Ubuntu 17.04, i7-7700T with `6GB RAM.
Here's my log:
*********************** Log Started 2017-09-14T01:32:22Z ***********************
01:32:22:************************* Folding@home Client *************************
01:32:22: Website: http://folding.stanford.edu/
01:32:22: Copyright: (c) 2009-2014 Stanford University
01:32:22: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:32:22: Args:
01:32:22: Config: /home/explodinglemur/config.xml
01:32:22:******************************** Build ********************************
01:32:22: Version: 7.4.4
01:32:22: Date: Mar 4 2014
01:32:22: Time: 12:02:38
01:32:22: SVN Rev: 4130
01:32:22: Branch: fah/trunk/client
01:32:22: Compiler: GNU 4.4.7
01:32:22: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
01:32:22: -fno-unsafe-math-optimizations -msse2
01:32:22: Platform: linux2 3.2.0-1-amd64
01:32:22: Bits: 64
01:32:22: Mode: Release
01:32:22:******************************* System ********************************
01:32:22: CPU: Intel(R) Core(TM) i7-7700T CPU @ 2.90GHz
01:32:22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
01:32:22: CPUs: 8
01:32:22: Memory: 15.38GiB
01:32:22:Free Memory: 14.72GiB
01:32:22: Threads: POSIX_THREADS
01:32:22: OS Version: 4.10
01:32:22:Has Battery: false
01:32:22: On Battery: false
01:32:22: UTC Offset: -7
01:32:22: PID: 9343
01:32:22: CWD: /home/explodinglemur
01:32:22: OS: Linux 4.10.0-33-generic x86_64
01:32:22: OS Arch: AMD64
01:32:22: GPUs: 0
01:32:22: CUDA: Not detected
01:32:22:***********************************************************************
01:32:22:<config>
01:32:22: <!-- Folding Slots -->
01:32:22: <slot id='0' type='CPU'/>
01:32:22:</config>
01:32:22:Connecting to assign-GPU.stanford.edu:32765
01:32:22:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:32765: No route to host
01:32:22:Connecting to assign-GPU2.stanford.edu:32765
01:32:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:32765: No route to host
01:32:22:Trying to access database...
01:32:22:Successfully acquired database lock
01:32:22:Enabled folding slot 00: READY cpu:7
01:32:22:WU00:FS00:Connecting to 171.67.108.45:8080
01:32:23:WU00:FS00:Connecting to 171.67.108.45:8080
01:32:23:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:32:23:WU00:FS00:Connecting to 171.64.65.35:80
01:32:24:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:32:24:ERROR:WU00:FS00:Exception: Could not get an assignment
01:32:24:WU00:FS00:Connecting to 171.67.108.45:8080
01:32:25:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:32:25:WU00:FS00:Connecting to 171.64.65.35:80
01:32:25:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:32:25:ERROR:WU00:FS00:Exception: Could not get an assignment
