Hello, so I started with FAH a few hours ago, and I already found a problem. I restarted my computer, and the Web Client page started reloading. Like it refreshed every few seconds. Reinstalled the program, and the same issue is there. Also, I want to use the FAH control, not the web client. It wont start when I run it. Any help is appreciated!
Video for 1st problem: https://goo.gl/JxHrRF
SPECS:
CPU: Intel 15-6400
GPU: EVGA GTX 1050Ti
web client reloading
Re: web client reloading
Did you allow the program in Windows firewall ? It should have prompted you to do so the first time you started FAH after installing it (it's been while since I last installed it on a new system, so I'm not sure it'd ask) ...
