Cryptobullionpools API Key and CureCoins
Locked
CoryG
Post by CoryG »
I created a F@H account and in the process registered a half dozen times or so because of invalid characters in the username. A side effect of this is that when I finally got to the point of having a valid username for the cryptobullionpools account the API key I had contained a ".1" after the username whereas the account with several million points on it from the past couple weeks of folding has no ".1" suffix. Is there any way to look up the API key required for cryptobullionpools based on my username so I can use that one, or some way to create a new API key which won't erase my existing points?
Re: Cryptobullionpools API Key and CureCoins
You'll have to ask that question of CureCoins. (They're independent of Folding@Home.)
FAH doesn't use cryptobullionpools; CureCoins uses FAH's publicly available points.
Locked
