Radeon Software Version 17.9.3 recommended
Vester
- Hardware configuration: Gigabyte Aorus Z590 Pro AX, Intel i9-10850K, 32GB Crucial Ballistix DDR4-2600, Samsung NVMe EVO 980 Pro 256GB, CoolerMaster liquid cooler ML360, Nvidia Titan X (Pascal), Dell Nvidia RTX 3080 10GB 4Y12V, Pop!_OS.
Radeon Software Version 17.9.3 has solved my issues with video crashes and "Windows is recovering..." messages. I recommend updating.
Re: Radeon Software Version 17.9.3 recommended
What is your GPU model and OS? Did you get those errors when doing something else in parallel to FAH?
Good to hear the 17.9.3 driver is working for you.
Vester
I am running a modified Dell Precision 390 with an Intel Core 2 Quad Q6700 @2.66 GHz, 8GB PC2-6400 RAM, with two video cards: Sapphire R9 290X and MSI R9 390. Running all at stock speeds and the OS is Windows 10 Pro. Photo.
No other programs were running, and I was no longer using the CPU cores to run F@h. The screen would flash blank and the system would usually recover. Sometimes it would stop running fah on the external GPU, the R9 390.
Thanks! So if another user has such problems -> get 17.9.3
