MB
Ricorocks
MB
Post by Ricorocks »
What MB's should I look at that support two or three (graphics cards), only intention FAH?
Thanks
Rico
Re: MB
Post by foldy »
EdOlkkola build several folding PCs and his recommendation is to use mainboards which have a big distance between the 3 graphics cards slots. So the GPUs have enough space to get fresh air. This is only needed for GPUs with high watt usage like gtx 1080 ti and if using a closed case.
Another point is to have enough pcie bandwidth speed for 3 GPUs, e.g. 3x pcie 3.0 x8. This is only needed for fast GPUs using Windows. On Linux it doesn't matter.
See this post: viewtopic.php?f=38&t=28847&p=292602&hil ... la#p292607
Or in general this post: viewtopic.php?f=38&t=30155
Ricorocks
Re: MB
Post by Ricorocks »
Thanks Foldy!
Duce H_K_
Hardware configuration: MoBo◘Gigabye X99 UD4-CF F24s
CPU◘2680V4 🔥Rosetta/SIDock
RAM◘64GB Hynix 2400 CL15
HDD◘ST1000DM003 Sata3 NCQ
GFX◘Zotac X-Gaming RTX3070 🔥Folding
VALID x86 fr◘5nan6w
Re: MB
Post by Duce H_K_ »
Giga-Byte X99 UD4 - supports up to 4 PCIE3.0-compatible devices, excluding risers (USB3, M2, etc). Also 40 lanes soc. LGA2011-3 CPU'S are supported.
My choice, but not the best one, there are known issues with this MB. But I got my luck with this upgrade:)
