Worth using to fold?
dreamscape
Post by dreamscape »
Hi all
Been away for some time, back again as I got given a machine...
It's a Core 2 Duo E8400 3Ghz with a geforce 210 PCI-E GPU. It's on eBay currently as i have zero use for it but I'm wondering if it would be better suited to folding@home?
Are the CPU/GPU still getting WU's? Is it worth it?
Re: Worth using to fold?
I dropped a Low Profile GTX 1050i in a low profile HP and it gets about 160,000 PPD. The 1050ti does not need more power than the power supply can provide, and fits.
https://www.zotac.com/us/product/graphi ... ow-profile
The 8 year old Geforce 210 will not fold.
The Core2duo should get 1,500 PPD
Without a more modern graphics card, I would not bother.
So either spend $165 on it or ebay it.
www.newegg.com/Product/Product.aspx?Ite ... 6814500417
