Assignment Servers 171.67.108.45 and 171.64.65.35:80
Robby_Firefox
Hardware configuration: Homebuilt Windows 10
Intel Core i7-4770 ~ started in early 2014 or 2015
32 GB RAM (up from 8 GB in 2018)
64-Bit Operating System
On 31 Mar 2020, installed a GigaByte GEFORCE GTX 1660 GPU
Post by Robby_Firefox »
FYI,
Am going on a day without a new item to fold. My client has been repeatedly polling the two above noted assignment servers for some work.
The last one I know finished this morning CDT before daybreak; been idling ever since.
- Robby
Processor: I7-4770 Memory: 32Gig RAM GPU: GeForce GTX 1660 MB: GigaByte GA-B85M-D3H
Re: Assignment Servers 171.67.108.45 and 171.64.65.35:80
Post the first 100 or so lines of your log file. Without it and the information it contains about how your client is set up, no one can give you any reason for the lack of assignments.
Robby_Firefox
Hello,
First below is what is in the current FAH control active log, from since I restarted the computer around 1300 GMT.
Below that, I'll dig out the code from the last successful run before this. By the way, I have made no known software changes here, especially to this client.
Yesterday, I replaced the stock fan for the CPU with a bigger/better one, and added another PCI card for USB 3 capability. Is the new card is causing the issue? Unlikely but with computers... The new fan is so much better I increased the folding speed to "medium" from slow, with no big increase in CPU temperature. NICE!!
In the meanwhile, I'll check my login credentials and make sure nothing was changed. If you see something that needs to be done on my end, please let me know. I am the admin user of this Windows 10 computer, and am running FAH as a service.
- Robby
*********************** Log Started 2017-09-06T13:15:40Z ***********************
13:15:40:************************* Folding@home Client *************************
13:15:40:      Website: http://folding.stanford.edu/
13:15:40:    Copyright: (c) 2009-2014 Stanford University
13:15:40:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:15:40:         Args:
13:15:40:       Config: C:/Users/Robby/AppData/Roaming/FAHClient/config.xml
13:15:40:******************************** Build ********************************
13:15:40:      Version: 7.4.4
13:15:40:         Date: Mar 4 2014
13:15:40:         Time: 20:26:54
13:15:40:      SVN Rev: 4130
13:15:40:       Branch: fah/trunk/client
13:15:40:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
13:15:40:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
13:15:40:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
13:15:40:     Platform: win32 XP
13:15:40:         Bits: 32
13:15:40:         Mode: Release
13:15:40:******************************* System ********************************
13:15:40:          CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
13:15:40:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
13:15:40:         CPUs: 8
13:15:40:       Memory: 7.89GiB
13:15:40:  Free Memory: 6.47GiB
13:15:40:      Threads: WINDOWS_THREADS
13:15:40:   OS Version: 6.2
13:15:40:  Has Battery: false
13:15:40:   On Battery: false
13:15:40:   UTC Offset: -5
13:15:40:          PID: 4960
13:15:40:          CWD: C:/WINDOWS/system32
13:15:40:           OS: Windows 10 Home
13:15:40:      OS Arch: AMD64
13:15:40:         GPUs: 0
13:15:40:         CUDA: Not detected
13:15:40:Win32 Service: true
13:15:40:***********************************************************************
13:15:40:<config>
13:15:40:  <!-- Folding Slot Configuration -->
13:15:40:  <cause v='ALZHEIMERS'/>
13:15:40:
13:15:40:  <!-- Network -->
13:15:40:  <proxy v=':8080'/>
13:15:40:
13:15:40:  <!-- User Information -->
13:15:40:  <passkey v='********************************'/>
13:15:40:  <team v='341'/>
13:15:40:  <user v='Robby'/>
13:15:40:
13:15:40:  <!-- Folding Slots -->
13:15:40:  <slot id='0' type='CPU'/>
13:15:40:</config>
13:15:40:Trying to access database...
13:15:41:Successfully acquired database lock
13:15:41:Enabled folding slot 00: READY cpu:7
13:15:41:WU00:FS00:Connecting to 171.67.108.45:8080
13:15:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
13:15:42:WU00:FS00:Connecting to 171.64.65.35:80
13:15:43:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
13:15:43:ERROR:WU00:FS00:Exception: Could not get an assignment
13:15:43:WU00:FS00:Connecting to 171.67.108.45:8080
13:15:44:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
13:15:44:WU00:FS00:Connecting to 171.64.65.35:80
13:15:45:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
13:15:45:ERROR:WU00:FS00:Exception: Could not get an assignment
13:16:44:WU00:FS00:Connecting to 171.67.108.45:8080
13:16:46:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
13:16:46:WU00:FS00:Connecting to 171.64.65.35:80
13:16:48:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
13:16:48:ERROR:WU00:FS00:Exception: Could not get an assignment
13:18:21:WU00:FS00:Connecting to 171.67.108.45:8080
13:18:21:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
13:18:21:WU00:FS00:Connecting to 171.64.65.35:80
13:18:22:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
13:18:22:ERROR:WU00:FS00:Exception: Could not get an assignment
13:20:58:WU00:FS00:Connecting to 171.67.108.45:8080
13:20:58:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
13:20:58:WU00:FS00:Connecting to 171.64.65.35:80
13:20:59:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
13:20:59:ERROR:WU00:FS00:Exception: Could not get an assignment
13:25:12:WU00:FS00:Connecting to 171.67.108.45:8080
13:25:13:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
13:25:13:WU00:FS00:Connecting to 171.64.65.35:80
13:25:13:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
13:25:13:ERROR:WU00:FS00:Exception: Could not get an assignment
13:32:04:WU00:FS00:Connecting to 171.67.108.45:8080
13:32:04:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
13:32:04:WU00:FS00:Connecting to 171.64.65.35:80
13:32:04:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
13:32:04:ERROR:WU00:FS00:Exception: Could not get an assignment
13:43:09:WU00:FS00:Connecting to 171.67.108.45:8080
13:43:10:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
13:43:10:WU00:FS00:Connecting to 171.64.65.35:80
13:43:10:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
13:43:10:ERROR:WU00:FS00:Exception: Could not get an assignment
14:01:06:WU00:FS00:Connecting to 171.67.108.45:8080
14:01:06:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:01:06:WU00:FS00:Connecting to 171.64.65.35:80
14:01:07:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:01:07:ERROR:WU00:FS00:Exception: Could not get an assignment
14:30:08:WU00:FS00:Connecting to 171.67.108.45:8080
14:30:09:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:30:09:WU00:FS00:Connecting to 171.64.65.35:80
14:30:09:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:30:09:ERROR:WU00:FS00:Exception: Could not get an assignment
15:17:07:WU00:FS00:Connecting to 171.67.108.45:8080
15:17:08:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
15:17:08:WU00:FS00:Connecting to 171.64.65.35:80
15:17:08:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
15:17:08:ERROR:WU00:FS00:Exception: Could not get an assignment
16:33:08:WU00:FS00:Connecting to 171.67.108.45:8080
16:33:08:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
16:33:08:WU00:FS00:Connecting to 171.64.65.35:80
16:33:09:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
16:33:09:ERROR:WU00:FS00:Exception: Could not get an assignment
18:36:08:WU00:FS00:Connecting to 171.67.108.45:8080
18:36:12:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:36:12:WU00:FS00:Connecting to 171.64.65.35:80
18:36:16:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:36:16:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2017-09-06 *******************************
21:55:08:WU00:FS00:Connecting to 171.67.108.45:8080
21:55:09:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
21:55:09:WU00:FS00:Connecting to 171.64.65.35:80
21:55:09:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:55:09:ERROR:WU00:FS00:Exception: Could not get an assignment
03:17:08:WU00:FS00:Connecting to 171.67.108.45:8080
03:17:09:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
03:17:09:WU00:FS00:Connecting to 171.64.65.35:80
03:17:09:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
03:17:09:ERROR:WU00:FS00:Exception: Could not get an assignment
03:39:17:FS00:Paused
03:39:22:FS00:Unpaused
03:39:23:WU00:FS00:Connecting to 171.67.108.45:8080
03:39:23:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
03:39:23:WU00:FS00:Connecting to 171.64.65.35:80
03:39:23:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
03:39:23:ERROR:WU00:FS00:Exception: Could not get an assignment
03:41:00:WU00:FS00:Connecting to 171.67.108.45:8080
03:41:00:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
03:41:00:WU00:FS00:Connecting to 171.64.65.35:80
03:41:01:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
03:41:01:ERROR:WU00:FS00:Exception: Could not get an assignment
03:43:37:WU00:FS00:Connecting to 171.67.108.45:8080
03:43:37:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
03:43:37:WU00:FS00:Connecting to 171.64.65.35:80
03:43:38:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
03:43:38:ERROR:WU00:FS00:Exception: Could not get an assignment
03:47:51:WU00:FS00:Connecting to 171.67.108.45:8080
03:47:52:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
03:47:52:WU00:FS00:Connecting to 171.64.65.35:80
03:47:52:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
03:47:52:ERROR:WU00:FS00:Exception: Could not get an assignment
03:54:43:WU00:FS00:Connecting to 171.67.108.45:8080
03:54:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
03:54:43:WU00:FS00:Connecting to 171.64.65.35:80
03:54:43:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
03:54:43:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2017-09-07 *******************************
04:05:48:WU00:FS00:Connecting to 171.67.108.45:8080
04:05:49:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
04:05:49:WU00:FS00:Connecting to 171.64.65.35:80
04:05:49:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
04:05:49:ERROR:WU00:FS00:Exception: Could not get an assignment
04:23:45:WU00:FS00:Connecting to 171.67.108.45:8080
04:23:55:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
04:23:55:WU00:FS00:Connecting to 171.64.65.35:80
04:24:16:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Failed to connect to 171.64.65.35:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:24:16:ERROR:WU00:FS00:Exception: Could not get an assignment
Last successful run....
*********************** Log Started 2017-09-06T05:45:04Z ***********************
05:45:04:************************* Folding@home Client *************************
05:45:04:      Website: http://folding.stanford.edu/
05:45:04:    Copyright: (c) 2009-2014 Stanford University
05:45:04:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:45:04:         Args:
05:45:04:       Config: C:/Users/Robby/AppData/Roaming/FAHClient/config.xml
05:45:04:******************************** Build ********************************
05:45:04:      Version: 7.4.4
05:45:04:         Date: Mar 4 2014
05:45:04:         Time: 20:26:54
05:45:04:      SVN Rev: 4130
05:45:04:       Branch: fah/trunk/client
05:45:04:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
05:45:04:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
05:45:04:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
05:45:04:     Platform: win32 XP
05:45:04:         Bits: 32
05:45:04:         Mode: Release
05:45:04:******************************* System ********************************
05:45:04:          CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
05:45:04:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
05:45:04:         CPUs: 8
05:45:04:       Memory: 7.89GiB
05:45:04:  Free Memory: 6.54GiB
05:45:04:      Threads: WINDOWS_THREADS
05:45:04:   OS Version: 6.2
05:45:04:  Has Battery: false
05:45:04:   On Battery: false
05:45:04:   UTC Offset: -5
05:45:04:          PID: 3852
05:45:04:          CWD: C:/WINDOWS/system32
05:45:04:           OS: Windows 10 Home
05:45:04:      OS Arch: AMD64
05:45:04:         GPUs: 0
05:45:04:         CUDA: Not detected
05:45:04:Win32 Service: true
05:45:04:***********************************************************************
05:45:04:<config>
05:45:04:  <!-- Folding Slot Configuration -->
05:45:04:  <cause v='ALZHEIMERS'/>
05:45:04:
05:45:04:  <!-- Network -->
05:45:04:  <proxy v=':8080'/>
05:45:04:
05:45:04:  <!-- User Information -->
05:45:04:  <passkey v='********************************'/>
05:45:04:  <team v='341'/>
05:45:04:  <user v='Robby'/>
05:45:04:
05:45:04:  <!-- Folding Slots -->
05:45:04:  <slot id='0' type='CPU'/>
05:45:04:</config>
05:45:04:Trying to access database...
05:45:04:Successfully acquired database lock
05:45:04:Enabled folding slot 00: READY cpu:7
05:45:04:WU00:FS00:Starting
05:45:04:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Robby/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 3852 -checkpoint 15 -np 7 -service
05:45:05:WU00:FS00:Started FahCore on PID 5148
05:45:05:WU00:FS00:Core PID:5292
05:45:05:WU00:FS00:FahCore 0xa4 started
05:45:06:WU00:FS00:0xa4:
05:45:06:WU00:FS00:0xa4:*------------------------------*
05:45:06:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
05:45:06:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:45:06:WU00:FS00:0xa4:Preparing to commence simulation
05:45:06:WU00:FS00:0xa4:- Ensuring status. Please wait.
05:45:16:WU00:FS00:0xa4:- Looking at optimizations...
05:45:16:WU00:FS00:0xa4:- Working with standard loops on this execution.
05:45:16:WU00:FS00:0xa4:- Previous termination of core was improper.
05:45:16:WU00:FS00:0xa4:- Going to use standard loops.
05:45:16:WU00:FS00:0xa4:- Files status OK
05:45:18:WU00:FS00:0xa4:- Expanded 817511 -> 1926548 (decompressed 235.6 percent)
05:45:18:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=817511 data_size=1926548, decompressed_data_size=1926548 diff=0
05:45:18:WU00:FS00:0xa4:- Digital signature verified
05:45:18:WU00:FS00:0xa4:Project: 8698 (Run 0, Clone 312, Gen 70)
05:45:18:WU00:FS00:0xa4:Entering M.D.
05:45:25:WU00:FS00:0xa4:Using Gromacs checkpoints
05:45:25:WU00:FS00:0xa4:Mapping NT from 7 to 7
05:45:31:WU00:FS00:0xa4:Resuming from checkpoint
05:45:31:WU00:FS00:0xa4:Verified 00/wudata_01.log
05:45:34:WU00:FS00:0xa4:Verified 00/wudata_01.trr
05:45:34:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
05:45:34:WU00:FS00:0xa4:Verified 00/wudata_01.edr
05:45:34:WU00:FS00:0xa4:Completed 1311640 out of 2500000 steps  (52%)
05:50:07:WU00:FS00:0xa4:Completed 1325000 out of 2500000 steps  (53%)
05:59:11:WU00:FS00:0xa4:Completed 1350000 out of 2500000 steps  (54%)
06:07:19:WU00:FS00:0xa4:Completed 1375000 out of 2500000 steps  (55%)
06:15:24:WU00:FS00:0xa4:Completed 1400000 out of 2500000 steps  (56%)
06:23:34:WU00:FS00:0xa4:Completed 1425000 out of 2500000 steps  (57%)
06:32:26:WU00:FS00:0xa4:Completed 1450000 out of 2500000 steps  (58%)
06:40:20:WU00:FS00:0xa4:Completed 1475000 out of 2500000 steps  (59%)
06:47:58:WU00:FS00:0xa4:Completed 1500000 out of 2500000 steps  (60%)
06:55:36:WU00:FS00:0xa4:Completed 1525000 out of 2500000 steps  (61%)
07:03:13:WU00:FS00:0xa4:Completed 1550000 out of 2500000 steps  (62%)
07:10:50:WU00:FS00:0xa4:Completed 1575000 out of 2500000 steps  (63%)
07:18:29:WU00:FS00:0xa4:Completed 1600000 out of 2500000 steps  (64%)
07:26:10:WU00:FS00:0xa4:Completed 1625000 out of 2500000 steps  (65%)
07:33:52:WU00:FS00:0xa4:Completed 1650000 out of 2500000 steps  (66%)
07:41:30:WU00:FS00:0xa4:Completed 1675000 out of 2500000 steps  (67%)
07:49:08:WU00:FS00:0xa4:Completed 1700000 out of 2500000 steps  (68%)
07:56:45:WU00:FS00:0xa4:Completed 1725000 out of 2500000 steps  (69%)
08:04:32:WU00:FS00:0xa4:Completed 1750000 out of 2500000 steps  (70%)
08:12:14:WU00:FS00:0xa4:Completed 1775000 out of 2500000 steps  (71%)
08:19:59:WU00:FS00:0xa4:Completed 1800000 out of 2500000 steps  (72%)
08:27:40:WU00:FS00:0xa4:Completed 1825000 out of 2500000 steps  (73%)
08:35:18:WU00:FS00:0xa4:Completed 1850000 out of 2500000 steps  (74%)
08:42:53:WU00:FS00:0xa4:Completed 1875000 out of 2500000 steps  (75%)
08:50:30:WU00:FS00:0xa4:Completed 1900000 out of 2500000 steps  (76%)
08:58:10:WU00:FS00:0xa4:Completed 1925000 out of 2500000 steps  (77%)
09:05:57:WU00:FS00:0xa4:Completed 1950000 out of 2500000 steps  (78%)
09:13:35:WU00:FS00:0xa4:Completed 1975000 out of 2500000 steps  (79%)
09:21:11:WU00:FS00:0xa4:Completed 2000000 out of 2500000 steps  (80%)
09:29:06:WU00:FS00:0xa4:Completed 2025000 out of 2500000 steps  (81%)
09:36:56:WU00:FS00:0xa4:Completed 2050000 out of 2500000 steps  (82%)
09:44:42:WU00:FS00:0xa4:Completed 2075000 out of 2500000 steps  (83%)
09:52:24:WU00:FS00:0xa4:Completed 2100000 out of 2500000 steps  (84%)
10:00:08:WU00:FS00:0xa4:Completed 2125000 out of 2500000 steps  (85%)
10:07:50:WU00:FS00:0xa4:Completed 2150000 out of 2500000 steps  (86%)
10:15:39:WU00:FS00:0xa4:Completed 2175000 out of 2500000 steps  (87%)
10:23:34:WU00:FS00:0xa4:Completed 2200000 out of 2500000 steps  (88%)
10:31:21:WU00:FS00:0xa4:Completed 2225000 out of 2500000 steps  (89%)
10:39:06:WU00:FS00:0xa4:Completed 2250000 out of 2500000 steps  (90%)
10:46:46:WU00:FS00:0xa4:Completed 2275000 out of 2500000 steps  (91%)
10:54:26:WU00:FS00:0xa4:Completed 2300000 out of 2500000 steps  (92%)
11:02:04:WU00:FS00:0xa4:Completed 2325000 out of 2500000 steps  (93%)
11:09:57:WU00:FS00:0xa4:Completed 2350000 out of 2500000 steps  (94%)
11:17:38:WU00:FS00:0xa4:Completed 2375000 out of 2500000 steps  (95%)
11:25:18:WU00:FS00:0xa4:Completed 2400000 out of 2500000 steps  (96%)
11:32:54:WU00:FS00:0xa4:Completed 2425000 out of 2500000 steps  (97%)
11:40:29:WU00:FS00:0xa4:Completed 2450000 out of 2500000 steps  (98%)
11:48:09:WU00:FS00:0xa4:Completed 2475000 out of 2500000 steps  (99%)
11:48:10:WU01:FS00:Connecting to 171.67.108.45:8080
11:48:11:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:48:11:WU01:FS00:Connecting to 171.64.65.35:80
11:48:11:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
11:48:11:ERROR:WU01:FS00:Exception: Could not get an assignment
11:48:12:WU01:FS00:Connecting to 171.67.108.45:8080
11:48:12:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:48:12:WU01:FS00:Connecting to 171.64.65.35:80
11:48:12:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
11:48:12:ERROR:WU01:FS00:Exception: Could not get an assignment
11:49:12:WU01:FS00:Connecting to 171.67.108.45:8080
11:49:12:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:49:12:WU01:FS00:Connecting to 171.64.65.35:80
11:49:13:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
11:49:13:ERROR:WU01:FS00:Exception: Could not get an assignment
11:50:49:WU01:FS00:Connecting to 171.67.108.45:8080
11:50:49:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:50:49:WU01:FS00:Connecting to 171.64.65.35:80
11:50:50:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
11:50:50:ERROR:WU01:FS00:Exception: Could not get an assignment
11:53:26:WU01:FS00:Connecting to 171.67.108.45:8080
11:53:27:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:53:27:WU01:FS00:Connecting to 171.64.65.35:80
11:53:30:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
11:53:30:ERROR:WU01:FS00:Exception: Could not get an assignment
11:55:47:WU00:FS00:0xa4:Completed 2500000 out of 2500000 steps  (100%)
11:55:48:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
11:55:58:WU00:FS00:0xa4:
11:55:58:WU00:FS00:0xa4:Finished Work Unit:
11:55:58:WU00:FS00:0xa4:- Reading up to 5302656 from "00/wudata_01.trr": Read 5302656
11:55:58:WU00:FS00:0xa4:trr file hash check passed.
11:55:58:WU00:FS00:0xa4:- Reading up to 976300 from "00/wudata_01.xtc": Read 976300
11:55:58:WU00:FS00:0xa4:xtc file hash check passed.
11:55:58:WU00:FS00:0xa4:edr file hash check passed.
11:55:58:WU00:FS00:0xa4:logfile size: 61465
11:55:59:WU00:FS00:0xa4:Leaving Run
11:55:59:WU00:FS00:0xa4:- Writing 6378125 bytes of core data to disk...
11:56:00:WU00:FS00:0xa4:Done: 6377613 -> 5463861 (compressed to 85.6 percent)
11:56:00:WU00:FS00:0xa4:  ... Done.
11:56:03:WU00:FS00:0xa4:- Shutting down core
11:56:03:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
11:56:03:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:56:03:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8698 run:0 clone:312 gen:70 core:0xa4 unit:0x0000004d0002894c58237f66ccfccc80
11:56:03:WU00:FS00:Uploading 5.21MiB to 155.247.166.220
11:56:03:WU00:FS00:Connecting to 155.247.166.220:8080
11:56:09:WU00:FS00:Upload 51.57%
11:56:15:WU00:FS00:Upload complete
11:56:15:WU00:FS00:Server responded WORK_ACK (400)
11:56:15:WU00:FS00:Final credit estimate, 6335.00 points
11:56:16:WU00:FS00:Cleaning up
11:57:41:WU01:FS00:Connecting to 171.67.108.45:8080
11:57:41:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:57:41:WU01:FS00:Connecting to 171.64.65.35:80
11:57:41:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
11:57:41:ERROR:WU01:FS00:Exception: Could not get an assignment
12:04:32:WU01:FS00:Connecting to 171.67.108.45:8080
12:04:32:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
12:04:32:WU01:FS00:Connecting to 171.64.65.35:80
12:04:33:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
12:04:33:ERROR:WU01:FS00:Exception: Could not get an assignment
12:15:38:WU01:FS00:Connecting to 171.67.108.45:8080
12:15:38:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
12:15:38:WU01:FS00:Connecting to 171.64.65.35:80
12:15:38:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
12:15:38:ERROR:WU01:FS00:Exception: Could not get an assignment
12:33:35:WU01:FS00:Connecting to 171.67.108.45:8080
12:33:35:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
12:33:35:WU01:FS00:Connecting to 171.64.65.35:80
12:33:36:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
12:33:36:ERROR:WU01:FS00:Exception: Could not get an assignment
13:02:37:WU01:FS00:Connecting to 171.67.108.45:8080
13:02:37:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
13:02:37:WU01:FS00:Connecting to 171.64.65.35:80
13:02:38:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
13:02:38:ERROR:WU01:FS00:Exception: Could not get an assignment
From the log you have the folding client at the default settings. That results in a request for a WU that will run on 7 CPU threads. There are only a few projects left that will assign to that value. There are three options to get work assigned on a regular basis:
1. Change the power slider from the default of Medium to either Full or Light. The first will use all 8 threads available from your CPU, the second will use half or 4 threads.
2. Set the number of threads you want to use manually by using Configure in FAHControl. You select the Slots tab, click on the CPU slot and then Edit. After setting the number save the changed configuration.
3. Install the public beta version of the folding client, 7.4.16. It has new code to negotiate with the AS for WU's using as many CPU threads as possible, up t the number set in the request for a new WU.
Robby_Firefox
Hello Joe,
Thanks a bunch for the information and feedback. Sorry not getting back to you until now. Had to sleep, work all day today, and just got home from an evening football game.
Interestingly, I have been doing all of my folding before on the "light" mode, mainly to keep from overheating my CPU. Since changing the cooler to a newer one, the CPU has been staying up to 60-70C, compared to above 70-80C with old one on light mode. I'll see how this works at high speed, as don't want to harm the computer if fan failure occurs (it supposed to shut itself down in that event - I hope). Did not know that the client's settings directly affected what would be worked on. The job that came in ~11K points if the machine can finish it in a little over 8 hours. Much larger points potential wise than the jobs I've had before. I have not worked with the settings very much, time to experiment in the future.
Also thanks for letting me know about the beta client out there. In a day off next week, may give it a try. I found it in the Forum and downloaded it.
Regards,
Robby
There is some history behind those CPU thread count settings. Some years ago, well before when the 7.4.4 version of the client was released, testing showed that the Gromacs code the CPU folding cores are based on had issues with multiples of "large" prime numbers. "Large" was determined at the time to be 11 or greater primes. There was code to adjust WU's requested for many of those values to usable ones, i.e. 13 would run a WU on 12 threads. Multiples of 7 were known to cause problems with some projects and they were restricted from assigning to those values, but for others the failure rate was deemed acceptable and those projects would assign to requests for 7.
Since the release of 7.4.4, an increasing number of CPU projects were found to have issues with multiples of 7. So the decision was made to no longer assign to them. As older projects that would assign to 7 and its multiples have finished up, fewer WU's have been available and occasionally all WU's from those projects are out and waiting for returns to generate the next WU's.
In addition, some projects with smaller proteins were found a couple years ago that have problems with multiples of 5 for CPU thread settings. So the current rules for CPU thread settings are multiples of 2, 3 and sometimes 5. New code was developed for the AS's and the beta client to handle that by assigning an available WU that used as many threads as possible up to the number set in the request instead of having a smaller blacklist and table of numbers that those requests would be mapped down to.
Back to the beta. Hopefully you found it through the announcement topic. That has been edited to include a couple known issues. First is that the default theme and some others do not work on Windows, more don't with Win 10. Second is that FAHControl has a known memory leak and should not be left open all of the time. Just use it when making settings or for short periods to monitor folding, alternatively use the Web Control.
