FahCore_a7.exe has stopped working
Brownfox
Post by Brownfox »
Hello
I've installed the client but it is failing to process any a7 work units. As soon as it tries to executes, it fails with the message FahCore_a7.exe has stopped working and repeats every few minutes until it gives up. It processes a4 units fine.
I've reinstalled but no change.
Section of the log follows.
Thanks for any help
Steve
07:49:35:WU00:FS00:Starting
07:49:35:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/steve/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 11196 -checkpoint 15 -np 3
07:49:35:WU00:FS00:Started FahCore on PID 6416
07:49:35:WU00:FS00:Core PID:11588
07:49:35:WU00:FS00:FahCore 0xa7 started
07:49:35:WU00:FS00:0xa7:*********************** Log Started 2017-10-29T07:49:35Z ***********************
07:49:35:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:49:35:WU00:FS00:0xa7:       Type: 0xa7
07:49:35:WU00:FS00:0xa7:       Core: Gromacs
07:49:35:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
07:49:35:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
07:49:35:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:49:35:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 6416 -checkpoint 15 -np 3
07:49:35:WU00:FS00:0xa7:     Config: <none>
07:49:35:WU00:FS00:0xa7:************************************ Build *************************************
07:49:35:WU00:FS00:0xa7:    Version: 0.0.11
07:49:35:WU00:FS00:0xa7:       Date: Sep 21 2016
07:49:35:WU00:FS00:0xa7:       Time: 01:53:37
07:49:35:WU00:FS00:0xa7: Repository: Git
07:49:35:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
07:49:35:WU00:FS00:0xa7:     Branch: master
07:49:35:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
07:49:35:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
07:49:35:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
07:49:35:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
07:49:35:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
07:49:35:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
07:49:35:WU00:FS00:0xa7:       Bits: 64
07:49:35:WU00:FS00:0xa7:       Mode: Release
07:49:35:WU00:FS00:0xa7:       SIMD: sse2
07:49:35:WU00:FS00:0xa7:************************************ System ************************************
07:49:35:WU00:FS00:0xa7:        CPU: Intel(R) Pentium(R) CPU J4205 @ 1.50GHz
07:49:35:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 92 Stepping 9
07:49:35:WU00:FS00:0xa7:       CPUs: 4
07:49:35:WU00:FS00:0xa7:     Memory: 7.82GiB
07:49:35:WU00:FS00:0xa7:Free Memory: 4.51GiB
07:49:35:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:49:35:WU00:FS00:0xa7: OS Version: 6.2
07:49:35:WU00:FS00:0xa7:Has Battery: false
07:49:35:WU00:FS00:0xa7: On Battery: false
07:49:35:WU00:FS00:0xa7: UTC Offset: 0
07:49:35:WU00:FS00:0xa7:        PID: 11588
07:49:35:WU00:FS00:0xa7:        CWD: C:\Users\steve\AppData\Roaming\FAHClient\work
07:49:35:WU00:FS00:0xa7:         OS: Windows 10 Home
07:49:35:WU00:FS00:0xa7:    OS Arch: AMD64
07:49:35:WU00:FS00:0xa7:********************************************************************************
07:49:38:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:49:38:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
07:50:35:WU00:FS00:Starting
07:50:35:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/steve/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 11196 -checkpoint 15 -np 3
07:50:35:WU00:FS00:Started FahCore on PID 4180
07:50:35:WU00:FS00:Core PID:7144
07:50:35:WU00:FS00:FahCore 0xa7 started
07:50:35:WU00:FS00:0xa7:*********************** Log Started 2017-10-29T07:50:35Z ***********************
07:50:35:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:50:35:WU00:FS00:0xa7:       Type: 0xa7
07:50:35:WU00:FS00:0xa7:       Core: Gromacs
07:50:35:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
07:50:35:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
07:50:35:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:50:35:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 4180 -checkpoint 15 -np 3
07:50:35:WU00:FS00:0xa7:     Config: <none>
07:50:35:WU00:FS00:0xa7:************************************ Build *************************************
07:50:35:WU00:FS00:0xa7:    Version: 0.0.11
07:50:35:WU00:FS00:0xa7:       Date: Sep 21 2016
07:50:35:WU00:FS00:0xa7:       Time: 01:53:37
07:50:35:WU00:FS00:0xa7: Repository: Git
07:50:35:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
07:50:35:WU00:FS00:0xa7:     Branch: master
07:50:35:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
07:50:35:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
07:50:35:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
07:50:35:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
07:50:36:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
07:50:36:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
07:50:36:WU00:FS00:0xa7:       Bits: 64
07:50:36:WU00:FS00:0xa7:       Mode: Release
07:50:36:WU00:FS00:0xa7:       SIMD: sse2
07:50:36:WU00:FS00:0xa7:************************************ System ************************************
07:50:36:WU00:FS00:0xa7:        CPU: Intel(R) Pentium(R) CPU J4205 @ 1.50GHz
07:50:36:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 92 Stepping 9
07:50:36:WU00:FS00:0xa7:       CPUs: 4
07:50:36:WU00:FS00:0xa7:     Memory: 7.82GiB
07:50:36:WU00:FS00:0xa7:Free Memory: 4.51GiB
07:50:36:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:50:36:WU00:FS00:0xa7: OS Version: 6.2
07:50:36:WU00:FS00:0xa7:Has Battery: false
07:50:36:WU00:FS00:0xa7: On Battery: false
07:50:36:WU00:FS00:0xa7: UTC Offset: 0
07:50:36:WU00:FS00:0xa7:        PID: 7144
07:50:36:WU00:FS00:0xa7:        CWD: C:\Users\steve\AppData\Roaming\FAHClient\work
07:50:36:WU00:FS00:0xa7:         OS: Windows 10 Home
07:50:36:WU00:FS00:0xa7:    OS Arch: AMD64
07:50:36:WU00:FS00:0xa7:********************************************************************************
07:50:55:WARNING:WU00:FS00:FahCore returned: FAILED_3 (255 = 0xff)
07:50:55:WARNING:WU00:FS00:Too many errors, failing
07:50:55:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:13802 run:0 clone:437 gen:108 core:0xa7 unit:0x0000008e80fccb04587e9453ba3a5bbd
Re: FahCore_a7.exe has stopped working
The error being shown is a Windows error being passed onto the folding client. Can you check the Windows logs to see what error is being reported at that time? That might point towards the cause of the folding core crashing.
Brownfox
Post by Brownfox »
Well, it seems that FahCore_a7 has started to work - it is now happily processing a workunit despite me not changing anything after failing regularly for several days. I'd still like to know why it stopped before and what to do if it happens again.
There were regular errors in the Windows application log before then e.g.
Faulting application name: FahCore_a7.exe, version: 0.0.0.0, time stamp: 0x57e1e83c
Faulting module name: LIBEAY32.dll, version: 1.0.2.8, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x000000000000cda3
Faulting process id: 0x192c
Faulting application start time: 0x01d35088ae8a0b8c
Faulting application path: C:\Users\steve\AppData\Roaming\FAHClient\cores\fahwebx.stanford.edu\cores\Win32\AMD64\Core_a7.fah\FahCore_a7.exe
Faulting module path: C:\Users\steve\AppData\Roaming\FAHClient\cores\fahwebx.stanford.edu\cores\Win32\AMD64\Core_a7.fah\LIBEAY32.dll
Report Id: f5b1b9b3-0e13-41c6-988a-dc8f5823aa4f
Faulting package full name:
Faulting package-relative application ID:
It may or may not be relevant but the clocks went back from summer time (GMT+1) to winter time (GMT) this morning, and the next work unit processed after that started working.
Thank you
Steve
the BST change is not related.
There's a newer version of FAHCore_a7 that's going through the final stages of beta testing and perhaps being released. If it was and you received the update, that could explain what changed.
