[tuto] opensuse 42.2, fah beta, installation
FAH provides a V7 client installer for Debian / Mint / Ubuntu / RedHat / CentOS / Fedora. Installation on other distros may or may not be easy but if you can offer help to others, they would appreciate it.
promeneur
Hardware configuration: openSUSE Tumbleweed, x86_64,Asrock B760M-HDV/M.2 D4, Intel Core i3-12100, 16 GB, Intel UHD Graphics 730, NVIDIA GeForce GT 1030, Edup-Love EP-9651GS Wi-Fi Bluetooth, multicard reader USB 3.0 startech.com 35fcreadbu3, Epson XP 7100, Headset Bluetooth 3.0 Philips SHQ7300
Post by promeneur »
1. check if zip2 is well installed with your opensuse.
install compat-libopenssl10 rpm from software.opensuse.org
https://software.opensuse.org/package/c ... term=ssl10
install the 3 fah rpms.
ignore message about zip2 not installed. zip2 with opensuse get a different name than the one expected by fah installer.
choose "break package..."
ignore message about corrupted package.
2. according to launch fah when system starts
move /etc/init.d/FAHClient to /usr/local/bin/
note: if in the future you want to uninstall fah packages you need to move /usr/local/bin/FAHClient to /etc/init.d/
create a fahclient.service file with this contents:
[Unit]
Description=Folding@Home V7 Client
Documentation=https://folding.stanford.edu/home/the-software/
[Service]
Type=simple
PIDFile=/var/run/fahclient.pid
ExecStart=/usr/local/bin/FAHClient -v start
ExecReload=/usr/local/bin/FAHClient -v restart
ExecStop=/usr/local/bin/FAHClient -v stop
KillMode=process
[Install]
WantedBy=multi-user.target
Put fahclient.service to /etc/systemd/system/
update its ownership and permissions as below
$ sudo chown root:root /etc/systemd/system/fahclient.service
$ sudo chmod u=rw,go=r /etc/systemd/system/fahclient.service
then
Reload systemd manager configuration
$ sudo systemctl daemon-reload
Query the status of service unit.
$ sudo systemctl status --full fahclient.service
Start and stop as a regular systemd service
$ sudo systemctl stop fahclient.service
$ sudo systemctl start fahclient.service
complete fahcontrol settings with your "name "and "passkey"
with "service manager" tool set fahclient service to "activate"
restart pc
3. if you have a problem of consuming too much core power or cpu high temperature or chassis fan noise i advise to keep "folding power" "full" and use cpulimit to limit cpu power consuming.
https://github.com/opsengine/cpulimit
usage doc: http://cpulimit.sourceforge.net/
cpulimit is supplied in the standard repo of 42.2
for example to limit to 12.5 % of cpu power and for a 4 cores cpu
put following example contents to /etc/init.d/boot.local file
# reducing cpu temp and chassis fan noise , limit to 12,5 % fah cpu power
# consumption for 4 cores (50 % / 4 = 12,5 %)
#cpulimit --exe FahCore_a3 --limit 50 &
cpulimit --exe FahCore_a4 --limit 50 &
cpulimit --exe FahCore_a7 --limit 50 &
you must have a cpulimit command for all current existing fah cores
use gkrellm with gkrellm-cpufreq to watch cpu frequencies, cpu power consuming, cpu temperatures, fan speeds
