:WU01:FS01:0x21:Completed 3062500 out of 6250000 steps (49%)
12:17:30:WU01:FS01:0x21:Completed 3125000 out of 6250000 steps (50%)
12:19:13:WU01:FS01:0x21:Completed 3187500 out of 6250000 steps (51%)
12:20:57:WU01:FS01:0x21:Completed 3250000 out of 6250000 steps (52%)
12:22:41:WU01:FS01:0x21:Completed 3312500 out of 6250000 steps (53%)
12:24:25:WU01:FS01:0x21:Completed 3375000 out of 6250000 steps (54%)
12:26:09:WU01:FS01:0x21:Completed 3437500 out of 6250000 steps (55%)
12:27:52:WU01:FS01:0x21:Completed 3500000 out of 6250000 steps (56%)
12:29:36:WU01:FS01:0x21:Completed 3562500 out of 6250000 steps (57%)
12:31:20:WU01:FS01:0x21:Completed 3625000 out of 6250000 steps (58%)
12:33:03:WU01:FS01:0x21:Completed 3687500 out of 6250000 steps (59%)
12:34:47:WU01:FS01:0x21:Completed 3750000 out of 6250000 steps (60%)
12:36:31:WU01:FS01:0x21:Completed 3812500 out of 6250000 steps (61%)
12:38:15:WU01:FS01:0x21:Completed 3875000 out of 6250000 steps (62%)
12:39:59:WU01:FS01:0x21:Completed 3937500 out of 6250000 steps (63%)
12:41:42:WU01:FS01:0x21:Completed 4000000 out of 6250000 steps (64%)
12:43:26:WU01:FS01:0x21:Completed 4062500 out of 6250000 steps (65%)
12:45:10:WU01:FS01:0x21:Completed 4125000 out of 6250000 steps (66%)
12:46:53:WU01:FS01:0x21:Completed 4187500 out of 6250000 steps (67%)
12:48:37:WU01:FS01:0x21:Completed 4250000 out of 6250000 steps (68%)
12:50:21:WU01:FS01:0x21:Completed 4312500 out of 6250000 steps (69%)
12:52:04:WU01:FS01:0x21:Completed 4375000 out of 6250000 steps (70%)
12:53:48:WU01:FS01:0x21:Completed 4437500 out of 6250000 steps (71%)
12:55:31:WU01:FS01:0x21:Completed 4500000 out of 6250000 steps (72%)
12:57:15:WU01:FS01:0x21:Completed 4562500 out of 6250000 steps (73%)
12:58:59:WU01:FS01:0x21:Completed 4625000 out of 6250000 steps (74%)
13:00:42:WU01:FS01:0x21:Completed 4687500 out of 6250000 steps (75%)
13:02:26:WU01:FS01:0x21:Completed 4750000 out of 6250000 steps (76%)
13:04:10:WU01:FS01:0x21:Completed 4812500 out of 6250000 steps (77%)
13:05:54:WU01:FS01:0x21:Completed 4875000 out of 6250000 steps (78%)
13:07:37:WU01:FS01:0x21:Completed 4937500 out of 6250000 steps (79%)
13:09:21:WU01:FS01:0x21:Completed 5000000 out of 6250000 steps (80%)
13:11:05:WU01:FS01:0x21:Completed 5062500 out of 6250000 steps (81%)
13:12:49:WU01:FS01:0x21:Completed 5125000 out of 6250000 steps (82%)
13:14:32:WU01:FS01:0x21:Completed 5187500 out of 6250000 steps (83%)
13:16:16:WU01:FS01:0x21:Completed 5250000 out of 6250000 steps (84%)
13:18:00:WU01:FS01:0x21:Completed 5312500 out of 6250000 steps (85%)
13:19:44:WU01:FS01:0x21:Completed 5375000 out of 6250000 steps (86%)
13:21:27:WU01:FS01:0x21:Completed 5437500 out of 6250000 steps (87%)
13:23:11:WU01:FS01:0x21:Completed 5500000 out of 6250000 steps (88%)
13:24:55:WU01:FS01:0x21:Completed 5562500 out of 6250000 steps (89%)
13:26:38:WU01:FS01:0x21:Completed 5625000 out of 6250000 steps (90%)
13:28:22:WU01:FS01:0x21:Completed 5687500 out of 6250000 steps (91%)
13:30:06:WU01:FS01:0x21:Completed 5750000 out of 6250000 steps (92%)
13:31:50:WU01:FS01:0x21:Completed 5812500 out of 6250000 steps (93%)
13:33:34:WU01:FS01:0x21:Completed 5875000 out of 6250000 steps (94%)
13:35:18:WU01:FS01:0x21:Completed 5937500 out of 6250000 steps (95%)
13:37:02:WU01:FS01:0x21:Completed 6000000 out of 6250000 steps (96%)
13:38:46:WU01:FS01:0x21:Completed 6062500 out of 6250000 steps (97%)
13:40:30:WU01:FS01:0x21:Completed 6125000 out of 6250000 steps (98%)
13:42:13:WU01:FS01:0x21:Completed 6187500 out of 6250000 steps (99%)
13:42:14:WU00:FS01:Connecting to 171.67.108.45:80
13:42:15:WU00:FS01:Assigned to work server 171.67.108.101
13:42:15:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Fiji XT [Radeon R9 Fury X] from 171.67.108.101
13:42:15:WU00:FS01:Connecting to 171.67.108.101:8080
13:42:33:WU00:FS01:Downloading 8.90MiB
13:42:43:WU00:FS01:Download 2.11%
13:42:49:WU00:FS01:Download 5.62%
13:42:55:WU00:FS01:Download 8.43%
13:43:01:WU00:FS01:Download 9.83%
13:43:09:WU00:FS01:Download 11.94%
13:43:16:WU00:FS01:Download 14.75%
13:43:22:WU00:FS01:Download 17.56%
13:43:28:WU00:FS01:Download 19.66%
13:43:36:WU00:FS01:Download 21.77%
13:43:42:WU00:FS01:Download 23.88%
13:43:49:WU00:FS01:Download 25.98%
13:43:57:WU01:FS01:0x21:Completed 6250000 out of 6250000 steps (100%)
13:43:58:WU00:FS01:Download 28.09%
13:43:58:WU01:FS01:0x21:Saving result file logfile_01.txt
13:43:58:WU01:FS01:0x21:Saving result file checkpointState.xml
13:43:58:WU01:FS01:0x21:Saving result file checkpt.crc
13:43:58:WU01:FS01:0x21:Saving result file log.txt
13:43:58:WU01:FS01:0x21:Saving result file positions.xtc
13:43:58:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
13:43:58:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:43:58:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9415 run:398 clone:1 gen:307 core:0x21 unit:0x00000163ab436c9d585e06cc44e533aa
13:43:58:WU01:FS01:Uploading 7.79MiB to 171.67.108.157
13:43:58:WU01:FS01:Connecting to 171.67.108.157:8080
13:44:05:WU00:FS01:Download 30.20%
13:44:07:WU01:FS01:Upload 2.41%
13:44:13:WU00:FS01:Download 32.30%
13:44:16:WU01:FS01:Upload 4.01%
13:44:22:WU00:FS01:Download 39.32%
13:44:26:WU01:FS01:Upload 5.61%
13:44:29:WU00:FS01:Download 42.84%
13:44:35:WU01:FS01:Upload 7.22%
13:44:35:WU00:FS01:Download 45.64%
13:44:41:WU00:FS01:Download 49.86%
13:44:43:WU01:FS01:Upload 8.82%
13:44:49:WU00:FS01:Download 54.77%
13:44:53:WU01:FS01:Upload 10.43%
13:44:55:WU00:FS01:Download 57.58%
13:44:59:WU01:FS01:Upload 12.03%
13:45:02:WU00:FS01:Download 60.39%
13:45:08:WU00:FS01:Download 62.50%
13:45:08:WU01:FS01:Upload 12.83%
13:45:15:WU00:FS01:Download 66.01%
13:45:18:WU01:FS01:Upload 14.44%
13:45:21:WU00:FS01:Download 70.93%
13:45:27:WU00:FS01:Download 74.44%
13:45:27:WU01:FS01:Upload 16.04%
13:45:33:WU00:FS01:Download 77.25%
13:45:36:WU01:FS01:Upload 17.64%
13:45:39:WU00:FS01:Download 80.76%
13:45:43:WU01:FS01:Upload 19.25%
13:45:45:WU00:FS01:Download 84.27%
13:45:50:WU01:FS01:Upload 20.85%
13:45:53:WU00:FS01:Download 88.48%
13:45:59:WU01:FS01:Upload 22.45%
13:46:00:WU00:FS01:Download 92.69%
13:46:07:WU00:FS01:Download 94.80%
13:46:09:WU01:FS01:Upload 24.06%
13:46:13:WU00:FS01:Download 96.91%
13:46:18:WU01:FS01:Upload 25.66%
13:46:21:WU00:FS01:Download 99.01%
13:46:24:WU00:FS01:Download complete
13:46:25:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13147 run:16 clone:7 gen:6 core:0x21 unit:0x00000006ab436c6559e67f751974c80a
13:46:25:WU00:FS01:Starting
13:46:25:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/fer.ROEBROEKS/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 12724 -checkpoint 15 -gpu 0 -gpu-vendor ati
13:46:25:WU00:FS01:Started FahCore on PID 7272
13:46:25:WU00:FS01:Core PID:8100
13:46:25:WU00:FS01:FahCore 0x21 started
13:46:25:WU00:FS01:0x21:*********************** Log Started 2017-11-05T13:46:25Z ***********************
13:46:25:WU00:FS01:0x21:Project: 13147 (Run 16, Clone 7, Gen 6)
13:46:25:WU00:FS01:0x21:Unit: 0x00000006ab436c6559e67f751974c80a
13:46:25:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
13:46:25:WU00:FS01:0x21:Machine: 1
13:46:25:WU00:FS01:0x21:Reading tar file core.xml
13:46:25:WU00:FS01:0x21:Reading tar file integrator.xml
13:46:25:WU00:FS01:0x21:Reading tar file state.xml
13:46:26:WU00:FS01:0x21:Reading tar file system.xml
13:46:27:WU00:FS01:0x21:Digital signatures verified
13:46:27:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
13:46:27:WU00:FS01:0x21:Version 0.0.18
13:46:27:WU01:FS01:Upload 27.27%
13:46:33:WU01:FS01:Upload 28.87%
13:46:41:WU01:FS01:Upload 29.67%
13:46:47:WU01:FS01:Upload 30.47%
13:46:50:WU00:FS01:0x21:Completed 0 out of 520000 steps (0%)
13:46:50:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
13:46:55:WU01:FS01:Upload 32.08%
13:47:04:WU01:FS01:Upload 33.68%
13:47:11:WU01:FS01:Upload 35.29%
13:47:17:WU01:FS01:Upload 36.09%
13:47:26:WU01:FS01:Upload 37.69%
13:47:33:WU01:FS01:Upload 39.30%
13:47:35:WU00:FS01:0x21:Completed 5200 out of 520000 steps (1%)
13:47:41:WU01:FS01:Upload 40.90%
13:47:51:WU01:FS01:Upload 42.50%
13:48:01:WU01:FS01:Upload 44.11%
13:48:11:WU01:FS01:Upload 45.71%
13:48:19:WU01:FS01:Upload 47.32%
13:48:21:WU00:FS01:0x21:Completed 10400 out of 520000 steps (2%)
13:48:26:WU01:FS01:Upload 48.12%
13:48:36:WU01:FS01:Upload 49.72%
13:48:43:WU01:FS01:Upload 50.52%
13:48:51:WU01:FS01:Upload 52.13%
13:49:01:WU01:FS01:Upload 53.73%
13:49:06:WU00:FS01:0x21:Completed 15600 out of 520000 steps (3%)
13:49:07:WU01:FS01:Upload 55.33%
13:49:13:WU01:FS01:Upload 56.94%
13:49:21:WU01:FS01:Upload 58.54%
13:49:27:WU01:FS01:Upload 59.34%
13:49:40:WU01:FS01:Upload 60.95%
13:49:50:WU01:FS01:Upload 62.55%
13:49:51:WU00:FS01:0x21:Completed 20800 out of 520000 steps (4%)
13:50:00:WU01:FS01:Upload 64.16%
13:50:09:WU01:FS01:Upload 65.76%
13:50:19:WU01:FS01:Upload 67.36%
13:50:29:WU01:FS01:Upload 68.97%
13:50:35:WU01:FS01:Upload 70.57%
13:50:36:WU00:FS01:0x21:Completed 26000 out of 520000 steps (5%)
13:50:42:WU01:FS01:Upload 71.37%
13:50:48:WU01:FS01:Upload 72.18%
13:50:56:WU01:FS01:Upload 73.78%
13:51:06:WU01:FS01:Upload 75.38%
13:51:14:WU01:FS01:Upload 76.99%
13:51:21:WU00:FS01:0x21:Completed 31200 out of 520000 steps (6%)
13:51:23:WU01:FS01:Upload 78.59%
13:51:34:WU01:FS01:Upload 80.20%
13:51:41:WU01:FS01:Upload 81.00%
13:51:51:WU01:FS01:Upload 82.60%
13:52:00:WU01:FS01:Upload 84.21%
13:52:06:WU00:FS01:0x21:Completed 36400 out of 520000 steps (7%)
13:52:11:WU01:FS01:Upload 85.81%
13:52:20:WU01:FS01:Upload 87.41%
13:52:32:WU01:FS01:Upload 89.02%
13:52:42:WU01:FS01:Upload 90.62%
13:52:50:WU01:FS01:Upload 91.42%
13:52:55:WU00:FS01:0x21:Completed 41600 out of 520000 steps (8%)
13:52:56:WU01:FS01:Upload 92.22%
13:53:05:WU01:FS01:Upload 93.03%
13:53:12:WU01:FS01:Upload 93.83%
13:53:18:WU01:FS01:Upload 94.63%
13:53:27:WU01:FS01:Upload 96.23%
13:53:35:WU01:FS01:Upload 97.84%
13:53:40:WU00:FS01:0x21:Completed 46800 out of 520000 steps (9%)
13:53:45:WU01:FS01:Upload 99.44%
13:53:54:WU01:FS01:Upload complete
13:53:54:WU01:FS01:Server responded WORK_ACK (400)
13:53:54:WU01:FS01:Final credit estimate, 32510.00 points
13:53:54:WU01:FS01:Cleaning up
13:54:25:WU00:FS01:0x21:Completed 52000 out of 520000 steps (10%)
13:55:10:WU00:FS01:0x21:Completed 57200 out of 520000 steps (11%)
13:55:55:WU00:FS01:0x21:Completed 62400 out of 520000 steps (12%)
13:56:41:WU00:FS01:0x21:Completed 67600 out of 520000 steps (13%)
13:57:26:WU00:FS01:0x21:Completed 72800 out of 520000 steps (14%)
13:58:11:WU00:FS01:0x21:Completed 78000 out of 520000 steps (15%)
13:59:00:WU00:FS01:0x21:Completed 83200 out of 520000 steps (16%)
13:59:45:WU00:FS01:0x21:Completed 88400 out of 520000 steps (17%)
14:00:30:WU00:FS01:0x21:Completed 93600 out of 520000 steps (18%)
14:01:15:WU00:FS01:0x21:Completed 98800 out of 520000 steps (19%)
14:02:00:WU00:FS01:0x21:Completed 104000 out of 520000 steps (20%)
14:02:45:WU00:FS01:0x21:Completed 109200 out of 520000 steps (21%)
14:03:30:WU00:FS01:0x21:Completed 114400 out of 520000 steps (22%)
14:04:15:WU00:FS01:0x21:Completed 119600 out of 520000 steps (23%)
14:05:04:WU00:FS01:0x21:Completed 124800 out of 520000 steps (24%)
14:05:49:WU00:FS01:0x21:Completed 130000 out of 520000 steps (25%)
14:06:34:WU00:FS01:0x21:Completed 135200 out of 520000 steps (26%)
14:07:19:WU00:FS01:0x21:Completed 140400 out of 520000 steps (27%)
14:08:04:WU00:FS01:0x21:Completed 145600 out of 520000 steps (28%)
14:08:49:WU00:FS01:0x21:Completed 150800 out of 520000 steps (29%)
14:09:34:WU00:FS01:0x21:Completed 156000 out of 520000 steps (30%)
14:10:23:WU00:FS01:0x21:Completed 161200 out of 520000 steps (31%)
14:11:08:WU00:FS01:0x21:Completed 166400 out of 520000 steps (32%)
14:11:53:WU00:FS01:0x21:Completed 171600 out of 520000 steps (33%)
14:12:38:WU00:FS01:0x21:Completed 176800 out of 520000 steps (34%)
14:13:24:WU00:FS01:0x21:Completed 182000 out of 520000 steps (35%)
14:14:09:WU00:FS01:0x21:Completed 187200 out of 520000 steps (36%)
14:14:54:WU00:FS01:0x21:Completed 192400 out of 520000 steps (37%)
14:15:39:WU00:FS01:0x21:Completed 197600 out of 520000 steps (38%)
14:16:28:WU00:FS01:0x21:Completed 202800 out of 520000 steps (39%)
14:17:13:WU00:FS01:0x21:Completed 208000 out of 520000 steps (40%)
14:17:58:WU00:FS01:0x21:Completed 213200 out of 520000 steps (41%)
14:18:43:WU00:FS01:0x21:Completed 218400 out of 520000 steps (42%)
14:19:28:WU00:FS01:0x21:Completed 223600 out of 520000 steps (43%)
14:20:13:WU00:FS01:0x21:Completed 228800 out of 520000 steps (44%)
14:20:58:WU00:FS01:0x21:Completed 234000 out of 520000 steps (45%)
14:21:44:WU00:FS01:0x21:Completed 239200 out of 520000 steps (46%)
14:22:33:WU00:FS01:0x21:Completed 244400 out of 520000 steps (47%)
14:23:18:WU00:FS01:0x21:Completed 249600 out of 520000 steps (48%)
14:24:03:WU00:FS01:0x21:Completed 254800 out of 520000 steps (49%)
14:24:48:WU00:FS01:0x21:Completed 260000 out of 520000 steps (50%)
14:25:33:WU00:FS01:0x21:Completed 265200 out of 520000 steps (51%)
14:26:18:WU00:FS01:0x21:Completed 270400 out of 520000 steps (52%)
14:27:03:WU00:FS01:0x21:Completed 275600 out of 520000 steps (53%)
14:27:52:WU00:FS01:0x21:Completed 280800 out of 520000 steps (54%)
14:28:37:WU00:FS01:0x21:Completed 286000 out of 520000 steps (55%)
14:29:23:WU00:FS01:0x21:Completed 291200 out of 520000 steps (56%)
14:30:08:WU00:FS01:0x21:Completed 296400 out of 520000 steps (57%)
14:30:53:WU00:FS01:0x21:Completed 301600 out of 520000 steps (58%)
14:31:38:WU00:FS01:0x21:Completed 306800 out of 520000 steps (59%)
14:32:23:WU00:FS01:0x21:Completed 312000 out of 520000 steps (60%)
14:33:08:WU00:FS01:0x21:Completed 317200 out of 520000 steps (61%)
14:33:58:WU00:FS01:0x21:Completed 322400 out of 520000 steps (62%)
14:34:43:WU00:FS01:0x21:Completed 327600 out of 520000 steps (63%)
14:35:28:WU00:FS01:0x21:Completed 332800 out of 520000 steps (64%)
14:36:13:WU00:FS01:0x21:Completed 338000 out of 520000 steps (65%)
14:36:58:WU00:FS01:0x21:Completed 343200 out of 520000 steps (66%)
14:37:43:WU00:FS01:0x21:Completed 348400 out of 520000 steps (67%)
14:38:28:WU00:FS01:0x21:Completed 353600 out of 520000 steps (68%)
14:39:13:WU00:FS01:0x21:Completed 358800 out of 520000 steps (69%)
14:40:02:WU00:FS01:0x21:Completed 364000 out of 520000 steps (70%)
14:40:48:WU00:FS01:0x21:Completed 369200 out of 520000 steps (71%)
14:41:33:WU00:FS01:0x21:Completed 374400 out of 520000 steps (72%)
14:42:18:WU00:FS01:0x21:Completed 379600 out of 520000 steps (73%)
14:43:03:WU00:FS01:0x21:Completed 384800 out of 520000 steps (74%)
14:43:48:WU00:FS01:0x21:Completed 390000 out of 520000 steps (75%)
14:44:33:WU00:FS01:0x21:Completed 395200 out of 520000 steps (76%)
14:45:22:WU00:FS01:0x21:Completed 400400 out of 520000 steps (77%)
14:46:07:WU00:FS01:0x21:Completed 405600 out of 520000 steps (78%)
14:46:52:WU00:FS01:0x21:Completed 410800 out of 520000 steps (79%)
14:47:38:WU00:FS01:0x21:Completed 416000 out of 520000 steps (80%)
14:48:23:WU00:FS01:0x21:Completed 421200 out of 520000 steps (81%)
14:49:08:WU00:FS01:0x21:Completed 426400 out of 520000 steps (82%)
14:49:53:WU00:FS01:0x21:Completed 431600 out of 520000 steps (83%)
14:50:38:WU00:FS01:0x21:Completed 436800 out of 520000 steps (84%)
14:51:27:WU00:FS01:0x21:Completed 442000 out of 520000 steps (85%)
14:52:12:WU00:FS01:0x21:Completed 447200 out of 520000 steps (86%)
14:52:57:WU00:FS01:0x21:Completed 452400 out of 520000 steps (87%)
14:53:42:WU00:FS01:0x21:Completed 457600 out of 520000 steps (88%)
14:54:27:WU00:FS01:0x21:Completed 462800 out of 520000 steps (89%)
14:55:12:WU00:FS01:0x21:Completed 468000 out of 520000 steps (90%)
14:55:58:WU00:FS01:0x21:Completed 473200 out of 520000 steps (91%)
14:56:43:WU00:FS01:0x21:Completed 478400 out of 520000 steps (92%)
14:57:32:WU00:FS01:0x21:Completed 483600 out of 520000 steps (93%)
14:58:17:WU00:FS01:0x21:Completed 488800 out of 520000 steps (94%)
14:59:02:WU00:FS01:0x21:Completed 494000 out of 520000 steps (95%)
14:59:47:WU00:FS01:0x21:Completed 499200 out of 520000 steps (96%)
15:00:32:WU00:FS01:0x21:Completed 504400 out of 520000 steps (97%)
15:01:17:WU00:FS01:0x21:Completed 509600 out of 520000 steps (98%)
15:02:02:WU00:FS01:0x21:Completed 514800 out of 520000 steps (99%)
15:02:03:WU01:FS01:Connecting to 171.67.108.45:80
15:02:04:WU01:FS01:Assigned to work server 171.67.108.101
15:02:04:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Fiji XT [Radeon R9 Fury X] from 171.67.108.101
15:02:04:WU01:FS01:Connecting to 171.67.108.101:8080
15:02:20:WU01:FS01:Downloading 8.95MiB
15:02:27:WU01:FS01:Download 64.98%
15:02:28:WU01:FS01:Download complete
15:02:28:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13148 run:66 clone:7 gen:7 core:0x21 unit:0x00000008ab436c6559e67f816b43e052
15:02:47:WU00:FS01:0x21:Completed 520000 out of 520000 steps (100%)
15:02:51:WU00:FS01:0x21:Saving result file logfile_01.txt
15:02:51:WU00:FS01:0x21:Saving result file checkpointState.xml
15:02:54:WU00:FS01:0x21:Saving result file checkpt.crc
15:02:54:WU00:FS01:0x21:Saving result file log.txt
15:02:54:WU00:FS01:0x21:Saving result file positions.xtc
15:02:55:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
15:02:55:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:02:55:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:13147 run:16 clone:7 gen:6 core:0x21 unit:0x00000006ab436c6559e67f751974c80a
15:02:55:WU00:FS01:Uploading 13.73MiB to 171.67.108.101
15:02:55:WU00:FS01:Connecting to 171.67.108.101:8080
15:02:55:WU01:FS01:Starting
15:02:55:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/fer.ROEBROEKS/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 12724 -checkpoint 15 -gpu 0 -gpu-vendor ati
15:02:55:WU01:FS01:Started FahCore on PID 14416
15:02:55:WU01:FS01:Core PID:1968
15:02:55:WU01:FS01:FahCore 0x21 started
15:02:56:WU01:FS01:0x21:*********************** Log Started 2017-11-05T15:02:55Z ***********************
15:02:56:WU01:FS01:0x21:Project: 13148 (Run 66, Clone 7, Gen 7)
15:02:56:WU01:FS01:0x21:Unit: 0x00000008ab436c6559e67f816b43e052
15:02:56:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
15:02:56:WU01:FS01:0x21:Machine: 1
15:02:56:WU01:FS01:0x21:Reading tar file core.xml
15:02:56:WU01:FS01:0x21:Reading tar file integrator.xml
15:02:56:WU01:FS01:0x21:Reading tar file state.xml
15:02:56:WU01:FS01:0x21:Reading tar file system.xml
15:02:57:WU01:FS01:0x21:Digital signatures verified
15:02:57:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
15:02:57:WU01:FS01:0x21:Version 0.0.18
15:03:04:WU00:FS01:Upload 1.37%
15:03:10:WU00:FS01:Upload 1.82%
15:03:16:WU00:FS01:Upload 2.28%
15:03:20:WU01:FS01:0x21:Completed 0 out of 520000 steps (0%)
15:03:20:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:03:25:WU00:FS01:Upload 3.19%
15:03:33:WU00:FS01:Upload 3.64%
15:03:41:WU00:FS01:Upload 4.55%
15:03:49:WU00:FS01:Upload 5.46%
15:03:55:WU00:FS01:Upload 5.92%
15:04:06:WU01:FS01:0x21:Completed 5200 out of 520000 steps (1%)
15:04:06:WU00:FS01:Upload 6.83%
15:04:12:WU00:FS01:Upload 7.29%
15:04:21:WU00:FS01:Upload 8.20%
15:04:27:WU00:FS01:Upload 8.65%
15:04:35:WU00:FS01:Upload 9.56%
15:04:44:WU00:FS01:Upload 10.47%
15:04:51:WU01:FS01:0x21:Completed 10400 out of 520000 steps (2%)
15:04:54:WU00:FS01:Upload 11.38%
15:05:00:WU00:FS01:Upload 12.29%
15:05:07:WU00:FS01:Upload 13.20%
15:05:14:WU00:FS01:Upload 14.12%
15:05:27:WU00:FS01:Upload 15.03%
15:05:36:WU01:FS01:0x21:Completed 15600 out of 520000 steps (3%)
15:05:36:WU00:FS01:Upload 15.94%
15:05:45:WU00:FS01:Upload 16.85%
15:05:51:WU00:FS01:Upload 17.30%
15:05:57:WU00:FS01:Upload 17.76%
15:06:04:WU00:FS01:Upload 18.21%
15:06:12:WU00:FS01:Upload 18.67%
15:06:18:WU00:FS01:Upload 19.12%
15:06:21:WU01:FS01:0x21:Completed 20800 out of 520000 steps (4%)
15:06:27:WU00:FS01:Upload 20.03%
15:06:33:WU00:FS01:Upload 20.49%
15:06:39:WU00:FS01:Upload 20.95%
15:06:46:WU00:FS01:Upload 21.86%
15:06:58:WU00:FS01:Upload 23.22%
15:07:06:WU00:FS01:Upload 23.68%
15:07:06:WU01:FS01:0x21:Completed 26000 out of 520000 steps (5%)
15:07:17:WU00:FS01:Upload 24.59%
15:07:27:WU00:FS01:Upload 25.50%
15:07:38:WU00:FS01:Upload 26.41%
15:07:46:WU00:FS01:Upload 27.32%
15:07:51:WU01:FS01:0x21:Completed 31200 out of 520000 steps (6%)
15:07:52:WU00:FS01:Upload 29.14%
15:08:01:WU00:FS01:Upload 30.05%
15:08:11:WU00:FS01:Upload 30.96%
15:08:18:WU00:FS01:Upload 31.87%
15:08:24:WU00:FS01:Upload 32.33%
15:08:30:WU00:FS01:Upload 33.24%
15:08:36:WU01:FS01:0x21:Completed 36400 out of 520000 steps (7%)
15:08:41:WU00:FS01:Upload 34.15%
15:08:51:WU00:FS01:Upload 35.06%
15:09:00:WU00:FS01:Upload 35.97%
15:09:09:WU00:FS01:Upload 36.88%
15:09:15:WU00:FS01:Upload 38.25%
15:09:25:WU01:FS01:0x21:Completed 41600 out of 520000 steps (8%)
15:09:25:WU00:FS01:Upload 39.16%
15:09:36:WU00:FS01:Upload 40.07%
15:09:42:WU00:FS01:Upload 40.98%
15:09:53:WU00:FS01:Upload 42.35%
15:10:00:WU00:FS01:Upload 42.80%
15:10:06:WU00:FS01:Upload 43.26%
15:10:10:WU01:FS01:0x21:Completed 46800 out of 520000 steps (9%)
15:10:16:WU00:FS01:Upload 44.17%
15:10:25:WU00:FS01:Upload 45.08%
15:10:32:WU00:FS01:Upload 45.99%
15:10:41:WU00:FS01:Upload 46.90%
15:10:48:WU00:FS01:Upload 47.81%
15:10:54:WU01:FS01:0x21:Completed 52000 out of 520000 steps (10%)
15:10:55:WU00:FS01:Upload 49.18%
15:11:01:WU00:FS01:Upload 50.09%
15:11:10:WU00:FS01:Upload 51.45%
15:11:18:WU00:FS01:Upload 52.36%
15:11:26:WU00:FS01:Upload 53.27%
15:11:33:WU00:FS01:Upload 53.73%
15:11:39:WU01:FS01:0x21:Completed 57200 out of 520000 steps (11%)
15:11:39:WU00:FS01:Upload 54.64%
15:11:47:WU00:FS01:Upload 56.01%
15:11:57:WU00:FS01:Upload 56.92%
15:12:03:WU00:FS01:Upload 57.37%
15:12:13:WU00:FS01:Upload 58.28%
15:12:21:WU00:FS01:Upload 59.19%
15:12:24:WU01:FS01:0x21:Completed 62400 out of 520000 steps (12%)
15:12:30:WU00:FS01:Upload 60.56%
15:12:40:WU00:FS01:Upload 61.47%
15:12:49:WU00:FS01:Upload 62.38%
15:12:58:WU00:FS01:Upload 63.29%
15:13:04:WU00:FS01:Upload 64.20%
15:13:09:WU01:FS01:0x21:Completed 67600 out of 520000 steps (13%)
15:13:13:WU00:FS01:Upload 65.57%
15:13:19:WU00:FS01:Upload 66.48%
15:13:27:WU00:FS01:Upload 67.39%
15:13:33:WU00:FS01:Upload 67.85%
15:13:40:WU00:FS01:Upload 68.76%
15:13:47:WU00:FS01:Upload 69.67%
15:13:53:WU00:FS01:Upload 70.58%
15:13:54:WU01:FS01:0x21:Completed 72800 out of 520000 steps (14%)
15:14:01:WU00:FS01:Upload 71.94%
15:14:09:WU00:FS01:Upload 73.31%
15:14:16:WU00:FS01:Upload 74.68%
15:14:22:WU00:FS01:Upload 75.13%
15:14:30:WU00:FS01:Upload 76.04%
15:14:37:WU00:FS01:Upload 76.95%
15:14:39:WU01:FS01:0x21:Completed 78000 out of 520000 steps (15%)
15:14:44:WU00:FS01:Upload 78.32%
15:14:54:WU00:FS01:Upload 79.23%
15:15:05:WU00:FS01:Upload 80.59%
15:15:11:WU00:FS01:Upload 81.05%
15:15:18:WU00:FS01:Upload 81.51%
15:15:27:WU00:FS01:Upload 82.42%
15:15:28:WU01:FS01:0x21:Completed 83200 out of 520000 steps (16%)
15:15:36:WU00:FS01:Upload 83.33%
15:15:43:WU00:FS01:Upload 84.24%
15:15:50:WU00:FS01:Upload 84.69%
15:15:56:WU00:FS01:Upload 85.15%
15:16:04:WU00:FS01:Upload 86.06%
15:16:13:WU00:FS01:Upload 86.97%
15:16:13:WU01:FS01:0x21:Completed 88400 out of 520000 steps (17%)
15:16:19:WU00:FS01:Upload 87.88%
15:16:29:WU00:FS01:Upload 89.25%
15:16:35:WU00:FS01:Upload 90.16%
15:16:42:WU00:FS01:Upload 91.07%
15:16:49:WU00:FS01:Upload 91.98%
15:16:56:WU00:FS01:Upload 92.89%
15:16:58:WU01:FS01:0x21:Completed 93600 out of 520000 steps (18%)
15:17:03:WU00:FS01:Upload 93.80%
15:17:12:WU00:FS01:Upload 94.71%
15:17:19:WU00:FS01:Upload 95.62%
15:17:25:WU00:FS01:Upload 96.53%
15:17:31:WU00:FS01:Upload 97.44%
15:17:40:WU00:FS01:Upload 98.81%
15:17:43:WU01:FS01:0x21:Completed 98800 out of 520000 steps (19%)
15:17:49:WU00:FS01:Upload 99.72%
15:17:59:WU00:FS01:Upload complete
15:18:00:WU00:FS01:Server responded WORK_ACK (400)
15:18:00:WU00:FS01:Final credit estimate, 23823.00 points
15:18:00:WU00:FS01:Cleaning up
15:18:28:WU01:FS01:0x21:Completed 104000 out of 520000 steps (20%)
15:19:13:WU01:FS01:0x21:Completed 109200 out of 520000 steps (21%)
15:19:58:WU01:FS01:0x21:Completed 114400 out of 520000 steps (22%)
15:20:43:WU01:FS01:0x21:Completed 119600 out of 520000 steps (23%)
15:21:32:WU01:FS01:0x21:Completed 124800 out of 520000 steps (24%)
15:22:17:WU01:FS01:0x21:Completed 130000 out of 520000 steps (25%)
15:23:02:WU01:FS01:0x21:Completed 135200 out of 520000 steps (26%)
15:23:47:WU01:FS01:0x21:Completed 140400 out of 520000 steps (27%)
15:24:32:WU01:FS01:0x21:Completed 145600 out of 520000 steps (28%)
15:25:17:WU01:FS01:0x21:Completed 150800 out of 520000 steps (29%)
15:26:02:WU01:FS01:0x21:Completed 156000 out of 520000 steps (30%)
15:26:51:WU01:FS01:0x21:Completed 161200 out of 520000 steps (31%)
15:27:36:WU01:FS01:0x21:Completed 166400 out of 520000 steps (32%)
15:28:21:WU01:FS01:0x21:Completed 171600 out of 520000 steps (33%)
******************************* Date: 2017-11-05 *******************************
15:29:06:WU01:FS01:0x21:Completed 176800 out of 520000 steps (34%)
15:29:51:WU01:FS01:0x21:Completed 182000 out of 520000 steps (35%)
15:30:36:WU01:FS01:0x21:Completed 187200 out of 520000 steps (36%)
15:31:21:WU01:FS01:0x21:Completed 192400 out of 520000 steps (37%)
15:32:06:WU01:FS01:0x21:Completed 197600 out of 520000 steps (38%)
15:32:55:WU01:FS01:0x21:Completed 202800 out of 520000 steps (39%)
15:33:40:WU01:FS01:0x21:Completed 208000 out of 520000 steps (40%)
15:34:25:WU01:FS01:0x21:Completed 213200 out of 520000 steps (41%)
15:35:10:WU01:FS01:0x21:Completed 218400 out of 520000 steps (42%)
15:35:55:WU01:FS01:0x21:Completed 223600 out of 520000 steps (43%)
15:36:40:WU01:FS01:0x21:Completed 228800 out of 520000 steps (44%)
15:37:25:WU01:FS01:0x21:Completed 234000 out of 520000 steps (45%)
15:38:10:WU01:FS01:0x21:Completed 239200 out of 520000 steps (46%)
15:38:59:WU01:FS01:0x21:Completed 244400 out of 520000 steps (47%)
15:39:44:WU01:FS01:0x21:Completed 249600 out of 520000 steps (48%)
15:40:29:WU01:FS01:0x21:Completed 254800 out of 520000 steps (49%)
15:41:14:WU01:FS01:0x21:Completed 260000 out of 520000 steps (50%)
15:41:59:WU01:FS01:0x21:Completed 265200 out of 520000 steps (51%)
15:42:44:WU01:FS01:0x21:Completed 270400 out of 520000 steps (52%)
15:43:28:WU01:FS01:0x21:Completed 275600 out of 520000 steps (53%)
15:44:17:WU01:FS01:0x21:Completed 280800 out of 520000 steps (54%)
15:45:02:WU01:FS01:0x21:Completed 286000 out of 520000 steps (55%)
15:45:47:WU01:FS01:0x21:Completed 291200 out of 520000 steps (56%)
15:46:32:WU01:FS01:0x21:Completed 296400 out of 520000 steps (57%)
15:47:17:WU01:FS01:0x21:Completed 301600 out of 520000 steps (58%)
15:48:02:WU01:FS01:0x21:Completed 306800 out of 520000 steps (59%)
15:48:47:WU01:FS01:0x21:Completed 312000 out of 520000 steps (60%)
15:49:32:WU01:FS01:0x21:Completed 317200 out of 520000 steps (61%)
15:50:21:WU01:FS01:0x21:Completed 322400 out of 520000 steps (62%)
15:51:06:WU01:FS01:0x21:Completed 327600 out of 520000 steps (63%)
15:51:51:WU01:FS01:0x21:Completed 332800 out of 520000 steps (64%)
15:52:36:WU01:FS01:0x21:Completed 338000 out of 520000 steps (65%)
15:53:21:WU01:FS01:0x21:Completed 343200 out of 520000 steps (66%)
15:54:06:WU01:FS01:0x21:Completed 348400 out of 520000 steps (67%)
15:54:51:WU01:FS01:0x21:Completed 353600 out of 520000 steps (68%)
15:55:36:WU01:FS01:0x21:Completed 358800 out of 520000 steps (69%)
15:56:26:WU01:FS01:0x21:Completed 364000 out of 520000 steps (70%)
15:57:11:WU01:FS01:0x21:Completed 369200 out of 520000 steps (71%)
15:57:56:WU01:FS01:0x21:Completed 374400 out of 520000 steps (72%)
15:58:41:WU01:FS01:0x21:Completed 379600 out of 520000 steps (73%)
15:59:26:WU01:FS01:0x21:Completed 384800 out of 520000 steps (74%)
16:00:11:WU01:FS01:0x21:Completed 390000 out of 520000 steps (75%)
16:00:56:WU01:FS01:0x21:Completed 395200 out of 520000 steps (76%)
16:01:45:WU01:FS01:0x21:Completed 400400 out of 520000 steps (77%)
16:02:30:WU01:FS01:0x21:Completed 405600 out of 520000 steps (78%)
16:03:15:WU01:FS01:0x21:Completed 410800 out of 520000 steps (79%)
16:04:01:WU01:FS01:0x21:Completed 416000 out of 520000 steps (80%)
16:04:46:WU01:FS01:0x21:Completed 421200 out of 520000 steps (81%)
16:05:31:WU01:FS01:0x21:Completed 426400 out of 520000 steps (82%)
16:06:17:WU01:FS01:0x21:Completed 431600 out of 520000 steps (83%)
16:07:02:WU01:FS01:0x21:Completed 436800 out of 520000 steps (84%)
16:07:51:WU01:FS01:0x21:Completed 442000 out of 520000 steps (85%)
16:08:36:WU01:FS01:0x21:Completed 447200 out of 520000 steps (86%)
16:09:22:WU01:FS01:0x21:Completed 452400 out of 520000 steps (87%)
16:10:07:WU01:FS01:0x21:Completed 457600 out of 520000 steps (88%)
16:10:53:WU01:FS01:0x21:Completed 462800 out of 520000 steps (89%)
16:11:38:WU01:FS01:0x21:Completed 468000 out of 520000 steps (90%)
16:12:23:WU01:FS01:0x21:Completed 473200 out of 520000 steps (91%)
16:13:09:WU01:FS01:0x21:Completed 478400 out of 520000 steps (92%)
16:13:58:WU01:FS01:0x21:Completed 483600 out of 520000 steps (93%)
16:14:43:WU01:FS01:0x21:Completed 488800 out of 520000 steps (94%)
16:15:28:WU01:FS01:0x21:Completed 494000 out of 520000 steps (95%)
16:16:14:WU01:FS01:0x21:Completed 499200 out of 520000 steps (96%)
16:16:59:WU01:FS01:0x21:Completed 504400 out of 520000 steps (97%)
16:17:44:WU01:FS01:0x21:Completed 509600 out of 520000 steps (98%)
16:18:30:WU01:FS01:0x21:Completed 514800 out of 520000 steps (99%)
16:18:30:WU00:FS01:Connecting to 171.67.108.45:80
16:18:30:WU00:FS01:Assigned to work server 171.67.108.157
16:18:30:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Fiji XT [Radeon R9 Fury X] from 171.67.108.157
16:18:30:WU00:FS01:Connecting to 171.67.108.157:8080
16:18:31:WU00:FS01:Downloading 5.14MiB
16:18:37:WU00:FS01:Download 10.94%
16:18:43:WU00:FS01:Download 17.02%
16:18:49:WU00:FS01:Download 23.10%
16:18:55:WU00:FS01:Download 29.17%
16:19:01:WU00:FS01:Download 38.90%
16:19:09:WU00:FS01:Download 46.19%
16:19:15:WU01:FS01:0x21:Completed 520000 out of 520000 steps (100%)
16:19:16:WU00:FS01:Download 51.05%
16:19:19:WU01:FS01:0x21:Saving result file logfile_01.txt
16:19:19:WU01:FS01:0x21:Saving result file checkpointState.xml
16:19:22:WU01:FS01:0x21:Saving result file checkpt.crc
16:19:22:WU01:FS01:0x21:Saving result file log.txt
16:19:22:WU01:FS01:0x21:Saving result file positions.xtc
16:19:22:WU00:FS01:Download 54.70%
16:19:23:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
16:19:23:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:19:23:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13148 run:66 clone:7 gen:7 core:0x21 unit:0x00000008ab436c6559e67f816b43e052
16:19:23:WU01:FS01:Uploading 13.78MiB to 171.67.108.101
16:19:23:WU01:FS01:Connecting to 171.67.108.101:8080
16:19:28:WU00:FS01:Download 59.56%
16:19:32:WU01:FS01:Upload 1.36%
16:19:34:WU00:FS01:Download 64.43%
16:19:39:WU01:FS01:Upload 2.27%
16:19:41:WU00:FS01:Download 69.29%
16:19:47:WU00:FS01:Download 74.15%
16:19:49:WU01:FS01:Upload 3.17%
16:19:53:WU00:FS01:Download 80.23%
16:19:55:WU01:FS01:Upload 3.63%
16:19:59:WU00:FS01:Download 87.52%
16:20:04:WU01:FS01:Upload 4.54%
16:20:06:WU00:FS01:Download 93.60%
16:20:10:WU01:FS01:Upload 5.44%
16:20:12:WU00:FS01:Download 97.25%
16:20:15:WU00:FS01:Download complete
16:20:15:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9415 run:1834 clone:1 gen:142 core:0x21 unit:0x000000a7ab436c9d585e06dac3f45731
16:20:15:WU00:FS01:Starting
16:20:15:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/fer.ROEBROEKS/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 12724 -checkpoint 15 -gpu 0 -gpu-vendor ati
16:20:15:WU00:FS01:Started FahCore on PID 13484
16:20:15:WU00:FS01:Core PID:944
16:20:15:WU00:FS01:FahCore 0x21 started
16:20:16:WU00:FS01:0x21:*********************** Log Started 2017-11-05T16:20:15Z ***********************
16:20:16:WU00:FS01:0x21:Project: 9415 (Run 1834, Clone 1, Gen 142)
16:20:16:WU00:FS01:0x21:Unit: 0x000000a7ab436c9d585e06dac3f45731
16:20:16:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
16:20:16:WU00:FS01:0x21:Machine: 1
16:20:16:WU00:FS01:0x21:Reading tar file core.xml
16:20:16:WU00:FS01:0x21:Reading tar file integrator.xml
16:20:16:WU00:FS01:0x21:Reading tar file state.xml
16:20:16:WU00:FS01:0x21:Reading tar file system.xml
16:20:16:WU00:FS01:0x21:Digital signatures verified
16:20:16:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
16:20:16:WU00:FS01:0x21:Version 0.0.18
16:20:19:WU00:FS01:0x21:Completed 0 out of 6250000 steps (0%)
16:20:19:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:20:20:WU01:FS01:Upload 6.35%
16:20:26:WU01:FS01:Upload 6.80%
16:20:37:WU01:FS01:Upload 7.71%
16:20:47:WU01:FS01:Upload 8.62%
16:20:56:WU01:FS01:Upload 9.52%
16:21:07:WU01:FS01:Upload 10.43%
16:21:16:WU01:FS01:Upload 11.34%
16:21:27:WU01:FS01:Upload 12.25%
16:21:35:WU01:FS01:Upload 12.70%
16:21:42:WU01:FS01:Upload 13.61%
16:21:49:WU01:FS01:Upload 14.06%
16:21:58:WU01:FS01:Upload 14.97%
16:22:02:WU00:FS01:0x21:Completed 62500 out of 6250000 steps (1%)
16:22:08:WU01:FS01:Upload 15.87%
16:22:16:WU01:FS01:Upload 16.78%
16:22:22:WU01:FS01:Upload 17.23%
16:22:31:WU01:FS01:Upload 18.14%
16:22:38:WU01:FS01:Upload 18.59%
16:22:47:WU01:FS01:Upload 19.50%
16:22:58:WU01:FS01:Upload 20.41%
16:23:04:WU01:FS01:Upload 20.86%
16:23:10:WU01:FS01:Upload 21.32%
16:23:16:WU01:FS01:Upload 21.77%
16:23:24:WU01:FS01:Upload 22.68%
16:23:35:WU01:FS01:Upload 23.58%
16:23:42:WU01:FS01:Upload 24.49%
16:23:45:WU00:FS01:0x21:Completed 125000 out of 6250000 steps (2%)
16:23:50:WU01:FS01:Upload 24.94%
16:24:00:WU01:FS01:Upload 25.85%
16:24:08:WU01:FS01:Upload 26.76%
16:24:16:WU01:FS01:Upload 27.66%
16:24:24:WU01:FS01:Upload 29.03%
16:24:30:WU01:FS01:Upload 30.39%
16:24:40:WU01:FS01:Upload 31.29%
16:24:46:WU01:FS01:Upload 31.75%
16:24:52:WU01:FS01:Upload 32.20%
16:25:03:WU01:FS01:Upload 33.11%
16:25:09:WU01:FS01:Upload 34.01%
16:25:16:WU01:FS01:Upload 34.92%
16:25:22:WU01:FS01:Upload 35.83%
16:25:28:WU00:FS01:0x21:Completed 187500 out of 6250000 steps (3%)
16:25:30:WU01:FS01:Upload 36.74%
16:25:36:WU01:FS01:Upload 37.19%
16:25:42:WU01:FS01:Upload 38.10%
16:25:48:WU01:FS01:Upload 38.55%
16:25:54:WU01:FS01:Upload 39.00%
16:26:02:WU01:FS01:Upload 40.36%
16:26:12:WU01:FS01:Upload 41.27%
16:26:20:WU01:FS01:Upload 42.63%
16:26:26:WU01:FS01:Upload 43.54%
16:26:32:WU01:FS01:Upload 44.45%
16:26:43:WU01:FS01:Upload 45.35%
16:26:49:WU01:FS01:Upload 45.81%
16:27:00:WU01:FS01:Upload 46.71%
16:27:10:WU00:FS01:0x21:Completed 250000 out of 6250000 steps (4%)
16:27:12:WU01:FS01:Upload 47.62%
16:27:19:WU01:FS01:Upload 48.53%
16:27:25:WU01:FS01:Upload 49.89%
16:27:31:WU01:FS01:Upload 50.79%
16:27:41:WU01:FS01:Upload 51.70%
16:27:50:WU01:FS01:Upload 52.61%
16:28:00:WU01:FS01:Upload 53.52%
16:28:09:WU01:FS01:Upload 54.42%
16:28:19:WU01:FS01:Upload 55.33%
16:28:29:WU01:FS01:Upload 56.69%
16:28:39:WU01:FS01:Upload 58.05%
16:28:50:WU01:FS01:Upload 58.96%
16:28:53:WU00:FS01:0x21:Completed 312500 out of 6250000 steps (5%)
16:28:58:WU01:FS01:Upload 59.86%
16:29:07:WU01:FS01:Upload 61.23%
16:29:13:WU01:FS01:Upload 61.68%
16:29:23:WU01:FS01:Upload 62.59%
16:29:33:WU01:FS01:Upload 63.49%
16:29:41:WU01:FS01:Upload 63.95%
16:29:47:WU01:FS01:Upload 64.40%
16:29:53:WU01:FS01:Upload 64.85%
16:29:59:WU01:FS01:Upload 65.31%
16:30:10:WU01:FS01:Upload 66.21%
16:30:16:WU01:FS01:Upload 67.12%
16:30:25:WU01:FS01:Upload 68.03%
16:30:36:WU00:FS01:0x21:Completed 375000 out of 6250000 steps (6%)
16:30:38:WU01:FS01:Upload 68.94%
16:30:45:WU01:FS01:Upload 69.84%
16:30:51:WU01:FS01:Upload 70.30%
16:30:58:WU01:FS01:Upload 71.20%
16:31:05:WU01:FS01:Upload 72.11%
16:31:12:WU01:FS01:Upload 73.02%
16:31:22:WU01:FS01:Upload 74.38%
16:31:29:WU01:FS01:Upload 75.28%
16:31:39:WU01:FS01:Upload 76.19%
16:31:48:WU01:FS01:Upload 77.10%
16:31:54:WU01:FS01:Upload 77.55%
16:32:01:WU01:FS01:Upload 78.01%
16:32:07:WU01:FS01:Upload 78.46%
16:32:15:WU01:FS01:Upload 79.37%
16:32:19:WU00:FS01:0x21:Completed 437500 out of 6250000 steps (7%)
16:32:21:WU01:FS01:Upload 79.82%
16:32:30:WU01:FS01:Upload 80.73%
16:32:37:WU01:FS01:Upload 81.63%
16:32:44:WU01:FS01:Upload 82.09%
16:32:50:WU01:FS01:Upload 82.54%
16:32:59:WU01:FS01:Upload 83.45%
16:33:06:WU01:FS01:Upload 84.35%
16:33:17:WU01:FS01:Upload 85.26%
16:33:23:WU01:FS01:Upload 86.17%
16:33:32:WU01:FS01:Upload 87.08%
16:33:39:WU01:FS01:Upload 87.98%
16:33:45:WU01:FS01:Upload 88.89%
16:33:51:WU01:FS01:Upload 89.80%
16:33:58:WU01:FS01:Upload 90.70%
16:34:02:WU00:FS01:0x21:Completed 500000 out of 6250000 steps (8%)
16:34:07:WU01:FS01:Upload 91.61%
16:34:15:WU01:FS01:Upload 92.52%
16:34:24:WU01:FS01:Upload 93.43%
16:34:32:WU01:FS01:Upload 94.33%
16:34:39:WU01:FS01:Upload 95.24%
16:34:49:WU01:FS01:Upload 96.15%
16:34:56:WU01:FS01:Upload 97.05%
16:35:05:WU01:FS01:Upload 97.96%
16:35:12:WU01:FS01:Upload 98.41%
16:35:18:WU01:FS01:Upload 99.32%
16:35:25:WU01:FS01:Upload 100.00%
16:35:33:WU01:FS01:Upload complete
16:35:34:WU01:FS01:Server responded WORK_ACK (400)
16:35:34:WU01:FS01:Final credit estimate, 24100.00 points
16:35:34:WU01:FS01:Cleaning up
16:35:45:WU00:FS01:0x21:Completed 562500 out of 6250000 steps (9%)
16:37:28:WU00:FS01:0x21:Completed 625000 out of 6250000 steps (10%)
16:39:11:WU00:FS01:0x21:Completed 687500 out of 6250000 steps (11%)
16:40:54:WU00:FS01:0x21:Completed 750000 out of 6250000 steps (12%)
16:42:38:WU00:FS01:0x21:Completed 812500 out of 6250000 steps (13%)
16:44:21:WU00:FS01:0x21:Completed 875000 out of 6250000 steps (14%)
16:46:04:WU00:FS01:0x21:Completed 937500 out of 6250000 steps (15%)
16:47:47:WU00:FS01:0x21:Completed 1000000 out of 6250000 steps (16%)
16:49:30:WU00:FS01:0x21:Completed 1062500 out of 6250000 steps (17%)
16:51:14:WU00:FS01:0x21:Completed 1125000 out of 6250000 steps (18%)
16:52:57:WU00:FS01:0x21:Completed 1187500 out of 6250000 steps (19%)
16:54:40:WU00:FS01:0x21:Completed 1250000 out of 6250000 steps (20%)
16:56:23:WU00:FS01:0x21:Completed 1312500 out of 6250000 steps (21%)
16:58:07:WU00:FS01:0x21:Completed 1375000 out of 6250000 steps (22%)
16:59:50:WU00:FS01:0x21:Completed 1437500 out of 6250000 steps (23%)
17:01:34:WU00:FS01:0x21:Completed 1500000 out of 6250000 steps (24%)
17:03:17:WU00:FS01:0x21:Completed 1562500 out of 6250000 steps (25%)
17:05:01:WU00:FS01:0x21:Completed 1625000 out of 6250000 steps (26%)
17:06:44:WU00:FS01:0x21:Completed 1687500 out of 6250000 steps (27%)
17:08:27:WU00:FS01:0x21:Completed 1750000 out of 6250000 steps (28%)
17:10:11:WU00:FS01:0x21:Completed 1812500 out of 6250000 steps (29%)
17:11:54:WU00:FS01:0x21:Completed 1875000 out of 6250000 steps (30%)
17:13:38:WU00:FS01:0x21:Completed 1937500 out of 6250000 steps (31%)
17:15:21:WU00:FS01:0x21:Completed 2000000 out of 6250000 steps (32%)
17:17:04:WU00:FS01:0x21:Completed 2062500 out of 6250000 steps (33%)
17:18:48:WU00:FS01:0x21:Completed 2125000 out of 6250000 steps (34%)
17:20:31:WU00:FS01:0x21:Completed 2187500 out of 6250000 steps (35%)
17:22:14:WU00:FS01:0x21:Completed 2250000 out of 6250000 steps (36%)
17:23:58:WU00:FS01:0x21:Completed 2312500 out of 6250000 steps (37%)
17:25:41:WU00:FS01:0x21:Completed 2375000 out of 6250000 steps (38%)
17:27:24:WU00:FS01:0x21:Completed 2437500 out of 6250000 steps (39%)
17:29:07:WU00:FS01:0x21:Completed 2500000 out of 6250000 steps (40%)
17:30:51:WU00:FS01:0x21:Completed 2562500 out of 6250000 steps (41%)
17:32:34:WU00:FS01:0x21:Completed 2625000 out of 6250000 steps (42%)
17:34:17:WU00:FS01:0x21:Completed 2687500 out of 6250000 steps (43%)
17:36:00:WU00:FS01:0x21:Completed 2750000 out of 6250000 steps (44%)
17:37:44:WU00:FS01:0x21:Completed 2812500 out of 6250000 steps (45%)
17:39:27:WU00:FS01:0x21:Completed 2875000 out of 6250000 steps (46%)
17:41:11:WU00:FS01:0x21:Completed 2937500 out of 6250000 steps (47%)
17:42:54:WU00:FS01:0x21:Completed 3000000 out of 6250000 steps (48%)
17:44:37:WU00:FS01:0x21:Completed 3062500 out of 6250000 steps (49%)
17:46:21:WU00:FS01:0x21:Completed 3125000 out of 6250000 steps (50%)
17:48:04:WU00:FS01:0x21:Completed 3187500 out of 6250000 steps (51%)
17:49:47:WU00:FS01:0x21:Completed 3250000 out of 6250000 steps (52%)
17:51:31:WU00:FS01:0x21:Completed 3312500 out of 6250000 steps (53%)
17:53:14:WU00:FS01:0x21:Completed 3375000 out of 6250000 steps (54%)
17:54:57:WU00:FS01:0x21:Completed 3437500 out of 6250000 steps (55%)
17:56:40:WU00:FS01:0x21:Completed 3500000 out of 6250000 steps (56%)
17:58:24:WU00:FS01:0x21:Completed 3562500 out of 6250000 steps (57%)
18:00:07:WU00:FS01:0x21:Completed 3625000 out of 6250000 steps (58%)
18:01:50:WU00:FS01:0x21:Completed 3687500 out of 6250000 steps (59%)
18:03:33:WU00:FS01:0x21:Completed 3750000 out of 6250000 steps (60%)
18:05:17:WU00:FS01:0x21:Completed 3812500 out of 6250000 steps (61%)
18:07:00:WU00:FS01:0x21:Completed 3875000 out of 6250000 steps (62%)
18:08:43:WU00:FS01:0x21:Completed 3937500 out of 6250000 steps (63%)
18:10:26:WU00:FS01:0x21:Completed 4000000 out of 6250000 steps (64%)
18:12:10:WU00:FS01:0x21:Completed 4062500 out of 6250000 steps (65%)
18:13:53:WU00:FS01:0x21:Completed 4125000 out of 6250000 steps (66%)
18:15:36:WU00:FS01:0x21:Completed 4187500 out of 6250000 steps (67%)
18:17:19:WU00:FS01:0x21:Completed 4250000 out of 6250000 steps (68%)
18:19:03:WU00:FS01:0x21:Completed 4312500 out of 6250000 steps (69%)
18:20:46:WU00:FS01:0x21:Completed 4375000 out of 6250000 steps (70%)
18:22:29:WU00:FS01:0x21:Completed 4437500 out of 6250000 steps (71%)
18:24:13:WU00:FS01:0x21:Completed 4500000 out of 6250000 steps (72%)
18:25:56:WU00:FS01:0x21:Completed 4562500 out of 6250000 steps (73%)
18:27:40:WU00:FS01:0x21:Completed 4625000 out of 6250000 steps (74%)
18:29:23:WU00:FS01:0x21:Completed 4687500 out of 6250000 steps (75%)
18:31:07:WU00:FS01:0x21:Completed 4750000 out of 6250000 steps (76%)
18:32:50:WU00:FS01:0x21:Completed 4812500 out of 6250000 steps (77%)
18:34:34:WU00:FS01:0x21:Completed 4875000 out of 6250000 steps (78%)
18:36:17:WU00:FS01:0x21:Completed 4937500 out of 6250000 steps (79%)
18:38:00:WU00:FS01:0x21:Completed 5000000 out of 6250000 steps (80%)
18:38:19:FS01:Finishing
18:39:44:WU00:FS01:0x21:Completed 5062500 out of 6250000 steps (81%)
18:41:28:WU00:FS01:0x21:Completed 5125000 out of 6250000 steps (82%)
18:43:11:WU00:FS01:0x21:Completed 5187500 out of 6250000 steps (83%)
18:44:55:WU00:FS01:0x21:Completed 5250000 out of 6250000 steps (84%)
18:46:38:WU00:FS01:0x21:Completed 5312500 out of 6250000 steps (85%)
18:48:22:WU00:FS01:0x21:Completed 5375000 out of 6250000 steps (86%)
18:50:05:WU00:FS01:0x21:Completed 5437500 out of 6250000 steps (87%)
18:51:49:WU00:FS01:0x21:Completed 5500000 out of 6250000 steps (88%)
18:53:32:WU00:FS01:0x21:Completed 5562500 out of 6250000 steps (89%)
18:55:16:WU00:FS01:0x21:Completed 5625000 out of 6250000 steps (90%)
18:56:59:WU00:FS01:0x21:Completed 5687500 out of 6250000 steps (91%)
18:58:42:WU00:FS01:0x21:Completed 5750000 out of 6250000 steps (92%)
19:00:25:WU00:FS01:0x21:Completed 5812500 out of 6250000 steps (93%)
19:02:09:WU00:FS01:0x21:Completed 5875000 out of 6250000 steps (94%)
19:03:52:WU00:FS01:0x21:Completed 5937500 out of 6250000 steps (95%)
19:05:35:WU00:FS01:0x21:Completed 6000000 out of 6250000 steps (96%)
19:07:19:WU00:FS01:0x21:Completed 6062500 out of 6250000 steps (97%)
19:09:03:WU00:FS01:0x21:Completed 6125000 out of 6250000 steps (98%)
19:10:46:WU00:FS01:0x21:Completed 6187500 out of 6250000 steps (99%)
19:12:29:WU00:FS01:0x21:Completed 6250000 out of 6250000 steps (100%)
19:12:30:WU00:FS01:0x21:Saving result file logfile_01.txt
19:12:30:WU00:FS01:0x21:Saving result file checkpointState.xml
19:12:30:WU00:FS01:0x21:Saving result file checkpt.crc
19:12:30:WU00:FS01:0x21:Saving result file log.txt
19:12:30:WU00:FS01:0x21:Saving result file positions.xtc
19:12:30:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
19:12:30:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:12:30:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9415 run:1834 clone:1 gen:142 core:0x21 unit:0x000000a7ab436c9d585e06dac3f45731
19:12:30:WU00:FS01:Uploading 7.75MiB to 171.67.108.157
19:12:30:WU00:FS01:Connecting to 171.67.108.157:8080
19:12:40:WU00:FS01:Upload 2.42%
19:12:51:WU00:FS01:Upload 4.03%
19:13:02:WU00:FS01:Upload 5.64%
19:13:10:WU00:FS01:Upload 7.26%
19:13:17:WU00:FS01:Upload 8.06%
19:13:25:WU00:FS01:Upload 9.68%
19:13:31:WU00:FS01:Upload 10.48%
19:13:41:WU00:FS01:Upload 12.10%
19:13:51:WU00:FS01:Upload 13.71%
19:14:01:WU00:FS01:Upload 15.32%
19:14:07:WU00:FS01:Upload 16.13%
19:14:15:WU00:FS01:Upload 16.93%
19:14:21:WU00:FS01:Upload 17.74%
19:14:29:WU00:FS01:Upload 19.35%
19:14:37:WU00:FS01:Upload 20.97%
19:14:46:WU00:FS01:Upload 22.58%
19:14:52:WU00:FS01:Upload 24.19%
19:15:01:WU00:FS01:Upload 25.80%
19:15:08:WU00:FS01:Upload 27.42%
19:15:17:WU00:FS01:Upload 29.83%
19:15:25:WU00:FS01:Upload 31.45%
19:15:34:WU00:FS01:Upload 32.25%
19:15:42:WU00:FS01:Upload 33.06%
19:15:49:WU00:FS01:Upload 33.87%
19:15:57:WU00:FS01:Upload 34.67%
19:16:07:WU00:FS01:Upload 36.29%
19:16:17:WU00:FS01:Upload 37.90%
19:16:25:WU00:FS01:Upload 40.32%
19:16:34:WU00:FS01:Upload 41.93%
19:16:42:WU00:FS01:Upload 43.54%
19:16:57:WU00:FS01:Upload 45.96%
19:17:05:WU00:FS01:Upload 46.77%
19:17:11:WU00:FS01:Upload 47.57%
19:17:17:WU00:FS01:Upload 48.38%
19:17:25:WU00:FS01:Upload 49.19%
19:17:31:WU00:FS01:Upload 49.99%
19:17:41:WU00:FS01:Upload 51.61%
19:17:52:WU00:FS01:Upload 54.03%
19:18:00:WU00:FS01:Upload 55.64%
19:18:10:WU00:FS01:Upload 57.25%
19:18:20:WU00:FS01:Upload 58.86%
19:18:28:WU00:FS01:Upload 60.48%
19:18:37:WU00:FS01:Upload 62.09%
19:18:43:WU00:FS01:Upload 62.90%
19:18:52:WU00:FS01:Upload 64.51%
19:19:02:WU00:FS01:Upload 66.12%
19:19:12:WU00:FS01:Upload 67.73%
19:19:21:WU00:FS01:Upload 69.35%
19:19:29:WU00:FS01:Upload 70.15%
19:19:35:WU00:FS01:Upload 70.96%
19:19:41:WU00:FS01:Upload 72.57%
19:19:55:WU00:FS01:Upload 74.18%
19:20:05:WU00:FS01:Upload 75.80%
19:20:12:WU00:FS01:Upload 77.41%
19:20:21:WU00:FS01:Upload 78.22%
19:20:31:WU00:FS01:Upload 79.83%
19:20:39:WU00:FS01:Upload 80.64%
19:20:49:WU00:FS01:Upload 82.25%
19:20:56:WU00:FS01:Upload 83.86%
19:21:05:WU00:FS01:Upload 85.47%
19:21:15:WU00:FS01:Upload 87.09%
19:21:22:WU00:FS01:Upload 87.89%
19:21:29:WU00:FS01:Upload 89.50%
19:21:35:WU00:FS01:Upload 91.12%
19:21:41:WU00:FS01:Upload 91.92%
19:21:49:WU00:FS01:Upload 93.54%
19:21:55:WU00:FS01:Upload 94.34%
19:22:01:WU00:FS01:Upload 95.15%
19:22:09:WU00:FS01:Upload 96.76%
19:22:15:WU00:FS01:Upload 97.57%
19:22:21:WU00:FS01:Upload 99.18%
19:22:32:WU00:FS01:Upload complete
19:22:32:WU00:FS01:Server responded WORK_ACK (400)
19:22:32:WU00:FS01:Final credit estimate, 32502.00 points
19:22:32:WU00:FS01:Cleaning up
Mod edit: added Code tags to log file listing
Re: dos atack
The firewall code in the router is probably flagging the http connections from FAHClient to the servers because they are not from "known" browsers like IE, Firefox, Safari. etc. You can probably add an exception for FAHClient's traffic.
Re: dos atack
Your router is simply reporting that FAHClient is uploading a result or downloading a new WU to/from one of the FAH servers. Nothing is wrong ... unless you happen to have a spyware infection that's uploading something that you don't want to be uploaded/downloaded.
Since all the servers mentioned belong to FAH, you can probably correlate those messages with entries in FAH's log, depending on whether the times reported are local times or UTC times.
Fer
Re: dos atack
Post by Fer »
The strange thing is that it happened only that one day not before and not after that time.
Haven’t made any changes to the firewall.
Router time is local time (Dutch).
