Bad Work Unit for All a7 Cores
rbpeake
Hardware configuration: Intel® Core™ 2 Duo processor E8500, dual 3.16GHz cores, 6MB L2 Cache, 1333MHz FSB (45nm); 4096MB Corsair™ XMS2 DDR2-800 RAM; 256MB eVGA™ NVIDIA® GeForce™ 8600 GT Video Card
Post by rbpeake »
On one machine, all my a7 work fails immediately:
21:31:07:WU01:FS01:FahCore 0xa7 started
21:31:07:WU01:FS01:0xa7:*********************** Log Started 2017-09-10T21:31:07Z ***********************
21:31:07:WU01:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
21:31:07:WU01:FS01:0xa7:       Type: 0xa7
21:31:07:WU01:FS01:0xa7:       Core: Gromacs
21:31:07:WU01:FS01:0xa7:    Website: http://folding.stanford.edu/
21:31:07:WU01:FS01:0xa7:  Copyright: (c) 2009-2016 Stanford University
21:31:07:WU01:FS01:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:31:07:WU01:FS01:0xa7:       Args: -dir 01 -suffix 01 -version 704 -lifeline 1420 -checkpoint 15 -np
21:31:07:WU01:FS01:0xa7:             22
21:31:07:WU01:FS01:0xa7:     Config: <none>
21:31:07:WU01:FS01:0xa7:************************************ Build *************************************
21:31:07:WU01:FS01:0xa7:    Version: 0.0.11
21:31:07:WU01:FS01:0xa7:       Date: Sep 21 2016
21:31:07:WU01:FS01:0xa7:       Time: 01:53:37
21:31:07:WU01:FS01:0xa7: Repository: Git
21:31:07:WU01:FS01:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
21:31:07:WU01:FS01:0xa7:     Branch: master
21:31:07:WU01:FS01:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
21:31:07:WU01:FS01:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
21:31:07:WU01:FS01:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
21:31:07:WU01:FS01:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
21:31:07:WU01:FS01:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
21:31:07:WU01:FS01:0xa7:   Platform: linux2 4.6.0-1-amd64
21:31:07:WU01:FS01:0xa7:       Bits: 64
21:31:07:WU01:FS01:0xa7:       Mode: Release
21:31:07:WU01:FS01:0xa7:       SIMD: sse2
21:31:07:WU01:FS01:0xa7:************************************ System ************************************
21:31:07:WU01:FS01:0xa7:        CPU: Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
21:31:07:WU01:FS01:0xa7:     CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
21:31:07:WU01:FS01:0xa7:       CPUs: 24
21:31:07:WU01:FS01:0xa7:     Memory: 72.00GiB
21:31:07:WU01:FS01:0xa7:Free Memory: 67.03GiB
21:31:07:WU01:FS01:0xa7:    Threads: WINDOWS_THREADS
21:31:07:WU01:FS01:0xa7: OS Version: 6.1
21:31:07:WU01:FS01:0xa7:Has Battery: false
21:31:07:WU01:FS01:0xa7: On Battery: false
21:31:07:WU01:FS01:0xa7: UTC Offset: -4
21:31:07:WU01:FS01:0xa7:        PID: 4348
21:31:07:WU01:FS01:0xa7:        CWD: C:\Users\Bob\AppData\Roaming\FAHClient\work
21:31:07:WU01:FS01:0xa7:         OS: Windows 7 Professional Service Pack 1
21:31:07:WU01:FS01:0xa7:    OS Arch: AMD64
21:31:07:WU01:FS01:0xa7:********************************************************************************
21:31:07:WU01:FS01:0xa7:Project: 13805 (Run 0, Clone 1278, Gen 104)
21:31:07:WU01:FS01:0xa7:Unit: 0x0000007c80fccb045907bc09f356ea94
21:31:07:WU01:FS01:0xa7:Reading tar file core.xml
21:31:07:WU01:FS01:0xa7:Reading tar file frame104.tpr
21:31:07:WU01:FS01:0xa7:Digital signatures verified
21:31:07:WU01:FS01:0xa7:Reducing thread count from 22 to 21 to avoid domain decomposition with large prime factor 11
21:31:07:WU01:FS01:0xa7:Calling: mdrun -s frame104.tpr -o frame104.trr -x frame104.xtc -cpt 15 -nt 21 -nt 21
21:31:07:WU01:FS01:0xa7:ERROR:
21:31:07:WU01:FS01:0xa7:ERROR:-------------------------------------------------------
21:31:07:WU01:FS01:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
21:31:07:WU01:FS01:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-sse-release/gromacs-core/build/gromacs/src/gromacs/commandline/pargs.cpp, line: 680
21:31:07:WU01:FS01:0xa7:ERROR:Fatal error:
21:31:07:WU01:FS01:0xa7:ERROR:Double command line argument -nt
21:31:07:WU01:FS01:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
21:31:07:WU01:FS01:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
21:31:11:WU00:FS01:Upload 51.73%
21:31:13:WU01:FS01:0xa7:Steps: first=26000000 total=250000
21:31:17:WU00:FS01:Upload 96.99%
21:31:17:WU01:FS01:0xa7:Completed 1 out of 250000 steps (0%)
21:31:17:WU00:FS01:Upload complete
21:31:17:WU00:FS01:Server responded WORK_ACK (400)
21:31:17:WU00:FS01:Cleaning up
21:31:19:WU01:FS01:0xa7:Saving result file ..\logfile_01.txt
21:31:19:WU01:FS01:0xa7:Saving result file frame104.trr
21:31:19:WU01:FS01:0xa7:Saving result file frame104.xtc
21:31:19:WU01:FS01:0xa7:Saving result file md.log
21:31:19:WU01:FS01:0xa7:Saving result file science.log
21:31:19:WU01:FS01:0xa7:Folding@home Core Shutdown: BAD_WORK_UNIT
21:31:20:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:31:20:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13805 run:0 clone:1278 gen:104 core:0xa7 unit:0x0000007c80fccb045907bc09f356ea94
21:31:20:WU01:FS01:Uploading 6.80MiB to 128.252.203.4
21:31:20:WU01:FS01:Connecting to 128.252.203.4:8080
21:31:20:WU00:FS01:Connecting to 171.67.108.45:8080
21:31:21:WU00:FS01:Assigned to work server 155.247.166.220
21:31:21:WU00:FS01:Requesting new work unit for slot 01: READY cpu:23 from 155.247.166.220
21:31:21:WU00:FS01:Connecting to 155.247.166.220:8080
21:31:21:WU00:FS01:Downloading 334.35KiB
21:31:21:WU00:FS01:Download complete
21:31:22:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8646 run:979 clone:0 gen:20 core:0xa4 unit:0x000000170002894c57e0c3b012ed070c
21:31:22:WU00:FS01:Starting
21:31:22:WARNING:WU00:FS01:AS lowered CPUs from 23 to 20
21:31:22:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Bob\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 3656 -checkpoint 15 -np 20
21:31:22:WU00:FS01:Started FahCore on PID 5044
21:31:22:WU00:FS01:Core PID:5000
21:31:22:WU00:FS01:FahCore 0xa4 started
Re: Bad Work Unit for All a7 Cores
a7 does not run in a virtual machine, (a4 does) are you virtualized?
In the advanced client have you tried 20 CPUs? -nt (number of threads) keeps counting down, but then gets confused by multiple -nt parameters
(i suspect a line where it goes from 23 to 22 was omitted)
It goes down from 22 to avoid a multiple of a large prime, 11
Sadly 21 is also a multiple of a large prime, 7
20 would have 5 as the largest prime, 5 is often OK.
if not, the number of CPUs as 16 is a sure thing.
if you wanted you could make 2 CPU slots one 16 and one 6, neither would have large primes.
In the a4 setup you can see it drop from 23 CPUs to 20, which works.
As to why you have 23 CPUs, I suspect one of two scenarios, one is that you have Folding on medium (number of CPUs minus one) or two, you have a GPU you did not tell us about. If it is the first you could change to Full which is 24 CPUs, which has no large prime factors. If you have a GPU, turning the CPU client down to 20 CPUs is best.
rbpeake
Post by rbpeake »
I have one GPU folding, which may be when the problem started. Using 24 cores was not a problem. I am using the beta client, would this not automatically adjust the remaining cores to a stable configuration? If not, what do I need to do to fix the problem? Is it a setting under "Configuration"?
Thanks!
rbpeake
Post by rbpeake »
I found the setting. Will force it to 20 cores for CPU, presumably setting to 22 will not work because 11 is a large prime number. Thanks.
If you worry about the 3 idle cores, you can make a second CPU slot with CPUS = 3, but it won't add much.
Glad you got it fixed!
Do you pass arguments manually using extra-core-args in advanced slot settings ?
There is a known issue with Core_A7, https://github.com/FoldingAtHome/fah-issues/issues/1179.
